[mpich-discuss] Using g95 to test mpich2-1.4/test file problems
謝奇哲 991546107 at stu.nkmu.edu.tw
Wed Aug 8 02:22:13 CDT 2012
  I'm sorry if I'm asking too many times.
  My case will need using mpi_init, so I install the MPICH2-1.4.
  I'm using WindosXP, Cygwin, g95 and single-node systems.
  And thank you, Jayesh Krishna. Answering my questions to let me know I should
install latest Cygwin version.
  So, I installed the latest Cygwin version on another computer.
  And then the Cygwin Information was CYGWIN_NT-5.1 PC03 1.7.16(0.262/5/3)
2012-07-20 22:55 i686 Cygwin.
  Now, I can use mpiexec running cpi. And I can use -n <number> equal or
greater than 4.
  daizy at PC03 /cygdrive/c/cygwin/mpich2-1.4
  $ mpiexec -n 4 ./examples/cpi
  Process 0 of 4 is on PC03
  pi is approximately 3.1415926544231239, Error is 0.0000000008333307
  wall clock time = 0.000000
  Process 1 of 4 is on PC03
  Process 2 of 4 is on PC03
  Process 3 of 4 is on PC03
  $ mpiexec -n 5 ./examples/cpi
  Process 0 of 5 is on PC03
  pi is approximately 3.1415926544231230, Error is 0.0000000008333298
  Process 1 of 5 is on PC03
  Process 2 of 5 is on PC03
  Process 3 of 5 is on PC03
  Process 4 of 5 is on PC03
  I would appreciate if someone can help me with the following problem:
  When I use command make testing in mpich2-1.4/test file, I still got
error messages (detail saves in testing.txt).
  Processing directory coll
  Looking in ./coll/testlist
  Unexpected output in allred: Fatal error in MPI_Init_thread: Other MPI
error, error stack:
  Unexpected output in allred: MPIR_Init_thread(388).................:
  Unexpected output in allred: MPID_Init(139)........................:
channel initialization failed
  Unexpected output in allred: MPIDI_CH3_Init(38)....................:
  Unexpected output in allred: MPID_nem_init(196)....................:
  Unexpected output in allred: MPIDI_CH3I_Seg_commit(366)............:
  Unexpected output in allred: MPIU_SHMW_Hnd_deserialize(324)........:
  Unexpected output in allred: MPIU_SHMW_Seg_open(863)...............:
  Unexpected output in allred: MPIU_SHMW_Seg_create_attach_templ(637): open
failed - Device or resource busy
  Program allred exited without No Errors
  Processing directory info
  Looking in ./info/testlist
  Processing directory init
  Looking in ./init/testlist
  Processing directory pt2pt
  Looking in ./pt2pt/testlist
  Unexpected output in sendflood: Fatal error in MPI_Init: Other MPI error,
error stack:
  Unexpected output in sendflood: MPIR_Init_thread(388).................:
  Unexpected output in sendflood: MPID_Init(139)........................:
  Unexpected output in sendflood: MPIDI_CH3_Init(38)....................:
  Unexpected output in sendflood: MPID_nem_init(196)....................:
  Unexpected output in sendflood: MPIDI_CH3I_Seg_commit(369)............:
  Unexpected output in sendflood: MPIU_SHMW_Seg_attach(925).............:
  Unexpected output in sendflood: MPIU_SHMW_Seg_create_attach_templ(637):
open failed - Permission denied
  Unexpected output in sendflood: [proxy:0:0 at PC03] HYDU_sock_read
(./utils/sock/sock.c:272): read error (Software caused connection abort)
  Unexpected output in sendflood: [proxy:0:0 at PC03] pmi_cb
(./pm/pmiserv/pmip_cb.c:228): unable to read PMI command
HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback
returned error status
  Unexpected output in sendflood: [proxy:0:0 at PC03] main
(./pm/pmiserv/pmip.c:226): demux engine error waiting for event
  Are these error messages related with single-node systems?
  Can you give me some advices to solve the problem?
  Best regards,
  Chi-Che Hsieh
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120808/619e299a/attachment-0001.html>
Configuring MPICH2 version 1.4 with  'F77=g95' 'FC=g95'
Running on system: CYGWIN_NT-5.1 PC03 1.7.16(0.262/5/3) 2012-07-20 22:55 i686 Cygwin
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.exe
checking for suffix of executables... .exe
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking build system type... i686-pc-cygwin
checking host system type... i686-pc-cygwin
checking for grep that handles long lines and -e... /usr/bin/grep
checking for fgrep... /usr/bin/grep -F
Executing mpich2prereq in /cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3 with
Executing mpich2prereq in /cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis
configure: ===== configuring src/mpl =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/mpl/configure  'F77=g95' 'FC=g95' --disable-option-checking
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking how to print strings... printf
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /usr/bin/sed
checking for egrep... /usr/bin/grep -E
checking for ld used by gcc... /usr/i686-pc-cygwin/bin/ld.exe
checking if the linker (/usr/i686-pc-cygwin/bin/ld.exe) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 8192
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert i686-pc-cygwin file names to i686-pc-cygwin format... func_convert_file_noop
checking how to convert i686-pc-cygwin file names to toolchain format... func_convert_file_noop
checking for /usr/i686-pc-cygwin/bin/ld.exe option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... file_magic ^x86 archive import|^x86 DLL
checking for dlltool... dlltool
checking how to associate runtime and link libraries... func_cygming_dll_for_implib
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for mt... no
checking if : is a manifest tool... no
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -DDLL_EXPORT -DPIC
checking if gcc PIC flag -DDLL_EXPORT -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/i686-pc-cygwin/bin/ld.exe) supports shared libraries... yes
checking dynamic linker characteristics... Win32 ld.exe
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking for variable argument list macro functionality... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking valgrind.h usability... no
checking valgrind.h presence... no
checking for valgrind.h... no
checking memcheck.h usability... no
checking memcheck.h presence... no
checking for memcheck.h... no
checking valgrind/valgrind.h usability... no
checking valgrind/valgrind.h presence... no
checking for valgrind/valgrind.h... no
checking valgrind/memcheck.h usability... no
checking valgrind/memcheck.h presence... no
checking for valgrind/memcheck.h... no
checking helgrind.h usability... no
checking helgrind.h presence... no
checking for helgrind.h... no
checking valgrind/helgrind.h usability... no
checking valgrind/helgrind.h presence... no
checking for valgrind/helgrind.h... no
checking drd.h usability... no
checking drd.h presence... no
checking for drd.h... no
checking valgrind/drd.h usability... no
checking valgrind/drd.h presence... no
checking for valgrind/drd.h... no
checking whether the valgrind headers are broken or too old... yes
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for strncmp... yes
checking whether strncmp needs a declaration... no
checking for putenv... yes
checking whether putenv needs a declaration... no
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating localdefs
config.status: creating include/config.h
config.status: include/config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing include/mplconfig.h commands
config.status: creating include/mplconfig.h - prefix MPL for include/config.h defines
config.status: include/mplconfig.h is unchanged
configure: ===== done with src/mpl configure =====
configure: ===== configuring src/openpa =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/openpa/configure --with-atomic-primitives=auto_allow_emulation 'F77=g95' 'FC=g95' --disable-option-checking
checking for gcc... (cached) gcc
checking whether to enable assertions... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking atomic.h usability... no
checking atomic.h presence... no
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for inline... inline
checking for pthread_create in -lpthread... yes
checking for pthread_yield... yes
checking if 100 threads can be run at once... yes
checking size of void *... 4
checking size of int... 4
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 primitives... yes
checking for support for gcc x86 primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... yes
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: src/config.h is unchanged
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
config.status: src/opa_config.h is unchanged
configure: ===== done with src/openpa configure =====
sourcing /cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra/mpich2prereq
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O2... yes
checking whether C compiler option -O2 works with an invalid prototype program... yes
checking whether routines compiled with -O2 can be linked with ones compiled without -O2... yes
checking for type of weak symbol alias support... pragma weak accepted but does not work (probably creates two non-weak entries)
no
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute__ ((weak_import)) allowed... yes
checking whether __attribute__((weak,alias(...))) allowed... no
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether g95 accepts -g... yes
checking whether Fortran 77 compiler accepts option -O2... yes
checking how to get verbose linking output from g95... -v
checking for Fortran 77 libraries of g95...  -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1 -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/lib/gcc// -L/lib// -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/lib// -lf95 -lm -lws2_32 -lcygwin -luser32 -lkernel32 -ladvapi32 -lshell32
checking whether g95 accepts the FLIBS found by autoconf... yes
checking whether gcc links with FLIBS found by autoconf... yes
checking whether Fortran 77 and C objects are compatible... yes
checking for linker for Fortran main program... Use Fortran to link programs
checking for Fortran 77 name mangling... lower 2uscore
checking for libraries to link Fortran main with C stdio routines... none
checking whether Fortran init will work with C... yes
checking whether we are using the GNU Fortran compiler... yes
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (g95    ) works... yes
checking whether the Fortran 90 compiler (g95    ) is a cross-compiler... no
checking whether Fortran 90 compiler works with Fortran 77 compiler... yes
checking whether Fortran 77 accepts ! for comments... yes
checking for include directory flag for Fortran... -I
checking for Fortran 77 flag for library directories... -L
checking whether Fortran 77 compiler processes .F files with C preprocessor... yes
checking whether we are using the GNU Fortran compiler... (cached) yes
checking whether g95 accepts -g... (cached) yes
checking for Fortran 90 module extension... mod
checking for Fortran 90 module include flag... -I
checking whether Fortran 90 compiler accepts option -O2... yes
checking whether Fortran 90 compiler processes .F90 files with C preprocessor... yes
checking what libraries are needed to link Fortran90 programs with C routines that use stdio... none
checking for Fortran 90 compiler vendor... gnu
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking whether the C++ compiler c++ can build an executable... yes
checking whether C++ compiler works with string... yes
checking whether the compiler supports exceptions... yes
checking whether the compiler recognizes bool as a built-in type... yes
checking whether the compiler implements namespaces... yes
checking whether <iostream> available... yes
checking whether the compiler implements the namespace std... yes
checking whether <math> available... no
checking for GNU g++ version... 4 . 5
checking whether C++ compiler accepts option -O2... yes
checking for perl... /usr/bin/perl
checking for killall... no
checking whether install works... yes
checking whether install breaks libraries... no
checking whether mkdir -p works... yes
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... yes
checking for bash... /usr/bin/bash
checking whether /usr/bin/bash supports arrays... yes
checking for doctext... false
checking for location of doctext style files... unavailable
checking for working volatile... yes
checking whether byte ordering is bigendian... no
checking whether C compiler allows unaligned doubles... yes
checking whether gcc supports __func__... yes
Using gcc to determine dependencies
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for max C struct integer alignment... eight
checking for max C struct floating point alignment... four
checking for max C struct alignment of structs with doubles... eight
checking for max C struct floating point alignment with long doubles... four
configure: WARNING: Structures containing long doubles may be aligned differently from structures with floats or longs.  MPICH2 does not handle this case automatically and you should avoid assumed extents for structures containing float types.
checking if alignment of structs with doubles is based on position... no
checking if alignment of structs with long long ints is based on position... no
checking if double alignment breaks rules, find actual alignment... no
checking for alignment restrictions on pointers... int or better
checking size of char... 1
checking size of unsigned char... 1
checking size of short... 2
checking size of unsigned short... 2
checking size of unsigned int... 4
checking size of long... 4
checking size of unsigned long... 4
checking size of long long... 8
checking size of unsigned long long... 8
checking size of float... 4
checking size of double... 8
checking size of long double... 12
checking for ANSI C header files... (cached) yes
checking size of wchar_t... 2
checking size of float_int... 8
checking size of double_int... 16
checking size of long_int... 8
checking size of short_int... 8
checking size of two_int... 8
checking size of long_double_int... 16
checking sys/bitypes.h usability... no
checking sys/bitypes.h presence... no
checking for sys/bitypes.h... no
checking inttypes.h usability... yes
checking inttypes.h presence... yes
checking stdint.h usability... yes
checking stdint.h presence... yes
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking stdbool.h usability... yes
checking stdbool.h presence... yes
checking for stdbool.h... yes
checking complex.h usability... yes
checking complex.h presence... yes
checking for complex.h... yes
checking size of _Bool... 1
checking size of float _Complex... 8
checking size of double _Complex... 16
checking size of long double _Complex... 24
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking for size of Fortran type integer... 4
checking for size of Fortran type real... 4
checking for size of Fortran type double precision... 8
checking whether integer*1 is supported... yes
checking whether integer*2 is supported... yes
checking whether integer*4 is supported... yes
checking whether integer*8 is supported... yes
checking whether integer*16 is supported... no
checking whether real*4 is supported... yes
checking whether real*8 is supported... yes
checking whether real*16 is supported... yes
checking for C type matching Fortran integer... int
checking for size of MPI_Status... 20
checking for values of Fortran logicals... True is 1 and False is 0
checking for BSD/POSIX style global symbol lister... no
checking for multiple __attribute__((alias)) support... yes
checking the minimum alignment of Fortran common block of 1 integers... 4
checking the minimum alignment of Fortran common block of 5 integers... 4, too small! reset to 32
checking for Fortran 90 integer kind for 4-byte integers... 4
checking for Fortran 90 integer kind for 8-byte integers... 8
checking if real*8 is supported in Fortran 90... yes
checking size of bool... 1
checking how to run the C++ preprocessor... c++ -E
checking complex usability... yes
checking complex presence... yes
checking for complex... yes
checking size of Complex... 8
checking size of DoubleComplex... 16
checking size of LongDoubleComplex... 24
checking if char * pointers use byte addresses... yes
checking for alignment restrictions on ... no
checking for alignment restrictions on int32_t... no
checking size of MPIR_Bsend_data_t... 56
checking for gcc __asm__ and pentium cmpxchgl instruction... yes
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... no
checking for gcc __asm__ and IA64 xchg4 instruction... no
checking stdlib.h usability... yes
checking stdlib.h presence... yes
checking sys/types.h usability... yes
checking sys/types.h presence... yes
checking string.h usability... yes
checking string.h presence... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stddef.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking unistd.h usability... yes
checking unistd.h presence... yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/uio.h... yes
checking for size_t... yes
checking for setitimer... yes
checking for alarm... yes
checking for vsnprintf... yes
checking for vsprintf... yes
checking whether vsnprintf needs a declaration... no
checking for strerror... yes
checking for strncasecmp... yes
checking whether strerror_r is declared... yes
checking for strerror_r... yes
checking whether strerror_r returns char *... no
checking whether strerror_r needs a declaration... no
checking for qsort... yes
checking for va_copy... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for mkstemp... yes
checking whether mkstemp needs a declaration... no
checking for fdopen... yes
checking whether fdopen needs a declaration... yes
checking for clock_gettime... yes
checking for clock_getres... yes
checking for gethrtime... no
checking for mach_absolute_time... no
checking for gettimeofday... yes
checking for library containing clock_gettime... none required
checking for library containing clock_getres... none required
checking whether struct timespec is defined in time.h... yes
checking for CLOCK_REALTIME defined in time.h... yes
sourcing /cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/setup_device
RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
sourcing /cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/setup_channel
RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
checking for pthread_key_create in -lpthread... yes
checking for pthread_key_create... yes
checking for pthread_cleanup_push... no
checking whether pthread_cleanup_push is available (may be a macro in pthread.h)... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE_NP... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK_NP... no
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK... yes
checking for thread local storage specifier... __thread
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking for sched_yield... yes
checking for yield... no
checking for usleep... yes
checking for sleep... yes
checking for select... yes
checking for getpid... yes
checking for sched_setaffinity... no
checking for sched_getaffinity... no
checking for bindprocessor... no
checking for thread_policy_set... no
configure: ===== configuring src/mpid/ch3 =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/configure  'F77=g95' 'FC=g95' --disable-option-checking
RUNNING CONFIGURE FOR CH3 DEVICE
checking for sys/types.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking uuid/uuid.h usability... yes
checking uuid/uuid.h presence... yes
checking for uuid/uuid.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for unistd.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for net/if.h... yes
checking for pid_t... yes
checking for inet_pton... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking whether CPP accepts variable length argument lists... yes
checking whether we can use struct ifconf... yes
configure: ===== configuring channels/nemesis =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/configure  'F77=g95' 'FC=g95' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' --disable-option-checking
RUNNING CONFIGURE FOR THE NEMESIS CHANNEL
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking for netinet/in.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for signal... yes
checking for rand... yes
checking for srand... yes
checking for OpenPA atomic primitive availability... yes
checking for mmap... yes
checking for munmap... yes
configure: Using a memory-mapped file for shared memory
checking whether struct hostent contains h_addr_list... yes
checking knem_io.h usability... no
checking knem_io.h presence... no
checking for knem_io.h... no
config.status: creating nemesis/Makefile
config.status: creating nemesis/src/Makefile
config.status: creating nemesis/utils/Makefile
config.status: creating nemesis/utils/replacements/Makefile
config.status: creating nemesis/utils/monitor/Makefile
config.status: creating nemesis/netmod/Makefile
config.status: creating nemesis/netmod/elan/Makefile
config.status: creating nemesis/netmod/gm/Makefile
config.status: creating nemesis/netmod/mx/Makefile
config.status: creating nemesis/netmod/tcp/Makefile
config.status: creating nemesis/netmod/psm/Makefile
config.status: creating nemesis/netmod/newmad/Makefile
config.status: creating nemesis/netmod/none/Makefile
config.status: creating nemesis/include/mpid_nem_net_module_defs.h
config.status: creating nemesis/src/mpid_nem_net_array.c
config.status: creating include/mpidi_ch3i_nemesis_conf.h
config.status: include/mpidi_ch3i_nemesis_conf.h is unchanged
configure: ===== done with channels/nemesis configure =====
config.status: creating util/Makefile
config.status: creating channels/Makefile
config.status: creating util/ftb/Makefile
config.status: creating include/mpid_thread.h
config.status: creating include/mpidi_ch3_conf.h
config.status: include/mpidi_ch3_conf.h is unchanged
config.status: executing default-1 commands
copying ./../common/thread/mpid_thread_mpe.c to src/mpid_thread.c
configure: ===== done with src/mpid/ch3 configure =====
configure: ===== configuring src/mpi/romio =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/configure  'F77=g95' 'FC=g95' --disable-option-checking
Configuring with args F77=g95 FC=g95 --disable-option-checking
checking for architecture... i686
configure: WARNING: Unknown architecture ... proceeding anyway
ROMIO home directory is /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio
checking for memalign... yes
checking Fortran external names
Fortran externals are lower case and have two trailing underscores
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for u_char... yes
checking for u_short... yes
checking for u_int... yes
checking for u_long... yes
checking sys/attr.h usability... no
checking sys/attr.h presence... no
checking for sys/attr.h... no
checking for int large enough for pointers... yes
checking for Fortran 90 KIND parameter for 8-byte integers...  8
checking that we can use integer*8 to declare MPI_DISPLACMENT_CURRENT... yes
Overriding Array test for MPICH2
checking for weak symbol support... pragma weak
checking that weak symbols are visible to other files... no
no
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs nfs
configure: WARNING: File locks may not work with NFS.  See the Installation and
users manual for instructions on testing and if necessary fixing this
checking for library containing aio_write... no
checking for library containing pthread_create... none required
checking for library containing aio_write... (cached) no
checking if aio.h exists and can be compiled... no
checking if sys/aio.h exists and can be compiled... no
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for large file defines... no
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for lseek64... no
checking for large file defines... none
checking spi/kernel_interface.h usability... no
checking spi/kernel_interface.h presence... no
checking for spi/kernel_interface.h... no
checking for Kernel_GetMemorySize... no
setting SYSDEP_INC to
setting CC to gcc
setting F77 to g95
setting TEST_CC to /cygdrive/c/cygwin/mpich2-1.4/bin/mpicc
setting TEST_F77 to /cygdrive/c/cygwin/mpich2-1.4/bin/mpif77
setting CFLAGS to    -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating mpi-io/Makefile
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating adio/common/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating test-internal/Makefile
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating adio/ad_nfs/Makefile
config.status: creating adio/ad_ufs/Makefile
config.status: creating adio/ad_bgl/Makefile
config.status: creating adio/ad_bglockless/Makefile
config.status: creating adio/ad_panfs/Makefile
config.status: creating adio/ad_xfs/Makefile
config.status: creating adio/ad_sfs/Makefile
config.status: creating adio/ad_pfs/Makefile
config.status: creating adio/ad_testfs/Makefile
config.status: creating adio/ad_pvfs/Makefile
config.status: creating adio/ad_pvfs2/Makefile
config.status: creating adio/ad_gridftp/Makefile
config.status: creating adio/ad_lustre/Makefile
config.status: creating adio/ad_zoidfs/Makefile
config.status: creating mpi-io/fortran/Makefile
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating mpi-io/glue/mpich2/Makefile
config.status: creating mpi-io/glue/mpich1/Makefile
config.status: creating mpi-io/glue/default/Makefile
config.status: creating common/dataloop/Makefile
config.status: creating adio/include/romioconf.h
configure: ===== done with src/mpi/romio configure =====
configure: ===== configuring src/pmi/simple =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/pmi/simple/configure  'F77=g95' 'FC=g95' --disable-option-checking
RUNNING CONFIGURE FOR THE SIMPLE PMI
checking for strings.h... (cached) yes
checking for sys/socket.h... (cached) yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for socket... yes
checking for setsockopt... yes
checking for gethostbyname... yes
checking whether socklen_t is defined (in sys/socket.h if present)... yes
config.status: creating pmiconf.h
config.status: pmiconf.h is unchanged
configure: ===== done with src/pmi/simple configure =====
configure: ===== configuring src/pm/hydra =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra/configure  'F77=g95' 'FC=g95' --disable-option-checking
checking for a thread-safe mkdir -p... mkdir -p
checking whether -lc should be explicitly linked in... yes
checking whether to build shared libraries... yes
checking for doxygen... /usr/bin/doxygen
checking ifaddrs.h usability... yes
checking ifaddrs.h presence... yes
checking for ifaddrs.h... yes
checking poll.h usability... yes
checking poll.h presence... yes
checking for poll.h... yes
checking for netdb.h... (cached) yes
checking winsock2.h usability... no
checking winsock2.h presence... yes
configure: WARNING: winsock2.h: present but cannot be compiled
configure: WARNING: winsock2.h:     check for missing prerequisite headers?
configure: WARNING: winsock2.h: see the Autoconf documentation
configure: WARNING: winsock2.h:     section "Present But Cannot Be Compiled"
configure: WARNING: winsock2.h: proceeding with the compiler's result
checking for winsock2.h... no
checking windows.h usability... yes
checking windows.h presence... yes
checking for windows.h... yes
checking for socket in -lsocket... no
checking for gethostbyname in -lnsl... no
checking for sigaction... yes
checking for alloca... no
checking for unsetenv... yes
checking for strsignal... yes
checking for getifaddrs... yes
checking for fcntl... yes
checking for isatty... yes
checking for inet_ntop... yes
checking for environ in unistd.h... yes
checking bootstrap server... ssh,rsh,fork,slurm,ll,lsf,sge,pbs,none,persist
checking process manager... pmiserv
checking user interface... mpich
checking desired process binding libraries... hwloc,plpa
configure: ===== configuring tools/bind/hwloc/hwloc =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra/tools/bind/hwloc/hwloc/configure --enable-embedded-mode 'F77=g95' 'FC=g95' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2 ' 'LDFLAGS=' 'LDFLAGS= ' 'LIBS=' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' --disable-option-checking
### Configuring hwloc distribution tarball
### Startup tests
checking target system type... i686-pc-cygwin
checking how to create a ustar tar archive... gnutar
checking for hwloc version... 1.2rc3-1
checking whether gcc and cc understand -c and -o together... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
### Configuring hwloc core
checking hwloc building mode... embedded
configure: hwloc builddir: /cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra/tools/bind/hwloc/hwloc
configure: hwloc srcdir: /cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra/tools/bind/hwloc/hwloc
checking if want hwloc maintainer support... disabled (embedded mode)
checking for hwloc directory prefix... (none)
checking for hwloc symbol prefix... hwloc_
checking which OS support to include... Windows
checking which CPU support to include... x86_32
checking for __attribute__... yes
checking for __attribute__(aligned)... yes
checking for __attribute__(always_inline)... yes
checking for __attribute__(cold)... yes
checking for __attribute__(const)... yes
checking for __attribute__(deprecated)... yes
checking for __attribute__(format)... no
checking for __attribute__(hot)... yes
checking for __attribute__(malloc)... yes
checking for __attribute__(may_alias)... yes
checking for __attribute__(no_instrument_function)... yes
checking for __attribute__(nonnull)... no
checking for __attribute__(noreturn)... yes
checking for __attribute__(packed)... yes
checking for __attribute__(pure)... yes
checking for __attribute__(sentinel)... no
checking for __attribute__(unused)... yes
checking for __attribute__(warn_unused_result)... yes
checking for __attribute__(weak_alias)... yes
checking whether to enable visibility... no (disabled)
checking for inline compatibility keyword... __inline__
checking whether function strncasecmp is declared... yes
checking for strftime... yes
checking for setlocale... yes
checking for KAFFINITY... no
checking for PROCESSOR_CACHE_TYPE... no
checking for CACHE_DESCRIPTOR... no
checking for LOGICAL_PROCESSOR_RELATIONSHIP... no
checking for RelationProcessorPackage... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION... no
checking for GROUP_AFFINITY... no
checking for PROCESSOR_RELATIONSHIP... no
checking for NUMA_NODE_RELATIONSHIP... no
checking for CACHE_RELATIONSHIP... no
checking for PROCESSOR_GROUP_INFO... no
checking for GROUP_RELATIONSHIP... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION_EX... no
checking for PSAPI_WORKING_SET_EX_BLOCK... no
checking for PSAPI_WORKING_SET_EX_INFORMATION... no
checking for main in -lgdi32... yes
checking sys/lgrp_user.h usability... no
checking sys/lgrp_user.h presence... no
checking for sys/lgrp_user.h... no
checking kstat.h usability... no
checking kstat.h presence... no
checking for kstat.h... no
checking whether _SC_NPROCESSORS_ONLN is declared... yes
checking whether _SC_NPROCESSORS_CONF is declared... yes
checking whether _SC_NPROC_ONLN is declared... no
checking whether _SC_NPROC_CONF is declared... no
checking whether _SC_LARGE_PAGESIZE is declared... no
checking mach/mach_host.h usability... no
checking mach/mach_host.h presence... no
checking for mach/mach_host.h... no
checking mach/mach_init.h usability... no
checking mach/mach_init.h presence... no
checking for mach/mach_init.h... no
checking for sys/sysctl.h... no
checking for sysctl... no
checking for sysctlbyname... no
checking whether function sched_setaffinity is declared... no
checking for working CPU_SET... no
checking for working CPU_SET_S... no
checking for working _syscall3... no
checking for KERRIGHED... no
checking for lib... /cygdrive/c/program files/microsoft visual studio/vc98/bin/lib
checking for bash... /usr/bin/sh
checking for ffs... yes
checking whether function ffs is declared... yes
checking for ffsl... no
checking for fls... no
checking for flsl... no
checking for clz... no
checking for clzl... no
checking for openat... yes
checking for getpagesize... yes
checking for posix_memalign... yes
checking sys/utsname.h usability... yes
checking sys/utsname.h presence... yes
checking for sys/utsname.h... yes
checking for uname... yes
checking numaif.h usability... no
checking numaif.h presence... no
checking for numaif.h... no
checking pthread_np.h usability... no
checking pthread_np.h presence... no
checking for pthread_np.h... no
checking whether pthread_setaffinity_np is declared... no
checking whether pthread_getaffinity_np is declared... no
checking for sys/cpuset.h... no
checking for library containing pthread_getthrds_np... no
checking for XML... yes
checking for xmlNewDoc... yes
checking for final XML support... yes
checking for cpuid... yes
checking for X... libraries , headers
checking for as... as
checking for dlltool... (cached) dlltool
checking for objdump... (cached) objdump
checking whether to build static libraries... no
config.status: creating include/Makefile
config.status: creating include/private/autogen/config.h
config.status: creating include/hwloc/autogen/config.h
configure: ===== done with tools/bind/hwloc/hwloc configure =====
configure: ===== configuring tools/bind/plpa/plpa =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra/tools/bind/plpa/plpa/configure --enable-included-mode 'F77=g95' 'FC=g95' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2 ' 'LDFLAGS=' 'LDFLAGS= ' 'LIBS=' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' --disable-option-checking
checking for PLPA version... 1.3.2
checking whether to enable "picky" compiler mode... no (default)
checking for flex... flex
checking lex output file root... lex.yy
checking lex library... -lfl
checking whether yytext is a pointer... yes
checking for bison... bison -y
checking for syscall... no
configure: error: Cannot continue
configure: ===== done with tools/bind/plpa/plpa configure =====
checking available process binding libraries...
checking checkpointing library... none
checking demux engine... poll,select,port
checking for poll... yes
checking debugging support... none
checking error checking... yes
checking warnings... no
checking profiling... yes
checking libftb.h usability... no
checking libftb.h presence... no
checking for libftb.h... no
checking for FTB_Connect in -lftb... no
checking for strsignal... (cached) yes
checking whether strsignal needs a declaration... no
checking for sigaction... (cached) yes
checking for signal... (cached) yes
checking for sigset... yes
checking for struct sigaction and sa_handler... yes
config.status: creating tools/bootstrap/src/bsci_init.c
config.status: creating hydra-doxygen.cfg
config.status: creating include/hydra_config.h
configure: ===== done with src/pm/hydra configure =====
configure: ===== configuring src/mpe2 =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/configure  'F77=g95' 'FC=g95' --disable-option-checking
Configuring MPE Profiling System with  'F77=g95' 'FC=g95' '--disable-option-checking' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2
checking gnumake... yes using --no-print-directory
checking BSD 4.4 make... no - whew
checking OSF V3 make... no
This MPE build is part of the MPICH2 build
checking for leftover Makefiles in subpackages ...  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/graphics" "src/collchk" cleaned
checking whether MPI_CC has been set ... /cygdrive/c/cygwin/mpich2-1.4/bin/mpicc
checking whether MPI_F77 has been set ... /cygdrive/c/cygwin/mpich2-1.4/bin/mpif77
checking for Fortran 77 libraries of g95...  -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1 -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/lib/gcc// -L/lib// -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/lib// -lpthread -lf95 -lm -lws2_32 -lcygwin -luser32 -lkernel32 -ladvapi32 -lshell32
checking whether C can link with  -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1 -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/lib/gcc// -L/lib// -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/lib// -lpthread -lf95 -lm -lws2_32 -lcygwin -luser32 -lkernel32 -ladvapi32 -lshell32... yes
checking for linker for Fortran main programs... Use Fortran to link programs
checking for Fortran 77 name mangling... lower doubleunderscore
checking what libraries are needed to link Fortran programs with C routines that use stdio... none
config.status: creating sbin/mpetestlink
config.status: creating sbin/mpetestexec
config.status: creating sbin/mpetestexeclog
config.status: creating sbin/mpeinstall
config.status: creating sbin/mpecheckinstall
config.status: WARNING:  'sbin/mpecheckinstall.in' seems to ignore the --datarootdir setting
config.status: creating sbin/mpecheckbuild
config.status: creating etc/mpe_help.conf
config.status: creating etc/mpe_f77env.conf
config.status: creating mpe_conf.h
=== configuring in src/misc (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/misc)
configure: running /bin/sh ./configure --disable-option-checking '--prefix=/usr/local'  'F77=g95' 'FC=g95' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' --cache-file=/dev/null --srcdir=.
Configuring MPE Miscellaneous Library with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/misc
checking for dbx... no
checking for gdb... /usr/bin/gdb
checking for sysinfo... yes
checking sys/systeminfo.h usability... no
checking sys/systeminfo.h presence... no
checking for sys/systeminfo.h... no
checking for sighandler_t... yes
checking for kill... yes
checking whether kill needs a declaration... no
config.status: creating src/dbxerr.c
config.status: creating mpe_misc_conf.h
=== configuring in src/callstack (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/callstack)
Configuring MPE CallStack Library with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/callstack
checking execinfo.h usability... no
checking execinfo.h presence... no
checking for execinfo.h... no
checking ucontext.h usability... no
checking ucontext.h presence... no
checking for ucontext.h... no
checking whether fdopen needs a declaration... no
config.status: creating include/mpe_callstack.h
config.status: creating etc/mpe_callstack_ldflags.conf
config.status: creating bin/bt2line
config.status: creating mpe_callstack_conf.h
=== configuring in src/logging (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/logging)
Configuring MPE Logging Library and Tools with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/logging
checking for header that defines C99 integer types, intXX_t ... <stdint.h>
checking whether <inttypes.h> defines the PRIdXX macros ... yes
checking if <stdint.h> can be behind system headers ... yes
checking for address-sized integer ... CLOG_int32_t
checking for srand48... yes
checking whether srand48 needs a declaration... no
checking for lrand48... yes
checking whether lrand48 needs a declaration... no
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for O_LARGEFILE for open() ... no
checking for O_BINARY for open() ... yes
checking for pthread_mutex_lock in -lpthread... yes
config.status: creating include/clog_inttypes.h
config.status: creating include/mpi_null.h
config.status: creating include/mpe_log_thread.h
config.status: creating etc/mpe_log.conf
config.status: creating etc/mpe_nolog.conf
config.status: creating etc/mpe_log_postlib.conf
config.status: creating mpe_logging_conf.h
=== configuring in src/wrappers (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/wrappers)
Configuring MPE Wrapper Libraries For MPI with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/wrappers
checking for stdarg is correct... yes
checking if compiler accepts prototypes ... yes
checking for safe PMPI invocations ... no
checking for the value of MPI_STATUS_SIZE ... 5
config.status: creating etc/mpe_mpilog.conf
config.status: creating etc/mpe_mpitrace.conf
config.status: creating mpe_wrappers_conf.h
=== configuring in src/graphics (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/graphics)
Configuring MPE X Graphics Library with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/graphics
checking for long pointer... no
checking for system... yes
config.status: creating contrib/life/Makefile
config.status: creating contrib/mandel/Makefile
config.status: creating contrib/mastermind/Makefile
config.status: creating contrib/test/Makefile
config.status: creating etc/mpe_mpianim.conf
config.status: creating etc/mpe_graphics.conf
config.status: creating mpe_graphics_conf.h
=== configuring in src/collchk (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/collchk)
Configuring MPE Collective and Datatype Checking Library with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/collchk
config.status: creating etc/mpe_mpicheck.conf
config.status: creating mpe_collchk_conf.h
=== configuring in src/slog2sdk (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/slog2sdk)
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/slog2sdk
Configuring SLOG2SDK with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for a BSD-compatible install... /usr/bin/install -c
checking if CLASSPATH is set... no, good to go
checking build system type... i686-pc-cygwin
checking host system type... i686-pc-cygwin
checking for java in user's PATH... found /cygdrive/c/WINDOWS/java
checking if /cygdrive/c/WINDOWS/java runs simple java class... no
checking for java in user's PATH... not found
configure: WARNING:  No Java Virtual Machine can be found anywhere!
MPE2:  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/graphics" "src/collchk" have been configured
configure: ===== done with src/mpe2 configure =====
checking size of OPA_ptr_t... 4
checking the sizeof MPI_Offset... 8
checking whether the Fortran Offset type works with Fortran 77... yes
checking whether the Fortran Offset type works with Fortran 90... yes
Running Configure for Fortran 90 Type routines
checking whether the C compiler works... yes
checking for C compiler default output file name... a.exe
checking for suffix of executables... .exe
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for grep that handles long lines and -e... /usr/bin/grep
checking for fgrep... /usr/bin/grep -F
checking for the precision and range of reals...  6 , 37
checking for the precision and range of double precision...  15 , 307
checking for the range of integer...  9
checking for available integer kinds...  2 , 1, 4 , 2, 9 , 4, 18 , 8,
checking for available integer ranges...  {  2 , 1 , 1 }, {  4 , 2 , 2 }, {  9 , 4 , 4 }, {  18 , 8 , 8 },
config.status: creating mpif90model.h
config.status: creating src/include/Makefile
config.status: creating src/include/mpich2info.h
config.status: creating mpich2-doxygen
config.status: creating src/include/mpichtimer.h
config.status: creating src/binding/Makefile
config.status: creating src/binding/cxx/Makefile
config.status: creating src/binding/cxx/mpicxx.h
config.status: creating src/binding/f77/Makefile
config.status: creating src/binding/f77/mpif.h
config.status: creating src/binding/f77/setbotf.f
config.status: creating src/binding/f77/setbot.c
config.status: creating src/binding/f90/Makefile
config.status: creating src/binding/f90/mpi_sizeofs.f90
config.status: creating src/binding/f90/mpi_base.f90
config.status: creating src/packaging/Makefile
config.status: creating src/packaging/pkgconfig/mpich2-c.pc
config.status: creating src/packaging/pkgconfig/mpich2-cxx.pc
config.status: creating src/packaging/pkgconfig/mpich2-f77.pc
config.status: creating src/packaging/pkgconfig/mpich2-f90.pc
config.status: creating src/packaging/pkgconfig/Makefile
config.status: creating src/packaging/envmods/mpich2.module
config.status: WARNING:  'src/packaging/envmods/mpich2.module.in' seems to ignore the --datarootdir setting
config.status: creating src/packaging/envmods/Makefile
config.status: creating src/env/mpixxx_opts.conf
config.status: creating src/env/mpicc
config.status: creating src/env/mpicc.conf
config.status: creating src/env/mpicc.bash
config.status: creating src/env/mpicxx
config.status: creating src/env/mpicxx.conf
config.status: creating src/env/mpicxx.bash
config.status: creating src/env/mpif77
config.status: creating src/env/mpif77.conf
config.status: creating src/env/mpif77.bash
config.status: creating src/env/mpif90
config.status: creating src/env/mpif90.conf
config.status: creating src/env/mpif90.bash
config.status: creating src/env/Makefile
config.status: creating src/util/createshlib
config.status: creating src/mpi/Makefile
config.status: creating src/mpi/attr/Makefile
config.status: creating src/mpi/coll/Makefile
config.status: creating src/mpi/comm/Makefile
config.status: creating src/mpi/datatype/Makefile
config.status: creating src/mpi/debugger/Makefile
config.status: creating src/mpi/errhan/Makefile
config.status: creating src/mpi/group/Makefile
config.status: creating src/mpi/init/Makefile
config.status: creating src/mpi/misc/Makefile
config.status: creating src/mpi/pt2pt/Makefile
config.status: creating src/mpi/rma/Makefile
config.status: creating src/mpi/spawn/Makefile
config.status: creating src/mpi/timer/Makefile
config.status: creating src/mpi/topo/Makefile
config.status: creating src/mpix/Makefile
config.status: creating src/mpix/comm/Makefile
config.status: creating src/mpid/Makefile
config.status: creating src/mpid/common/Makefile
config.status: creating src/mpid/common/datatype/Makefile
config.status: creating src/mpid/common/datatype/dataloop/Makefile
config.status: creating src/pm/Makefile
config.status: creating src/pmi/Makefile
config.status: creating src/pmi/simple/Makefile
config.status: creating src/nameserv/Makefile
config.status: creating src/nameserv/file/Makefile
config.status: creating src/nameserv/mpd/Makefile
config.status: creating src/nameserv/pmi/Makefile
config.status: creating src/nameserv/test/Makefile
config.status: creating src/util/Makefile
config.status: creating src/util/info/Makefile
config.status: creating src/util/instrm/Makefile
config.status: creating src/util/thread/Makefile
config.status: creating src/util/mem/Makefile
config.status: creating src/util/msgs/Makefile
config.status: creating src/util/param/Makefile
config.status: creating src/util/dbg/Makefile
config.status: creating src/util/dbg/getfuncstack
config.status: creating src/util/osserv/Makefile
config.status: creating src/util/procmap/Makefile
config.status: creating src/util/other/Makefile
config.status: creating src/include/mpi.h
config.status: creating test/util/Makefile
config.status: creating test/basic/Makefile
config.status: creating test/commands/Makefile
config.status: creating test/commands/cmdtests
config.status: creating test/mpid/Makefile
config.status: creating test/mpid/ch3/Makefile
config.status: creating test/util/timer/Makefile
config.status: creating examples/Makefile
config.status: creating examples/f77/Makefile
config.status: creating examples/f90/Makefile
config.status: creating examples/cxx/Makefile
config.status: creating src/util/logging/Makefile
config.status: creating src/util/logging/common/Makefile
config.status: creating doc/Makefile
config.status: creating doc/mansrc/Makefile
config.status: creating doc/mansrc/createhtmlindex
config.status: creating doc/refman/Makefile
config.status: creating doc/installguide/Makefile
config.status: creating doc/userguide/Makefile
config.status: creating doc/logging/Makefile
config.status: creating doc/design/Makefile
config.status: creating doc/smpd/Makefile
config.status: creating doc/windev/Makefile
config.status: creating src/include/mpichconf.h
config.status: executing default-2 commands
config.status: executing default-3 commands
config.status: executing default-4 commands
config.status: executing default-5 commands
config.status: executing default-6 commands
config.status: executing default-7 commands
config.status: executing default-8 commands
config.status: executing default-9 commands
config.status: executing default-10 commands
config.status: executing default-11 commands
config.status: executing default-12 commands
=== configuring in test/mpi (/cygdrive/c/cygwin/mpich2-1.4/test/mpi)
configure: running /bin/sh ./configure --disable-option-checking '--prefix=/usr/local'  'F77=g95' 'FC=g95' --cache-file=/dev/null --srcdir=.
