[mpich-discuss] Run MPICH2 on Window 7
Chin-Jung_Chen at nal.com
Tue Feb 28 15:13:39 CST 2012
Our IT has installed the MPICH2 on the Window 7 OS PC workstation (64 bit).
However, he experience the following error messages when he tried to run
the "mpiexec" command after the installation. Will you be able to help for
the issue? Thanks.
_________________________________________________________________________________________
C:\Windows\system32>mpiexec -hosts 2 NAL198.MIS.NALCAD.COM
NAL198.MIS.NALCAD.COM hostname
Error while connecting to host, No connection could be made because the
target machine actively refused it. (10061)
Connect on sock (host=NAL198.MIS.NALCAD.COM, port=8676) failed, exhaused
all end points
Unable to connect to 'NAL198.MIS.NALCAD.COM:8676',
sock error: Error = -1
Chin-Jung Chen
Engineering Analysis Group
North American Lighting, Inc.
248-522-2125
