[mpich-discuss] problem running smpd on a windows machine
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed Feb 15 10:21:12 CST 2012
 This looks like an installation problem. Please uninstall your existing version and follow steps in section 9.4 of the installer's guide (http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs) to install MPICH2.
Jayesh
----- Original Message -----
To: jayesh at mcs.anl.gov
Sent: Tuesday, February 14, 2012 5:41:23 PM
Subject: Re: [mpich-discuss] problem running smpd on a windows machine
Jayesh,
On another computer, I have the symptom that when I go to launch the program, it asks me for an authentication passphrase for spmd. When I enter the passphrase "behappy" that comes as part of the installation, it says "Unknown option: -d" then it asks again for the passphrase. When I re-enter it, it times out and says "Error while connecting to host. No connection could be made because the target machine actively refused it. (10061) Connect on sock (host ="Ultrafast, port=8676" failed. Exhausted all endpoints.
Unable to connect to "Ultrafast:8676",
sock error. Error = -1"
Perhaps you could point me to some document that would explain what all that means?
thanks,
Don
D. K. Steinman
Phone: 281.835.6364
FAX: 281.835.3806
Cell: 281.414.3074
In a message dated 2/14/2012 4:30:06 P.M. Central Standard Time, jayesh at mcs.anl.gov writes:
Can you try changing the mpiexec line from
c:\"Program Files (x86)"\MPICH2\bin\mpiexec.exe -n 12 -localonly "c:\MCPNX_2.7.0\bin\mcnpx.exe inp = Lito519 outp = Lito519o"
to
c:\Progra~1\MPICH2\bin\mpiexec.exe -n 12 -localonly "c:\MCPNX_2.7.0\bin\mcnpx.exe inp=C:\MCNP\mcnp_data\Lito519 outp=C:\MCNP\mcnp_data\Lito519o"
Jayesh
Sent: Tuesday, February 14, 2012 4:07:59 PM
Jayesh,
here is a file with the same contents as the batch file I use to run MCNPX. The executable line is on line 8. As you can see, the path to all executables is on that line. In addition, the path to MCNPX is set as an environmental variable. The machine has 12 cores, and the batch file is in the directory that has the input file. There is a different message when MCNPX cannot find an input file, this error says:
Launch process failed. The system cannot find the file specified
I thank you for your assistance with this, it is truly exasperating!
regards,
Don
D. K. Steinman
Phone: 281.835.6364
FAX: 281.835.3806
Cell: 281.414.3074
In a message dated 2/14/2012 3:57:25 P.M. Central Standard Time, jayesh at mcs.anl.gov writes:
It looks like mpiexec is not able to find the MCNPX executable.
Can you run a small job on the local node ?
Please let us know the mpiexec command (copy-paste the command and its output) that you use to launch your job ? Where is the MCNPX executable located (Is it available on all nodes. Is it on a shared directory)?
Jayesh
Sent: Tuesday, February 14, 2012 3:36:05 PM
OK, I tried that, Jayesh. Now when I use the MCNPX batch file, it says "failed to launch process, system cannot find the file error 2" However, the command line specifies the directory with the executable in it.
any other hints? Would you like to see the MCNPX batch file?
D. K. Steinman
Phone: 281.835.6364
FAX: 281.835.3806
Cell: 281.414.3074
In a message dated 2/14/2012 3:12:43 P.M. Central Standard Time, jayesh at mcs.anl.gov writes:
Can you try re-installing (uninstall MPICH2, and then install it again following instructions in Sec 9.4) following instructions in Section 9.4 (NOT 9.1) of the installer's guide (http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs)?
Jayesh
Sent: Tuesday, February 14, 2012 1:48:23 PM
Hi, Jayesh,
thanks for the quick response. I'm trying everything I can in order to run MCNPX in the MPI version. Whenever I try to launch MPI I constantly get denied access. I have a 12 core processor, and it fails to launch 12 times, each with an error message about not having access.
Would you be amenable to looking at my batch file?
Don
D. K. Steinman
Phone: 281.835.6364
FAX: 281.835.3806
Cell: 281.414.3074
In a message dated 2/14/2012 1:45:52 P.M. Central Standard Time, jayesh at mcs.anl.gov writes:
Why are you manually installing SMPD (smpd -install)? SMPD should have been installed as part of the MPICH2 installation.
Jayesh
Sent: Tuesday, February 14, 2012 1:41:14 PM
Subject: [mpich-discuss] problem running smpd on a windows machine
I'm trying to get MPICH2 to run on my windows machines. I have downloaded and installed both the 32 bit and 64 bit versions. However, when I try to run smpd -install, I get the message that
OpenSCManager failed:
Access is denied. (error 5)
Unable to remove the previous installation, install failed.
I've never had a previous installation.
What am I doing wrong?
thanks,
Don Steinman
Applied Physics and Measurements, Inc.
Missouri City, TX
D. K. Steinman
Phone: 281.835.6364
FAX: 281.835.3806
Cell: 281.414.3074
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
