[mpich-discuss] Problems Running WRF on Ubuntu 11.10, MPICH2
    Sukanta Basu
    sukanta.basu at gmail.com
    Wed Feb  8 21:33:50 CST 2012
Hi Gus,
I tried setting the stack option in limits.conf. No change. I logged
on to each nodes and checked that the ulimit is indeed unlimited.
I just installed openmpi and recompiled WRF. It now runs with any
array sizes. However, I have a different problem. Now, one of the
processes quits suddenly during the run (with a segmentation fault
error). I think both the mpich2 and openmpi problems are somewhat
related.
Best regards,
Sukanta
On Wed, Feb 8, 2012 at 6:20 PM, Gustavo Correa <gus at ldeo.columbia.edu> wrote:
> Hi Sukanta
> Did you set the stacksize [not only memlock] to unlimited in
> /etc/security/limits.conf on all nodes?
> Not sure this will work, but you could try to run 'ulimit -s'  and 'ulimit -l' via mpiexec, just to check:
> mpiexec -prepend-rank -f hostfile -np 32 ulimit -s
> mpiexec -prepend-rank -f hostfile -np 32 ulimit -l
> Or just login to each node and check.
> Also, if your WRF is compiled with OpenMP,
> I think the Intel-specific environment variable for OMP_STACKSIZE is
> KMP_STACKSIZE [not MP_STACKSIZE], although they should also accept
> the portable/standard OMP_STACKSIZE [but I don't know if they do].
> For some models here I had to make is as big as 512m [I don't run wrf, though].
> 'man ifort' should tell more about it [at the end of the man page].
> I hope this helps,
> Gus Correa
> On Feb 8, 2012, at 4:23 PM, Anthony Chan wrote:
>> There is fpi, Fortran counterpart of cpi, you can try that.
>> Also, there is MPICH2 testsuite which is located in
>> mpich2-xxx/test/mpi can be invoked by "make testing".
>> It is unlikely those tests will reveal anything.
>> The testsuite is meant to test the MPI implementation
>> not your app.
>> As what you said earlier, your difficulty in running WRF
>> with larger dataset is memory related.  You should contact WRF
>> emailing list for more pointers.
>> ----- Original Message -----
>>> Hi Anthony,
>>> Is there any other mpi example code (other than cpi.c) that I could
>>> test which will give me more information about my mpich setup?
>>> Here is the output from cpi (using 32 cores on 4 nodes):
>>> mpiuser at crayN1-5150jo:~/Misc$ mpiexec -f mpd.hosts -n 32 ./cpi
>>> Process 1 on crayN1-5150jo
>>> Process 18 on crayN2-5150jo
>>> Process 2 on crayN2-5150jo
>>> Process 26 on crayN2-5150jo
>>> Process 5 on crayN1-5150jo
>>> Process 14 on crayN2-5150jo
>>> Process 21 on crayN1-5150jo
>>> Process 22 on crayN2-5150jo
>>> Process 25 on crayN1-5150jo
>>> Process 6 on crayN2-5150jo
>>> Process 9 on crayN1-5150jo
>>> Process 17 on crayN1-5150jo
>>> Process 30 on crayN2-5150jo
>>> Process 10 on crayN2-5150jo
>>> Process 29 on crayN1-5150jo
>>> Process 13 on crayN1-5150jo
>>> Process 8 on crayN3-5150jo
>>> Process 20 on crayN3-5150jo
>>> Process 4 on crayN3-5150jo
>>> Process 12 on crayN3-5150jo
>>> Process 0 on crayN3-5150jo
>>> Process 24 on crayN3-5150jo
>>> Process 16 on crayN3-5150jo
>>> Process 28 on crayN3-5150jo
>>> Process 3 on crayN4-5150jo
>>> Process 7 on crayN4-5150jo
>>> Process 11 on crayN4-5150jo
>>> Process 23 on crayN4-5150jo
>>> Process 27 on crayN4-5150jo
>>> Process 31 on crayN4-5150jo
>>> Process 19 on crayN4-5150jo
>>> Process 15 on crayN4-5150jo
>>> pi is approximately 3.1416009869231249, Error is 0.0000083333333318
>>> wall clock time = 0.009401
>>> Best regards,
>>> Sukanta
>>> On Wed, Feb 8, 2012 at 1:19 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
>>>> Hmm.. Not sure what is happening.. I don't see anything
>>>> obviously wrong in your mpiexec verbose output (though
>>>> I am not hydra expert). Your code now is killed because of
>>>> segmentation fault. Naively, I would recompile WRF with -g
>>>> and use a debugger to see where segfault is. If you don't want
>>>> to mess around WRF source code, you may want to contact WRF
>>>> developers to see if they have encountered similar problem
>>>> before.
>>>>> Dear Anthony,
>>>>> Thanks for your response. Yes, I did try MP_STACK_SIZE and
>>>>> OMP_STACKSIZE. The error is still there. I have attached a log file
>>>>> (I
>>>>> ran mpiexec with -verbose option). May be this will help.
>>>>> Best regards,
>>>>> Sukanta
>>>>> On Tue, Feb 7, 2012 at 3:28 PM, Anthony Chan <chan at mcs.anl.gov>
>>>>> wrote:
>>>>>> I am not familar with WRF, and not sure if WRF uses any thread
>>>>>> in dmpar mode. Did you try setting MP_STACK_SIZE or OMP_STACKSIZE
>>>>>> see: http://forum.wrfforum.com/viewtopic.php?f=6&t=255
>>>>>> A.Chan
>>>>>>> Hi,
>>>>>>> I am using a small cluster of 4 nodes (each with 8 cores + 24 GB
>>>>>>> RAM).
>>>>>>> OS: Ubuntu 11.10. The cluster uses nfs file system and gigE
>>>>>>> connections.
>>>>>>> I installed mpich2 and ran cpi.c program successfully.
>>>>>>> I installed WRF (http://www.wrf-model.org/index.php) using the
>>>>>>> intel
>>>>>>> compilers (dmpar option)
>>>>>>> I set ulimit -l and -s to be unlimited in .bashrc (all nodes)
>>>>>>> I set memlock to be unlimited in limits.conf (all nodes)
>>>>>>> I have password-less ssh (public key sharing) on all the nodes
>>>>>>> I ran parallel jobs with 40x40x40, 40x40x50, and 40x40x60 grid
>>>>>>> points
>>>>>>> successfully. However, when I utilize 40x40x80 grid points, I
>>>>>>> get
>>>>>>> the
>>>>>>> following MPI error:
>>>>>>> Fatal error in PMPI_Wait: Other MPI error, error stack:
>>>>>>> PMPI_Wait(183)............: MPI_Wait(request=0x34e83a4,
>>>>>>> status=0x7fff7b24c400) failed
>>>>>>> MPIR_Wait_impl(77)........:
>>>>>>> dequeue_and_set_error(596): Communication error with rank 8
>>>>>>> Given that I can run the exact simulation with slightly lesser
>>>>>>> number
>>>>>>> of grid points without any problem, this error is related to
>>>>>>> stack
>>>>>>> size. What could be the problem?
>>>>>>> Thanks,
>>>>>>> Sukanta
>>>>>>> Sukanta Basu
>>>>>>> Associate Professor
>>>>>>> North Carolina State University
>>>>>>> http://www4.ncsu.edu/~sbasu5/
>>>>>>> _______________________________________________
>>>>>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>>>>>> To manage subscription options or unsubscribe:
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>>> Sukanta Basu
>>>>> Associate Professor
>>> Sukanta Basu
>>> Associate Professor
Sukanta Basu
Associate Professor
