[mpich-discuss] fatal error: mpidpre.h: No such file or directory;	compilation on Ubuntu 11.04
    Alexander Beck-Ratzka
    alexander.beck-ratzka at aei.mpg.de
    Mon Jan 16 06:22:54 CST 2012
Hi Folks,
I have tried to compile the mpich on my Ubuntu driven laptop (a machine with
for CPUs). My goal was touse MPICH as a standolane solution for debug and
develop purposes.
I have followed the instructions on
http://robotics.ee.uwa.edu.au/courses/adv-comp-arch/labs/mpi/mpi_at_home.html
so I have downloaded mpich2-1.4.1p1from
http://www.mcs.anl.gov/research/projects/mpich2/
Then I have configured it with
./configure --with-device=ch3_p4 --with-mpe --with-romio --enable-fc --enable-
cxx --enable-debug --enable-traceback --prefix /opt/mpich
and  also with
--with-device=ch_shmem
--with-device=ch3_shmem
--with-device=ch_p4
The log of the configuration and the log of the make is at the end of this
Email.
The make fails always (with every device option) with the error:
[snip]
  CC              dataloop.c
In file included from ./../mpid_dataloop.h:115:0,
                 from ./dataloop.h:16,
                 from dataloop.c:12:
/home/alibeck/Downloads/mpich2-1.4.1p1/src/include/mpiimpl.h:123:21: fatal
compilation terminated.
make[5]: *** [dataloop.o] Error 1
make[5]: Leaving directory
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpid/common/datatype/dataloop'
make[4]: *** [all-redirect] Error 2
make[4]: Leaving directory
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpid/common/datatype'
make[3]: *** [all-redirect] Error 2
make[3]: Leaving directory
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpid/common'
make[2]: *** [all-redirect] Error 2
make[2]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpid'
make[1]: *** [all-redirect] Error 2
make[1]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src'
make: *** [all-redirect] Error 2
[snip]
Any suggestions?
Best wishes
Alexander
######################configure.log###############
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.63.  Invocation command line was
  $ ./configure --with-device=ch3_p4 --with-mpe --with-romio --enable-fc --
enable-cxx --enable-debug --enable-traceback --prefix /opt/mpich
## Platform. ##
hostname = NB403276-W510
uname -m = x86_64
uname -r = 2.6.38-8-generic
uname -s = Linux
uname -v = #42-Ubuntu SMP Mon Apr 11 03:31:24 UTC 2011
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = unknown
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /sbin
PATH: /bin
## Core tests. ##
Configuring MPICH2 version 1.4.1p1 with  '--with-device=ch3_p4' '--with-mpe'
'--with-romio' '--enable-fc' '--enable-cxx' '--enable-debug' '--enable-
traceback' '--prefix' '/opt/mpich'
Running on system: Linux NB403276-W510 2.6.38-8-generic #42-Ubuntu SMP Mon Apr
11 03:31:24 UTC 2011 x86_64 x86_64 x86_64 GNU/Linux
configure:3121: checking for gcc
checking for gcc... configure:3137: found /usr/bin/gcc
configure:3148: result: gcc
gcc
configure:3182: checking for C compiler version
configure:3190: gcc --version >&5
gcc (Ubuntu/Linaro 4.5.2-8ubuntu4) 4.5.2
Copyright (C) 2010 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:3194: $? = 0
configure:3201: gcc -v >&5
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/lto-
wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro
4.5.2-8ubuntu4' --with-bugurl=file:///usr/share/doc/gcc-4.5/README.Bugs --
enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.5
--enable-shared --enable-multiarch --with-multiarch-defaults=x86_64-linux-gnu
--enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib/x86_64-
linux-gnu --without-included-gettext --enable-threads=posix --with-gxx-
include-dir=/usr/include/c++/4.5 --libdir=/usr/lib/x86_64-linux-gnu --enable-
nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-
libstdcxx-time=yes --enable-plugin --enable-gold --enable-ld=default --with-
plugin-ld=ld.gold --enable-objc-gc --disable-werror --with-arch-32=i686 --
with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --
host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.5.2 (Ubuntu/Linaro 4.5.2-8ubuntu4)
configure:3205: $? = 0
configure:3212: gcc -V >&5
gcc: '-V' option must have argument
configure:3216: $? = 1
configure:3239: checking for C compiler default output file name
checking for C compiler default output file name... configure:3261: gcc
conftest.c   >&5
configure:3265: $? = 0
configure:3303: result: a.out
a.out
configure:3322: checking whether the C compiler works
checking whether the C compiler works... configure:3332: ./a.out
configure:3336: $? = 0
configure:3355: result: yes
yes
configure:3362: checking whether we are cross compiling
checking whether we are cross compiling... configure:3364: result: no
no
configure:3367: checking for suffix of executables
checking for suffix of executables... configure:3374: gcc -o conftest
conftest.c   >&5
configure:3378: $? = 0
configure:3404: result:
configure:3410: checking for suffix of object files
checking for suffix of object files... configure:3436: gcc -c     conftest.c >&5
configure:3440: $? = 0
configure:3465: result: o
o
configure:3469: checking whether we are using the GNU C compiler
checking whether we are using the GNU C compiler... configure:3498: gcc -c
conftest.c >&5
configure:3505: $? = 0
configure:3522: result: yes
yes
configure:3531: checking whether gcc accepts -g
checking whether gcc accepts -g... configure:3561: gcc -c -g   conftest.c >&5
configure:3568: $? = 0
configure:3669: result: yes
yes
configure:3686: checking for gcc option to accept ISO C89
checking for gcc option to accept ISO C89... configure:3760: gcc  -c
conftest.c >&5
configure:3767: $? = 0
configure:3790: result: none needed
none needed
configure:3826: checking how to run the C preprocessor
checking how to run the C preprocessor... configure:3866: gcc -E   conftest.c
configure:3873: $? = 0
configure:3904: gcc -E   conftest.c
conftest.c:9:28: fatal error: ac_nonexistent.h: No such file or directory
configure:3911: $? = 1
configure: failed program was:
| /* confdefs.h.  */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define USE_SMP_COLLECTIVES 1
| /* end confdefs.h.  */
| #include <ac_nonexistent.h>
configure:3944: result: gcc -E
gcc -E
configure:3973: gcc -E   conftest.c
configure:3980: $? = 0
configure:4011: gcc -E   conftest.c
configure:4018: $? = 1
| /* confdefs.h.  */
configure:4080: checking build system type
checking build system type... configure:4098: result: x86_64-unknown-linux-gnu
configure:4120: checking host system type
checking host system type... configure:4135: result: x86_64-unknown-linux-gnu
configure:4172: checking for grep that handles long lines and -e
checking for grep that handles long lines and -e... configure:4232: result:
/bin/grep
/bin/grep
configure:4237: checking for fgrep
checking for fgrep... configure:4301: result: /bin/grep -F
/bin/grep -F
configure:6845: ===== configuring src/mpl =====
configure: ===== configuring src/mpl =====
configure:6952: executing:
/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/configure  '--with-
device=ch3_p4' '--with-mpe' '--with-romio' '--enable-fc' '--enable-cxx' '--
enable-debug' '--enable-traceback' '--prefix' '/opt/mpich' --disable-option-
checking
configure: executing: /home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/configure
'--with-device=ch3_p4' '--with-mpe' '--with-romio' '--enable-fc' '--enable-
cxx' '--enable-debug' '--enable-traceback' '--prefix' '/opt/mpich' --disable-
option-checking
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared
libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking for variable argument list macro functionality... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking valgrind.h usability... no
checking valgrind.h presence... no
checking for valgrind.h... no
checking memcheck.h usability... no
checking memcheck.h presence... no
checking for memcheck.h... no
checking valgrind/valgrind.h usability... no
checking valgrind/valgrind.h presence... no
checking for valgrind/valgrind.h... no
checking valgrind/memcheck.h usability... no
checking valgrind/memcheck.h presence... no
checking for valgrind/memcheck.h... no
checking helgrind.h usability... no
checking helgrind.h presence... no
checking for helgrind.h... no
checking valgrind/helgrind.h usability... no
checking valgrind/helgrind.h presence... no
checking for valgrind/helgrind.h... no
checking drd.h usability... no
checking drd.h presence... no
checking for drd.h... no
checking valgrind/drd.h usability... no
checking valgrind/drd.h presence... no
checking for valgrind/drd.h... no
checking whether the valgrind headers are broken or too old... yes
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for strncmp... yes
checking whether strncmp needs a declaration... no
checking for putenv... yes
checking whether putenv needs a declaration... no
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating localdefs
config.status: creating include/config.h
config.status: include/config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing include/mplconfig.h commands
config.status: creating include/mplconfig.h - prefix MPL for include/config.h
defines
config.status: include/mplconfig.h is unchanged
configure:6971: ===== done with src/mpl configure =====
configure: ===== done with src/mpl configure =====
WRAPPER_LIBS(='') does not contain '-lmpl', prepending
CPPFLAGS(='') does not contain '-
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include', appending
CPPFLAGS(=' -I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include') does
not contain '-I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include',
appending
LIBS(=' ') does not contain '-lopa', prepending
configure:7069: gcc -o conftest     -
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include -
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include   conftest.c -lopa
>&5
conftest.c:12:28: fatal error: opa_primitives.h: No such file or directory
configure:7076: $? = 1
| /* confdefs.h.  */
| #define HAVE_ERROR_CHECKING MPID_ERROR_LEVEL_ALL
| #define MPICH_ERROR_MSG_LEVEL MPICH_ERROR_MSG_ALL
| #define USE_LOGGING MPID_LOGGING_NONE
| #include "opa_primitives.h"
| int
| main ()
| OPA_int_t i;
| OPA_store_int(i,10);
| OPA_fetch_and_incr_int(&i,5);
|   return 0;
CPPFLAGS(=' -I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include -
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include') does not contain '-
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src', appending
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src') does not contain '-
configure:7150: ===== configuring src/openpa =====
configure: ===== configuring src/openpa =====
configure:7257: executing:
/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/configure --with-atomic-
primitives=auto_allow_emulation '--with-device=ch3_p4' '--with-mpe' '--with-
romio' '--enable-fc' '--enable-cxx' '--enable-debug' '--enable-traceback' '--
prefix' '/opt/mpich' --disable-option-checking
libraries... yes
checking for gcc... (cached) gcc
checking whether to enable assertions... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking atomic.h usability... no
checking atomic.h presence... no
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for inline... inline
checking for pthread_create in -lpthread... yes
checking for pthread_yield... yes
checking if 100 threads can be run at once... yes
checking size of void *... 8
checking size of int... 4
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 primitives... yes
checking for support for gcc x86 primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... yes
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: src/config.h is unchanged
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
config.status: src/opa_config.h is unchanged
configure:7276: ===== done with src/openpa configure =====
configure: ===== done with src/openpa configure =====
WRAPPER_LIBS(='-lmpl ') does not contain '-lopa', prepending
configure:7789: WARNING: Device ch3_p4 is unknown
configure: WARNING: Device ch3_p4 is unknown
sourcing /home/alibeck/Downloads/mpich2-1.4.1p1/src/pm/hydra/mpich2prereq
configure:8062: checking whether the compiler defines __func__
checking whether the compiler defines __func__... configure:8099: gcc -o
conftest     -I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include -
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src -
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src   conftest.c   >&5
configure:8103: $? = 0
configure:8109: ./conftest
configure:8113: $? = 0
configure:8186: result: yes
yes
configure:8197: checking whether the compiler defines __FUNC__
checking whether the compiler defines __FUNC__... configure:8234: gcc -o
conftest.c: In function 'foo':
conftest.c:24:20: error: '__FUNC__' undeclared (first use in this function)
conftest.c:24:20: note: each undeclared identifier is reported only once for
each function it appears in
configure:8238: $? = 1
configure: program exited with status 1
| /* confdefs.h.  */
| #define MPICH_THREAD_LEVEL MPI_THREAD_SINGLE
| #define MPIU_THREAD_GRANULARITY MPIU_THREAD_GRANULARITY_SINGLE
| #define MPIU_HANDLE_ALLOCATION_METHOD MPIU_HANDLE_ALLOCATION_MUTEX
| #define MPIU_THREAD_REFCOUNT MPIU_REFCOUNT_NONE
| #define HAVE_ROMIO 1
| #define HAVE__FUNC__ /**/
| #include <string.h>
| int foo(void);
| int foo(void)
|     return (strcmp(__FUNC__, "foo") == 0);
| int main(int argc, char ** argv)
|     return (foo() ? 0 : 1);
configure:8321: result: no
no
configure:8332: checking whether the compiler sets __FUNCTION__
checking whether the compiler sets __FUNCTION__... configure:8369: gcc -o
configure:8373: $? = 0
configure:8379: ./conftest
configure:8383: $? = 0
configure:8456: result: yes
yes
configure:8474: checking whether C compiler accepts option -O2
checking whether C compiler accepts option -O2... configure:8544: gcc -o
pac_test1.log 2>&1
configure:8551: $? = 0
configure:8603: gcc -o conftest -O2     -
pac_test2.log 2>&1
configure:8610: $? = 0
configure:8625: diff -b pac_test1.log pac_test2.log > pac_test.log
configure:8628: $? = 0
configure:8749: result: yes
yes
configure:8765: checking whether C compiler option -O2 works with an invalid
prototype program
checking whether C compiler option -O2 works with an invalid prototype
program... configure:8783: gcc -o conftest -O2     -
conftest.c: In function 'main':
conftest.c:20:14: warning: 'return' with a value, in function returning void
configure:8790: $? = 0
configure:8809: result: yes
yes
configure:8814: checking whether routines compiled with -O2 can be linked with
ones compiled without -O2
checking whether routines compiled with -O2 can be linked with ones compiled
without -O2... configure:8872: gcc -c     -
pac_test3.log 2>&1
configure:8879: $? = 0
configure:8887: mv conftest.o pac_conftest.o
configure:8890: $? = 0
configure:8951: gcc -o conftest     -
pac_conftest.o   > pac_test4.log 2>&1
configure:8958: $? = 0
configure:9025: gcc -o conftest -O2     -
pac_conftest.o   > pac_test5.log 2>&1
configure:9032: $? = 0
configure:9047: diff -b pac_test4.log pac_test5.log > pac_test.log
configure:9050: $? = 0
configure:9219: result: yes
yes
configure:9255: checking for type of weak symbol alias support
checking for type of weak symbol alias support... configure:9289: gcc -o
conftest    -O2  -I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include -
configure:9296: $? = 0
configure:9344: gcc -c    -O2  -
configure:9351: $? = 0
configure:9358: mv conftest.o pac_conftest.o
configure:9361: $? = 0
configure:9416: gcc -o conftest    -O2  -
pac_conftest.o   >&5
configure:9423: $? = 0
configure:9455: gcc -c    -O2  -
configure:9462: $? = 0
configure:9469: mv conftest.o pac_conftest.o
configure:9472: $? = 0
configure:9528: gcc -o conftest    -O2  -
pac_conftest.o   >&5
configure:9535: $? = 0
configure:9789: result: pragma weak
pragma weak
configure:9816: checking whether __attribute__ ((weak)) allowed
checking whether __attribute__ ((weak)) allowed... configure:9843: gcc -c    -
configure:9850: $? = 0
configure:9865: result: yes
yes
configure:9869: checking whether __attribute__ ((weak_import)) allowed
checking whether __attribute__ ((weak_import)) allowed... configure:9896: gcc -
c    -O2  -I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include -
conftest.c:20:1: warning: 'weak_import' attribute directive ignored
configure:9903: $? = 0
configure:9918: result: yes
yes
configure:9921: checking whether __attribute__((weak,alias(...))) allowed
checking whether __attribute__((weak,alias(...))) allowed... configure:9948:
gcc -c    -O2  -I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include -
conftest.c:20:5: error: 'foo' aliased to undefined symbol '__foo'
configure:9955: $? = 1
| /* confdefs.h.  */
| #define HAVE__FUNCTION__ /**/
| #define HAVE_PRAGMA_WEAK 1
| int foo(int) __attribute__((weak,alias("__foo")));
| int
| main ()
| int a;
|   return 0;
configure:9970: result: no
no
configure:9984: checking for multiple weak symbol support
checking for multiple weak symbol support... configure:10017: gcc -c    -O2  -
configure:10024: $? = 0
configure:10031: mv conftest.o pac_conftest.o
configure:10034: $? = 0
configure:10089: gcc -o conftest    -O2  -
pac_conftest.o   >&5
configure:10096: $? = 0
configure:10167: result: yes
yes
configure:10289: checking for ifort
checking for ifort... configure:10319: result: no
no
configure:10289: checking for pgf77
checking for pgf77... configure:10319: result: no
no
configure:10289: checking for af77
checking for af77... configure:10319: result: no
no
configure:10289: checking for xlf
checking for xlf... configure:10319: result: no
no
configure:10289: checking for frt
checking for frt... configure:10319: result: no
no
configure:10289: checking for cf77
checking for cf77... configure:10319: result: no
no
configure:10289: checking for fort77
checking for fort77... configure:10319: result: no
no
configure:10289: checking for fl32
checking for fl32... configure:10319: result: no
no
checking for fort... configure:10319: result: no
no
configure:10289: checking for ifc
checking for ifc... configure:10319: result: no
no
configure:10289: checking for efc
checking for efc... configure:10319: result: no
no
configure:10289: checking for ftn
checking for ftn... configure:10319: result: no
no
configure:10289: checking for gfortran
checking for gfortran... configure:10305: found /usr/bin/gfortran
configure:10316: result: gfortran
gfortran
configure:10342: checking for Fortran 77 compiler version
configure:10350: gfortran --version >&5
GNU Fortran (Ubuntu/Linaro 4.5.2-8ubuntu4) 4.5.2
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
configure:10354: $? = 0
configure:10361: gfortran -v >&5
COLLECT_GCC=gfortran
wrapper
Thread model: posix
configure:10365: $? = 0
configure:10372: gfortran -V >&5
gfortran: '-V' option must have argument
configure:10376: $? = 1
configure:10384: checking whether we are using the GNU Fortran 77 compiler
checking whether we are using the GNU Fortran 77 compiler... configure:10403:
gfortran -c   conftest.F >&5
configure:10410: $? = 0
configure:10427: result: yes
yes
configure:10433: checking whether gfortran accepts -g
checking whether gfortran accepts -g... configure:10450: gfortran -c -g
conftest.f >&5
configure:10457: $? = 0
configure:10473: result: yes
yes
configure:10532: checking whether Fortran 77 compiler accepts option -O2
checking whether Fortran 77 compiler accepts option -O2... configure:10591:
gfortran -o conftest     conftest.f   > pac_test1.log 2>&1
configure:10598: $? = 0
configure:10650: gfortran -o conftest -O2     conftest.f   > pac_test2.log 2>&1
configure:10657: $? = 0
configure:10672: diff -b pac_test1.log pac_test2.log > pac_test.log
configure:10675: $? = 0
configure:10796: result: yes
yes
configure:10801: checking whether routines compiled with -O2 can be linked with
without -O2... configure:10854: gfortran -c   conftest.f > pac_test3.log 2>&1
configure:10861: $? = 0
configure:10869: mv conftest.o pac_conftest.o
configure:10872: $? = 0
configure:10924: gfortran -o conftest -O2     conftest.f pac_conftest.o   >
pac_test4.log 2>&1
configure:10931: $? = 0
configure:10946: diff -b pac_test2.log pac_test4.log > pac_test.log
configure:10949: $? = 0
configure:11070: result: yes
yes
configure:11108: checking how to get verbose linking output from gfortran
checking how to get verbose linking output from gfortran... configure:11124:
gfortran -c   -O2 conftest.f >&5
configure:11131: $? = 0
configure:11153: gfortran -o conftest -O2 -v conftest.f
Thread model: posix
 /usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/f951 conftest.f -ffixed-
form -quiet -dumpbase conftest.f -mtune=generic -march=x86-64 -auxbase
conftest -O2 -version -fintrinsic-modules-path /usr/lib/x86_64-linux-
gnu/gcc/x86_64-linux-gnu/4.5.2/finclude -o /tmp/ccULtHlG.s
GNU Fortran (Ubuntu/Linaro 4.5.2-8ubuntu4) version 4.5.2 (x86_64-linux-gnu)
	compiled by GNU C version 4.5.2, GMP version 4.3.2, MPFR version 3.0.0-p8,
MPC version 0.9
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
MPC version 0.9
 as -V -Qy --64 -o /tmp/cc9isxMo.o /tmp/ccULtHlG.s
GNU assembler version 2.21.0 (x86_64-linux-gnu) using BFD version (GNU
Binutils for Ubuntu) 2.21.0.20110327
 /usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/collect2 --build-id --
eh-frame-hdr -m elf_x86_64 --hash-style=gnu -dynamic-linker /lib64/ld-linux-
x86-64.so.2 -z relro -o conftest /usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-
gnu/4.5.2/../../../crt1.o /usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-
gnu/4.5.2/../../../crti.o /usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-
gnu/4.5.2/crtbegin.o -L/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2 -
L/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/../../.. -
L/usr/lib/x86_64-linux-gnu /tmp/cc9isxMo.o -lgfortran -lm -lgcc_s -lgcc -lc -
lgcc_s -lgcc /usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/crtend.o
/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/../../../crtn.o
configure:11222: result: -v
-v
configure:11224: checking for Fortran 77 libraries of gfortran
checking for Fortran 77 libraries of gfortran... configure:11247: gfortran -o
Thread model: posix
gnu/gcc/x86_64-linux-gnu/4.5.2/finclude -o /tmp/ccIiboIO.s
MPC version 0.9
MPC version 0.9
 as -V -Qy --64 -o /tmp/ccLdtCix.o /tmp/ccIiboIO.s
L/usr/lib/x86_64-linux-gnu /tmp/ccLdtCix.o -lgfortran -lm -lgcc_s -lgcc -lc -
configure:11424: result:  -L/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-
gnu/4.5.2 -L/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/../../.. -
L/usr/lib/x86_64-linux-gnu -lgfortran -lm
 -L/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2 -L/usr/lib/x86_64-
linux-gnu/gcc/x86_64-linux-gnu/4.5.2/../../.. -L/usr/lib/x86_64-linux-gnu -
lgfortran -lm
configure:11440: checking whether gfortran accepts the FLIBS found by autoconf
checking whether gfortran accepts the FLIBS found by autoconf...
configure:11462: gfortran -o conftest   -O2   conftest.f   >&5
configure:11469: $? = 0
configure:11478: result: yes
yes
configure:11548: checking whether gcc links with FLIBS found by autoconf
checking whether gcc links with FLIBS found by autoconf... configure:11583: gcc
-o conftest    -O2  -I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include -
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src   conftest.c  -
L/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2 -L/usr/lib/x86_64-linux-
gnu/gcc/x86_64-linux-gnu/4.5.2/../../.. -L/usr/lib/x86_64-linux-gnu -lgfortran
-lm   >&5
configure:11590: $? = 0
configure:11599: result: yes
yes
configure:11681: checking whether Fortran 77 and C objects are compatible
checking whether Fortran 77 and C objects are compatible... configure:11770:
configure:11777: $? = 0
configure:11784: mv conftest.o pac_conftest.o
configure:11787: $? = 0
configure:11802: gfortran -o conftest   -O2   conftest.f pac_conftest.o   >&5
configure:11809: $? = 0
configure:11819: result: yes
yes
configure:12045: checking for linker for Fortran main program
checking for linker for Fortran main program... configure:12076: gcc -c    -O2
configure:12083: $? = 0
configure:12164: gcc -c    -O2  -
configure:12171: $? = 0
configure:12178: mv conftest.o pac_conftest.o
configure:12181: $? = 0
configure:12196: gfortran -o conftest   -O2   conftest.f pac_conftest.o   >&5
configure:12203: $? = 0
configure:12212: result: Use Fortran to link programs
configure:12388: checking for Fortran 77 name mangling
checking for Fortran 77 name mangling... configure:12416: gfortran -c   -O2
conftest.f >&5
configure:12423: $? = 0
configure:12430: mv conftest.o f77conftest.o
configure:12433: $? = 0
configure:12468: gcc -o conftest    -O2  -
f77conftest.o  -L/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2 -
L/usr/lib/x86_64-linux-gnu -lgfortran -lm   >&5
configure:12475: $? = 0
configure:12672: result: lower uscore
lower uscore
configure:12735: checking for egrep
checking for egrep... configure:12799: result: /bin/grep -E
/bin/grep -E
configure:12804: checking for ANSI C header files
checking for ANSI C header files... configure:12834: gcc -c    -O2  -
configure:12841: $? = 0
configure:12940: gcc -o conftest    -O2  -
configure:12944: $? = 0
configure:12950: ./conftest
configure:12954: $? = 0
configure:12972: result: yes
yes
configure:12998: checking for libraries to link Fortran main with C stdio
routines
checking for libraries to link Fortran main with C stdio routines...
