[mpich-discuss] mpi/threads tests fail with 1.4.1p1
    Justin Bronder
    jsbronder at gmail.com
    Tue Jan 17 16:05:41 CST 2012
On 12/01/12 14:37 -0600, Rajeev Thakur wrote:
> Just remove the --enable-threads=runtime and retry.
I still get the same errors.  Isn't enable-threads=runtime the default?
> Rajeev
> On Jan 11, 2012, at 11:24 AM, Justin Bronder wrote:
> > I'm getting some new failures when running the test suite with 1.4.1p1.  It
> > looks like these are simple enough that I'm just running something
> > incorrectly.
> > I configured with:
> > --prefix=/usr --build=x86_64-pc-linux-gnu --host=x86_64-pc-linux-gnu
> > --enable-shared --with-thread-package=pthreads --enable-threads=runtime
> > --with-pm=hydra --disable-mpe --with-hwloc-prefix=/usr --disable-fast
> > --enable-smpcoll --enable-romio --enable-cxx
> > I set all the test files to use the in-source-tree mpiexec with:
> > sed -i "s,-mpiexec=[^ ]*,-mpiexec=$(pwd)/src/pm/hydra/mpiexec.hydra,g" $(find
> > ./test -name 'Makefile')
> > Then I run the tests with:
> > make CC=$(pwd)/bin/mpicc CXX=$(pwd)/bin/mpicxx F77=$(pwd)/bin/mpif77
> > FC=$(pwd)/bin/mpif90 testing
> > The only ones failing are in test/mpi/threads and they all fail with an error
> > similar to:
> > MPI_Init_thread must return MPI_THREAD_MULTIPLE in order for this test to run.
> > I've seen other reports where setting the channel for mpiexec was required,
> > but it doesn't look like that's supported by mpiexec.hydra.  What am I
> > missing?
> > Thanks in advance,
> > Justin Bronder
> > _______________________________________________
> > mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Justin Bronder
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120117/fce612cb/attachment.pgp>
