[mpich-discuss] Run MPICH2 on Window 7
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue Feb 28 16:45:15 CST 2012
 Try turning off the firewalls on both the machines.
-Jayesh
----- Original Message -----
Cc: mpich-discuss-bounces at mcs.anl.gov
Sent: Tuesday, February 28, 2012 4:33:55 PM
Subject: Re: [mpich-discuss] Run MPICH2 on Window 7
Yes.
Chin-Jung Chen
Engineering Analysis Group
North American Lighting, Inc.
248-522-2125
Cc:	Chin-Jung_Chen at nal.com
Date:	02/28/2012 04:39 PM
Sent by:	mpich-discuss-bounces at mcs.anl.gov
 Do you have MPICH2 installed on NAL198.MIS.NALCAD.COM ?
Jayesh
Sent: Tuesday, February 28, 2012 3:13:39 PM
Subject: [mpich-discuss] Run MPICH2 on Window 7
Our IT has installed the MPICH2 on the Window 7 OS PC workstation (64 bit).
However, he experience the following error messages when he tried to run
the "mpiexec" command after the installation.  Will you be able to help for
the issue?  Thanks.
_________________________________________________________________________________________
C:\Windows\system32>mpiexec -hosts 2 NAL198.MIS.NALCAD.COM
NAL198.MIS.NALCAD.COM hostname
Error while connecting to host, No connection could be made because the
target machine actively refused it. (10061)
Connect on sock (host=NAL198.MIS.NALCAD.COM, port=8676) failed, exhaused
all end points
Unable to connect to 'NAL198.MIS.NALCAD.COM:8676',
sock error: Error = -1
Chin-Jung Chen
248-522-2125
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