configure:13034: gcc -c    -O2  -
configure:13041: $? = 0
configure:13048: mv conftest.o pac_conftest.o
configure:13051: $? = 0
configure:13076: gfortran -o conftest   -O2   conftest.f pac_conftest.o    >&5
configure:13083: $? = 0
configure:13134: result: none
none
configure:13187: checking whether Fortran init will work with C
checking whether Fortran init will work with C... configure:13215: gfortran -c
-O2 conftest.f >&5
configure:13222: $? = 0
configure:13229: mv conftest.o pac_f77conftest.o
configure:13232: $? = 0
configure:13286: gcc -o conftest    -O2  -
pac_f77conftest.o   >&5
configure:13293: $? = 0
configure:13334: result: yes
yes
configure:13420: checking for ifort
checking for ifort... configure:13450: result: no
no
configure:13420: checking for pgf90
checking for pgf90... configure:13450: result: no
no
configure:13420: checking for pathf90
checking for pathf90... configure:13450: result: no
no
configure:13420: checking for pathf95
checking for pathf95... configure:13450: result: no
no
configure:13420: checking for xlf90
checking for xlf90... configure:13450: result: no
no
configure:13420: checking for xlf95
checking for xlf95... configure:13450: result: no
no
configure:13420: checking for xlf2003
checking for xlf2003... configure:13450: result: no
no
configure:13420: checking for f90
checking for f90... configure:13450: result: no
no
configure:13420: checking for epcf90
checking for epcf90... configure:13450: result: no
no
configure:13420: checking for f95
checking for f95... configure:13436: found /usr/bin/f95
configure:13447: result: f95
f95
configure:13473: checking for Fortran compiler version
configure:13481: f95 --version >&5
configure:13485: $? = 0
configure:13492: f95 -v >&5
COLLECT_GCC=f95
wrapper
Thread model: posix
configure:13496: $? = 0
configure:13503: f95 -V >&5
f95: '-V' option must have argument
configure:13507: $? = 1
configure:13515: checking whether we are using the GNU Fortran compiler
checking whether we are using the GNU Fortran compiler... configure:13534: f95
-c    conftest.F >&5
configure:13541: $? = 0
configure:13558: result: yes
yes
configure:13564: checking whether f95 accepts -g
checking whether f95 accepts -g... configure:13581: f95 -c -g  conftest.f >&5
configure:13588: $? = 0
configure:13604: result: yes
yes
configure:13936: checking for extension for Fortran 90 programs
checking for extension for Fortran 90 programs... configure:13957: f95 -c
conftest.f90 >&5
configure:13964: $? = 0
configure:13970: result: f90
f90
configure:14037: checking whether the Fortran 90 compiler (f95    ) works
checking whether the Fortran 90 compiler (f95    ) works... configure:14054:
f95 -o conftest      conftest.f90   >&5
configure:14061: $? = 0
configure:14071: result: yes
yes
configure:14073: checking whether the Fortran 90 compiler (f95    ) is a cross-
compiler
checking whether the Fortran 90 compiler (f95    ) is a cross-compiler...
configure:14085: f95 -o conftest      conftest.f90   >&5
configure:14089: $? = 0
configure:14095: ./conftest
configure:14099: $? = 0
configure:14115: result: no
no
configure:14143: checking whether Fortran 90 compiler works with Fortran 77
compiler
checking whether Fortran 90 compiler works with Fortran 77 compiler...
configure:14177: gfortran -c   -O2 conftest.f >&5
configure:14184: $? = 0
configure:14192: mv conftest.o pac_f77conftest.o
configure:14195: $? = 0
configure:14222: f95 -o conftest      conftest.f90 pac_f77conftest.o   >&5
configure:14229: $? = 0
configure:14287: result: yes
yes
configure:14350: checking whether Fortran 77 accepts ! for comments
checking whether Fortran 77 accepts ! for comments... configure:14374: gfortran
configure:14381: $? = 0
configure:14406: result: yes
yes
configure:14416: checking for include directory flag for Fortran
checking for include directory flag for Fortran... configure:14449: gfortran -c
-I src   -O2 conftest.f >&5
configure:14456: $? = 0
configure:14484: result: -I
-I
configure:14501: checking for Fortran 77 flag for library directories
checking for Fortran 77 flag for library directories... configure:14526:
configure:14533: $? = 0
configure:14541: mv conftest.o pac_f77conftest.o
configure:14544: $? = 0
configure:14547: test -d conftestdir || mkdir conftestdir
configure:14550: $? = 0
configure:14553: ar cr conftestdir/libf77conftest.a pac_f77conftest.o
configure:14556: $? = 0
configure:14559: ranlib conftestdir/libf77conftest.a
configure:14562: $? = 0
configure:14586: gfortran -o conftest   -O2 -Lconftestdir   conftest.f -
lf77conftest   >&5
configure:14593: $? = 0
configure:14633: result: -L
-L
configure:14858: checking whether Fortran 77 compiler processes .F files with C
preprocessor
checking whether Fortran 77 compiler processes .F files with C preprocessor...
configure:14885: gfortran -c   -O2  -
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src conftest.F >&5
configure:14892: $? = 0
configure:14992: result: yes
yes
configure:15152: checking for Fortran compiler version
configure:15160: f95 --version >&5
configure:15164: $? = 0
configure:15171: f95 -v >&5
COLLECT_GCC=f95
wrapper
Thread model: posix
configure:15175: $? = 0
configure:15182: f95 -V >&5
configure:15186: $? = 1
configure:15194: checking whether we are using the GNU Fortran compiler
checking whether we are using the GNU Fortran compiler... (cached)
configure:15237: result: yes
yes
configure:15243: checking whether f95 accepts -g
checking whether f95 accepts -g... (cached) configure:15283: result: yes
yes
configure:15319: checking whether the Fortran 90 compiler (f95    ) works
checking whether the Fortran 90 compiler (f95    ) works... configure:15336:
configure:15343: $? = 0
configure:15353: result: yes
yes
configure:15355: checking whether the Fortran 90 compiler (f95    ) is a cross-
compiler
configure:15367: f95 -o conftest      conftest.f90   >&5
configure:15371: $? = 0
configure:15377: ./conftest
configure:15381: $? = 0
configure:15397: result: no
no
configure:15452: checking for Fortran 90 module extension
checking for Fortran 90 module extension... configure:15480: f95 -c
conftest.f90 >&5
configure:15487: $? = 0
configure:15547: result: mod
mod
configure:15557: checking for Fortran 90 module include flag
checking for Fortran 90 module include flag... configure:15592: f95 -c
conftest.f90 >&5
configure:15599: $? = 0
configure:15652: f95 -c   -Iconftestdir  conftest.f90 >&5
configure:15659: $? = 0
configure:15749: result: -I
-I
configure:15789: checking whether Fortran 90 compiler accepts option -O2
checking whether Fortran 90 compiler accepts option -O2... configure:15848: f95
-o conftest      conftest.f90   > pac_test1.log 2>&1
configure:15855: $? = 0
configure:15907: f95 -o conftest -O2      conftest.f90   > pac_test2.log 2>&1
configure:15914: $? = 0
configure:15929: diff -b pac_test1.log pac_test2.log > pac_test.log
configure:15932: $? = 0
configure:16053: result: yes
yes
configure:16058: checking whether routines compiled with -O2 can be linked with
without -O2... configure:16111: f95 -c    conftest.f90 > pac_test3.log 2>&1
configure:16118: $? = 0
configure:16126: mv conftest.o pac_conftest.o
configure:16129: $? = 0
configure:16181: f95 -o conftest -O2      conftest.f90 pac_conftest.o   >
pac_test4.log 2>&1
configure:16188: $? = 0
configure:16203: diff -b pac_test2.log pac_test4.log > pac_test.log
configure:16206: $? = 0
configure:16327: result: yes
yes
configure:16359: checking whether Fortran 90 compiler processes .F90 files with
C preprocessor
checking whether Fortran 90 compiler processes .F90 files with C
preprocessor... configure:16386: f95 -c   -O2  -
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src  conftest.F90 >&5
configure:16393: $? = 0
configure:16493: result: yes
yes
configure:16514: checking what libraries are needed to link Fortran90 programs
with C routines that use stdio
checking what libraries are needed to link Fortran90 programs with C routines
that use stdio... configure:16550: gcc -c    -O2  -
configure:16557: $? = 0
configure:16565: mv conftest.o pac_conftest.o
configure:16568: $? = 0
configure:16591: f95 -o conftest   -O2    conftest.f90 pac_conftest.o   >&5
configure:16598: $? = 0
configure:16684: result: none
none
configure:16701: checking for Fortran 90 compiler vendor
checking for Fortran 90 compiler vendor... configure:16710: f95 --version
</dev/null >conftest.txt 2>&1
configure:16713: $? = 0
configure:16750: result: gnu
gnu
configure:16967: checking for g++
checking for g++... configure:16983: found /usr/bin/g++
configure:16994: result: g++
g++
configure:17021: checking for C++ compiler version
configure:17029: g++ --version >&5
g++ (Ubuntu/Linaro 4.5.2-8ubuntu4) 4.5.2
configure:17033: $? = 0
configure:17040: g++ -v >&5
COLLECT_GCC=g++
wrapper
Thread model: posix
configure:17044: $? = 0
configure:17051: g++ -V >&5
g++: '-V' option must have argument
configure:17055: $? = 1
configure:17058: checking whether we are using the GNU C++ compiler
checking whether we are using the GNU C++ compiler... configure:17087: g++ -c
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src conftest.cpp >&5
configure:17094: $? = 0
configure:17111: result: yes
yes
configure:17120: checking whether g++ accepts -g
checking whether g++ accepts -g... configure:17150: g++ -c -g  -
configure:17157: $? = 0
configure:17258: result: yes
yes
configure:17294: checking whether the C++ compiler g++ can build an executable
checking whether the C++ compiler g++ can build an executable...
configure:17334: g++ -o conftest    -
configure:17341: $? = 0
configure:17367: result: yes
yes
configure:17376: checking whether C++ compiler works with string
checking whether C++ compiler works with string... configure:17410: g++ -c    -
configure:17417: $? = 0
configure:17438: result: yes
yes
configure:17451: checking whether the compiler supports exceptions
checking whether the compiler supports exceptions... configure:17484: g++ -c
configure:17491: $? = 0
configure:17513: result: yes
yes
configure:17523: checking whether the compiler recognizes bool as a built-in
type
checking whether the compiler recognizes bool as a built-in type...
configure:17560: g++ -c    -
configure:17567: $? = 0
configure:17589: result: yes
yes
configure:17599: checking whether the compiler implements namespaces
checking whether the compiler implements namespaces... configure:17632: g++ -c
configure:17639: $? = 0
configure:17661: result: yes
yes
configure:17682: checking whether <iostream> available
checking whether <iostream> available... configure:17711: g++ -c    -
configure:17718: $? = 0
configure:17733: result: yes
yes
configure:17739: checking whether the compiler implements the namespace std
checking whether the compiler implements the namespace std... configure:17776:
g++ -c    -I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include -
configure:17783: $? = 0
configure:17806: result: yes
yes
configure:17820: checking whether <math> available
checking whether <math> available... configure:17849: g++ -c    -
conftest.cpp:32:16: fatal error: math: No such file or directory
configure:17856: $? = 1
| /* confdefs.h.  */
| #define USE_WEAK_SYMBOLS 1
| #define HAVE_MULTIPLE_PRAGMA_WEAK 1
| #define HAVE_LONG_LONG 1
| #define STDCALL
| #define F77_NAME_LOWER_USCORE 1
| #define STDC_HEADERS 1
| #define HAVE_MPI_F_INIT_WORKS_WITH_C 1
| #define HAVE_FORTRAN_BINDING 1
| #define HAVE_CXX_EXCEPTIONS /**/
| #define HAVE_NAMESPACES /**/
| #define HAVE_NAMESPACE_STD /**/
| #include <math>
| int
| main ()
| using namespace std;
|   return 0;
configure:17871: result: no
no
configure:17936: checking for GNU g++ version
checking for GNU g++ version... configure:17974: g++ -o conftest    -
configure:17978: $? = 0
configure:17984: ./conftest
configure:17988: $? = 0
configure:18005: result: 4 . 5
4 . 5
configure:18054: checking whether C++ compiler accepts option -O2
checking whether C++ compiler accepts option -O2... configure:18124: g++ -o
pac_test1.log 2>&1
configure:18131: $? = 0
configure:18183: g++ -o conftest -O2    -
pac_test2.log 2>&1
configure:18190: $? = 0
configure:18205: diff -b pac_test1.log pac_test2.log > pac_test.log
configure:18208: $? = 0
configure:18329: result: yes
yes
configure:18334: checking whether routines compiled with -O2 can be linked with
without -O2... configure:18392: g++ -c    -
pac_test3.log 2>&1
configure:18399: $? = 0
configure:18407: mv conftest.o pac_conftest.o
configure:18410: $? = 0
configure:18472: g++ -o conftest -O2    -
configure:18479: $? = 0
configure:18494: diff -b pac_test2.log pac_test4.log > pac_test.log
configure:18497: $? = 0
configure:18618: result: yes
yes
configure:18678: checking for perl
checking for perl... configure:18696: found /usr/bin/perl
configure:18708: result: /usr/bin/perl
/usr/bin/perl
configure:18721: checking for ar
checking for ar... configure:18737: found /usr/bin/ar
configure:18748: result: ar
ar
configure:18782: checking for ranlib
checking for ranlib... configure:18798: found /usr/bin/ranlib
configure:18809: result: ranlib
ranlib
configure:18828: checking for killall
checking for killall... configure:18844: found /usr/bin/killall
configure:18855: result: killall
killall
configure:18890: checking for a BSD-compatible install
checking for a BSD-compatible install... configure:18958: result:
/usr/bin/install -c
/usr/bin/install -c
configure:18987: checking whether install works
checking whether install works... configure:18995: result: yes
yes
configure:19103: checking whether install breaks libraries
checking whether install breaks libraries... configure:19130: gcc -c    -O2  -
configure:19137: $? = 0
configure:19172: gcc -o conftest    -O2  -
libconftest1.a >&5
configure:19179: $? = 0
configure:19257: result: no
no
configure:19278: checking whether mkdir -p works
checking whether mkdir -p works... configure:19294: result: yes
yes
configure:19312: checking for make
checking for make... configure:19328: found /usr/bin/make
configure:19339: result: make
make
configure:19353: checking whether clock skew breaks make
checking whether clock skew breaks make... configure:19378: result: no
no
configure:19388: checking whether make supports include
checking whether make supports include... configure:19416: result: yes
yes
configure:19425: checking whether make allows comments in actions
checking whether make allows comments in actions... configure:19452: result:
yes
yes
configure:19466: checking for virtual path format
checking for virtual path format... configure:19509: result: VPATH
VPATH
configure:19519: checking whether make sets CFLAGS
checking whether make sets CFLAGS... configure:19545: result: yes
yes
configure:19594: checking for bash
checking for bash... configure:19612: found /bin/bash
configure:19624: result: /bin/bash
/bin/bash
configure:19647: checking whether /bin/bash supports arrays
checking whether /bin/bash supports arrays... configure:19656: result: yes
yes
configure:22125: checking for doctext
checking for doctext... configure:22156: result: false
false
configure:22166: checking for location of doctext style files
checking for location of doctext style files... configure:22183: result:
unavailable
unavailable
configure:22195: checking for an ANSI C-conforming const
checking for an ANSI C-conforming const... configure:22270: gcc -c    -O2  -
configure:22277: $? = 0
configure:22292: result: yes
yes
configure:22302: checking for working volatile
checking for working volatile... configure:22331: gcc -c    -O2  -
configure:22338: $? = 0
configure:22353: result: yes
yes
configure:22363: checking for C/C++ restrict keyword
checking for C/C++ restrict keyword... configure:22398: gcc -c    -O2  -
configure:22405: $? = 0
configure:22423: result: __restrict
__restrict
configure:22439: checking for inline
checking for inline... configure:22465: gcc -c    -O2  -
configure:22472: $? = 0
configure:22490: result: inline
inline
configure:22514: checking whether __attribute__ allowed
checking whether __attribute__ allowed... configure:22541: gcc -c    -O2  -
configure:22548: $? = 0
configure:22563: result: yes
yes
configure:22565: checking whether __attribute__((format)) allowed
checking whether __attribute__((format)) allowed... configure:22592: gcc -c
configure:22599: $? = 0
configure:22614: result: yes
yes
configure:22640: checking whether byte ordering is bigendian
checking whether byte ordering is bigendian... configure:22665: gcc -c    -O2
conftest.c:38:13: error: expected '=', ',', ';', 'asm' or '__attribute__'
before 'a'
configure:22672: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_CXX_BINDING 1
| #define FILE_NAMEPUB_BASEDIR "."
| #define USE_FILE_FOR_NAMEPUB 1
| #define HAVE_NAMEPUB_SERVICE 1
| #define restrict __restrict
| #define HAVE_GCC_ATTRIBUTE 1
| #ifndef __APPLE_CC__
| 	       not a universal capable compiler
| 	     #endif
| 	     typedef int dummy;
configure:22722: gcc -c    -O2  -
configure:22729: $? = 0
configure:22761: gcc -c    -O2  -
conftest.c:44:4: error: 'not' undeclared (first use in this function)
conftest.c:44:4: note: each undeclared identifier is reported only once for
conftest.c:44:8: error: expected ';' before 'big'
configure:22768: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #include <sys/types.h>
| 		#include <sys/param.h>
| int
| main ()
| #if BYTE_ORDER != BIG_ENDIAN
| 		 not big endian
| 		#endif
|   return 0;
configure:23020: result: no
no
configure:23067: checking whether C compiler allows unaligned doubles
checking whether C compiler allows unaligned doubles... configure:23110: gcc -o
configure:23114: $? = 0
configure:23120: ./conftest
configure:23124: $? = 0
configure:23141: result: yes
yes
configure:23160: checking whether gcc supports __func__
checking whether gcc supports __func__... configure:23186: gcc -c    -O2  -
configure:23193: $? = 0
configure:23208: result: yes
yes
configure:23351: result: Using gcc to determine dependencies
configure:23383: checking whether long double is supported
checking whether long double is supported... configure:23410: gcc -c    -O2  -
configure:23417: $? = 0
configure:23432: result: yes
yes
configure:23443: checking whether long long is supported
checking whether long long is supported... configure:23470: gcc -c    -O2  -
configure:23477: $? = 0
configure:23492: result: yes
yes
configure:23505: checking for max C struct integer alignment
checking for max C struct integer alignment... configure:23633: gcc -o conftest
configure:23637: $? = 0
configure:23643: ./conftest
configure:23647: $? = 0
configure:23666: result: eight
eight
configure:23703: checking for max C struct floating point alignment
checking for max C struct floating point alignment... configure:23815: gcc -o
configure:23819: $? = 0
configure:23825: ./conftest
configure:23829: $? = 0
configure:23848: result: sixteen
sixteen
configure:23883: checking for max C struct alignment of structs with doubles
checking for max C struct alignment of structs with doubles... configure:23964:
configure:23968: $? = 0
configure:23974: ./conftest
configure:23978: $? = 0
configure:23997: result: eight
eight
configure:24004: checking for max C struct floating point alignment with long
doubles
checking for max C struct floating point alignment with long doubles...
configure:24086: gcc -o conftest    -O2  -
configure:24090: $? = 0
configure:24096: ./conftest
configure:24100: $? = 0
configure:24119: result: sixteen
sixteen
configure:24129: WARNING: Structures containing long doubles may be aligned
differently from structures with floats or longs.  MPICH2 does not handle this
case automatically and you should avoid assumed extents for structures
containing float types.
configure: WARNING: Structures containing long doubles may be aligned
configure:24164: checking if alignment of structs with doubles is based on
position
checking if alignment of structs with doubles is based on position...
configure:24208: gcc -o conftest    -O2  -
configure:24212: $? = 0
configure:24218: ./conftest
configure:24222: $? = 0
configure:24241: result: no
no
configure:24257: checking if alignment of structs with long long ints is based
on position
checking if alignment of structs with long long ints is based on position...
configure:24303: gcc -o conftest    -O2  -
configure:24307: $? = 0
configure:24313: ./conftest
configure:24317: $? = 0
configure:24336: result: no
no
configure:24352: checking if double alignment breaks rules, find actual
alignment
checking if double alignment breaks rules, find actual alignment...