RUNNING CONFIGURE FOR MPI TESTS
checking whether /cygdrive/c/cygwin/mpich2-1.4/bin/mpicc accepts -g... yes
checking for /cygdrive/c/cygwin/mpich2-1.4/bin/mpicc option to accept ISO C89... none needed
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking how to run the C preprocessor... /cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -E
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for library containing pthread_barrier_init... no
checking for pthread_create... yes
checking for pthread_yield... yes
checking for pthread_barrier_init... no
checking for pthread_barrier_wait... no
checking for major version of MPI... 2
checking for minor version of MPI... 2
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether /cygdrive/c/cygwin/mpich2-1.4/bin/mpif77 accepts -g... yes
checking how to get verbose linking output from /cygdrive/c/cygwin/mpich2-1.4/bin/mpif77... -v
checking for Fortran 77 libraries of /cygdrive/c/cygwin/mpich2-1.4/bin/mpif77...  -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1 -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/lib/gcc// -L/lib// -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/lib// -lf95 -lm -lws2_32 -lcygwin -luser32 -lkernel32 -ladvapi32 -lshell32
checking for Fortran 77 name mangling... lower 2uscore
checking for Fortran libraries needed for getarg... none needed
checking whether Fortran 77 supports Cray-style pointer... no
checking whether we are using the GNU Fortran compiler... yes
checking whether /cygdrive/c/cygwin/mpich2-1.4/bin/mpif90 accepts -g... yes
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (/cygdrive/c/cygwin/mpich2-1.4/bin/mpif90  -nativelinking  ) works... yes
checking whether the Fortran 90 compiler (/cygdrive/c/cygwin/mpich2-1.4/bin/mpif90  -nativelinking  ) is a cross-compiler... no
checking for Fortran flag needed to accept free-form source... none
checking whether Fortran 90 supports Cray-style pointer... no
checking whether we are using the GNU C++ compiler... yes
checking whether /cygdrive/c/cygwin/mpich2-1.4/bin/mpicxx accepts -g... yes
checking whether MPI_2DOUBLE_COMPLEX is available... no
checking whether MPI_2COMPLEX is available... no
checking size of void *... 4
checking size of int... 4
checking for C integer type of address size... int
configure: creating ./config.status
config.status: creating maint/testmerge
config.status: creating runtests
config.status: creating Makefile
config.status: creating basic/Makefile
config.status: creating attr/Makefile
config.status: creating coll/Makefile
config.status: creating comm/Makefile
config.status: creating datatype/Makefile
config.status: creating errhan/Makefile
config.status: creating group/Makefile
config.status: creating info/Makefile
config.status: creating init/Makefile
config.status: creating pt2pt/Makefile
config.status: creating rma/Makefile
config.status: creating spawn/Makefile
config.status: creating topo/Makefile
config.status: creating io/Makefile
config.status: creating f77/Makefile
config.status: creating f77/attr/Makefile
config.status: creating f77/attr/attraints.h
config.status: creating f77/pt2pt/attr1aints.h
config.status: creating f77/ext/add1size.h
config.status: creating f77/datatype/Makefile
config.status: creating f77/datatype/typeaints.h
config.status: creating f77/util/Makefile
config.status: creating f77/coll/Makefile
config.status: creating f77/comm/Makefile
config.status: creating f77/topo/Makefile
config.status: creating f77/init/Makefile
config.status: creating f77/rma/addsize.h
config.status: creating f77/pt2pt/Makefile
config.status: creating f77/info/Makefile
config.status: creating f77/spawn/Makefile
config.status: creating f77/spawn/type1aint.h
config.status: creating f77/rma/Makefile
config.status: creating f77/ext/Makefile
config.status: creating f77/ext/testlist
config.status: creating f77/io/Makefile
config.status: creating f77/io/iooffset.h
config.status: creating f77/io/iodisp.h
config.status: creating f77/io/ioaint.h
config.status: creating f90/Makefile
config.status: creating f90/attr/Makefile
config.status: creating f90/datatype/Makefile
config.status: creating f90/f90types/Makefile
config.status: creating f90/util/Makefile
config.status: creating f90/coll/Makefile
config.status: creating f90/comm/Makefile
config.status: creating f90/topo/Makefile
config.status: creating f90/init/Makefile
config.status: creating f90/pt2pt/Makefile
config.status: creating f90/rma/Makefile
config.status: creating f90/info/Makefile
config.status: creating f90/spawn/Makefile
config.status: creating f90/timer/Makefile
config.status: creating f90/ext/Makefile
config.status: creating f90/ext/testlist
config.status: creating f90/io/Makefile
config.status: creating f90/misc/Makefile
config.status: creating cxx/Makefile
config.status: creating cxx/util/Makefile
config.status: creating cxx/attr/Makefile
config.status: creating cxx/pt2pt/Makefile
config.status: creating cxx/comm/Makefile
config.status: creating cxx/coll/Makefile
config.status: creating cxx/errhan/Makefile
config.status: creating cxx/info/Makefile
config.status: creating cxx/datatype/Makefile
config.status: creating cxx/io/Makefile
config.status: creating cxx/init/Makefile
config.status: creating cxx/rma/Makefile
config.status: creating cxx/spawn/Makefile
config.status: creating threads/Makefile
config.status: creating threads/pt2pt/Makefile
config.status: creating threads/util/Makefile
config.status: creating threads/comm/Makefile
config.status: creating threads/init/Makefile
config.status: creating threads/spawn/Makefile
config.status: creating errors/Makefile
config.status: creating errors/attr/Makefile
config.status: creating errors/basic/Makefile
config.status: creating errors/coll/Makefile
config.status: creating errors/comm/Makefile
config.status: creating errors/faults/Makefile
config.status: creating errors/group/Makefile
config.status: creating errors/pt2pt/Makefile
config.status: creating errors/rma/Makefile
config.status: creating errors/spawn/Makefile
config.status: creating errors/topo/Makefile
config.status: creating errors/io/Makefile
config.status: creating errors/cxx/Makefile
config.status: creating errors/cxx/errhan/Makefile
config.status: creating errors/cxx/io/Makefile
config.status: creating errors/f77/Makefile
config.status: creating errors/f90/Makefile
config.status: creating manual/Makefile
config.status: creating manual/manyconnect
config.status: creating perf/Makefile
config.status: creating testlist
config.status: creating cxx/testlist
config.status: creating f77/testlist
config.status: creating f90/testlist
config.status: creating threads/testlist
config.status: creating errors/testlist
config.status: creating errors/cxx/testlist
config.status: creating include/mpitestconf.h
config.status: include/mpitestconf.h is unchanged
Configuration completed.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120808/619e299a/attachment-0001.obj>
Beginning make
Using variables CC='gcc' CFLAGS='   -O2' LDFLAGS=' ' F77='g95' FFLAGS='  -O2' FC='g95' FCFLAGS='  -O2' CXX='c++' CXXFLAGS='  -O2' AR='ar' CPP='gcc -E' CPPFLAGS=' -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers'
make all-local
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4'
make clean && cd test && make clean
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4'
make cleanlibs
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4'
rm -f lib/libmpich.a lib/libpmpich.a
rm -f lib/libmpichcxx.a
rm -f lib/libfmpich.a lib/libmpichf90.a
rm -f lib/libmpich.dll*
rm -f lib/libpmpich.dll*
rm -f lib/libmpichcxx.dll*
rm -f lib/libfmpich.dll*
rm -f lib/libmpichf90.dll*
rm -f lib/libmpichf90.*.dll*
rm -f lib/libmpich.*.dll*
rm -f lib/libpmpich.*.dll*
rm -f lib/libmpichcxx.*.dll*
rm -f lib/libfmpich.*.dll*
rm -f lib/libmpich.la* lib/libpmpich.la*
rm -f lib/libmpichf90.la*
rm -f lib/libmpichcxx.la*
rm -f lib/libfmpich.la*
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4'
for dir in  src/mpl src/openpa src - ; do \
	if [ "$dir" = "-" ] ; then break ; fi ; \
	(cd $dir && make clean ) ; done
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
 rm -f strsep.exe
 rm -f strsep
test -z "libmpl.la" || rm -f libmpl.la
rm -f "./so_locations"
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
Making clean in test
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
 rm -f sanity.exe test_primitives.exe test_barriers.exe test_queue.exe
 rm -f sanity test_primitives test_barriers test_queue
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
Making clean in src
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
test -z "libopa.la" || rm -f libopa.la
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
Making clean in .
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
rm -rf .libs _libs
rm -f *.lo
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src'
for dir in mpl mpid mpi mpix util nameserv binding env packaging mpe2 pmi pm - ; do \
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
 rm -f strsep.exe
 rm -f strsep
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid'
for dir in common ch3 - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common'
(cd datatype && make clean )
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype'
(cd dataloop && make clean )
make[8]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype/dataloop'
make[8]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype/dataloop'
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3'
for dir in channels src util ; do \
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels'
for dir in nemesis - ; do \
make[8]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis'
(cd nemesis && make clean )
make[9]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis'
(cd src && make clean )
make[10]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/src'
make[10]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/src'
(cd netmod && make clean )
make[10]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod'
for dir in tcp - ; do \
make[11]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
make[11]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
make[10]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod'
(cd utils && make clean )
make[10]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils'
(cd monitor && make clean )
make[11]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
make[11]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
(cd replacements && make clean )
make[11]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
make[11]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
make[10]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[9]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis'
make[9]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/src'
make[9]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/src'
make[8]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis'
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/src'
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/src'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/util'
for dir in   - ; do \
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/util'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi'
for dir in attr coll comm datatype errhan group init misc pt2pt rma spawn timer topo romio  - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/attr'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/attr'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/coll'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/coll'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/comm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/comm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/datatype'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/datatype'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/errhan'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/errhan'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/group'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/group'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/init'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/init'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/misc'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/misc'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/pt2pt'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/pt2pt'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/rma'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/rma'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/spawn'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/spawn'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/timer'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/timer'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/topo'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/topo'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio'
cleaning directory mpi-io
cleaning directory adio/common
cleaning directory mpi-io/glue/mpich2
cleaning directory adio/ad_testfs
cleaning directory adio/ad_ufs
cleaning directory adio/ad_nfs
cleaning directory test-internal
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/test-internal'
rm -f .P* PI* *.o
rm -f file_realms_test io_bounds_test heap_test
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/test-internal'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/test'
rm -f .P* PI* *.o
rm -f simple perf async coll_test coll_perf misc file_info excl large_array  atomicity noncontig i_noncontig noncontig_coll split_coll shared_fp  large_file psimple error status noncontig_coll2 aggregation1 aggregation2  async-multiple ordered_fp hindexed fcoll_test fperf fmisc pfcoll_test
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/test'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpix'
(cd comm && make clean )
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpix/comm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpix/comm'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpix'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util'
for dir in mem info msgs instrm thread dbg param osserv procmap other  - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/mem'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/mem'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/info'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/info'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/msgs'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/msgs'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/instrm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/instrm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/thread'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/thread'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/dbg'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/dbg'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/param'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/param'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/osserv'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/osserv'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/procmap'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/procmap'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/other'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/other'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/nameserv'
for dir in file - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/nameserv/file'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/nameserv/file'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/nameserv'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding'
for dir in  f77 f90 cxx - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
rm -f *.mod
rm -f mpimod.pcl mpimod.pc
rm -f libmpichf90.a
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/cxx'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/cxx'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
make clean-postamble
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging'
(cd pkgconfig && make clean )
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/pkgconfig'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/pkgconfig'
(cd envmods && make clean )
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/envmods'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/envmods'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpe2'
rm -f /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/lib*
rm -f /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/*.jar
rm -f /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/*.o
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpe2'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pmi'
for dir in simple - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pmi/simple'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pmi/simple'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pmi'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm'
for dir in hydra  - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
Making clean in ../../mpl
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
 rm -f strsep.exe
 rm -f strsep
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
Making clean in .
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
 rm -f hydra_persist.exe hydra_nameserver.exe hydra_pmi_proxy.exe mpiexec.hydra.exe
 rm -f hydra_persist hydra_nameserver hydra_pmi_proxy mpiexec.hydra
rm -rf .libs _libs
test -z "libhydra.la libpm.la" || rm -f libhydra.la libpm.la
rm -f *.o
rm -f *.lo
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src'
cd examples && make clean
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/examples'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/examples'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test'
for dir in mpi mpid util basic commands ; do \
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi'
rm -f summary.xml
for dir in util attr basic datatype coll comm errhan group info init pt2pt rma spawn topo io  f77 f90 cxx threads errors manual perf - ; do \
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/util'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/util'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/attr'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/attr'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/basic'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/basic'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/datatype'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/datatype'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/coll'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/coll'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/comm'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/comm'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errhan'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errhan'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/group'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/group'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/info'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/info'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/init'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/init'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/pt2pt'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/pt2pt'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/rma'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/rma'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/spawn'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/spawn'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/topo'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/topo'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/io'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/io'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77'
for dir in util attr datatype coll pt2pt info init comm topo rma spawn io ext ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/util'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/util'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/attr'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/attr'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/datatype'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/datatype'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/coll'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/coll'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/pt2pt'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/pt2pt'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/info'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/info'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/init'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/init'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/comm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/comm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/topo'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/topo'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/spawn'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/spawn'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
rm -f .iotest.txt.*
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/ext'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/ext'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90'
for dir in util timer attr coll datatype pt2pt info comm rma spawn topo io ext init misc f90types ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/util'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/util'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/timer'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/timer'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/attr'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/attr'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/coll'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/coll'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/pt2pt'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/pt2pt'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/info'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/info'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/comm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/comm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/spawn'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/spawn'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/topo'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/topo'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/io'
rm -f .iotest.txt.*
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/io'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/ext'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/ext'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/init'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/init'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/misc'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/misc'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/f90types'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/f90types'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx'
for dir in util attr pt2pt init info comm coll datatype errhan io rma spawn ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/util'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/util'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/attr'
rm -f summary.xml
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/attr'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/pt2pt'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/pt2pt'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/init'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/init'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/info'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/info'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/comm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/comm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/coll'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/coll'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/datatype'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/datatype'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/errhan'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/errhan'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/io'
rm -f .iotest.txt.*
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/io'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/rma'
rm -f summary.xml
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/rma'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/spawn'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx/spawn'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/cxx'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/threads'
rm -f summary.xml
for dir in util pt2pt comm init spawn ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/threads/util'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/threads/util'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/threads/pt2pt'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/threads/pt2pt'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/threads/comm'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/threads/comm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/threads/init'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/threads/init'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/threads/spawn'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/threads/spawn'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/threads'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors'
for dir in attr coll comm group pt2pt rma spawn topo io  f77 f90 cxx basic faults - ; do \
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/attr'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/attr'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/coll'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/coll'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/comm'
rm -f summary.xml
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/comm'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/group'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/group'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/pt2pt'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/pt2pt'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/rma'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/rma'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/spawn'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/spawn'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/topo'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/topo'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/io'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/io'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/f77'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/f77'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/f90'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/f90'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/cxx'
(cd io && make clean )
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/cxx/io'
rm -f summary.xml
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/cxx/io'
(cd errhan && make clean )
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/cxx/errhan'
rm -f summary.xml
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/cxx/errhan'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/cxx'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/basic'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/basic'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/faults'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors/faults'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/errors'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/manual'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/manual'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/perf'
rm -f summary.xml
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/perf'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpid'
(cd ch3 && make clean )
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpid/ch3'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpid/ch3'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpid'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/util'
(cd timer && make clean )
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/util/timer'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/util/timer'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/util'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/basic'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/basic'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/commands'
rm -f err.txt out.log out.txt stdintest stdintest2 sdtiotest a.out
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/commands'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test'
rm -f lib/newconfig
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
  CC     mplstr.lo
  CC     mpltrmem.lo
  CC     mplenv.lo
  CCLD   libmpl.la
libtool: link: warning: undefined symbols not allowed in i686-pc-cygwin shared libraries
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
Making all in src
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
make  all-am
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
/bin/sh ../libtool --tag=CC    --mode=compile gcc -DHAVE_CONFIG_H -I.       -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo opa_primitives.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c opa_primitives.c -o opa_primitives.o
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/bin/sh ../libtool --tag=CC    --mode=compile gcc -DHAVE_CONFIG_H -I.       -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c opa_queue.c -o opa_queue.o
mv -f .deps/opa_queue.Tpo .deps/opa_queue.Plo
/bin/sh ../libtool --tag=CC    --mode=link gcc    -version-info 1:0  -o libopa.la -rpath /usr/local/lib opa_primitives.lo opa_queue.lo  -lpthread
libtool: link: ar cru .libs/libopa.a  opa_primitives.o opa_queue.o
libtool: link: ranlib .libs/libopa.a
libtool: link: ( cd ".libs" && rm -f "libopa.la" && ln -s "../libopa.la" "libopa.la" )
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
Making all in test
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype/dataloop'
  CC              dataloop.c
  CC              segment.c
  CC              segment_packunpack.c
  CC              segment_flatten.c
  CC              segment_count.c
  CC              dataloop_create.c
  CC              dataloop_create_contig.c
  CC              dataloop_create_vector.c
  CC              dataloop_create_blockindexed.c
  CC              dataloop_create_indexed.c
  CC              dataloop_create_struct.c
  CC              dataloop_create_pairtype.c
  CC              subarray_support.c
  CC              darray_support.c
  AR cr ../../../../../lib/libmpich.a dataloop.o segment.o segment_packunpack.o segment_flatten.o segment_count.o dataloop_create.o dataloop_create_contig.o dataloop_create_vector.o dataloop_create_blockindexed.o dataloop_create_indexed.o dataloop_create_struct.o dataloop_create_pairtype.o subarray_support.o darray_support.o
  RANLIB          libmpich.a
date > .libstamp0
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype/dataloop'
make all-local
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype'
  CC              mpid_type_debug.c
  CC              mpid_segment.c
  CC              mpid_ext32_segment.c
  CC              mpid_ext32_datatype.c
  CC              mpid_type_dup.c
  CC              mpir_type_get_contig_blocks.c
  CC              mpir_type_flatten.c
  CC              mpid_type_commit.c
  CC              mpid_type_zerolen.c
  CC              mpid_type_vector.c
  CC              mpid_type_contiguous.c
  CC              mpid_type_create_resized.c
  CC              mpid_type_blockindexed.c
  CC              mpid_type_indexed.c
  CC              mpid_type_struct.c
  CC              mpid_type_get_envelope.c
  CC              mpid_datatype_free.c
  CC              mpid_datatype_contents.c
  CC              mpid_type_get_contents.c
  CC              mpid_type_create_pairtype.c
  CC              mpid_contents_support.c
  AR cr ../../../../lib/libmpich.a mpid_type_debug.o mpid_segment.o mpid_ext32_segment.o mpid_ext32_datatype.o mpid_type_dup.o mpir_type_get_contig_blocks.o mpir_type_flatten.o mpid_type_commit.o mpid_type_zerolen.o mpid_type_vector.o mpid_type_contiguous.o mpid_type_create_resized.o mpid_type_blockindexed.o mpid_type_indexed.o mpid_type_struct.o mpid_type_get_envelope.o mpid_datatype_free.o mpid_datatype_contents.o mpid_type_get_contents.o mpid_type_create_pairtype.o mpid_contents_support.o
  RANLIB          libmpich.a
date > .libstamp0
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/src'
  CC              mpid_nem_alloc.c
  CC              mpid_nem_init.c
  CC              mpid_nem_queue.c
  CC              mpid_nem_barrier.c
  CC              mpid_nem_mpich2.c
  CC              mpid_nem_ckpt.c
  CC              mpid_nem_finalize.c
  CC              mpid_nem_network_poll.c
  CC              mpid_nem_network.c
  CC              mpid_nem_debug.c
  CC              mpid_nem_lmt.c
  CC              mpid_nem_lmt_shm.c
  CC              mpid_nem_net_array.c
  CC              mpid_nem_lmt_dma.c
  CC              mpid_nem_lmt_vmsplice.c
  AR cr ../../../../../../../lib/libmpich.a mpid_nem_alloc.o mpid_nem_init.o mpid_nem_queue.o mpid_nem_barrier.o mpid_nem_mpich2.o mpid_nem_ckpt.o mpid_nem_finalize.o mpid_nem_network_poll.o mpid_nem_network.o mpid_nem_debug.o mpid_nem_lmt.o mpid_nem_lmt_shm.o mpid_nem_net_array.o mpid_nem_lmt_dma.o mpid_nem_lmt_vmsplice.o
  RANLIB          libmpich.a
date > .libstamp0
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/src'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[8]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
  CC              tcp_finalize.c
  CC              tcp_init.c
  CC              tcp_send.c
  CC              tcp_utility.c
  CC              socksm.c
  CC              tcp_getip.c
  CC              tcp_ckpt.c
  AR cr ../../../../../../../../lib/libmpich.a tcp_finalize.o tcp_init.o tcp_send.o tcp_utility.o socksm.o tcp_getip.o tcp_ckpt.o
  RANLIB          libmpich.a
date > .libstamp0
make[8]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[8]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
  CC              papi_defs.c
  AR cr ../../../../../../../../lib/libmpich.a papi_defs.o
  RANLIB          libmpich.a
date > .libstamp0
make[8]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
make[8]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
  CC              mkstemp.c
  AR cr ../../../../../../../../lib/libmpich.a mkstemp.o
  RANLIB          libmpich.a
date > .libstamp0
make[8]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/src'
  CC              ch3_finalize.c
  CC              ch3_init.c
  CC              ch3_isend.c
  CC              ch3_isendv.c
  CC              ch3_istartmsg.c
  CC              ch3_istartmsgv.c
  CC              ch3_progress.c
  CC              ch3_abort.c
  CC              ch3i_comm.c
  CC              ch3i_eagernoncontig.c
  AR cr ../../../../../../lib/libmpich.a ch3_finalize.o ch3_init.o ch3_isend.o ch3_isendv.o ch3_istartmsg.o ch3_istartmsgv.o ch3_progress.o ch3_abort.o ch3i_comm.o ch3i_eagernoncontig.o
  RANLIB          libmpich.a
date > .libstamp0
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/src'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/src'
  CC              ch3u_buffer.c
  CC              ch3u_comm_spawn_multiple.c
  CC              ch3u_handle_connection.c
  CC              ch3u_handle_recv_pkt.c
  CC              ch3u_handle_recv_req.c
  CC              ch3u_handle_send_req.c
  CC              ch3u_port.c
  CC              ch3u_recvq.c
  CC              ch3u_request.c
  CC              ch3u_rma_ops.c
  CC              ch3u_rma_sync.c
  CC              ch3u_rndv.c
  CC              ch3u_eager.c
  CC              ch3u_eagersync.c
  CC              mpid_abort.c
  CC              mpid_cancel_recv.c
  CC              mpid_cancel_send.c
  CC              mpid_comm_disconnect.c
  CC              mpid_comm_spawn_multiple.c
  CC              mpid_finalize.c
  CC              mpid_get_universe_size.c
  CC              mpid_getpname.c
  CC              mpid_init.c
  CC              mpid_iprobe.c
  CC              mpid_irecv.c
  CC              mpid_irsend.c
  CC              mpid_isend.c
  CC              mpid_issend.c
  CC              mpid_port.c
  CC              mpid_probe.c
  CC              mpid_recv.c
  CC              mpid_rsend.c
  CC              mpid_send.c
  CC              mpid_ssend.c
  CC              mpid_startall.c
  CC              mpid_vc.c
  CC              mpid_rma.c
  CC              mpidi_isend_self.c
  CC              mpidi_pg.c
  CC              mpidi_printf.c
  AR cr ../../../../lib/libmpich.a ch3u_buffer.o ch3u_comm_spawn_multiple.o ch3u_handle_connection.o ch3u_handle_recv_pkt.o ch3u_handle_recv_req.o ch3u_handle_send_req.o ch3u_port.o ch3u_recvq.o ch3u_request.o ch3u_rma_ops.o ch3u_rma_sync.o ch3u_rndv.o ch3u_eager.o ch3u_eagersync.o mpid_abort.o mpid_cancel_recv.o mpid_cancel_send.o mpid_comm_disconnect.o mpid_comm_spawn_multiple.o mpid_finalize.o mpid_get_universe_size.o mpid_getpname.o mpid_init.o mpid_iprobe.o mpid_irecv.o mpid_irsend.o mpid_isend.o mpid_issend.o mpid_port.o mpid_probe.o mpid_recv.o mpid_rsend.o mpid_send.o mpid_ssend.o mpid_startall.o mpid_vc.o mpid_rma.o mpidi_isend_self.o mpidi_pg.o mpidi_printf.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/src'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/util'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/util'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/attr'
  CC              attr_delete.c
  CC              attr_get.c
  CC              attr_put.c
  CC              comm_create_keyval.c
  CC              comm_delete_attr.c
  CC              comm_free_keyval.c
  CC              comm_get_attr.c
  CC              comm_set_attr.c
  CC              keyval_create.c
  CC              keyval_free.c
  CC              type_create_keyval.c
  CC              type_delete_attr.c
  CC              type_free_keyval.c
  CC              type_get_attr.c
  CC              type_set_attr.c
  CC              win_create_keyval.c
  CC              win_delete_attr.c
  CC              win_free_keyval.c
  CC              win_get_attr.c
  CC              win_set_attr.c
  CC              attrutil.c
  CC              dup_fn.c
  AR cr ../../../lib/libmpich.a attr_delete.o attr_get.o attr_put.o comm_create_keyval.o comm_delete_attr.o comm_free_keyval.o comm_get_attr.o comm_set_attr.o keyval_create.o keyval_free.o type_create_keyval.o type_delete_attr.o type_free_keyval.o type_get_attr.o type_set_attr.o win_create_keyval.o win_delete_attr.o win_free_keyval.o win_get_attr.o win_set_attr.o attrutil.o dup_fn.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/attr'
  CC             -D<profiling> ./attr_delete.c
  CC             -D<profiling> ./attr_get.c
  CC             -D<profiling> ./attr_put.c
  CC             -D<profiling> ./comm_create_keyval.c
  CC             -D<profiling> ./comm_delete_attr.c
  CC             -D<profiling> ./comm_free_keyval.c
  CC             -D<profiling> ./comm_get_attr.c
  CC             -D<profiling> ./comm_set_attr.c
  CC             -D<profiling> ./keyval_create.c
  CC             -D<profiling> ./keyval_free.c
  CC             -D<profiling> ./type_create_keyval.c
  CC             -D<profiling> ./type_delete_attr.c
  CC             -D<profiling> ./type_free_keyval.c
  CC             -D<profiling> ./type_get_attr.c
  CC             -D<profiling> ./type_set_attr.c
  CC             -D<profiling> ./win_create_keyval.c
  CC             -D<profiling> ./win_delete_attr.c
  CC             -D<profiling> ./win_free_keyval.c
  CC             -D<profiling> ./win_get_attr.c
  CC             -D<profiling> ./win_set_attr.c
  AR cr ../../../lib/libpmpich.a _attr_delete.o _attr_get.o _attr_put.o _comm_create_keyval.o _comm_delete_attr.o _comm_free_keyval.o _comm_get_attr.o _comm_set_attr.o _keyval_create.o _keyval_free.o _type_create_keyval.o _type_delete_attr.o _type_free_keyval.o _type_get_attr.o _type_set_attr.o _win_create_keyval.o _win_delete_attr.o _win_free_keyval.o _win_get_attr.o _win_set_attr.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/attr'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/attr'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/coll'
  CC              allreduce.c
  CC              barrier.c
  CC              op_create.c
  CC              op_free.c
  CC              bcast.c
  CC              alltoall.c
  CC              alltoallv.c
  CC              reduce.c
  CC              scatter.c
  CC              gather.c
  CC              scatterv.c
  CC              gatherv.c
  CC              scan.c
  CC              exscan.c
  CC              allgather.c
  CC              allgatherv.c
  CC              red_scat.c
  CC              alltoallw.c
  CC              reduce_local.c
  CC              op_commutative.c
  CC              red_scat_block.c
  CC              helper_fns.c
  CC              opsum.c
  CC              opmax.c
  CC              opmin.c
  CC              opband.c
  CC              opbor.c
  CC              opbxor.c
  CC              opland.c
  CC              oplor.c
  CC              oplxor.c
  CC              opprod.c
  CC              opminloc.c
  CC              opmaxloc.c
  AR cr ../../../lib/libmpich.a allreduce.o barrier.o op_create.o op_free.o bcast.o alltoall.o alltoallv.o reduce.o scatter.o gather.o scatterv.o gatherv.o scan.o exscan.o allgather.o allgatherv.o red_scat.o alltoallw.o reduce_local.o op_commutative.o red_scat_block.o helper_fns.o opsum.o opmax.o opmin.o opband.o opbor.o opbxor.o opland.o oplor.o oplxor.o opprod.o opminloc.o opmaxloc.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/coll'
  CC             -D<profiling> ./allreduce.c
  CC             -D<profiling> ./barrier.c
  CC             -D<profiling> ./op_create.c
  CC             -D<profiling> ./op_free.c
  CC             -D<profiling> ./bcast.c
  CC             -D<profiling> ./alltoall.c
  CC             -D<profiling> ./alltoallv.c
  CC             -D<profiling> ./reduce.c
  CC             -D<profiling> ./scatter.c
  CC             -D<profiling> ./gather.c
  CC             -D<profiling> ./scatterv.c
  CC             -D<profiling> ./gatherv.c
  CC             -D<profiling> ./scan.c
  CC             -D<profiling> ./exscan.c
  CC             -D<profiling> ./allgather.c
  CC             -D<profiling> ./allgatherv.c
  CC             -D<profiling> ./red_scat.c
  CC             -D<profiling> ./alltoallw.c
  CC             -D<profiling> ./reduce_local.c
  CC             -D<profiling> ./op_commutative.c
  CC             -D<profiling> ./red_scat_block.c
  AR cr ../../../lib/libpmpich.a _allreduce.o _barrier.o _op_create.o _op_free.o _bcast.o _alltoall.o _alltoallv.o _reduce.o _scatter.o _gather.o _scatterv.o _gatherv.o _scan.o _exscan.o _allgather.o _allgatherv.o _red_scat.o _alltoallw.o _reduce_local.o _op_commutative.o _red_scat_block.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/coll'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/coll'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/comm'
  CC              comm_compare.c
  CC              comm_create.c
  CC              comm_dup.c
  CC              comm_free.c
  CC              comm_get_name.c
  CC              comm_group.c
  CC              comm_rank.c
  CC              comm_size.c
  CC              comm_remote_group.c
  CC              comm_remote_size.c
  CC              comm_set_name.c
  CC              comm_split.c
  CC              comm_test_inter.c
  CC              intercomm_create.c
  CC              intercomm_merge.c
  CC              commutil.c
  AR cr ../../../lib/libmpich.a comm_compare.o comm_create.o comm_dup.o comm_free.o comm_get_name.o comm_group.o comm_rank.o comm_size.o comm_remote_group.o comm_remote_size.o comm_set_name.o comm_split.o comm_test_inter.o intercomm_create.o intercomm_merge.o commutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/comm'
  CC             -D<profiling> ./comm_compare.c
  CC             -D<profiling> ./comm_create.c
  CC             -D<profiling> ./comm_dup.c
  CC             -D<profiling> ./comm_free.c
  CC             -D<profiling> ./comm_get_name.c
  CC             -D<profiling> ./comm_group.c
  CC             -D<profiling> ./comm_rank.c
  CC             -D<profiling> ./comm_size.c
  CC             -D<profiling> ./comm_remote_group.c
  CC             -D<profiling> ./comm_remote_size.c
  CC             -D<profiling> ./comm_set_name.c
  CC             -D<profiling> ./comm_split.c
  CC             -D<profiling> ./comm_test_inter.c
  CC             -D<profiling> ./intercomm_create.c
  CC             -D<profiling> ./intercomm_merge.c
  AR cr ../../../lib/libpmpich.a _comm_compare.o _comm_create.o _comm_dup.o _comm_free.o _comm_get_name.o _comm_group.o _comm_rank.o _comm_size.o _comm_remote_group.o _comm_remote_size.o _comm_set_name.o _comm_split.o _comm_test_inter.o _intercomm_create.o _intercomm_merge.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/comm'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/comm'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/datatype'
  CC              address.c
  CC              get_address.c
  CC              get_count.c
  CC              get_elements.c
  CC              pack.c
  CC              unpack.c
  CC              pack_size.c
  CC              status_set_elements.c
  CC              type_get_name.c
  CC              type_set_name.c
  CC              type_size.c
  CC              type_extent.c
  CC              type_vector.c
  CC              type_commit.c
  CC              type_indexed.c
  CC              type_hindexed.c
  CC              type_struct.c
  CC              type_contiguous.c
  CC              type_free.c
  CC              type_hvector.c
  CC              type_dup.c
  CC              type_get_envelope.c
  CC              type_get_contents.c
  CC              type_ub.c
  CC              type_lb.c
  CC              type_get_extent.c
  CC              type_get_true_extent.c
  CC              type_match_size.c
  CC              type_create_struct.c
  CC              type_create_hindexed.c
  CC              type_create_hvector.c
  CC              pack_external.c
  CC              pack_external_size.c
  CC              unpack_external.c
  CC              type_create_indexed_block.c
  CC              type_create_resized.c
  CC              type_create_darray.c
  CC              type_create_subarray.c
  CC              typeutil.c
  AR cr ../../../lib/libmpich.a address.o get_address.o get_count.o get_elements.o pack.o unpack.o pack_size.o status_set_elements.o type_get_name.o type_set_name.o type_size.o type_extent.o type_vector.o type_commit.o type_indexed.o type_hindexed.o type_struct.o type_contiguous.o type_free.o type_hvector.o type_dup.o type_get_envelope.o type_get_contents.o type_ub.o type_lb.o type_get_extent.o type_get_true_extent.o type_match_size.o type_create_struct.o type_create_hindexed.o type_create_hvector.o pack_external.o pack_external_size.o unpack_external.o type_create_indexed_block.o type_create_resized.o type_create_darray.o type_create_subarray.o typeutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/datatype'
  CC             -D<profiling> ./address.c
  CC             -D<profiling> ./get_address.c
  CC             -D<profiling> ./get_count.c
  CC             -D<profiling> ./get_elements.c
  CC             -D<profiling> ./pack.c
  CC             -D<profiling> ./unpack.c
  CC             -D<profiling> ./pack_size.c
  CC             -D<profiling> ./status_set_elements.c
  CC             -D<profiling> ./type_get_name.c
  CC             -D<profiling> ./type_set_name.c
  CC             -D<profiling> ./type_size.c
  CC             -D<profiling> ./type_extent.c
  CC             -D<profiling> ./type_vector.c
  CC             -D<profiling> ./type_commit.c
  CC             -D<profiling> ./type_indexed.c
  CC             -D<profiling> ./type_hindexed.c
  CC             -D<profiling> ./type_struct.c
  CC             -D<profiling> ./type_contiguous.c
  CC             -D<profiling> ./type_free.c
  CC             -D<profiling> ./type_hvector.c
  CC             -D<profiling> ./type_dup.c
  CC             -D<profiling> ./type_get_envelope.c
