[mpich-discuss] MPI-IO issue
    Wei-keng Liao
    wkliao at ece.northwestern.edu
    Fri Feb 10 17:07:17 CST 2012
Matt,
Based on the way you use the new derived datatype in MPI_FILE_SET_VIEW,
the lowerbound and extent should be 0 and ie*je*ke*8, respectively.
8 byte is the bytes for real*8 type. Can you verify those values?
Wei-keng
On Feb 10, 2012, at 4:25 PM, Grismer, Matthew J Civ USAF AFMC AFRL/RBAT wrote:
> Thanks for the info, I was not aware of the extent of the derived type.  I
> used MPI_Type_create_resized to change the lower bound and extent of the
> derived types on each processor to cover the entire array, not just the
> sub-blocks I wanted.  Now x reads correctly on each processor, but then y
> and z are still wrong.  After the MPI_File_read_all command for x, I used
> the MPI_File_get_position command to see where each processors file pointer
> was.  Only on processor 0 has the file pointer moved to the correct location
> in the file, on all the other processors it is different and far short of
> the correct location.  I'm defining the derived types and extents the same
> way on all the processors, and even check the extents after I set them to
> verify they are correct.  Any other thoughts on what I am missing?  Thanks.
> Matt
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Wei-keng Liao
> Sent: Wednesday, February 08, 2012 7:33 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] MPI-IO issue
> Hi,
> I am guessing the problem is the datatype you created.
> Please check the type extent to see if it equals to the
> size of entire array, using MPI_Type_extent(). If not,
> the file pointer after the first read will not move to
> the beginning of the second array you expected, which
> leads to reading data from a wrong file location.
> Also, if each process reads a block subarray, I suggest
> to use MPI_Type_create_subarray to create the new datatype.
> Wei-keng
> On Feb 8, 2012, at 3:46 PM, Grismer, Matthew J Civ USAF AFMC AFRL/RBAT
> wrote:
>> I am attempting to use MPI-IO to read block, structured data from a
>> file.  Three three-dimensional coordinate arrays are stored in the file,
>> one after another with Fortran ordering and in binary (not Fortran
>> unformatted):
>> header info
>> (((x(i,j,k),i=1,ie),j=1,je),k=1,ke)
>> (((y(i,j,k),i=1,ie),j=1,je),k=1,ke)
>> (((z(i,j,k),i=1,ie),j=1,je),k=1,ke)
>> Each processor reads a block subset of the arrays, and I've defined a
>> derived type using MPI_TYPE_INDEXED for the blocks that go to each
>> processor.  MPI_TYPE_INDEXED takes as arguments the number of blocks,
>> block size, and block displacement;  I created (and committed) the
>> datatype with the number of blocks/displacements 3 times (i.e.
>> subsetie*subsetje*subsetke*3) what I need for one variable above on a
>> given processor.  Then I used the following to read the file across the
>> processors:
>> count = subsetie*subsetje*subsetke
>> call MPI_FILE_SET_VIEW ( fh, skipheader, mpi_real8, newdatatype,
>> "native", mpi_info_null, ierror )
>> call MPI_FILE_READ_ALL ( fh, x, count, mpi_real8, ierror )
>> call MPI_FILE_READ_ALL ( fh, y, count, mpi_real8, ierror )
>> call MPI_FILE_READ_ALL ( fh, z, count, mpi_real8, ierror )
>> The result from this is x is read correctly, y and z are not.  However,
>> if I define one variable xyz(subsetie,subsetje,subsetke,3) and read all
>> the data in one call:
>> count = subsetie*subsetje*subsetke*3
>> call MPI_FILE_READ_ALL ( fh, xyz, count, mpi_real8, ierror )
>> everything is read correctly, which also verifies my derived type is
>> correct.  Alternatively I can reset the view (with correct
>> displacements) after each READ_ALL and read into the individual
>> variables.
>> Is this the expected behavior?  If so I do not understand how to make
>> successive collective reads from a file without resetting the view
>> before every read, which will take a toll on performance when I continue
>> to read many additional variables from the file.
>> Matt
>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