configure:24409: gcc -o conftest    -O2  -
configure:24413: $? = 0
configure:24419: ./conftest
configure:24423: $? = 0
configure:24442: result: no
no
configure:24458: checking for alignment restrictions on pointers
checking for alignment restrictions on pointers... configure:24488: gcc -o
configure:24492: $? = 0
configure:24498: ./conftest
configure:24502: $? = 0
configure:24528: result: int or better
int or better
configure:24540: checking size of char
checking size of char... configure:24845: gcc -o conftest    -O2  -
configure:24849: $? = 0
configure:24855: ./conftest
configure:24859: $? = 0
configure:24885: result: 1
1
configure:24899: checking size of unsigned char
checking size of unsigned char... configure:25204: gcc -o conftest    -O2  -
configure:25208: $? = 0
configure:25214: ./conftest
configure:25218: $? = 0
configure:25244: result: 1
1
configure:25258: checking size of short
checking size of short... configure:25563: gcc -o conftest    -O2  -
configure:25567: $? = 0
configure:25573: ./conftest
configure:25577: $? = 0
configure:25603: result: 2
2
configure:25617: checking size of unsigned short
checking size of unsigned short... configure:25922: gcc -o conftest    -O2  -
configure:25926: $? = 0
configure:25932: ./conftest
configure:25936: $? = 0
configure:25962: result: 2
2
configure:25976: checking size of int
checking size of int... configure:26281: gcc -o conftest    -O2  -
configure:26285: $? = 0
configure:26291: ./conftest
configure:26295: $? = 0
configure:26321: result: 4
4
configure:26335: checking size of unsigned int
checking size of unsigned int... configure:26640: gcc -o conftest    -O2  -
configure:26644: $? = 0
configure:26650: ./conftest
configure:26654: $? = 0
configure:26680: result: 4
4
configure:26694: checking size of long
checking size of long... configure:26999: gcc -o conftest    -O2  -
configure:27003: $? = 0
configure:27009: ./conftest
configure:27013: $? = 0
configure:27039: result: 8
8
configure:27053: checking size of unsigned long
checking size of unsigned long... configure:27358: gcc -o conftest    -O2  -
configure:27362: $? = 0
configure:27368: ./conftest
configure:27372: $? = 0
configure:27398: result: 8
8
configure:27412: checking size of long long
checking size of long long... configure:27717: gcc -o conftest    -O2  -
configure:27721: $? = 0
configure:27727: ./conftest
configure:27731: $? = 0
configure:27757: result: 8
8
configure:27771: checking size of unsigned long long
checking size of unsigned long long... configure:28076: gcc -o conftest    -O2
configure:28080: $? = 0
configure:28086: ./conftest
configure:28090: $? = 0
configure:28116: result: 8
8
configure:28130: checking size of float
checking size of float... configure:28435: gcc -o conftest    -O2  -
configure:28439: $? = 0
configure:28445: ./conftest
configure:28449: $? = 0
configure:28475: result: 4
4
configure:28489: checking size of double
checking size of double... configure:28794: gcc -o conftest    -O2  -
configure:28798: $? = 0
configure:28804: ./conftest
configure:28808: $? = 0
configure:28834: result: 8
8
configure:28848: checking size of long double
checking size of long double... configure:29153: gcc -o conftest    -O2  -
configure:29157: $? = 0
configure:29163: ./conftest
configure:29167: $? = 0
configure:29193: result: 16
16
configure:29207: checking size of void *
checking size of void *... configure:29512: gcc -o conftest    -O2  -
configure:29516: $? = 0
configure:29522: ./conftest
configure:29526: $? = 0
configure:29552: result: 8
8
configure:29563: checking for ANSI C header files
checking for ANSI C header files... (cached) configure:29731: result: yes
yes
configure:29757: checking stddef.h usability
checking stddef.h usability... configure:29774: gcc -c    -O2  -
configure:29781: $? = 0
configure:29795: result: yes
yes
configure:29799: checking stddef.h presence
checking stddef.h presence... configure:29814: gcc -E  -
configure:29821: $? = 0
configure:29835: result: yes
yes
configure:29863: checking for stddef.h
checking for stddef.h... configure:29872: result: yes
yes
configure:29891: checking size of wchar_t
checking size of wchar_t... configure:30226: gcc -o conftest    -O2  -
configure:30230: $? = 0
configure:30236: ./conftest
configure:30240: $? = 0
configure:30266: result: 4
4
configure:30281: checking size of float_int
checking size of float_int... configure:30592: gcc -o conftest    -O2  -
configure:30596: $? = 0
configure:30602: ./conftest
configure:30606: $? = 0
configure:30632: result: 8
8
configure:30646: checking size of double_int
checking size of double_int... configure:30957: gcc -o conftest    -O2  -
configure:30961: $? = 0
configure:30967: ./conftest
configure:30971: $? = 0
configure:30997: result: 16
16
configure:31011: checking size of long_int
checking size of long_int... configure:31322: gcc -o conftest    -O2  -
configure:31326: $? = 0
configure:31332: ./conftest
configure:31336: $? = 0
configure:31362: result: 16
16
configure:31376: checking size of short_int
checking size of short_int... configure:31687: gcc -o conftest    -O2  -
configure:31691: $? = 0
configure:31697: ./conftest
configure:31701: $? = 0
configure:31727: result: 8
8
configure:31741: checking size of two_int
checking size of two_int... configure:32052: gcc -o conftest    -O2  -
configure:32056: $? = 0
configure:32062: ./conftest
configure:32066: $? = 0
configure:32092: result: 8
8
configure:32106: checking size of long_double_int
checking size of long_double_int... configure:32417: gcc -o conftest    -O2  -
configure:32421: $? = 0
configure:32427: ./conftest
configure:32431: $? = 0
configure:32457: result: 32
32
configure:32480: checking sys/bitypes.h usability
checking sys/bitypes.h usability... configure:32497: gcc -c    -O2  -
configure:32504: $? = 0
configure:32518: result: yes
yes
configure:32522: checking sys/bitypes.h presence
checking sys/bitypes.h presence... configure:32537: gcc -E  -
configure:32544: $? = 0
configure:32558: result: yes
yes
configure:32586: checking for sys/bitypes.h
checking for sys/bitypes.h... configure:32593: result: yes
yes
configure:32625: checking inttypes.h usability
checking inttypes.h usability... configure:32642: gcc -c    -O2  -
configure:32649: $? = 0
configure:32663: result: yes
yes
configure:32667: checking inttypes.h presence
checking inttypes.h presence... configure:32682: gcc -E  -
configure:32689: $? = 0
configure:32703: result: yes
yes
configure:32731: checking for inttypes.h
checking for inttypes.h... configure:32740: result: yes
yes
configure:32625: checking stdint.h usability
checking stdint.h usability... configure:32642: gcc -c    -O2  -
yes
configure:32667: checking stdint.h presence
checking stdint.h presence... configure:32682: gcc -E  -
yes
configure:32731: checking for stdint.h
checking for stdint.h... configure:32740: result: yes
yes
configure:32758: checking for int8_t
checking for int8_t... configure:32789: gcc -c    -O2  -
configure:32796: $? = 0
configure:32825: gcc -c    -O2  -
conftest.c:107:12: error: size of array 'test_array' is negative
configure:32832: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define WORDS_LITTLEENDIAN 1
| #define HAVE_LONG_DOUBLE 1
| #define HAVE_LONG_LONG_INT 1
| #define HAVE_MAX_INTEGER_ALIGNMENT 8
| #define HAVE_MAX_STRUCT_ALIGNMENT 8
| #define HAVE_MAX_FP_ALIGNMENT 16
| #define HAVE_MAX_DOUBLE_FP_ALIGNMENT 8
| #define HAVE_MAX_LONG_DOUBLE_FP_ALIGNMENT 16
| #define SIZEOF_CHAR 1
| #define SIZEOF_UNSIGNED_CHAR 1
| #define SIZEOF_SHORT 2
| #define SIZEOF_UNSIGNED_SHORT 2
| #define SIZEOF_INT 4
| #define SIZEOF_UNSIGNED_INT 4
| #define SIZEOF_LONG 8
| #define SIZEOF_UNSIGNED_LONG 8
| #define SIZEOF_LONG_LONG 8
| #define SIZEOF_UNSIGNED_LONG_LONG 8
| #define SIZEOF_FLOAT 4
| #define SIZEOF_DOUBLE 8
| #define SIZEOF_LONG_DOUBLE 16
| #define SIZEOF_VOID_P 8
| #define HAVE_STDDEF_H 1
| #define SIZEOF_WCHAR_T 4
| #define SIZEOF_FLOAT_INT 8
| #define SIZEOF_DOUBLE_INT 16
| #define SIZEOF_LONG_INT 16
| #define SIZEOF_SHORT_INT 8
| #define SIZEOF_TWO_INT 8
| #define SIZEOF_LONG_DOUBLE_INT 32
| #define HAVE_SYS_BITYPES_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| #  include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| int
| main ()
| static int test_array [1 - 2 * !((int8_t) ((((int8_t) 1 << (8 - 2)) - 1) * 2
+ 1)
| 		 < (int8_t) ((((int8_t) 1 << (8 - 2)) - 1) * 2 + 2))];
| test_array [0] = 0
|   return 0;
configure:32861: result: yes
yes
configure:32874: checking for int16_t
checking for int16_t... configure:32905: gcc -c    -O2  -
configure:32912: $? = 0
configure:32941: gcc -c    -O2  -
configure:32948: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| static int test_array [1 - 2 * !((int16_t) ((((int16_t) 1 << (16 - 2)) - 1)
* 2 + 1)
| 		 < (int16_t) ((((int16_t) 1 << (16 - 2)) - 1) * 2 + 2))];
| test_array [0] = 0
|   return 0;
configure:32977: result: yes
yes
configure:32990: checking for int32_t
checking for int32_t... configure:33021: gcc -c    -O2  -
configure:33028: $? = 0
configure:33057: gcc -c    -O2  -
conftest.c:108:53: warning: integer overflow in expression
conftest.c:107:12: error: storage size of 'test_array' isn't constant
configure:33064: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| static int test_array [1 - 2 * !((int32_t) ((((int32_t) 1 << (32 - 2)) - 1)
* 2 + 1)
| 		 < (int32_t) ((((int32_t) 1 << (32 - 2)) - 1) * 2 + 2))];
| test_array [0] = 0
|   return 0;
configure:33093: result: yes
yes
configure:33106: checking for int64_t
checking for int64_t... configure:33137: gcc -c    -O2  -
configure:33144: $? = 0
configure:33173: gcc -c    -O2  -
configure:33180: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| static int test_array [1 - 2 * !((int64_t) ((((int64_t) 1 << (64 - 2)) - 1)
* 2 + 1)
| 		 < (int64_t) ((((int64_t) 1 << (64 - 2)) - 1) * 2 + 2))];
| test_array [0] = 0
|   return 0;
configure:33209: result: yes
yes
configure:33260: checking for uint8_t
checking for uint8_t... configure:33291: gcc -c    -O2  -
configure:33298: $? = 0
configure:33319: result: yes
yes
configure:33337: checking for uint16_t
checking for uint16_t... configure:33368: gcc -c    -O2  -
configure:33375: $? = 0
configure:33396: result: yes
yes
configure:33410: checking for uint32_t
checking for uint32_t... configure:33441: gcc -c    -O2  -
configure:33448: $? = 0
configure:33469: result: yes
yes
configure:33487: checking for uint64_t
checking for uint64_t... configure:33518: gcc -c    -O2  -
configure:33525: $? = 0
configure:33546: result: yes
yes
configure:33613: checking stdbool.h usability
checking stdbool.h usability... configure:33630: gcc -c    -O2  -
configure:33637: $? = 0
configure:33651: result: yes
yes
configure:33655: checking stdbool.h presence
checking stdbool.h presence... configure:33670: gcc -E  -
configure:33677: $? = 0
configure:33691: result: yes
yes
configure:33719: checking for stdbool.h
checking for stdbool.h... configure:33728: result: yes
yes
configure:33613: checking complex.h usability
checking complex.h usability... configure:33630: gcc -c    -O2  -
yes
configure:33655: checking complex.h presence
checking complex.h presence... configure:33670: gcc -E  -
yes
configure:33719: checking for complex.h
checking for complex.h... configure:33728: result: yes
yes
configure:33747: checking size of _Bool
checking size of _Bool... configure:34082: gcc -o conftest    -O2  -
configure:34086: $? = 0
configure:34092: ./conftest
configure:34096: $? = 0
configure:34122: result: 1
1
configure:34136: checking size of float _Complex
checking size of float _Complex... configure:34471: gcc -o conftest    -O2  -
configure:34475: $? = 0
configure:34481: ./conftest
configure:34485: $? = 0
configure:34511: result: 8
8
configure:34525: checking size of double _Complex
checking size of double _Complex... configure:34860: gcc -o conftest    -O2  -
configure:34864: $? = 0
configure:34870: ./conftest
configure:34874: $? = 0
configure:34900: result: 16
16
configure:34914: checking size of long double _Complex
checking size of long double _Complex... configure:35249: gcc -o conftest    -
configure:35253: $? = 0
configure:35259: ./conftest
configure:35263: $? = 0
configure:35289: result: 32
32
configure:35301: checking for _Bool
checking for _Bool... configure:35329: gcc -c    -O2  -
configure:35336: $? = 0
configure:35363: gcc -c    -O2  -
conftest.c:121:20: error: expected expression before ')' token
configure:35370: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_INT8_T 1
| #define HAVE_INT16_T 1
| #define HAVE_INT32_T 1
| #define HAVE_INT64_T 1
| #define HAVE_UINT8_T 1
| #define HAVE_UINT16_T 1
| #define HAVE_UINT32_T 1
| #define HAVE_UINT64_T 1
| #define HAVE_STDBOOL_H 1
| #define HAVE_COMPLEX_H 1
| #define SIZEOF__BOOL 1
| #define SIZEOF_FLOAT__COMPLEX 8
| #define SIZEOF_DOUBLE__COMPLEX 16
| #define SIZEOF_LONG_DOUBLE__COMPLEX 32
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| if (sizeof ((_Bool)))
| 	  return 0;
|   return 0;
configure:35393: result: yes
yes
configure:35403: checking for float _Complex
checking for float _Complex... configure:35431: gcc -c    -O2  -
configure:35438: $? = 0
configure:35465: gcc -c    -O2  -
conftest.c:122:29: error: expected expression before ')' token
configure:35472: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE__BOOL 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| if (sizeof ((float _Complex)))
| 	  return 0;
|   return 0;
configure:35495: result: yes
yes
configure:35505: checking for double _Complex
checking for double _Complex... configure:35533: gcc -c    -O2  -
configure:35540: $? = 0
configure:35567: gcc -c    -O2  -
conftest.c:123:30: error: expected expression before ')' token
configure:35574: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_FLOAT__COMPLEX 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| if (sizeof ((double _Complex)))
| 	  return 0;
|   return 0;
configure:35597: result: yes
yes
configure:35607: checking for long double _Complex
checking for long double _Complex... configure:35635: gcc -c    -O2  -
configure:35642: $? = 0
configure:35669: gcc -c    -O2  -
conftest.c:124:35: error: expected expression before ')' token
configure:35676: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_DOUBLE__COMPLEX 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| if (sizeof ((long double _Complex)))
| 	  return 0;
|   return 0;
configure:35699: result: yes
yes
configure:36127: checking for size of Fortran type integer
checking for size of Fortran type integer... configure:36178: gcc -c    -O2  -
configure:36185: $? = 0
configure:36193: mv conftest.o pac_conftest.o
configure:36196: $? = 0
configure:36229: gfortran -o conftest   -O2   conftest.f pac_conftest.o   >&5
configure:36233: $? = 0
configure:36239: ./conftest
configure:36243: $? = 0
configure:36292: result: 4
4
configure:36307: checking for size of Fortran type real
checking for size of Fortran type real... configure:36358: gcc -c    -O2  -
configure:36365: $? = 0
configure:36373: mv conftest.o pac_conftest.o
configure:36376: $? = 0
configure:36409: gfortran -o conftest   -O2   conftest.f pac_conftest.o   >&5
configure:36413: $? = 0
configure:36419: ./conftest
configure:36423: $? = 0
configure:36472: result: 4
4
configure:36487: checking for size of Fortran type double precision
checking for size of Fortran type double precision... configure:36538: gcc -c
configure:36545: $? = 0
configure:36553: mv conftest.o pac_conftest.o
configure:36556: $? = 0
configure:36589: gfortran -o conftest   -O2   conftest.f pac_conftest.o   >&5
configure:36593: $? = 0
configure:36599: ./conftest
configure:36603: $? = 0
configure:36652: result: 8
8
configure:36675: checking whether integer*1 is supported
checking whether integer*1 is supported... configure:36692: gfortran -c   -O2
conftest.f >&5
configure:36699: $? = 0
configure:36714: result: yes
yes
configure:36716: checking whether integer*2 is supported
checking whether integer*2 is supported... configure:36733: gfortran -c   -O2
conftest.f >&5
configure:36740: $? = 0
configure:36755: result: yes
yes
configure:36757: checking whether integer*4 is supported
checking whether integer*4 is supported... configure:36774: gfortran -c   -O2
conftest.f >&5
configure:36781: $? = 0
configure:36796: result: yes
yes
configure:36798: checking whether integer*8 is supported
checking whether integer*8 is supported... configure:36815: gfortran -c   -O2
conftest.f >&5
configure:36822: $? = 0
configure:36837: result: yes
yes
configure:36839: checking whether integer*16 is supported
checking whether integer*16 is supported... configure:36856: gfortran -c   -O2
conftest.f >&5
configure:36863: $? = 0
configure:36878: result: yes
yes
configure:36880: checking whether real*4 is supported
checking whether real*4 is supported... configure:36897: gfortran -c   -O2
conftest.f >&5
configure:36904: $? = 0
configure:36919: result: yes
yes
configure:36921: checking whether real*8 is supported
checking whether real*8 is supported... configure:36938: gfortran -c   -O2
conftest.f >&5
configure:36945: $? = 0
configure:36960: result: yes
yes
configure:36962: checking whether real*16 is supported
checking whether real*16 is supported... configure:36979: gfortran -c   -O2
conftest.f >&5
conftest.f:2.13:
      real*16 a
             1
Error: Old-style type declaration REAL*16 not supported at (1)
configure:36986: $? = 1
configure: failed program was:
|       program main
|       real*16 a
|       end
configure:37001: result: no
no
configure:37393: checking for C type matching Fortran integer
checking for C type matching Fortran integer... configure:37400: result: int
int
configure:37456: checking for size of MPI_Status
checking for size of MPI_Status... configure:37764: gcc -o conftest    -O2  -
configure:37768: $? = 0
configure:37774: ./conftest
configure:37778: $? = 0
configure:37796: result: 20
20
configure:37927: checking for values of Fortran logicals
checking for values of Fortran logicals... configure:37976: gcc -c    -O2  -
configure:37983: $? = 0
configure:37990: mv conftest.o pac_conftest.o
configure:37993: $? = 0
configure:38031: gfortran -o conftest   -O2   conftest.f pac_conftest.o   >&5
configure:38035: $? = 0
configure:38041: ./conftest
configure:38045: $? = 0
configure:38096: result: True is 1 and False is 0
configure:38125: checking for BSD/POSIX style global symbol lister
checking for BSD/POSIX style global symbol lister... configure:38177: gcc -c
configure:38184: $? = 0
configure:38265: result: BSD style,/usr/bin/nm -g -B
configure:38319: checking stdio.h usability
checking stdio.h usability... configure:38336: gcc -c    -O2  -
configure:38343: $? = 0
configure:38357: result: yes
yes
configure:38361: checking stdio.h presence
checking stdio.h presence... configure:38376: gcc -E  -
configure:38383: $? = 0
configure:38397: result: yes
yes
configure:38425: checking for stdio.h
checking for stdio.h... configure:38434: result: yes
yes
configure:38449: checking for multiple __attribute__((alias)) support
checking for multiple __attribute__((alias)) support... configure:38520: gcc -c
configure:38527: $? = 0
configure:38535: cp conftest.o pac_conftest_other.o
configure:38538: $? = 0
configure:38615: gcc -o conftest    -O2  -
pac_conftest_other.o   >&5
configure:38622: $? = 0
configure:38633: cp conftest pac_conftest_main
configure:38636: $? = 0
configure:38701: ./pac_conftest_main
configure:38704: $? = 0
configure:38711: result: yes
yes
configure:38739: checking the minimum alignment of Fortran common block of 1
integers
checking the minimum alignment of Fortran common block of 1 integers...
configure:38788: gcc -c    -O2  -
configure:38795: $? = 0
configure:38803: mv conftest.o pac_conftest.o
configure:38806: $? = 0
configure:38836: f95 -o conftest   -O2    conftest.f90 pac_conftest.o   >
pac_align0.log 2>&1
configure:38843: $? = 0
configure:38951: gcc -c    -O2  -
configure:38958: $? = 0
configure:38966: mv conftest.o pac_conftest.o
configure:38969: $? = 0
configure:39000: f95 -o conftest   -O2    conftest.f90 pac_conftest.o   >
pac_align1.log 2>&1
configure:39007: $? = 0
configure:39021: diff -b pac_align0.log pac_align1.log > pac_test.log
configure:39024: $? = 1
*** diff -b pac_align0.log pac_align1.log :
0a1
> /usr/bin/ld: Warning: alignment 4 of symbol `mpifcmb_' in pac_conftest.o is
smaller than 16 in /tmp/cc9frf6Q.o
failed C program was:
            /* confdefs.h.  */
#define PACKAGE_NAME ""
#define PACKAGE_TARNAME ""
#define PACKAGE_VERSION ""
#define PACKAGE_STRING ""
#define PACKAGE_BUGREPORT ""
#define USE_SMP_COLLECTIVES 1
#define STDCALL
#define HAVE_LONG_DOUBLE__COMPLEX 1
#define MPIR_REAL4_CTYPE float
#define MPIR_REAL8_CTYPE double
#define MPIR_REAL16_CTYPE long double
#define MPIR_INTEGER1_CTYPE char
#define MPIR_INTEGER2_CTYPE short
#define MPIR_INTEGER4_CTYPE int
#define MPIR_INTEGER8_CTYPE long
#define SIZEOF_F77_INTEGER 4
#define SIZEOF_F77_REAL 4
#define SIZEOF_F77_DOUBLE_PRECISION 8
#define HAVE_AINT_LARGER_THAN_FINT 1
#define HAVE_AINT_DIFFERENT_THAN_FINT 1
#define HAVE_FINT_IS_INT 1
#define F77_TRUE_VALUE_SET 1
#define F77_TRUE_VALUE 1
#define F77_FALSE_VALUE 0
#define HAVE_STDIO_H 1
/* end confdefs.h.  */
struct mpif_cmblk_t_ { int imembers[1]; };
typedef struct mpif_cmblk_t_ mpif_cmblk_t;
mpif_cmblk_t mpifcmbr __attribute__((aligned(4))) = {0};
extern mpif_cmblk_t _CMPIFCMB  __attribute__ ((alias("mpifcmbr")));
extern mpif_cmblk_t   MPIFCMB  __attribute__ ((alias("mpifcmbr")));
extern mpif_cmblk_t   MPIFCMB_ __attribute__ ((alias("mpifcmbr")));
extern mpif_cmblk_t _Cmpifcmb  __attribute__ ((alias("mpifcmbr")));
extern mpif_cmblk_t   mpifcmb  __attribute__ ((alias("mpifcmbr")));
extern mpif_cmblk_t   mpifcmb_ __attribute__ ((alias("mpifcmbr")));
failed Fortran program was:
        program fconftest
        integer isize
        parameter (isize=1)
        integer status_array(isize)
        common /mpifcmb/ status_array
        save /mpifcmb/
        end
pac_align1.log 2>&1
0a1
> /usr/bin/ld: Warning: alignment 8 of symbol `mpifcmb_' in pac_conftest.o is
smaller than 16 in /tmp/cc3Tx0q5.o
            /* confdefs.h.  */
#define STDCALL
mpif_cmblk_t mpifcmbr __attribute__((aligned(8))) = {0};
        program fconftest
        integer isize
        parameter (isize=1)
        save /mpifcmb/
        end
pac_align1.log 2>&1
configure:39024: $? = 0
configure:39123: result: 16
16
configure:39134: checking the minimum alignment of Fortran common block of 5
integers
checking the minimum alignment of Fortran common block of 5 integers...
configure:39183: gcc -c    -O2  -
configure:39190: $? = 0
configure:39198: mv conftest.o pac_conftest.o
configure:39201: $? = 0
configure:39231: f95 -o conftest   -O2    conftest.f90 pac_conftest.o   >
pac_align0.log 2>&1
configure:39238: $? = 0
configure:39346: gcc -c    -O2  -
configure:39353: $? = 0
configure:39361: mv conftest.o pac_conftest.o
configure:39364: $? = 0
configure:39395: f95 -o conftest   -O2    conftest.f90 pac_conftest.o   >
pac_align1.log 2>&1
configure:39402: $? = 0
configure:39416: diff -b pac_align0.log pac_align1.log > pac_test.log
configure:39419: $? = 1
0a1
smaller than 16 in /tmp/ccUZNcZB.o
            /* confdefs.h.  */
#define STDCALL
struct mpif_cmblk_t_ { int imembers[5]; };
        program fconftest
        integer isize
        parameter (isize=5)
        save /mpifcmb/
        end
pac_align1.log 2>&1
0a1
smaller than 16 in /tmp/ccQ7HxQN.o
            /* confdefs.h.  */
#define HAVE_ERROR_CHECKING MPID_ERROR_LEVEL_ALL
#define MPICH_ERROR_MSG_LEVEL MPICH_ERROR_MSG_ALL
#define USE_LOGGING MPID_LOGGING_NONE
#define STDCALL
        program fconftest
        integer isize
        parameter (isize=5)
        save /mpifcmb/
        end
pac_align1.log 2>&1
configure:39419: $? = 0
pac_align1.log 2>&1
configure:39530: result: 16, too small! reset to 32
configure:39659: checking for Fortran 90 integer kind for 8-byte integers
checking for Fortran 90 integer kind for 8-byte integers... configure:39708:
f95 -o conftest   -O2    conftest.f90   >&5
configure:39712: $? = 0
configure:39718: ./conftest
configure:39722: $? = 0
configure:39746: result: 8
8
configure:40001: checking if real*8 is supported in Fortran 90
checking if real*8 is supported in Fortran 90... configure:40020: f95 -c   -O2
conftest.f90 >&5
configure:40027: $? = 0
configure:40047: result: yes
yes
configure:40191: checking size of bool
checking size of bool... configure:40496: g++ -o conftest   -O2  -
configure:40500: $? = 0
configure:40506: ./conftest
configure:40510: $? = 0
configure:40536: result: 1
1
configure:40584: checking how to run the C++ preprocessor
checking how to run the C++ preprocessor... configure:40620: g++ -E  -
configure:40627: $? = 0
configure:40658: g++ -E  -
conftest.cpp:109:28: fatal error: ac_nonexistent.h: No such file or directory
compilation terminated.
