[mpich-discuss] mpich2 hangs on Ubuntu beowulf cluster(with NFS)
Gustavo Correa
gus at ldeo.columbia.edu
Wed Jan 4 15:34:51 CST 2012
Hi Konstantinos
Since you can run cpi and hello across the network,
the problem may not be in your cluster setup, but in your code.
There is a chance that your code deadlocks.
This may or may not happen depending on the number of processors, use of network, etc.
If you post the code, or a simplified version of it, it may help.
I hope this helps,
Gus Correa
On Jan 4, 2012, at 4:19 PM, Konstantinos Varotsos wrote:
> Hi
> I am trying to run a Fortran exe on two four quad machines les0 and les1.
> The machines are set up with ubuntu 11.04 and NFS
> I have installed the latest stable mpich2 with gfortran and gcc.
> The problem is that when I try to run the code on both machines
> the run hangs without any error.
> The exe runs fine on each machine separately and produces output.
> Also cpi example runs fine.
> mpiexec -f machinefile -n 8 ./cpi
> Process 4 of 8 is on les1
> Process 5 of 8 is on les1
> Process 7 of 8 is on les1
> Process 6 of 8 is on les1
> Process 0 of 8 is on les0
> Process 1 of 8 is on les0
> Process 2 of 8 is on les0
> Process 3 of 8 is on les0
> pi is approximately 3.1415926544231247, Error is 0.0000000008333316
> wall clock time = 0.002584
> hello.f runs fine too
> mpiexec -f machinefile -n 8 ./hellow_exe
> Process 0 of 8 is alive
> Process 1 of 8 is alive
> Process 2 of 8 is alive
> Process 3 of 8 is alive
> Process 5 of 8 is alive
> Process 7 of 8 is alive
> Process 4 of 8 is alive
> Process 6 of 8 is alive
> machinefile
> les1:4
> les0:4
> The command i use
> mpiexec -f machinefile -n 8 ./test.x_RESTART > output/les_$time.output &
> I looked through the mpich forum and I found a post
> with similar tiltle to mine but with hubrid code
> This is not the case. The code is mpi
> I am stuck! Any help will be appreaciated
> Thanx, Kwstas
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
