[mpich-discuss] Compiled applications working standalone,	but not using mpiexec
    Hugh Cassidy
    hcassid2 at uwo.ca
    Sun Feb 26 16:41:48 CST 2012
Hello,
I have MPICH2 32 installed on Windows 7. The cpi.exe example works fine
when I run, for example, the command:
mpiexec -n 4 cpi.exe
I have been able to compile, using gfortran, the fpi.f example.
Furthermore, I can run the generate application in a standalone fashion:
fpi.exe
However, when I attempt to use mpiexec, it doesn't work:
mpiexec -n 4 fpi.exe
Doesn't seem to do anything - I'm just returned immediately to the
command prompt with no output displayed. Does anyone know why this may
be happening? I'm experiencing the same problem trying to run another
application that makes use of mpi - it runs standalone, but not using
the mpiexec command. I'm guessing this means there is some problem with
the compilation step?
Thanks!
