[mpich-discuss] Howto use MPI_Comm_merge together with	MPI_Comm_spawn
    Umit
    umitcanyilmaz at gmail.com
    Thu Feb 16 07:06:49 CST 2012
Hello All,
Can anyone tell me what is wrong with this simple code:
#define NUM_SPAWNS 4
double timer;
int i;
char str[100];
int main( int argc, char *argv[] )
    MPI_Comm parentcomm, intercomm;
    MPI_Comm comm, scomm;
    MPI_Init( &argc, &argv );
    MPI_Comm_get_parent( &parentcomm );
    int np = NUM_SPAWNS;
    int size;
    MPI_Comm_size( MPI_COMM_WORLD , &size );
    if (parentcomm == MPI_COMM_NULL)
       scomm = MPI_COMM_WORLD;
       int errcodes[np];
       MPI_Comm_spawn( "/home/test/Desktop/merge/./a.out", MPI_ARGV_NULL,
np, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &intercomm, errcodes );
       MPI_Intercomm_merge( intercomm, 1, &comm );
    else
        printf("I'm the spawned.\n");
    MPI_Finalize();
    return 0;
I called MPI_Intercomm_merge outside of if statement but I got the same
error.
Spawn is successfull. I have especially tested it. If I try to merge, i got
the following error:
test at ubuntu:~/Desktop/merge$ mpirun -np 1 ./a.out
I'm the spawned.
I'm the spawned.
I'm the spawned.
I'm the spawned.
Fatal error in MPI_Intercomm_merge: Other MPI error, error stack:
MPI_Intercomm_merge(288)..........: MPI_Intercomm_merge(comm=0x84000000,
high=1, newintracomm=0xbf97ff40) failed
MPI_Intercomm_merge(263)..........:
MPIR_Get_contextid(639)...........:
MPI_Allreduce(773)................: MPI_Allreduce(sbuf=MPI_IN_PLACE,
rbuf=0xbf97fd18, count=64, MPI_INT, MPI_BAND, comm=0x84000002) failed
MPIR_Allreduce(289)...............:
MPIC_Sendrecv(161)................:
MPIC_Wait(513)....................:
MPIDI_CH3I_Progress(150)..........:
MPID_nem_mpich2_blocking_recv(948):
MPID_nem_tcp_connpoll(1720).......:
state_commrdy_handler(1556).......:
MPID_nem_tcp_recv_handler(1446)...: socket closed
rank 0 in job 21  ubuntu_38267   caused collective abort of all ranks
  exit status of rank 0: killed by signal 9
Thanks In Advance,
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120216/de36f0fe/attachment.htm>