  CC             -D<profiling> ./type_get_contents.c
  CC             -D<profiling> ./type_ub.c
  CC             -D<profiling> ./type_lb.c
  CC             -D<profiling> ./type_get_extent.c
  CC             -D<profiling> ./type_get_true_extent.c
  CC             -D<profiling> ./type_match_size.c
  CC             -D<profiling> ./type_create_struct.c
  CC             -D<profiling> ./type_create_hindexed.c
  CC             -D<profiling> ./type_create_hvector.c
  CC             -D<profiling> ./pack_external.c
  CC             -D<profiling> ./pack_external_size.c
  CC             -D<profiling> ./unpack_external.c
  CC             -D<profiling> ./type_create_indexed_block.c
  CC             -D<profiling> ./type_create_resized.c
  CC             -D<profiling> ./type_create_darray.c
  CC             -D<profiling> ./type_create_subarray.c
  AR cr ../../../lib/libpmpich.a _address.o _get_address.o _get_count.o _get_elements.o _pack.o _unpack.o _pack_size.o _status_set_elements.o _type_get_name.o _type_set_name.o _type_size.o _type_extent.o _type_vector.o _type_commit.o _type_indexed.o _type_hindexed.o _type_struct.o _type_contiguous.o _type_free.o _type_hvector.o _type_dup.o _type_get_envelope.o _type_get_contents.o _type_ub.o _type_lb.o _type_get_extent.o _type_get_true_extent.o _type_match_size.o _type_create_struct.o _type_create_hindexed.o _type_create_hvector.o _pack_external.o _pack_external_size.o _unpack_external.o _type_create_indexed_block.o _type_create_resized.o _type_create_darray.o _type_create_subarray.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/datatype'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/datatype'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/errhan'
  CC              add_error_code.c
  CC              add_error_class.c
  CC              add_error_string.c
  CC              comm_call_errhandler.c
  CC              comm_create_errhandler.c
  CC              comm_get_errhandler.c
  CC              comm_set_errhandler.c
  CC              errhandler_create.c
  CC              errhandler_free.c
  CC              errhandler_get.c
  CC              errhandler_set.c
  CC              error_class.c
  CC              error_string.c
  CC              file_create_errhandler.c
  CC              file_get_errhandler.c
  CC              file_set_errhandler.c
  CC              file_call_errhandler.c
  CC              win_create_errhandler.c
  CC              win_call_errhandler.c
  CC              win_get_errhandler.c
  CC              win_set_errhandler.c
  CC              errutil.c
  CC              dynerrutil.c
  AR cr ../../../lib/libmpich.a add_error_code.o add_error_class.o add_error_string.o comm_call_errhandler.o comm_create_errhandler.o comm_get_errhandler.o comm_set_errhandler.o errhandler_create.o errhandler_free.o errhandler_get.o errhandler_set.o error_class.o error_string.o file_create_errhandler.o file_get_errhandler.o file_set_errhandler.o file_call_errhandler.o win_create_errhandler.o win_call_errhandler.o win_get_errhandler.o win_set_errhandler.o errutil.o dynerrutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/errhan'
  CC             -D<profiling> ./add_error_code.c
  CC             -D<profiling> ./add_error_class.c
  CC             -D<profiling> ./add_error_string.c
  CC             -D<profiling> ./comm_call_errhandler.c
  CC             -D<profiling> ./comm_create_errhandler.c
  CC             -D<profiling> ./comm_get_errhandler.c
  CC             -D<profiling> ./comm_set_errhandler.c
  CC             -D<profiling> ./errhandler_create.c
  CC             -D<profiling> ./errhandler_free.c
  CC             -D<profiling> ./errhandler_get.c
  CC             -D<profiling> ./errhandler_set.c
  CC             -D<profiling> ./error_class.c
  CC             -D<profiling> ./error_string.c
  CC             -D<profiling> ./file_create_errhandler.c
  CC             -D<profiling> ./file_get_errhandler.c
  CC             -D<profiling> ./file_set_errhandler.c
  CC             -D<profiling> ./file_call_errhandler.c
  CC             -D<profiling> ./win_create_errhandler.c
  CC             -D<profiling> ./win_call_errhandler.c
  CC             -D<profiling> ./win_get_errhandler.c
  CC             -D<profiling> ./win_set_errhandler.c
  AR cr ../../../lib/libpmpich.a _add_error_code.o _add_error_class.o _add_error_string.o _comm_call_errhandler.o _comm_create_errhandler.o _comm_get_errhandler.o _comm_set_errhandler.o _errhandler_create.o _errhandler_free.o _errhandler_get.o _errhandler_set.o _error_class.o _error_string.o _file_create_errhandler.o _file_get_errhandler.o _file_set_errhandler.o _file_call_errhandler.o _win_create_errhandler.o _win_call_errhandler.o _win_get_errhandler.o _win_set_errhandler.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/errhan'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/errhan'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/group'
  CC              group_compare.c
  CC              group_difference.c
  CC              group_excl.c
  CC              group_free.c
  CC              group_incl.c
  CC              group_intersection.c
  CC              group_range_excl.c
  CC              group_range_incl.c
  CC              group_rank.c
  CC              group_size.c
  CC              group_translate_ranks.c
  CC              group_union.c
  CC              grouputil.c
  AR cr ../../../lib/libmpich.a group_compare.o group_difference.o group_excl.o group_free.o group_incl.o group_intersection.o group_range_excl.o group_range_incl.o group_rank.o group_size.o group_translate_ranks.o group_union.o grouputil.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/group'
  CC             -D<profiling> ./group_compare.c
  CC             -D<profiling> ./group_difference.c
  CC             -D<profiling> ./group_excl.c
  CC             -D<profiling> ./group_free.c
  CC             -D<profiling> ./group_incl.c
  CC             -D<profiling> ./group_intersection.c
  CC             -D<profiling> ./group_range_excl.c
  CC             -D<profiling> ./group_range_incl.c
  CC             -D<profiling> ./group_rank.c
  CC             -D<profiling> ./group_size.c
  CC             -D<profiling> ./group_translate_ranks.c
  CC             -D<profiling> ./group_union.c
  AR cr ../../../lib/libpmpich.a _group_compare.o _group_difference.o _group_excl.o _group_free.o _group_incl.o _group_intersection.o _group_range_excl.o _group_range_incl.o _group_rank.o _group_size.o _group_translate_ranks.o _group_union.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/group'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/group'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/init'
  CC              abort.c
  CC              init.c
  CC              initialized.c
  CC              initthread.c
  CC              ismain.c
  CC              finalize.c
  CC              finalized.c
  CC              querythread.c
  CC              initinfo.c
  CC              async.c
  AR cr ../../../lib/libmpich.a abort.o init.o initialized.o initthread.o ismain.o finalize.o finalized.o querythread.o initinfo.o async.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/init'
  CC             -D<profiling> ./abort.c
  CC             -D<profiling> ./init.c
  CC             -D<profiling> ./initialized.c
  CC             -D<profiling> ./initthread.c
  CC             -D<profiling> ./ismain.c
  CC             -D<profiling> ./finalize.c
  CC             -D<profiling> ./finalized.c
  CC             -D<profiling> ./querythread.c
  AR cr ../../../lib/libpmpich.a _abort.o _init.o _initialized.o _initthread.o _ismain.o _finalize.o _finalized.o _querythread.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/init'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/init'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/misc'
  CC              getpname.c
  CC              pcontrol.c
  CC              version.c
  AR cr ../../../lib/libmpich.a getpname.o pcontrol.o version.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/misc'
  CC             -D<profiling> ./getpname.c
  CC             -D<profiling> ./pcontrol.c
  CC             -D<profiling> ./version.c
  AR cr ../../../lib/libpmpich.a _getpname.o _pcontrol.o _version.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/misc'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/misc'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/pt2pt'
  CC              bsend.c
  CC              bsend_init.c
  CC              bufattach.c
  CC              buffree.c
  CC              cancel.c
  CC              greq_start.c
  CC              greq_complete.c
  CC              ibsend.c
  CC              iprobe.c
  CC              irecv.c
  CC              irsend.c
  CC              isend.c
  CC              issend.c
  CC              probe.c
  CC              recv.c
  CC              recv_init.c
  CC              request_free.c
  CC              request_get_status.c
  CC              rsend.c
  CC              rsend_init.c
  CC              send.c
  CC              send_init.c
  CC              sendrecv.c
  CC              sendrecv_rep.c
  CC              status_set_cancelled.c
  CC              ssend.c
  CC              ssend_init.c
  CC              start.c
  CC              startall.c
  CC              test.c
  CC              test_cancelled.c
  CC              testall.c
  CC              testany.c
  CC              testsome.c
  CC              wait.c
  CC              waitall.c
  CC              waitany.c
  CC              waitsome.c
  CC              bsendutil.c
  CC              mpir_request.c
  AR cr ../../../lib/libmpich.a bsend.o bsend_init.o bufattach.o buffree.o cancel.o greq_start.o greq_complete.o ibsend.o iprobe.o irecv.o irsend.o isend.o issend.o probe.o recv.o recv_init.o request_free.o request_get_status.o rsend.o rsend_init.o send.o send_init.o sendrecv.o sendrecv_rep.o status_set_cancelled.o ssend.o ssend_init.o start.o startall.o test.o test_cancelled.o testall.o testany.o testsome.o wait.o waitall.o waitany.o waitsome.o bsendutil.o mpir_request.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/pt2pt'
  CC             -D<profiling> ./bsend.c
  CC             -D<profiling> ./bsend_init.c
  CC             -D<profiling> ./bufattach.c
  CC             -D<profiling> ./buffree.c
  CC             -D<profiling> ./cancel.c
  CC             -D<profiling> ./greq_start.c
  CC             -D<profiling> ./greq_complete.c
  CC             -D<profiling> ./ibsend.c
  CC             -D<profiling> ./iprobe.c
  CC             -D<profiling> ./irecv.c
  CC             -D<profiling> ./irsend.c
  CC             -D<profiling> ./isend.c
  CC             -D<profiling> ./issend.c
  CC             -D<profiling> ./probe.c
  CC             -D<profiling> ./recv.c
  CC             -D<profiling> ./recv_init.c
  CC             -D<profiling> ./request_free.c
  CC             -D<profiling> ./request_get_status.c
  CC             -D<profiling> ./rsend.c
  CC             -D<profiling> ./rsend_init.c
  CC             -D<profiling> ./send.c
  CC             -D<profiling> ./send_init.c
  CC             -D<profiling> ./sendrecv.c
  CC             -D<profiling> ./sendrecv_rep.c
  CC             -D<profiling> ./status_set_cancelled.c
  CC             -D<profiling> ./ssend.c
  CC             -D<profiling> ./ssend_init.c
  CC             -D<profiling> ./start.c
  CC             -D<profiling> ./startall.c
  CC             -D<profiling> ./test.c
  CC             -D<profiling> ./test_cancelled.c
  CC             -D<profiling> ./testall.c
  CC             -D<profiling> ./testany.c
  CC             -D<profiling> ./testsome.c
  CC             -D<profiling> ./wait.c
  CC             -D<profiling> ./waitall.c
  CC             -D<profiling> ./waitany.c
  CC             -D<profiling> ./waitsome.c
  AR cr ../../../lib/libpmpich.a _bsend.o _bsend_init.o _bufattach.o _buffree.o _cancel.o _greq_start.o _greq_complete.o _ibsend.o _iprobe.o _irecv.o _irsend.o _isend.o _issend.o _probe.o _recv.o _recv_init.o _request_free.o _request_get_status.o _rsend.o _rsend_init.o _send.o _send_init.o _sendrecv.o _sendrecv_rep.o _status_set_cancelled.o _ssend.o _ssend_init.o _start.o _startall.o _test.o _test_cancelled.o _testall.o _testany.o _testsome.o _wait.o _waitall.o _waitany.o _waitsome.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/pt2pt'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/pt2pt'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/rma'
  CC              accumulate.c
  CC              alloc_mem.c
  CC              free_mem.c
  CC              get.c
  CC              put.c
  CC              win_complete.c
  CC              win_create.c
  CC              win_fence.c
  CC              win_free.c
  CC              win_get_group.c
  CC              win_get_name.c
  CC              win_lock.c
  CC              win_post.c
  CC              win_set_name.c
  CC              win_start.c
  CC              win_unlock.c
  CC              win_wait.c
  CC              win_test.c
  CC              winutil.c
  AR cr ../../../lib/libmpich.a accumulate.o alloc_mem.o free_mem.o get.o put.o win_complete.o win_create.o win_fence.o win_free.o win_get_group.o win_get_name.o win_lock.o win_post.o win_set_name.o win_start.o win_unlock.o win_wait.o win_test.o winutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/rma'
  CC             -D<profiling> ./accumulate.c
  CC             -D<profiling> ./alloc_mem.c
  CC             -D<profiling> ./free_mem.c
  CC             -D<profiling> ./get.c
  CC             -D<profiling> ./put.c
  CC             -D<profiling> ./win_complete.c
  CC             -D<profiling> ./win_create.c
  CC             -D<profiling> ./win_fence.c
  CC             -D<profiling> ./win_free.c
  CC             -D<profiling> ./win_get_group.c
  CC             -D<profiling> ./win_get_name.c
  CC             -D<profiling> ./win_lock.c
  CC             -D<profiling> ./win_post.c
  CC             -D<profiling> ./win_set_name.c
  CC             -D<profiling> ./win_start.c
  CC             -D<profiling> ./win_unlock.c
  CC             -D<profiling> ./win_wait.c
  CC             -D<profiling> ./win_test.c
  AR cr ../../../lib/libpmpich.a _accumulate.o _alloc_mem.o _free_mem.o _get.o _put.o _win_complete.o _win_create.o _win_fence.o _win_free.o _win_get_group.o _win_get_name.o _win_lock.o _win_post.o _win_set_name.o _win_start.o _win_unlock.o _win_wait.o _win_test.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/rma'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/rma'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/spawn'
  CC              comm_disconnect.c
  CC              comm_get_parent.c
  CC              comm_join.c
  CC              comm_spawn.c
  CC              comm_spawn_multiple.c
  CC              lookup_name.c
  CC              publish_name.c
  CC              unpublish_name.c
  CC              open_port.c
  CC              close_port.c
  CC              comm_connect.c
  CC              comm_accept.c
  AR cr ../../../lib/libmpich.a comm_disconnect.o comm_get_parent.o comm_join.o comm_spawn.o comm_spawn_multiple.o lookup_name.o publish_name.o unpublish_name.o open_port.o close_port.o comm_connect.o comm_accept.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/spawn'
  CC             -D<profiling> ./comm_disconnect.c
  CC             -D<profiling> ./comm_get_parent.c
  CC             -D<profiling> ./comm_join.c
  CC             -D<profiling> ./comm_spawn.c
  CC             -D<profiling> ./comm_spawn_multiple.c
  CC             -D<profiling> ./lookup_name.c
  CC             -D<profiling> ./publish_name.c
  CC             -D<profiling> ./unpublish_name.c
  CC             -D<profiling> ./open_port.c
  CC             -D<profiling> ./close_port.c
  CC             -D<profiling> ./comm_connect.c
  CC             -D<profiling> ./comm_accept.c
  AR cr ../../../lib/libpmpich.a _comm_disconnect.o _comm_get_parent.o _comm_join.o _comm_spawn.o _comm_spawn_multiple.o _lookup_name.o _publish_name.o _unpublish_name.o _open_port.o _close_port.o _comm_connect.o _comm_accept.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/spawn'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/spawn'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/timer'
  CC              wtime.c
  CC              wtick.c
  CC              mpidtime.c
  AR cr ../../../lib/libmpich.a wtime.o wtick.o mpidtime.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/timer'
  CC             -D<profiling> ./wtime.c
  CC             -D<profiling> ./wtick.c
  AR cr ../../../lib/libpmpich.a _wtime.o _wtick.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/timer'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/timer'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/topo'
  CC              cart_coords.c
  CC              cart_create.c
  CC              cart_get.c
  CC              cart_map.c
  CC              cart_rank.c
  CC              cart_shift.c
  CC              cart_sub.c
  CC              dims_create.c
  CC              graph_get.c
  CC              graph_map.c
  CC              graph_nbr.c
  CC              graphcreate.c
  CC              graphdimsget.c
  CC              graphnbrcnt.c
  CC              cartdim_get.c
  CC              topo_test.c
  CC              dist_gr_create_adj.c
  CC              dist_gr_create.c
  CC              dist_gr_neighb_count.c
  CC              dist_gr_neighb.c
  CC              topoutil.c
  AR cr ../../../lib/libmpich.a cart_coords.o cart_create.o cart_get.o cart_map.o cart_rank.o cart_shift.o cart_sub.o dims_create.o graph_get.o graph_map.o graph_nbr.o graphcreate.o graphdimsget.o graphnbrcnt.o cartdim_get.o topo_test.o dist_gr_create_adj.o dist_gr_create.o dist_gr_neighb_count.o dist_gr_neighb.o topoutil.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/topo'
  CC             -D<profiling> ./cart_coords.c
  CC             -D<profiling> ./cart_create.c
  CC             -D<profiling> ./cart_get.c
  CC             -D<profiling> ./cart_map.c
  CC             -D<profiling> ./cart_rank.c
  CC             -D<profiling> ./cart_shift.c
  CC             -D<profiling> ./cart_sub.c
  CC             -D<profiling> ./dims_create.c
  CC             -D<profiling> ./graph_get.c
  CC             -D<profiling> ./graph_map.c
  CC             -D<profiling> ./graph_nbr.c
  CC             -D<profiling> ./graphcreate.c
  CC             -D<profiling> ./graphdimsget.c
  CC             -D<profiling> ./graphnbrcnt.c
  CC             -D<profiling> ./cartdim_get.c
  CC             -D<profiling> ./topo_test.c
  CC             -D<profiling> ./dist_gr_create_adj.c
  CC             -D<profiling> ./dist_gr_create.c
  CC             -D<profiling> ./dist_gr_neighb_count.c
  CC             -D<profiling> ./dist_gr_neighb.c
  AR cr ../../../lib/libpmpich.a _cart_coords.o _cart_create.o _cart_get.o _cart_map.o _cart_rank.o _cart_shift.o _cart_sub.o _dims_create.o _graph_get.o _graph_map.o _graph_nbr.o _graphcreate.o _graphdimsget.o _graphnbrcnt.o _cartdim_get.o _topo_test.o _dist_gr_create_adj.o _dist_gr_create.o _dist_gr_neighb_count.o _dist_gr_neighb.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/topo'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/topo'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio'
make mpiolib
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio'
compiling ROMIO in directory mpi-io
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io'
  CC              close.c
  CC              read.c
  CC              open.c
  CC              write.c
  CC              set_view.c
  CC              iread.c
  CC              iwrite.c
  CC              seek.c
  CC              get_posn.c
  CC              delete.c
  CC              read_all.c
  CC              read_at.c
  CC              read_atall.c
  CC              iread_at.c
  CC              iwrite_at.c
  CC              write_all.c
  CC              get_bytoff.c
  CC              write_at.c
  CC              write_atall.c
  CC              get_view.c
  CC              get_group.c
  CC              get_amode.c
  CC              get_extent.c
  CC              fsync.c
  CC              get_atom.c
  CC              set_atom.c
  CC              set_size.c
  CC              get_size.c
  CC              prealloc.c
  CC              file_f2c.c
  CC              file_c2f.c
  CC              set_info.c
  CC              get_info.c
  CC              rd_atallb.c
  CC              rd_atalle.c
  CC              read_allb.c
  CC              read_alle.c
  CC              wr_atallb.c
  CC              wr_atalle.c
  CC              write_allb.c
  CC              write_alle.c
  CC              get_posn_sh.c
  CC              iread_sh.c
  CC              read_sh.c
  CC              write_sh.c
  CC              iwrite_sh.c
  CC              seek_sh.c
  CC              read_ord.c
  CC              read_orde.c
  CC              write_ordb.c
  CC              read_ordb.c
  CC              write_ord.c
  CC              write_orde.c
  CC              mpiu_greq.c
  CC              mpich2_fileutil.c
  CC              register_datarep.c
  CC              mpir-mpioinit.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/lib/libmpich.a close.o read.o open.o write.o set_view.o  iread.o iwrite.o  seek.o get_posn.o  delete.o read_all.o read_at.o  read_atall.o iread_at.o iwrite_at.o write_all.o get_bytoff.o  write_at.o write_atall.o get_view.o get_group.o get_amode.o  get_extent.o fsync.o get_atom.o set_atom.o  set_size.o get_size.o prealloc.o file_f2c.o file_c2f.o  set_info.o get_info.o  rd_atallb.o rd_atalle.o read_allb.o read_alle.o wr_atallb.o  wr_atalle.o write_allb.o write_alle.o  get_posn_sh.o iread_sh.o read_sh.o write_sh.o  iwrite_sh.o seek_sh.o read_ord.o read_orde.o write_ordb.o  read_ordb.o write_ord.o write_orde.o mpiu_greq.o mpich2_fileutil.o  register_datarep.o mpir-mpioinit.o
ranlib /cygdrive/c/cygwin/mpich2-1.4/lib/libmpich.a
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io'
compiling ROMIO in directory adio/common
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/common'
  CC              ad_close.c
  CC              ad_init.c
  CC              ad_end.c
  CC              ad_open.c
  CC              flatten.c
  CC              malloc.c
  CC              ad_read_coll.c
  CC              eof_offset.c
  CC              ad_write_coll.c
  CC              lock.c
  CC              ad_read_str.c
  CC              ad_write_str.c
  CC              iscontig.c
  CC              get_fp_posn.c
  CC              ad_seek.c
  CC              ad_delete.c
  CC              ad_flush.c
  CC              ad_hints.c
  CC              error.c
  CC              ad_fstype.c
  CC              ad_get_sh_fp.c
  CC              ad_set_sh_fp.c
  CC              shfp_fname.c
  CC              byte_offset.c
  CC              status_setb.c
  CC              ad_aggregate.c
  CC              cb_config_list.c
  CC              ad_read_str_naive.c
  CC              ad_set_view.c
  CC              ad_iopen.c
  CC              ad_write_str_naive.c
  CC              ad_resize.c
  CC              ad_read.c
  CC              ad_write.c
  CC              ad_iread.c
  CC              ad_iwrite.c
  CC              ad_done.c
  CC              ad_wait.c
  CC              adi_close.c
  CC              ad_prealloc.c
  CC              ad_fcntl.c
  CC              ad_iread_fake.c
  CC              ad_iwrite_fake.c
  CC              ad_done_fake.c
  CC              ad_wait_fake.c
  CC              ad_subarray.c
  CC              ad_darray.c
  CC              strfns.c
  CC              greq_fns.c
  CC              system_hints.c
  CC              ad_write_nolock.c
  CC              ad_coll_exch_new.c
  CC              ad_coll_build_req_new.c
  CC              ad_io_coll.c
  CC              ad_aggregate_new.c
  CC              heap-sort.c
  CC              ad_opencoll.c
  CC              ad_opencoll_scalable.c
  CC              ad_opencoll_failsafe.c
  CC              ad_features.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/lib/libmpich.a ad_close.o ad_init.o ad_end.o ad_open.o flatten.o  malloc.o ad_read_coll.o eof_offset.o  ad_write_coll.o lock.o ad_read_str.o ad_write_str.o iscontig.o  get_fp_posn.o ad_seek.o ad_delete.o ad_flush.o ad_hints.o error.o  ad_fstype.o ad_get_sh_fp.o ad_set_sh_fp.o shfp_fname.o byte_offset.o  status_setb.o ad_aggregate.o cb_config_list.o  ad_read_str_naive.o ad_set_view.o ad_iopen.o  ad_write_str_naive.o ad_resize.o ad_read.o ad_write.o ad_iread.o  ad_iwrite.o ad_done.o ad_wait.o adi_close.o ad_prealloc.o ad_fcntl.o  ad_iread_fake.o ad_iwrite_fake.o ad_done_fake.o ad_wait_fake.o  ad_subarray.o ad_darray.o strfns.o greq_fns.o system_hints.o  ad_write_nolock.o  ad_coll_exch_new.o ad_coll_build_req_new.o ad_io_coll.o  ad_aggregate_new.o heap-sort.o  ad_opencoll.o ad_opencoll_scalable.o ad_opencoll_failsafe.o ad_features.o
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/common'
compiling ROMIO in directory mpi-io/glue/mpich2
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/glue/mpich2'
  CC              mpio_file.c
  CC              mpio_err.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/lib/libmpich.a mpio_file.o mpio_err.o
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/glue/mpich2'
compiling ROMIO in directory adio/ad_testfs
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/ad_testfs'
  CC              ad_testfs_close.c
  CC              ad_testfs_read.c
  CC              ad_testfs_rdcoll.c
  CC              ad_testfs_wrcoll.c
  CC              ad_testfs_open.c
  CC              ad_testfs_write.c
  CC              ad_testfs_done.c
  CC              ad_testfs_fcntl.c
  CC              ad_testfs_iread.c
  CC              ad_testfs_iwrite.c
  CC              ad_testfs_wait.c
  CC              ad_testfs_flush.c
  CC              ad_testfs_seek.c
  CC              ad_testfs_resize.c
  CC              ad_testfs_hints.c
  CC              ad_testfs_delete.c
  CC              ad_testfs.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/lib/libmpich.a ad_testfs_close.o ad_testfs_read.o ad_testfs_rdcoll.o  ad_testfs_wrcoll.o ad_testfs_open.o ad_testfs_write.o  ad_testfs_done.o ad_testfs_fcntl.o ad_testfs_iread.o  ad_testfs_iwrite.o ad_testfs_wait.o ad_testfs_flush.o  ad_testfs_seek.o ad_testfs_resize.o ad_testfs_hints.o  ad_testfs_delete.o ad_testfs.o
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/ad_testfs'
compiling ROMIO in directory adio/ad_ufs
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/ad_ufs'
  CC              ad_ufs_open.c
  CC              ad_ufs.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/lib/libmpich.a ad_ufs_open.o ad_ufs.o
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/ad_ufs'
compiling ROMIO in directory adio/ad_nfs
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/ad_nfs'
  CC              ad_nfs_read.c
  CC              ad_nfs_open.c
  CC              ad_nfs_write.c
  CC              ad_nfs_done.c
  CC              ad_nfs_fcntl.c
  CC              ad_nfs_iread.c
  CC              ad_nfs_iwrite.c
  CC              ad_nfs_wait.c
  CC              ad_nfs_setsh.c
  CC              ad_nfs_getsh.c
  CC              ad_nfs.c
  CC              ad_nfs_resize.c
  CC              ad_nfs_features.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/lib/libmpich.a ad_nfs_read.o  ad_nfs_open.o ad_nfs_write.o ad_nfs_done.o  ad_nfs_fcntl.o ad_nfs_iread.o ad_nfs_iwrite.o ad_nfs_wait.o  ad_nfs_setsh.o ad_nfs_getsh.o ad_nfs.o ad_nfs_resize.o ad_nfs_features.o
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/ad_nfs'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio'
building profiling interface in directory mpi-io
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/close.c -o _close.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/read.c -o _read.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/open.c -o _open.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/get_extent.c -o _get_extent.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/write.c -o _write.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/set_view.c -o _set_view.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/seek.c -o _seek.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/read_at.c -o _read_at.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/prealloc.c -o _prealloc.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/iread.c -o _iread.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/iwrite.c -o _iwrite.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/get_posn.c -o _get_posn.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/delete.c -o _delete.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/read_all.c -o _read_all.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/get_bytoff.c -o _get_bytoff.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/read_atall.c -o _read_atall.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/iread_at.c -o _iread_at.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/iwrite_at.c -o _iwrite_at.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/get_group.c -o _get_group.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/get_amode.c -o _get_amode.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/write_all.c -o _write_all.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/write_at.c -o _write_at.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/write_atall.c -o _write_atall.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/get_view.c -o _get_view.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/fsync.c -o _fsync.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/get_atom.c -o _get_atom.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/set_atom.c -o _set_atom.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/set_size.c -o _set_size.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/get_size.c -o _get_size.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/file_f2c.c -o _file_f2c.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/file_c2f.c -o _file_c2f.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/set_info.c -o _set_info.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/get_info.c -o _get_info.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/rd_atallb.c -o _rd_atallb.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/rd_atalle.c -o _rd_atalle.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/read_allb.c -o _read_allb.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/read_alle.c -o _read_alle.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/wr_atallb.c -o _wr_atallb.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/wr_atalle.c -o _wr_atalle.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/write_allb.c -o _write_allb.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/write_alle.c -o _write_alle.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/get_posn_sh.c -o _get_posn_sh.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/iread_sh.c -o _iread_sh.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/read_sh.c -o _read_sh.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/write_sh.c -o _write_sh.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/iwrite_sh.c -o _iwrite_sh.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/seek_sh.c -o _seek_sh.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/read_ord.c -o _read_ord.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/read_orde.c -o _read_orde.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/write_ordb.c -o _write_ordb.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/read_ordb.c -o _read_ordb.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/write_ord.c -o _write_ord.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/write_orde.c -o _write_orde.o
gcc  -I. -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../adio/include -I../adio/include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/../../../include  -I../../../include  -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H -DMPIO_BUILD_PROFILING -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -c /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/register_datarep.c -o _register_datarep.o
ar cr /cygdrive/c/cygwin/mpich2-1.4/lib/libmpich.a _close.o _read.o _open.o _get_extent.o  _write.o _set_view.o _seek.o _read_at.o _prealloc.o  _iread.o _iwrite.o  _get_posn.o  _delete.o _read_all.o _get_bytoff.o  _read_atall.o _iread_at.o _iwrite_at.o _get_group.o _get_amode.o  _write_all.o _write_at.o _write_atall.o _get_view.o  _fsync.o _get_atom.o _set_atom.o _set_size.o _get_size.o  _file_f2c.o _file_c2f.o  _set_info.o _get_info.o  _rd_atallb.o _rd_atalle.o _read_allb.o _read_alle.o _wr_atallb.o  _wr_atalle.o _write_allb.o _write_alle.o  _get_posn_sh.o _iread_sh.o _read_sh.o _write_sh.o  _iwrite_sh.o _seek_sh.o _read_ord.o _read_orde.o _write_ordb.o  _read_ordb.o _write_ord.o _write_orde.o _register_datarep.o
ranlib /cygdrive/c/cygwin/mpich2-1.4/lib/libmpich.a
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpix'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpix/comm'
  CC              group_comm.c
  AR cr ../../../lib/libmpich.a group_comm.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpix/comm'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpix'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/mem'
  CC              trmem.c
  CC              handlemem.c
  CC              safestr.c
  CC              argstr.c
  CC              strerror.c
  AR cr ../../../lib/libmpich.a trmem.o handlemem.o safestr.o argstr.o strerror.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/mem'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/info'
  CC              infoutil.c
  CC              info_create.c
  CC              info_delete.c
  CC              info_dup.c
  CC              info_free.c
  CC              info_get.c
  CC              info_getn.c
  CC              info_getnth.c
  CC              info_getvallen.c
  CC              info_set.c
  AR cr ../../../lib/libmpich.a infoutil.o info_create.o info_delete.o info_dup.o info_free.o info_get.o info_getn.o info_getnth.o info_getvallen.o info_set.o
  RANLIB          libmpich.a
date > .libstamp0
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/info'
  CC             -D<profiling> ./info_create.c
  CC             -D<profiling> ./info_delete.c
  CC             -D<profiling> ./info_dup.c
  CC             -D<profiling> ./info_free.c
  CC             -D<profiling> ./info_get.c
  CC             -D<profiling> ./info_getn.c
  CC             -D<profiling> ./info_getnth.c
  CC             -D<profiling> ./info_getvallen.c
  CC             -D<profiling> ./info_set.c
  AR cr ../../../lib/libpmpich.a _info_create.o _info_delete.o _info_dup.o _info_free.o _info_get.o _info_getn.o _info_getnth.o _info_getvallen.o _info_set.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/info'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/info'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/msgs'
  CC              msgprint.c
  AR cr ../../../lib/libmpich.a msgprint.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/msgs'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/instrm'
  CC              states.c
  CC              instr.c
  AR cr ../../../lib/libmpich.a states.o instr.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/instrm'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/thread'
  CC              mpiu_thread.c
  AR cr ../../../lib/libmpich.a mpiu_thread.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/thread'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/dbg'
  CC              dbg_printf.c
  CC              timelimit.c
  CC              exit.c
  AR cr ../../../lib/libmpich.a dbg_printf.o timelimit.o exit.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/dbg'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/param'
  CC              param_vals.c
  AR cr ../../../lib/libmpich.a param_vals.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/param'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/osserv'
  CC              dl.c
  AR cr ../../../lib/libmpich.a dl.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/osserv'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/procmap'
  CC              local_proc.c
  AR cr ../../../lib/libmpich.a local_proc.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/procmap'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/other'
  CC              outliers.c
  CC              assert.c
  AR cr ../../../lib/libmpich.a outliers.o assert.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/other'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/nameserv'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/nameserv/file'
  CC              file_nameserv.c
  AR cr ../../../lib/libmpich.a file_nameserv.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/nameserv/file'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/nameserv'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
  CC             -o _wsendf.o -c -D... ./sendf.c
  CC             -o _wrecvf.o -c -D... ./recvf.c
  CC             -o _wget_countf.o -c -D... ./get_countf.c
  CC             -o _wbsendf.o -c -D... ./bsendf.c
  CC             -o _wssendf.o -c -D... ./ssendf.c
  CC             -o _wrsendf.o -c -D... ./rsendf.c
  CC             -o _wbufattachf.o -c -D... ./bufattachf.c
  CC             -o _wbufdetachf.o -c -D... ./bufdetachf.c
  CC             -o _wisendf.o -c -D... ./isendf.c
  CC             -o _wibsendf.o -c -D... ./ibsendf.c
  CC             -o _wissendf.o -c -D... ./issendf.c
  CC             -o _wirsendf.o -c -D... ./irsendf.c
  CC             -o _wirecvf.o -c -D... ./irecvf.c
  CC             -o _wwaitf.o -c -D... ./waitf.c
  CC             -o _wtestf.o -c -D... ./testf.c
  CC             -o _wrequest_freef.o -c -D... ./request_freef.c
  CC             -o _wwaitanyf.o -c -D... ./waitanyf.c
  CC             -o _wtestanyf.o -c -D... ./testanyf.c
  CC             -o _wwaitallf.o -c -D... ./waitallf.c
  CC             -o _wtestallf.o -c -D... ./testallf.c
  CC             -o _wwaitsomef.o -c -D... ./waitsomef.c
  CC             -o _wtestsomef.o -c -D... ./testsomef.c
  CC             -o _wiprobef.o -c -D... ./iprobef.c
  CC             -o _wprobef.o -c -D... ./probef.c
  CC             -o _wcancelf.o -c -D... ./cancelf.c
  CC             -o _wtestcancelf.o -c -D... ./testcancelf.c
  CC             -o _wsend_initf.o -c -D... ./send_initf.c
  CC             -o _wbsend_initf.o -c -D... ./bsend_initf.c
  CC             -o _wssend_initf.o -c -D... ./ssend_initf.c
  CC             -o _wrsend_initf.o -c -D... ./rsend_initf.c
  CC             -o _wrecv_initf.o -c -D... ./recv_initf.c
  CC             -o _wstartf.o -c -D... ./startf.c
  CC             -o _wstartallf.o -c -D... ./startallf.c
  CC             -o _wsendrecvf.o -c -D... ./sendrecvf.c
  CC             -o _wsndrcvrplf.o -c -D... ./sndrcvrplf.c
  CC             -o _wtypecontigf.o -c -D... ./typecontigf.c
  CC             -o _wtype_vectorf.o -c -D... ./type_vectorf.c
  CC             -o _wtype_hvectorf.o -c -D... ./type_hvectorf.c
  CC             -o _wtype_indexedf.o -c -D... ./type_indexedf.c
  CC             -o _wtype_hindexedf.o -c -D... ./type_hindexedf.c
  CC             -o _wtype_structf.o -c -D... ./type_structf.c
  CC             -o _wtype_extentf.o -c -D... ./type_extentf.c
  CC             -o _wtype_sizef.o -c -D... ./type_sizef.c
  CC             -o _wtype_lbf.o -c -D... ./type_lbf.c
  CC             -o _wtype_ubf.o -c -D... ./type_ubf.c
  CC             -o _wtype_commitf.o -c -D... ./type_commitf.c
  CC             -o _wtype_freef.o -c -D... ./type_freef.c
  CC             -o _wget_elementsf.o -c -D... ./get_elementsf.c
  CC             -o _wpackf.o -c -D... ./packf.c
  CC             -o _wunpackf.o -c -D... ./unpackf.c
  CC             -o _wpack_sizef.o -c -D... ./pack_sizef.c
  CC             -o _wbarrierf.o -c -D... ./barrierf.c
  CC             -o _wbcastf.o -c -D... ./bcastf.c
  CC             -o _wgatherf.o -c -D... ./gatherf.c
  CC             -o _wgathervf.o -c -D... ./gathervf.c
  CC             -o _wscatterf.o -c -D... ./scatterf.c
  CC             -o _wscattervf.o -c -D... ./scattervf.c
  CC             -o _wallgatherf.o -c -D... ./allgatherf.c
  CC             -o _wallgathervf.o -c -D... ./allgathervf.c
  CC             -o _walltoallf.o -c -D... ./alltoallf.c
  CC             -o _walltoallvf.o -c -D... ./alltoallvf.c
  CC             -o _wreducef.o -c -D... ./reducef.c
  CC             -o _wop_createf.o -c -D... ./op_createf.c
  CC             -o _wop_freef.o -c -D... ./op_freef.c
  CC             -o _wallreducef.o -c -D... ./allreducef.c
  CC             -o _wredscatf.o -c -D... ./redscatf.c
  CC             -o _wscanf.o -c -D... ./scanf.c
  CC             -o _wgroup_sizef.o -c -D... ./group_sizef.c
  CC             -o _wgroup_rankf.o -c -D... ./group_rankf.c
  CC             -o _wgrouptranksf.o -c -D... ./grouptranksf.c
  CC             -o _wgroup_comparef.o -c -D... ./group_comparef.c
  CC             -o _wcomm_groupf.o -c -D... ./comm_groupf.c
  CC             -o _wgroup_unionf.o -c -D... ./group_unionf.c
  CC             -o _wgroupinterf.o -c -D... ./groupinterf.c
  CC             -o _wgroupdifff.o -c -D... ./groupdifff.c
  CC             -o _wgroup_inclf.o -c -D... ./group_inclf.c
  CC             -o _wgroup_exclf.o -c -D... ./group_exclf.c
  CC             -o _wgrouprinclf.o -c -D... ./grouprinclf.c
  CC             -o _wgrouprexclf.o -c -D... ./grouprexclf.c
  CC             -o _wgroup_freef.o -c -D... ./group_freef.c
  CC             -o _wcomm_sizef.o -c -D... ./comm_sizef.c
  CC             -o _wcomm_rankf.o -c -D... ./comm_rankf.c
  CC             -o _wcomm_comparef.o -c -D... ./comm_comparef.c
  CC             -o _wcomm_dupf.o -c -D... ./comm_dupf.c
  CC             -o _wcomm_createf.o -c -D... ./comm_createf.c
  CC             -o _wcomm_splitf.o -c -D... ./comm_splitf.c
  CC             -o _wcomm_freef.o -c -D... ./comm_freef.c
  CC             -o _wcommtesticf.o -c -D... ./commtesticf.c
  CC             -o _wcommrsizef.o -c -D... ./commrsizef.c
  CC             -o _wcommrgroupf.o -c -D... ./commrgroupf.c
  CC             -o _wiccreatef.o -c -D... ./iccreatef.c
  CC             -o _wicmergef.o -c -D... ./icmergef.c
  CC             -o _wkeyval_freef.o -c -D... ./keyval_freef.c
  CC             -o _wattr_putf.o -c -D... ./attr_putf.c
  CC             -o _wattr_getf.o -c -D... ./attr_getf.c
  CC             -o _wattr_deletef.o -c -D... ./attr_deletef.c
  CC             -o _wtopo_testf.o -c -D... ./topo_testf.c
  CC             -o _wcart_createf.o -c -D... ./cart_createf.c
  CC             -o _wdims_createf.o -c -D... ./dims_createf.c
  CC             -o _wgraph_createf.o -c -D... ./graph_createf.c
  CC             -o _wgraphdims_getf.o -c -D... ./graphdims_getf.c
  CC             -o _wgraph_getf.o -c -D... ./graph_getf.c
  CC             -o _wcartdim_getf.o -c -D... ./cartdim_getf.c
  CC             -o _wcart_getf.o -c -D... ./cart_getf.c
  CC             -o _wcart_rankf.o -c -D... ./cart_rankf.c
  CC             -o _wcart_coordsf.o -c -D... ./cart_coordsf.c
  CC             -o _wgrfnbcountf.o -c -D... ./grfnbcountf.c
  CC             -o _wgrfnbrsf.o -c -D... ./grfnbrsf.c
  CC             -o _wcart_shiftf.o -c -D... ./cart_shiftf.c
  CC             -o _wcart_subf.o -c -D... ./cart_subf.c
  CC             -o _wcart_mapf.o -c -D... ./cart_mapf.c
  CC             -o _wgraph_mapf.o -c -D... ./graph_mapf.c
  CC             -o _wgetpnamef.o -c -D... ./getpnamef.c
  CC             -o _wget_versionf.o -c -D... ./get_versionf.c
  CC             -o _werrhcreatef.o -c -D... ./errhcreatef.c
  CC             -o _werrhsetf.o -c -D... ./errhsetf.c
  CC             -o _werrhgetf.o -c -D... ./errhgetf.c
  CC             -o _werrhfreef.o -c -D... ./errhfreef.c
  CC             -o _werror_stringf.o -c -D... ./error_stringf.c
  CC             -o _werror_classf.o -c -D... ./error_classf.c
  CC             -o _wfinalizef.o -c -D... ./finalizef.c
  CC             -o _winitializedf.o -c -D... ./initializedf.c
  CC             -o _wabortf.o -c -D... ./abortf.c
  CC             -o _wclose_portf.o -c -D... ./close_portf.c
  CC             -o _wcomm_acceptf.o -c -D... ./comm_acceptf.c
  CC             -o _wcomm_connectf.o -c -D... ./comm_connectf.c
  CC             -o _wcommdiscf.o -c -D... ./commdiscf.c
  CC             -o _wcommparentf.o -c -D... ./commparentf.c
  CC             -o _wcomm_joinf.o -c -D... ./comm_joinf.c
  CC             -o _wcomm_spawnf.o -c -D... ./comm_spawnf.c
  CC             -o _wspawnmultf.o -c -D... ./spawnmultf.c
  CC             -o _wlookup_namef.o -c -D... ./lookup_namef.c
  CC             -o _wopen_portf.o -c -D... ./open_portf.c
  CC             -o _wpublish_namef.o -c -D... ./publish_namef.c
  CC             -o _wunpubnamef.o -c -D... ./unpubnamef.c
  CC             -o _waccumulatef.o -c -D... ./accumulatef.c
  CC             -o _wgetf.o -c -D... ./getf.c
  CC             -o _wputf.o -c -D... ./putf.c
  CC             -o _wwin_completef.o -c -D... ./win_completef.c
  CC             -o _wwin_createf.o -c -D... ./win_createf.c
  CC             -o _wwin_fencef.o -c -D... ./win_fencef.c
  CC             -o _wwin_freef.o -c -D... ./win_freef.c
  CC             -o _wwin_get_groupf.o -c -D... ./win_get_groupf.c
  CC             -o _wwin_lockf.o -c -D... ./win_lockf.c
  CC             -o _wwin_postf.o -c -D... ./win_postf.c
  CC             -o _wwin_startf.o -c -D... ./win_startf.c
  CC             -o _wwin_testf.o -c -D... ./win_testf.c
  CC             -o _wwin_unlockf.o -c -D... ./win_unlockf.c
  CC             -o _wwin_waitf.o -c -D... ./win_waitf.c
  CC             -o _walltoallwf.o -c -D... ./alltoallwf.c
  CC             -o _wexscanf.o -c -D... ./exscanf.c
  CC             -o _wadderrclassf.o -c -D... ./adderrclassf.c
  CC             -o _wadderrcodef.o -c -D... ./adderrcodef.c
  CC             -o _wadderrstringf.o -c -D... ./adderrstringf.c
  CC             -o _wcommcallerrf.o -c -D... ./commcallerrf.c
  CC             -o _wcommnewkeyf.o -c -D... ./commnewkeyf.c
  CC             -o _wcommdelattrf.o -c -D... ./commdelattrf.c
  CC             -o _wcommfreekeyf.o -c -D... ./commfreekeyf.c
  CC             -o _wcomm_get_attrf.o -c -D... ./comm_get_attrf.c
  CC             -o _wcommgetnamf.o -c -D... ./commgetnamf.c
  CC             -o _wcomm_set_attrf.o -c -D... ./comm_set_attrf.c
  CC             -o _wcomm_set_namef.o -c -D... ./comm_set_namef.c
  CC             -o _wfilecallerrf.o -c -D... ./filecallerrf.c
  CC             -o _wgreqcompletef.o -c -D... ./greqcompletef.c
  CC             -o _wgreqstartf.o -c -D... ./greqstartf.c
  CC             -o _wisthrmainf.o -c -D... ./isthrmainf.c
  CC             -o _wquery_threadf.o -c -D... ./query_threadf.c
  CC             -o _wstatgetclf.o -c -D... ./statgetclf.c
  CC             -o _wstatsetelf.o -c -D... ./statsetelf.c
  CC             -o _wtypenewkeyf.o -c -D... ./typenewkeyf.c
  CC             -o _wtypedelattrf.o -c -D... ./typedelattrf.c
  CC             -o _wtype_dupf.o -c -D... ./type_dupf.c
  CC             -o _wtypefreekeyf.o -c -D... ./typefreekeyf.c
  CC             -o _wtype_get_attrf.o -c -D... ./type_get_attrf.c
  CC             -o _wtypegetcntsf.o -c -D... ./typegetcntsf.c
  CC             -o _wtypegetenvf.o -c -D... ./typegetenvf.c
  CC             -o _wtypegnamef.o -c -D... ./typegnamef.c
  CC             -o _wtypesetattrf.o -c -D... ./typesetattrf.c
  CC             -o _wtypesetnamef.o -c -D... ./typesetnamef.c
  CC             -o _wtype_match_sizef.o -c -D... ./type_match_sizef.c
  CC             -o _wwincallerrf.o -c -D... ./wincallerrf.c
  CC             -o _wwinnewkeyf.o -c -D... ./winnewkeyf.c
  CC             -o _wwindelattrf.o -c -D... ./windelattrf.c
  CC             -o _wwinfreekeyf.o -c -D... ./winfreekeyf.c
  CC             -o _wwin_get_attrf.o -c -D... ./win_get_attrf.c
  CC             -o _wwin_get_namef.o -c -D... ./win_get_namef.c
  CC             -o _wwin_set_attrf.o -c -D... ./win_set_attrf.c
  CC             -o _wwin_set_namef.o -c -D... ./win_set_namef.c
  CC             -o _walloc_memf.o -c -D... ./alloc_memf.c
  CC             -o _wcommcreerrf.o -c -D... ./commcreerrf.c
  CC             -o _wcommgeterrf.o -c -D... ./commgeterrf.c
  CC             -o _wcommseterrf.o -c -D... ./commseterrf.c
  CC             -o _wfilecreerrf.o -c -D... ./filecreerrf.c
  CC             -o _wfilegeterrf.o -c -D... ./filegeterrf.c
  CC             -o _wfileseterrf.o -c -D... ./fileseterrf.c
  CC             -o _wfinalizedf.o -c -D... ./finalizedf.c
  CC             -o _wfree_memf.o -c -D... ./free_memf.c
  CC             -o _winfo_createf.o -c -D... ./info_createf.c