configure:40665: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_C_MULTI_ATTR_ALIAS 1
| #define SIZEOF_BOOL 1
| #define MPIR_CXX_BOOL_CTYPE _Bool
| #include <ac_nonexistent.h>
configure:40698: result: g++ -E
g++ -E
configure:40727: g++ -E  -
configure:40734: $? = 0
configure:40765: g++ -E  -
configure:40772: $? = 1
| /* confdefs.h.  */
| #define STDCALL
configure:40822: checking complex usability
checking complex usability... configure:40839: g++ -c   -O2  -
configure:40846: $? = 0
configure:40860: result: yes
yes
configure:40864: checking complex presence
checking complex presence... configure:40879: g++ -E  -
configure:40886: $? = 0
configure:40900: result: yes
yes
configure:40928: checking for complex
checking for complex... configure:40935: result: yes
yes
configure:40948: checking size of Complex
checking size of Complex... configure:41283: g++ -o conftest   -O2  -
configure:41287: $? = 0
configure:41293: ./conftest
configure:41297: $? = 0
configure:41323: result: 8
8
configure:41337: checking size of DoubleComplex
checking size of DoubleComplex... configure:41672: g++ -o conftest   -O2  -
configure:41676: $? = 0
configure:41682: ./conftest
configure:41686: $? = 0
configure:41712: result: 16
16
configure:41727: checking size of LongDoubleComplex
checking size of LongDoubleComplex... configure:42062: g++ -o conftest   -O2  -
configure:42066: $? = 0
configure:42072: ./conftest
configure:42076: $? = 0
configure:42102: result: 32
32
configure:42189: checking if char * pointers use byte addresses
checking if char * pointers use byte addresses... configure:42217: gcc -o
configure:42221: $? = 0
configure:42227: ./conftest
configure:42231: $? = 0
configure:42248: result: yes
yes
configure:42275: checking for alignment restrictions on
checking for alignment restrictions on ... configure:42319: gcc -o conftest
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src -
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src   conftest.c   >&5
configure:42323: $? = 0
configure:42329: ./conftest
configure:42333: $? = 0
configure:42351: result: no
no
configure:42372: checking for alignment restrictions on int32_t
checking for alignment restrictions on int32_t... configure:42416: gcc -o
configure:42420: $? = 0
configure:42426: ./conftest
configure:42430: $? = 0
configure:42448: result: no
no
configure:42464: checking size of MPIR_Bsend_data_t
checking size of MPIR_Bsend_data_t... configure:42793: gcc -o conftest    -O2
configure:42797: $? = 0
configure:42803: ./conftest
configure:42807: $? = 0
configure:42833: result: 88
88
configure:42852: checking for gcc __asm__ and pentium cmpxchgl instruction
checking for gcc __asm__ and pentium cmpxchgl instruction... configure:42886:
conftest.c: Assembler messages:
conftest.c:129: Error: Incorrect register `%rdx' used with `l' suffix
configure:42890: $? = 1
configure: program exited with status 1
| /* confdefs.h.  */
| #define MPICH_THREAD_LEVEL MPI_THREAD_SINGLE
| #define MPIU_THREAD_GRANULARITY MPIU_THREAD_GRANULARITY_SINGLE
| #define MPIU_HANDLE_ALLOCATION_METHOD MPIU_HANDLE_ALLOCATION_MUTEX
| #define MPIU_THREAD_REFCOUNT MPIU_REFCOUNT_NONE
| #define HAVE_ROMIO 1
| #define HAVE__FUNC__ /**/
| #define STDCALL
| #define SIZEOF_COMPLEX 8
| #define SIZEOF_DOUBLECOMPLEX 16
| #define SIZEOF_LONGDOUBLECOMPLEX 32
| #define HAVE_CXX_COMPLEX 1
| #define MPIR_CXX_BOOL_VALUE 0x4c000133
| #define MPIR_CXX_COMPLEX_VALUE 0x4c000834
| #define MPIR_CXX_DOUBLE_COMPLEX_VALUE 0x4c001035
| #define MPIR_CXX_LONG_DOUBLE_COMPLEX_VALUE 0x4c002036
| #define HAVE_ANY_INT64_T_ALIGNMENT 1
| #define HAVE_ANY_INT32_T_ALIGNMENT 1
| #define SIZEOF_MPIR_BSEND_DATA_T 88
| int main(int argc, char *argv[])
| long int compval = 10;
| volatile long int *p = &compval;
| long int oldval = 10;
| long int newval = 20;
| char ret;
| long int readval;
| __asm__ __volatile__ ("lock; cmpxchgl %3, %1; sete %0"
| 	: "=q" (ret), "=m" (*p), "=a" (readval)
| 	: "r" (newval), "m" (*p), "a" (oldval) : "memory");
| return (compval == 20) ? 0 : -1;
configure:42916: result: no
no
configure:42935: checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction...
configure:42969: gcc -o conftest    -O2  -
configure:42973: $? = 0
configure:42979: ./conftest
configure:42983: $? = 0
configure:42985: result: yes
yes
configure:43008: checking for gcc __asm__ and IA64 xchg4 instruction
checking for gcc __asm__ and IA64 xchg4 instruction... configure:43043: gcc -o
conftest.c:125: Error: no such instruction: `xchg4 %rax=[%rdi],%rsi'
conftest.c:125: Error: no such instruction: `xchg4 %rdx=[%rax],%rdx'
configure:43047: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_GCC_AND_X86_64_ASM 1
| unsigned long _InterlockedExchange(volatile void *ptr, unsigned long x)
|    unsigned long result;
|    __asm__ __volatile ("xchg4 %0=[%1],%2" : "=r" (result)
|        : "r" (ptr), "r" (x) : "memory");
|    return result;
| long val = 1;
| volatile long *p = &val;
| long oldval = _InterlockedExchange(p, (unsigned long)2);
| return (oldval == 1 && val == 2) ? 0 : -1;
configure:43072: result: no
no
configure:43290: checking for ANSI C header files
checking for ANSI C header files... (cached) configure:43458: result: yes
yes
configure:43501: checking stdlib.h usability
checking stdlib.h usability... configure:43518: gcc -c    -O2  -
configure:43525: $? = 0
configure:43539: result: yes
yes
configure:43543: checking stdlib.h presence
checking stdlib.h presence... configure:43558: gcc -E  -
configure:43565: $? = 0
configure:43579: result: yes
yes
configure:43607: checking for stdlib.h
checking for stdlib.h... configure:43616: result: yes
yes
configure:43501: checking stdarg.h usability
checking stdarg.h usability... configure:43518: gcc -c    -O2  -
yes
configure:43543: checking stdarg.h presence
checking stdarg.h presence... configure:43558: gcc -E  -
yes
configure:43607: checking for stdarg.h
checking for stdarg.h... configure:43616: result: yes
yes
configure:43501: checking sys/types.h usability
checking sys/types.h usability... configure:43518: gcc -c    -O2  -
yes
configure:43543: checking sys/types.h presence
checking sys/types.h presence... configure:43558: gcc -E  -
yes
configure:43607: checking for sys/types.h
checking for sys/types.h... configure:43616: result: yes
yes
configure:43501: checking string.h usability
checking string.h usability... configure:43518: gcc -c    -O2  -
yes
configure:43543: checking string.h presence
checking string.h presence... configure:43558: gcc -E  -
yes
configure:43607: checking for string.h
checking for string.h... configure:43616: result: yes
yes
configure:43490: checking for inttypes.h
checking for inttypes.h... (cached) configure:43497: result: yes
yes
configure:43501: checking limits.h usability
checking limits.h usability... configure:43518: gcc -c    -O2  -
yes
configure:43543: checking limits.h presence
checking limits.h presence... configure:43558: gcc -E  -
yes
configure:43607: checking for limits.h
checking for limits.h... configure:43616: result: yes
yes
configure:43490: checking for stddef.h
checking for stddef.h... (cached) configure:43497: result: yes
yes
configure:43501: checking errno.h usability
checking errno.h usability... configure:43518: gcc -c    -O2  -
yes
configure:43543: checking errno.h presence
checking errno.h presence... configure:43558: gcc -E  -
yes
configure:43607: checking for errno.h
checking for errno.h... configure:43616: result: yes
yes
configure:43501: checking sys/socket.h usability
checking sys/socket.h usability... configure:43518: gcc -c    -O2  -
yes
configure:43543: checking sys/socket.h presence
checking sys/socket.h presence... configure:43558: gcc -E  -
yes
configure:43607: checking for sys/socket.h
checking for sys/socket.h... configure:43616: result: yes
yes
configure:43501: checking sys/time.h usability
checking sys/time.h usability... configure:43518: gcc -c    -O2  -
yes
configure:43543: checking sys/time.h presence
checking sys/time.h presence... configure:43558: gcc -E  -
yes
configure:43607: checking for sys/time.h
checking for sys/time.h... configure:43616: result: yes
yes
configure:43501: checking unistd.h usability
checking unistd.h usability... configure:43518: gcc -c    -O2  -
yes
configure:43543: checking unistd.h presence
checking unistd.h presence... configure:43558: gcc -E  -
yes
configure:43607: checking for unistd.h
checking for unistd.h... configure:43616: result: yes
yes
configure:43501: checking endian.h usability
checking endian.h usability... configure:43518: gcc -c    -O2  -
yes
configure:43543: checking endian.h presence
checking endian.h presence... configure:43558: gcc -E  -
yes
configure:43607: checking for endian.h
checking for endian.h... configure:43616: result: yes
yes
configure:43501: checking assert.h usability
checking assert.h usability... configure:43518: gcc -c    -O2  -
yes
configure:43543: checking assert.h presence
checking assert.h presence... configure:43558: gcc -E  -
yes
configure:43607: checking for assert.h
checking for assert.h... configure:43616: result: yes
yes
configure:43501: checking sys/param.h usability
checking sys/param.h usability... configure:43518: gcc -c    -O2  -
yes
configure:43543: checking sys/param.h presence
checking sys/param.h presence... configure:43558: gcc -E  -
yes
configure:43607: checking for sys/param.h
checking for sys/param.h... configure:43616: result: yes
yes
configure:43631: checking for sys/uio.h
checking for sys/uio.h... configure:43661: gcc -c    -O2  -
configure:43668: $? = 0
configure:43683: result: yes
yes
configure:43694: checking for size_t
checking for size_t... configure:43722: gcc -c    -O2  -
configure:43729: $? = 0
configure:43756: gcc -c    -O2  -
conftest.c: In function 'main':
conftest.c:173:21: error: expected expression before ')' token
configure:43763: $? = 1
| /* confdefs.h.  */
| #define HAVE__FUNCTION__ /**/
| #define HAVE_PRAGMA_WEAK 1
| #define STDCALL
| #define HAVE_STDLIB_H 1
| #define HAVE_STDARG_H 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_STRING_H 1
| #define HAVE_LIMITS_H 1
| #define HAVE_ERRNO_H 1
| #define HAVE_SYS_SOCKET_H 1
| #define HAVE_SYS_TIME_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_ENDIAN_H 1
| #define HAVE_ASSERT_H 1
| #define HAVE_SYS_PARAM_H 1
| #define HAVE_SYS_UIO_H 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| if (sizeof ((size_t)))
| 	  return 0;
|   return 0;
configure:43786: result: yes
yes
configure:43805: checking for setitimer
checking for setitimer... configure:43861: gcc -o conftest    -O2  -
configure:43868: $? = 0
configure:43890: result: yes
yes
configure:43805: checking for alarm
checking for alarm... configure:43861: gcc -o conftest    -O2  -
yes
configure:43908: checking for vsnprintf
checking for vsnprintf... configure:43964: gcc -o conftest    -O2  -
conftest.c:162:6: warning: conflicting types for built-in function 'vsnprintf'
configure:43971: $? = 0
configure:43993: result: yes
yes
configure:43908: checking for vsprintf
checking for vsprintf... configure:43964: gcc -o conftest    -O2  -
conftest.c:163:6: warning: conflicting types for built-in function 'vsprintf'
yes
configure:44008: checking whether vsnprintf needs a declaration
checking whether vsnprintf needs a declaration... configure:44037: gcc -c    -
conftest.c:143:5: error: conflicting types for 'vsnprintf'
configure:44044: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_SETITIMER 1
| #define HAVE_ALARM 1
| #define HAVE_VSNPRINTF 1
| #define HAVE_VSPRINTF 1
| #include <stdio.h>
| #include <stdarg.h>
| int vsnprintf(double, int, double, const char *);
| int
| main ()
| int a=vsnprintf(1.0,27,1.0,"foo");
|   return 0;
configure:44059: result: no
no
configure:44078: checking for strerror
checking for strerror... configure:44134: gcc -o conftest    -O2  -
configure:44141: $? = 0
configure:44163: result: yes
yes
configure:44078: checking for strncasecmp
checking for strncasecmp... configure:44134: gcc -o conftest    -O2  -
conftest.c:165:6: warning: conflicting types for built-in function
'strncasecmp'
yes
configure:44175: checking whether strerror_r is declared
checking whether strerror_r is declared... configure:44204: gcc -c    -O2  -
configure:44211: $? = 0
configure:44226: result: yes
yes
configure:44248: checking for strerror_r
checking for strerror_r... configure:44304: gcc -o conftest    -O2  -
configure:44311: $? = 0
configure:44333: result: yes
yes
configure:44345: checking whether strerror_r returns char *
checking whether strerror_r returns char *... configure:44379: gcc -c    -O2  -
conftest.c:183:13: error: invalid type argument of unary '*' (have 'int')
conftest.c:184:14: warning: initialization makes pointer from integer without
a cast
configure:44386: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_STRERROR 1
| #define HAVE_STRNCASECMP 1
| #define HAVE_DECL_STRERROR_R 1
| #define HAVE_STRERROR_R 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| 	  char buf[100];
| 	  char x = *strerror_r (0, buf, sizeof buf);
| 	  char *p = strerror_r (0, buf, sizeof buf);
| 	  return !p || x;
|   return 0;
configure:44465: result: no
no
configure:44477: checking whether strerror_r needs a declaration
checking whether strerror_r needs a declaration... configure:44505: gcc -c    -
O2  -I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include -
conftest.c:146:5: error: conflicting types for 'strerror_r'
/usr/include/string.h:427:12: note: previous declaration of 'strerror_r' was
here
configure:44512: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #include <string.h>
| int strerror_r(double, int, double, const char *);
| int
| main ()
| int a=strerror_r(1.0,27,1.0,"foo");
|   return 0;
configure:44527: result: no
no
configure:44545: checking for snprintf
checking for snprintf... configure:44601: gcc -o conftest    -O2  -
conftest.c:168:6: warning: conflicting types for built-in function 'snprintf'
configure:44608: $? = 0
configure:44630: result: yes
yes
configure:44644: checking whether snprintf needs a declaration
checking whether snprintf needs a declaration... configure:44672: gcc -c    -O2
conftest.c:147:5: error: conflicting types for 'snprintf'
configure:44679: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_SNPRINTF 1
| #include <stdio.h>
| int snprintf(double, int, double, const char *);
| int
| main ()
| int a=snprintf(1.0,27,1.0,"foo");
|   return 0;
configure:44694: result: no
no
configure:44712: checking for qsort
checking for qsort... configure:44768: gcc -o conftest    -O2  -
configure:44775: $? = 0
configure:44797: result: yes
yes
configure:44816: checking for va_copy
checking for va_copy... configure:44852: gcc -o conftest    -O2  -
configure:44859: $? = 0
configure:44879: result: yes
yes
configure:44964: checking for variable argument list macro functionality
checking for variable argument list macro functionality... configure:44990: gcc
-o conftest    -O2  -I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include -
configure:44997: $? = 0
configure:45010: result: yes
yes
configure:45028: checking for working alloca.h
checking for working alloca.h... configure:45055: gcc -o conftest    -O2  -
configure:45062: $? = 0
configure:45082: result: yes
yes
configure:45092: checking for alloca
checking for alloca... configure:45139: gcc -o conftest    -O2  -
configure:45146: $? = 0
configure:45166: result: yes
yes
configure:45425: checking for strdup
checking for strdup... configure:45481: gcc -o conftest    -O2  -
conftest.c:174:6: warning: conflicting types for built-in function 'strdup'
configure:45488: $? = 0
configure:45510: result: yes
yes
configure:45525: checking whether strdup needs a declaration
checking whether strdup needs a declaration... configure:45553: gcc -c    -O2
conftest.c:153:45: error: macro "strdup" passed 4 arguments, but takes just 1
conftest.c:153:5: error: 'strdup' redeclared as different kind of symbol
conftest.c:157:30: error: macro "strdup" passed 4 arguments, but takes just 1
configure:45560: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_QSORT 1
| #define HAVE_VA_COPY 1
| #define HAVE_MACRO_VA_ARGS 1
| #define HAVE_ALLOCA_H 1
| #define HAVE_ALLOCA 1
| #define HAVE_STRDUP 1
| #include <string.h>
| int strdup(double, int, double, const char *);
| int
| main ()
| int a=strdup(1.0,27,1.0,"foo");
|   return 0;
configure:45575: result: no
no
configure:45914: checking for mkstemp
checking for mkstemp... configure:45970: gcc -o conftest    -O2  -
configure:45977: $? = 0
configure:45999: result: yes
yes
configure:46013: checking whether mkstemp needs a declaration
checking whether mkstemp needs a declaration... configure:46041: gcc -c    -O2
conftest.c:154:5: error: conflicting types for 'mkstemp'
/usr/include/stdlib.h:620:12: note: previous declaration of 'mkstemp' was here
configure:46048: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_MKSTEMP 1
| #include <stdlib.h>
| int mkstemp(double, int, double, const char *);
| int
| main ()
| int a=mkstemp(1.0,27,1.0,"foo");
|   return 0;
configure:46063: result: no
no
configure:46080: checking for fdopen
checking for fdopen... configure:46136: gcc -o conftest    -O2  -
configure:46143: $? = 0
configure:46165: result: yes
yes
configure:46179: checking whether fdopen needs a declaration
checking whether fdopen needs a declaration... configure:46207: gcc -c    -O2
configure:46214: $? = 0
configure:46229: result: yes
yes
configure:46246: checking for putenv
checking for putenv... configure:46302: gcc -o conftest    -O2  -
configure:46309: $? = 0
configure:46331: result: yes
yes
configure:46345: checking whether putenv needs a declaration
checking whether putenv needs a declaration... configure:46373: gcc -c    -O2
conftest.c:157:5: error: conflicting types for 'putenv'
/usr/include/stdlib.h:579:12: note: previous declaration of 'putenv' was here
configure:46380: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_FDOPEN 1
| #define NEEDS_FDOPEN_DECL 1
| #define HAVE_PUTENV 1
| #include <stdlib.h>
| int putenv(double, int, double, const char *);
| int
| main ()
| int a=putenv(1.0,27,1.0,"foo");
|   return 0;
configure:46395: result: no
no
configure:46442: checking for clock_gettime
checking for clock_gettime... configure:46498: gcc -o conftest    -O2  -
/tmp/ccPjr6W4.o: In function `main':
conftest.c:(.text+0x7): undefined reference to `clock_gettime'
collect2: ld returned 1 exit status
configure:46505: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| /* Define clock_gettime to an innocuous variant, in case <limits.h> declares
clock_gettime.
|    For example, HP-UX 11i <limits.h> declares gettimeofday.  */
| #define clock_gettime innocuous_clock_gettime
| /* System header to define __stub macros and hopefully few prototypes,
|     which can conflict with char clock_gettime (); below.
|     Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
|     <limits.h> exists even on freestanding compilers.  */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| #undef clock_gettime
| /* Override any GCC internal prototype to avoid an error.
|    Use char because int might match the return type of a GCC
|    builtin and then its argument prototype would still apply.  */
| #ifdef __cplusplus
| extern "C"
| #endif
| /* The GNU C library defines this for functions which it implements
|     to always fail with ENOSYS.  Some functions are actually named
|     something starting with __ and the normal name is an alias.  */
| #if defined __stub_clock_gettime || defined __stub___clock_gettime
| choke me
| #endif
| int
| main ()
| return clock_gettime ();
|   return 0;
configure:46527: result: no
no
configure:46442: checking for clock_getres
checking for clock_getres... configure:46498: gcc -o conftest    -O2  -
/tmp/ccXVBuza.o: In function `main':
conftest.c:(.text+0x7): undefined reference to `clock_getres'
| /* confdefs.h.  */
| #define STDCALL
| /* Define clock_getres to an innocuous variant, in case <limits.h> declares
clock_getres.
| #define clock_getres innocuous_clock_getres
|     which can conflict with char clock_getres (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef clock_getres
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_clock_getres || defined __stub___clock_getres
| choke me
| #endif
| int
| main ()
| return clock_getres ();
|   return 0;
no
configure:46442: checking for gethrtime
checking for gethrtime... configure:46498: gcc -o conftest    -O2  -
/tmp/ccb7u2ui.o: In function `main':
conftest.c:(.text+0x7): undefined reference to `gethrtime'
| /* confdefs.h.  */
| #define STDCALL
| /* Define gethrtime to an innocuous variant, in case <limits.h> declares
gethrtime.
| #define gethrtime innocuous_gethrtime
|     which can conflict with char gethrtime (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef gethrtime
| #ifdef __cplusplus
| extern "C"
| #endif
| char gethrtime ();
| #if defined __stub_gethrtime || defined __stub___gethrtime
| choke me
| #endif
| int
| main ()
| return gethrtime ();
|   return 0;
no
configure:46442: checking for mach_absolute_time
checking for mach_absolute_time... configure:46498: gcc -o conftest    -O2  -
/tmp/ccv2qzLp.o: In function `main':
conftest.c:(.text+0x7): undefined reference to `mach_absolute_time'
| /* confdefs.h.  */
| #define STDCALL
| /* Define mach_absolute_time to an innocuous variant, in case <limits.h>
declares mach_absolute_time.
