[mpich-discuss] Fwd: Error MPICH
Gus Correa
gus at ldeo.columbia.edu
Thu Aug 30 16:36:47 CDT 2012
Hi Jairo
Ricardo is right, there are many possible causes.
You need to send more information, otherwise it is hard to guess what is
going on.
Here are a few questions. Your answers may help.
1) Are you using MPICH in Linux or Windows?
2) What is your mpirun/mpiexec command line?
3) Do you use a 'machinefile'? What is the content of your machinefile?
4) Does your 'programa' [I guess this is your executable] live in the
Network File System [NFS]?
5) Does your home directory live also in the NFS?
6) Is your MPICH also installed in your NFS?
Or do you have a separate copy of MPICH installed on each cluster node?
7) What happens if you login to each of your cluster nodes: can you see
'programa' there
in the expected directory [say, using the 'ls' command]?
If your cluster has only two nodes, Master, and Slave, testing this is
really quick.
If you send the output of 'ls programa' on each node, this may help.
8) What happens if you use the full path name to 'programa' in your
Say, something like this:
mpiexec -f hostfile -np 2 /full/path/to/programa
where 'hostfile' has this content:
Master:1
Slave:1
I hope this helps,
Gus Correa
On 08/30/2012 03:30 PM, Ricardo Román Brenes wrote:
> well there's al ot of problems that could be causing this...
> are you sure the file exists? is it executable?
> is it in the same directory path in all the nodes?
> how are you running it?
> mpich in win or linux?
> On Thu, Aug 30, 2012 at 1:27 PM, JAIRO ALMEIDA
> <dealmeida.jairo at gmail.com <mailto:dealmeida.jairo at gmail.com>> wrote:
> Hi,
> I'm studant and study distributed systems. When running a compiled
> C program, introduced this error (problem with execution of
> programa on Slave: [Errno 2] No such file or directory).
> The program is shared between cluster nodes by Network File
> System. You can help me?
> Thanks!
> Att,
> Jairo de Almeida
> undergraduate research
> Federal Institute of Science Education and Technology São Paulo
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> <mailto:mpich-discuss at mcs.anl.gov>
> To manage subscription options or unsubscribe:
