[mpich-discuss] [EXTERNAL] Re: Modifying ssh calls for MPICH2
Kekatpure, Rohan Deodatta (-EXP)
rdkekat at sandia.gov
Tue Jan 17 16:19:12 CST 2012
I think I have more basic problems than what you are referring to:
I copy-pasted Reuti's code into a file named mpitest.c and tried to compile with
gcc -Wall mpitest.c
It failed to compile and issued following error(s):
Undefined symbols:
"_ompi_mpi_comm_world", referenced from:
_main in cc8tNiKW.o
"_MPI_Comm_rank", referenced from:
_main in cc8tNiKW.o
"_MPI_Finalize", referenced from:
_main in cc8tNiKW.o
"_MPI_Init", referenced from:
_main in cc8tNiKW.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
Rohan
On Jan 17, 2012, at 3:09 PM, Jed Brown wrote:
On Tue, Jan 17, 2012 at 16:02, Reuti <reuti at staff.uni-marburg.de<mailto:reuti at staff.uni-marburg.de>> wrote:
main(int argc, char **argv)
int node;
int i,j;
float f;
MPI_Init(NULL,NULL);
MPI_Comm_rank(MPI_COMM_WORLD, &node);
printf("Hello World from Node %d.\n", node);
for(j=0; j <= 100000; j++)
for(i=0;i <= 100000; i++)
f=i*2.718281828*i+i+i*3.141592654;
Well this is an odd spin loop because the compiler will happily remove it for you (note that MPICH2's mpicc wrapper very frequently has optimization flags in it). I would suggest sleep(3) instead, or, if you must, force the loop to actually be executed (e.g. seed the loop with the rank and use the result).
mpich-discuss mailing list mpich-discuss at mcs.anl.gov<mailto:mpich-discuss at mcs.anl.gov>
To manage subscription options or unsubscribe:
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120117/779278df/attachment.htm>