| #define mach_absolute_time innocuous_mach_absolute_time
|     which can conflict with char mach_absolute_time (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef mach_absolute_time
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_mach_absolute_time || defined __stub___mach_absolute_time
| choke me
| #endif
| int
| main ()
| return mach_absolute_time ();
|   return 0;
no
configure:46442: checking for gettimeofday
checking for gettimeofday... configure:46498: gcc -o conftest    -O2  -
configure:46505: $? = 0
configure:46527: result: yes
yes
configure:49488: checking for thread local storage specifier
checking for thread local storage specifier... configure:49525: gcc -o conftest
configure:49532: $? = 0
configure:49567: result: __thread
__thread
configure:49587: checking sched.h usability
checking sched.h usability... configure:49604: gcc -c    -O2  -
configure:49611: $? = 0
configure:49625: result: yes
yes
configure:49629: checking sched.h presence
checking sched.h presence... configure:49644: gcc -E  -
configure:49651: $? = 0
configure:49665: result: yes
yes
configure:49693: checking for sched.h
checking for sched.h... configure:49702: result: yes
yes
configure:49726: checking for sched_yield
checking for sched_yield... configure:49782: gcc -o conftest    -O2  -
configure:49789: $? = 0
configure:49811: result: yes
yes
configure:49726: checking for yield
checking for yield... configure:49782: gcc -o conftest    -O2  -
/tmp/ccil84m0.o: In function `main':
conftest.c:(.text+0x7): undefined reference to `yield'
configure:49789: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_GETTIMEOFDAY 1
| #define MPIR_Pint long
| #define MPIR_PINT_FMT_DEC_SPEC "%ld"
| #define MPIR_Upint unsigned long
| #define MPIR_UPINT_FMT_DEC_SPEC "%lu"
| #define MPIU_SIZE_T unsigned long
| #define MPIU_THREAD_PACKAGE_NAME MPIU_THREAD_PACKAGE_NONE
| #define MPIU_TLS_SPECIFIER __thread
| #define HAVE_SCHED_H 1
| #define HAVE_SCHED_YIELD 1
| /* Define yield to an innocuous variant, in case <limits.h> declares yield.
| #define yield innocuous_yield
|     which can conflict with char yield (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef yield
| #ifdef __cplusplus
| extern "C"
| #endif
| char yield ();
| #if defined __stub_yield || defined __stub___yield
| choke me
| #endif
| int
| main ()
| return yield ();
|   return 0;
configure:49811: result: no
no
configure:49726: checking for usleep
checking for usleep... configure:49782: gcc -o conftest    -O2  -
yes
configure:49726: checking for sleep
checking for sleep... configure:49782: gcc -o conftest    -O2  -
yes
configure:49726: checking for select
checking for select... configure:49782: gcc -o conftest    -O2  -
yes
configure:49726: checking for getpid
checking for getpid... configure:49782: gcc -o conftest    -O2  -
yes
configure:49835: checking for sched_setaffinity
checking for sched_setaffinity... configure:49891: gcc -o conftest    -O2  -
configure:49898: $? = 0
configure:49920: result: yes
yes
configure:49835: checking for sched_getaffinity
checking for sched_getaffinity... configure:49891: gcc -o conftest    -O2  -
yes
configure:49835: checking for bindprocessor
checking for bindprocessor... configure:49891: gcc -o conftest    -O2  -
/tmp/ccY90fwX.o: In function `main':
conftest.c:(.text+0x7): undefined reference to `bindprocessor'
configure:49898: $? = 1
| /* confdefs.h.  */
| #define STDCALL
| #define HAVE_USLEEP 1
| #define HAVE_SLEEP 1
| #define HAVE_SELECT 1
| #define HAVE_GETPID 1
| #define HAVE_SCHED_SETAFFINITY 1
| #define HAVE_SCHED_GETAFFINITY 1
| /* Define bindprocessor to an innocuous variant, in case <limits.h> declares
bindprocessor.
| #define bindprocessor innocuous_bindprocessor
|     which can conflict with char bindprocessor (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef bindprocessor
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_bindprocessor || defined __stub___bindprocessor
| choke me
| #endif
| int
| main ()
| return bindprocessor ();
|   return 0;
configure:49920: result: no
no
configure:49835: checking for thread_policy_set
checking for thread_policy_set... configure:49891: gcc -o conftest    -O2  -
/tmp/cczYYm1S.o: In function `main':
conftest.c:(.text+0x7): undefined reference to `thread_policy_set'
| /* confdefs.h.  */
| #define STDCALL
| /* Define thread_policy_set to an innocuous variant, in case <limits.h>
declares thread_policy_set.
| #define thread_policy_set innocuous_thread_policy_set
|     which can conflict with char thread_policy_set (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef thread_policy_set
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_thread_policy_set || defined __stub___thread_policy_set
| choke me
| #endif
| int
| main ()
| return thread_policy_set ();
|   return 0;
no
configure:49934: checking whether cpu_set_t available
checking whether cpu_set_t available... configure:49962: gcc -c    -O2  -
configure:49969: $? = 0
configure:49984: result: yes
yes
configure:49993: checking whether the CPU_SET and CPU_ZERO macros are defined
checking whether the CPU_SET and CPU_ZERO macros are defined... configure:50021:
/tmp/ccRc0Q76.o: In function `main':
conftest.c:(.text+0xd): undefined reference to `CPU_ZERO'
conftest.c:(.text+0x1c): undefined reference to `CPU_SET'
configure:50028: $? = 1
| /* confdefs.h.  */
| #define USE_WEAK_SYMBOLS 1
| #define HAVE_MULTIPLE_PRAGMA_WEAK 1
| #define HAVE_LONG_LONG 1
| #define STDCALL
| #define F77_NAME_LOWER_USCORE 1
| #define STDC_HEADERS 1
| #define HAVE_MPI_F_INIT_WORKS_WITH_C 1
| #define HAVE_FORTRAN_BINDING 1
| #define HAVE_CXX_EXCEPTIONS /**/
| #define HAVE_NAMESPACES /**/
| #define HAVE_NAMESPACE_STD /**/
| #define HAVE_CPU_SET_T 1
| #include <sched.h>
| int
| main ()
|  cpu_set_t t; CPU_ZERO(&t); CPU_SET(1,&t);
|   return 0;
configure:50048: result: no
no
configure:50460: ===== configuring src/mpi/romio =====
configure: ===== configuring src/mpi/romio =====
configure:50567: executing:
/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/romio/configure  '--with-
device=ch3_p4' '--with-mpe' '--with-romio' '--enable-fc' '--enable-cxx' '--
enable-debug' '--enable-traceback' '--prefix' '/opt/mpich' --disable-option-
checking
configure: executing:
checking
Configuring with args --with-device=ch3_p4 --with-mpe --with-romio --enable-fc
--enable-cxx --enable-debug --enable-traceback --prefix /opt/mpich --disable-
option-checking
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... yes
checking for architecture... LINUX
ROMIO home directory is /home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/romio
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether f95 accepts -g... yes
checking how to run the C preprocessor... gcc -E
checking for memalign... yes
checking Fortran external names
Fortran externals have a trailing underscore and are lowercase
checking for inline... inline
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for unistd.h... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for sys/types.h... (cached) yes
checking for u_char... yes
checking for u_short... yes
checking for u_int... yes
checking for u_long... yes
checking sys/attr.h usability... no
checking sys/attr.h presence... no
checking for sys/attr.h... no
checking size of int... 4
checking size of void *... 8
checking for int large enough for pointers... no
checking size of long long... 8
checking for extension for Fortran 90 programs... f90
checking for Fortran 90 KIND parameter for 8-byte integers...            8
checking that we can use integer*8 to declare MPI_DISPLACMENT_CURRENT... yes
Overriding Array test for MPICH2
checking for weak symbol support... pragma weak
checking that weak symbols are visible to other files... yes
checking that the compiler correctly implements weak symbols... yes
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs nfs
configure: WARNING: File locks may not work with NFS.  See the Installation and
users manual for instructions on testing and if necessary fixing this
checking for library containing aio_write... -lrt
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking if aio.h exists and can be compiled... yes
checking if sys/aio.h exists and can be compiled... no
checking whether aio routines can be used... yes
checking for obsolete two-argument aio_write... no
checking for obsolete two-argument aio_suspend... no
checking for aio_fildes member of aiocb structure... yes
checking for aio_whence member of aiocb structure... no
checking for aio_handle member of aiocb structure... no
checking for aio_reqprio member of aiocb structure... yes
checking for aio_sigevent member of aiocb structure... yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for large file defines... yes
checking whether off64_t is an scalar type... yes
checking for strerror... yes
checking for doctext... false
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for lseek64... yes
checking whether lseek64 needs a declaration... no
checking spi/kernel_interface.h usability... no
checking spi/kernel_interface.h presence... no
checking for spi/kernel_interface.h... no
checking for Kernel_GetMemorySize... no
setting SYSDEP_INC to
checking for C/C++ restrict keyword... __restrict
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
setting CC to gcc
setting F77 to f95
setting TEST_CC to /home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpicc
setting TEST_F77 to /home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpif77
setting CFLAGS to    -O2 -g -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -
D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -
setting USER_CFLAGS to
setting USER_FFLAGS to
configure: creating ./config.status
config.status: creating Makefile
config.status: creating localdefs
config.status: creating mpi-io/Makefile
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating adio/common/Makefile
config.status: creating test/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating test-internal/Makefile
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating adio/ad_nfs/Makefile
config.status: creating adio/ad_ufs/Makefile
config.status: creating adio/ad_bgl/Makefile
config.status: creating adio/ad_bglockless/Makefile
config.status: creating adio/ad_panfs/Makefile
config.status: creating adio/ad_xfs/Makefile
config.status: creating adio/ad_sfs/Makefile
config.status: creating adio/ad_pfs/Makefile
config.status: creating adio/ad_testfs/Makefile
config.status: creating adio/ad_pvfs/Makefile
config.status: creating adio/ad_pvfs2/Makefile
config.status: creating adio/ad_gridftp/Makefile
config.status: creating adio/ad_lustre/Makefile
config.status: creating adio/ad_zoidfs/Makefile
config.status: creating mpi-io/fortran/Makefile
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating mpi-io/glue/mpich2/Makefile
config.status: creating mpi-io/glue/mpich1/Makefile
config.status: creating mpi-io/glue/default/Makefile
config.status: creating common/dataloop/Makefile
config.status: creating adio/include/romioconf.h
config.status: executing default-1 commands
configure:50586: ===== done with src/mpi/romio configure =====
configure: ===== done with src/mpi/romio configure =====
configure:50460: ===== configuring src/pmi/simple =====
configure: ===== configuring src/pmi/simple =====
/home/alibeck/Downloads/mpich2-1.4.1p1/src/pmi/simple/configure  '--with-
checking
checking
RUNNING CONFIGURE FOR THE SIMPLE PMI
checking for make... make
checking for gcc... gcc
checking for string.h... (cached) yes
checking for stdlib.h... (cached) yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking for strings.h... (cached) yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking for strncasecmp... yes
checking for sys/socket.h... (cached) yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for socket... yes
checking for setsockopt... yes
checking for gethostbyname... yes
checking whether socklen_t is defined (in sys/socket.h if present)... yes
checking whether struct hostent contains h_addr_list... yes
config.status: creating pmiconf.h
config.status: pmiconf.h is unchanged
configure:50586: ===== done with src/pmi/simple configure =====
configure: ===== done with src/pmi/simple configure =====
configure:50460: ===== configuring src/pm/hydra =====
configure: ===== configuring src/pm/hydra =====
/home/alibeck/Downloads/mpich2-1.4.1p1/src/pm/hydra/configure  '--with-
checking
checking
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for fgrep... /bin/grep -F
checking for an ANSI C-conforming const... yes
checking for working volatile... yes
checking size of unsigned long... 8
checking for size_t... yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared
libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for variable argument list macro functionality... yes
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking for doxygen... /usr/bin/doxygen
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking ifaddrs.h usability... yes
checking ifaddrs.h presence... yes
checking for ifaddrs.h... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking poll.h usability... yes
checking poll.h presence... yes
checking for poll.h... yes
checking for netdb.h... (cached) yes
checking winsock2.h usability... no
checking winsock2.h presence... no
checking for winsock2.h... no
checking windows.h usability... no
checking windows.h presence... no
checking for windows.h... no
checking for socket in -lsocket... no
checking for gethostbyname in -lnsl... yes
checking for gettimeofday... yes
checking for time... yes
checking for sigaction... yes
checking for signal... yes
checking for usleep... yes
checking for alloca... no
checking for unsetenv... yes
checking for strsignal... yes
checking for getifaddrs... yes
checking for fcntl... yes
checking for alarm... yes
checking for isatty... yes
checking for inet_ntop... yes
checking for environ in unistd.h... no
checking for manually declared extern environ... yes
checking bootstrap server...
user,ssh,rsh,fork,slurm,ll,lsf,sge,pbs,manual,persist
checking tm.h usability... no
checking tm.h presence... no
checking for tm.h... no
checking for tm_init in -ltorque... no
checking process manager... pmiserv
checking user interface... mpich
checking desired processor topology libraries... hwloc,plpa
configure: ===== configuring tools/topo/hwloc/hwloc =====
/home/alibeck/Downloads/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/configure
--enable-embedded-mode '--with-device=ch3_p4' '--with-mpe' '--with-romio' '--
enable-fc' '--enable-cxx' '--enable-debug' '--enable-traceback' '--prefix'
'/opt/mpich' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2 ' 'LDFLAGS= -
lnsl' 'LIBS=' 'LIBS=-lrt  ' 'CPPFLAGS= -
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src' --disable-option-
checking
### Configuring hwloc distribution tarball
### Startup tests
checking target system type... x86_64-unknown-linux-gnu
checking how to create a ustar tar archive... gnutar
checking for hwloc version... 1.2.1rc2-1
checking whether gcc and cc understand -c and -o together... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
### Configuring hwloc core
checking hwloc building mode... embedded
configure: hwloc builddir:
configure: hwloc srcdir:
checking if want hwloc maintainer support... disabled (embedded mode)
checking for hwloc directory prefix... (none)
checking for hwloc symbol prefix... hwloc_
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking which OS support to include... Linux
checking which CPU support to include... x86_64
checking size of unsigned int... 4
checking for __attribute__... yes
checking for __attribute__(aligned)... yes
checking for __attribute__(always_inline)... yes
checking for __attribute__(cold)... yes
checking for __attribute__(const)... yes
checking for __attribute__(deprecated)... yes
checking for __attribute__(format)... yes
checking for __attribute__(hot)... yes
checking for __attribute__(malloc)... yes
checking for __attribute__(may_alias)... yes
checking for __attribute__(no_instrument_function)... yes
checking for __attribute__(nonnull)... no
checking for __attribute__(noreturn)... yes
checking for __attribute__(packed)... yes
checking for __attribute__(pure)... yes
checking for __attribute__(sentinel)... yes
checking for __attribute__(unused)... yes
checking for __attribute__(warn_unused_result)... yes
checking for __attribute__(weak_alias)... yes
checking if gcc supports -fvisibility... yes
checking whether to enable visibility... yes (via -fvisibility=hidden)
configure: WARNING: " -fvisibility=hidden" has been added to the hwloc CFLAGS
checking for inline compatibility keyword... __inline__
checking whether function strncasecmp is declared... yes
checking for strftime... yes
checking for setlocale... yes
checking for stdint.h... (cached) yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking for KAFFINITY... no
checking for PROCESSOR_CACHE_TYPE... no
checking for CACHE_DESCRIPTOR... no
checking for LOGICAL_PROCESSOR_RELATIONSHIP... no
checking for RelationProcessorPackage... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION... no
checking for GROUP_AFFINITY... no
checking for PROCESSOR_RELATIONSHIP... no
checking for NUMA_NODE_RELATIONSHIP... no
checking for CACHE_RELATIONSHIP... no
checking for PROCESSOR_GROUP_INFO... no
checking for GROUP_RELATIONSHIP... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION_EX... no
checking for PSAPI_WORKING_SET_EX_BLOCK... no
checking for PSAPI_WORKING_SET_EX_INFORMATION... no
checking for main in -lgdi32... no
checking sys/lgrp_user.h usability... no
checking sys/lgrp_user.h presence... no
checking for sys/lgrp_user.h... no
checking kstat.h usability... no
checking kstat.h presence... no
checking for kstat.h... no
checking whether _SC_NPROCESSORS_ONLN is declared... yes
checking whether _SC_NPROCESSORS_CONF is declared... yes
checking whether _SC_NPROC_ONLN is declared... no
checking whether _SC_NPROC_CONF is declared... no
checking whether _SC_LARGE_PAGESIZE is declared... no
checking mach/mach_host.h usability... no
checking mach/mach_host.h presence... no
checking for mach/mach_host.h... no
checking mach/mach_init.h usability... no
checking mach/mach_init.h presence... no
checking for mach/mach_init.h... no
checking for sys/sysctl.h... yes
checking whether CTL_HW is declared... no
checking whether HW_NCPU is declared... no
checking for sysctl... yes
checking for sysctlbyname... no
checking for pthread_t... yes
checking whether function sched_setaffinity is declared... yes
checking for old prototype of sched_setaffinity... no
checking for working CPU_SET... yes
checking for working CPU_SET_S... yes
checking for working _syscall3... no
checking for KERRIGHED... no
checking for lib... no
checking for bash... /bin/bash
checking for ffs... yes
checking whether function ffs is declared... yes
checking for ffsl... yes
checking whether function ffsl is declared... yes
checking for fls... no
checking for flsl... no
checking for clz... no
checking for clzl... no
checking for openat... yes
checking for getpagesize... yes
checking for posix_memalign... yes
checking sys/utsname.h usability... yes
checking sys/utsname.h presence... yes
checking for sys/utsname.h... yes
checking for uname... yes
checking numaif.h usability... no
checking numaif.h presence... no
checking for numaif.h... no
checking pthread_np.h usability... no
checking pthread_np.h presence... no
checking for pthread_np.h... no
checking whether pthread_setaffinity_np is declared... yes
checking whether pthread_getaffinity_np is declared... yes
checking for sched_setaffinity... yes
checking for sys/cpuset.h... no
checking for library containing pthread_getthrds_np... no
checking for XML... no
checking for cpuid... yes
checking for X... no
libraries... yes
checking whether to build static libraries... no
config.status: creating include/Makefile
config.status: creating src/Makefile
config.status: creating include/private/autogen/config.h
config.status: include/private/autogen/config.h is unchanged
config.status: creating include/hwloc/autogen/config.h
config.status: include/hwloc/autogen/config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
configure: ===== done with tools/topo/hwloc/hwloc configure =====
configure: ===== configuring tools/topo/plpa/plpa =====
/home/alibeck/Downloads/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/configure
--enable-included-mode '--with-device=ch3_p4' '--with-mpe' '--with-romio' '--
checking
checking for PLPA version... 1.3.2
checking whether to enable "picky" compiler mode... no (default)
checking for flex... no
checking for lex... no
checking for bison... no
checking for byacc... no
checking for syscall... yes
checking sys/syscall.h usability... yes
checking sys/syscall.h presence... yes
checking for sys/syscall.h... yes
checking for __NR_sched_setaffinity... yes
checking for __NR_sched_getaffinity... yes
checking for PLPA building mode... included
checking if want PLPA maintainer support... enabled
checking for PLPA config prefix... .
checking for PLPA symbol prefix... plpa_
checking valgrind/valgrind.h usability... no
checking valgrind/valgrind.h presence... no
checking for valgrind/valgrind.h... no
configure: WARNING: valgrind.h not found
checking whether to build PLPA executables... no
libraries... yes
checking whether to build shared libraries... no
config.status: creating ./Makefile
config.status: creating ./config/Makefile
config.status: creating ./src/Makefile
config.status: creating ./src/libplpa/Makefile
config.status: creating ./src/plpa-info/Makefile
config.status: creating ./src/plpa-taskset/Makefile
config.status: creating ./src/libplpa/plpa_config.h
config.status: ./src/libplpa/plpa_config.h is unchanged
config.status: creating ./src/libplpa/plpa.h
config.status: ./src/libplpa/plpa.h is unchanged
configure: ===== done with tools/topo/plpa/plpa configure =====
checking available processor topology libraries...  hwloc plpa
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for pthread_key_create in -lpthread... yes
checking checkpointing library... none
checking demux engine... poll,select,port
checking for poll... yes
checking for select... yes
checking debugging support... none
checking error checking... yes
checking warnings... no
checking profiling... yes
checking libftb.h usability... no
checking libftb.h presence... no
checking for libftb.h... no
checking for FTB_Connect in -lftb... no
checking for strsignal... (cached) yes
checking whether strsignal needs a declaration... no
checking for sigaction... (cached) yes
checking for signal... (cached) yes
checking for sigset... yes
checking for struct sigaction and sa_handler... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
config.status: creating tools/bootstrap/src/bsci_init.c
config.status: creating hydra-doxygen.cfg
config.status: creating include/hydra_config.h
configure:50586: ===== done with src/pm/hydra configure =====
configure: ===== done with src/pm/hydra configure =====
configure:50460: ===== configuring src/mpe2 =====
configure: ===== configuring src/mpe2 =====
/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2/configure  '--with-
checking
configure: executing: /home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2/configure
'--with-device=ch3_p4' '--with-mpe' '--with-romio' '--enable-fc' '--enable-
cxx' '--enable-debug' '--enable-traceback' '--prefix' '/opt/mpich' --disable-
option-checking
Configuring MPE Profiling System with  '--with-device=ch3_p4' '--with-mpe' '--
with-romio' '--enable-fc' '--enable-cxx' '--enable-debug' '--enable-traceback'
'--prefix' '/opt/mpich' '--disable-option-checking'
'MPI_CC=/home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpicc'
'MPI_F77=/home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=
-O2' 'LDFLAGS= ' 'LIBS=-lrt  ' 'CPPFLAGS= -
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src' 'F77=gfortran'
'FFLAGS=  -O2'
checking for current directory name...
checking gnumake... yes using --no-print-directory
checking BSD 4.4 make... no - whew
checking OSF V3 make... no
This MPE build is part of the MPICH2 build
checking for leftover Makefiles in subpackages ...  "src/misc" "src/callstack"
"src/logging" "src/wrappers" "src/collchk" "src/slog2sdk" cleaned
checking whether MPI_CC has been set ...
checking whether gfortran accepts -g... yes
checking whether MPI_F77 has been set ...
checking how to get verbose linking output from gfortran... -v
checking for Fortran 77 libraries of gfortran...  -L/usr/lib/x86_64-linux-
gnu/gcc/x86_64-linux-gnu/4.5.2 -L/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-
gnu/4.5.2/../../.. -L/usr/lib/x86_64-linux-gnu -lrt -lgfortran -lm
checking whether gfortran accepts the FLIBS found by autoconf... yes
checking whether C can link with  -L/usr/lib/x86_64-linux-gnu/gcc/x86_64-
gnu/4.5.2/../../.. -L/usr/lib/x86_64-linux-gnu -lrt -lgfortran -lm... yes
checking for linker for Fortran main programs... Use Fortran to link programs
checking whether Fortran 77 and C objects are compatible... yes
checking for Fortran 77 name mangling... lower underscore
checking what libraries are needed to link Fortran programs with C routines
that use stdio... none
checking for Fortran 77 flag for library directories... -L
checking for include directory flag for Fortran... -I
checking whether install works... yes
checking whether install breaks libraries... no
config.status: creating sbin/mpetestlink
config.status: creating sbin/mpetestexec
config.status: creating sbin/mpetestexeclog
config.status: creating sbin/mpeinstall
config.status: creating sbin/mpecheckinstall
config.status: WARNING:  'sbin/mpecheckinstall.in' seems to ignore the --
datarootdir setting
config.status: creating sbin/mpecheckbuild
config.status: creating etc/mpe_help.conf
config.status: creating etc/mpe_f77env.conf
config.status: creating mpe_conf.h
=== configuring in src/misc
(/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2/src/misc)
configure: running /bin/bash ./configure --disable-option-checking '--
prefix=/opt/mpich'  '--with-device=ch3_p4' '--with-mpe' '--with-romio' '--
'FFLAGS=  -O2' --cache-file=/dev/null --srcdir=.
