[mpich-discuss] error in mpiexec
    Jed Brown
    jedbrown at mcs.anl.gov
    Thu Feb  2 22:08:38 CST 2012
On Thu, Feb 2, 2012 at 21:30, Jeff Hammond <jhammond at alcf.anl.gov> wrote:
> (This question belongs on mpich-discuss at mcs.anl.gov)
> It seems that you are using mpiexec from OpenMPI with a binary compiled
> with MPICH2.  This is not a good idea.
> Please use the mpiexec from MPICH2.  If you do not know where it is, try
> 'find /home/mpich2-1.4.1p1/ -name mpiexec'.
> You can see what mpiexec you are using by calling 'which mpiexec'.
This problem is way too common. Why doesn't mpiexec put some token in the
environment that MPI_Init() can check and error if it doesn't match
(including version, if necessary)? Same with Open MPI. The error message
could even helpfully point out the location of the correct mpiexec.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120203/590372a5/attachment.htm>
