[mpich-discuss] extra bytes
Kokron, Daniel S. (GSFC-610.1)[Computer Sciences Corporation]
daniel.s.kokron at nasa.gov
Thu Aug 9 14:33:16 CDT 2012
The attached program writes a single distributed 3D field to a file using calls to MPI_Type_create_subarray,
MPI_File_set_view and MPI_File_write_all. It then attempts to append two 1D variables to the end of the file
from a single rank. I've implemented three scenarios for the 1D writes. See the case structure for scenarios.
The final size of the file should be [(516x516x72)+(2*72)]*4 = 76682304 Bytes.
This is the case under scenario 0 and 1 for all process counts (isize*jsize) I've tested.
I get the correct size under scenario 2 for all process counts tested only
if isize is 3 or smaller.
With isize=4, I get a file that is 76683852 B (+1548B)
isize=5 -> 76683952 (+100B)
isize=6 -> 76684024 (+72B)
isize=7 -> 76684072 (+48B)
isize=8 -> 76685912 (+1840B)
isize=9 -> 76685968 (+56B)
These results are from using the Intel 12.1.4.319 compiler with SGI MPT-2.06 on the pleiades platform (Linux 2.6.32.54-0.3.1.20120223-nasa).
I've also confirmed that the odd behavior occurs under MPT-1.25, IntelMPI-4.0.2.003, IntelMPI-3.1.038,
MVAPICH2-1.8 and OpenMPI-1.5.5 on the same platform with the same compiler.
The odd behavior is present when writing to Lustre or a RAM FS on pleiades.
The odd behavior is present on the discover platform (Linux 2.6.27.54-0.2-default) using Intel 12.1.4.319 with IntelMPI-4.0.3.008 and writing to a GPFS file system.
Is this expected behavior?
Daniel Kokron
NASA Ames (ARC-TN)
SciCon group
301-286-3959
Desc: tst_2Dlayout.F90
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120809/e8cc5fdd/attachment.obj>