Configuring MPE Miscellaneous Library with  '--disable-option-checking' '--
'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for dbx... no
checking for gdb... /usr/bin/gdb
checking for sysinfo... yes
checking sys/systeminfo.h usability... no
checking sys/systeminfo.h presence... no
checking for sys/systeminfo.h... no
checking for sighandler_t... no
checking for kill... yes
checking whether kill needs a declaration... no
config.status: creating src/dbxerr.c
config.status: creating mpe_misc_conf.h
=== configuring in src/callstack
(/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2/src/callstack)
Configuring MPE CallStack Library with  '--disable-option-checking' '--
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking execinfo.h usability... yes
checking execinfo.h presence... yes
checking for execinfo.h... yes
checking whether <execinfo.h> defines backtrace_symbols_fd() ... yes
checking if <execinfo.h> links with -Wl,--export-dynamic ... yes
checking for fdopen... yes
checking whether fdopen needs a declaration... no
config.status: creating include/mpe_callstack.h
config.status: creating etc/mpe_callstack_ldflags.conf
config.status: creating bin/bt2line
config.status: creating mpe_callstack_conf.h
=== configuring in src/logging
(/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2/src/logging)
Configuring MPE Logging Library and Tools with  '--disable-option-checking' '--
checking whether byte ordering is bigendian... no
checking sys/bitypes.h usability... yes
checking sys/bitypes.h presence... yes
checking for sys/bitypes.h... yes
checking for header that defines C99 integer types, intXX_t ... <stdint.h>
checking for inttypes.h... (cached) yes
checking whether <inttypes.h> defines the PRIdXX macros ... yes
checking if <stdint.h> can be behind system headers ... yes
checking for address-sized integer ... CLOG_int64_t
checking for mkstemp... yes
checking whether mkstemp needs a declaration... no
checking for srand48... yes
checking whether srand48 needs a declaration... no
checking for lrand48... yes
checking whether lrand48 needs a declaration... no
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for O_LARGEFILE for open() ... needs _LARGEFILE64_SOURCE
checking for O_BINARY for open() ... no
checking for pthread_mutex_lock in -lpthread... yes
config.status: creating include/clog_inttypes.h
config.status: creating include/mpi_null.h
config.status: creating include/mpe_log_thread.h
config.status: creating etc/mpe_log.conf
config.status: creating etc/mpe_nolog.conf
config.status: creating etc/mpe_log_postlib.conf
config.status: creating mpe_logging_conf.h
=== configuring in src/wrappers
(/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2/src/wrappers)
Configuring MPE Wrapper Libraries For MPI with  '--disable-option-checking' '--
checking for working alloca.h... yes
checking for alloca... yes
checking for stdarg is correct... yes
checking if compiler accepts prototypes ... yes
checking for safe PMPI invocations ... no
checking for the value of MPI_STATUS_SIZE ... 5
config.status: creating etc/mpe_mpilog.conf
config.status: creating etc/mpe_mpitrace.conf
config.status: creating mpe_wrappers_conf.h
=== configuring in src/graphics
(/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2/src/graphics)
Configuring MPE X Graphics Library with  '--disable-option-checking' '--
configure: WARNING:  Could not find appropriate X windows libraries.  MPE
routines that make use of X11 graphics will NOT be built unless you put X
windows libraries in your path and reconfigure!
=== configuring in src/collchk
(/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2/src/collchk)
Configuring MPE Collective and Datatype Checking Library with  '--disable-
option-checking' '--prefix=/opt/mpich' '--with-device=ch3_p4' '--with-mpe' '--
config.status: creating etc/mpe_mpicheck.conf
config.status: creating mpe_collchk_conf.h
=== configuring in src/slog2sdk
(/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2/src/slog2sdk)
Configuring SLOG2SDK with  '--disable-option-checking' '--prefix=/opt/mpich' '--
with-device=ch3_p4' '--with-mpe' '--with-romio' '--enable-fc' '--enable-cxx'
checking if CLASSPATH is set... no, good to go
checking for java in user's PATH... found /usr/bin/java
checking if /usr/bin/java runs simple java class... yes
checking if /usr/bin/java runs simple jar file... yes
checking if /usr/bin/java runs non-GUI tool... yes
checking if /usr/bin/java runs simple Swing class... yes
checking if /usr/bin/java runs simple Swing jar file... yes
checking for Java version... java full version "1.6.0_26-b03", i.e. Java 2 SDK
checking for cygpath... no
creating sample logfiles from source
checking for leftover Makefiles in subpackages ... none
config.status: creating sbin/install-package
config.status: creating bin/slog2print
config.status: creating bin/slog2navigator
config.status: creating bin/slog2filter
config.status: creating bin/slog2updater
config.status: creating bin/logconvertor
config.status: creating bin/jumpshot
config.status: creating bin/clogprint
config.status: creating bin/clogTOslog2
config.status: creating bin/clog2print
config.status: creating bin/clog2TOslog2
=== configuring in trace_rlog
(/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2/src/slog2sdk/trace_rlog)
Configuring TRACE_RLOG implementation with  '--disable-option-checking' '--
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking size of long... 8
checking size of __int64... 0
checking for sed... sed
checking for a sed that does not truncate output... sed
libraries... yes
checking for malloc in -lefence... no
checking for strstr... yes
checking for javah in user's PATH... found /usr/bin/javah
checking if /usr exists... yes
checking for <jni.h> include flag... no
checking for javah in known path... found /usr/lib/jvm/java-6-
sun-1.6.0.26/bin/javah
checking if /usr/lib/jvm/java-6-sun-1.6.0.26 exists... yes
checking for <jni.h> include flag... found -I/usr/lib/jvm/java-6-
sun-1.6.0.26/include -I/usr/lib/jvm/java-6-sun-1.6.0.26/include/linux
checking for <jni.h> usability... yes
checking for ranlib... (cached) ranlib
config.status: creating bin/traceprint
config.status: creating bin/traceTOslog2
config.status: creating trace_impl.h
SLOG2SDK:  "trace_rlog" have been configured
MPE2:  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/collchk"
"src/slog2sdk" have been configured
configure:50586: ===== done with src/mpe2 configure =====
configure: ===== done with src/mpe2 configure =====
configure:50624: checking size of OPA_ptr_t
checking size of OPA_ptr_t... configure:50953: gcc -o conftest    -O2  -
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src   conftest.c -lrt   >&5
configure:50957: $? = 0
configure:50963: ./conftest
configure:50967: $? = 0
configure:50993: result: 8
8
configure:51048: checking the sizeof MPI_Offset
checking the sizeof MPI_Offset... configure:51348: gcc -o conftest    -O2  -
configure:51352: $? = 0
configure:51358: ./conftest
configure:51362: $? = 0
configure:51382: result: 8
8
configure:51432: checking whether the Fortran Offset type works with Fortran 77
checking whether the Fortran Offset type works with Fortran 77...
configure:51447: gfortran -c   -O2 conftest.f >&5
configure:51454: $? = 0
configure:51468: result: yes
yes
configure:51482: checking whether the Fortran Offset type works with Fortran 90
checking whether the Fortran Offset type works with Fortran 90...
configure:51497: f95 -c   -O2  conftest.f90 >&5
configure:51504: $? = 0
configure:51524: result: yes
yes
Running Configure for Fortran 90 Type routines
configure: WARNING: unrecognized options: --with-device, --with-mpe, --with-
romio, --enable-fc, --enable-cxx, --enable-debug, --enable-traceback
checking whether we are using the GNU Fortran compiler... yes
checking for the precision and range of reals...  6 , 37
checking for the precision and range of double precision...  15 , 307
checking for the range of integer...  9
checking for linker for Fortran main program... Use Fortran to link programs
checking for Fortran 77 name mangling... lower uscore
checking for available integer kinds...  2 , 1, 4 , 2, 9 , 4, 18 , 8,
checking for available integer ranges...  {  2 , 1 , 1 }, {  4 , 2 , 2 }, {  9
, 4 , 4 }, {  18 , 8 , 8 },
config.status: creating mpif90model.h
configure:51625: WARNING: The ch3_p4 device did not set the maximum size of a
processor name, 128 being used.
configure: WARNING: The ch3_p4 device did not set the maximum size of a
configure:51849: creating ./config.status
## Running config.status. ##
This file was extended by config.status, which was
generated by GNU Autoconf 2.63.  Invocation command line was
  CONFIG_FILES    =
  CONFIG_HEADERS  =
  CONFIG_LINKS    =
  CONFIG_COMMANDS =
  $ ./config.status
on NB403276-W510
config.status:1364: creating Makefile
config.status:1364: creating src/Makefile
config.status:1364: creating src/include/Makefile
config.status: creating src/include/Makefile
config.status:1364: creating src/include/mpich2info.h
config.status: creating src/include/mpich2info.h
config.status:1364: creating mpich2-doxygen
config.status: creating mpich2-doxygen
config.status:1364: creating src/include/mpichtimer.h
config.status: creating src/include/mpichtimer.h
config.status:1364: creating src/binding/Makefile
config.status: creating src/binding/Makefile
config.status:1364: creating src/binding/cxx/Makefile
config.status: creating src/binding/cxx/Makefile
config.status:1364: creating src/binding/cxx/mpicxx.h
config.status: creating src/binding/cxx/mpicxx.h
config.status:1364: creating src/binding/f77/Makefile
config.status: creating src/binding/f77/Makefile
config.status:1364: creating src/binding/f77/mpif.h
config.status: creating src/binding/f77/mpif.h
config.status:1364: creating src/binding/f77/setbotf.f
config.status: creating src/binding/f77/setbotf.f
config.status:1364: creating src/binding/f77/setbot.c
config.status: creating src/binding/f77/setbot.c
config.status:1364: creating src/binding/f90/Makefile
config.status: creating src/binding/f90/Makefile
config.status:1364: creating src/binding/f90/mpi_sizeofs.f90
config.status: creating src/binding/f90/mpi_sizeofs.f90
config.status:1364: creating src/binding/f90/mpi_base.f90
config.status: creating src/binding/f90/mpi_base.f90
config.status:1364: creating src/packaging/Makefile
config.status: creating src/packaging/Makefile
config.status:1364: creating src/packaging/pkgconfig/mpich2-c.pc
config.status: creating src/packaging/pkgconfig/mpich2-c.pc
config.status:1364: creating src/packaging/pkgconfig/mpich2-cxx.pc
config.status: creating src/packaging/pkgconfig/mpich2-cxx.pc
config.status:1364: creating src/packaging/pkgconfig/mpich2-f77.pc
config.status: creating src/packaging/pkgconfig/mpich2-f77.pc
config.status:1364: creating src/packaging/pkgconfig/mpich2-f90.pc
config.status: creating src/packaging/pkgconfig/mpich2-f90.pc
config.status:1364: creating src/packaging/pkgconfig/Makefile
config.status: creating src/packaging/pkgconfig/Makefile
config.status:1364: creating src/packaging/envmods/mpich2.module
config.status: creating src/packaging/envmods/mpich2.module
config.status:1511: WARNING:  'src/packaging/envmods/mpich2.module.in' seems to
ignore the --datarootdir setting
config.status: WARNING:  'src/packaging/envmods/mpich2.module.in' seems to
config.status:1364: creating src/packaging/envmods/Makefile
config.status: creating src/packaging/envmods/Makefile
config.status:1364: creating src/env/mpixxx_opts.conf
config.status: creating src/env/mpixxx_opts.conf
config.status:1364: creating src/env/mpicc
config.status: creating src/env/mpicc
config.status:1364: creating src/env/mpicc.conf
config.status: creating src/env/mpicc.conf
config.status:1364: creating src/env/mpicc.bash
config.status: creating src/env/mpicc.bash
config.status:1364: creating src/env/mpicxx
config.status: creating src/env/mpicxx
config.status:1364: creating src/env/mpicxx.conf
config.status: creating src/env/mpicxx.conf
config.status:1364: creating src/env/mpicxx.bash
config.status: creating src/env/mpicxx.bash
config.status:1364: creating src/env/mpif77
config.status: creating src/env/mpif77
config.status:1364: creating src/env/mpif77.conf
config.status: creating src/env/mpif77.conf
config.status:1364: creating src/env/mpif77.bash
config.status: creating src/env/mpif77.bash
config.status:1364: creating src/env/mpif90
config.status: creating src/env/mpif90
config.status:1364: creating src/env/mpif90.conf
config.status: creating src/env/mpif90.conf
config.status:1364: creating src/env/mpif90.bash
config.status: creating src/env/mpif90.bash
config.status:1364: creating src/env/Makefile
config.status: creating src/env/Makefile
config.status:1364: creating src/util/createshlib
config.status: creating src/util/createshlib
config.status:1364: creating src/mpi/Makefile
config.status: creating src/mpi/Makefile
config.status:1364: creating src/mpi/attr/Makefile
config.status: creating src/mpi/attr/Makefile
config.status:1364: creating src/mpi/coll/Makefile
config.status: creating src/mpi/coll/Makefile
config.status:1364: creating src/mpi/comm/Makefile
config.status: creating src/mpi/comm/Makefile
config.status:1364: creating src/mpi/datatype/Makefile
config.status: creating src/mpi/datatype/Makefile
config.status:1364: creating src/mpi/debugger/Makefile
config.status: creating src/mpi/debugger/Makefile
config.status:1364: creating src/mpi/errhan/Makefile
config.status: creating src/mpi/errhan/Makefile
config.status:1364: creating src/mpi/group/Makefile
config.status: creating src/mpi/group/Makefile
config.status:1364: creating src/mpi/init/Makefile
config.status: creating src/mpi/init/Makefile
config.status:1364: creating src/mpi/misc/Makefile
config.status: creating src/mpi/misc/Makefile
config.status:1364: creating src/mpi/pt2pt/Makefile
config.status: creating src/mpi/pt2pt/Makefile
config.status:1364: creating src/mpi/rma/Makefile
config.status: creating src/mpi/rma/Makefile
config.status:1364: creating src/mpi/spawn/Makefile
config.status: creating src/mpi/spawn/Makefile
config.status:1364: creating src/mpi/timer/Makefile
config.status: creating src/mpi/timer/Makefile
config.status:1364: creating src/mpi/topo/Makefile
config.status: creating src/mpi/topo/Makefile
config.status:1364: creating src/mpix/Makefile
config.status: creating src/mpix/Makefile
config.status:1364: creating src/mpix/comm/Makefile
config.status: creating src/mpix/comm/Makefile
config.status:1364: creating src/mpid/Makefile
config.status: creating src/mpid/Makefile
config.status:1364: creating src/mpid/common/Makefile
config.status: creating src/mpid/common/Makefile
config.status:1364: creating src/mpid/common/datatype/Makefile
config.status: creating src/mpid/common/datatype/Makefile
config.status:1364: creating src/mpid/common/datatype/dataloop/Makefile
config.status: creating src/mpid/common/datatype/dataloop/Makefile
config.status:1364: creating src/pm/Makefile
config.status: creating src/pm/Makefile
config.status:1364: creating src/pmi/Makefile
config.status: creating src/pmi/Makefile
config.status:1364: creating src/pmi/simple/Makefile
config.status: creating src/pmi/simple/Makefile
config.status:1364: creating src/nameserv/Makefile
config.status: creating src/nameserv/Makefile
config.status:1364: creating src/nameserv/file/Makefile
config.status: creating src/nameserv/file/Makefile
config.status:1364: creating src/nameserv/mpd/Makefile
config.status: creating src/nameserv/mpd/Makefile
config.status:1364: creating src/nameserv/pmi/Makefile
config.status: creating src/nameserv/pmi/Makefile
config.status:1364: creating src/nameserv/test/Makefile
config.status: creating src/nameserv/test/Makefile
config.status:1364: creating src/util/Makefile
config.status: creating src/util/Makefile
config.status:1364: creating src/util/info/Makefile
config.status: creating src/util/info/Makefile
config.status:1364: creating src/util/instrm/Makefile
config.status: creating src/util/instrm/Makefile
config.status:1364: creating src/util/thread/Makefile
config.status: creating src/util/thread/Makefile
config.status:1364: creating src/util/mem/Makefile
config.status: creating src/util/mem/Makefile
config.status:1364: creating src/util/msgs/Makefile
config.status: creating src/util/msgs/Makefile
config.status:1364: creating src/util/param/Makefile
config.status: creating src/util/param/Makefile
config.status:1364: creating src/util/dbg/Makefile
config.status: creating src/util/dbg/Makefile
config.status:1364: creating src/util/dbg/getfuncstack
config.status: creating src/util/dbg/getfuncstack
config.status:1364: creating src/util/osserv/Makefile
config.status: creating src/util/osserv/Makefile
config.status:1364: creating src/util/procmap/Makefile
config.status: creating src/util/procmap/Makefile
config.status:1364: creating src/util/other/Makefile
config.status: creating src/util/other/Makefile
config.status:1364: creating src/include/mpi.h
config.status: creating src/include/mpi.h
config.status:1364: creating test/Makefile
config.status:1364: creating test/util/Makefile
config.status: creating test/util/Makefile
config.status:1364: creating test/basic/Makefile
config.status: creating test/basic/Makefile
config.status:1364: creating test/commands/Makefile
config.status: creating test/commands/Makefile
config.status:1364: creating test/commands/cmdtests
config.status: creating test/commands/cmdtests
config.status:1364: creating test/mpid/Makefile
config.status: creating test/mpid/Makefile
config.status:1364: creating test/mpid/ch3/Makefile
config.status: creating test/mpid/ch3/Makefile
config.status:1364: creating test/util/timer/Makefile
config.status: creating test/util/timer/Makefile
config.status:1364: creating examples/Makefile
config.status: creating examples/Makefile
config.status:1364: creating examples/f77/Makefile
config.status: creating examples/f77/Makefile
config.status:1364: creating examples/f90/Makefile
config.status: creating examples/f90/Makefile
config.status:1364: creating examples/cxx/Makefile
config.status: creating examples/cxx/Makefile
config.status:1364: creating src/util/logging/Makefile
config.status: creating src/util/logging/Makefile
config.status:1364: creating src/util/logging/common/Makefile
config.status: creating src/util/logging/common/Makefile
config.status:1364: creating doc/Makefile
config.status: creating doc/Makefile
config.status:1364: creating doc/mansrc/Makefile
config.status: creating doc/mansrc/Makefile
config.status:1364: creating doc/mansrc/createhtmlindex
config.status: creating doc/mansrc/createhtmlindex
config.status:1364: creating doc/refman/Makefile
config.status: creating doc/refman/Makefile
config.status:1364: creating doc/installguide/Makefile
config.status: creating doc/installguide/Makefile
config.status:1364: creating doc/userguide/Makefile
config.status: creating doc/userguide/Makefile
config.status:1364: creating doc/logging/Makefile
config.status: creating doc/logging/Makefile
config.status:1364: creating doc/design/Makefile
config.status: creating doc/design/Makefile
config.status:1364: creating doc/smpd/Makefile
config.status: creating doc/smpd/Makefile
config.status:1364: creating doc/windev/Makefile
config.status: creating doc/windev/Makefile
config.status:1364: creating src/include/mpichconf.h
config.status: creating src/include/mpichconf.h
config.status:1580: src/include/mpichconf.h is unchanged
config.status: src/include/mpichconf.h is unchanged
config.status:1598: executing default-1 commands
config.status:1598: executing default-2 commands
config.status: executing default-2 commands
config.status:1598: executing default-3 commands
config.status: executing default-3 commands
config.status:1598: executing default-4 commands
config.status: executing default-4 commands
config.status:1598: executing default-5 commands
config.status: executing default-5 commands
config.status:1598: executing default-6 commands
config.status: executing default-6 commands
config.status:1598: executing default-7 commands
config.status: executing default-7 commands
config.status:1598: executing default-8 commands
config.status: executing default-8 commands
config.status:1598: executing default-9 commands
config.status: executing default-9 commands
config.status:1598: executing default-10 commands
config.status: executing default-10 commands
config.status:1598: executing default-11 commands
config.status: executing default-11 commands
config.status:1598: executing default-12 commands
config.status: executing default-12 commands
configure:53314: === configuring in test/mpi
(/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi)
=== configuring in test/mpi (/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi)
configure:53417: running /bin/bash ./configure --disable-option-checking '--
enable-fc' '--enable-cxx' '--enable-debug' '--enable-traceback' --cache-
RUNNING CONFIGURE FOR MPI TESTS
checking whether /home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpicc accepts -
g... yes
checking for /home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpicc option to accept
checking whether long double is supported... yes
checking whether long long is supported... yes
/home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpicc -E
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking for major version of MPI... 2
checking for minor version of MPI... 2
checking whether /home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpif77 accepts -
g... yes
checking whether integer*4 is supported... yes
checking whether integer*8 is supported... yes
checking whether integer*16 is supported... yes
/home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpif77... -v
/home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpif77...  -L/usr/lib/x86_64-linux-
gnu/4.5.2/../../.. -L/usr/lib/x86_64-linux-gnu -lgfortran -lm
checking for Fortran libraries needed for getarg... none needed
checking whether Fortran 77 supports Cray-style pointer... yes
checking for Fortran 77 compiler flag for Cray-style pointer... -fcray-pointer
checking whether /home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpif90 accepts -
g... yes
checking whether the Fortran 90 compiler
(/home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpif90  -nativelinking  ) works...
yes
(/home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpif90  -nativelinking  ) is a
cross-compiler... no
checking for Fortran flag needed to allow free-form source... none
checking whether Fortran 90 supports Cray-style pointer... yes
checking for Fortran 90 compiler flag for Cray-style pointer... -fcray-pointer
checking whether we are using the GNU C++ compiler... yes
checking whether /home/alibeck/Downloads/mpich2-1.4.1p1/bin/mpicxx accepts -
g... yes
checking whether <iostream> available... yes
checking whether the compiler implements namespaces... yes
checking whether the compiler implements the namespace std... yes
checking whether MPI_2DOUBLE_COMPLEX is available... no
checking whether MPI_2COMPLEX is available... no
checking size of short... 2
checking for C integer type of address size... long
checking for perl... /usr/bin/perl
config.status: creating maint/testmerge
config.status: creating runtests
config.status: creating basic/Makefile
config.status: creating attr/Makefile
config.status: creating util/Makefile
config.status: creating coll/Makefile
config.status: creating comm/Makefile
config.status: creating datatype/Makefile
config.status: creating errhan/Makefile
config.status: creating group/Makefile
config.status: creating info/Makefile
config.status: creating init/Makefile
config.status: creating pt2pt/Makefile
config.status: creating rma/Makefile
config.status: creating spawn/Makefile
config.status: creating topo/Makefile
config.status: creating io/Makefile
config.status: creating f77/Makefile
config.status: creating f77/attr/Makefile
config.status: creating f77/attr/attraints.h
config.status: creating f77/pt2pt/attr1aints.h
config.status: creating f77/ext/add1size.h
config.status: creating f77/datatype/Makefile
config.status: creating f77/datatype/typeaints.h
config.status: creating f77/util/Makefile
config.status: creating f77/coll/Makefile
config.status: creating f77/comm/Makefile
config.status: creating f77/topo/Makefile
config.status: creating f77/init/Makefile
config.status: creating f77/rma/addsize.h
config.status: creating f77/pt2pt/Makefile
config.status: creating f77/info/Makefile
config.status: creating f77/spawn/Makefile
config.status: creating f77/spawn/type1aint.h
config.status: creating f77/rma/Makefile
config.status: creating f77/ext/Makefile
config.status: creating f77/ext/testlist
config.status: creating f77/io/Makefile
config.status: creating f77/io/iooffset.h
config.status: creating f77/io/iodisp.h
config.status: creating f77/io/ioaint.h
config.status: creating f90/Makefile
config.status: creating f90/attr/Makefile
config.status: creating f90/datatype/Makefile
config.status: creating f90/f90types/Makefile
config.status: creating f90/util/Makefile
config.status: creating f90/coll/Makefile
config.status: creating f90/comm/Makefile
config.status: creating f90/topo/Makefile
config.status: creating f90/init/Makefile
config.status: creating f90/pt2pt/Makefile
config.status: creating f90/rma/Makefile
config.status: creating f90/info/Makefile
config.status: creating f90/spawn/Makefile
config.status: creating f90/timer/Makefile
config.status: creating f90/ext/Makefile
config.status: creating f90/ext/testlist
config.status: creating f90/io/Makefile
config.status: creating f90/misc/Makefile
config.status: creating cxx/Makefile
config.status: creating cxx/util/Makefile
config.status: creating cxx/attr/Makefile
config.status: creating cxx/pt2pt/Makefile
config.status: creating cxx/comm/Makefile
config.status: creating cxx/coll/Makefile
config.status: creating cxx/errhan/Makefile
config.status: creating cxx/info/Makefile
config.status: creating cxx/datatype/Makefile
config.status: creating cxx/io/Makefile
config.status: creating cxx/init/Makefile
config.status: creating cxx/rma/Makefile
config.status: creating cxx/spawn/Makefile
config.status: creating threads/Makefile
config.status: creating threads/pt2pt/Makefile
config.status: creating threads/util/Makefile
config.status: creating threads/comm/Makefile
config.status: creating threads/init/Makefile
config.status: creating threads/spawn/Makefile
config.status: creating errors/Makefile
config.status: creating errors/attr/Makefile
config.status: creating errors/basic/Makefile
config.status: creating errors/coll/Makefile
config.status: creating errors/comm/Makefile
config.status: creating errors/faults/Makefile
config.status: creating errors/group/Makefile
config.status: creating errors/pt2pt/Makefile
config.status: creating errors/rma/Makefile
config.status: creating errors/spawn/Makefile
config.status: creating errors/topo/Makefile
config.status: creating errors/io/Makefile
config.status: creating errors/cxx/Makefile
config.status: creating errors/cxx/errhan/Makefile
config.status: creating errors/cxx/io/Makefile
config.status: creating errors/f77/Makefile
config.status: creating errors/f90/Makefile
config.status: creating manual/Makefile
config.status: creating manual/manyconnect
config.status: creating perf/Makefile
config.status: creating testlist
config.status: creating cxx/testlist
config.status: creating f77/testlist
config.status: creating f90/testlist
config.status: creating threads/testlist
config.status: creating errors/testlist
config.status: creating errors/cxx/testlist
config.status: creating include/mpitestconf.h
config.status: include/mpitestconf.h is unchanged
Configuration completed.