  CC             -o _winfo_deletef.o -c -D... ./info_deletef.c
  CC             -o _winfo_dupf.o -c -D... ./info_dupf.c
  CC             -o _winfo_freef.o -c -D... ./info_freef.c
  CC             -o _winfo_getf.o -c -D... ./info_getf.c
  CC             -o _winfognkf.o -c -D... ./infognkf.c
  CC             -o _winfognthkf.o -c -D... ./infognthkf.c
  CC             -o _winfovallenf.o -c -D... ./infovallenf.c
  CC             -o _winfo_setf.o -c -D... ./info_setf.c
  CC             -o _wpack_externalf.o -c -D... ./pack_externalf.c
  CC             -o _wpackesizef.o -c -D... ./packesizef.c
  CC             -o _wreqgetstatf.o -c -D... ./reqgetstatf.c
  CC             -o _wtypedarrayf.o -c -D... ./typedarrayf.c
  CC             -o _wtypechindf.o -c -D... ./typechindf.c
  CC             -o _wtypechvecf.o -c -D... ./typechvecf.c
  CC             -o _wtypecindbf.o -c -D... ./typecindbf.c
  CC             -o _wtypecresizef.o -c -D... ./typecresizef.c
  CC             -o _wtypecstructf.o -c -D... ./typecstructf.c
  CC             -o _wtypecsubarrf.o -c -D... ./typecsubarrf.c
  CC             -o _wtypegetextentf.o -c -D... ./typegetextentf.c
  CC             -o _wtypegtextf.o -c -D... ./typegtextf.c
  CC             -o _wunpackextf.o -c -D... ./unpackextf.c
  CC             -o _wwincreerrf.o -c -D... ./wincreerrf.c
  CC             -o _wwingeterrf.o -c -D... ./wingeterrf.c
  CC             -o _wwinseterrf.o -c -D... ./winseterrf.c
  CC             -o _wreduce_localf.o -c -D... ./reduce_localf.c
  CC             -o _wop_commutativef.o -c -D... ./op_commutativef.c
  CC             -o _wreduce_scatter_blockf.o -c -D... ./reduce_scatter_blockf.c
  CC             -o _wdist_graph_create_adjacentf.o -c -D... ./dist_graph_create_adjacentf.c
  CC             -o _wdist_graph_createf.o -c -D... ./dist_graph_createf.c
  CC             -o _wdist_graph_neighbors_countf.o -c -D... ./dist_graph_neighbors_countf.c
  CC             -o _wdist_graph_neighborsf.o -c -D... ./dist_graph_neighborsf.c
  CC             -o _wfile_openf.o -c -D... ./file_openf.c
  CC             -o _wfile_closef.o -c -D... ./file_closef.c
  CC             -o _wfile_deletef.o -c -D... ./file_deletef.c
  CC             -o _wfile_set_sizef.o -c -D... ./file_set_sizef.c
  CC             -o _wfile_preallocatef.o -c -D... ./file_preallocatef.c
  CC             -o _wfile_get_sizef.o -c -D... ./file_get_sizef.c
  CC             -o _wfile_get_groupf.o -c -D... ./file_get_groupf.c
  CC             -o _wfile_get_amodef.o -c -D... ./file_get_amodef.c
  CC             -o _wfile_set_infof.o -c -D... ./file_set_infof.c
  CC             -o _wfile_get_infof.o -c -D... ./file_get_infof.c
  CC             -o _wfile_set_viewf.o -c -D... ./file_set_viewf.c
  CC             -o _wfile_get_viewf.o -c -D... ./file_get_viewf.c
  CC             -o _wfile_read_atf.o -c -D... ./file_read_atf.c
  CC             -o _wfile_read_at_allf.o -c -D... ./file_read_at_allf.c
  CC             -o _wfile_write_atf.o -c -D... ./file_write_atf.c
  CC             -o _wfile_write_at_allf.o -c -D... ./file_write_at_allf.c
  CC             -o _wfile_iread_atf.o -c -D... ./file_iread_atf.c
  CC             -o _wfile_iwrite_atf.o -c -D... ./file_iwrite_atf.c
  CC             -o _wfile_readf.o -c -D... ./file_readf.c
  CC             -o _wfile_read_allf.o -c -D... ./file_read_allf.c
  CC             -o _wfile_writef.o -c -D... ./file_writef.c
  CC             -o _wfile_write_allf.o -c -D... ./file_write_allf.c
  CC             -o _wfile_ireadf.o -c -D... ./file_ireadf.c
  CC             -o _wfile_iwritef.o -c -D... ./file_iwritef.c
  CC             -o _wfile_seekf.o -c -D... ./file_seekf.c
  CC             -o _wfile_get_positionf.o -c -D... ./file_get_positionf.c
  CC             -o _wfile_get_byte_offsetf.o -c -D... ./file_get_byte_offsetf.c
  CC             -o _wfile_read_sharedf.o -c -D... ./file_read_sharedf.c
  CC             -o _wfile_write_sharedf.o -c -D... ./file_write_sharedf.c
  CC             -o _wfile_iread_sharedf.o -c -D... ./file_iread_sharedf.c
  CC             -o _wfile_iwrite_sharedf.o -c -D... ./file_iwrite_sharedf.c
  CC             -o _wfile_read_orderedf.o -c -D... ./file_read_orderedf.c
  CC             -o _wfile_write_orderedf.o -c -D... ./file_write_orderedf.c
  CC             -o _wfile_seek_sharedf.o -c -D... ./file_seek_sharedf.c
  CC             -o _wfile_get_position_sharedf.o -c -D... ./file_get_position_sharedf.c
  CC             -o _wfile_read_at_all_beginf.o -c -D... ./file_read_at_all_beginf.c
  CC             -o _wfile_read_at_all_endf.o -c -D... ./file_read_at_all_endf.c
  CC             -o _wfile_write_at_all_beginf.o -c -D... ./file_write_at_all_beginf.c
  CC             -o _wfile_write_at_all_endf.o -c -D... ./file_write_at_all_endf.c
  CC             -o _wfile_read_all_beginf.o -c -D... ./file_read_all_beginf.c
  CC             -o _wfile_read_all_endf.o -c -D... ./file_read_all_endf.c
  CC             -o _wfile_write_all_beginf.o -c -D... ./file_write_all_beginf.c
  CC             -o _wfile_write_all_endf.o -c -D... ./file_write_all_endf.c
  CC             -o _wfile_read_ordered_beginf.o -c -D... ./file_read_ordered_beginf.c
  CC             -o _wfile_read_ordered_endf.o -c -D... ./file_read_ordered_endf.c
  CC             -o _wfile_write_ordered_beginf.o -c -D... ./file_write_ordered_beginf.c
  CC             -o _wfile_write_ordered_endf.o -c -D... ./file_write_ordered_endf.c
  CC             -o _wfile_get_type_extentf.o -c -D... ./file_get_type_extentf.c
  CC             -o _wregister_datarepf.o -c -D... ./register_datarepf.c
  CC             -o _wfile_set_atomicityf.o -c -D... ./file_set_atomicityf.c
  CC             -o _wfile_get_atomicityf.o -c -D... ./file_get_atomicityf.c
  CC             -o _wfile_syncf.o -c -D... ./file_syncf.c
  CC             -o _winitf.o -c -D... ./initf.c
  CC             -o _winitthreadf.o -c -D... ./initthreadf.c
  CC             -o _wpcontrolf.o -c -D... ./pcontrolf.c
  CC             -o _waddressf.o -c -D... ./addressf.c
  CC             -o _wgetaddressf.o -c -D... ./getaddressf.c
  CC             -o _wwtimef.o -c -D... ./wtimef.c
  CC             -o _wwtickf.o -c -D... ./wtickf.c
  CC             -o _wkeyval_createf.o -c -D... ./keyval_createf.c
  CC             -o _wdup_fnf.o -c -D... ./dup_fnf.c
  CC             -o _wnull_del_fnf.o -c -D... ./null_del_fnf.c
  CC             -o _wnull_copy_fnf.o -c -D... ./null_copy_fnf.c
  CC             -o _wdup_comm_fnf.o -c -D... ./dup_comm_fnf.c
  CC             -o _wnull_comm_del_fnf.o -c -D... ./null_comm_del_fnf.c
  CC             -o _wnull_comm_copy_fnf.o -c -D... ./null_comm_copy_fnf.c
  CC             -o _wdup_win_fnf.o -c -D... ./dup_win_fnf.c
  CC             -o _wnull_win_del_fnf.o -c -D... ./null_win_del_fnf.c
  CC             -o _wnull_win_copy_fnf.o -c -D... ./null_win_copy_fnf.c
  CC             -o _wdup_type_fnf.o -c -D... ./dup_type_fnf.c
  CC             -o _wnull_type_del_fnf.o -c -D... ./null_type_del_fnf.c
  CC             -o _wnull_type_copy_fnf.o -c -D... ./null_type_copy_fnf.c
  CC             -o _wstatusf2c.o -c -D... ./statusf2c.c
  CC             -o _wstatusc2f.o -c -D... ./statusc2f.c
  AR cr ../../../lib/libfmpich.a _wsendf.o _wrecvf.o _wget_countf.o _wbsendf.o _wssendf.o _wrsendf.o _wbufattachf.o _wbufdetachf.o _wisendf.o _wibsendf.o _wissendf.o _wirsendf.o _wirecvf.o _wwaitf.o _wtestf.o _wrequest_freef.o _wwaitanyf.o _wtestanyf.o _wwaitallf.o _wtestallf.o _wwaitsomef.o _wtestsomef.o _wiprobef.o _wprobef.o _wcancelf.o _wtestcancelf.o _wsend_initf.o _wbsend_initf.o _wssend_initf.o _wrsend_initf.o _wrecv_initf.o _wstartf.o _wstartallf.o _wsendrecvf.o _wsndrcvrplf.o _wtypecontigf.o _wtype_vectorf.o _wtype_hvectorf.o _wtype_indexedf.o _wtype_hindexedf.o _wtype_structf.o _wtype_extentf.o _wtype_sizef.o _wtype_lbf.o _wtype_ubf.o _wtype_commitf.o _wtype_freef.o _wget_elementsf.o _wpackf.o _wunpackf.o _wpack_sizef.o _wbarrierf.o _wbcastf.o _wgatherf.o _wgathervf.o _wscatterf.o _wscattervf.o _wallgatherf.o _wallgathervf.o _walltoallf.o _walltoallvf.o _wreducef.o _wop_createf.o _wop_freef.o _wallreducef.o _wredscatf.o _wscanf.o _wgroup_sizef.o _wgroup_rankf.o _wgrouptranksf.o _wgroup_comparef.o _wcomm_groupf.o _wgroup_unionf.o _wgroupinterf.o _wgroupdifff.o _wgroup_inclf.o _wgroup_exclf.o _wgrouprinclf.o _wgrouprexclf.o _wgroup_freef.o _wcomm_sizef.o _wcomm_rankf.o _wcomm_comparef.o _wcomm_dupf.o _wcomm_createf.o _wcomm_splitf.o _wcomm_freef.o _wcommtesticf.o _wcommrsizef.o _wcommrgroupf.o _wiccreatef.o _wicmergef.o _wkeyval_freef.o _wattr_putf.o _wattr_getf.o _wattr_deletef.o _wtopo_testf.o _wcart_createf.o _wdims_createf.o _wgraph_createf.o _wgraphdims_getf.o _wgraph_getf.o _wcartdim_getf.o _wcart_getf.o _wcart_rankf.o _wcart_coordsf.o _wgrfnbcountf.o _wgrfnbrsf.o _wcart_shiftf.o _wcart_subf.o _wcart_mapf.o _wgraph_mapf.o _wgetpnamef.o _wget_versionf.o _werrhcreatef.o _werrhsetf.o _werrhgetf.o _werrhfreef.o _werror_stringf.o _werror_classf.o _wfinalizef.o _winitializedf.o _wabortf.o _wclose_portf.o _wcomm_acceptf.o _wcomm_connectf.o _wcommdiscf.o _wcommparentf.o _wcomm_joinf.o _wcomm_spawnf.o _wspawnmultf.o _wlookup_namef.o _wopen_portf.o _wpublish_namef.o _wunpubnamef.o _waccumulatef.o _wgetf.o _wputf.o _wwin_completef.o _wwin_createf.o _wwin_fencef.o _wwin_freef.o _wwin_get_groupf.o _wwin_lockf.o _wwin_postf.o _wwin_startf.o _wwin_testf.o _wwin_unlockf.o _wwin_waitf.o _walltoallwf.o _wexscanf.o _wadderrclassf.o _wadderrcodef.o _wadderrstringf.o _wcommcallerrf.o _wcommnewkeyf.o _wcommdelattrf.o _wcommfreekeyf.o _wcomm_get_attrf.o _wcommgetnamf.o _wcomm_set_attrf.o _wcomm_set_namef.o _wfilecallerrf.o _wgreqcompletef.o _wgreqstartf.o _wisthrmainf.o _wquery_threadf.o _wstatgetclf.o _wstatsetelf.o _wtypenewkeyf.o _wtypedelattrf.o _wtype_dupf.o _wtypefreekeyf.o _wtype_get_attrf.o _wtypegetcntsf.o _wtypegetenvf.o _wtypegnamef.o _wtypesetattrf.o _wtypesetnamef.o _wtype_match_sizef.o _wwincallerrf.o _wwinnewkeyf.o _wwindelattrf.o _wwinfreekeyf.o _wwin_get_attrf.o _wwin_get_namef.o _wwin_set_attrf.o _wwin_set_namef.o _walloc_memf.o _wcommcreerrf.o _wcommgeterrf.o _wcommseterrf.o _wfilecreerrf.o _wfilegeterrf.o _wfileseterrf.o _wfinalizedf.o _wfree_memf.o _winfo_createf.o _winfo_deletef.o _winfo_dupf.o _winfo_freef.o _winfo_getf.o _winfognkf.o _winfognthkf.o _winfovallenf.o _winfo_setf.o _wpack_externalf.o _wpackesizef.o _wreqgetstatf.o _wtypedarrayf.o _wtypechindf.o _wtypechvecf.o _wtypecindbf.o _wtypecresizef.o _wtypecstructf.o _wtypecsubarrf.o _wtypegetextentf.o _wtypegtextf.o _wunpackextf.o _wwincreerrf.o _wwingeterrf.o _wwinseterrf.o _wreduce_localf.o _wop_commutativef.o _wreduce_scatter_blockf.o _wdist_graph_create_adjacentf.o _wdist_graph_createf.o _wdist_graph_neighbors_countf.o _wdist_graph_neighborsf.o _wfile_openf.o _wfile_closef.o _wfile_deletef.o _wfile_set_sizef.o _wfile_preallocatef.o _wfile_get_sizef.o _wfile_get_groupf.o _wfile_get_amodef.o _wfile_set_infof.o _wfile_get_infof.o _wfile_set_viewf.o _wfile_get_viewf.o _wfile_read_atf.o _wfile_read_at_allf.o _wfile_write_atf.o _wfile_write_at_allf.o _wfile_iread_atf.o _wfile_iwrite_atf.o _wfile_readf.o _wfile_read_allf.o _wfile_writef.o _wfile_write_allf.o _wfile_ireadf.o _wfile_iwritef.o _wfile_seekf.o _wfile_get_positionf.o _wfile_get_byte_offsetf.o _wfile_read_sharedf.o _wfile_write_sharedf.o _wfile_iread_sharedf.o _wfile_iwrite_sharedf.o _wfile_read_orderedf.o _wfile_write_orderedf.o _wfile_seek_sharedf.o _wfile_get_position_sharedf.o _wfile_read_at_all_beginf.o _wfile_read_at_all_endf.o _wfile_write_at_all_beginf.o _wfile_write_at_all_endf.o _wfile_read_all_beginf.o _wfile_read_all_endf.o _wfile_write_all_beginf.o _wfile_write_all_endf.o _wfile_read_ordered_beginf.o _wfile_read_ordered_endf.o _wfile_write_ordered_beginf.o _wfile_write_ordered_endf.o _wfile_get_type_extentf.o _wregister_datarepf.o _wfile_set_atomicityf.o _wfile_get_atomicityf.o _wfile_syncf.o _winitf.o _winitthreadf.o _wpcontrolf.o _waddressf.o _wgetaddressf.o _wwtimef.o _wwtickf.o _wkeyval_createf.o _wdup_fnf.o _wnull_del_fnf.o _wnull_copy_fnf.o _wdup_comm_fnf.o _wnull_comm_del_fnf.o _wnull_comm_copy_fnf.o _wdup_win_fnf.o _wnull_win_del_fnf.o _wnull_win_copy_fnf.o _wdup_type_fnf.o _wnull_type_del_fnf.o _wnull_type_copy_fnf.o _wstatusf2c.o _wstatusc2f.o
  RANLIB          libfmpich.a
date > .libstamp0
  CC              sendf.c
  CC              recvf.c
  CC              get_countf.c
  CC              bsendf.c
  CC              ssendf.c
  CC              rsendf.c
  CC              bufattachf.c
  CC              bufdetachf.c
  CC              isendf.c
  CC              ibsendf.c
  CC              issendf.c
  CC              irsendf.c
  CC              irecvf.c
  CC              waitf.c
  CC              testf.c
  CC              request_freef.c
  CC              waitanyf.c
  CC              testanyf.c
  CC              waitallf.c
  CC              testallf.c
  CC              waitsomef.c
  CC              testsomef.c
  CC              iprobef.c
  CC              probef.c
  CC              cancelf.c
  CC              testcancelf.c
  CC              send_initf.c
  CC              bsend_initf.c
  CC              ssend_initf.c
  CC              rsend_initf.c
  CC              recv_initf.c
  CC              startf.c
  CC              startallf.c
  CC              sendrecvf.c
  CC              sndrcvrplf.c
  CC              typecontigf.c
  CC              type_vectorf.c
  CC              type_hvectorf.c
  CC              type_indexedf.c
  CC              type_hindexedf.c
  CC              type_structf.c
  CC              type_extentf.c
  CC              type_sizef.c
  CC              type_lbf.c
  CC              type_ubf.c
  CC              type_commitf.c
  CC              type_freef.c
  CC              get_elementsf.c
  CC              packf.c
  CC              unpackf.c
  CC              pack_sizef.c
  CC              barrierf.c
  CC              bcastf.c
  CC              gatherf.c
  CC              gathervf.c
  CC              scatterf.c
  CC              scattervf.c
  CC              allgatherf.c
  CC              allgathervf.c
  CC              alltoallf.c
  CC              alltoallvf.c
  CC              reducef.c
  CC              op_createf.c
  CC              op_freef.c
  CC              allreducef.c
  CC              redscatf.c
  CC              scanf.c
  CC              group_sizef.c
  CC              group_rankf.c
  CC              grouptranksf.c
  CC              group_comparef.c
  CC              comm_groupf.c
  CC              group_unionf.c
  CC              groupinterf.c
  CC              groupdifff.c
  CC              group_inclf.c
  CC              group_exclf.c
  CC              grouprinclf.c
  CC              grouprexclf.c
  CC              group_freef.c
  CC              comm_sizef.c
  CC              comm_rankf.c
  CC              comm_comparef.c
  CC              comm_dupf.c
  CC              comm_createf.c
  CC              comm_splitf.c
  CC              comm_freef.c
  CC              commtesticf.c
  CC              commrsizef.c
  CC              commrgroupf.c
  CC              iccreatef.c
  CC              icmergef.c
  CC              keyval_freef.c
  CC              attr_putf.c
  CC              attr_getf.c
  CC              attr_deletef.c
  CC              topo_testf.c
  CC              cart_createf.c
  CC              dims_createf.c
  CC              graph_createf.c
  CC              graphdims_getf.c
  CC              graph_getf.c
  CC              cartdim_getf.c
  CC              cart_getf.c
  CC              cart_rankf.c
  CC              cart_coordsf.c
  CC              grfnbcountf.c
  CC              grfnbrsf.c
  CC              cart_shiftf.c
  CC              cart_subf.c
  CC              cart_mapf.c
  CC              graph_mapf.c
  CC              getpnamef.c
  CC              get_versionf.c
  CC              errhcreatef.c
  CC              errhsetf.c
  CC              errhgetf.c
  CC              errhfreef.c
  CC              error_stringf.c
  CC              error_classf.c
  CC              finalizef.c
  CC              initializedf.c
  CC              abortf.c
  CC              close_portf.c
  CC              comm_acceptf.c
  CC              comm_connectf.c
  CC              commdiscf.c
  CC              commparentf.c
  CC              comm_joinf.c
  CC              comm_spawnf.c
  CC              spawnmultf.c
  CC              lookup_namef.c
  CC              open_portf.c
  CC              publish_namef.c
  CC              unpubnamef.c
  CC              accumulatef.c
  CC              getf.c
  CC              putf.c
  CC              win_completef.c
  CC              win_createf.c
  CC              win_fencef.c
  CC              win_freef.c
  CC              win_get_groupf.c
  CC              win_lockf.c
  CC              win_postf.c
  CC              win_startf.c
  CC              win_testf.c
  CC              win_unlockf.c
  CC              win_waitf.c
  CC              alltoallwf.c
  CC              exscanf.c
  CC              adderrclassf.c
  CC              adderrcodef.c
  CC              adderrstringf.c
  CC              commcallerrf.c
  CC              commnewkeyf.c
  CC              commdelattrf.c
  CC              commfreekeyf.c
  CC              comm_get_attrf.c
  CC              commgetnamf.c
  CC              comm_set_attrf.c
  CC              comm_set_namef.c
  CC              filecallerrf.c
  CC              greqcompletef.c
  CC              greqstartf.c
  CC              isthrmainf.c
  CC              query_threadf.c
  CC              statgetclf.c
  CC              statsetelf.c
  CC              typenewkeyf.c
  CC              typedelattrf.c
  CC              type_dupf.c
  CC              typefreekeyf.c
  CC              type_get_attrf.c
  CC              typegetcntsf.c
  CC              typegetenvf.c
  CC              typegnamef.c
  CC              typesetattrf.c
  CC              typesetnamef.c
  CC              type_match_sizef.c
  CC              wincallerrf.c
  CC              winnewkeyf.c
  CC              windelattrf.c
  CC              winfreekeyf.c
  CC              win_get_attrf.c
  CC              win_get_namef.c
  CC              win_set_attrf.c
  CC              win_set_namef.c
  CC              alloc_memf.c
  CC              commcreerrf.c
  CC              commgeterrf.c
  CC              commseterrf.c
  CC              filecreerrf.c
  CC              filegeterrf.c
  CC              fileseterrf.c
  CC              finalizedf.c
  CC              free_memf.c
  CC              info_createf.c
  CC              info_deletef.c
  CC              info_dupf.c
  CC              info_freef.c
  CC              info_getf.c
  CC              infognkf.c
  CC              infognthkf.c
  CC              infovallenf.c
  CC              info_setf.c
  CC              pack_externalf.c
  CC              packesizef.c
  CC              reqgetstatf.c
  CC              typedarrayf.c
  CC              typechindf.c
  CC              typechvecf.c
  CC              typecindbf.c
  CC              typecresizef.c
  CC              typecstructf.c
  CC              typecsubarrf.c
  CC              typegetextentf.c
  CC              typegtextf.c
  CC              unpackextf.c
  CC              wincreerrf.c
  CC              wingeterrf.c
  CC              winseterrf.c
  CC              reduce_localf.c
  CC              op_commutativef.c
  CC              reduce_scatter_blockf.c
  CC              dist_graph_create_adjacentf.c
  CC              dist_graph_createf.c
  CC              dist_graph_neighbors_countf.c
  CC              dist_graph_neighborsf.c
  CC              file_openf.c
  CC              file_closef.c
  CC              file_deletef.c
  CC              file_set_sizef.c
  CC              file_preallocatef.c
  CC              file_get_sizef.c
  CC              file_get_groupf.c
  CC              file_get_amodef.c
  CC              file_set_infof.c
  CC              file_get_infof.c
  CC              file_set_viewf.c
  CC              file_get_viewf.c
  CC              file_read_atf.c
  CC              file_read_at_allf.c
  CC              file_write_atf.c
  CC              file_write_at_allf.c
  CC              file_iread_atf.c
  CC              file_iwrite_atf.c
  CC              file_readf.c
  CC              file_read_allf.c
  CC              file_writef.c
  CC              file_write_allf.c
  CC              file_ireadf.c
  CC              file_iwritef.c
  CC              file_seekf.c
  CC              file_get_positionf.c
  CC              file_get_byte_offsetf.c
  CC              file_read_sharedf.c
  CC              file_write_sharedf.c
  CC              file_iread_sharedf.c
  CC              file_iwrite_sharedf.c
  CC              file_read_orderedf.c
  CC              file_write_orderedf.c
  CC              file_seek_sharedf.c
  CC              file_get_position_sharedf.c
  CC              file_read_at_all_beginf.c
  CC              file_read_at_all_endf.c
  CC              file_write_at_all_beginf.c
  CC              file_write_at_all_endf.c
  CC              file_read_all_beginf.c
  CC              file_read_all_endf.c
  CC              file_write_all_beginf.c
  CC              file_write_all_endf.c
  CC              file_read_ordered_beginf.c
  CC              file_read_ordered_endf.c
  CC              file_write_ordered_beginf.c
  CC              file_write_ordered_endf.c
  CC              file_get_type_extentf.c
  CC              register_datarepf.c
  CC              file_set_atomicityf.c
  CC              file_get_atomicityf.c
  CC              file_syncf.c
  CC              initf.c
  CC              initthreadf.c
  CC              pcontrolf.c
  CC              addressf.c
  CC              getaddressf.c
  CC              wtimef.c
  CC              wtickf.c
  CC              keyval_createf.c
  CC              dup_fnf.c
  CC              null_del_fnf.c
  CC              null_copy_fnf.c
  CC              dup_comm_fnf.c
  CC              null_comm_del_fnf.c
  CC              null_comm_copy_fnf.c
  CC              dup_win_fnf.c
  CC              null_win_del_fnf.c
  CC              null_win_copy_fnf.c
  CC              dup_type_fnf.c
  CC              null_type_del_fnf.c
  CC              null_type_copy_fnf.c
  CC              statusf2c.c
  CC              statusc2f.c
  CC              setbot.c
  F77             setbotf.f
  AR cr ../../../lib/libmpich.a sendf.o recvf.o get_countf.o bsendf.o ssendf.o rsendf.o bufattachf.o bufdetachf.o isendf.o ibsendf.o issendf.o irsendf.o irecvf.o waitf.o testf.o request_freef.o waitanyf.o testanyf.o waitallf.o testallf.o waitsomef.o testsomef.o iprobef.o probef.o cancelf.o testcancelf.o send_initf.o bsend_initf.o ssend_initf.o rsend_initf.o recv_initf.o startf.o startallf.o sendrecvf.o sndrcvrplf.o typecontigf.o type_vectorf.o type_hvectorf.o type_indexedf.o type_hindexedf.o type_structf.o type_extentf.o type_sizef.o type_lbf.o type_ubf.o type_commitf.o type_freef.o get_elementsf.o packf.o unpackf.o pack_sizef.o barrierf.o bcastf.o gatherf.o gathervf.o scatterf.o scattervf.o allgatherf.o allgathervf.o alltoallf.o alltoallvf.o reducef.o op_createf.o op_freef.o allreducef.o redscatf.o scanf.o group_sizef.o group_rankf.o grouptranksf.o group_comparef.o comm_groupf.o group_unionf.o groupinterf.o groupdifff.o group_inclf.o group_exclf.o grouprinclf.o grouprexclf.o group_freef.o comm_sizef.o comm_rankf.o comm_comparef.o comm_dupf.o comm_createf.o comm_splitf.o comm_freef.o commtesticf.o commrsizef.o commrgroupf.o iccreatef.o icmergef.o keyval_freef.o attr_putf.o attr_getf.o attr_deletef.o topo_testf.o cart_createf.o dims_createf.o graph_createf.o graphdims_getf.o graph_getf.o cartdim_getf.o cart_getf.o cart_rankf.o cart_coordsf.o grfnbcountf.o grfnbrsf.o cart_shiftf.o cart_subf.o cart_mapf.o graph_mapf.o getpnamef.o get_versionf.o errhcreatef.o errhsetf.o errhgetf.o errhfreef.o error_stringf.o error_classf.o finalizef.o initializedf.o abortf.o close_portf.o comm_acceptf.o comm_connectf.o commdiscf.o commparentf.o comm_joinf.o comm_spawnf.o spawnmultf.o lookup_namef.o open_portf.o publish_namef.o unpubnamef.o accumulatef.o getf.o putf.o win_completef.o win_createf.o win_fencef.o win_freef.o win_get_groupf.o win_lockf.o win_postf.o win_startf.o win_testf.o win_unlockf.o win_waitf.o alltoallwf.o exscanf.o adderrclassf.o adderrcodef.o adderrstringf.o commcallerrf.o commnewkeyf.o commdelattrf.o commfreekeyf.o comm_get_attrf.o commgetnamf.o comm_set_attrf.o comm_set_namef.o filecallerrf.o greqcompletef.o greqstartf.o isthrmainf.o query_threadf.o statgetclf.o statsetelf.o typenewkeyf.o typedelattrf.o type_dupf.o typefreekeyf.o type_get_attrf.o typegetcntsf.o typegetenvf.o typegnamef.o typesetattrf.o typesetnamef.o type_match_sizef.o wincallerrf.o winnewkeyf.o windelattrf.o winfreekeyf.o win_get_attrf.o win_get_namef.o win_set_attrf.o win_set_namef.o alloc_memf.o commcreerrf.o commgeterrf.o commseterrf.o filecreerrf.o filegeterrf.o fileseterrf.o finalizedf.o free_memf.o info_createf.o info_deletef.o info_dupf.o info_freef.o info_getf.o infognkf.o infognthkf.o infovallenf.o info_setf.o pack_externalf.o packesizef.o reqgetstatf.o typedarrayf.o typechindf.o typechvecf.o typecindbf.o typecresizef.o typecstructf.o typecsubarrf.o typegetextentf.o typegtextf.o unpackextf.o wincreerrf.o wingeterrf.o winseterrf.o reduce_localf.o op_commutativef.o reduce_scatter_blockf.o dist_graph_create_adjacentf.o dist_graph_createf.o dist_graph_neighbors_countf.o dist_graph_neighborsf.o file_openf.o file_closef.o file_deletef.o file_set_sizef.o file_preallocatef.o file_get_sizef.o file_get_groupf.o file_get_amodef.o file_set_infof.o file_get_infof.o file_set_viewf.o file_get_viewf.o file_read_atf.o file_read_at_allf.o file_write_atf.o file_write_at_allf.o file_iread_atf.o file_iwrite_atf.o file_readf.o file_read_allf.o file_writef.o file_write_allf.o file_ireadf.o file_iwritef.o file_seekf.o file_get_positionf.o file_get_byte_offsetf.o file_read_sharedf.o file_write_sharedf.o file_iread_sharedf.o file_iwrite_sharedf.o file_read_orderedf.o file_write_orderedf.o file_seek_sharedf.o file_get_position_sharedf.o file_read_at_all_beginf.o file_read_at_all_endf.o file_write_at_all_beginf.o file_write_at_all_endf.o file_read_all_beginf.o file_read_all_endf.o file_write_all_beginf.o file_write_all_endf.o file_read_ordered_beginf.o file_read_ordered_endf.o file_write_ordered_beginf.o file_write_ordered_endf.o file_get_type_extentf.o register_datarepf.o file_set_atomicityf.o file_get_atomicityf.o file_syncf.o initf.o initthreadf.o pcontrolf.o addressf.o getaddressf.o wtimef.o wtickf.o keyval_createf.o dup_fnf.o null_del_fnf.o null_copy_fnf.o dup_comm_fnf.o null_comm_del_fnf.o null_comm_copy_fnf.o dup_win_fnf.o null_win_del_fnf.o null_win_copy_fnf.o dup_type_fnf.o null_type_del_fnf.o null_type_copy_fnf.o statusf2c.o statusc2f.o setbot.o setbotf.o
  RANLIB          libmpich.a
date > .libstamp2
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
  CC             -D<profiling> ./sendf.c
  CC             -D<profiling> ./recvf.c
  CC             -D<profiling> ./get_countf.c
  CC             -D<profiling> ./bsendf.c
  CC             -D<profiling> ./ssendf.c
  CC             -D<profiling> ./rsendf.c
  CC             -D<profiling> ./bufattachf.c
  CC             -D<profiling> ./bufdetachf.c
  CC             -D<profiling> ./isendf.c
  CC             -D<profiling> ./ibsendf.c
  CC             -D<profiling> ./issendf.c
  CC             -D<profiling> ./irsendf.c
  CC             -D<profiling> ./irecvf.c
  CC             -D<profiling> ./waitf.c
  CC             -D<profiling> ./testf.c
  CC             -D<profiling> ./request_freef.c
  CC             -D<profiling> ./waitanyf.c
  CC             -D<profiling> ./testanyf.c
  CC             -D<profiling> ./waitallf.c
  CC             -D<profiling> ./testallf.c
  CC             -D<profiling> ./waitsomef.c
  CC             -D<profiling> ./testsomef.c
  CC             -D<profiling> ./iprobef.c
  CC             -D<profiling> ./probef.c
  CC             -D<profiling> ./cancelf.c
  CC             -D<profiling> ./testcancelf.c
  CC             -D<profiling> ./send_initf.c
  CC             -D<profiling> ./bsend_initf.c
  CC             -D<profiling> ./ssend_initf.c
  CC             -D<profiling> ./rsend_initf.c
  CC             -D<profiling> ./recv_initf.c
  CC             -D<profiling> ./startf.c
  CC             -D<profiling> ./startallf.c
  CC             -D<profiling> ./sendrecvf.c
  CC             -D<profiling> ./sndrcvrplf.c
  CC             -D<profiling> ./typecontigf.c
  CC             -D<profiling> ./type_vectorf.c
  CC             -D<profiling> ./type_hvectorf.c
  CC             -D<profiling> ./type_indexedf.c
  CC             -D<profiling> ./type_hindexedf.c
  CC             -D<profiling> ./type_structf.c
  CC             -D<profiling> ./type_extentf.c
  CC             -D<profiling> ./type_sizef.c
  CC             -D<profiling> ./type_lbf.c
  CC             -D<profiling> ./type_ubf.c
  CC             -D<profiling> ./type_commitf.c
  CC             -D<profiling> ./type_freef.c
  CC             -D<profiling> ./get_elementsf.c
  CC             -D<profiling> ./packf.c
  CC             -D<profiling> ./unpackf.c
  CC             -D<profiling> ./pack_sizef.c
  CC             -D<profiling> ./barrierf.c
  CC             -D<profiling> ./bcastf.c
  CC             -D<profiling> ./gatherf.c
  CC             -D<profiling> ./gathervf.c
  CC             -D<profiling> ./scatterf.c
  CC             -D<profiling> ./scattervf.c
  CC             -D<profiling> ./allgatherf.c
  CC             -D<profiling> ./allgathervf.c
  CC             -D<profiling> ./alltoallf.c
  CC             -D<profiling> ./alltoallvf.c
  CC             -D<profiling> ./reducef.c
  CC             -D<profiling> ./op_createf.c
  CC             -D<profiling> ./op_freef.c
  CC             -D<profiling> ./allreducef.c
  CC             -D<profiling> ./redscatf.c
  CC             -D<profiling> ./scanf.c
  CC             -D<profiling> ./group_sizef.c
  CC             -D<profiling> ./group_rankf.c
  CC             -D<profiling> ./grouptranksf.c
  CC             -D<profiling> ./group_comparef.c
  CC             -D<profiling> ./comm_groupf.c
  CC             -D<profiling> ./group_unionf.c
  CC             -D<profiling> ./groupinterf.c
  CC             -D<profiling> ./groupdifff.c
  CC             -D<profiling> ./group_inclf.c
  CC             -D<profiling> ./group_exclf.c
  CC             -D<profiling> ./grouprinclf.c
  CC             -D<profiling> ./grouprexclf.c
  CC             -D<profiling> ./group_freef.c
  CC             -D<profiling> ./comm_sizef.c
  CC             -D<profiling> ./comm_rankf.c
  CC             -D<profiling> ./comm_comparef.c
  CC             -D<profiling> ./comm_dupf.c
  CC             -D<profiling> ./comm_createf.c
  CC             -D<profiling> ./comm_splitf.c
  CC             -D<profiling> ./comm_freef.c
  CC             -D<profiling> ./commtesticf.c
  CC             -D<profiling> ./commrsizef.c
  CC             -D<profiling> ./commrgroupf.c
  CC             -D<profiling> ./iccreatef.c
  CC             -D<profiling> ./icmergef.c
  CC             -D<profiling> ./keyval_freef.c
  CC             -D<profiling> ./attr_putf.c
  CC             -D<profiling> ./attr_getf.c
  CC             -D<profiling> ./attr_deletef.c
  CC             -D<profiling> ./topo_testf.c
  CC             -D<profiling> ./cart_createf.c
  CC             -D<profiling> ./dims_createf.c
  CC             -D<profiling> ./graph_createf.c
  CC             -D<profiling> ./graphdims_getf.c
  CC             -D<profiling> ./graph_getf.c
  CC             -D<profiling> ./cartdim_getf.c
  CC             -D<profiling> ./cart_getf.c
  CC             -D<profiling> ./cart_rankf.c
  CC             -D<profiling> ./cart_coordsf.c
  CC             -D<profiling> ./grfnbcountf.c
  CC             -D<profiling> ./grfnbrsf.c
  CC             -D<profiling> ./cart_shiftf.c
  CC             -D<profiling> ./cart_subf.c
  CC             -D<profiling> ./cart_mapf.c
  CC             -D<profiling> ./graph_mapf.c
  CC             -D<profiling> ./getpnamef.c
  CC             -D<profiling> ./get_versionf.c
  CC             -D<profiling> ./errhcreatef.c
  CC             -D<profiling> ./errhsetf.c
  CC             -D<profiling> ./errhgetf.c
  CC             -D<profiling> ./errhfreef.c
  CC             -D<profiling> ./error_stringf.c
  CC             -D<profiling> ./error_classf.c
  CC             -D<profiling> ./finalizef.c
  CC             -D<profiling> ./initializedf.c
  CC             -D<profiling> ./abortf.c
  CC             -D<profiling> ./close_portf.c
  CC             -D<profiling> ./comm_acceptf.c
  CC             -D<profiling> ./comm_connectf.c
  CC             -D<profiling> ./commdiscf.c
  CC             -D<profiling> ./commparentf.c
  CC             -D<profiling> ./comm_joinf.c
  CC             -D<profiling> ./comm_spawnf.c
  CC             -D<profiling> ./spawnmultf.c
  CC             -D<profiling> ./lookup_namef.c
  CC             -D<profiling> ./open_portf.c
  CC             -D<profiling> ./publish_namef.c
  CC             -D<profiling> ./unpubnamef.c
  CC             -D<profiling> ./accumulatef.c
  CC             -D<profiling> ./getf.c
  CC             -D<profiling> ./putf.c
  CC             -D<profiling> ./win_completef.c
  CC             -D<profiling> ./win_createf.c
  CC             -D<profiling> ./win_fencef.c
  CC             -D<profiling> ./win_freef.c
  CC             -D<profiling> ./win_get_groupf.c
  CC             -D<profiling> ./win_lockf.c
  CC             -D<profiling> ./win_postf.c
  CC             -D<profiling> ./win_startf.c
  CC             -D<profiling> ./win_testf.c
  CC             -D<profiling> ./win_unlockf.c
  CC             -D<profiling> ./win_waitf.c
  CC             -D<profiling> ./alltoallwf.c
  CC             -D<profiling> ./exscanf.c
  CC             -D<profiling> ./adderrclassf.c
  CC             -D<profiling> ./adderrcodef.c
  CC             -D<profiling> ./adderrstringf.c
  CC             -D<profiling> ./commcallerrf.c
  CC             -D<profiling> ./commnewkeyf.c
  CC             -D<profiling> ./commdelattrf.c
  CC             -D<profiling> ./commfreekeyf.c
  CC             -D<profiling> ./comm_get_attrf.c
  CC             -D<profiling> ./commgetnamf.c
  CC             -D<profiling> ./comm_set_attrf.c
  CC             -D<profiling> ./comm_set_namef.c
  CC             -D<profiling> ./filecallerrf.c
  CC             -D<profiling> ./greqcompletef.c
  CC             -D<profiling> ./greqstartf.c
  CC             -D<profiling> ./isthrmainf.c
  CC             -D<profiling> ./query_threadf.c
  CC             -D<profiling> ./statgetclf.c
  CC             -D<profiling> ./statsetelf.c
  CC             -D<profiling> ./typenewkeyf.c
  CC             -D<profiling> ./typedelattrf.c
  CC             -D<profiling> ./type_dupf.c
  CC             -D<profiling> ./typefreekeyf.c
  CC             -D<profiling> ./type_get_attrf.c
  CC             -D<profiling> ./typegetcntsf.c
  CC             -D<profiling> ./typegetenvf.c
  CC             -D<profiling> ./typegnamef.c
  CC             -D<profiling> ./typesetattrf.c
  CC             -D<profiling> ./typesetnamef.c
  CC             -D<profiling> ./type_match_sizef.c
  CC             -D<profiling> ./wincallerrf.c
  CC             -D<profiling> ./winnewkeyf.c
  CC             -D<profiling> ./windelattrf.c
  CC             -D<profiling> ./winfreekeyf.c
  CC             -D<profiling> ./win_get_attrf.c
  CC             -D<profiling> ./win_get_namef.c
  CC             -D<profiling> ./win_set_attrf.c
  CC             -D<profiling> ./win_set_namef.c
  CC             -D<profiling> ./alloc_memf.c
  CC             -D<profiling> ./commcreerrf.c
  CC             -D<profiling> ./commgeterrf.c
  CC             -D<profiling> ./commseterrf.c
  CC             -D<profiling> ./filecreerrf.c
  CC             -D<profiling> ./filegeterrf.c
  CC             -D<profiling> ./fileseterrf.c
  CC             -D<profiling> ./finalizedf.c
  CC             -D<profiling> ./free_memf.c
  CC             -D<profiling> ./info_createf.c
  CC             -D<profiling> ./info_deletef.c
  CC             -D<profiling> ./info_dupf.c
  CC             -D<profiling> ./info_freef.c
  CC             -D<profiling> ./info_getf.c
  CC             -D<profiling> ./infognkf.c
  CC             -D<profiling> ./infognthkf.c
  CC             -D<profiling> ./infovallenf.c
  CC             -D<profiling> ./info_setf.c
  CC             -D<profiling> ./pack_externalf.c
  CC             -D<profiling> ./packesizef.c
  CC             -D<profiling> ./reqgetstatf.c
  CC             -D<profiling> ./typedarrayf.c
  CC             -D<profiling> ./typechindf.c
  CC             -D<profiling> ./typechvecf.c
  CC             -D<profiling> ./typecindbf.c
  CC             -D<profiling> ./typecresizef.c
  CC             -D<profiling> ./typecstructf.c
  CC             -D<profiling> ./typecsubarrf.c
  CC             -D<profiling> ./typegetextentf.c
  CC             -D<profiling> ./typegtextf.c
  CC             -D<profiling> ./unpackextf.c
  CC             -D<profiling> ./wincreerrf.c
  CC             -D<profiling> ./wingeterrf.c
  CC             -D<profiling> ./winseterrf.c
  CC             -D<profiling> ./reduce_localf.c
  CC             -D<profiling> ./op_commutativef.c
  CC             -D<profiling> ./reduce_scatter_blockf.c
  CC             -D<profiling> ./dist_graph_create_adjacentf.c
  CC             -D<profiling> ./dist_graph_createf.c
  CC             -D<profiling> ./dist_graph_neighbors_countf.c
  CC             -D<profiling> ./dist_graph_neighborsf.c
  CC             -D<profiling> ./file_openf.c
  CC             -D<profiling> ./file_closef.c
  CC             -D<profiling> ./file_deletef.c
  CC             -D<profiling> ./file_set_sizef.c
  CC             -D<profiling> ./file_preallocatef.c
  CC             -D<profiling> ./file_get_sizef.c
  CC             -D<profiling> ./file_get_groupf.c
  CC             -D<profiling> ./file_get_amodef.c
  CC             -D<profiling> ./file_set_infof.c
  CC             -D<profiling> ./file_get_infof.c
  CC             -D<profiling> ./file_set_viewf.c
  CC             -D<profiling> ./file_get_viewf.c
  CC             -D<profiling> ./file_read_atf.c
  CC             -D<profiling> ./file_read_at_allf.c
  CC             -D<profiling> ./file_write_atf.c
  CC             -D<profiling> ./file_write_at_allf.c
  CC             -D<profiling> ./file_iread_atf.c
  CC             -D<profiling> ./file_iwrite_atf.c
  CC             -D<profiling> ./file_readf.c
  CC             -D<profiling> ./file_read_allf.c
  CC             -D<profiling> ./file_writef.c
  CC             -D<profiling> ./file_write_allf.c
  CC             -D<profiling> ./file_ireadf.c
  CC             -D<profiling> ./file_iwritef.c
  CC             -D<profiling> ./file_seekf.c
  CC             -D<profiling> ./file_get_positionf.c
  CC             -D<profiling> ./file_get_byte_offsetf.c
  CC             -D<profiling> ./file_read_sharedf.c
  CC             -D<profiling> ./file_write_sharedf.c
  CC             -D<profiling> ./file_iread_sharedf.c
  CC             -D<profiling> ./file_iwrite_sharedf.c
  CC             -D<profiling> ./file_read_orderedf.c
  CC             -D<profiling> ./file_write_orderedf.c
  CC             -D<profiling> ./file_seek_sharedf.c
  CC             -D<profiling> ./file_get_position_sharedf.c
  CC             -D<profiling> ./file_read_at_all_beginf.c
  CC             -D<profiling> ./file_read_at_all_endf.c
  CC             -D<profiling> ./file_write_at_all_beginf.c
  CC             -D<profiling> ./file_write_at_all_endf.c
  CC             -D<profiling> ./file_read_all_beginf.c
  CC             -D<profiling> ./file_read_all_endf.c
  CC             -D<profiling> ./file_write_all_beginf.c
  CC             -D<profiling> ./file_write_all_endf.c
  CC             -D<profiling> ./file_read_ordered_beginf.c
  CC             -D<profiling> ./file_read_ordered_endf.c
  CC             -D<profiling> ./file_write_ordered_beginf.c
  CC             -D<profiling> ./file_write_ordered_endf.c
  CC             -D<profiling> ./file_get_type_extentf.c
  CC             -D<profiling> ./register_datarepf.c
  CC             -D<profiling> ./file_set_atomicityf.c
  CC             -D<profiling> ./file_get_atomicityf.c
  CC             -D<profiling> ./file_syncf.c
  CC             -D<profiling> ./initf.c
  CC             -D<profiling> ./initthreadf.c
  CC             -D<profiling> ./pcontrolf.c
  CC             -D<profiling> ./addressf.c
  CC             -D<profiling> ./getaddressf.c
  CC             -D<profiling> ./wtimef.c
  CC             -D<profiling> ./wtickf.c
  CC             -D<profiling> ./keyval_createf.c
  CC             -D<profiling> ./dup_fnf.c
  CC             -D<profiling> ./null_del_fnf.c
  CC             -D<profiling> ./null_copy_fnf.c
  CC             -D<profiling> ./dup_comm_fnf.c
  CC             -D<profiling> ./null_comm_del_fnf.c
  CC             -D<profiling> ./null_comm_copy_fnf.c
  CC             -D<profiling> ./dup_win_fnf.c
  CC             -D<profiling> ./null_win_del_fnf.c
  CC             -D<profiling> ./null_win_copy_fnf.c
  CC             -D<profiling> ./dup_type_fnf.c
  CC             -D<profiling> ./null_type_del_fnf.c
  CC             -D<profiling> ./null_type_copy_fnf.c
  CC             -D<profiling> ./statusf2c.c
  CC             -D<profiling> ./statusc2f.c
  AR cr ../../../lib/libpmpich.a _sendf.o _recvf.o _get_countf.o _bsendf.o _ssendf.o _rsendf.o _bufattachf.o _bufdetachf.o _isendf.o _ibsendf.o _issendf.o _irsendf.o _irecvf.o _waitf.o _testf.o _request_freef.o _waitanyf.o _testanyf.o _waitallf.o _testallf.o _waitsomef.o _testsomef.o _iprobef.o _probef.o _cancelf.o _testcancelf.o _send_initf.o _bsend_initf.o _ssend_initf.o _rsend_initf.o _recv_initf.o _startf.o _startallf.o _sendrecvf.o _sndrcvrplf.o _typecontigf.o _type_vectorf.o _type_hvectorf.o _type_indexedf.o _type_hindexedf.o _type_structf.o _type_extentf.o _type_sizef.o _type_lbf.o _type_ubf.o _type_commitf.o _type_freef.o _get_elementsf.o _packf.o _unpackf.o _pack_sizef.o _barrierf.o _bcastf.o _gatherf.o _gathervf.o _scatterf.o _scattervf.o _allgatherf.o _allgathervf.o _alltoallf.o _alltoallvf.o _reducef.o _op_createf.o _op_freef.o _allreducef.o _redscatf.o _scanf.o _group_sizef.o _group_rankf.o _grouptranksf.o _group_comparef.o _comm_groupf.o _group_unionf.o _groupinterf.o _groupdifff.o _group_inclf.o _group_exclf.o _grouprinclf.o _grouprexclf.o _group_freef.o _comm_sizef.o _comm_rankf.o _comm_comparef.o _comm_dupf.o _comm_createf.o _comm_splitf.o _comm_freef.o _commtesticf.o _commrsizef.o _commrgroupf.o _iccreatef.o _icmergef.o _keyval_freef.o _attr_putf.o _attr_getf.o _attr_deletef.o _topo_testf.o _cart_createf.o _dims_createf.o _graph_createf.o _graphdims_getf.o _graph_getf.o _cartdim_getf.o _cart_getf.o _cart_rankf.o _cart_coordsf.o _grfnbcountf.o _grfnbrsf.o _cart_shiftf.o _cart_subf.o _cart_mapf.o _graph_mapf.o _getpnamef.o _get_versionf.o _errhcreatef.o _errhsetf.o _errhgetf.o _errhfreef.o _error_stringf.o _error_classf.o _finalizef.o _initializedf.o _abortf.o _close_portf.o _comm_acceptf.o _comm_connectf.o _commdiscf.o _commparentf.o _comm_joinf.o _comm_spawnf.o _spawnmultf.o _lookup_namef.o _open_portf.o _publish_namef.o _unpubnamef.o _accumulatef.o _getf.o _putf.o _win_completef.o _win_createf.o _win_fencef.o _win_freef.o _win_get_groupf.o _win_lockf.o _win_postf.o _win_startf.o _win_testf.o _win_unlockf.o _win_waitf.o _alltoallwf.o _exscanf.o _adderrclassf.o _adderrcodef.o _adderrstringf.o _commcallerrf.o _commnewkeyf.o _commdelattrf.o _commfreekeyf.o _comm_get_attrf.o _commgetnamf.o _comm_set_attrf.o _comm_set_namef.o _filecallerrf.o _greqcompletef.o _greqstartf.o _isthrmainf.o _query_threadf.o _statgetclf.o _statsetelf.o _typenewkeyf.o _typedelattrf.o _type_dupf.o _typefreekeyf.o _type_get_attrf.o _typegetcntsf.o _typegetenvf.o _typegnamef.o _typesetattrf.o _typesetnamef.o _type_match_sizef.o _wincallerrf.o _winnewkeyf.o _windelattrf.o _winfreekeyf.o _win_get_attrf.o _win_get_namef.o _win_set_attrf.o _win_set_namef.o _alloc_memf.o _commcreerrf.o _commgeterrf.o _commseterrf.o _filecreerrf.o _filegeterrf.o _fileseterrf.o _finalizedf.o _free_memf.o _info_createf.o _info_deletef.o _info_dupf.o _info_freef.o _info_getf.o _infognkf.o _infognthkf.o _infovallenf.o _info_setf.o _pack_externalf.o _packesizef.o _reqgetstatf.o _typedarrayf.o _typechindf.o _typechvecf.o _typecindbf.o _typecresizef.o _typecstructf.o _typecsubarrf.o _typegetextentf.o _typegtextf.o _unpackextf.o _wincreerrf.o _wingeterrf.o _winseterrf.o _reduce_localf.o _op_commutativef.o _reduce_scatter_blockf.o _dist_graph_create_adjacentf.o _dist_graph_createf.o _dist_graph_neighbors_countf.o _dist_graph_neighborsf.o _file_openf.o _file_closef.o _file_deletef.o _file_set_sizef.o _file_preallocatef.o _file_get_sizef.o _file_get_groupf.o _file_get_amodef.o _file_set_infof.o _file_get_infof.o _file_set_viewf.o _file_get_viewf.o _file_read_atf.o _file_read_at_allf.o _file_write_atf.o _file_write_at_allf.o _file_iread_atf.o _file_iwrite_atf.o _file_readf.o _file_read_allf.o _file_writef.o _file_write_allf.o _file_ireadf.o _file_iwritef.o _file_seekf.o _file_get_positionf.o _file_get_byte_offsetf.o _file_read_sharedf.o _file_write_sharedf.o _file_iread_sharedf.o _file_iwrite_sharedf.o _file_read_orderedf.o _file_write_orderedf.o _file_seek_sharedf.o _file_get_position_sharedf.o _file_read_at_all_beginf.o _file_read_at_all_endf.o _file_write_at_all_beginf.o _file_write_at_all_endf.o _file_read_all_beginf.o _file_read_all_endf.o _file_write_all_beginf.o _file_write_all_endf.o _file_read_ordered_beginf.o _file_read_ordered_endf.o _file_write_ordered_beginf.o _file_write_ordered_endf.o _file_get_type_extentf.o _register_datarepf.o _file_set_atomicityf.o _file_get_atomicityf.o _file_syncf.o _initf.o _initthreadf.o _pcontrolf.o _addressf.o _getaddressf.o _wtimef.o _wtickf.o _keyval_createf.o _dup_fnf.o _null_del_fnf.o _null_copy_fnf.o _dup_comm_fnf.o _null_comm_del_fnf.o _null_comm_copy_fnf.o _dup_win_fnf.o _null_win_del_fnf.o _null_win_copy_fnf.o _dup_type_fnf.o _null_type_del_fnf.o _null_type_copy_fnf.o _statusf2c.o _statusc2f.o
  RANLIB          libpmpich.a
date > .libstamp4
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
rm -f mpifnoext.h
sed -e 's/^C/\!/g' -e '/EXTERNAL/d' \
                -e '/REAL\*8/d' \
	-e '/DOUBLE PRECISION/d' \
	-e '/MPI_WTICK/d' ../f77/mpif.h > mpifnoext.h
g95 -O2 -I. -c ./mpi_constants.f90
g95 -O2 -I. -c mpi_sizeofs.f90
g95 -O2 -I. -c mpi_base.f90
g95 -O2 -I. -c ./mpi.f90
  CC              create_f90_int.c
  CC              create_f90_real.c
  CC              create_f90_complex.c
  CC              typef90cmplxf.c
  CC              typef90realf.c
  CC              typef90intf.c
  CC              create_f90_util.c
  AR cr ../../../lib/libmpich.a create_f90_int.o create_f90_real.o create_f90_complex.o typef90cmplxf.o typef90realf.o typef90intf.o create_f90_util.o
  RANLIB          libmpich.a
date > .libstamp0
  AR cr libmpichf90.a mpi.o mpi_constants.o mpi_sizeofs.o mpi_base.o
  RANLIB          libmpichf90.a
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
  CC             -D<profiling> ./create_f90_int.c
  CC             -D<profiling> ./create_f90_real.c
  CC             -D<profiling> ./create_f90_complex.c
  CC             -D<profiling> ./typef90cmplxf.c
  CC             -D<profiling> ./typef90realf.c
  CC             -D<profiling> ./typef90intf.c
  AR cr ../../../lib/libpmpich.a _create_f90_int.o _create_f90_real.o _create_f90_complex.o _typef90cmplxf.o _typef90realf.o _typef90intf.o
  RANLIB          libpmpich.a
date > .libstamp2
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
make all-postamble
if [ -s libmpichf90.a ] ; then \
   cp -p libmpichf90.a ../../../lib ; fi
if [ -s libmpichf90.la ] ; then \
   cp -p libmpichf90.la ../../../lib ; fi
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/cxx'
  CXX             initcxx.cxx
  AR cr ../../../lib/libmpichcxx.a initcxx.o
  RANLIB          libmpichcxx.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/cxx'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
  CC              mpich2version.c
gcc -O2   -o mpich2version mpich2version.o  \
../../lib/libmpich.a -lpthread
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/pkgconfig'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/pkgconfig'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/envmods'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/envmods'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpe2'
make --no-print-directory  build_lib_bin
**** Making src/misc ....
make --no-print-directory  mpe_debug_objs
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi.a
gcc -I.. -I../include  -I../../.. -I../../../include -O2  -DMPE_NOMPI -o mpehname.no -c mpehname.c
mpehname.c: In function ?MPE_GetHostName?:
mpehname.c:59:16: ??????????????????
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi.a mpehname.no
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe.a
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I../../.. -I../../../include   -o decomp.po -c decomp.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I../../.. -I../../../include   -o mpe_seq.po -c mpe_seq.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I../../.. -I../../../include   -o dbxerr.po -c dbxerr.c
dbxerr.c: In function ?MPE_DefaultHandler?:
dbxerr.c:429:1: ???expected ?=?, ?,?, ?;?, ?asm? or ?__attribute__? before ?{? token
dbxerr.c:459:1: ???expected ?=?, ?,?, ?;?, ?asm? or ?__attribute__? before ?{? token
dbxerr.c:408:6: ????? ?sig? ?????
dbxerr.c:407:6: ???prototype declaration
dbxerr.c:475:1: ???expected ?{? at end of input
Makefile:82: recipe for target `dbxerr.po' failed
make[7]: *** [dbxerr.po] Error 1
Makefile:111: recipe for target `default' failed
make[6]: *** [default] Error 2
Makefile:43: recipe for target `build_lib_bin' failed
make[5]: *** [build_lib_bin] Error 2
Makefile:26: recipe for target `all' failed
make[4]: *** [all] Error 2
**** Making src/callstack ....
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -o iterator.po -c iterator.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -o fancyprint.po -c fancyprint.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include -O2  -o iterator.no -c iterator.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include -O2  -o fancyprint.no -c fancyprint.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi.a iterator.no fancyprint.no
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe.a iterator.po fancyprint.po
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/check_callstack.exe
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include -O2  -o check_callstack.no -c check_callstack.c
cp -f check_callstack.no mpe2tmp.o
gcc  -O2  -o /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/check_callstack.exe mpe2tmp.o \
                         -L/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib -lmpe_nompi
**** Making src/logging ....
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpi_null.no -c mpi_null.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_util.no -c clog_util.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_timer.no -c clog_timer.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_uuid.no -c clog_uuid.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_commset.no -c clog_commset.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_preamble.no -c clog_preamble.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_record.no -c clog_record.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_sync.no -c clog_sync.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_block.no -c clog_block.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_buffer.no -c clog_buffer.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_merger.no -c clog_merger.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_cache.no -c clog_cache.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_joiner.no -c clog_joiner.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog.no -c clog.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log_thread.no -c mpe_log_thread.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log.no -c mpe_log.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log_null.no -c mpe_log_null.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o mpe_log_null.po -c mpe_log_null.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_util.po -c clog_util.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_timer.po -c clog_timer.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_uuid.po -c clog_uuid.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_commset.po -c clog_commset.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_preamble.po -c clog_preamble.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_record.po -c clog_record.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_sync.po -c clog_sync.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_block.po -c clog_block.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_buffer.po -c clog_buffer.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_merger.po -c clog_merger.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_cache.po -c clog_cache.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_joiner.po -c clog_joiner.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog.po -c clog.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o mpe_log_thread.po -c mpe_log_thread.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o mpe_log.po -c mpe_log.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi.a mpi_null.no clog_util.no clog_timer.no clog_uuid.no clog_commset.no clog_preamble.no clog_record.no clog_sync.no clog_block.no clog_buffer.no clog_merger.no clog_cache.no clog_joiner.no clog.no mpe_log_thread.no mpe_log.no
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_logf.no -c mpe_logf.c
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi_null.a
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi_null.a mpi_null.no mpe_log_null.no
make[8]: `mpe_logf.no' is up to date.
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi_null.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_null.a
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_null.a mpe_log_null.po
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o mpe_logf.po -c mpe_logf.c
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_null.a
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe.a clog_util.po clog_timer.po clog_uuid.po clog_commset.po clog_preamble.po clog_record.po clog_sync.po clog_block.po clog_buffer.po clog_merger.po clog_cache.po clog_joiner.po clog.po mpe_log_thread.po mpe_log.po
make[8]: `mpe_logf.po' is up to date.
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/clog2_print.exe  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/clog2_join.exe  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/clog2_repair.exe
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_print.no -c clog_print.c
cp -f clog_print.no mpe2tmp1.o
gcc  -O2  -o /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/clog2_print.exe mpe2tmp1.o \
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_join.no -c clog_join.c
cp -f clog_join.no mpe2tmp2.o
gcc  -O2  -o /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/clog2_join.exe mpe2tmp2.o \
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_repair.no -c clog_repair.c
cp -f clog_repair.no mpe2tmp3.o
gcc  -O2  -o /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/clog2_repair.exe mpe2tmp3.o \
**** Making src/wrappers ....
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c log_mpi_util.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c log_mpi_core.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c trace_mpi_core.c
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/liblmpe.a
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/liblmpe.a log_mpi_util.o log_mpi_core.o
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/liblmpe.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libtmpe.a
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libtmpe.a trace_mpi_core.o
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libtmpe.a
/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77   -c mpi_f2c_consts.f
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c mpe_proff.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_f2cmpi.a mpi_f2c_consts.o log_mpi_util.o mpe_proff.o
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_f2cmpi.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/mpe_prof.o
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c mpe_prof.c
make --no-print-directory  linktest_all
make --no-print-directory  linktest_C
make --no-print-directory  linktest_F77
**** Making src/graphics ....
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o mpe_graphics.no -c mpe_graphics.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xcolor.no -c xcolor.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xframe.no -c xframe.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xinit.no -c xinit.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xwmap.no -c xwmap.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xmouse.no -c xmouse.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xkey.no -c xkey.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o mpe_graphics.po -c mpe_graphics.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xcolor.po -c xcolor.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xframe.po -c xframe.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xinit.po -c xinit.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xwmap.po -c xwmap.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xmouse.po -c xmouse.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xkey.po -c xkey.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o visual_mess.po -c visual_mess.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi.a mpe_graphics.no xcolor.no xframe.no xinit.no xwmap.no xmouse.no xkey.no
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe.a mpe_graphics.po xcolor.po xframe.po xinit.po xwmap.po xmouse.po xkey.po
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o mpe_graphicsf.po -c mpe_graphicsf.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xmousef.po -c xmousef.c
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libampe.a
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libampe.a visual_mess.po
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libampe.a
**** Making src/collchk ....
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_collchk.a
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c err_han.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c is_init.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c check_buff.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c check_dims.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c check_graph.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c check_size.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_amode.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_call.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_dtype.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_high_low.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_int.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_local_leader.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_op.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_root.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_tag.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_datarep.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_whence.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c allgather.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c allgatherv.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c allreduce.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c alltoall.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c alltoallv.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c barrier.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c bcast.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c cart_create.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c cart_map.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c gather.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c gatherv.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c graph_create.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c graph_map.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c init.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c intercomm_create.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c intercomm_merge.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c reduce.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c reduce_scatter.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c scan.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c scatter.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c scatterv.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c finalize.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c exscan.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c alltoallw.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_open.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_preallocate.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_all_begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_all.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_all_end.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_at_all_begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_at_all.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_at_all_end.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_ordered_begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_ordered.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_ordered_end.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_seek_shared.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_set_atomicity.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_set_size.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_set_view.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_all_begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_all.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_all_end.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_at_all_begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_at_all.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_at_all_end.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_ordered_begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_ordered.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_ordered_end.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c add_fh.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c get_fh.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c win_create.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c win_fence.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c add_win.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c get_win.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_accept.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_connect.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_create.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_disconnect.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_dup.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_spawn.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_spawn_multiple.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_split.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_collchk.a *.o
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_collchk.a
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpe2'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pmi'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pmi/simple'
  CC              simple_pmiutil.c
  CC              simple_pmi.c
  AR cr ../../../lib/libmpich.a simple_pmiutil.o simple_pmi.o
  RANLIB          libmpich.a
date > .libstamp0
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pmi/simple'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pmi'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
Making all in ../../mpl
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
Making all in .
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
  CC     alloc.lo
  CC     args.lo
  CC     dbg.lo
  CC     env.lo
  CC     launch.lo
  CC     others.lo
  CC     signals.lo
  CC     sock.lo
  CC     string.lo
  CC     bind.lo
  CC     bsci_init.lo
  CC     bsci_finalize.lo
  CC     bsci_launch.lo
  CC     bsci_query_node_list.lo
  CC     bsci_query_job_id.lo
  CC     bsci_query_proxy_id.lo
  CC     bsci_query_native_int.lo
  CC     bsci_wait.lo
  CC     bsci_env.lo
  CC     bscu_wait.lo
  CC     bscu_cb.lo
  CC     external_common.lo
  CC     external_common_launch.lo
  CC     fork_init.lo
  CC     none_init.lo
  CC     rsh_init.lo
  CC     rsh_env.lo
  CC     ssh_init.lo
  CC     ssh.lo
  CC     ssh_env.lo
  CC     ssh_finalize.lo
  CC     slurm_init.lo
  CC     slurm_launch.lo
  CC     slurm_env.lo
  CC     slurm_query_native_int.lo
  CC     slurm_query_node_list.lo
  CC     slurm_query_proxy_id.lo
  CC     slurm_query_jobid.lo
  CC     ll_init.lo
  CC     ll_launch.lo
  CC     ll_query_native_int.lo
  CC     ll_query_node_list.lo
  CC     ll_query_proxy_id.lo
  CC     ll_env.lo
  CC     lsf_init.lo
  CC     lsf_query_native_int.lo
  CC     lsf_query_node_list.lo
  CC     lsf_env.lo
  CC     sge_init.lo
  CC     sge_query_native_int.lo
  CC     sge_query_node_list.lo
  CC     sge_env.lo
  CC     pbs_init.lo
  CC     pbs_query_native_int.lo
  CC     pbs_query_node_list.lo
  CC     pbs_query_jobid.lo
  CC     persist_init.lo
  CC     persist_launch.lo
  CC     persist_wait.lo
  CC     ckpoint.lo
  CC     demux.lo
  CC     demux_poll.lo
  CC     demux_select.lo
  CC     debugger.lo
  CC     hydt_ftb_dummy.lo
  CC     uiu.lo
  CCLD   libhydra.la
  CC     pmiserv_pmi.lo
  CC     pmiserv_pmi_v1.lo
  CC     pmiserv_pmi_v2.lo
  CC     pmiserv_pmci.lo
  CC     pmiserv_cb.lo
  CC     pmiserv_utils.lo
  CC     common.lo
  CC     pmi_v2_common.lo
  CCLD   libpm.la
  CC     hydra_persist-persist_server.o
  CCLD   hydra_persist.exe
  CC     hydra_nameserver-hydra_nameserver.o
  CCLD   hydra_nameserver.exe
  CC     hydra_pmi_proxy-pmip.o
  CC     hydra_pmi_proxy-pmip_cb.o
  CC     hydra_pmi_proxy-pmip_utils.o
  CC     hydra_pmi_proxy-pmip_pmi_v1.o
  CC     hydra_pmi_proxy-pmip_pmi_v2.o
  CC     hydra_pmi_proxy-common.o
  CC     hydra_pmi_proxy-pmi_v2_common.o
  CCLD   hydra_pmi_proxy.exe
  CC     mpiexec.o
  CC     utils.o
  CCLD   mpiexec.hydra.exe
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm'
make all-postamble
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src'
for dir in mpl openpa ; do \
    (cd $dir && make prefix=/cygdrive/c/cygwin/mpich2-1.4 exec_prefix=/cygdrive/c/cygwin/mpich2-1.4 \
    bindir=/cygdrive/c/cygwin/mpich2-1.4/bin libdir=/cygdrive/c/cygwin/mpich2-1.4/lib \
    includedir=/cygdrive/c/cygwin/mpich2-1.4/include docdir=/cygdrive/c/cygwin/mpich2-1.4/share/doc install) ; \
done
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
test -z "/cygdrive/c/cygwin/mpich2-1.4/lib" || /usr/bin/mkdir -p "/cygdrive/c/cygwin/mpich2-1.4/lib"
 /bin/sh ./libtool   --mode=install /usr/bin/install -c   libmpl.la '/cygdrive/c/cygwin/mpich2-1.4/lib'
libtool: install: /usr/bin/install -c .libs/libmpl.lai /cygdrive/c/cygwin/mpich2-1.4/lib/libmpl.la
libtool: install: /usr/bin/install -c .libs/libmpl.a /cygdrive/c/cygwin/mpich2-1.4/lib/libmpl.a
libtool: install: chmod 644 /cygdrive/c/cygwin/mpich2-1.4/lib/libmpl.a
libtool: install: ranlib /cygdrive/c/cygwin/mpich2-1.4/lib/libmpl.a
libtool: install: warning: remember to run `libtool --finish /usr/local/lib'
make[4]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
Making install in src
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
 /bin/sh ../libtool   --mode=install /usr/bin/install -c   libopa.la '/cygdrive/c/cygwin/mpich2-1.4/lib'
libtool: install: /usr/bin/install -c .libs/libopa.lai /cygdrive/c/cygwin/mpich2-1.4/lib/libopa.la
libtool: install: /usr/bin/install -c .libs/libopa.a /cygdrive/c/cygwin/mpich2-1.4/lib/libopa.a
libtool: install: chmod 644 /cygdrive/c/cygwin/mpich2-1.4/lib/libopa.a
libtool: install: ranlib /cygdrive/c/cygwin/mpich2-1.4/lib/libopa.a
test -z "/cygdrive/c/cygwin/mpich2-1.4/include" || /usr/bin/mkdir -p "/cygdrive/c/cygwin/mpich2-1.4/include"
 /usr/bin/install -c -m 644 opa_config.h opa_primitives.h opa_queue.h opa_util.h '/cygdrive/c/cygwin/mpich2-1.4/include'
/usr/bin/mkdir -p '/cygdrive/c/cygwin/mpich2-1.4/include/primitives'
 /usr/bin/install -c -m 644  primitives/opa_by_lock.h primitives/opa_emulated.h primitives/opa_gcc_ia64.h primitives/opa_gcc_intel_32_64.h primitives/opa_gcc_intel_32_64_barrier.h primitives/opa_gcc_intel_32_64_ops.h primitives/opa_gcc_intel_32_64_p3.h primitives/opa_gcc_intel_32_64_p3barrier.h primitives/opa_gcc_intrinsics.h primitives/opa_gcc_ppc.h primitives/opa_gcc_sicortex.h primitives/opa_nt_intrinsics.h primitives/opa_sun_atomic_ops.h primitives/opa_unsafe.h '/cygdrive/c/cygwin/mpich2-1.4/include/primitives'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
Making install in test
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[5]: Nothing to be done for `install-exec-am'.
make[5]: Nothing to be done for `install-data-am'.
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
test -z "/cygdrive/c/cygwin/mpich2-1.4/share/doc" || /usr/bin/mkdir -p "/cygdrive/c/cygwin/mpich2-1.4/share/doc"
 /usr/bin/install -c -m 644 README '/cygdrive/c/cygwin/mpich2-1.4/share/doc'
test -z "/cygdrive/c/cygwin/mpich2-1.4/lib/pkgconfig" || /usr/bin/mkdir -p "/cygdrive/c/cygwin/mpich2-1.4/lib/pkgconfig"
 /usr/bin/install -c -m 644 openpa.pc '/cygdrive/c/cygwin/mpich2-1.4/lib/pkgconfig'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src'
make all-postamble
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4'
( cd examples && make )
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/examples'
  CC              cpi.c
../bin/mpicc   -o cpi cpi.o  -lm
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/examples'
Make completed
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4'
if [ ! -d /usr/local ] ; then mkdir -p /usr/local ; fi
if [ ! -d /usr/local/share ] ; then mkdir -p /usr/local/share ; fi
if [ ! -d /usr/local/share/doc/ ] ; then mkdir -p /usr/local/share/doc/ ; fi
if [ ! -d /usr/local/share/man ] ; then mkdir -p /usr/local/share/man ; fi
if [ ! -d /usr/local/include ] ; then mkdir -p /usr/local/include ; fi
if [ ! -d /usr/local/lib ] ; then mkdir -p /usr/local/lib ; fi
make install-local
if [ "no" = "yes" ] ; then \
    /usr/bin/install -c -m 644 src/mpi/debugger/libtvmpich2.dll \
		/usr/local/lib/libtvmpich2.dll ; fi
if [ -n "" ] ; then \
    for pm in  /dev/null ; do \
	if [ -d src/pm/$pm ] ; then \
	     (cd src/pm/$pm && \
	make prefix=/usr/local bindir=/usr/local/bin install-alt ) ; \
	fi ; \
    done ; \
fi
/usr/bin/install -c -m 644  src/include/mpi.h /usr/local/include/mpi.h
/usr/bin/install -c -m 644  ./src/include/mpix.h /usr/local/include/mpix.h
/usr/bin/install -c -m 644  lib/libmpich.a /usr/local/lib/libmpich.a
/usr/bin/install -c -m 644 index.htm /usr/local/share/doc//index.htm
/usr/bin/install -c -m 644 index.htm /usr/local/share/doc//www1/index.htm
/usr/bin/install -c -m 644 MPI.html /usr/local/share/doc//www1/MPI.html
/usr/bin/install -c -m 644 mpicc.html /usr/local/share/doc//www1/mpicc.html
/usr/bin/install -c -m 644 mpicxx.html /usr/local/share/doc//www1/mpicxx.html
/usr/bin/install -c -m 644 mpiexec.html /usr/local/share/doc//www1/mpiexec.html
/usr/bin/install -c -m 644 mpif77.html /usr/local/share/doc//www1/mpif77.html
/usr/bin/install -c -m 644 mpif90.html /usr/local/share/doc//www1/mpif90.html
/usr/bin/install -c -m 644 index.htm /usr/local/share/doc//www3/index.htm
/usr/bin/install -c -m 644 MPI_Abort.html /usr/local/share/doc//www3/MPI_Abort.html
/usr/bin/install -c -m 644 MPI_Accumulate.html /usr/local/share/doc//www3/MPI_Accumulate.html
/usr/bin/install -c -m 644 MPI_Add_error_class.html /usr/local/share/doc//www3/MPI_Add_error_class.html
/usr/bin/install -c -m 644 MPI_Add_error_code.html /usr/local/share/doc//www3/MPI_Add_error_code.html
/usr/bin/install -c -m 644 MPI_Add_error_string.html /usr/local/share/doc//www3/MPI_Add_error_string.html
/usr/bin/install -c -m 644 MPI_Address.html /usr/local/share/doc//www3/MPI_Address.html
/usr/bin/install -c -m 644 MPI_Allgather.html /usr/local/share/doc//www3/MPI_Allgather.html
/usr/bin/install -c -m 644 MPI_Allgatherv.html /usr/local/share/doc//www3/MPI_Allgatherv.html
/usr/bin/install -c -m 644 MPI_Alloc_mem.html /usr/local/share/doc//www3/MPI_Alloc_mem.html
/usr/bin/install -c -m 644 MPI_Allreduce.html /usr/local/share/doc//www3/MPI_Allreduce.html
/usr/bin/install -c -m 644 MPI_Alltoall.html /usr/local/share/doc//www3/MPI_Alltoall.html
/usr/bin/install -c -m 644 MPI_Alltoallv.html /usr/local/share/doc//www3/MPI_Alltoallv.html
/usr/bin/install -c -m 644 MPI_Alltoallw.html /usr/local/share/doc//www3/MPI_Alltoallw.html
/usr/bin/install -c -m 644 MPI_Attr_delete.html /usr/local/share/doc//www3/MPI_Attr_delete.html
/usr/bin/install -c -m 644 MPI_Attr_get.html /usr/local/share/doc//www3/MPI_Attr_get.html
/usr/bin/install -c -m 644 MPI_Attr_put.html /usr/local/share/doc//www3/MPI_Attr_put.html
/usr/bin/install -c -m 644 MPI_Barrier.html /usr/local/share/doc//www3/MPI_Barrier.html
/usr/bin/install -c -m 644 MPI_Bcast.html /usr/local/share/doc//www3/MPI_Bcast.html
/usr/bin/install -c -m 644 MPI_Bsend.html /usr/local/share/doc//www3/MPI_Bsend.html
/usr/bin/install -c -m 644 MPI_Bsend_init.html /usr/local/share/doc//www3/MPI_Bsend_init.html
/usr/bin/install -c -m 644 MPI_Buffer_attach.html /usr/local/share/doc//www3/MPI_Buffer_attach.html
/usr/bin/install -c -m 644 MPI_Buffer_detach.html /usr/local/share/doc//www3/MPI_Buffer_detach.html
/usr/bin/install -c -m 644 MPI_Cancel.html /usr/local/share/doc//www3/MPI_Cancel.html
/usr/bin/install -c -m 644 MPI_Cart_coords.html /usr/local/share/doc//www3/MPI_Cart_coords.html
/usr/bin/install -c -m 644 MPI_Cart_create.html /usr/local/share/doc//www3/MPI_Cart_create.html
/usr/bin/install -c -m 644 MPI_Cart_get.html /usr/local/share/doc//www3/MPI_Cart_get.html
/usr/bin/install -c -m 644 MPI_Cart_map.html /usr/local/share/doc//www3/MPI_Cart_map.html
/usr/bin/install -c -m 644 MPI_Cart_rank.html /usr/local/share/doc//www3/MPI_Cart_rank.html
/usr/bin/install -c -m 644 MPI_Cart_shift.html /usr/local/share/doc//www3/MPI_Cart_shift.html
/usr/bin/install -c -m 644 MPI_Cart_sub.html /usr/local/share/doc//www3/MPI_Cart_sub.html
/usr/bin/install -c -m 644 MPI_Cartdim_get.html /usr/local/share/doc//www3/MPI_Cartdim_get.html
/usr/bin/install -c -m 644 MPI_Close_port.html /usr/local/share/doc//www3/MPI_Close_port.html
/usr/bin/install -c -m 644 MPI_Comm_accept.html /usr/local/share/doc//www3/MPI_Comm_accept.html
/usr/bin/install -c -m 644 MPI_Comm_call_errhandler.html /usr/local/share/doc//www3/MPI_Comm_call_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_compare.html /usr/local/share/doc//www3/MPI_Comm_compare.html
/usr/bin/install -c -m 644 MPI_Comm_connect.html /usr/local/share/doc//www3/MPI_Comm_connect.html
/usr/bin/install -c -m 644 MPI_Comm_create.html /usr/local/share/doc//www3/MPI_Comm_create.html
/usr/bin/install -c -m 644 MPI_Comm_create_errhandler.html /usr/local/share/doc//www3/MPI_Comm_create_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_create_keyval.html /usr/local/share/doc//www3/MPI_Comm_create_keyval.html
/usr/bin/install -c -m 644 MPI_Comm_delete_attr.html /usr/local/share/doc//www3/MPI_Comm_delete_attr.html
/usr/bin/install -c -m 644 MPI_Comm_disconnect.html /usr/local/share/doc//www3/MPI_Comm_disconnect.html
/usr/bin/install -c -m 644 MPI_Comm_dup.html /usr/local/share/doc//www3/MPI_Comm_dup.html
/usr/bin/install -c -m 644 MPI_Comm_free.html /usr/local/share/doc//www3/MPI_Comm_free.html
/usr/bin/install -c -m 644 MPI_Comm_free_keyval.html /usr/local/share/doc//www3/MPI_Comm_free_keyval.html
/usr/bin/install -c -m 644 MPI_Comm_get_attr.html /usr/local/share/doc//www3/MPI_Comm_get_attr.html
/usr/bin/install -c -m 644 MPI_Comm_get_errhandler.html /usr/local/share/doc//www3/MPI_Comm_get_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_get_name.html /usr/local/share/doc//www3/MPI_Comm_get_name.html
/usr/bin/install -c -m 644 MPI_Comm_get_parent.html /usr/local/share/doc//www3/MPI_Comm_get_parent.html
/usr/bin/install -c -m 644 MPI_Comm_group.html /usr/local/share/doc//www3/MPI_Comm_group.html
/usr/bin/install -c -m 644 MPI_Comm_join.html /usr/local/share/doc//www3/MPI_Comm_join.html
/usr/bin/install -c -m 644 MPI_Comm_rank.html /usr/local/share/doc//www3/MPI_Comm_rank.html
/usr/bin/install -c -m 644 MPI_Comm_remote_group.html /usr/local/share/doc//www3/MPI_Comm_remote_group.html
/usr/bin/install -c -m 644 MPI_Comm_remote_size.html /usr/local/share/doc//www3/MPI_Comm_remote_size.html
/usr/bin/install -c -m 644 MPI_Comm_set_attr.html /usr/local/share/doc//www3/MPI_Comm_set_attr.html
/usr/bin/install -c -m 644 MPI_Comm_set_errhandler.html /usr/local/share/doc//www3/MPI_Comm_set_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_set_name.html /usr/local/share/doc//www3/MPI_Comm_set_name.html
/usr/bin/install -c -m 644 MPI_Comm_size.html /usr/local/share/doc//www3/MPI_Comm_size.html
/usr/bin/install -c -m 644 MPI_Comm_spawn.html /usr/local/share/doc//www3/MPI_Comm_spawn.html
/usr/bin/install -c -m 644 MPI_Comm_spawn_multiple.html /usr/local/share/doc//www3/MPI_Comm_spawn_multiple.html
/usr/bin/install -c -m 644 MPI_Comm_split.html /usr/local/share/doc//www3/MPI_Comm_split.html
/usr/bin/install -c -m 644 MPI_Comm_test_inter.html /usr/local/share/doc//www3/MPI_Comm_test_inter.html
/usr/bin/install -c -m 644 MPI_Dims_create.html /usr/local/share/doc//www3/MPI_Dims_create.html
/usr/bin/install -c -m 644 MPI_Dist_graph_create.html /usr/local/share/doc//www3/MPI_Dist_graph_create.html
/usr/bin/install -c -m 644 MPI_Dist_graph_create_adjacent.html /usr/local/share/doc//www3/MPI_Dist_graph_create_adjacent.html
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors.html /usr/local/share/doc//www3/MPI_Dist_graph_neighbors.html
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors_count.html /usr/local/share/doc//www3/MPI_Dist_graph_neighbors_count.html
/usr/bin/install -c -m 644 MPI_Errhandler_create.html /usr/local/share/doc//www3/MPI_Errhandler_create.html
/usr/bin/install -c -m 644 MPI_Errhandler_free.html /usr/local/share/doc//www3/MPI_Errhandler_free.html
/usr/bin/install -c -m 644 MPI_Errhandler_get.html /usr/local/share/doc//www3/MPI_Errhandler_get.html
/usr/bin/install -c -m 644 MPI_Errhandler_set.html /usr/local/share/doc//www3/MPI_Errhandler_set.html
/usr/bin/install -c -m 644 MPI_Error_class.html /usr/local/share/doc//www3/MPI_Error_class.html
/usr/bin/install -c -m 644 MPI_Error_string.html /usr/local/share/doc//www3/MPI_Error_string.html
/usr/bin/install -c -m 644 MPI_Exscan.html /usr/local/share/doc//www3/MPI_Exscan.html
/usr/bin/install -c -m 644 MPI_File_c2f.html /usr/local/share/doc//www3/MPI_File_c2f.html
/usr/bin/install -c -m 644 MPI_File_call_errhandler.html /usr/local/share/doc//www3/MPI_File_call_errhandler.html
/usr/bin/install -c -m 644 MPI_File_close.html /usr/local/share/doc//www3/MPI_File_close.html
/usr/bin/install -c -m 644 MPI_File_create_errhandler.html /usr/local/share/doc//www3/MPI_File_create_errhandler.html
/usr/bin/install -c -m 644 MPI_File_delete.html /usr/local/share/doc//www3/MPI_File_delete.html
/usr/bin/install -c -m 644 MPI_File_f2c.html /usr/local/share/doc//www3/MPI_File_f2c.html
/usr/bin/install -c -m 644 MPI_File_get_amode.html /usr/local/share/doc//www3/MPI_File_get_amode.html
/usr/bin/install -c -m 644 MPI_File_get_atomicity.html /usr/local/share/doc//www3/MPI_File_get_atomicity.html
/usr/bin/install -c -m 644 MPI_File_get_byte_offset.html /usr/local/share/doc//www3/MPI_File_get_byte_offset.html
/usr/bin/install -c -m 644 MPI_File_get_errhandler.html /usr/local/share/doc//www3/MPI_File_get_errhandler.html
/usr/bin/install -c -m 644 MPI_File_get_group.html /usr/local/share/doc//www3/MPI_File_get_group.html
/usr/bin/install -c -m 644 MPI_File_get_info.html /usr/local/share/doc//www3/MPI_File_get_info.html
/usr/bin/install -c -m 644 MPI_File_get_position.html /usr/local/share/doc//www3/MPI_File_get_position.html
/usr/bin/install -c -m 644 MPI_File_get_position_shared.html /usr/local/share/doc//www3/MPI_File_get_position_shared.html
/usr/bin/install -c -m 644 MPI_File_get_size.html /usr/local/share/doc//www3/MPI_File_get_size.html
/usr/bin/install -c -m 644 MPI_File_get_type_extent.html /usr/local/share/doc//www3/MPI_File_get_type_extent.html
/usr/bin/install -c -m 644 MPI_File_get_view.html /usr/local/share/doc//www3/MPI_File_get_view.html
/usr/bin/install -c -m 644 MPI_File_iread.html /usr/local/share/doc//www3/MPI_File_iread.html
/usr/bin/install -c -m 644 MPI_File_iread_at.html /usr/local/share/doc//www3/MPI_File_iread_at.html
/usr/bin/install -c -m 644 MPI_File_iread_shared.html /usr/local/share/doc//www3/MPI_File_iread_shared.html
/usr/bin/install -c -m 644 MPI_File_iwrite.html /usr/local/share/doc//www3/MPI_File_iwrite.html
/usr/bin/install -c -m 644 MPI_File_iwrite_at.html /usr/local/share/doc//www3/MPI_File_iwrite_at.html
/usr/bin/install -c -m 644 MPI_File_iwrite_shared.html /usr/local/share/doc//www3/MPI_File_iwrite_shared.html
/usr/bin/install -c -m 644 MPI_File_open.html /usr/local/share/doc//www3/MPI_File_open.html
/usr/bin/install -c -m 644 MPI_File_preallocate.html /usr/local/share/doc//www3/MPI_File_preallocate.html
/usr/bin/install -c -m 644 MPI_File_read.html /usr/local/share/doc//www3/MPI_File_read.html
/usr/bin/install -c -m 644 MPI_File_read_all.html /usr/local/share/doc//www3/MPI_File_read_all.html
/usr/bin/install -c -m 644 MPI_File_read_all_begin.html /usr/local/share/doc//www3/MPI_File_read_all_begin.html
/usr/bin/install -c -m 644 MPI_File_read_all_end.html /usr/local/share/doc//www3/MPI_File_read_all_end.html
/usr/bin/install -c -m 644 MPI_File_read_at.html /usr/local/share/doc//www3/MPI_File_read_at.html
/usr/bin/install -c -m 644 MPI_File_read_at_all.html /usr/local/share/doc//www3/MPI_File_read_at_all.html
/usr/bin/install -c -m 644 MPI_File_read_at_all_begin.html /usr/local/share/doc//www3/MPI_File_read_at_all_begin.html
/usr/bin/install -c -m 644 MPI_File_read_at_all_end.html /usr/local/share/doc//www3/MPI_File_read_at_all_end.html
/usr/bin/install -c -m 644 MPI_File_read_ordered.html /usr/local/share/doc//www3/MPI_File_read_ordered.html
/usr/bin/install -c -m 644 MPI_File_read_ordered_begin.html /usr/local/share/doc//www3/MPI_File_read_ordered_begin.html
/usr/bin/install -c -m 644 MPI_File_read_ordered_end.html /usr/local/share/doc//www3/MPI_File_read_ordered_end.html
/usr/bin/install -c -m 644 MPI_File_read_shared.html /usr/local/share/doc//www3/MPI_File_read_shared.html
/usr/bin/install -c -m 644 MPI_File_seek.html /usr/local/share/doc//www3/MPI_File_seek.html
/usr/bin/install -c -m 644 MPI_File_seek_shared.html /usr/local/share/doc//www3/MPI_File_seek_shared.html
/usr/bin/install -c -m 644 MPI_File_set_atomicity.html /usr/local/share/doc//www3/MPI_File_set_atomicity.html
/usr/bin/install -c -m 644 MPI_File_set_errhandler.html /usr/local/share/doc//www3/MPI_File_set_errhandler.html
/usr/bin/install -c -m 644 MPI_File_set_info.html /usr/local/share/doc//www3/MPI_File_set_info.html
/usr/bin/install -c -m 644 MPI_File_set_size.html /usr/local/share/doc//www3/MPI_File_set_size.html
/usr/bin/install -c -m 644 MPI_File_set_view.html /usr/local/share/doc//www3/MPI_File_set_view.html
/usr/bin/install -c -m 644 MPI_File_sync.html /usr/local/share/doc//www3/MPI_File_sync.html
/usr/bin/install -c -m 644 MPI_File_write.html /usr/local/share/doc//www3/MPI_File_write.html
/usr/bin/install -c -m 644 MPI_File_write_all.html /usr/local/share/doc//www3/MPI_File_write_all.html
/usr/bin/install -c -m 644 MPI_File_write_all_begin.html /usr/local/share/doc//www3/MPI_File_write_all_begin.html
/usr/bin/install -c -m 644 MPI_File_write_all_end.html /usr/local/share/doc//www3/MPI_File_write_all_end.html
/usr/bin/install -c -m 644 MPI_File_write_at.html /usr/local/share/doc//www3/MPI_File_write_at.html
/usr/bin/install -c -m 644 MPI_File_write_at_all.html /usr/local/share/doc//www3/MPI_File_write_at_all.html
/usr/bin/install -c -m 644 MPI_File_write_at_all_begin.html /usr/local/share/doc//www3/MPI_File_write_at_all_begin.html
/usr/bin/install -c -m 644 MPI_File_write_at_all_end.html /usr/local/share/doc//www3/MPI_File_write_at_all_end.html
/usr/bin/install -c -m 644 MPI_File_write_ordered.html /usr/local/share/doc//www3/MPI_File_write_ordered.html
/usr/bin/install -c -m 644 MPI_File_write_ordered_begin.html /usr/local/share/doc//www3/MPI_File_write_ordered_begin.html
/usr/bin/install -c -m 644 MPI_File_write_ordered_end.html /usr/local/share/doc//www3/MPI_File_write_ordered_end.html
/usr/bin/install -c -m 644 MPI_File_write_shared.html /usr/local/share/doc//www3/MPI_File_write_shared.html
/usr/bin/install -c -m 644 MPI_Finalize.html /usr/local/share/doc//www3/MPI_Finalize.html
/usr/bin/install -c -m 644 MPI_Finalized.html /usr/local/share/doc//www3/MPI_Finalized.html
/usr/bin/install -c -m 644 MPI_Free_mem.html /usr/local/share/doc//www3/MPI_Free_mem.html
/usr/bin/install -c -m 644 MPI_Gather.html /usr/local/share/doc//www3/MPI_Gather.html
/usr/bin/install -c -m 644 MPI_Gatherv.html /usr/local/share/doc//www3/MPI_Gatherv.html
/usr/bin/install -c -m 644 MPI_Get.html /usr/local/share/doc//www3/MPI_Get.html
/usr/bin/install -c -m 644 MPI_Get_address.html /usr/local/share/doc//www3/MPI_Get_address.html
/usr/bin/install -c -m 644 MPI_Get_count.html /usr/local/share/doc//www3/MPI_Get_count.html
/usr/bin/install -c -m 644 MPI_Get_elements.html /usr/local/share/doc//www3/MPI_Get_elements.html
/usr/bin/install -c -m 644 MPI_Get_processor_name.html /usr/local/share/doc//www3/MPI_Get_processor_name.html
/usr/bin/install -c -m 644 MPI_Get_version.html /usr/local/share/doc//www3/MPI_Get_version.html
/usr/bin/install -c -m 644 MPI_Graph_create.html /usr/local/share/doc//www3/MPI_Graph_create.html
/usr/bin/install -c -m 644 MPI_Graph_get.html /usr/local/share/doc//www3/MPI_Graph_get.html
/usr/bin/install -c -m 644 MPI_Graph_map.html /usr/local/share/doc//www3/MPI_Graph_map.html
/usr/bin/install -c -m 644 MPI_Graph_neighbors.html /usr/local/share/doc//www3/MPI_Graph_neighbors.html
/usr/bin/install -c -m 644 MPI_Graph_neighbors_count.html /usr/local/share/doc//www3/MPI_Graph_neighbors_count.html
/usr/bin/install -c -m 644 MPI_Graphdims_get.html /usr/local/share/doc//www3/MPI_Graphdims_get.html
/usr/bin/install -c -m 644 MPI_Grequest_complete.html /usr/local/share/doc//www3/MPI_Grequest_complete.html
/usr/bin/install -c -m 644 MPI_Grequest_start.html /usr/local/share/doc//www3/MPI_Grequest_start.html
/usr/bin/install -c -m 644 MPI_Group_compare.html /usr/local/share/doc//www3/MPI_Group_compare.html
/usr/bin/install -c -m 644 MPI_Group_difference.html /usr/local/share/doc//www3/MPI_Group_difference.html
/usr/bin/install -c -m 644 MPI_Group_excl.html /usr/local/share/doc//www3/MPI_Group_excl.html
/usr/bin/install -c -m 644 MPI_Group_free.html /usr/local/share/doc//www3/MPI_Group_free.html
/usr/bin/install -c -m 644 MPI_Group_incl.html /usr/local/share/doc//www3/MPI_Group_incl.html
/usr/bin/install -c -m 644 MPI_Group_intersection.html /usr/local/share/doc//www3/MPI_Group_intersection.html
/usr/bin/install -c -m 644 MPI_Group_range_excl.html /usr/local/share/doc//www3/MPI_Group_range_excl.html
/usr/bin/install -c -m 644 MPI_Group_range_incl.html /usr/local/share/doc//www3/MPI_Group_range_incl.html
/usr/bin/install -c -m 644 MPI_Group_rank.html /usr/local/share/doc//www3/MPI_Group_rank.html
/usr/bin/install -c -m 644 MPI_Group_size.html /usr/local/share/doc//www3/MPI_Group_size.html
/usr/bin/install -c -m 644 MPI_Group_translate_ranks.html /usr/local/share/doc//www3/MPI_Group_translate_ranks.html
/usr/bin/install -c -m 644 MPI_Group_union.html /usr/local/share/doc//www3/MPI_Group_union.html
/usr/bin/install -c -m 644 MPI_Ibsend.html /usr/local/share/doc//www3/MPI_Ibsend.html
/usr/bin/install -c -m 644 MPI_Info_create.html /usr/local/share/doc//www3/MPI_Info_create.html
/usr/bin/install -c -m 644 MPI_Info_delete.html /usr/local/share/doc//www3/MPI_Info_delete.html
/usr/bin/install -c -m 644 MPI_Info_dup.html /usr/local/share/doc//www3/MPI_Info_dup.html
/usr/bin/install -c -m 644 MPI_Info_free.html /usr/local/share/doc//www3/MPI_Info_free.html
/usr/bin/install -c -m 644 MPI_Info_get.html /usr/local/share/doc//www3/MPI_Info_get.html
/usr/bin/install -c -m 644 MPI_Info_get_nkeys.html /usr/local/share/doc//www3/MPI_Info_get_nkeys.html
/usr/bin/install -c -m 644 MPI_Info_get_nthkey.html /usr/local/share/doc//www3/MPI_Info_get_nthkey.html
/usr/bin/install -c -m 644 MPI_Info_get_valuelen.html /usr/local/share/doc//www3/MPI_Info_get_valuelen.html
/usr/bin/install -c -m 644 MPI_Info_set.html /usr/local/share/doc//www3/MPI_Info_set.html
/usr/bin/install -c -m 644 MPI_Init.html /usr/local/share/doc//www3/MPI_Init.html
/usr/bin/install -c -m 644 MPI_Init_thread.html /usr/local/share/doc//www3/MPI_Init_thread.html
/usr/bin/install -c -m 644 MPI_Initialized.html /usr/local/share/doc//www3/MPI_Initialized.html
/usr/bin/install -c -m 644 MPI_Intercomm_create.html /usr/local/share/doc//www3/MPI_Intercomm_create.html
/usr/bin/install -c -m 644 MPI_Intercomm_merge.html /usr/local/share/doc//www3/MPI_Intercomm_merge.html
/usr/bin/install -c -m 644 MPI_Iprobe.html /usr/local/share/doc//www3/MPI_Iprobe.html
/usr/bin/install -c -m 644 MPI_Irecv.html /usr/local/share/doc//www3/MPI_Irecv.html
/usr/bin/install -c -m 644 MPI_Irsend.html /usr/local/share/doc//www3/MPI_Irsend.html
/usr/bin/install -c -m 644 MPI_Is_thread_main.html /usr/local/share/doc//www3/MPI_Is_thread_main.html
/usr/bin/install -c -m 644 MPI_Isend.html /usr/local/share/doc//www3/MPI_Isend.html
/usr/bin/install -c -m 644 MPI_Issend.html /usr/local/share/doc//www3/MPI_Issend.html
/usr/bin/install -c -m 644 MPI_Keyval_create.html /usr/local/share/doc//www3/MPI_Keyval_create.html
/usr/bin/install -c -m 644 MPI_Keyval_free.html /usr/local/share/doc//www3/MPI_Keyval_free.html
/usr/bin/install -c -m 644 MPI_Lookup_name.html /usr/local/share/doc//www3/MPI_Lookup_name.html
/usr/bin/install -c -m 644 MPI_Op_commute.html /usr/local/share/doc//www3/MPI_Op_commute.html
/usr/bin/install -c -m 644 MPI_Op_create.html /usr/local/share/doc//www3/MPI_Op_create.html
/usr/bin/install -c -m 644 MPI_Op_free.html /usr/local/share/doc//www3/MPI_Op_free.html
/usr/bin/install -c -m 644 MPI_Open_port.html /usr/local/share/doc//www3/MPI_Open_port.html
/usr/bin/install -c -m 644 MPI_Pack.html /usr/local/share/doc//www3/MPI_Pack.html
/usr/bin/install -c -m 644 MPI_Pack_external.html /usr/local/share/doc//www3/MPI_Pack_external.html
/usr/bin/install -c -m 644 MPI_Pack_external_size.html /usr/local/share/doc//www3/MPI_Pack_external_size.html
/usr/bin/install -c -m 644 MPI_Pack_size.html /usr/local/share/doc//www3/MPI_Pack_size.html
/usr/bin/install -c -m 644 MPI_Pcontrol.html /usr/local/share/doc//www3/MPI_Pcontrol.html
/usr/bin/install -c -m 644 MPI_Probe.html /usr/local/share/doc//www3/MPI_Probe.html
/usr/bin/install -c -m 644 MPI_Publish_name.html /usr/local/share/doc//www3/MPI_Publish_name.html
/usr/bin/install -c -m 644 MPI_Put.html /usr/local/share/doc//www3/MPI_Put.html
/usr/bin/install -c -m 644 MPI_Query_thread.html /usr/local/share/doc//www3/MPI_Query_thread.html
/usr/bin/install -c -m 644 MPI_Recv.html /usr/local/share/doc//www3/MPI_Recv.html
/usr/bin/install -c -m 644 MPI_Recv_init.html /usr/local/share/doc//www3/MPI_Recv_init.html
/usr/bin/install -c -m 644 MPI_Reduce.html /usr/local/share/doc//www3/MPI_Reduce.html
/usr/bin/install -c -m 644 MPI_Reduce_local.html /usr/local/share/doc//www3/MPI_Reduce_local.html
/usr/bin/install -c -m 644 MPI_Reduce_scatter.html /usr/local/share/doc//www3/MPI_Reduce_scatter.html
/usr/bin/install -c -m 644 MPI_Reduce_scatter_block.html /usr/local/share/doc//www3/MPI_Reduce_scatter_block.html
/usr/bin/install -c -m 644 MPI_Register_datarep.html /usr/local/share/doc//www3/MPI_Register_datarep.html
/usr/bin/install -c -m 644 MPI_Request_free.html /usr/local/share/doc//www3/MPI_Request_free.html
