[mpich-discuss] Working with TotalView & mpiexec.hydra
Anatoly G
anatolyrishon at gmail.com
Tue Feb 28 08:51:07 CST 2012
Dear MPICH2.
I want to debug my MPI program. (files attached).
*Execution line without TotalView is (works fine):*
/space/local/bin/mpiexec.hydra -genvall -disable-auto-cleanup -f
MpiConfigMachines.txt -n 1 -launcher=rsh mpi_rcv_waitany 100 1000000 90
1000 1 logs/res1_ : -n 1 mpi_rcv_waitany 100 1000000 90 1000 1 logs/res2_ :
-n 1 mpi_rcv_waitany 100 1000000 90 1000 1 logs/res3_
*Execution line withTotalView is (fails):*
MpiConfigMachines.txt -n 1 -launcher=rsh tv mpi_rcv_waitany -a 100 1000000
90 1000 1 logs/res1_ : -n 1 mpi_rcv_waitany 100 1000000 90 1000 1
logs/res2_ : -n 1 mpi_rcv_waitany 100 1000000 90 1000 1 logs/res3_
TotalView is executed. Shows text of program. I start debugging using
"Next" commands until I arrive to line:
MPI::Init(argc, argv);
Executing this line cause failure of program, but totalview is still up.
*In shell I see an error*:
[cli_0]: write_line error; fd=6 buf=:cmd=init pmi_version=1 pmi_subversion=1
system msg for write_line failure : Bad file descriptor
[cli_0]: Unable to write to PMI_fd
[cli_0]: write_line error; fd=6 buf=:cmd=get_appnum
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(411):
MPID_Init(138).......: channel initialization failed
MPID_Init(423).......: PMI_Get_appnum returned -1
Can you please help me with this problem.
Anatoly.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120228/f49abfff/attachment.htm>
boogie:100
Type: text/x-chdr
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120228/f49abfff/attachment.h>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120228/f49abfff/attachment.cpp>