## Cache variables. ##
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_c_bigendian=no
ac_cv_c_compiler_gnu=yes
ac_cv_c_const=yes
ac_cv_c_inline=inline
ac_cv_c_int16_t=yes
ac_cv_c_int32_t=yes
ac_cv_c_int64_t=yes
ac_cv_c_int8_t=yes
ac_cv_c_restrict=__restrict
ac_cv_c_uint16_t=yes
ac_cv_c_uint32_t=yes
ac_cv_c_uint64_t=yes
ac_cv_c_uint8_t=yes
ac_cv_c_volatile=yes
ac_cv_cxx_bool=yes
ac_cv_cxx_compiler_gnu=yes
ac_cv_cxx_exceptions=yes
ac_cv_cxx_namespace_std=yes
ac_cv_cxx_namespaces=yes
ac_cv_env_AR_FLAGS_set=
ac_cv_env_AR_FLAGS_value=
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FCFLAGS_set=
ac_cv_env_FCFLAGS_value=
ac_cv_env_FC_set=
ac_cv_env_FC_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_FROM_MPICH2_set=
ac_cv_env_FROM_MPICH2_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_MPICH2LIB_CFLAGS_set=
ac_cv_env_MPICH2LIB_CFLAGS_value=
ac_cv_env_MPICH2LIB_CPPFLAGS_set=
ac_cv_env_MPICH2LIB_CPPFLAGS_value=
ac_cv_env_MPICH2LIB_CXXFLAGS_set=
ac_cv_env_MPICH2LIB_CXXFLAGS_value=
ac_cv_env_MPICH2LIB_FCFLAGS_set=
ac_cv_env_MPICH2LIB_FCFLAGS_value=
ac_cv_env_MPICH2LIB_FFLAGS_set=
ac_cv_env_MPICH2LIB_FFLAGS_value=
ac_cv_env_MPICH2LIB_LDFLAGS_set=
ac_cv_env_MPICH2LIB_LDFLAGS_value=
ac_cv_env_MPICH2LIB_LIBS_set=
ac_cv_env_MPICH2LIB_LIBS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_f77_compiler_gnu=yes
ac_cv_f77_libs=' -L/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2 -
L/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/../../.. -
L/usr/lib/x86_64-linux-gnu -lgfortran -lm'
ac_cv_fc_compiler_gnu=yes
ac_cv_func_alarm=yes
ac_cv_func_alloca_works=yes
ac_cv_func_bindprocessor=no
ac_cv_func_clock_getres=no
ac_cv_func_clock_gettime=no
ac_cv_func_fdopen=yes
ac_cv_func_gethrtime=no
ac_cv_func_getpid=yes
ac_cv_func_gettimeofday=yes
ac_cv_func_mach_absolute_time=no
ac_cv_func_mkstemp=yes
ac_cv_func_putenv=yes
ac_cv_func_qsort=yes
ac_cv_func_sched_getaffinity=yes
ac_cv_func_sched_setaffinity=yes
ac_cv_func_sched_yield=yes
ac_cv_func_select=yes
ac_cv_func_setitimer=yes
ac_cv_func_sleep=yes
ac_cv_func_snprintf=yes
ac_cv_func_strdup=yes
ac_cv_func_strerror=yes
ac_cv_func_strerror_r=yes
ac_cv_func_strerror_r_char_p=no
ac_cv_func_strncasecmp=yes
ac_cv_func_thread_policy_set=no
ac_cv_func_usleep=yes
ac_cv_func_vsnprintf=yes
ac_cv_func_vsprintf=yes
ac_cv_func_yield=no
ac_cv_have_decl_strerror_r=yes
ac_cv_header_assert_h=yes
ac_cv_header_complex=yes
ac_cv_header_complex_h=yes
ac_cv_header_endian_h=yes
ac_cv_header_errno_h=yes
ac_cv_header_inttypes_h=yes
ac_cv_header_limits_h=yes
ac_cv_header_sched_h=yes
ac_cv_header_stdarg_h=yes
ac_cv_header_stdbool_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stddef_h=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdio_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_sys_bitypes_h=yes
ac_cv_header_sys_param_h=yes
ac_cv_header_sys_socket_h=yes
ac_cv_header_sys_time_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_sys_uio_h=yes
ac_cv_header_unistd_h=yes
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_objext=o
ac_cv_path_BASH_SHELL=/bin/bash
ac_cv_path_DOCTEXT=false
ac_cv_path_EGREP='/bin/grep -E'
ac_cv_path_FGREP='/bin/grep -F'
ac_cv_path_GREP=/bin/grep
ac_cv_path_NM_G='/usr/bin/nm -g'
ac_cv_path_PERL=/usr/bin/perl
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_AR=ar
ac_cv_prog_CPP='gcc -E'
ac_cv_prog_CXXCPP='g++ -E'
ac_cv_prog_KILLALL=killall
ac_cv_prog_MAKE=make
ac_cv_prog_RANLIB=ranlib
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_ac_ct_CXX=g++
ac_cv_prog_ac_ct_F77=gfortran
ac_cv_prog_ac_ct_FC=f95
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_f77_g=yes
ac_cv_prog_f77_v=-v
ac_cv_prog_fc_g=yes
ac_cv_prog_install_breaks_libs=no
ac_cv_sizeof_Complex=8
ac_cv_sizeof_DoubleComplex=16
ac_cv_sizeof_LongDoubleComplex=32
ac_cv_sizeof_MPIR_Bsend_data_t=88
ac_cv_sizeof_MPI_Offset=8
ac_cv_sizeof_OPA_ptr_t=8
ac_cv_sizeof__Bool=1
ac_cv_sizeof_bool=1
ac_cv_sizeof_char=1
ac_cv_sizeof_double=8
ac_cv_sizeof_double__Complex=16
ac_cv_sizeof_double_int=16
ac_cv_sizeof_float=4
ac_cv_sizeof_float__Complex=8
ac_cv_sizeof_float_int=8
ac_cv_sizeof_int=4
ac_cv_sizeof_long=8
ac_cv_sizeof_long_double=16
ac_cv_sizeof_long_double__Complex=32
ac_cv_sizeof_long_double_int=32
ac_cv_sizeof_long_int=16
ac_cv_sizeof_long_long=8
ac_cv_sizeof_short=2
ac_cv_sizeof_short_int=8
ac_cv_sizeof_two_int=8
ac_cv_sizeof_unsigned_char=1
ac_cv_sizeof_unsigned_int=4
ac_cv_sizeof_unsigned_long=8
ac_cv_sizeof_unsigned_long_long=8
ac_cv_sizeof_unsigned_short=2
ac_cv_sizeof_void_p=8
ac_cv_sizeof_wchar_t=4
ac_cv_tls=__thread
ac_cv_type__Bool=yes
ac_cv_type_double__Complex=yes
ac_cv_type_float__Complex=yes
ac_cv_type_long_double__Complex=yes
ac_cv_type_size_t=yes
ac_cv_working_alloca_h=yes
pac_cv_attr_weak=yes
pac_cv_attr_weak_alias=no
pac_cv_attr_weak_import=yes
pac_cv_c_char_p_is_byte=yes
pac_cv_c_double_alignment_exception=no
pac_cv_c_double_pos_align=no
pac_cv_c_fp_align_nr=16
pac_cv_c_llint_pos_align=no
pac_cv_c_max_double_fp_align=eight
pac_cv_c_max_fp_align=sixteen
pac_cv_c_max_integer_align=eight
pac_cv_c_max_longdouble_fp_align=sixteen
pac_cv_c_struct_align_nr=8
pac_cv_cc_has___func__=yes
pac_cv_cpu_set_defined=no
pac_cv_cxx_builds_exe=yes
pac_cv_cxx_compiles_string=yes
pac_cv_cxx_has_iostream=yes
pac_cv_cxx_has_math=no
pac_cv_f77_accepts_F=yes
pac_cv_f77_flibs_valid=unknown
pac_cv_f77_sizeof_double_precision=8
pac_cv_f77_sizeof_integer=4
pac_cv_f77_sizeof_real=4
pac_cv_fc_accepts_F90=yes
pac_cv_fc_and_f77=yes
pac_cv_fc_module_case=lower
pac_cv_fc_module_ext=mod
pac_cv_fc_module_incflag=-I
pac_cv_fc_vendor=gnu
pac_cv_fort90_real8=yes
pac_cv_fort_integer16=yes
pac_cv_fort_integer1=yes
pac_cv_fort_integer2=yes
pac_cv_fort_integer4=yes
pac_cv_fort_integer8=yes
pac_cv_fort_real16=no
pac_cv_fort_real4=yes
pac_cv_fort_real8=yes
pac_cv_func_decl_fdopen=yes
pac_cv_func_decl_mkstemp=no
pac_cv_func_decl_putenv=no
pac_cv_func_decl_snprintf=no
pac_cv_func_decl_strdup=no
pac_cv_func_decl_strerror_r=no
pac_cv_func_decl_vsnprintf=no
pac_cv_func_va_copy=yes
pac_cv_gnu_attr_format=yes
pac_cv_gnu_attr_pure=yes
pac_cv_have__func__=yes
pac_cv_have__function__=yes
pac_cv_have_cap__func__=no
pac_cv_have_cpu_set_t=yes
pac_cv_have_long_double=yes
pac_cv_have_long_long=yes
pac_cv_int32_t_alignment=no
pac_cv_int64_t_alignment=no
pac_cv_mkdir_p=yes
pac_cv_my_conf_dir=/home/alibeck/Downloads/mpich2-1.4.1p1
pac_cv_pointers_have_int_alignment=yes
pac_cv_prog_c_multiple_weak_symbols=yes
pac_cv_prog_c_unaligned_doubles=yes
pac_cv_prog_c_weak_symbols='pragma weak'
pac_cv_prog_f77_and_c_stdio_libs=none
pac_cv_prog_f77_exclaim_comments=yes
pac_cv_prog_f77_has_incdir=-I
pac_cv_prog_f77_library_dir_flag=-L
pac_cv_prog_f77_name_mangle='lower uscore'
pac_cv_prog_f77_true_false_value='1 0'
pac_cv_prog_fc_and_c_stdio_libs=none
pac_cv_prog_fc_cross=no
pac_cv_prog_fc_int_kind_16=8
pac_cv_prog_fc_works=yes
pac_cv_prog_make_allows_comments=yes
pac_cv_prog_make_found_clock_skew=no
pac_cv_prog_make_include=yes
pac_cv_prog_make_set_cflags=yes
pac_cv_prog_make_vpath=VPATH
pac_cv_sizeof_mpi_status=20
## Output variables. ##
ABIVERSION='3:3'
ADDRESS_KIND='8'
ALLOCA=''
AR='ar'
AR_FLAGS='cr'
BASH_SHELL='/bin/bash'
BSEND_OVERHEAD='88'
BUILD_BASH_SCRIPTS='yes'
BUILD_DLLS='no'
BUILD_TVDLL='no'
CC='gcc'
CC_SHL='true'
CC_SHL_DBG=''
CFLAGS='   -O2'
CMB_1INT_ALIGNMENT='__attribute__((aligned(16)))'
CMB_STATUS_ALIGNMENT='__attribute__((aligned(32)))'
CONFIGURE_ARGS_CLEAN='--with-device=ch3_p4 --with-mpe --with-romio --enable-fc
--enable-cxx --enable-debug --enable-traceback --prefix /opt/mpich'
CONFIGURE_ARGUMENTS=' '\''--with-device=ch3_p4'\'' '\''--with-mpe'\'' '\''--
with-romio'\'' '\''--enable-fc'\'' '\''--enable-cxx'\'' '\''--enable-debug'\''
'\''--enable-traceback'\'' '\''--prefix'\'' '\''/opt/mpich'\'''
CPP='gcc -E'
CPPFLAGS=' -I/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl/include -
I/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src -
CREATESHLIB='false'
CXX='g++'
CXXCPP='g++ -E'
CXXFLAGS='  -O2'
CXX_DEFS=' -DHAVE_CXX_IOSTREAM -DHAVE_NAMESPACE_STD'
CXX_LINKPATH_SHL=''
CXX_SHL='false'
C_LINKPATH_SHL=''
C_LINK_SHL='true'
C_LINK_SHL_DBG=''
DBG_SHLIB_TYPE=''
DEFS='-DHAVE_CONFIG_H'
DEVICE='ch3_p4'
DEVICE_ARGS=''
DEVICE_NAME='ch3_p4'
DLLIMPORT=''
DOCTEXT='false'
DOCTEXTSTYLE=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
ENABLE_SHLIB='none'
EXEEXT=''
EXTERNAL_SRC_DIRS=' src/mpl src/openpa'
EXTRA_STATUS_DECL=''
F77='gfortran'
F77CPP=''
F77_COMPLEX16='1275072554'
F77_COMPLEX32='1275076652'
F77_COMPLEX8='1275070504'
F77_INCDIR='-I'
F77_INTEGER16='MPI_DATATYPE_NULL'
F77_INTEGER1='1275068717'
F77_INTEGER2='1275068975'
F77_INTEGER4='1275069488'
F77_INTEGER8='1275070513'
F77_LIBDIR_LEADER='-L'
F77_LINKPATH_SHL=''
F77_NAME_MANGLE='F77_NAME_LOWER_USCORE'
F77_OTHER_LIBS=''
F77_REAL16='1275072555'
F77_REAL4='1275069479'
F77_REAL8='1275070505'
F77_SHL='false'
FC='f95'
FCCPP=''
FCEXT='f90'
FCFLAGS='  -O2'
FCINC='-I'
FCINCFLAG='-I'
FCMODEXT='mod'
FCMODINCFLAG='-I'
FCMODINCSPEC=''
FC_LINKPATH_SHL=''
FC_OTHER_LIBS=''
FC_SHL=''
FC_WORK_FILES_ARG=''
FFLAGS='  -O2'
FILE=''
FINCLUDES='-I/home/alibeck/Downloads/mpich2-1.4.1p1/src'
FLIBS=' -L/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2 -
FORTRAN_BINDING='1'
FORTRAN_MPI_OFFSET='integer*8'
FROM_MPICH2='yes'
FWRAPNAME='fmpich'
GCC='yes'
GNUCXX_MINORVERSION='5'
GNUCXX_VERSION='4'
GREP='/bin/grep'
HAVE_CXX_EXCEPTIONS='1'
HAVE_ROMIO='#include "mpio.h"'
INCLUDE_MPICXX_H='#include "mpicxx.h"'
INCLUDE_MPIDDEFS_H='/* ... no device specific definitions ... */'
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
KILLALL='killall'
LDFLAGS=' '
LDFLAGS_DEPS=''
LIBOBJS=''
LIBS='-lrt  '
LIBTOOL=''
LIB_DEPS=''
LTLIBOBJS=''
MAKE='make'
MAKE_DEPEND_C='gcc -MM'
MANY_PM='no'
MKDIR_P='mkdir -p'
MPIBASEMODNAME='mpi_base'
MPICC='$(bindir)/mpicc'
MPICH2LIB_CFLAGS=''
MPICH2LIB_CPPFLAGS=''
MPICH2LIB_CXXFLAGS=''
MPICH2LIB_FCFLAGS=''
MPICH2LIB_FFLAGS=''
MPICH2LIB_LDFLAGS=''
MPICH2LIB_LIBS=''
MPICH2_NUMVERSION='10401301'
MPICH2_RELEASE_DATE='Thu Sep  1 13:53:02 CDT 2011'
MPICH2_VERSION='1.4.1p1'
MPICH_TIMER_KIND='USE_GETTIMEOFDAY'
MPICONSTMODNAME='mpi_constants'
MPICXX='$(bindir)/mpicxx'
MPICXXLIBNAME='mpichcxx'
MPID_TIMER_TYPE='struct timeval'
MPIF77='$(bindir)/mpif77'
MPIFC='$(bindir)/mpif90'
MPIFLIBNAME='mpich'
MPIFPMPI=',PMPI_WTIME,PMPI_WTICK'
MPILIBNAME='mpich'
MPIMODNAME='mpi'
MPIR_CXX_BOOL='0x4c000133'
MPIR_CXX_COMPLEX='0x4c000834'
MPIR_CXX_DOUBLE_COMPLEX='0x4c001035'
MPIR_CXX_LONG_DOUBLE_COMPLEX='0x4c002036'
MPISIZEOFMODNAME='mpi_sizeofs'
MPIU_DLL_SPEC_DEF='#define MPIU_DLL_SPEC'
MPIU_THREAD_LIB_NAME='mpich'
MPI_2COMPLEX='1275072548'
MPI_2DOUBLE_COMPLEX='1275076645'
MPI_2DOUBLE_PRECISION='1275072547'
MPI_2INT='0x4c000816'
MPI_2INTEGER='1275070496'
MPI_2REAL='1275070497'
MPI_AINT='long'
MPI_AINT_DATATYPE='0x4c000843'
MPI_AINT_FMT_DEC_SPEC='%ld'
MPI_AINT_FMT_HEX_SPEC='%lx'
MPI_BYTE='0x4c00010d'
MPI_CHAR='0x4c000101'
MPI_CHARACTER='1275068698'
MPI_COMPLEX16='0x4c00102a'
MPI_COMPLEX32='0x4c00202c'
MPI_COMPLEX8='0x4c000828'
MPI_COMPLEX='1275070494'
MPI_C_BOOL='0x4c00013f'
MPI_C_DOUBLE_COMPLEX='0x4c001041'
MPI_C_FLOAT_COMPLEX='0x4c000840'
MPI_C_LONG_DOUBLE_COMPLEX='0x4c002042'
MPI_DOUBLE='0x4c00080b'
MPI_DOUBLE_COMPLEX='1275072546'
MPI_DOUBLE_INT='0x8c000001'
MPI_DOUBLE_PRECISION='1275070495'
MPI_F77_2INT='1275070486'
MPI_F77_AINT='1275070531'
MPI_F77_BYTE='1275068685'
MPI_F77_CHAR='1275068673'
MPI_F77_C_BOOL='1275068735'
MPI_F77_C_COMPLEX='1275070528'
MPI_F77_C_DOUBLE_COMPLEX='1275072577'
MPI_F77_C_FLOAT_COMPLEX='1275070528'
MPI_F77_C_LONG_DOUBLE_COMPLEX='1275076674'
MPI_F77_DOUBLE='1275070475'
MPI_F77_DOUBLE_INT='-1946157055'
MPI_F77_FLOAT='1275069450'
MPI_F77_FLOAT_INT='-1946157056'
MPI_F77_INT16_T='1275068984'
MPI_F77_INT32_T='1275069497'
MPI_F77_INT64_T='1275070522'
MPI_F77_INT8_T='1275068727'
MPI_F77_INT='1275069445'
MPI_F77_LB='1275068432'
MPI_F77_LONG='1275070471'
MPI_F77_LONG_DOUBLE='1275072524'
MPI_F77_LONG_DOUBLE_INT='-1946157052'
MPI_F77_LONG_INT='-1946157054'
MPI_F77_LONG_LONG='1275070473'
MPI_F77_LONG_LONG_INT='1275070473'
MPI_F77_OFFSET='1275070532'
MPI_F77_PACKED='1275068687'
MPI_F77_SHORT='1275068931'
MPI_F77_SHORT_INT='-1946157053'
MPI_F77_SIGNED_CHAR='1275068696'
MPI_F77_UB='1275068433'
MPI_F77_UINT16_T='1275068988'
MPI_F77_UINT32_T='1275069501'
MPI_F77_UINT64_T='1275070526'
MPI_F77_UINT8_T='1275068731'
MPI_F77_UNSIGNED='1275069446'
MPI_F77_UNSIGNED_CHAR='1275068674'
MPI_F77_UNSIGNED_LONG='1275070472'
MPI_F77_UNSIGNED_LONG_LONG='1275070489'
MPI_F77_UNSIGNED_SHORT='1275068932'
MPI_F77_WCHAR='1275069454'
MPI_FINT='int'
MPI_FLOAT='0x4c00040a'
MPI_FLOAT_INT='0x8c000000'
MPI_INT16_T='0x4c000238'
MPI_INT32_T='0x4c000439'
MPI_INT64_T='0x4c00083a'
MPI_INT8_T='0x4c000137'
MPI_INT='0x4c000405'
MPI_INTEGER16='MPI_DATATYPE_NULL'
MPI_INTEGER1='0x4c00012d'
MPI_INTEGER2='0x4c00022f'
MPI_INTEGER4='0x4c000430'
MPI_INTEGER8='0x4c000831'
MPI_INTEGER='1275069467'
MPI_LB='0x4c000010'
MPI_LOGICAL='1275069469'
MPI_LONG='0x4c000807'
MPI_LONG_DOUBLE='0x4c00100c'
MPI_LONG_DOUBLE_INT='0x8c000004'
MPI_LONG_INT='0x8c000002'
MPI_LONG_LONG='0x4c000809'
MPI_MAX_PROCESSOR_NAME='128'
MPI_OFFSET='long long'
MPI_OFFSET_DATATYPE='0x4c000844'
MPI_OFFSET_TYPEDEF='typedef long long MPI_Offset;'
MPI_PACKED='0x4c00010f'
MPI_REAL16='0x4c00102b'
MPI_REAL4='0x4c000427'
MPI_REAL8='0x4c000829'
MPI_REAL='1275069468'
MPI_SHORT='0x4c000203'
MPI_SHORT_INT='0x8c000003'
MPI_SIGNED_CHAR='0x4c000118'
MPI_STATUS_SIZE='5'
MPI_UB='0x4c000011'
MPI_UINT16_T='0x4c00023c'
MPI_UINT32_T='0x4c00043d'
MPI_UINT64_T='0x4c00083e'
MPI_UINT8_T='0x4c00013b'
MPI_UNSIGNED_CHAR='0x4c000102'
MPI_UNSIGNED_INT='0x4c000406'
MPI_UNSIGNED_LONG='0x4c000808'
MPI_UNSIGNED_LONG_LONG='0x4c000819'
MPI_UNSIGNED_SHORT='0x4c000204'
MPI_WCHAR='0x4c00040e'
NEEDSPLIB='no'
NO_WEAK_SYM=''
NO_WEAK_SYM_TARGET='build_proflib'
OBJEXT='o'
OFFSET_KIND='8'
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PERL='/usr/bin/perl'
PMPIFLIBNAME='pmpich'
PMPILIBNAME='pmpich'
PROFILE_DEF_MPI=''
RANLIB='ranlib'
RANLIB_AFTER_INSTALL='no'
REQD=''
REQI1=''
REQI2=''
REQI8=''
SET_CFLAGS='CFLAGS='
SET_MAKE='MAKE=make'
SHELL='/bin/bash'
SHLIB_EXT='so'
SHLIB_FROM_LO='no'
SHLIB_INSTALL='$(INSTALL_PROGRAM)'
SIZEOF_FC_CHARACTER='1'
SIZEOF_FC_DOUBLE_PRECISION='8'
SIZEOF_FC_INTEGER='4'
SIZEOF_FC_REAL='4'
SIZEOF_MPI_STATUS='20'
USER_CFLAGS=''
USER_CPPFLAGS=''
USER_CXXFLAGS=''
USER_FCFLAGS=''
USER_FFLAGS=''
USER_LDFLAGS=''
USER_LIBS=''
VPATH='VPATH=.:${srcdir}'
WRAPPER_CFLAGS=' '
WRAPPER_CPPFLAGS=' '
WRAPPER_CXXFLAGS=' '
WRAPPER_FCFLAGS=' '
WRAPPER_FFLAGS=' '
WRAPPER_LDFLAGS='  '
WRAPPER_LIBS='-lopa -lmpl  -lrt  '
WTIME_DOUBLE_TYPE='REAL*8'
XARGS_NODATA_OPT='-r'
ac_ct_CC='gcc'
ac_ct_CXX='g++'
ac_ct_F77='gfortran'
ac_ct_FC='f95'
bindings=' f77 f90 cxx'
bindings_dirs=' src/binding/f77 src/binding/f90 src/binding/cxx'
bindir='${exec_prefix}/bin'
build='x86_64-unknown-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
debugger_dir=''
device_name='ch3_p4'
docdir='${datarootdir}/doc/${PACKAGE}'
dvidir='${docdir}'
exec_prefix='${prefix}'
host='x86_64-unknown-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
logging_dir=''
logging_name='none'
logging_subdirs=''
mandir='${datarootdir}/man'
master_top_builddir='/home/alibeck/Downloads/mpich2-1.4.1p1'
master_top_srcdir='/home/alibeck/Downloads/mpich2-1.4.1p1'
modincdir='${prefix}/include'
mpe_dir='mpe2'
nameserv_name='file'
oldincludedir='/usr/include'
opadir='openpa'
other_install_dirs=' src/mpl src/openpa src/pm/hydra src/mpe2'
other_pm_names=''
pac_prog=''
pdfdir='${docdir}'
pm_name='hydra'
pmi_name='simple'
prefix='/opt/mpich'
program_transform_name='s,x,x,'
psdir='${docdir}'
romio_dir='romio'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
subdirs=' test/mpi'
subsystems='  src/mpi/romio src/pmi/simple src/pm/hydra src/mpe2
src/binding/f90'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
#define PACKAGE_NAME ""
#define PACKAGE_TARNAME ""
#define PACKAGE_VERSION ""
#define PACKAGE_STRING ""
#define PACKAGE_BUGREPORT ""
#define USE_SMP_COLLECTIVES 1
#define HAVE_ERROR_CHECKING MPID_ERROR_LEVEL_ALL
#define MPICH_ERROR_MSG_LEVEL MPICH_ERROR_MSG_ALL
#define USE_LOGGING MPID_LOGGING_NONE
#define MPICH_THREAD_LEVEL MPI_THREAD_SINGLE
#define MPIU_THREAD_GRANULARITY MPIU_THREAD_GRANULARITY_SINGLE
#define MPIU_HANDLE_ALLOCATION_METHOD MPIU_HANDLE_ALLOCATION_MUTEX
#define MPIU_THREAD_REFCOUNT MPIU_REFCOUNT_NONE
#define HAVE_ROMIO 1
#define HAVE__FUNC__ /**/
#define HAVE__FUNCTION__ /**/
#define HAVE_PRAGMA_WEAK 1
#define USE_WEAK_SYMBOLS 1
#define HAVE_MULTIPLE_PRAGMA_WEAK 1
#define HAVE_LONG_LONG 1
#define STDCALL
#define F77_NAME_LOWER_USCORE 1
#define STDC_HEADERS 1
#define HAVE_MPI_F_INIT_WORKS_WITH_C 1
#define HAVE_FORTRAN_BINDING 1
#define HAVE_CXX_EXCEPTIONS /**/
#define HAVE_NAMESPACES /**/
#define HAVE_NAMESPACE_STD /**/
#define HAVE_CXX_BINDING 1
#define FILE_NAMEPUB_BASEDIR "."