/usr/bin/install -c -m 644 MPI_Request_get_status.html /usr/local/share/doc//www3/MPI_Request_get_status.html
/usr/bin/install -c -m 644 MPI_Rsend.html /usr/local/share/doc//www3/MPI_Rsend.html
/usr/bin/install -c -m 644 MPI_Rsend_init.html /usr/local/share/doc//www3/MPI_Rsend_init.html
/usr/bin/install -c -m 644 MPI_Scan.html /usr/local/share/doc//www3/MPI_Scan.html
/usr/bin/install -c -m 644 MPI_Scatter.html /usr/local/share/doc//www3/MPI_Scatter.html
/usr/bin/install -c -m 644 MPI_Scatterv.html /usr/local/share/doc//www3/MPI_Scatterv.html
/usr/bin/install -c -m 644 MPI_Send.html /usr/local/share/doc//www3/MPI_Send.html
/usr/bin/install -c -m 644 MPI_Send_init.html /usr/local/share/doc//www3/MPI_Send_init.html
/usr/bin/install -c -m 644 MPI_Sendrecv.html /usr/local/share/doc//www3/MPI_Sendrecv.html
/usr/bin/install -c -m 644 MPI_Sendrecv_replace.html /usr/local/share/doc//www3/MPI_Sendrecv_replace.html
/usr/bin/install -c -m 644 MPI_Ssend.html /usr/local/share/doc//www3/MPI_Ssend.html
/usr/bin/install -c -m 644 MPI_Ssend_init.html /usr/local/share/doc//www3/MPI_Ssend_init.html
/usr/bin/install -c -m 644 MPI_Start.html /usr/local/share/doc//www3/MPI_Start.html
/usr/bin/install -c -m 644 MPI_Startall.html /usr/local/share/doc//www3/MPI_Startall.html
/usr/bin/install -c -m 644 MPI_Status_set_cancelled.html /usr/local/share/doc//www3/MPI_Status_set_cancelled.html
/usr/bin/install -c -m 644 MPI_Status_set_elements.html /usr/local/share/doc//www3/MPI_Status_set_elements.html
/usr/bin/install -c -m 644 MPI_Test.html /usr/local/share/doc//www3/MPI_Test.html
/usr/bin/install -c -m 644 MPI_Test_cancelled.html /usr/local/share/doc//www3/MPI_Test_cancelled.html
/usr/bin/install -c -m 644 MPI_Testall.html /usr/local/share/doc//www3/MPI_Testall.html
/usr/bin/install -c -m 644 MPI_Testany.html /usr/local/share/doc//www3/MPI_Testany.html
/usr/bin/install -c -m 644 MPI_Testsome.html /usr/local/share/doc//www3/MPI_Testsome.html
/usr/bin/install -c -m 644 MPI_Topo_test.html /usr/local/share/doc//www3/MPI_Topo_test.html
/usr/bin/install -c -m 644 MPI_Type_commit.html /usr/local/share/doc//www3/MPI_Type_commit.html
/usr/bin/install -c -m 644 MPI_Type_contiguous.html /usr/local/share/doc//www3/MPI_Type_contiguous.html
/usr/bin/install -c -m 644 MPI_Type_create_darray.html /usr/local/share/doc//www3/MPI_Type_create_darray.html
/usr/bin/install -c -m 644 MPI_Type_create_hindexed.html /usr/local/share/doc//www3/MPI_Type_create_hindexed.html
/usr/bin/install -c -m 644 MPI_Type_create_hvector.html /usr/local/share/doc//www3/MPI_Type_create_hvector.html
/usr/bin/install -c -m 644 MPI_Type_create_indexed_block.html /usr/local/share/doc//www3/MPI_Type_create_indexed_block.html
/usr/bin/install -c -m 644 MPI_Type_create_keyval.html /usr/local/share/doc//www3/MPI_Type_create_keyval.html
/usr/bin/install -c -m 644 MPI_Type_create_resized.html /usr/local/share/doc//www3/MPI_Type_create_resized.html
/usr/bin/install -c -m 644 MPI_Type_create_struct.html /usr/local/share/doc//www3/MPI_Type_create_struct.html
/usr/bin/install -c -m 644 MPI_Type_create_subarray.html /usr/local/share/doc//www3/MPI_Type_create_subarray.html
/usr/bin/install -c -m 644 MPI_Type_delete_attr.html /usr/local/share/doc//www3/MPI_Type_delete_attr.html
/usr/bin/install -c -m 644 MPI_Type_dup.html /usr/local/share/doc//www3/MPI_Type_dup.html
/usr/bin/install -c -m 644 MPI_Type_extent.html /usr/local/share/doc//www3/MPI_Type_extent.html
/usr/bin/install -c -m 644 MPI_Type_free.html /usr/local/share/doc//www3/MPI_Type_free.html
/usr/bin/install -c -m 644 MPI_Type_free_keyval.html /usr/local/share/doc//www3/MPI_Type_free_keyval.html
/usr/bin/install -c -m 644 MPI_Type_get_attr.html /usr/local/share/doc//www3/MPI_Type_get_attr.html
/usr/bin/install -c -m 644 MPI_Type_get_contents.html /usr/local/share/doc//www3/MPI_Type_get_contents.html
/usr/bin/install -c -m 644 MPI_Type_get_envelope.html /usr/local/share/doc//www3/MPI_Type_get_envelope.html
/usr/bin/install -c -m 644 MPI_Type_get_extent.html /usr/local/share/doc//www3/MPI_Type_get_extent.html
/usr/bin/install -c -m 644 MPI_Type_get_name.html /usr/local/share/doc//www3/MPI_Type_get_name.html
/usr/bin/install -c -m 644 MPI_Type_get_true_extent.html /usr/local/share/doc//www3/MPI_Type_get_true_extent.html
/usr/bin/install -c -m 644 MPI_Type_hindexed.html /usr/local/share/doc//www3/MPI_Type_hindexed.html
/usr/bin/install -c -m 644 MPI_Type_hvector.html /usr/local/share/doc//www3/MPI_Type_hvector.html
/usr/bin/install -c -m 644 MPI_Type_indexed.html /usr/local/share/doc//www3/MPI_Type_indexed.html
/usr/bin/install -c -m 644 MPI_Type_lb.html /usr/local/share/doc//www3/MPI_Type_lb.html
/usr/bin/install -c -m 644 MPI_Type_match_size.html /usr/local/share/doc//www3/MPI_Type_match_size.html
/usr/bin/install -c -m 644 MPI_Type_set_attr.html /usr/local/share/doc//www3/MPI_Type_set_attr.html
/usr/bin/install -c -m 644 MPI_Type_set_name.html /usr/local/share/doc//www3/MPI_Type_set_name.html
/usr/bin/install -c -m 644 MPI_Type_size.html /usr/local/share/doc//www3/MPI_Type_size.html
/usr/bin/install -c -m 644 MPI_Type_struct.html /usr/local/share/doc//www3/MPI_Type_struct.html
/usr/bin/install -c -m 644 MPI_Type_ub.html /usr/local/share/doc//www3/MPI_Type_ub.html
/usr/bin/install -c -m 644 MPI_Type_vector.html /usr/local/share/doc//www3/MPI_Type_vector.html
/usr/bin/install -c -m 644 MPI_Unpack.html /usr/local/share/doc//www3/MPI_Unpack.html
/usr/bin/install -c -m 644 MPI_Unpack_external.html /usr/local/share/doc//www3/MPI_Unpack_external.html
/usr/bin/install -c -m 644 MPI_Unpublish_name.html /usr/local/share/doc//www3/MPI_Unpublish_name.html
/usr/bin/install -c -m 644 MPI_Wait.html /usr/local/share/doc//www3/MPI_Wait.html
/usr/bin/install -c -m 644 MPI_Waitall.html /usr/local/share/doc//www3/MPI_Waitall.html
/usr/bin/install -c -m 644 MPI_Waitany.html /usr/local/share/doc//www3/MPI_Waitany.html
/usr/bin/install -c -m 644 MPI_Waitsome.html /usr/local/share/doc//www3/MPI_Waitsome.html
/usr/bin/install -c -m 644 MPI_Win_call_errhandler.html /usr/local/share/doc//www3/MPI_Win_call_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_complete.html /usr/local/share/doc//www3/MPI_Win_complete.html
/usr/bin/install -c -m 644 MPI_Win_create.html /usr/local/share/doc//www3/MPI_Win_create.html
/usr/bin/install -c -m 644 MPI_Win_create_errhandler.html /usr/local/share/doc//www3/MPI_Win_create_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_create_keyval.html /usr/local/share/doc//www3/MPI_Win_create_keyval.html
/usr/bin/install -c -m 644 MPI_Win_delete_attr.html /usr/local/share/doc//www3/MPI_Win_delete_attr.html
/usr/bin/install -c -m 644 MPI_Win_fence.html /usr/local/share/doc//www3/MPI_Win_fence.html
/usr/bin/install -c -m 644 MPI_Win_free.html /usr/local/share/doc//www3/MPI_Win_free.html
/usr/bin/install -c -m 644 MPI_Win_free_keyval.html /usr/local/share/doc//www3/MPI_Win_free_keyval.html
/usr/bin/install -c -m 644 MPI_Win_get_attr.html /usr/local/share/doc//www3/MPI_Win_get_attr.html
/usr/bin/install -c -m 644 MPI_Win_get_errhandler.html /usr/local/share/doc//www3/MPI_Win_get_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_get_group.html /usr/local/share/doc//www3/MPI_Win_get_group.html
/usr/bin/install -c -m 644 MPI_Win_get_name.html /usr/local/share/doc//www3/MPI_Win_get_name.html
/usr/bin/install -c -m 644 MPI_Win_lock.html /usr/local/share/doc//www3/MPI_Win_lock.html
/usr/bin/install -c -m 644 MPI_Win_post.html /usr/local/share/doc//www3/MPI_Win_post.html
/usr/bin/install -c -m 644 MPI_Win_set_attr.html /usr/local/share/doc//www3/MPI_Win_set_attr.html
/usr/bin/install -c -m 644 MPI_Win_set_errhandler.html /usr/local/share/doc//www3/MPI_Win_set_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_set_name.html /usr/local/share/doc//www3/MPI_Win_set_name.html
/usr/bin/install -c -m 644 MPI_Win_start.html /usr/local/share/doc//www3/MPI_Win_start.html
/usr/bin/install -c -m 644 MPI_Win_test.html /usr/local/share/doc//www3/MPI_Win_test.html
/usr/bin/install -c -m 644 MPI_Win_unlock.html /usr/local/share/doc//www3/MPI_Win_unlock.html
/usr/bin/install -c -m 644 MPI_Win_wait.html /usr/local/share/doc//www3/MPI_Win_wait.html
/usr/bin/install -c -m 644 MPI_Wtick.html /usr/local/share/doc//www3/MPI_Wtick.html
/usr/bin/install -c -m 644 MPI_Wtime.html /usr/local/share/doc//www3/MPI_Wtime.html
/usr/bin/install -c -m 644 MPIX_Group_comm_create.html /usr/local/share/doc//www3/MPIX_Group_comm_create.html
/usr/bin/install -c -m 644 MPI.1 /usr/local/share/man/man1/MPI.1
/usr/bin/install -c -m 644 mpicc.1 /usr/local/share/man/man1/mpicc.1
/usr/bin/install -c -m 644 mpicxx.1 /usr/local/share/man/man1/mpicxx.1
/usr/bin/install -c -m 644 mpiexec.1 /usr/local/share/man/man1/mpiexec.1
/usr/bin/install -c -m 644 mpif77.1 /usr/local/share/man/man1/mpif77.1
/usr/bin/install -c -m 644 mpif90.1 /usr/local/share/man/man1/mpif90.1
/usr/bin/install -c -m 644 MPI_Abort.3 /usr/local/share/man/man3/MPI_Abort.3
/usr/bin/install -c -m 644 MPI_Accumulate.3 /usr/local/share/man/man3/MPI_Accumulate.3
/usr/bin/install -c -m 644 MPI_Add_error_class.3 /usr/local/share/man/man3/MPI_Add_error_class.3
/usr/bin/install -c -m 644 MPI_Add_error_code.3 /usr/local/share/man/man3/MPI_Add_error_code.3
/usr/bin/install -c -m 644 MPI_Add_error_string.3 /usr/local/share/man/man3/MPI_Add_error_string.3
/usr/bin/install -c -m 644 MPI_Address.3 /usr/local/share/man/man3/MPI_Address.3
/usr/bin/install -c -m 644 MPI_Allgather.3 /usr/local/share/man/man3/MPI_Allgather.3
/usr/bin/install -c -m 644 MPI_Allgatherv.3 /usr/local/share/man/man3/MPI_Allgatherv.3
/usr/bin/install -c -m 644 MPI_Alloc_mem.3 /usr/local/share/man/man3/MPI_Alloc_mem.3
/usr/bin/install -c -m 644 MPI_Allreduce.3 /usr/local/share/man/man3/MPI_Allreduce.3
/usr/bin/install -c -m 644 MPI_Alltoall.3 /usr/local/share/man/man3/MPI_Alltoall.3
/usr/bin/install -c -m 644 MPI_Alltoallv.3 /usr/local/share/man/man3/MPI_Alltoallv.3
/usr/bin/install -c -m 644 MPI_Alltoallw.3 /usr/local/share/man/man3/MPI_Alltoallw.3
/usr/bin/install -c -m 644 MPI_Attr_delete.3 /usr/local/share/man/man3/MPI_Attr_delete.3
/usr/bin/install -c -m 644 MPI_Attr_get.3 /usr/local/share/man/man3/MPI_Attr_get.3
/usr/bin/install -c -m 644 MPI_Attr_put.3 /usr/local/share/man/man3/MPI_Attr_put.3
/usr/bin/install -c -m 644 MPI_Barrier.3 /usr/local/share/man/man3/MPI_Barrier.3
/usr/bin/install -c -m 644 MPI_Bcast.3 /usr/local/share/man/man3/MPI_Bcast.3
/usr/bin/install -c -m 644 MPI_Bsend.3 /usr/local/share/man/man3/MPI_Bsend.3
/usr/bin/install -c -m 644 MPI_Bsend_init.3 /usr/local/share/man/man3/MPI_Bsend_init.3
/usr/bin/install -c -m 644 MPI_Buffer_attach.3 /usr/local/share/man/man3/MPI_Buffer_attach.3
/usr/bin/install -c -m 644 MPI_Buffer_detach.3 /usr/local/share/man/man3/MPI_Buffer_detach.3
/usr/bin/install -c -m 644 MPI_Cancel.3 /usr/local/share/man/man3/MPI_Cancel.3
/usr/bin/install -c -m 644 MPI_Cart_coords.3 /usr/local/share/man/man3/MPI_Cart_coords.3
/usr/bin/install -c -m 644 MPI_Cart_create.3 /usr/local/share/man/man3/MPI_Cart_create.3
/usr/bin/install -c -m 644 MPI_Cart_get.3 /usr/local/share/man/man3/MPI_Cart_get.3
/usr/bin/install -c -m 644 MPI_Cart_map.3 /usr/local/share/man/man3/MPI_Cart_map.3
/usr/bin/install -c -m 644 MPI_Cart_rank.3 /usr/local/share/man/man3/MPI_Cart_rank.3
/usr/bin/install -c -m 644 MPI_Cart_shift.3 /usr/local/share/man/man3/MPI_Cart_shift.3
/usr/bin/install -c -m 644 MPI_Cart_sub.3 /usr/local/share/man/man3/MPI_Cart_sub.3
/usr/bin/install -c -m 644 MPI_Cartdim_get.3 /usr/local/share/man/man3/MPI_Cartdim_get.3
/usr/bin/install -c -m 644 MPI_Close_port.3 /usr/local/share/man/man3/MPI_Close_port.3
/usr/bin/install -c -m 644 MPI_Comm_accept.3 /usr/local/share/man/man3/MPI_Comm_accept.3
/usr/bin/install -c -m 644 MPI_Comm_call_errhandler.3 /usr/local/share/man/man3/MPI_Comm_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_compare.3 /usr/local/share/man/man3/MPI_Comm_compare.3
/usr/bin/install -c -m 644 MPI_Comm_connect.3 /usr/local/share/man/man3/MPI_Comm_connect.3
/usr/bin/install -c -m 644 MPI_Comm_create.3 /usr/local/share/man/man3/MPI_Comm_create.3
/usr/bin/install -c -m 644 MPI_Comm_create_errhandler.3 /usr/local/share/man/man3/MPI_Comm_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_create_keyval.3 /usr/local/share/man/man3/MPI_Comm_create_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_delete_attr.3 /usr/local/share/man/man3/MPI_Comm_delete_attr.3
/usr/bin/install -c -m 644 MPI_Comm_disconnect.3 /usr/local/share/man/man3/MPI_Comm_disconnect.3
/usr/bin/install -c -m 644 MPI_Comm_dup.3 /usr/local/share/man/man3/MPI_Comm_dup.3
/usr/bin/install -c -m 644 MPI_Comm_free.3 /usr/local/share/man/man3/MPI_Comm_free.3
/usr/bin/install -c -m 644 MPI_Comm_free_keyval.3 /usr/local/share/man/man3/MPI_Comm_free_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_get_attr.3 /usr/local/share/man/man3/MPI_Comm_get_attr.3
/usr/bin/install -c -m 644 MPI_Comm_get_errhandler.3 /usr/local/share/man/man3/MPI_Comm_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_get_name.3 /usr/local/share/man/man3/MPI_Comm_get_name.3
/usr/bin/install -c -m 644 MPI_Comm_get_parent.3 /usr/local/share/man/man3/MPI_Comm_get_parent.3
/usr/bin/install -c -m 644 MPI_Comm_group.3 /usr/local/share/man/man3/MPI_Comm_group.3
/usr/bin/install -c -m 644 MPI_Comm_join.3 /usr/local/share/man/man3/MPI_Comm_join.3
/usr/bin/install -c -m 644 MPI_Comm_rank.3 /usr/local/share/man/man3/MPI_Comm_rank.3
/usr/bin/install -c -m 644 MPI_Comm_remote_group.3 /usr/local/share/man/man3/MPI_Comm_remote_group.3
/usr/bin/install -c -m 644 MPI_Comm_remote_size.3 /usr/local/share/man/man3/MPI_Comm_remote_size.3
/usr/bin/install -c -m 644 MPI_Comm_set_attr.3 /usr/local/share/man/man3/MPI_Comm_set_attr.3
/usr/bin/install -c -m 644 MPI_Comm_set_errhandler.3 /usr/local/share/man/man3/MPI_Comm_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_set_name.3 /usr/local/share/man/man3/MPI_Comm_set_name.3
/usr/bin/install -c -m 644 MPI_Comm_size.3 /usr/local/share/man/man3/MPI_Comm_size.3
/usr/bin/install -c -m 644 MPI_Comm_spawn.3 /usr/local/share/man/man3/MPI_Comm_spawn.3
/usr/bin/install -c -m 644 MPI_Comm_spawn_multiple.3 /usr/local/share/man/man3/MPI_Comm_spawn_multiple.3
/usr/bin/install -c -m 644 MPI_Comm_split.3 /usr/local/share/man/man3/MPI_Comm_split.3
/usr/bin/install -c -m 644 MPI_Comm_test_inter.3 /usr/local/share/man/man3/MPI_Comm_test_inter.3
/usr/bin/install -c -m 644 MPI_Dims_create.3 /usr/local/share/man/man3/MPI_Dims_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create.3 /usr/local/share/man/man3/MPI_Dist_graph_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create_adjacent.3 /usr/local/share/man/man3/MPI_Dist_graph_create_adjacent.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors.3 /usr/local/share/man/man3/MPI_Dist_graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors_count.3 /usr/local/share/man/man3/MPI_Dist_graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Errhandler_create.3 /usr/local/share/man/man3/MPI_Errhandler_create.3
/usr/bin/install -c -m 644 MPI_Errhandler_free.3 /usr/local/share/man/man3/MPI_Errhandler_free.3
/usr/bin/install -c -m 644 MPI_Errhandler_get.3 /usr/local/share/man/man3/MPI_Errhandler_get.3
/usr/bin/install -c -m 644 MPI_Errhandler_set.3 /usr/local/share/man/man3/MPI_Errhandler_set.3
/usr/bin/install -c -m 644 MPI_Error_class.3 /usr/local/share/man/man3/MPI_Error_class.3
/usr/bin/install -c -m 644 MPI_Error_string.3 /usr/local/share/man/man3/MPI_Error_string.3
/usr/bin/install -c -m 644 MPI_Exscan.3 /usr/local/share/man/man3/MPI_Exscan.3
/usr/bin/install -c -m 644 MPI_File_c2f.3 /usr/local/share/man/man3/MPI_File_c2f.3
/usr/bin/install -c -m 644 MPI_File_call_errhandler.3 /usr/local/share/man/man3/MPI_File_call_errhandler.3
/usr/bin/install -c -m 644 MPI_File_close.3 /usr/local/share/man/man3/MPI_File_close.3
/usr/bin/install -c -m 644 MPI_File_create_errhandler.3 /usr/local/share/man/man3/MPI_File_create_errhandler.3
/usr/bin/install -c -m 644 MPI_File_delete.3 /usr/local/share/man/man3/MPI_File_delete.3
/usr/bin/install -c -m 644 MPI_File_f2c.3 /usr/local/share/man/man3/MPI_File_f2c.3
/usr/bin/install -c -m 644 MPI_File_get_amode.3 /usr/local/share/man/man3/MPI_File_get_amode.3
/usr/bin/install -c -m 644 MPI_File_get_atomicity.3 /usr/local/share/man/man3/MPI_File_get_atomicity.3
/usr/bin/install -c -m 644 MPI_File_get_byte_offset.3 /usr/local/share/man/man3/MPI_File_get_byte_offset.3
/usr/bin/install -c -m 644 MPI_File_get_errhandler.3 /usr/local/share/man/man3/MPI_File_get_errhandler.3
/usr/bin/install -c -m 644 MPI_File_get_group.3 /usr/local/share/man/man3/MPI_File_get_group.3
/usr/bin/install -c -m 644 MPI_File_get_info.3 /usr/local/share/man/man3/MPI_File_get_info.3
/usr/bin/install -c -m 644 MPI_File_get_position.3 /usr/local/share/man/man3/MPI_File_get_position.3
/usr/bin/install -c -m 644 MPI_File_get_position_shared.3 /usr/local/share/man/man3/MPI_File_get_position_shared.3
/usr/bin/install -c -m 644 MPI_File_get_size.3 /usr/local/share/man/man3/MPI_File_get_size.3
/usr/bin/install -c -m 644 MPI_File_get_type_extent.3 /usr/local/share/man/man3/MPI_File_get_type_extent.3
/usr/bin/install -c -m 644 MPI_File_get_view.3 /usr/local/share/man/man3/MPI_File_get_view.3
/usr/bin/install -c -m 644 MPI_File_iread.3 /usr/local/share/man/man3/MPI_File_iread.3
/usr/bin/install -c -m 644 MPI_File_iread_at.3 /usr/local/share/man/man3/MPI_File_iread_at.3
/usr/bin/install -c -m 644 MPI_File_iread_shared.3 /usr/local/share/man/man3/MPI_File_iread_shared.3
/usr/bin/install -c -m 644 MPI_File_iwrite.3 /usr/local/share/man/man3/MPI_File_iwrite.3
/usr/bin/install -c -m 644 MPI_File_iwrite_at.3 /usr/local/share/man/man3/MPI_File_iwrite_at.3
/usr/bin/install -c -m 644 MPI_File_iwrite_shared.3 /usr/local/share/man/man3/MPI_File_iwrite_shared.3
/usr/bin/install -c -m 644 MPI_File_open.3 /usr/local/share/man/man3/MPI_File_open.3
/usr/bin/install -c -m 644 MPI_File_preallocate.3 /usr/local/share/man/man3/MPI_File_preallocate.3
/usr/bin/install -c -m 644 MPI_File_read.3 /usr/local/share/man/man3/MPI_File_read.3
/usr/bin/install -c -m 644 MPI_File_read_all.3 /usr/local/share/man/man3/MPI_File_read_all.3
/usr/bin/install -c -m 644 MPI_File_read_all_begin.3 /usr/local/share/man/man3/MPI_File_read_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_all_end.3 /usr/local/share/man/man3/MPI_File_read_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_at.3 /usr/local/share/man/man3/MPI_File_read_at.3
/usr/bin/install -c -m 644 MPI_File_read_at_all.3 /usr/local/share/man/man3/MPI_File_read_at_all.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_begin.3 /usr/local/share/man/man3/MPI_File_read_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_end.3 /usr/local/share/man/man3/MPI_File_read_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_ordered.3 /usr/local/share/man/man3/MPI_File_read_ordered.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_begin.3 /usr/local/share/man/man3/MPI_File_read_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_end.3 /usr/local/share/man/man3/MPI_File_read_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_read_shared.3 /usr/local/share/man/man3/MPI_File_read_shared.3
/usr/bin/install -c -m 644 MPI_File_seek.3 /usr/local/share/man/man3/MPI_File_seek.3
/usr/bin/install -c -m 644 MPI_File_seek_shared.3 /usr/local/share/man/man3/MPI_File_seek_shared.3
/usr/bin/install -c -m 644 MPI_File_set_atomicity.3 /usr/local/share/man/man3/MPI_File_set_atomicity.3
/usr/bin/install -c -m 644 MPI_File_set_errhandler.3 /usr/local/share/man/man3/MPI_File_set_errhandler.3
/usr/bin/install -c -m 644 MPI_File_set_info.3 /usr/local/share/man/man3/MPI_File_set_info.3
/usr/bin/install -c -m 644 MPI_File_set_size.3 /usr/local/share/man/man3/MPI_File_set_size.3
/usr/bin/install -c -m 644 MPI_File_set_view.3 /usr/local/share/man/man3/MPI_File_set_view.3
/usr/bin/install -c -m 644 MPI_File_sync.3 /usr/local/share/man/man3/MPI_File_sync.3
/usr/bin/install -c -m 644 MPI_File_write.3 /usr/local/share/man/man3/MPI_File_write.3
/usr/bin/install -c -m 644 MPI_File_write_all.3 /usr/local/share/man/man3/MPI_File_write_all.3
/usr/bin/install -c -m 644 MPI_File_write_all_begin.3 /usr/local/share/man/man3/MPI_File_write_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_all_end.3 /usr/local/share/man/man3/MPI_File_write_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_at.3 /usr/local/share/man/man3/MPI_File_write_at.3
/usr/bin/install -c -m 644 MPI_File_write_at_all.3 /usr/local/share/man/man3/MPI_File_write_at_all.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_begin.3 /usr/local/share/man/man3/MPI_File_write_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_end.3 /usr/local/share/man/man3/MPI_File_write_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_ordered.3 /usr/local/share/man/man3/MPI_File_write_ordered.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_begin.3 /usr/local/share/man/man3/MPI_File_write_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_end.3 /usr/local/share/man/man3/MPI_File_write_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_write_shared.3 /usr/local/share/man/man3/MPI_File_write_shared.3
/usr/bin/install -c -m 644 MPI_Finalize.3 /usr/local/share/man/man3/MPI_Finalize.3
/usr/bin/install -c -m 644 MPI_Finalized.3 /usr/local/share/man/man3/MPI_Finalized.3
/usr/bin/install -c -m 644 MPI_Free_mem.3 /usr/local/share/man/man3/MPI_Free_mem.3
/usr/bin/install -c -m 644 MPI_Gather.3 /usr/local/share/man/man3/MPI_Gather.3
/usr/bin/install -c -m 644 MPI_Gatherv.3 /usr/local/share/man/man3/MPI_Gatherv.3
/usr/bin/install -c -m 644 MPI_Get.3 /usr/local/share/man/man3/MPI_Get.3
/usr/bin/install -c -m 644 MPI_Get_address.3 /usr/local/share/man/man3/MPI_Get_address.3
/usr/bin/install -c -m 644 MPI_Get_count.3 /usr/local/share/man/man3/MPI_Get_count.3
/usr/bin/install -c -m 644 MPI_Get_elements.3 /usr/local/share/man/man3/MPI_Get_elements.3
/usr/bin/install -c -m 644 MPI_Get_processor_name.3 /usr/local/share/man/man3/MPI_Get_processor_name.3
/usr/bin/install -c -m 644 MPI_Get_version.3 /usr/local/share/man/man3/MPI_Get_version.3
/usr/bin/install -c -m 644 MPI_Graph_create.3 /usr/local/share/man/man3/MPI_Graph_create.3
/usr/bin/install -c -m 644 MPI_Graph_get.3 /usr/local/share/man/man3/MPI_Graph_get.3
/usr/bin/install -c -m 644 MPI_Graph_map.3 /usr/local/share/man/man3/MPI_Graph_map.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors.3 /usr/local/share/man/man3/MPI_Graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors_count.3 /usr/local/share/man/man3/MPI_Graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Graphdims_get.3 /usr/local/share/man/man3/MPI_Graphdims_get.3
/usr/bin/install -c -m 644 MPI_Grequest_complete.3 /usr/local/share/man/man3/MPI_Grequest_complete.3
/usr/bin/install -c -m 644 MPI_Grequest_start.3 /usr/local/share/man/man3/MPI_Grequest_start.3
/usr/bin/install -c -m 644 MPI_Group_compare.3 /usr/local/share/man/man3/MPI_Group_compare.3
/usr/bin/install -c -m 644 MPI_Group_difference.3 /usr/local/share/man/man3/MPI_Group_difference.3
/usr/bin/install -c -m 644 MPI_Group_excl.3 /usr/local/share/man/man3/MPI_Group_excl.3
/usr/bin/install -c -m 644 MPI_Group_free.3 /usr/local/share/man/man3/MPI_Group_free.3
/usr/bin/install -c -m 644 MPI_Group_incl.3 /usr/local/share/man/man3/MPI_Group_incl.3
/usr/bin/install -c -m 644 MPI_Group_intersection.3 /usr/local/share/man/man3/MPI_Group_intersection.3
/usr/bin/install -c -m 644 MPI_Group_range_excl.3 /usr/local/share/man/man3/MPI_Group_range_excl.3
/usr/bin/install -c -m 644 MPI_Group_range_incl.3 /usr/local/share/man/man3/MPI_Group_range_incl.3
/usr/bin/install -c -m 644 MPI_Group_rank.3 /usr/local/share/man/man3/MPI_Group_rank.3
/usr/bin/install -c -m 644 MPI_Group_size.3 /usr/local/share/man/man3/MPI_Group_size.3
/usr/bin/install -c -m 644 MPI_Group_translate_ranks.3 /usr/local/share/man/man3/MPI_Group_translate_ranks.3
/usr/bin/install -c -m 644 MPI_Group_union.3 /usr/local/share/man/man3/MPI_Group_union.3
/usr/bin/install -c -m 644 MPI_Ibsend.3 /usr/local/share/man/man3/MPI_Ibsend.3
/usr/bin/install -c -m 644 MPI_Info_create.3 /usr/local/share/man/man3/MPI_Info_create.3
/usr/bin/install -c -m 644 MPI_Info_delete.3 /usr/local/share/man/man3/MPI_Info_delete.3
/usr/bin/install -c -m 644 MPI_Info_dup.3 /usr/local/share/man/man3/MPI_Info_dup.3
/usr/bin/install -c -m 644 MPI_Info_free.3 /usr/local/share/man/man3/MPI_Info_free.3
/usr/bin/install -c -m 644 MPI_Info_get.3 /usr/local/share/man/man3/MPI_Info_get.3
/usr/bin/install -c -m 644 MPI_Info_get_nkeys.3 /usr/local/share/man/man3/MPI_Info_get_nkeys.3
/usr/bin/install -c -m 644 MPI_Info_get_nthkey.3 /usr/local/share/man/man3/MPI_Info_get_nthkey.3
/usr/bin/install -c -m 644 MPI_Info_get_valuelen.3 /usr/local/share/man/man3/MPI_Info_get_valuelen.3
/usr/bin/install -c -m 644 MPI_Info_set.3 /usr/local/share/man/man3/MPI_Info_set.3
/usr/bin/install -c -m 644 MPI_Init.3 /usr/local/share/man/man3/MPI_Init.3
/usr/bin/install -c -m 644 MPI_Init_thread.3 /usr/local/share/man/man3/MPI_Init_thread.3
/usr/bin/install -c -m 644 MPI_Initialized.3 /usr/local/share/man/man3/MPI_Initialized.3
/usr/bin/install -c -m 644 MPI_Intercomm_create.3 /usr/local/share/man/man3/MPI_Intercomm_create.3
/usr/bin/install -c -m 644 MPI_Intercomm_merge.3 /usr/local/share/man/man3/MPI_Intercomm_merge.3
/usr/bin/install -c -m 644 MPI_Iprobe.3 /usr/local/share/man/man3/MPI_Iprobe.3
/usr/bin/install -c -m 644 MPI_Irecv.3 /usr/local/share/man/man3/MPI_Irecv.3
/usr/bin/install -c -m 644 MPI_Irsend.3 /usr/local/share/man/man3/MPI_Irsend.3
/usr/bin/install -c -m 644 MPI_Is_thread_main.3 /usr/local/share/man/man3/MPI_Is_thread_main.3
/usr/bin/install -c -m 644 MPI_Isend.3 /usr/local/share/man/man3/MPI_Isend.3
/usr/bin/install -c -m 644 MPI_Issend.3 /usr/local/share/man/man3/MPI_Issend.3
/usr/bin/install -c -m 644 MPI_Keyval_create.3 /usr/local/share/man/man3/MPI_Keyval_create.3
/usr/bin/install -c -m 644 MPI_Keyval_free.3 /usr/local/share/man/man3/MPI_Keyval_free.3
/usr/bin/install -c -m 644 MPI_Lookup_name.3 /usr/local/share/man/man3/MPI_Lookup_name.3
/usr/bin/install -c -m 644 MPI_Op_commute.3 /usr/local/share/man/man3/MPI_Op_commute.3
/usr/bin/install -c -m 644 MPI_Op_create.3 /usr/local/share/man/man3/MPI_Op_create.3
/usr/bin/install -c -m 644 MPI_Op_free.3 /usr/local/share/man/man3/MPI_Op_free.3
/usr/bin/install -c -m 644 MPI_Open_port.3 /usr/local/share/man/man3/MPI_Open_port.3
/usr/bin/install -c -m 644 MPI_Pack.3 /usr/local/share/man/man3/MPI_Pack.3
/usr/bin/install -c -m 644 MPI_Pack_external.3 /usr/local/share/man/man3/MPI_Pack_external.3
/usr/bin/install -c -m 644 MPI_Pack_external_size.3 /usr/local/share/man/man3/MPI_Pack_external_size.3
/usr/bin/install -c -m 644 MPI_Pack_size.3 /usr/local/share/man/man3/MPI_Pack_size.3
/usr/bin/install -c -m 644 MPI_Pcontrol.3 /usr/local/share/man/man3/MPI_Pcontrol.3
/usr/bin/install -c -m 644 MPI_Probe.3 /usr/local/share/man/man3/MPI_Probe.3
/usr/bin/install -c -m 644 MPI_Publish_name.3 /usr/local/share/man/man3/MPI_Publish_name.3
/usr/bin/install -c -m 644 MPI_Put.3 /usr/local/share/man/man3/MPI_Put.3
/usr/bin/install -c -m 644 MPI_Query_thread.3 /usr/local/share/man/man3/MPI_Query_thread.3
/usr/bin/install -c -m 644 MPI_Recv.3 /usr/local/share/man/man3/MPI_Recv.3
/usr/bin/install -c -m 644 MPI_Recv_init.3 /usr/local/share/man/man3/MPI_Recv_init.3
/usr/bin/install -c -m 644 MPI_Reduce.3 /usr/local/share/man/man3/MPI_Reduce.3
/usr/bin/install -c -m 644 MPI_Reduce_local.3 /usr/local/share/man/man3/MPI_Reduce_local.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter.3 /usr/local/share/man/man3/MPI_Reduce_scatter.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter_block.3 /usr/local/share/man/man3/MPI_Reduce_scatter_block.3
/usr/bin/install -c -m 644 MPI_Register_datarep.3 /usr/local/share/man/man3/MPI_Register_datarep.3
/usr/bin/install -c -m 644 MPI_Request_free.3 /usr/local/share/man/man3/MPI_Request_free.3
/usr/bin/install -c -m 644 MPI_Request_get_status.3 /usr/local/share/man/man3/MPI_Request_get_status.3
/usr/bin/install -c -m 644 MPI_Rsend.3 /usr/local/share/man/man3/MPI_Rsend.3
/usr/bin/install -c -m 644 MPI_Rsend_init.3 /usr/local/share/man/man3/MPI_Rsend_init.3
/usr/bin/install -c -m 644 MPI_Scan.3 /usr/local/share/man/man3/MPI_Scan.3
/usr/bin/install -c -m 644 MPI_Scatter.3 /usr/local/share/man/man3/MPI_Scatter.3
/usr/bin/install -c -m 644 MPI_Scatterv.3 /usr/local/share/man/man3/MPI_Scatterv.3
/usr/bin/install -c -m 644 MPI_Send.3 /usr/local/share/man/man3/MPI_Send.3
/usr/bin/install -c -m 644 MPI_Send_init.3 /usr/local/share/man/man3/MPI_Send_init.3
/usr/bin/install -c -m 644 MPI_Sendrecv.3 /usr/local/share/man/man3/MPI_Sendrecv.3
/usr/bin/install -c -m 644 MPI_Sendrecv_replace.3 /usr/local/share/man/man3/MPI_Sendrecv_replace.3
/usr/bin/install -c -m 644 MPI_Ssend.3 /usr/local/share/man/man3/MPI_Ssend.3
/usr/bin/install -c -m 644 MPI_Ssend_init.3 /usr/local/share/man/man3/MPI_Ssend_init.3
/usr/bin/install -c -m 644 MPI_Start.3 /usr/local/share/man/man3/MPI_Start.3
/usr/bin/install -c -m 644 MPI_Startall.3 /usr/local/share/man/man3/MPI_Startall.3
/usr/bin/install -c -m 644 MPI_Status_set_cancelled.3 /usr/local/share/man/man3/MPI_Status_set_cancelled.3
/usr/bin/install -c -m 644 MPI_Status_set_elements.3 /usr/local/share/man/man3/MPI_Status_set_elements.3
/usr/bin/install -c -m 644 MPI_Test.3 /usr/local/share/man/man3/MPI_Test.3
/usr/bin/install -c -m 644 MPI_Test_cancelled.3 /usr/local/share/man/man3/MPI_Test_cancelled.3
/usr/bin/install -c -m 644 MPI_Testall.3 /usr/local/share/man/man3/MPI_Testall.3
/usr/bin/install -c -m 644 MPI_Testany.3 /usr/local/share/man/man3/MPI_Testany.3
/usr/bin/install -c -m 644 MPI_Testsome.3 /usr/local/share/man/man3/MPI_Testsome.3
/usr/bin/install -c -m 644 MPI_Topo_test.3 /usr/local/share/man/man3/MPI_Topo_test.3
/usr/bin/install -c -m 644 MPI_Type_commit.3 /usr/local/share/man/man3/MPI_Type_commit.3
/usr/bin/install -c -m 644 MPI_Type_contiguous.3 /usr/local/share/man/man3/MPI_Type_contiguous.3
/usr/bin/install -c -m 644 MPI_Type_create_darray.3 /usr/local/share/man/man3/MPI_Type_create_darray.3
/usr/bin/install -c -m 644 MPI_Type_create_hindexed.3 /usr/local/share/man/man3/MPI_Type_create_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_create_hvector.3 /usr/local/share/man/man3/MPI_Type_create_hvector.3
/usr/bin/install -c -m 644 MPI_Type_create_indexed_block.3 /usr/local/share/man/man3/MPI_Type_create_indexed_block.3
/usr/bin/install -c -m 644 MPI_Type_create_keyval.3 /usr/local/share/man/man3/MPI_Type_create_keyval.3
/usr/bin/install -c -m 644 MPI_Type_create_resized.3 /usr/local/share/man/man3/MPI_Type_create_resized.3
/usr/bin/install -c -m 644 MPI_Type_create_struct.3 /usr/local/share/man/man3/MPI_Type_create_struct.3
/usr/bin/install -c -m 644 MPI_Type_create_subarray.3 /usr/local/share/man/man3/MPI_Type_create_subarray.3
/usr/bin/install -c -m 644 MPI_Type_delete_attr.3 /usr/local/share/man/man3/MPI_Type_delete_attr.3
/usr/bin/install -c -m 644 MPI_Type_dup.3 /usr/local/share/man/man3/MPI_Type_dup.3
/usr/bin/install -c -m 644 MPI_Type_extent.3 /usr/local/share/man/man3/MPI_Type_extent.3
/usr/bin/install -c -m 644 MPI_Type_free.3 /usr/local/share/man/man3/MPI_Type_free.3
/usr/bin/install -c -m 644 MPI_Type_free_keyval.3 /usr/local/share/man/man3/MPI_Type_free_keyval.3
/usr/bin/install -c -m 644 MPI_Type_get_attr.3 /usr/local/share/man/man3/MPI_Type_get_attr.3
/usr/bin/install -c -m 644 MPI_Type_get_contents.3 /usr/local/share/man/man3/MPI_Type_get_contents.3
/usr/bin/install -c -m 644 MPI_Type_get_envelope.3 /usr/local/share/man/man3/MPI_Type_get_envelope.3
/usr/bin/install -c -m 644 MPI_Type_get_extent.3 /usr/local/share/man/man3/MPI_Type_get_extent.3
/usr/bin/install -c -m 644 MPI_Type_get_name.3 /usr/local/share/man/man3/MPI_Type_get_name.3
/usr/bin/install -c -m 644 MPI_Type_get_true_extent.3 /usr/local/share/man/man3/MPI_Type_get_true_extent.3
/usr/bin/install -c -m 644 MPI_Type_hindexed.3 /usr/local/share/man/man3/MPI_Type_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_hvector.3 /usr/local/share/man/man3/MPI_Type_hvector.3
/usr/bin/install -c -m 644 MPI_Type_indexed.3 /usr/local/share/man/man3/MPI_Type_indexed.3
/usr/bin/install -c -m 644 MPI_Type_lb.3 /usr/local/share/man/man3/MPI_Type_lb.3
/usr/bin/install -c -m 644 MPI_Type_match_size.3 /usr/local/share/man/man3/MPI_Type_match_size.3
/usr/bin/install -c -m 644 MPI_Type_set_attr.3 /usr/local/share/man/man3/MPI_Type_set_attr.3
/usr/bin/install -c -m 644 MPI_Type_set_name.3 /usr/local/share/man/man3/MPI_Type_set_name.3
/usr/bin/install -c -m 644 MPI_Type_size.3 /usr/local/share/man/man3/MPI_Type_size.3
/usr/bin/install -c -m 644 MPI_Type_struct.3 /usr/local/share/man/man3/MPI_Type_struct.3
/usr/bin/install -c -m 644 MPI_Type_ub.3 /usr/local/share/man/man3/MPI_Type_ub.3
/usr/bin/install -c -m 644 MPI_Type_vector.3 /usr/local/share/man/man3/MPI_Type_vector.3
/usr/bin/install -c -m 644 MPI_Unpack.3 /usr/local/share/man/man3/MPI_Unpack.3
/usr/bin/install -c -m 644 MPI_Unpack_external.3 /usr/local/share/man/man3/MPI_Unpack_external.3
/usr/bin/install -c -m 644 MPI_Unpublish_name.3 /usr/local/share/man/man3/MPI_Unpublish_name.3
/usr/bin/install -c -m 644 MPI_Wait.3 /usr/local/share/man/man3/MPI_Wait.3
/usr/bin/install -c -m 644 MPI_Waitall.3 /usr/local/share/man/man3/MPI_Waitall.3
/usr/bin/install -c -m 644 MPI_Waitany.3 /usr/local/share/man/man3/MPI_Waitany.3
/usr/bin/install -c -m 644 MPI_Waitsome.3 /usr/local/share/man/man3/MPI_Waitsome.3
/usr/bin/install -c -m 644 MPI_Win_call_errhandler.3 /usr/local/share/man/man3/MPI_Win_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_complete.3 /usr/local/share/man/man3/MPI_Win_complete.3
/usr/bin/install -c -m 644 MPI_Win_create.3 /usr/local/share/man/man3/MPI_Win_create.3
/usr/bin/install -c -m 644 MPI_Win_create_errhandler.3 /usr/local/share/man/man3/MPI_Win_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_create_keyval.3 /usr/local/share/man/man3/MPI_Win_create_keyval.3
/usr/bin/install -c -m 644 MPI_Win_delete_attr.3 /usr/local/share/man/man3/MPI_Win_delete_attr.3
/usr/bin/install -c -m 644 MPI_Win_fence.3 /usr/local/share/man/man3/MPI_Win_fence.3
/usr/bin/install -c -m 644 MPI_Win_free.3 /usr/local/share/man/man3/MPI_Win_free.3
/usr/bin/install -c -m 644 MPI_Win_free_keyval.3 /usr/local/share/man/man3/MPI_Win_free_keyval.3
/usr/bin/install -c -m 644 MPI_Win_get_attr.3 /usr/local/share/man/man3/MPI_Win_get_attr.3
/usr/bin/install -c -m 644 MPI_Win_get_errhandler.3 /usr/local/share/man/man3/MPI_Win_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_get_group.3 /usr/local/share/man/man3/MPI_Win_get_group.3
/usr/bin/install -c -m 644 MPI_Win_get_name.3 /usr/local/share/man/man3/MPI_Win_get_name.3
/usr/bin/install -c -m 644 MPI_Win_lock.3 /usr/local/share/man/man3/MPI_Win_lock.3
/usr/bin/install -c -m 644 MPI_Win_post.3 /usr/local/share/man/man3/MPI_Win_post.3
/usr/bin/install -c -m 644 MPI_Win_set_attr.3 /usr/local/share/man/man3/MPI_Win_set_attr.3
/usr/bin/install -c -m 644 MPI_Win_set_errhandler.3 /usr/local/share/man/man3/MPI_Win_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_set_name.3 /usr/local/share/man/man3/MPI_Win_set_name.3
/usr/bin/install -c -m 644 MPI_Win_start.3 /usr/local/share/man/man3/MPI_Win_start.3
/usr/bin/install -c -m 644 MPI_Win_test.3 /usr/local/share/man/man3/MPI_Win_test.3
/usr/bin/install -c -m 644 MPI_Win_unlock.3 /usr/local/share/man/man3/MPI_Win_unlock.3
/usr/bin/install -c -m 644 MPI_Win_wait.3 /usr/local/share/man/man3/MPI_Win_wait.3
/usr/bin/install -c -m 644 MPI_Wtick.3 /usr/local/share/man/man3/MPI_Wtick.3
/usr/bin/install -c -m 644 MPI_Wtime.3 /usr/local/share/man/man3/MPI_Wtime.3
/usr/bin/install -c -m 644 MPIX_Group_comm_create.3 /usr/local/share/man/man3/MPIX_Group_comm_create.3
if [ -s src/mpi/romio/include/mpiof.h ] ; then /usr/bin/install -c -m 644  src/mpi/romio/include/mpiof.h /usr/local/include/mpiof.h ; fi
if [ -s src/mpi/romio/include/mpio.h ] ; then /usr/bin/install -c -m 644  src/mpi/romio/include/mpio.h /usr/local/include/mpio.h ; fi
if [ -s lib/libmpich.a ] ; then /usr/bin/install -c -m 644  lib/libmpich.a /usr/local/lib/libmpich.a ; fi
if [ -s lib/libmpichcxx.a ] ; then /usr/bin/install -c -m 644  lib/libmpichcxx.a /usr/local/lib/libmpichcxx.a ; fi
if [ -s lib/libfmpich.a ] ; then /usr/bin/install -c -m 644  lib/libfmpich.a /usr/local/lib/libfmpich.a ; fi
if [ -s lib/libpmpich.a ] ; then /usr/bin/install -c -m 644  lib/libpmpich.a /usr/local/lib/libpmpich.a ; fi
if [ -s lib/libmpichf90.a ] ; then /usr/bin/install -c -m 644  lib/libmpichf90.a /usr/local/lib/libmpichf90.a ; fi
if [ -s lib/libmpich.dll ] ; then false -version-info 3:0 --mode=install  lib/libmpich.dll /usr/local/lib/libmpich.dll ; fi
if [ -s lib/libpmpich.dll ] ; then false -version-info 3:0 --mode=install  lib/libpmpich.dll /usr/local/lib/libpmpich.dll ; fi
if [ -s lib/libfmpich.dll ] ; then false -version-info 3:0 --mode=install  lib/libfmpich.dll /usr/local/lib/libfmpich.dll ; fi
if [ -s lib/libmpichf90.dll ] ; then false -version-info 3:0 --mode=install  lib/libmpichf90.dll /usr/local/lib/libmpichf90.dll ; fi
if [ -s lib/libmpichcxx.dll ] ; then false -version-info 3:0 --mode=install  lib/libmpichcxx.dll /usr/local/lib/libmpichcxx.dll ; fi
if [ -s ./doc/userguide/user.pdf ] ; then /usr/bin/install -c -m 644  ./doc/userguide/user.pdf /usr/local/share/doc//user.pdf ; fi
if [ -s ./doc/installguide/install.pdf ] ; then /usr/bin/install -c -m 644  ./doc/installguide/install.pdf /usr/local/share/doc//install.pdf ; fi
if [ -s ./doc/smpd/smpd_pmi.pdf ] ; then /usr/bin/install -c -m 644  ./doc/smpd/smpd_pmi.pdf /usr/local/share/doc//smpd_pmi.pdf ; fi
if [ -s ./doc/logging/logging.pdf ] ; then /usr/bin/install -c -m 644  ./doc/logging/logging.pdf /usr/local/share/doc//logging.pdf ; fi
(cd src/env && make INSTALL_STRIP_FLAG= PACKAGE= prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
if [ ! -d /usr/local ] ; then mkdir -p /usr/local ; fi
if [ ! -d /usr/local/bin ] ; then mkdir -p /usr/local/bin ; fi
/usr/bin/install -c   mpich2version /usr/local/bin/mpich2version
/usr/bin/install -c  mpicc /usr/local/bin/mpicc
if [ ! -d /usr/local/etc ] ; then mkdir -p /usr/local/etc ; fi
/usr/bin/install -c -m 644  mpixxx_opts.conf /usr/local/etc/mpixxx_opts.conf
/usr/bin/install -c -m 644  mpicc.conf /usr/local/etc/mpicc.conf
if [ -s mpicxx ] ; then /usr/bin/install -c  mpicxx /usr/local/bin/mpicxx ; fi
if [ -s mpif77 ] ; then /usr/bin/install -c  mpif77 /usr/local/bin/mpif77 ; fi
if [ -s mpif90 ] ; then /usr/bin/install -c  mpif90 /usr/local/bin/mpif90 ; fi
if [ -s mpicxx.conf ] ; then /usr/bin/install -c -m 644  mpicxx.conf /usr/local/etc/mpicxx.conf ; fi
if [ -s mpif77.conf ] ; then /usr/bin/install -c -m 644  mpif77.conf /usr/local/etc/mpif77.conf ; fi
if [ -s mpif90.conf ] ; then /usr/bin/install -c -m 644  mpif90.conf /usr/local/etc/mpif90.conf ; fi
make prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install-postamble
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
if [ -x /usr/local/bin/mpicxx ] ; then \
    cd /usr/local/bin && ln -f -s mpicxx mpic++ ; fi
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
(cd src/packaging/pkgconfig && make INSTALL_STRIP_FLAG= PACKAGE= prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/pkgconfig'
if [ ! -d /usr/local/lib/pkgconfig ] ; then mkdir -p /usr/local/lib/pkgconfig ; fi
if [ -s mpich2-c.pc ] ; then /usr/bin/install -c -m 644  mpich2-c.pc /usr/local/lib/pkgconfig/mpich2-c.pc ; fi
if [ -s mpich2-cxx.pc ] ; then /usr/bin/install -c -m 644  mpich2-cxx.pc /usr/local/lib/pkgconfig/mpich2-cxx.pc ; fi
if [ -s mpich2-f77.pc ] ; then /usr/bin/install -c -m 644  mpich2-f77.pc /usr/local/lib/pkgconfig/mpich2-f77.pc ; fi
if [ -s mpich2-f90.pc ] ; then /usr/bin/install -c -m 644  mpich2-f90.pc /usr/local/lib/pkgconfig/mpich2-f90.pc ; fi
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/pkgconfig'
(cd src/packaging/envmods && make INSTALL_STRIP_FLAG= PACKAGE= prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/envmods'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/envmods'
for dir in  src/binding/f77 src/binding/f90 src/binding/cxx - ; do \
	if [ "$dir" = "-" ] ; then break ; fi ;\
	(cd $dir && make INSTALL_STRIP_FLAG= PACKAGE= prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install) ;\
done
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
if [ ! -d /usr/local/include ] ; then mkdir -p /usr/local/include ; fi
/usr/bin/install -c -m 644  mpif.h /usr/local/include/mpif.h
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
/usr/bin/install -c -m 644  mpi.mod /usr/local/include/mpi.mod
/usr/bin/install -c -m 644  mpi_constants.mod /usr/local/include/mpi_constants.mod
/usr/bin/install -c -m 644  mpi_base.mod /usr/local/include/mpi_base.mod
/usr/bin/install -c -m 644  mpi_sizeofs.mod /usr/local/include/mpi_sizeofs.mod
if [ ! -d /usr/local/lib ] ; then mkdir -p /usr/local/lib ; fi
/usr/bin/install -c -m 644  libmpichf90.a /usr/local/lib/libmpichf90.a
if [ -s mpimod.pcl ] ; then /usr/bin/install -c -m 644  mpimod.pcl /usr/local/include/mpimod.pcl ; fi
if [ -s mpimod.pc ] ; then /usr/bin/install -c -m 644  mpimod.pc /usr/local/include/mpimod.pc ; fi
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/cxx'
/usr/bin/install -c -m 644  mpicxx.h /usr/local/include/mpicxx.h
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/cxx'
for dir in  src/mpl src/openpa src/pm/hydra src/mpe2 - ; do \
done
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
test -z "/usr/local/lib" || /usr/bin/mkdir -p "/usr/local/lib"
 /bin/sh ./libtool   --mode=install /usr/bin/install -c   libmpl.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libmpl.lai /usr/local/lib/libmpl.la
libtool: install: /usr/bin/install -c .libs/libmpl.a /usr/local/lib/libmpl.a
libtool: install: chmod 644 /usr/local/lib/libmpl.a
libtool: install: ranlib /usr/local/lib/libmpl.a
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
Making install in src
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
 /bin/sh ../libtool   --mode=install /usr/bin/install -c   libopa.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libopa.lai /usr/local/lib/libopa.la
libtool: install: /usr/bin/install -c .libs/libopa.a /usr/local/lib/libopa.a
libtool: install: chmod 644 /usr/local/lib/libopa.a
libtool: install: ranlib /usr/local/lib/libopa.a
test -z "/usr/local/include" || /usr/bin/mkdir -p "/usr/local/include"
 /usr/bin/install -c -m 644 opa_config.h opa_primitives.h opa_queue.h opa_util.h '/usr/local/include'
/usr/bin/mkdir -p '/usr/local/include/primitives'
 /usr/bin/install -c -m 644  primitives/opa_by_lock.h primitives/opa_emulated.h primitives/opa_gcc_ia64.h primitives/opa_gcc_intel_32_64.h primitives/opa_gcc_intel_32_64_barrier.h primitives/opa_gcc_intel_32_64_ops.h primitives/opa_gcc_intel_32_64_p3.h primitives/opa_gcc_intel_32_64_p3barrier.h primitives/opa_gcc_intrinsics.h primitives/opa_gcc_ppc.h primitives/opa_gcc_sicortex.h primitives/opa_nt_intrinsics.h primitives/opa_sun_atomic_ops.h primitives/opa_unsafe.h '/usr/local/include/primitives'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
Making install in test
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
test -z "/usr/local/share/doc/openpa" || /usr/bin/mkdir -p "/usr/local/share/doc/openpa"
 /usr/bin/install -c -m 644 README '/usr/local/share/doc/openpa'
test -z "/usr/local/lib/pkgconfig" || /usr/bin/mkdir -p "/usr/local/lib/pkgconfig"
 /usr/bin/install -c -m 644 openpa.pc '/usr/local/lib/pkgconfig'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
Making install in ../../mpl
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
Making install in .
