[mpich-discuss] mpich2 hangs on Ubuntu beowulf cluster(with NFS)	update
    Konstantinos Varotsos
    kvarotso at gmail.com
    Fri Jan  6 05:53:47 CST 2012
Hi there,
I talked to the person that used the code before and
she told me that the code worked on a grid here in Greece with no problems
  So I searched for other reasons. Because the code is pre-compiled
in another machine (ia32, due to fortran licence issues ) the libaries
used were mpich-1.2p1
so I installed there the latest stable version.
Now when I run the exe I receive an error
  Internal Error: invalid error code 209e0e (Ring ids do not match) in
MPIR_Bcast_intra:1119
Fatal error in PMPI_Bcast: Other MPI error, error stack:
PMPI_Bcast(1478)......: MPI_Bcast(buf=0xa0e2cf8, count=1, MPI_CHAR,
root=0, comm=0x84000004) failed
MPIR_Bcast_impl(1321).:
MPIR_Bcast_intra(1119):
Fatal error in PMPI_Barrier: Other MPI error, error stack:
PMPI_Barrier(425)...........: MPI_Barrier(comm=0x84000004) failed
MPIR_Barrier_impl(306)......:
MPIR_Bcast_impl(1321).......:
MPIR_Bcast_intra(1155)......:
MPIR_Bcast_binomial(213)....: Failure during collective
MPIR_Barrier_impl(292)......:
MPIR_Barrier_or_coll_fn(121):
MPIR_Barrier_intra(83)......:
dequeue_and_set_error(596)..: Communication error with rank 8
I did a make testing and all test passed except to this
<NAME>bcastlength</NAME>^M
<NP>4</NP>^M
<WORKDIR>./errors/coll</WORKDIR>^M
<STATUS>fail</STATUS>^M
<TESTDIFF>^M
Did not detect mismatched length (long) on process 3
Did not detect mismatched length (short) on process 3
  Found 2 errors
I dont know how to translate these two errors.
I dont know if this is relevant but some suggest to deactivate
hypertherading
Do you have any suggestions?
Thanx
Kwstas