#define USE_FILE_FOR_NAMEPUB 1
#define HAVE_NAMEPUB_SERVICE 1
#define restrict __restrict
#define HAVE_GCC_ATTRIBUTE 1
#define WORDS_LITTLEENDIAN 1
#define HAVE_LONG_DOUBLE 1
#define HAVE_LONG_LONG_INT 1
#define HAVE_MAX_INTEGER_ALIGNMENT 8
#define HAVE_MAX_STRUCT_ALIGNMENT 8
#define HAVE_MAX_FP_ALIGNMENT 16
#define HAVE_MAX_DOUBLE_FP_ALIGNMENT 8
#define HAVE_MAX_LONG_DOUBLE_FP_ALIGNMENT 16
#define SIZEOF_CHAR 1
#define SIZEOF_UNSIGNED_CHAR 1
#define SIZEOF_SHORT 2
#define SIZEOF_UNSIGNED_SHORT 2
#define SIZEOF_INT 4
#define SIZEOF_UNSIGNED_INT 4
#define SIZEOF_LONG 8
#define SIZEOF_UNSIGNED_LONG 8
#define SIZEOF_LONG_LONG 8
#define SIZEOF_UNSIGNED_LONG_LONG 8
#define SIZEOF_FLOAT 4
#define SIZEOF_DOUBLE 8
#define SIZEOF_LONG_DOUBLE 16
#define SIZEOF_VOID_P 8
#define HAVE_STDDEF_H 1
#define SIZEOF_WCHAR_T 4
#define SIZEOF_FLOAT_INT 8
#define SIZEOF_DOUBLE_INT 16
#define SIZEOF_LONG_INT 16
#define SIZEOF_SHORT_INT 8
#define SIZEOF_TWO_INT 8
#define SIZEOF_LONG_DOUBLE_INT 32
#define HAVE_SYS_BITYPES_H 1
#define HAVE_INTTYPES_H 1
#define HAVE_STDINT_H 1
#define HAVE_INT8_T 1
#define HAVE_INT16_T 1
#define HAVE_INT32_T 1
#define HAVE_INT64_T 1
#define HAVE_UINT8_T 1
#define HAVE_UINT16_T 1
#define HAVE_UINT32_T 1
#define HAVE_UINT64_T 1
#define HAVE_STDBOOL_H 1
#define HAVE_COMPLEX_H 1
#define SIZEOF__BOOL 1
#define SIZEOF_FLOAT__COMPLEX 8
#define SIZEOF_DOUBLE__COMPLEX 16
#define SIZEOF_LONG_DOUBLE__COMPLEX 32
#define HAVE__BOOL 1
#define HAVE_FLOAT__COMPLEX 1
#define HAVE_DOUBLE__COMPLEX 1
#define HAVE_LONG_DOUBLE__COMPLEX 1
#define MPIR_REAL4_CTYPE float
#define MPIR_REAL8_CTYPE double
#define MPIR_REAL16_CTYPE long double
#define MPIR_INTEGER1_CTYPE char
#define MPIR_INTEGER2_CTYPE short
#define MPIR_INTEGER4_CTYPE int
#define MPIR_INTEGER8_CTYPE long
#define SIZEOF_F77_INTEGER 4
#define SIZEOF_F77_REAL 4
#define SIZEOF_F77_DOUBLE_PRECISION 8
#define HAVE_AINT_LARGER_THAN_FINT 1
#define HAVE_AINT_DIFFERENT_THAN_FINT 1
#define HAVE_FINT_IS_INT 1
#define F77_TRUE_VALUE_SET 1
#define F77_TRUE_VALUE 1
#define F77_FALSE_VALUE 0
#define HAVE_STDIO_H 1
#define HAVE_C_MULTI_ATTR_ALIAS 1
#define SIZEOF_BOOL 1
#define MPIR_CXX_BOOL_CTYPE _Bool
#define SIZEOF_COMPLEX 8
#define SIZEOF_DOUBLECOMPLEX 16
#define SIZEOF_LONGDOUBLECOMPLEX 32
#define HAVE_CXX_COMPLEX 1
#define MPIR_CXX_BOOL_VALUE 0x4c000133
#define MPIR_CXX_COMPLEX_VALUE 0x4c000834
#define MPIR_CXX_DOUBLE_COMPLEX_VALUE 0x4c001035
#define MPIR_CXX_LONG_DOUBLE_COMPLEX_VALUE 0x4c002036
#define HAVE_ANY_INT64_T_ALIGNMENT 1
#define HAVE_ANY_INT32_T_ALIGNMENT 1
#define SIZEOF_MPIR_BSEND_DATA_T 88
#define HAVE_GCC_AND_X86_64_ASM 1
#define HAVE_STDLIB_H 1
#define HAVE_STDARG_H 1
#define HAVE_SYS_TYPES_H 1
#define HAVE_STRING_H 1
#define HAVE_LIMITS_H 1
#define HAVE_ERRNO_H 1
#define HAVE_SYS_SOCKET_H 1
#define HAVE_SYS_TIME_H 1
#define HAVE_UNISTD_H 1
#define HAVE_ENDIAN_H 1
#define HAVE_ASSERT_H 1
#define HAVE_SYS_PARAM_H 1
#define HAVE_SYS_UIO_H 1
#define HAVE_SETITIMER 1
#define HAVE_ALARM 1
#define HAVE_VSNPRINTF 1
#define HAVE_VSPRINTF 1
#define HAVE_STRERROR 1
#define HAVE_STRNCASECMP 1
#define HAVE_DECL_STRERROR_R 1
#define HAVE_STRERROR_R 1
#define HAVE_SNPRINTF 1
#define HAVE_QSORT 1
#define HAVE_VA_COPY 1
#define HAVE_MACRO_VA_ARGS 1
#define HAVE_ALLOCA_H 1
#define HAVE_ALLOCA 1
#define HAVE_STRDUP 1
#define HAVE_MKSTEMP 1
#define HAVE_FDOPEN 1
#define NEEDS_FDOPEN_DECL 1
#define HAVE_PUTENV 1
#define HAVE_GETTIMEOFDAY 1
#define MPIR_Pint long
#define MPIR_PINT_FMT_DEC_SPEC "%ld"
#define MPIR_Upint unsigned long
#define MPIR_UPINT_FMT_DEC_SPEC "%lu"
#define MPIU_SIZE_T unsigned long
#define MPIU_THREAD_PACKAGE_NAME MPIU_THREAD_PACKAGE_NONE
#define MPIU_TLS_SPECIFIER __thread
#define HAVE_SCHED_H 1
#define HAVE_SCHED_YIELD 1
#define HAVE_USLEEP 1
#define HAVE_SLEEP 1
#define HAVE_SELECT 1
#define HAVE_GETPID 1
#define HAVE_SCHED_SETAFFINITY 1
#define HAVE_SCHED_GETAFFINITY 1
#define HAVE_CPU_SET_T 1
#define SIZEOF_OPA_PTR_T 8
#define HAVE_FC_TYPE_ROUTINES 1
#define HAVE_MPICHCONF 1
configure: exit 0
###########################make.log######
Beginning make
Using variables CC='gcc' CFLAGS='   -O2' LDFLAGS=' ' F77='gfortran' FFLAGS='
-O2' FC='f95' FCFLAGS='  -O2' CXX='g++' CXXFLAGS='  -O2' AR='ar' CPP='gcc -E'
make all-local
make[1]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1'
make[2]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1'
make clean && cd test && make clean
make[3]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1'
make cleanlibs
make[4]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1'
rm -f lib/libmpich.a lib/libpmpich.a
rm -f lib/libmpichcxx.a
rm -f lib/libfmpich.a lib/libmpichf90.a
rm -f lib/libmpich.so*
rm -f lib/libpmpich.so*
rm -f lib/libmpichcxx.so*
rm -f lib/libfmpich.so*
rm -f lib/libmpichf90.so*
rm -f lib/libmpichf90.*.so*
rm -f lib/libmpich.*.so*
rm -f lib/libpmpich.*.so*
rm -f lib/libmpichcxx.*.so*
rm -f lib/libfmpich.*.so*
rm -f lib/libmpich.la* lib/libpmpich.la*
rm -f lib/libmpichf90.la*
rm -f lib/libmpichcxx.la*
rm -f lib/libfmpich.la*
make[4]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1'
for dir in  src/mpl src/openpa src - ; do \
		if [ "$dir" = "-" ] ; then break ; fi ; \
		(cd $dir && make clean ) ; done
make[4]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl'
 rm -f strsep
test -z "libmpl.la" || rm -f libmpl.la
rm -f "./so_locations"
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[4]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa'
Making clean in test
make[5]: Entering directory
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/test'
 rm -f sanity test_primitives test_barriers test_queue
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[5]: Leaving directory
Making clean in src
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa/src'
test -z "libopa.la" || rm -f libopa.la
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
Making clean in .
rm -rf .libs _libs
rm -f *.lo
make[5]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa'
make[4]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa'
make[4]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src'
for dir in mpl mpid mpi mpix util nameserv binding env packaging mpe2 pmi pm -
; do \
make[5]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl'
 rm -f strsep
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[5]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl'
make[5]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpid'
for dir in common ch3_p4 - ; do \
make[6]: Entering directory
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpid/common'
(cd datatype && make clean )
make[7]: Entering directory
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpid/common/datatype'
(cd dataloop && make clean )
make[8]: Entering directory
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpid/common/datatype/dataloop'
make[8]: Leaving directory
make[7]: Leaving directory
make[6]: Leaving directory
/bin/bash: line 2: cd: ch3_p4: No such file or directory
make[5]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpid'
make[5]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi'
for dir in attr coll comm datatype errhan group init misc pt2pt rma spawn
timer topo romio  - ; do \
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/attr'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/coll'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/comm'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/datatype'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/errhan'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/group'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/init'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/misc'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/pt2pt'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/rma'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/spawn'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/timer'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/topo'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/romio'
cleaning directory mpi-io
cleaning directory adio/common
cleaning directory mpi-io/glue/mpich2
cleaning directory adio/ad_testfs
cleaning directory adio/ad_ufs
cleaning directory adio/ad_nfs
cleaning directory test-internal
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/romio/test-internal'
rm -f .P* PI* *.o
rm -f file_realms_test io_bounds_test heap_test
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi/romio/test'
rm -f .P* PI* *.o
rm -f simple perf async coll_test coll_perf misc file_info excl large_array
atomicity noncontig i_noncontig noncontig_coll split_coll shared_fp large_file
psimple error status noncontig_coll2 aggregation1 aggregation2 async-multiple
ordered_fp hindexed fcoll_test fperf fmisc pfcoll_test
make[5]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpi'
make[5]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpix'
(cd comm && make clean )
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpix/comm'
make[5]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpix'
make[5]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/util'
for dir in mem info msgs instrm thread dbg param osserv procmap other  - ; do
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/util/mem'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/util/info'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/util/msgs'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/util/instrm'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/util/thread'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/util/dbg'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/util/param'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/util/osserv'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/util/procmap'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/util/other'
make[5]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/util'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/nameserv'
for dir in file - ; do \
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/nameserv/file'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/binding'
for dir in  f77 f90 cxx - ; do \
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/binding/f77'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/binding/f90'
rm -f *.mod
rm -f mpimod.pcl mpimod.pc
rm -f libmpichf90.a
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/binding/cxx'
make[5]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/env'
make clean-postamble
make[6]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/env'
make[6]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/env'
make[5]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/env'
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/packaging'
(cd pkgconfig && make clean )
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/packaging/pkgconfig'
(cd envmods && make clean )
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/packaging/envmods'
make[5]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2'
rm -f /home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2/lib/lib*
rm -f /home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2/lib/*.jar
rm -f /home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2/lib/*.o
cd src && make --no-print-directory  clean
make[5]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpe2'
make[5]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/pmi'
for dir in simple - ; do \
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/pmi/simple'
make[5]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/pmi'
make[5]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/pm'
for dir in hydra  - ; do \
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/pm/hydra'
Making clean in tools/topo/hwloc/hwloc
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc'
Making clean in include
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/include'
rm -rf .libs _libs
rm -f *.lo
Making clean in src
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/src'
test -z "" || rm -f
rm -rf .libs _libs
test -z "libhwloc_embedded.la" || rm -f libhwloc_embedded.la
rm -f *.o
rm -f *.lo
Making clean in .
rm -rf .libs _libs
rm -f *.lo
Making clean in tools/topo/plpa/plpa
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa'
Making clean in src
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src'
Making clean in plpa-taskset
make[9]: Entering directory
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/plpa-
taskset'
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[9]: Leaving directory
taskset'
Making clean in plpa-info
info'
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
info'
Making clean in libplpa
`/home/alibeck/Downloads/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/libplpa'
test -z "" || rm -f
rm -rf .libs _libs
test -z " libplpa_included.la" || rm -f  libplpa_included.la
rm -f *.o
rm -f *.lo
Making clean in .
rm -rf .libs _libs
rm -f *.lo
Making clean in .
rm -rf .libs _libs
rm -f *.lo
Making clean in ../../mpl
make[7]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl'
 rm -f strsep
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[7]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl'
Making clean in .
 rm -f hydra_persist hydra_nameserver hydra_pmi_proxy mpiexec.hydra
rm -rf .libs _libs
test -z "libhydra.la libpm.la" || rm -f libhydra.la libpm.la
rm -f *.o
rm -f *.lo
make[5]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/pm'
make[4]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src'
cd examples && make clean
make[5]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/examples'
make[5]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/examples'
make[3]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1'
make[3]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/test'
for dir in mpi mpid util basic commands ; do \
make[4]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi'
rm -f summary.xml
for dir in util attr basic datatype coll comm errhan group info init pt2pt rma
spawn topo io  f77 f90 cxx  errors manual perf - ; do \
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/util'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/attr'
rm -f summary.xml
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/basic'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/datatype'
rm -f summary.xml
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/coll'
rm -f summary.xml
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/comm'
rm -f summary.xml
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errhan'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/group'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/info'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/init'
rm -f summary.xml
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/pt2pt'
rm -f summary.xml
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/rma'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/spawn'
rm -f summary.xml
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/topo'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/io'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77'
for dir in util attr datatype coll pt2pt info init comm topo rma spawn io ext
; do \
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77/util'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77/attr'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77/datatype'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77/coll'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77/pt2pt'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77/info'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77/init'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77/comm'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77/topo'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77/rma'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77/spawn'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77/io'
rm -f .iotest.txt.*
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f77/ext'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90'
for dir in util timer attr coll datatype pt2pt info comm rma spawn topo io ext
init misc f90types ; do \
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/util'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/timer'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/attr'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/coll'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/datatype'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/pt2pt'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/info'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/comm'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/rma'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/spawn'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/topo'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/io'
rm -f .iotest.txt.*
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/ext'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/init'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/misc'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/f90/f90types'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/cxx'
for dir in util attr pt2pt init info comm coll datatype errhan io rma spawn ;
do \
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/cxx/util'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/cxx/attr'
rm -f summary.xml
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/cxx/pt2pt'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/cxx/init'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/cxx/info'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/cxx/comm'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/cxx/coll'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/cxx/datatype'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/cxx/errhan'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/cxx/io'
rm -f .iotest.txt.*
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/cxx/rma'
rm -f summary.xml
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/cxx/spawn'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors'
for dir in attr coll comm group pt2pt rma spawn topo io  f77 f90 cxx basic
faults - ; do \
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/attr'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/coll'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/comm'
rm -f summary.xml
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/group'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/pt2pt'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/rma'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/spawn'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/topo'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/io'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/f77'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/f90'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/cxx'
(cd io && make clean )
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/cxx/io'
rm -f summary.xml
(cd errhan && make clean )
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/cxx/errhan'
rm -f summary.xml
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/basic'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/errors/faults'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/manual'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi/perf'
rm -f summary.xml
make[4]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpi'
make[4]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpid'
(cd ch3 && make clean )
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpid/ch3'
make[4]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/test/mpid'
make[4]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/test/util'
(cd timer && make clean )
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/util/timer'
make[4]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/test/util'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/basic'
make[4]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/test/basic'
`/home/alibeck/Downloads/mpich2-1.4.1p1/test/commands'
rm -f err.txt out.log out.txt stdintest stdintest2 sdtiotest a.out
make[3]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/test'
rm -f lib/newconfig
make[2]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1'
make[1]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1'
make[1]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl'
  CC     mplstr.lo
  CC     mpltrmem.lo
  CC     mplenv.lo
  CCLD   libmpl.la
make[1]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl'
Making all in src
make  all-am
/bin/bash ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.      -
MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o
opa_primitives.lo opa_primitives.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -MT opa_primitives.lo -MD -MP -MF
.deps/opa_primitives.Tpo -c opa_primitives.c -o opa_primitives.o
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -MT opa_queue.lo -MD -MP -MF
.deps/opa_queue.Tpo -c opa_queue.c -o opa_queue.o
mv -f .deps/opa_queue.Tpo .deps/opa_queue.Plo
/bin/bash ../libtool --tag=CC   --mode=link gcc   -version-info 1:0  -o
libopa.la -rpath /opt/mpich/lib opa_primitives.lo opa_queue.lo  -lpthread
libtool: link: ar cru .libs/libopa.a  opa_primitives.o opa_queue.o
libtool: link: ranlib .libs/libopa.a
libtool: link: ( cd ".libs" && rm -f "libopa.la" && ln -s "../libopa.la"
"libopa.la" )
Making all in test
make[2]: Nothing to be done for `all'.
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa'
make[1]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/openpa'
make[1]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src'
make[2]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl'
make[2]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpl'
make[2]: Entering directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpid'
  CC              dataloop.c
In file included from ./../mpid_dataloop.h:115:0,
                 from ./dataloop.h:16,
                 from dataloop.c:12:
/home/alibeck/Downloads/mpich2-1.4.1p1/src/include/mpiimpl.h:123:21: fatal
error: mpidpre.h: No such file or directory
compilation terminated.
make[5]: *** [dataloop.o] Error 1
make[4]: *** [all-redirect] Error 2
make[3]: *** [all-redirect] Error 2
make[2]: *** [all-redirect] Error 2
make[2]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src/mpid'
make[1]: *** [all-redirect] Error 2
make[1]: Leaving directory `/home/alibeck/Downloads/mpich2-1.4.1p1/src'
make: *** [all-redirect] Error 2