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
test -z "/usr/local/bin" || mkdir -p "/usr/local/bin"
  /bin/sh ./libtool   --mode=install /usr/bin/install -c hydra_persist.exe hydra_nameserver.exe hydra_pmi_proxy.exe mpiexec.hydra.exe '/usr/local/bin'
libtool: install: /usr/bin/install -c .libs/hydra_persist.exe /usr/local/bin/hydra_persist.exe
libtool: install: /usr/bin/install -c .libs/hydra_nameserver.exe /usr/local/bin/hydra_nameserver.exe
libtool: install: /usr/bin/install -c .libs/hydra_pmi_proxy.exe /usr/local/bin/hydra_pmi_proxy.exe
libtool: install: /usr/bin/install -c .libs/mpiexec.hydra.exe /usr/local/bin/mpiexec.hydra.exe
make  install-exec-hook
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
if [ -x /usr/local/bin/mpiexec.hydra ] ; then \
    cd /usr/local/bin && ln -f -s mpiexec.hydra mpiexec ; \
    cd /usr/local/bin && ln -f -s mpiexec.hydra mpirun ; \
fi
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/hydra'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpe2'
Installing MPE2 include files to /usr/local/include
Replacing existing file /usr/local/include/clog_commset.h...
Replacing existing file /usr/local/include/clog_const.h...
Replacing existing file /usr/local/include/clog_inttypes.h...
Replacing existing file /usr/local/include/clog_uuid.h...
Replacing existing file /usr/local/include/mpe.h...
Replacing existing file /usr/local/include/mpe_callstack.h...
Replacing existing file /usr/local/include/mpe_graphics.h...
Replacing existing file /usr/local/include/mpe_graphicsf.h...
Replacing existing file /usr/local/include/mpe_log.h...
Replacing existing file /usr/local/include/mpe_log_thread.h...
Replacing existing file /usr/local/include/mpe_logf.h...
Replacing existing file /usr/local/include/mpe_misc.h...
Installing MPE2 libraries to /usr/local/lib
Replacing existing file /usr/local/lib/libampe.a...
Replacing existing file /usr/local/lib/liblmpe.a...
Replacing existing file /usr/local/lib/libmpe.a...
Replacing existing file /usr/local/lib/libmpe_collchk.a...
Replacing existing file /usr/local/lib/libmpe_f2cmpi.a...
Replacing existing file /usr/local/lib/libmpe_nompi.a...
Replacing existing file /usr/local/lib/libmpe_nompi_null.a...
Replacing existing file /usr/local/lib/libmpe_null.a...
Replacing existing file /usr/local/lib/libtmpe.a...
Replacing existing file /usr/local/lib/mpe_prof.o...
Installing MPE2 utility programs to /usr/local/bin
Replacing existing file /usr/local/bin/bt2line...
Replacing existing file /usr/local/bin/check_callstack.exe...
Replacing existing file /usr/local/bin/clog2_join.exe...
Replacing existing file /usr/local/bin/clog2_print.exe...
Replacing existing file /usr/local/bin/clog2_repair.exe...
Installing MPE2 configuration files to /usr/local/etc
Installing MPE2 system utility programs to /usr/local/sbin
Replacing existing file /usr/local/sbin/mpecheckinstall...
Replacing existing file /usr/local/share/examples_logging/comm1_isr.c...
Replacing existing file /usr/local/share/examples_logging/comm1_isr_loop.c...
Replacing existing file /usr/local/share/examples_logging/comm2_connect_accept.c...
Replacing existing file /usr/local/share/examples_logging/comm2_spawn_child.c...
Replacing existing file /usr/local/share/examples_logging/comm2_spawn_parent.c...
Replacing existing file /usr/local/share/examples_logging/cpi.c...
Replacing existing file /usr/local/share/examples_logging/cpilog.c...
Replacing existing file /usr/local/share/examples_logging/cpilog_pack.c...
Replacing existing file /usr/local/share/examples_logging/fcomm1_isr.f...
Replacing existing file /usr/local/share/examples_logging/fpilog.f...
Replacing existing file /usr/local/share/examples_logging/fpilog_pack.F...
Replacing existing file /usr/local/share/examples_logging/iotest.c...
Replacing existing file /usr/local/share/examples_logging/log_cost.c...
Replacing existing file /usr/local/share/examples_logging/Makefile...
Replacing existing file /usr/local/share/examples_logging/openmp_mpilog.F...
Replacing existing file /usr/local/share/examples_logging/openmp_sendrecv.c...
Replacing existing file /usr/local/share/examples_logging/pthread_allreduce.c...
Replacing existing file /usr/local/share/examples_logging/pthread_sendrecv.c...
Replacing existing file /usr/local/share/examples_logging/pthread_sendrecv_user.c...
Replacing existing file /usr/local/share/examples_logging/srtest.c...
Replacing existing file /usr/local/share/examples_graphics/cpi.c...
Replacing existing file /usr/local/share/examples_graphics/cxgraphics.c...
Replacing existing file /usr/local/share/examples_graphics/fxgraphics.f...
Replacing existing file /usr/local/share/examples_graphics/Makefile...
Replacing existing file /usr/local/share/examples_collchk/composite.c...
Replacing existing file /usr/local/share/examples_collchk/Makefile...
Replacing existing file /usr/local/share/examples_collchk/scatterv.c...
Replacing existing file /usr/local/share/examples_collchk/time_allreduce.c...
Replacing existing file /usr/local/share/examples_collchk/time_alltoallv.c...
Replacing existing file /usr/local/share/examples_collchk/time_alltoallv0.c...
Replacing existing file /usr/local/share/examples_collchk/time_bcast.c...
Replacing existing file /usr/local/share/examples_collchk/wrong_composite.c...
Replacing existing file /usr/local/share/examples_collchk/wrong_int_byte.c...
Replacing existing file /usr/local/share/examples_collchk/wrong_reals.f...
Replacing existing file /usr/local/share/examples_collchk/wrong_root.c...
Replacing existing file /usr/local/share/examples_collchk/wrong_scatterv.c...
Installing MPE2 man to /usr/local/share/man
Replacing existing file /usr/local/share/man/man4/MPE_Add_RGB_color.4...
Replacing existing file /usr/local/share/man/man4/MPE_CaptureFile.4...
Replacing existing file /usr/local/share/man/man4/MPE_Close_graphics.4...
Replacing existing file /usr/local/share/man/man4/MPE_Comm_global_rank.4...
Replacing existing file /usr/local/share/man/man4/MPE_Decomp1d.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_comm_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_comm_state.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_info_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_info_state.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_state.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_circle.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_line.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_logic.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_point.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_points.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_string.4...
Replacing existing file /usr/local/share/man/man4/MPE_Errors_call_debugger.4...
Replacing existing file /usr/local/share/man/man4/MPE_Fill_circle.4...
Replacing existing file /usr/local/share/man/man4/MPE_Fill_rectangle.4...
Replacing existing file /usr/local/share/man/man4/MPE_Finish_log.4...
Replacing existing file /usr/local/share/man/man4/MPE_Get_mouse_press.4...
Replacing existing file /usr/local/share/man/man4/MPE_GetHostName.4...
Replacing existing file /usr/local/share/man/man4/MPE_GetTags.4...
Replacing existing file /usr/local/share/man/man4/MPE_Iget_mouse_press.4...
Replacing existing file /usr/local/share/man/man4/MPE_Init_log.4...
Replacing existing file /usr/local/share/man/man4/MPE_Initialized_logging.4...
Replacing existing file /usr/local/share/man/man4/MPE_IO_Stdout_to_file.4...
Replacing existing file /usr/local/share/man/man4/MPE_Line_thickness.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_bare_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_comm_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_comm_receive.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_comm_send.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_get_event_number.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_get_solo_eventID.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_get_state_eventIDs.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_info_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_merged_logfilename.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_pack.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_receive.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_send.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_sync_clocks.4...
Replacing existing file /usr/local/share/man/man4/MPE_Make_color_array.4...
Replacing existing file /usr/local/share/man/man4/MPE_Num_colors.4...
Replacing existing file /usr/local/share/man/man4/MPE_Open_graphics.4...
Replacing existing file /usr/local/share/man/man4/MPE_ReturnTags.4...
Replacing existing file /usr/local/share/man/man4/MPE_Seq_begin.4...
Replacing existing file /usr/local/share/man/man4/MPE_Seq_end.4...
Replacing existing file /usr/local/share/man/man4/MPE_Signals_call_debugger.4...
Replacing existing file /usr/local/share/man/man4/MPE_Start_log.4...
Replacing existing file /usr/local/share/man/man4/MPE_Stop_log.4...
Replacing existing file /usr/local/share/man/man4/MPE_TagsEnd.4...
Replacing existing file /usr/local/share/man/man4/MPE_Update.4...
Installing MPE2 html to /usr/local/share/doc/
Replacing existing file /usr/local/share/doc//www4/libmpe.cit...
Replacing existing file /usr/local/share/doc//www4/MPE_Add_RGB_color.html...
Replacing existing file /usr/local/share/doc//www4/MPE_CaptureFile.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Close_graphics.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Comm_global_rank.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Decomp1d.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_comm_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_comm_state.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_info_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_info_state.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_state.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_circle.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_line.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_logic.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_point.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_points.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_string.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Errors_call_debugger.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Fill_circle.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Fill_rectangle.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Finish_log.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Get_mouse_press.html...
Replacing existing file /usr/local/share/doc//www4/MPE_GetHostName.html...
Replacing existing file /usr/local/share/doc//www4/MPE_GetTags.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Iget_mouse_press.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Init_log.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Initialized_logging.html...
Replacing existing file /usr/local/share/doc//www4/MPE_IO_Stdout_to_file.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Line_thickness.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_bare_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_comm_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_comm_receive.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_comm_send.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_get_event_number.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_get_solo_eventID.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_get_state_eventIDs.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_info_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_merged_logfilename.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_pack.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_receive.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_send.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_sync_clocks.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Make_color_array.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Num_colors.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Open_graphics.html...
Replacing existing file /usr/local/share/doc//www4/MPE_ReturnTags.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Seq_begin.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Seq_end.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Signals_call_debugger.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Start_log.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Stop_log.html...
Replacing existing file /usr/local/share/doc//www4/MPE_TagsEnd.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Update.html...
Installed MPE2 in /usr/local
/usr/local/sbin/mpeuninstall may be used to remove the installation
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpe2'
(NOXMLCLOSE=YES && export NOXMLCLOSE && cd mpi && make testing)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi'
./runtests -srcdir=. -tests=testlist \
	   -mpiexec=/usr/local/bin/mpiexec \
	   -xmlfile=summary.xml
Looking in ./testlist
Processing directory attr
Looking in ./attr/testlist
Processing directory coll
Looking in ./coll/testlist
Unexpected output in allred: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allred: MPIR_Init_thread(388).................:
Unexpected output in allred: MPID_Init(139)........................: channel initialization failed
Unexpected output in allred: MPIDI_CH3_Init(38)....................:
Unexpected output in allred: MPID_nem_init(196)....................:
Unexpected output in allred: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allred: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allred: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allred: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program allred exited without No Errors
Unexpected output in allredmany: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in allredmany: MPIR_Init_thread(388).................:
Unexpected output in allredmany: MPID_Init(139)........................: channel initialization failed
Unexpected output in allredmany: MPIDI_CH3_Init(38)....................:
Unexpected output in allredmany: MPID_nem_init(196)....................:
Unexpected output in allredmany: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allredmany: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allredmany: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allredmany: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program allredmany exited without No Errors
Unexpected output in allred2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allred2: MPIR_Init_thread(388).................:
Unexpected output in allred2: MPID_Init(139)........................: channel initialization failed
Unexpected output in allred2: MPIDI_CH3_Init(38)....................:
Unexpected output in allred2: MPID_nem_init(196)....................:
Unexpected output in allred2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in allred2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in allred2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program allred2 exited without No Errors
Unexpected output in allred3: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allred3: MPIR_Init_thread(388).................:
Unexpected output in allred3: MPID_Init(139)........................: channel initialization failed
Unexpected output in allred3: MPIDI_CH3_Init(38)....................:
Unexpected output in allred3: MPID_nem_init(196)....................:
Unexpected output in allred3: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allred3: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allred3: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allred3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program allred3 exited without No Errors
Unexpected output in allred5: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allred5: MPIR_Init_thread(388).................:
Unexpected output in allred5: MPID_Init(139)........................: channel initialization failed
Unexpected output in allred5: MPIDI_CH3_Init(38)....................:
Unexpected output in allred5: MPID_nem_init(196)....................:
Unexpected output in allred5: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in allred5: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in allred5: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in allred5: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allred5: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allred5: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allred5: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program allred5 exited without No Errors
Unexpected output in reduce: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in reduce: MPIR_Init_thread(388).................:
Unexpected output in reduce: MPID_Init(139)........................: channel initialization failed
Unexpected output in reduce: MPIDI_CH3_Init(38)....................:
Unexpected output in reduce: MPID_nem_init(196)....................:
Unexpected output in reduce: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in reduce: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in reduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in reduce: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in reduce: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in reduce: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in reduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program reduce exited without No Errors
Unexpected output in reduce: [proxy:0:0 at PC03] HYDU_sock_read (./utils/sock/sock.c:272): read error (Software caused connection abort)
Unexpected output in reduce: [proxy:0:0 at PC03] pmi_cb (./pm/pmiserv/pmip_cb.c:228): unable to read PMI command
Unexpected output in reduce: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in reduce: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in reduce: [mpiexec at PC03] control_cb (./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
Unexpected output in reduce: [mpiexec at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in reduce: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:179): error waiting for event
Unexpected output in reduce: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Unexpected output in red3: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in red3: MPIR_Init_thread(388).................:
Unexpected output in red3: MPID_Init(139)........................: channel initialization failed
Unexpected output in red3: MPIDI_CH3_Init(38)....................:
Unexpected output in red3: MPID_nem_init(196)....................:
Unexpected output in red3: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in red3: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in red3: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in red3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in red3: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in red3: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in red3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in red3: [proxy:0:0 at PC03] handle_pmi_response (./pm/pmiserv/pmip_cb.c:406): assert (!closed) failed
Unexpected output in red3: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:930): unable to handle PMI response
Unexpected output in red3: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in red3: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in red3: [mpiexec at PC03] control_cb (./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
Unexpected output in red3: [mpiexec at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in red3: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:179): error waiting for event
Unexpected output in red3: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program red3 exited without No Errors
Unexpected output in red4: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in red4: MPIR_Init_thread(388).................:
Unexpected output in red4: MPID_Init(139)........................: channel initialization failed
Unexpected output in red4: MPIDI_CH3_Init(38)....................:
Unexpected output in red4: MPID_nem_init(196)....................:
Unexpected output in red4: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in red4: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in red4: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in red4: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in red4: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in red4: MPIU_SHMW_Seg_attach(925).............:
Program red4 exited without No Errors
Unexpected output in alltoallv0: [mpiexec at PC03] control_cb (./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
Unexpected output in alltoallv0: [mpiexec at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in alltoallv0: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:179): error waiting for event
Unexpected output in alltoallv0: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program alltoallv0 exited without No Errors
Unexpected output in alltoallw1: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in alltoallw1: MPIR_Init_thread(388).................:
Unexpected output in alltoallw1: MPID_Init(139)........................: channel initialization failed
Unexpected output in alltoallw1: MPIDI_CH3_Init(38)....................:
Unexpected output in alltoallw1: MPID_nem_init(196)....................:
Unexpected output in alltoallw1: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in alltoallw1: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in alltoallw1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in alltoallw1: [proxy:0:0 at PC03] HYDU_sock_read (./utils/sock/sock.c:272): read error (Software caused connection abort)
Unexpected output in alltoallw1: [proxy:0:0 at PC03] pmi_cb (./pm/pmiserv/pmip_cb.c:228): unable to read PMI command
Unexpected output in alltoallw1: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in alltoallw1: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in alltoallw1: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in alltoallw1: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in alltoallw1: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in alltoallw1: [mpiexec at PC03] control_cb (./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
Unexpected output in alltoallw1: [mpiexec at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in alltoallw1: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:179): error waiting for event
Unexpected output in alltoallw1: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program alltoallw1 exited without No Errors
Unexpected output in alltoallw_zeros: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in alltoallw_zeros: MPIR_Init_thread(388).................:
Unexpected output in alltoallw_zeros: MPID_Init(139)........................: channel initialization failed
Unexpected output in alltoallw_zeros: MPIDI_CH3_Init(38)....................:
Unexpected output in alltoallw_zeros: MPID_nem_init(196)....................:
Unexpected output in alltoallw_zeros: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in alltoallw_zeros: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in alltoallw_zeros: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in alltoallw_zeros: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in alltoallw_zeros: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in alltoallw_zeros: MPIU_SHMW_Seg_open(863)...............:
Program alltoallw_zeros exited without No Errors
Unexpected output in allgather2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allgather2: MPIR_Init_thread(388).................:
Unexpected output in allgather2: MPID_Init(139)........................: channel initialization failed
Unexpected output in allgather2: MPIDI_CH3_Init(38)....................:
Unexpected output in allgather2: MPID_nem_init(196)....................:
Unexpected output in allgather2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in allgather2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in allgather2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in allgather2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allgather2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allgather2: MPIU_SHMW_Seg_open(863)...............:
Program allgather2 exited without No Errors
Unexpected output in bcasttest: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in bcasttest: MPIR_Init_thread(388).................:
Unexpected output in bcasttest: MPID_Init(139)........................: channel initialization failed
Unexpected output in bcasttest: MPIDI_CH3_Init(38)....................:
Unexpected output in bcasttest: MPID_nem_init(196)....................:
Unexpected output in bcasttest: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in bcasttest: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in bcasttest: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in bcasttest: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program bcasttest exited without No Errors
Unexpected output in bcast3: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in bcast3: MPIR_Init_thread(388).................:
Unexpected output in bcast3: MPID_Init(139)........................: channel initialization failed
Unexpected output in bcast3: MPIDI_CH3_Init(38)....................:
Unexpected output in bcast3: MPID_nem_init(196)....................:
Unexpected output in bcast3: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in bcast3: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in bcast3: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in bcast3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in bcast3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program bcast3 exited without No Errors
Unexpected output in coll4: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in coll4: MPIR_Init_thread(388).................:
Unexpected output in coll4: MPID_Init(139)........................: channel initialization failed
Unexpected output in coll4: MPIDI_CH3_Init(38)....................:
Unexpected output in coll4: MPID_nem_init(196)....................:
Unexpected output in coll4: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in coll4: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in coll4: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program coll4 exited without No Errors
Unexpected output in coll7: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in coll7: MPIR_Init_thread(388).................:
Unexpected output in coll7: MPID_Init(139)........................: channel initialization failed
Unexpected output in coll7: MPIDI_CH3_Init(38)....................:
Unexpected output in coll7: MPID_nem_init(196)....................:
Unexpected output in coll7: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in coll7: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in coll7: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in coll7: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in coll7: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in coll7: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in coll7: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program coll7 exited without No Errors
Unexpected output in coll8: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in coll8: MPIR_Init_thread(388).................:
Unexpected output in coll8: MPID_Init(139)........................: channel initialization failed
Unexpected output in coll8: MPIDI_CH3_Init(38)....................:
Unexpected output in coll8: MPID_nem_init(196)....................:
Unexpected output in coll8: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in coll8: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in coll8: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in coll8: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program coll8 exited without No Errors
Unexpected output in redscat2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in redscat2: MPIR_Init_thread(388).................:
Unexpected output in redscat2: MPID_Init(139)........................: channel initialization failed
Unexpected output in redscat2: MPIDI_CH3_Init(38)....................:
Unexpected output in redscat2: MPID_nem_init(196)....................:
Unexpected output in redscat2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in redscat2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in redscat2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in redscat2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program redscat2 exited without No Errors
Unexpected output in redscat2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in redscatinter: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in redscatinter: MPIR_Init_thread(388).................:
Unexpected output in redscatinter: MPID_Init(139)........................: channel initialization failed
Unexpected output in redscatinter: MPIDI_CH3_Init(38)....................:
Unexpected output in redscatinter: MPID_nem_init(196)....................:
Unexpected output in redscatinter: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in redscatinter: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in redscatinter: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in redscatinter: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in redscatinter: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in redscatinter: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in redscatinter: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program redscatinter exited without No Errors
Unexpected output in red_scat_block: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in red_scat_block: MPIR_Init_thread(388).................:
Unexpected output in red_scat_block: MPID_Init(139)........................: channel initialization failed
Unexpected output in red_scat_block: MPIDI_CH3_Init(38)....................:
Unexpected output in red_scat_block: MPID_nem_init(196)....................:
Unexpected output in red_scat_block: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in red_scat_block: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in red_scat_block: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in red_scat_block: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in red_scat_block: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in red_scat_block: MPIU_SHMW_Seg_attach(925).............:
Program red_scat_block exited without No Errors
Unexpected output in red_scat_block2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in red_scat_block2: MPIR_Init_thread(388).................:
Unexpected output in red_scat_block2: MPID_Init(139)........................: channel initialization failed
Unexpected output in red_scat_block2: MPIDI_CH3_Init(38)....................:
Unexpected output in red_scat_block2: MPID_nem_init(196)....................:
Unexpected output in red_scat_block2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in red_scat_block2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in red_scat_block2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in red_scat_block2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program red_scat_block2 exited without No Errors
Unexpected output in scatter2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in scatter2: MPIR_Init_thread(388).................:
Unexpected output in scatter2: MPID_Init(139)........................: channel initialization failed
Unexpected output in scatter2: MPIDI_CH3_Init(38)....................:
Unexpected output in scatter2: MPID_nem_init(196)....................:
Unexpected output in scatter2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in scatter2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in scatter2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in scatter2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in scatter2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in scatter2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in scatter2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program scatter2 exited without No Errors
Unexpected output in icbcast: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icbcast: MPIR_Init_thread(388).................:
Unexpected output in icbcast: MPID_Init(139)........................: channel initialization failed
Unexpected output in icbcast: MPIDI_CH3_Init(38)....................:
Unexpected output in icbcast: MPID_nem_init(196)....................:
Unexpected output in icbcast: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icbcast: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icbcast: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in icbcast: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icbcast: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icbcast: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icbcast: MPIU_SHMW_Seg_open(863)...............:
Program icbcast exited without No Errors
Unexpected output in icallreduce: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icallreduce: MPIR_Init_thread(388).................:
Unexpected output in icallreduce: MPID_Init(139)........................: channel initialization failed
Unexpected output in icallreduce: MPIDI_CH3_Init(38)....................:
Unexpected output in icallreduce: MPID_nem_init(196)....................:
Unexpected output in icallreduce: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icallreduce: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icallreduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icallreduce: [proxy:0:0 at PC03] HYDU_sock_read (./utils/sock/sock.c:272): read error (Software caused connection abort)
Unexpected output in icallreduce: [proxy:0:0 at PC03] pmi_cb (./pm/pmiserv/pmip_cb.c:228): unable to read PMI command
Unexpected output in icallreduce: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in icallreduce: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in icallreduce: [mpiexec at PC03] control_cb (./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
Unexpected output in icallreduce: [mpiexec at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in icallreduce: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:179): error waiting for event
Unexpected output in icallreduce: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program icallreduce exited without No Errors
Unexpected output in icreduce: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icreduce: MPIR_Init_thread(388).................:
Unexpected output in icreduce: MPID_Init(139)........................: channel initialization failed
Unexpected output in icreduce: MPIDI_CH3_Init(38)....................:
Unexpected output in icreduce: MPID_nem_init(196)....................:
Unexpected output in icreduce: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icreduce: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icreduce: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in icreduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icreduce: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icreduce: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icreduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Permission denied
Unexpected output in icreduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program icreduce exited without No Errors
Unexpected output in icscatter: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icscatter: MPIR_Init_thread(388).................:
Unexpected output in icscatter: MPID_Init(139)........................: channel initialization failed
Unexpected output in icscatter: MPIDI_CH3_Init(38)....................:
Unexpected output in icscatter: MPID_nem_init(196)....................:
Unexpected output in icscatter: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icscatter: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icscatter: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icscatter: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program icscatter exited without No Errors
Unexpected output in icgather: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icgather: MPIR_Init_thread(388).................:
Unexpected output in icgather: MPID_Init(139)........................: channel initialization failed
Unexpected output in icgather: MPIDI_CH3_Init(38)....................:
Unexpected output in icgather: MPID_nem_init(196)....................:
Unexpected output in icgather: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icgather: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icgather: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in icgather: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in icgather: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icgather: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icgather: MPIU_SHMW_Seg_attach(925).............:
Program icgather exited without No Errors
Unexpected output in icallgather: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icallgather: MPIR_Init_thread(388).................:
Unexpected output in icallgather: MPID_Init(139)........................: channel initialization failed
Unexpected output in icallgather: MPIDI_CH3_Init(38)....................:
Unexpected output in icallgather: MPID_nem_init(196)....................:
Unexpected output in icallgather: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icallgather: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icallgather: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icallgather: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icallgather: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icallgather: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in icallgather: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program icallgather exited without No Errors
Unexpected output in icscatterv: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icscatterv: MPIR_Init_thread(388).................:
Unexpected output in icscatterv: MPID_Init(139)........................: channel initialization failed
Unexpected output in icscatterv: MPIDI_CH3_Init(38)....................:
Unexpected output in icscatterv: MPID_nem_init(196)....................:
Unexpected output in icscatterv: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icscatterv: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icscatterv: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icscatterv: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Permission denied
Program icscatterv exited without No Errors
Unexpected output in icalltoall: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icalltoall: MPIR_Init_thread(388).................:
Unexpected output in icalltoall: MPID_Init(139)........................: channel initialization failed
Unexpected output in icalltoall: MPIDI_CH3_Init(38)....................:
Unexpected output in icalltoall: MPID_nem_init(196)....................:
Unexpected output in icalltoall: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icalltoall: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icalltoall: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program icalltoall exited without No Errors
Unexpected output in icalltoallw: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icalltoallw: MPIR_Init_thread(388).................:
Unexpected output in icalltoallw: MPID_Init(139)........................: channel initialization failed
Unexpected output in icalltoallw: MPIDI_CH3_Init(38)....................:
Unexpected output in icalltoallw: MPID_nem_init(196)....................:
Unexpected output in icalltoallw: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icalltoallw: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icalltoallw: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icalltoallw: [proxy:0:0 at PC03] HYDU_sock_read (./utils/sock/sock.c:272): read error (Software caused connection abort)
Unexpected output in icalltoallw: [proxy:0:0 at PC03] pmi_cb (./pm/pmiserv/pmip_cb.c:228): unable to read PMI command
Unexpected output in icalltoallw: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in icalltoallw: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in icalltoallw: [mpiexec at PC03] control_cb (./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
Unexpected output in icalltoallw: [mpiexec at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in icalltoallw: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:179): error waiting for event
Unexpected output in icalltoallw: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program icalltoallw exited without No Errors
Unexpected output in opmin: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in opmin: MPIR_Init_thread(388).................:
Unexpected output in opmin: MPID_Init(139)........................: channel initialization failed
Unexpected output in opmin: MPIDI_CH3_Init(38)....................:
Unexpected output in opmin: MPID_nem_init(196)....................:
Unexpected output in opmin: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in opmin: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in opmin: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program opmin exited without No Errors
Unexpected output in opmaxloc: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in opmaxloc: MPIR_Init_thread(388).................:
Unexpected output in opmaxloc: MPID_Init(139)........................: channel initialization failed
Unexpected output in opmaxloc: MPIDI_CH3_Init(38)....................:
Unexpected output in opmaxloc: MPID_nem_init(196)....................:
Unexpected output in opmaxloc: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in opmaxloc: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in opmaxloc: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program opmaxloc exited without No Errors
Processing directory comm
Looking in ./comm/testlist
Unexpected output in dupic: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in dupic: MPIR_Init_thread(388).................:
Unexpected output in dupic: MPID_Init(139)........................: channel initialization failed
Unexpected output in dupic: MPIDI_CH3_Init(38)....................:
Unexpected output in dupic: MPID_nem_init(196)....................:
Unexpected output in dupic: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in dupic: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in dupic: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in dupic: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in dupic: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in dupic: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in dupic: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program dupic exited without No Errors
Unexpected output in ic1: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in ic1: MPIR_Init_thread(388).................:
Unexpected output in ic1: MPID_Init(139)........................: channel initialization failed
Unexpected output in ic1: MPIDI_CH3_Init(38)....................:
Unexpected output in ic1: MPID_nem_init(196)....................:
Unexpected output in ic1: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in ic1: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in ic1: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in ic1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in ic1: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in ic1: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in ic1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program ic1 exited without No Errors
Unexpected output in icgroup: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icgroup: MPIR_Init_thread(388).................:
Unexpected output in icgroup: MPID_Init(139)........................: channel initialization failed
Unexpected output in icgroup: MPIDI_CH3_Init(38)....................:
Unexpected output in icgroup: MPID_nem_init(196)....................:
Unexpected output in icgroup: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icgroup: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icgroup: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program icgroup exited without No Errors
Unexpected output in iccreate: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in iccreate: MPIR_Init_thread(388).................:
Unexpected output in iccreate: MPID_Init(139)........................: channel initialization failed
Unexpected output in iccreate: MPIDI_CH3_Init(38)....................:
Unexpected output in iccreate: MPID_nem_init(196)....................:
Unexpected output in iccreate: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in iccreate: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in iccreate: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in iccreate: [proxy:0:0 at PC03] HYDU_sock_read (./utils/sock/sock.c:272): read error (Software caused connection abort)
Unexpected output in iccreate: [proxy:0:0 at PC03] pmi_cb (./pm/pmiserv/pmip_cb.c:228): unable to read PMI command
Unexpected output in iccreate: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in iccreate: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in iccreate: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in iccreate: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in iccreate: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in iccreate: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in iccreate: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Permission denied
Unexpected output in iccreate: [mpiexec at PC03] control_cb (./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
Unexpected output in iccreate: [mpiexec at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in iccreate: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:179): error waiting for event
Unexpected output in iccreate: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program iccreate exited without No Errors
Processing directory datatype
Looking in ./datatype/testlist
Unexpected output in darray-pack: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in darray-pack: MPIR_Init_thread(388).................:
Unexpected output in darray-pack: MPID_Init(139)........................: channel initialization failed
Unexpected output in darray-pack: MPIDI_CH3_Init(38)....................:
Unexpected output in darray-pack: MPID_nem_init(196)....................:
Unexpected output in darray-pack: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in darray-pack: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in darray-pack: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in darray-pack: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in darray-pack: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in darray-pack: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in darray-pack: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program darray-pack exited without No Errors
Processing directory errhan
Looking in ./errhan/testlist
Processing directory group
Looking in ./group/testlist
Unexpected output in groupcreate: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in groupcreate: MPIR_Init_thread(388).................:
Unexpected output in groupcreate: MPID_Init(139)........................: channel initialization failed
Unexpected output in groupcreate: MPIDI_CH3_Init(38)....................:
Unexpected output in groupcreate: MPID_nem_init(196)....................:
Unexpected output in groupcreate: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in groupcreate: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in groupcreate: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program groupcreate exited without No Errors
Unexpected output in grouptest2: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in grouptest2: MPIR_Init_thread(388).................:
Unexpected output in grouptest2: MPID_Init(139)........................: channel initialization failed
Unexpected output in grouptest2: MPIDI_CH3_Init(38)....................:
Unexpected output in grouptest2: MPID_nem_init(196)....................:
Unexpected output in grouptest2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in grouptest2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in grouptest2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in grouptest2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program grouptest2 exited without No Errors
Unexpected output in gtranksperf: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in gtranksperf: MPIR_Init_thread(388).................:
Unexpected output in gtranksperf: MPID_Init(139)........................: channel initialization failed
Unexpected output in gtranksperf: MPIDI_CH3_Init(38)....................:
Unexpected output in gtranksperf: MPID_nem_init(196)....................:
Unexpected output in gtranksperf: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in gtranksperf: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in gtranksperf: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in gtranksperf: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in gtranksperf: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in gtranksperf: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in gtranksperf: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program gtranksperf exited without No Errors
Processing directory info
Looking in ./info/testlist
Processing directory init
Looking in ./init/testlist
Processing directory pt2pt
Looking in ./pt2pt/testlist
Unexpected output in sendflood: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in sendflood: MPIR_Init_thread(388).................:
Unexpected output in sendflood: MPID_Init(139)........................: channel initialization failed
Unexpected output in sendflood: MPIDI_CH3_Init(38)....................:
Unexpected output in sendflood: MPID_nem_init(196)....................:
Unexpected output in sendflood: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in sendflood: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in sendflood: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Permission denied
Unexpected output in sendflood: [proxy:0:0 at PC03] HYDU_sock_read (./utils/sock/sock.c:272): read error (Software caused connection abort)
Unexpected output in sendflood: [proxy:0:0 at PC03] pmi_cb (./pm/pmiserv/pmip_cb.c:228): unable to read PMI command
Unexpected output in sendflood: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in sendflood: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in sendflood: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in sendflood: [mpiexec at PC03] control_cb (./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
Unexpected output in sendflood: [mpiexec at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in sendflood: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:179): error waiting for event
Unexpected output in sendflood: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program sendflood exited without No Errors
Processing directory rma
Looking in ./rma/testlist
Unexpected output in lockcontention2: [mpiexec at PC03] control_cb (./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
Unexpected output in lockcontention2: [mpiexec at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in lockcontention2: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:179): error waiting for event
Unexpected output in lockcontention2: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program lockcontention2 exited without No Errors
Unexpected output in fetchandadd_tree_am: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in fetchandadd_tree_am: MPIR_Init_thread(388).................:
Unexpected output in fetchandadd_tree_am: MPID_Init(139)........................: channel initialization failed
Unexpected output in fetchandadd_tree_am: MPIDI_CH3_Init(38)....................:
Unexpected output in fetchandadd_tree_am: MPID_nem_init(196)....................:
Unexpected output in fetchandadd_tree_am: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in fetchandadd_tree_am: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in fetchandadd_tree_am: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in fetchandadd_tree_am: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in fetchandadd_tree_am: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in fetchandadd_tree_am: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in fetchandadd_tree_am: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program fetchandadd_tree_am exited without No Errors
Processing directory spawn
Looking in ./spawn/testlist
Unexpected output in taskmaster: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in taskmaster: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:906): assert (!closed) failed
Unexpected output in taskmaster: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in taskmaster: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in taskmaster: [proxy:8:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:906): assert (!closed) failed
Unexpected output in taskmaster: [proxy:8:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in taskmaster: [proxy:8:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in taskmaster: [mpiexec at PC03] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting
Unexpected output in taskmaster: [mpiexec at PC03] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion
Unexpected output in taskmaster: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:189): launcher returned error waiting for completion
Unexpected output in taskmaster: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program taskmaster exited without No Errors
Unexpected output in disconnect_reconnect: Fatal error in MPI_Comm_connect: Invalid port, error stack:
Unexpected output in disconnect_reconnect: MPI_Comm_connect(127).............: MPI_Comm_connect(port="tag#0$description#PC03$port#1867$ifname#10.67.254.216$", MPI_INFO_NULL, root=0, MPI_COMM_WORLD, newcomm=0x22ac48) failed
Unexpected output in disconnect_reconnect: MPID_Comm_connect(191)............:
Unexpected output in disconnect_reconnect: MPIDI_Comm_connect(546)...........: Named port tag#0$description#PC03$port#1867$ifname#10.67.254.216$ does not exist
Unexpected output in disconnect_reconnect: MPIDI_Comm_connect(401)...........:
Unexpected output in disconnect_reconnect: MPIC_Sendrecv(192)................:
Unexpected output in disconnect_reconnect: MPIC_Wait(540)....................:
Unexpected output in disconnect_reconnect: MPIDI_CH3I_Progress(402)..........:
Unexpected output in disconnect_reconnect: MPID_nem_mpich2_blocking_recv(905):
Unexpected output in disconnect_reconnect: MPID_nem_tcp_connpoll(1838).......:
Unexpected output in disconnect_reconnect: state_c_tmpvcsent_handler(1264)...: Failure during connection protocol
Unexpected output in disconnect_reconnect: recv_cmd_pkt(739).................: read from socket failed - Connection reset by peerFatal error in MPI_Comm_connect: Invalid port, error stack:
Unexpected output in disconnect_reconnect: MPI_Comm_connect(127)..: MPI_Comm_connect(port="", MPI_INFO_NULL, root=0, MPI_COMM_WORLD, newcomm=0x22ac48) failed
Unexpected output in disconnect_reconnect: MPID_Comm_connect(191).:
Unexpected output in disconnect_reconnect: MPIDI_Comm_connect(412): Named port  does not exist
Unexpected output in disconnect_reconnect: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in disconnect_reconnect: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:906): assert (!closed) failed
Unexpected output in disconnect_reconnect: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in disconnect_reconnect: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in disconnect_reconnect: [mpiexec at PC03] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting
Unexpected output in disconnect_reconnect: [mpiexec at PC03] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion
Unexpected output in disconnect_reconnect: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:189): launcher returned error waiting for completion
Unexpected output in disconnect_reconnect: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program disconnect_reconnect exited without No Errors
Unexpected output in disconnect3: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in disconnect3: MPIR_Init_thread(388).................:
Unexpected output in disconnect3: MPID_Init(139)........................: channel initialization failed
Unexpected output in disconnect3: MPIDI_CH3_Init(38)....................:
Unexpected output in disconnect3: MPID_nem_init(196)....................:
Unexpected output in disconnect3: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in disconnect3: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in disconnect3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program disconnect3 exited without No Errors
Processing directory topo
Looking in ./topo/testlist
Unexpected output in topotest: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in topotest: MPIR_Init_thread(388).................:
Unexpected output in topotest: MPID_Init(139)........................: channel initialization failed
Unexpected output in topotest: MPIDI_CH3_Init(38)....................:
Unexpected output in topotest: MPID_nem_init(196)....................:
Unexpected output in topotest: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in topotest: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in topotest: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in topotest: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in topotest: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in topotest: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in topotest: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program topotest exited without No Errors
Processing directory io
Looking in ./io/testlist
Unexpected output in async_any: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in async_any: MPIR_Init_thread(388).................:
Unexpected output in async_any: MPID_Init(139)........................: channel initialization failed
Unexpected output in async_any: MPIDI_CH3_Init(38)....................:
Unexpected output in async_any: MPID_nem_init(196)....................:
Unexpected output in async_any: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in async_any: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in async_any: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in async_any: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program async_any exited without No Errors
Processing directory f77
Looking in ./f77/testlist
Looking in ./f77/attr/testlist
Failed to build baseattrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/attr'
  F77             baseattrf.f
(cd ../util && make mtestf.o)
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/util'
  F77             mtestf.f
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/util'
/usr/local/bin/mpif77  ../util/mtestf.o  -o baseattrf baseattrf.o
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:63: recipe for target `baseattrf' failed
make[2]: *** [baseattrf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/attr'
Failed to build baseattr2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/attr'
  F77             baseattr2f.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o baseattr2f baseattr2f.o
Makefile:61: recipe for target `baseattr2f' failed
make[2]: *** [baseattr2f] Error 1
Failed to build commattrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/attr'
  F77             commattrf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o commattrf commattrf.o
Makefile:65: recipe for target `commattrf' failed
make[2]: *** [commattrf] Error 1
Failed to build commattr2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/attr'
  F77             commattr2f.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o commattr2f commattr2f.o
Makefile:67: recipe for target `commattr2f' failed
make[2]: *** [commattr2f] Error 1
Failed to build commattr3f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/attr'
  F77             commattr3f.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o commattr3f commattr3f.o
Makefile:69: recipe for target `commattr3f' failed
make[2]: *** [commattr3f] Error 1
Failed to build typeattrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/attr'
  F77             typeattrf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o typeattrf typeattrf.o
Makefile:59: recipe for target `typeattrf' failed
make[2]: *** [typeattrf] Error 1
Failed to build typeattr2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/attr'
  F77             typeattr2f.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o typeattr2f typeattr2f.o
Makefile:73: recipe for target `typeattr2f' failed
make[2]: *** [typeattr2f] Error 1
Failed to build typeattr3f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/attr'
  F77             typeattr3f.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o typeattr3f typeattr3f.o
Makefile:71: recipe for target `typeattr3f' failed
make[2]: *** [typeattr3f] Error 1
Looking in ./f77/coll/testlist
Failed to build uallreducef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/coll'
  F77             uallreducef.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o uallreducef uallreducef.o
Makefile:65: recipe for target `uallreducef' failed
make[2]: *** [uallreducef] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/coll'
Failed to build exscanf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/coll'
  F77             exscanf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o exscanf exscanf.o
Makefile:67: recipe for target `exscanf' failed
make[2]: *** [exscanf] Error 1
Failed to build alltoallwf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/coll'
  F77             alltoallwf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o alltoallwf alltoallwf.o
Makefile:69: recipe for target `alltoallwf' failed
make[2]: *** [alltoallwf] Error 1
Failed to build inplacef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/coll'
  F77             inplacef.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o inplacef inplacef.o
Makefile:57: recipe for target `inplacef' failed
make[2]: *** [inplacef] Error 1
Failed to build reducelocalf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/coll'
  F77             reducelocalf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o reducelocalf reducelocalf.o
Makefile:63: recipe for target `reducelocalf' failed
make[2]: *** [reducelocalf] Error 1
Looking in ./f77/datatype/testlist
Failed to build typenamef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/datatype'
  F77             typenamef.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o typenamef typenamef.o
Makefile:71: recipe for target `typenamef' failed
make[2]: *** [typenamef] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/datatype'
Failed to build typesnamef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/datatype'
  F77             typesnamef.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o typesnamef typesnamef.o
Makefile:73: recipe for target `typesnamef' failed
make[2]: *** [typesnamef] Error 1
Failed to build typecntsf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/datatype'
  F77             typecntsf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o typecntsf typecntsf.o
Makefile:65: recipe for target `typecntsf' failed
make[2]: *** [typecntsf] Error 1
Failed to build typem2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/datatype'
  F77             typem2f.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o typem2f typem2f.o
Makefile:59: recipe for target `typem2f' failed
make[2]: *** [typem2f] Error 1
Failed to build typesubf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/datatype'
  F77             typesubf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o typesubf typesubf.o
Makefile:61: recipe for target `typesubf' failed
make[2]: *** [typesubf] Error 1
Failed to build packef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/datatype'
  F77             packef.f
In file packef.f:138
       call mpi_pack_external( 'external32', inbuf2, insize2,
                                             1
In file packef.f:131
       call mpi_pack_external( 'external32', cbuf, csize,
                                             2
Warning (155): Inconsistent types (INTEGER(4)/CHARACTER(1)) in actual argument lists at (1) and (2)
                                             1
In file packef.f:124
       call mpi_pack_external( 'external32', rbuf, rsize,
                                             2
Warning (155): Inconsistent types (INTEGER(4)/REAL(8)) in actual argument lists at (1) and (2)
In file packef.f:155
     &  aintv(2), ioutbuf2, insize2, MPI_INTEGER, ierr )
                  1
In file packef.f:153
     &  aintv(2), coutbuf, csize, MPI_CHARACTER, ierr )
                  2
                  1
In file packef.f:151
     &  aintv(2), routbuf, rsize, MPI_DOUBLE_PRECISION, ierr )
                  2
/usr/local/bin/mpif77  ../util/mtestf.o  -o packef packef.o
Makefile:69: recipe for target `packef' failed
make[2]: *** [packef] Error 1
Failed to build gaddressf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/datatype'
  F77             gaddressf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o gaddressf gaddressf.o
Makefile:63: recipe for target `gaddressf' failed
make[2]: *** [gaddressf] Error 1
Failed to build allctypesf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/datatype'
  F77             allctypesf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o allctypesf allctypesf.o
Makefile:67: recipe for target `allctypesf' failed
make[2]: *** [allctypesf] Error 1
Looking in ./f77/pt2pt/testlist
Failed to build statusesf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/pt2pt'
  F77             statusesf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o statusesf statusesf.o
Makefile:60: recipe for target `statusesf' failed
make[2]: *** [statusesf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/pt2pt'
Failed to build greqf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/pt2pt'
  F77             greqf.f
  F77             dummyf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o greqf greqf.o dummyf.o
Makefile:58: recipe for target `greqf' failed
make[2]: *** [greqf] Error 1
Looking in ./f77/info/testlist
Failed to build infotestf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/info'
  F77             infotestf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o infotestf infotestf.o
Makefile:57: recipe for target `infotestf' failed
make[2]: *** [infotestf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/info'
Failed to build infotest2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/info'
  F77             infotest2f.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o infotest2f infotest2f.o
Makefile:59: recipe for target `infotest2f' failed
make[2]: *** [infotest2f] Error 1
Looking in ./f77/spawn/testlist
Failed to build namepubf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/spawn'
  F77             namepubf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o namepubf namepubf.o
Makefile:68: recipe for target `namepubf' failed
make[2]: *** [namepubf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/spawn'
Failed to build spawnf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/spawn'
  F77             spawnf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o spawnf spawnf.o
Makefile:64: recipe for target `spawnf' failed
make[2]: *** [spawnf] Error 1
Failed to build spawnargvf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/spawn'
  F77             spawnargvf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o spawnargvf spawnargvf.o
Makefile:66: recipe for target `spawnargvf' failed
make[2]: *** [spawnargvf] Error 1
Failed to build connaccf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/spawn'
  F77             connaccf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o connaccf connaccf.o
Makefile:62: recipe for target `connaccf' failed
make[2]: *** [connaccf] Error 1
Failed to build spawnmultf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/spawn'
  F77             spawnmultf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o spawnmultf spawnmultf.o
Makefile:60: recipe for target `spawnmultf' failed
make[2]: *** [spawnmultf] Error 1
Failed to build spawnmult2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/spawn'
  F77             spawnmult2f.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o spawnmult2f spawnmult2f.o
Makefile:58: recipe for target `spawnmult2f' failed
make[2]: *** [spawnmult2f] Error 1
Looking in ./f77/io/testlist
Failed to build iwriteatf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
../../maint/testmerge -defn=../../maint/common.defn \
	./ioharness.defn ./ioharness.tlt
Opening ../../maint/common.defn..
