[mpich-discuss] mpich2 hangs on Ubuntu beowulf cluster(with	NFS) update
    Darius Buntinas
    buntinas at mcs.anl.gov
    Mon Jan  9 15:28:38 CST 2012
Here's a patch that should fix the internal error so mpich2 can report a valid error message.  If you built mpich2 from source, apply this patch, and rebuild and reinstall it, then relink your application with the new library and try it again.
Let me know how this works.
-d
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120109/eb1ef112/attachment.obj>
On Jan 6, 2012, at 6:26 PM, Konstantinos Varotsos wrote:
> Hi
> the version I am using is mpich2-1.4.1p1 and the output with -l flag
> [8] Internal Error: invalid error code 209e0e (Ring ids do not match) in MPIR_Bcast_intra:1119
> [8] Fatal error in PMPI_Bcast: Other MPI error, error stack:
> [8] PMPI_Bcast(1478)......: MPI_Bcast(buf=0xa913cf8, count=1, MPI_CHAR, root=0, comm=0x84000004) failed
> [8] MPIR_Bcast_impl(1321).:
> [8] MPIR_Bcast_intra(1119):
> [0] Fatal error in PMPI_Barrier: Other MPI error, error stack:
> [0] PMPI_Barrier(425)...........: MPI_Barrier(comm=0x84000004) failed
> [0] MPIR_Barrier_impl(306)......:
> [0] MPIR_Bcast_impl(1321).......:
> [0] MPIR_Bcast_intra(1155)......:
> [0] MPIR_Bcast_binomial(213)....: Failure during collective
> [0] MPIR_Barrier_impl(292)......:
> [0] MPIR_Barrier_or_coll_fn(121):
> [0] MPIR_Barrier_intra(83)......:
> [0] dequeue_and_set_error(596)..: Communication error with rank 8
> thanx Kwstas
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
