[mpich-discuss] mpich2 hangs on Ubuntu beowulf	cluster(with	NFS) with patch
    Gustavo Correa
    gus at ldeo.columbia.edu
    Mon Jan 23 10:49:27 CST 2012
Hi Konstantinos
It sounds as an ocean model code ...
Sometimes signal 11, segmentation fault, happens because of a small stack size.
Did you set the stack size on your compute nodes to a large value, or to unlimited?
You may need to ask the sys admin to change it in /etc/security/limits.conf.
I hope this helps,
Gus Correa
On Jan 23, 2012, at 6:49 AM, Konstantinos Varotsos wrote:
> Hi there I rebuilt mpich2 with the patch.
> Now when running the code I get
> [0]  ***** SCRATCH RUN *****
> [0]
> [0]
> [0]            WT =  0.2400E+00,  U* =  0.9615E+00,  L = -0.2832E+03
> [0]            DTDZ FREE =  0.3000E-02,  ZODY=  0.4176E+01
> [0]            ZO(BTM) =  0.1600E+00,  CDBTM=  0.9175E-02,  UG =   0.1000E+02
> [0]            NNX =    96,  NNY =    96,  NNZ =    96
> [0]            SFC SMLT = 1,  FILTER = 0,  ITI =      0,  ITMAX =    100
> [0]            IUPWIND = 1,  BUYNCY = 1,  NO ALISNG = 1,  ITCUT = 1
> [0]            DT =    0.000000E+00,  ZO =    0.160000E+00,  TS =    0.301928E+03,  SUBSD = 0
> [0]            BRCLICITY = 0,  METHOD = 0,  IOCEAN = 0,  IVIS = 0
> [7]  size of stats array =     4050
> [0]            DSL =    0.502859E+02
> [0]  Search for zi above the height =    0.300000E+02
> [0]  iz_min =     1
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   EXIT CODE: 11
> =   CLEANING UP REMAINING PROCESSES
> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> Thanx Kwstas
> mpich2version
> MPICH2 Version:        1.4.1p1
> MPICH2 Release date:    Thu Sep  1 13:53:02 CDT 2011
> MPICH2 Device:        ch3:nemesis
> MPICH2 configure:     --prefix=/mirror/mpiuser/mpich2-install
> MPICH2 CC:     gcc    -O2
> MPICH2 CXX:     c++   -O2
> MPICH2 F77:     ifort   -O2
> MPICH2 FC:     ifort   -O2
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
