[mpich-discuss] Executing mutithreaded code on multiple	machines fails under Windows vista/smpd
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed Feb  8 11:25:40 CST 2012
 Take a look at Section 9.5 of the Windows developer's guide (http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs) for more information.
Jayesh
----- Original Message -----
To: mpich2-maint at mcs.anl.gov
Sent: Monday, February 6, 2012 4:40:44 AM
Subject: Re: [mpich2-maint] #1573: Executing mutithreaded code on multiple	machines fails under Windows vista/smpd
Thanks for reply. as you suggested, I turned off the firewalls on the two machines and can make my code run correctly.
Is there any means to make smpd work without turning off the firewalls? (fine tuning of the MS firewall parameters, for instance).
Thanks again,
Jean-Marc Adamo
mpich2-maint mailing list
mpich2-maint at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/mpich2-maint