  F77             iwriteatf.f
/usr/local/bin/mpif77   -o iwriteatf iwriteatf.o  ../util/mtestf.o
/usr/local/lib/libpmpich.a(_finalize.o):finalize.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_finalize.o):finalize.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_finalize.o):finalize.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_finalize.o):finalize.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_finalize.o):finalize.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_finalize.o):finalize.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:117: recipe for target `iwriteatf' failed
make[2]: *** [iwriteatf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
Failed to build iwritef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             iwritef.f
/usr/local/bin/mpif77   -o iwritef iwritef.o  ../util/mtestf.o
Makefile:93: recipe for target `iwritef' failed
make[2]: *** [iwritef] Error 1
Failed to build iwriteshf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             iwriteshf.f
/usr/local/bin/mpif77   -o iwriteshf iwriteshf.o  ../util/mtestf.o
Makefile:87: recipe for target `iwriteshf' failed
make[2]: *** [iwriteshf] Error 1
Failed to build writef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             writef.f
/usr/local/bin/mpif77   -o writef writef.o  ../util/mtestf.o
Makefile:85: recipe for target `writef' failed
make[2]: *** [writef] Error 1
Failed to build writeatf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             writeatf.f
/usr/local/bin/mpif77   -o writeatf writeatf.o  ../util/mtestf.o
Makefile:91: recipe for target `writeatf' failed
make[2]: *** [writeatf] Error 1
Failed to build writeallf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             writeallf.f
/usr/local/bin/mpif77   -o writeallf writeallf.o  ../util/mtestf.o
Makefile:89: recipe for target `writeallf' failed
make[2]: *** [writeallf] Error 1
Failed to build writeshf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             writeshf.f
/usr/local/bin/mpif77   -o writeshf writeshf.o  ../util/mtestf.o
Makefile:115: recipe for target `writeshf' failed
make[2]: *** [writeshf] Error 1
Failed to build writeordf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             writeordf.f
/usr/local/bin/mpif77   -o writeordf writeordf.o  ../util/mtestf.o
Makefile:123: recipe for target `writeordf' failed
make[2]: *** [writeordf] Error 1
Failed to build writeatallf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             writeatallf.f
/usr/local/bin/mpif77   -o writeatallf writeatallf.o  ../util/mtestf.o
Makefile:121: recipe for target `writeatallf' failed
make[2]: *** [writeatallf] Error 1
Failed to build writeatallbef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             writeatallbef.f
/usr/local/bin/mpif77   -o writeatallbef writeatallbef.o  ../util/mtestf.o \
Makefile:106: recipe for target `writeatallbef' failed
make[2]: *** [writeatallbef] Error 1
Failed to build writeallbef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             writeallbef.f
/usr/local/bin/mpif77   -o writeallbef writeallbef.o  ../util/mtestf.o
Makefile:95: recipe for target `writeallbef' failed
make[2]: *** [writeallbef] Error 1
Failed to build writeordbef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             writeordbef.f
/usr/local/bin/mpif77   -o writeordbef writeordbef.o  ../util/mtestf.o
Makefile:111: recipe for target `writeordbef' failed
make[2]: *** [writeordbef] Error 1
Failed to build fileerrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             fileerrf.f
/usr/local/bin/mpif77   -o fileerrf fileerrf.o  ../util/mtestf.o
/usr/local/lib/libpmpich.a(_abort.o):abort.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_abort.o):abort.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_abort.o):abort.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_abort.o):abort.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_abort.o):abort.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_abort.o):abort.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:119: recipe for target `fileerrf' failed
make[2]: *** [fileerrf] Error 1
Failed to build fileinfof; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             fileinfof.f
/usr/local/bin/mpif77   -o fileinfof fileinfof.o  ../util/mtestf.o
Makefile:99: recipe for target `fileinfof' failed
make[2]: *** [fileinfof] Error 1
Failed to build shpositionf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             shpositionf.f
/usr/local/bin/mpif77   -o shpositionf shpositionf.o  ../util/mtestf.o
Makefile:83: recipe for target `shpositionf' failed
make[2]: *** [shpositionf] Error 1
Failed to build atomicityf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             atomicityf.f
/usr/local/bin/mpif77   -o atomicityf atomicityf.o
Makefile:109: recipe for target `atomicityf' failed
make[2]: *** [atomicityf] Error 1
Failed to build miscfilef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             miscfilef.f
/usr/local/bin/mpif77   -o miscfilef miscfilef.o  ../util/mtestf.o
Makefile:97: recipe for target `miscfilef' failed
make[2]: *** [miscfilef] Error 1
Failed to build setviewcurf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  F77             setviewcurf.f
/usr/local/bin/mpif77   -o setviewcurf setviewcurf.o  ../util/mtestf.o
Makefile:113: recipe for target `setviewcurf' failed
make[2]: *** [setviewcurf] Error 1
Failed to build c2f2ciof; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/io'
  CC              c2f2cio.c
  F77             c2f2ciof.f
/usr/local/bin/mpif77   -o c2f2ciof c2f2cio.o c2f2ciof.o  ../util/mtestf.o  \
/usr/local/lib/libpmpich.a(_comm_group.o):comm_group.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_group.o):comm_group.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_group.o):comm_group.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_group.o):comm_group.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_group.o):comm_group.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_group.o):comm_group.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:103: recipe for target `c2f2ciof' failed
make[2]: *** [c2f2ciof] Error 1
Looking in ./f77/rma/testlist
Failed to build winscale1f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
  F77             winscale1f.f
/usr/local/bin/mpif77   -o winscale1f winscale1f.o  ../util/mtestf.o
Makefile:83: recipe for target `winscale1f' failed
make[2]: *** [winscale1f] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
Failed to build winfencef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
  F77             winfencef.f
/usr/local/bin/mpif77   -o winfencef winfencef.o  ../util/mtestf.o
Makefile:99: recipe for target `winfencef' failed
make[2]: *** [winfencef] Error 1
Failed to build wingetf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
  F77             wingetf.f
/usr/local/bin/mpif77   -o wingetf wingetf.o  ../util/mtestf.o
Makefile:81: recipe for target `wingetf' failed
make[2]: *** [wingetf] Error 1
Failed to build winscale2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
  F77             winscale2f.f
/usr/local/bin/mpif77   -o winscale2f winscale2f.o  ../util/mtestf.o
Makefile:95: recipe for target `winscale2f' failed
make[2]: *** [winscale2f] Error 1
Failed to build winerrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
  F77             winerrf.f
/usr/local/bin/mpif77   -o winerrf winerrf.o  ../util/mtestf.o
Makefile:87: recipe for target `winerrf' failed
make[2]: *** [winerrf] Error 1
Failed to build winnamef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
  F77             winnamef.f
/usr/local/bin/mpif77   -o winnamef winnamef.o  ../util/mtestf.o
Makefile:105: recipe for target `winnamef' failed
make[2]: *** [winnamef] Error 1
Failed to build wingroupf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
  F77             wingroupf.f
/usr/local/bin/mpif77   -o wingroupf wingroupf.o  ../util/mtestf.o
Makefile:97: recipe for target `wingroupf' failed
make[2]: *** [wingroupf] Error 1
Failed to build winaccf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
  F77             winaccf.f
/usr/local/bin/mpif77   -o winaccf winaccf.o  ../util/mtestf.o
Makefile:101: recipe for target `winaccf' failed
make[2]: *** [winaccf] Error 1
Failed to build c2f2cwinf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
  CC              c2f2cwin.c
  F77             c2f2cwinf.f
/usr/local/bin/mpif77   -o c2f2cwinf c2f2cwin.o c2f2cwinf.o  ../util/mtestf.o  \
/usr/local/lib/libpmpich.a(_win_get_group.o):win_get_group.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_win_get_group.o):win_get_group.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_win_get_group.o):win_get_group.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_win_get_group.o):win_get_group.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_win_get_group.o):win_get_group.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_win_get_group.o):win_get_group.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:92: recipe for target `c2f2cwinf' failed
make[2]: *** [c2f2cwinf] Error 1
Failed to build baseattrwinf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
  F77             baseattrwinf.f
/usr/local/bin/mpif77   -o baseattrwinf baseattrwinf.o  ../util/mtestf.o \
Makefile:89: recipe for target `baseattrwinf' failed
make[2]: *** [baseattrwinf] Error 1
Failed to build winattrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
  F77             winattrf.f
/usr/local/bin/mpif77   -o winattrf winattrf.o  ../util/mtestf.o
Makefile:85: recipe for target `winattrf' failed
make[2]: *** [winattrf] Error 1
Failed to build winattr2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/rma'
  F77             winattr2f.f
/usr/local/bin/mpif77   -o winattr2f winattr2f.o  ../util/mtestf.o
Makefile:103: recipe for target `winattr2f' failed
make[2]: *** [winattr2f] Error 1
Looking in ./f77/init/testlist
Failed to build baseenvf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/init'
  F77             baseenvf.f
/usr/local/bin/mpif77   -o baseenvf baseenvf.o  ../util/mtestf.o
Makefile:78: recipe for target `baseenvf' failed
make[2]: *** [baseenvf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/init'
Looking in ./f77/comm/testlist
Failed to build commnamef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/comm'
  F77             commnamef.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o commnamef commnamef.o
Makefile:59: recipe for target `commnamef' failed
make[2]: *** [commnamef] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/comm'
Failed to build commerrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/comm'
  F77             commerrf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o commerrf commerrf.o
Makefile:57: recipe for target `commerrf' failed
make[2]: *** [commerrf] Error 1
Processing directory ext
Looking in ./f77/ext/testlist
Failed to build c2f2cf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/ext'
  CC              c2f2c.c
  F77             c2f2cf.f
/usr/local/bin/mpif77   -o c2f2cf c2f2c.o c2f2cf.o  ../util/mtestf.o
/usr/local/lib/libpmpich.a(_comm_rank.o):comm_rank.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_rank.o):comm_rank.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_rank.o):comm_rank.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_rank.o):comm_rank.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_rank.o):comm_rank.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_rank.o):comm_rank.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:87: recipe for target `c2f2cf' failed
make[2]: *** [c2f2cf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/ext'
Failed to build ctypesinf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/ext'
  F77             ctypesinf.f
  CC              ctypesfromc.c
/usr/local/bin/mpif77   -o ctypesinf ctypesinf.o ctypesfromc.o  \
../util/mtestf.o
Makefile:80: recipe for target `ctypesinf' failed
make[2]: *** [ctypesinf] Error 1
Looking in ./f77/topo/testlist
Failed to build cartcrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/topo'
  F77             cartcrf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o cartcrf cartcrf.o
Makefile:59: recipe for target `cartcrf' failed
make[2]: *** [cartcrf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/topo'
Failed to build dgraph_wgtf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/topo'
  F77             dgraph_wgtf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o dgraph_wgtf dgraph_wgtf.o
Makefile:57: recipe for target `dgraph_wgtf' failed
make[2]: *** [dgraph_wgtf] Error 1
Failed to build dgraph_unwgtf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f77/topo'
  F77             dgraph_unwgtf.f
/usr/local/bin/mpif77  ../util/mtestf.o  -o dgraph_unwgtf dgraph_unwgtf.o
Makefile:61: recipe for target `dgraph_unwgtf' failed
make[2]: *** [dgraph_unwgtf] Error 1
Processing directory cxx
Looking in ./cxx/testlist
Processing directory attr
Looking in ./cxx/attr/testlist
Looking in ./cxx/pt2pt/testlist
Looking in ./cxx/comm/testlist
Processing directory coll
Looking in ./cxx/coll/testlist
Unexpected output in uallreduce: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in uallreduce: MPIR_Init_thread(388).................:
Unexpected output in uallreduce: MPID_Init(139)........................: channel initialization failed
Unexpected output in uallreduce: MPIDI_CH3_Init(38)....................:
Unexpected output in uallreduce: MPID_nem_init(196)....................:
Unexpected output in uallreduce: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in uallreduce: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in uallreduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in uallreduce: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in uallreduce: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in uallreduce: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in uallreduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program uallreduce exited without No Errors
Unexpected output in uscan: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in uscan: MPIR_Init_thread(388).................:
Unexpected output in uscan: MPID_Init(139)........................: channel initialization failed
Unexpected output in uscan: MPIDI_CH3_Init(38)....................:
Unexpected output in uscan: MPID_nem_init(196)....................:
Unexpected output in uscan: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in uscan: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in uscan: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in uscan: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in uscan: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in uscan: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in uscan: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program uscan exited without No Errors
Unexpected output in uexscan: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in uexscan: MPIR_Init_thread(388).................:
Unexpected output in uexscan: MPID_Init(139)........................: channel initialization failed
Unexpected output in uexscan: MPIDI_CH3_Init(38)....................:
Unexpected output in uexscan: MPID_nem_init(196)....................:
Unexpected output in uexscan: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in uexscan: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in uexscan: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in uexscan: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program uexscan exited without No Errors
Unexpected output in alltoallw2x: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in alltoallw2x: MPIR_Init_thread(388).................:
Unexpected output in alltoallw2x: MPID_Init(139)........................: channel initialization failed
Unexpected output in alltoallw2x: MPIDI_CH3_Init(38)....................:
Unexpected output in alltoallw2x: MPID_nem_init(196)....................:
Unexpected output in alltoallw2x: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in alltoallw2x: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in alltoallw2x: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in alltoallw2x: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in alltoallw2x: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in alltoallw2x: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in alltoallw2x: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in alltoallw2x: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Permission denied
Program alltoallw2x exited without No Errors
Unexpected output in icallgatherx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icallgatherx: MPIR_Init_thread(388).................:
Unexpected output in icallgatherx: MPID_Init(139)........................: channel initialization failed
Unexpected output in icallgatherx: MPIDI_CH3_Init(38)....................:
Unexpected output in icallgatherx: MPID_nem_init(196)....................:
Unexpected output in icallgatherx: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icallgatherx: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icallgatherx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in icallgatherx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icallgatherx: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icallgatherx: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icallgatherx: MPIU_SHMW_Seg_open(863)...............:
Program icallgatherx exited without No Errors
Unexpected output in icgathervx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icgathervx: MPIR_Init_thread(388).................:
Unexpected output in icgathervx: MPID_Init(139)........................: channel initialization failed
Unexpected output in icgathervx: MPIDI_CH3_Init(38)....................:
Unexpected output in icgathervx: MPID_nem_init(196)....................:
Unexpected output in icgathervx: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icgathervx: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icgathervx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in icgathervx: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icgathervx: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icgathervx: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in icgathervx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program icgathervx exited without No Errors
Unexpected output in icscattervx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icscattervx: MPIR_Init_thread(388).................:
Unexpected output in icscattervx: MPID_Init(139)........................: channel initialization failed
Unexpected output in icscattervx: MPIDI_CH3_Init(38)....................:
Unexpected output in icscattervx: MPID_nem_init(196)....................:
Unexpected output in icscattervx: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icscattervx: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icscattervx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in icscattervx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program icscattervx exited without No Errors
Looking in ./cxx/errhan/testlist
Looking in ./cxx/init/testlist
Looking in ./cxx/info/testlist
Looking in ./cxx/datatype/testlist
Looking in ./cxx/io/testlist
Unexpected output in writeatallx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in writeatallx: MPIR_Init_thread(388).................:
Unexpected output in writeatallx: MPID_Init(139)........................: channel initialization failed
Unexpected output in writeatallx: MPIDI_CH3_Init(38)....................:
Unexpected output in writeatallx: MPID_nem_init(196)....................:
Unexpected output in writeatallx: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in writeatallx: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in writeatallx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in writeatallx: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in writeatallx: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in writeatallx: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in writeatallx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program writeatallx exited without No Errors
Unexpected output in writeatallbex: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in writeatallbex: MPIR_Init_thread(388).................:
Unexpected output in writeatallbex: MPID_Init(139)........................: channel initialization failed
Unexpected output in writeatallbex: MPIDI_CH3_Init(38)....................:
Unexpected output in writeatallbex: MPID_nem_init(196)....................:
Unexpected output in writeatallbex: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in writeatallbex: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in writeatallbex: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program writeatallbex exited without No Errors
Unexpected output in writeordbex: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in writeordbex: MPIR_Init_thread(388).................:
Unexpected output in writeordbex: MPID_Init(139)........................: channel initialization failed
Unexpected output in writeordbex: MPIDI_CH3_Init(38)....................:
Unexpected output in writeordbex: MPID_nem_init(196)....................:
Unexpected output in writeordbex: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in writeordbex: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in writeordbex: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in writeordbex: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in writeordbex: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in writeordbex: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in writeordbex: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program writeordbex exited without No Errors
Unexpected output in iwriteatnosx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in iwriteatnosx: MPIR_Init_thread(388).................:
Unexpected output in iwriteatnosx: MPID_Init(139)........................: channel initialization failed
Unexpected output in iwriteatnosx: MPIDI_CH3_Init(38)....................:
Unexpected output in iwriteatnosx: MPID_nem_init(196)....................:
Unexpected output in iwriteatnosx: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in iwriteatnosx: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in iwriteatnosx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program iwriteatnosx exited without No Errors
Unexpected output in iwriteshnosx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in iwriteshnosx: MPIR_Init_thread(388).................:
Unexpected output in iwriteshnosx: MPID_Init(139)........................: channel initialization failed
Unexpected output in iwriteshnosx: MPIDI_CH3_Init(38)....................:
Unexpected output in iwriteshnosx: MPID_nem_init(196)....................:
Unexpected output in iwriteshnosx: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in iwriteshnosx: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in iwriteshnosx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program iwriteshnosx exited without No Errors
Unexpected output in writeatallbenosx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in writeatallbenosx: MPIR_Init_thread(388).................:
Unexpected output in writeatallbenosx: MPID_Init(139)........................: channel initialization failed
Unexpected output in writeatallbenosx: MPIDI_CH3_Init(38)....................:
Unexpected output in writeatallbenosx: MPID_nem_init(196)....................:
Unexpected output in writeatallbenosx: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in writeatallbenosx: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in writeatallbenosx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in writeatallbenosx: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in writeatallbenosx: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in writeatallbenosx: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in writeatallbenosx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program writeatallbenosx exited without No Errors
Looking in ./cxx/spawn/testlist
Looking in ./cxx/rma/testlist
Unexpected output in winscale2x: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in winscale2x: MPIR_Init_thread(388).................:
Unexpected output in winscale2x: MPID_Init(139)........................: channel initialization failed
Unexpected output in winscale2x: MPIDI_CH3_Init(38)....................:
Unexpected output in winscale2x: MPID_nem_init(196)....................:
Unexpected output in winscale2x: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in winscale2x: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in winscale2x: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program winscale2x exited without No Errors
Processing directory f90
Looking in ./f90/testlist
Looking in ./f90/attr/testlist
Failed to build baseattrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/attr'
  FC              baseattrf90.f90
(cd ../util && make mtestf90.o)
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/util'
  FC              mtestf90.f90
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/util'
/usr/local/bin/mpif90  ../util/mtestf90.o  -o baseattrf90 baseattrf90.o
Makefile:82: recipe for target `baseattrf90' failed
make[2]: *** [baseattrf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/attr'
Failed to build baseattr2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/attr'
  FC              baseattr2f90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o baseattr2f90 baseattr2f90.o
Makefile:86: recipe for target `baseattr2f90' failed
make[2]: *** [baseattr2f90] Error 1
Failed to build commattrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/attr'
  FC              commattrf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o commattrf90 commattrf90.o
Makefile:84: recipe for target `commattrf90' failed
make[2]: *** [commattrf90] Error 1
Failed to build commattr2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/attr'
  FC              commattr2f90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o commattr2f90 commattr2f90.o
Makefile:92: recipe for target `commattr2f90' failed
make[2]: *** [commattr2f90] Error 1
Failed to build commattr3f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/attr'
  FC              commattr3f90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o commattr3f90 commattr3f90.o
Makefile:80: recipe for target `commattr3f90' failed
make[2]: *** [commattr3f90] Error 1
Failed to build typeattrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/attr'
  FC              typeattrf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o typeattrf90 typeattrf90.o
Makefile:88: recipe for target `typeattrf90' failed
make[2]: *** [typeattrf90] Error 1
Failed to build typeattr2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/attr'
  FC              typeattr2f90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o typeattr2f90 typeattr2f90.o
Makefile:96: recipe for target `typeattr2f90' failed
make[2]: *** [typeattr2f90] Error 1
Failed to build typeattr3f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/attr'
  FC              typeattr3f90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o typeattr3f90 typeattr3f90.o
Makefile:94: recipe for target `typeattr3f90' failed
make[2]: *** [typeattr3f90] Error 1
Failed to build fandcattrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/attr'
  FC              fandcattrf90.f90
  CC              fandcattrc.c
/usr/local/bin/mpif90  ../util/mtestf90.o  -o fandcattrf90 fandcattrf90.o fandcattrc.o
/usr/local/lib/libpmpich.a(_comm_get_attr.o):comm_get_attr.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_get_attr.o):comm_get_attr.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_get_attr.o):comm_get_attr.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_get_attr.o):comm_get_attr.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_get_attr.o):comm_get_attr.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_get_attr.o):comm_get_attr.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:90: recipe for target `fandcattrf90' failed
make[2]: *** [fandcattrf90] Error 1
Looking in ./f90/coll/testlist
Failed to build uallreducef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/coll'
  FC              uallreducef90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o uallreducef90 uallreducef90.o
Makefile:70: recipe for target `uallreducef90' failed
make[2]: *** [uallreducef90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/coll'
Failed to build exscanf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/coll'
  FC              exscanf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o exscanf90 exscanf90.o
Makefile:66: recipe for target `exscanf90' failed
make[2]: *** [exscanf90] Error 1
Failed to build alltoallwf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/coll'
  FC              alltoallwf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o alltoallwf90 alltoallwf90.o
Makefile:64: recipe for target `alltoallwf90' failed
make[2]: *** [alltoallwf90] Error 1
Failed to build inplacef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/coll'
  FC              inplacef90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o inplacef90 inplacef90.o
Makefile:58: recipe for target `inplacef90' failed
make[2]: *** [inplacef90] Error 1
Failed to build reducelocalf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/coll'
  FC              reducelocalf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o reducelocalf90 reducelocalf90.o
Makefile:62: recipe for target `reducelocalf90' failed
make[2]: *** [reducelocalf90] Error 1
Processing directory comm
Looking in ./f90/comm/testlist
Failed to build commnamef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/comm'
  FC              commnamef90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o commnamef90 commnamef90.o
Makefile:59: recipe for target `commnamef90' failed
make[2]: *** [commnamef90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/comm'
Failed to build commerrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/comm'
  FC              commerrf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o commerrf90 commerrf90.o
Makefile:57: recipe for target `commerrf90' failed
make[2]: *** [commerrf90] Error 1
Looking in ./f90/ext/testlist
Failed to build c2f2cf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/ext'
  FC              c2f2cf90.f90
  CC              c2f902c.c
/usr/local/bin/mpif90   -o c2f2cf90 c2f2cf90.o c2f902c.o  ../util/mtestf90.o  \
Makefile:80: recipe for target `c2f2cf90' failed
make[2]: *** [c2f2cf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/ext'
Failed to build ctypesinf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/ext'
  FC              ctypesinf90.f90
  CC              ctypesfromc.c
/usr/local/bin/mpif90   -o ctypesinf90 ctypesinf90.o ctypesfromc.o  \
../util/mtestf90.o
Makefile:85: recipe for target `ctypesinf90' failed
make[2]: *** [ctypesinf90] Error 1
Looking in ./f90/info/testlist
Failed to build infotestf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/info'
  FC              infotestf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o infotestf90 infotestf90.o
Makefile:59: recipe for target `infotestf90' failed
make[2]: *** [infotestf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/info'
Failed to build infotest2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/info'
  FC              infotest2f90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o infotest2f90 infotest2f90.o
Makefile:57: recipe for target `infotest2f90' failed
make[2]: *** [infotest2f90] Error 1
Looking in ./f90/init/testlist
Failed to build baseenvf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/init'
  FC              baseenvf90.f90
/usr/local/bin/mpif90   -o baseenvf90 baseenvf90.o  ../util/mtestf90.o
Makefile:78: recipe for target `baseenvf90' failed
make[2]: *** [baseenvf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/init'
Looking in ./f90/io/testlist
Failed to build fileerrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/io'
  FC              fileerrf90.f90
/usr/local/bin/mpif90   -o fileerrf90 fileerrf90.o  ../util/mtestf90.o
Makefile:92: recipe for target `fileerrf90' failed
make[2]: *** [fileerrf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/io'
Failed to build fileinfof90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/io'
  FC              fileinfof90.f90
/usr/local/bin/mpif90   -o fileinfof90 fileinfof90.o  ../util/mtestf90.o \
Makefile:97: recipe for target `fileinfof90' failed
make[2]: *** [fileinfof90] Error 1
Failed to build shpositionf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/io'
  FC              shpositionf90.f90
/usr/local/bin/mpif90   -o shpositionf90 shpositionf90.o  ../util/mtestf90.o \
Makefile:85: recipe for target `shpositionf90' failed
make[2]: *** [shpositionf90] Error 1
Failed to build atomicityf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/io'
  FC              atomicityf90.f90
/usr/local/bin/mpif90   -o atomicityf90 atomicityf90.o
Makefile:90: recipe for target `atomicityf90' failed
make[2]: *** [atomicityf90] Error 1
Failed to build miscfilef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/io'
  FC              miscfilef90.f90
/usr/local/bin/mpif90   -o miscfilef90 miscfilef90.o  ../util/mtestf90.o \
Makefile:100: recipe for target `miscfilef90' failed
make[2]: *** [miscfilef90] Error 1
Failed to build setviewcurf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/io'
  FC              setviewcurf90.f90
/usr/local/bin/mpif90   -o setviewcurf90 setviewcurf90.o  ../util/mtestf90.o \
Makefile:82: recipe for target `setviewcurf90' failed
make[2]: *** [setviewcurf90] Error 1
Failed to build c2f2ciof90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/io'
  FC              c2f2ciof90.f90
  CC              c2f902cio.c
/usr/local/bin/mpif90   -o c2f2ciof90 c2f2ciof90.o c2f902cio.o  \
../util/mtestf90.o
Makefile:94: recipe for target `c2f2ciof90' failed
make[2]: *** [c2f2ciof90] Error 1
Processing directory misc
Looking in ./f90/misc/testlist
Failed to build sizeof2; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/misc'
  FC              sizeof2.f90
/usr/local/bin/mpif90   -o sizeof2 sizeof2.o
Makefile:65: recipe for target `sizeof2' failed
make[2]: *** [sizeof2] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/misc'
Processing directory pt2pt
Looking in ./f90/pt2pt/testlist
Failed to build statusesf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/pt2pt'
  FC              statusesf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o statusesf90 statusesf90.o
Makefile:60: recipe for target `statusesf90' failed
make[2]: *** [statusesf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/pt2pt'
Failed to build greqf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/pt2pt'
  FC              greqf90.f90
  FC              dummyf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o greqf90 greqf90.o dummyf90.o
Makefile:58: recipe for target `greqf90' failed
make[2]: *** [greqf90] Error 1
Processing directory datatype
Looking in ./f90/datatype/testlist
Failed to build typenamef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
  FC              typenamef90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o typenamef90 typenamef90.o
Makefile:66: recipe for target `typenamef90' failed
make[2]: *** [typenamef90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
Failed to build typesnamef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
  FC              typesnamef90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o typesnamef90 typesnamef90.o
Makefile:78: recipe for target `typesnamef90' failed
make[2]: *** [typesnamef90] Error 1
Failed to build typecntsf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
  FC              typecntsf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o typecntsf90 typecntsf90.o
Makefile:82: recipe for target `typecntsf90' failed
make[2]: *** [typecntsf90] Error 1
Failed to build typem2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
  FC              typem2f90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o typem2f90 typem2f90.o
Makefile:70: recipe for target `typem2f90' failed
make[2]: *** [typem2f90] Error 1
Failed to build typesubf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
  FC              typesubf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o typesubf90 typesubf90.o
Makefile:62: recipe for target `typesubf90' failed
make[2]: *** [typesubf90] Error 1
Failed to build packef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
  FC              packef90.f90
In file packef90.f90:156
                   1
In file packef90.f90:154
                   2
                   1
In file packef90.f90:152
                   2
In file packef90.f90:139
       call mpi_pack_external( 'external32', inbuf2, insize2,  &
                                             1
In file packef90.f90:132
       call mpi_pack_external( 'external32', cbuf, csize,  &
                                             2
                                             1
In file packef90.f90:125
       call mpi_pack_external( 'external32', rbuf, rsize,  &
                                             2
/usr/local/bin/mpif90  ../util/mtestf90.o  -o packef90 packef90.o
Makefile:74: recipe for target `packef90' failed
make[2]: *** [packef90] Error 1
Failed to build gaddressf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
  FC              gaddressf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o gaddressf90 gaddressf90.o
Makefile:60: recipe for target `gaddressf90' failed
make[2]: *** [gaddressf90] Error 1
Failed to build allctypesf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
  FC              allctypesf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o allctypesf90 allctypesf90.o
Makefile:80: recipe for target `allctypesf90' failed
make[2]: *** [allctypesf90] Error 1
Failed to build structf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
  FC              structf.f90
In file structf.f90:65
          call mpi_get_address(x,disp(2),ierr)
                               1
In file structf.f90:61
          call mpi_get_address(name,disp(1),ierr)
                               2
Warning (155): Inconsistent types (REAL(8)/CHARACTER(1)) in actual argument lists at (1) and (2)
In file structf.f90:87
     &            x,1,MPI_DOUBLE_PRECISION, comm,ierr)
                  1
In file structf.f90:85
     &            name,5,MPI_CHARACTER, comm,ierr)
                  2
/usr/local/bin/mpif90  ../util/mtestf90.o  -o structf structf.o
Makefile:64: recipe for target `structf' failed
make[2]: *** [structf] Error 1
Failed to build indtype; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
  FC              indtype.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o indtype indtype.o
Makefile:76: recipe for target `indtype' failed
make[2]: *** [indtype] Error 1
Failed to build createf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
  FC              createf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o createf90 createf90.o
Makefile:68: recipe for target `createf90' failed
make[2]: *** [createf90] Error 1
Failed to build sizeof; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/datatype'
  FC              sizeof.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o sizeof sizeof.o
Makefile:72: recipe for target `sizeof' failed
make[2]: *** [sizeof] Error 1
Processing directory f90types
Looking in ./f90/f90types/testlist
Processing directory rma
Looking in ./f90/rma/testlist
Failed to build winscale1f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
  FC              winscale1f90.f90
/usr/local/bin/mpif90   -o winscale1f90 winscale1f90.o  ../util/mtestf90.o \
Makefile:93: recipe for target `winscale1f90' failed
make[2]: *** [winscale1f90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
Failed to build winfencef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
  FC              winfencef90.f90
/usr/local/bin/mpif90   -o winfencef90 winfencef90.o  ../util/mtestf90.o \
Makefile:101: recipe for target `winfencef90' failed
make[2]: *** [winfencef90] Error 1
Failed to build wingetf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
  FC              wingetf90.f90
/usr/local/bin/mpif90   -o wingetf90 wingetf90.o  ../util/mtestf90.o
Makefile:83: recipe for target `wingetf90' failed
make[2]: *** [wingetf90] Error 1
Failed to build winscale2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
  FC              winscale2f90.f90
/usr/local/bin/mpif90   -o winscale2f90 winscale2f90.o  ../util/mtestf90.o \
Makefile:109: recipe for target `winscale2f90' failed
make[2]: *** [winscale2f90] Error 1
Failed to build winerrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
  FC              winerrf90.f90
/usr/local/bin/mpif90   -o winerrf90 winerrf90.o  ../util/mtestf90.o
Makefile:81: recipe for target `winerrf90' failed
make[2]: *** [winerrf90] Error 1
Failed to build winnamef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
  FC              winnamef90.f90
/usr/local/bin/mpif90   -o winnamef90 winnamef90.o  ../util/mtestf90.o
Makefile:104: recipe for target `winnamef90' failed
make[2]: *** [winnamef90] Error 1
Failed to build wingroupf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
  FC              wingroupf90.f90
/usr/local/bin/mpif90   -o wingroupf90 wingroupf90.o  ../util/mtestf90.o \
Makefile:96: recipe for target `wingroupf90' failed
make[2]: *** [wingroupf90] Error 1
Failed to build winaccf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
  FC              winaccf90.f90
/usr/local/bin/mpif90   -o winaccf90 winaccf90.o  ../util/mtestf90.o
Makefile:85: recipe for target `winaccf90' failed
make[2]: *** [winaccf90] Error 1
Failed to build c2f2cwinf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
  FC              c2f2cwinf90.f90
  CC              c2f902cwin.c
/usr/local/bin/mpif90   -o c2f2cwinf90 c2f2cwinf90.o c2f902cwin.o  \
../util/mtestf90.o
Makefile:106: recipe for target `c2f2cwinf90' failed
make[2]: *** [c2f2cwinf90] Error 1
Failed to build baseattrwinf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
  FC              baseattrwinf90.f90
/usr/local/bin/mpif90   -o baseattrwinf90 baseattrwinf90.o  ../util/mtestf90.o \
Makefile:87: recipe for target `baseattrwinf90' failed
make[2]: *** [baseattrwinf90] Error 1
Failed to build winattrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
  FC              winattrf90.f90
/usr/local/bin/mpif90   -o winattrf90 winattrf90.o  ../util/mtestf90.o
Makefile:99: recipe for target `winattrf90' failed
make[2]: *** [winattrf90] Error 1
Failed to build winattr2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/rma'
  FC              winattr2f90.f90
/usr/local/bin/mpif90   -o winattr2f90 winattr2f90.o  ../util/mtestf90.o \
Makefile:90: recipe for target `winattr2f90' failed
make[2]: *** [winattr2f90] Error 1
Processing directory spawn
Looking in ./f90/spawn/testlist
Failed to build namepubf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/spawn'
  FC              namepubf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o namepubf90 namepubf90.o
Makefile:60: recipe for target `namepubf90' failed
make[2]: *** [namepubf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/spawn'
Failed to build spawnf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/spawn'
  FC              spawnf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o spawnf90 spawnf90.o
Makefile:62: recipe for target `spawnf90' failed
make[2]: *** [spawnf90] Error 1
Failed to build spawnargvf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/spawn'
  FC              spawnargvf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o spawnargvf90 spawnargvf90.o   \
Makefile:67: recipe for target `spawnargvf90' failed
make[2]: *** [spawnargvf90] Error 1
Failed to build connaccf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/spawn'
  FC              connaccf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o connaccf90 connaccf90.o
Makefile:58: recipe for target `connaccf90' failed
make[2]: *** [connaccf90] Error 1
Failed to build spawnmultf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/spawn'
  FC              spawnmultf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o spawnmultf90 spawnmultf90.o   \
Makefile:64: recipe for target `spawnmultf90' failed
make[2]: *** [spawnmultf90] Error 1
Failed to build spawnmult2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/spawn'
  FC              spawnmult2f90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o spawnmult2f90 spawnmult2f90.o
Makefile:70: recipe for target `spawnmult2f90' failed
make[2]: *** [spawnmult2f90] Error 1
Processing directory timer
Looking in ./f90/timer/testlist
Failed to build wtimef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/timer'
  FC              wtimef90.f90
/usr/local/bin/mpif90   -o wtimef90 wtimef90.o
Makefile:54: recipe for target `wtimef90' failed
make[2]: *** [wtimef90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/timer'
Processing directory topo
Looking in ./f90/topo/testlist
Failed to build cartcrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/topo'
  FC              cartcrf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o cartcrf90 cartcrf90.o
Makefile:59: recipe for target `cartcrf90' failed
make[2]: *** [cartcrf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/topo'
Failed to build dgraph_wgtf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/topo'
  FC              dgraph_wgtf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o dgraph_wgtf90 dgraph_wgtf90.o
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:57: recipe for target `dgraph_wgtf90' failed
make[2]: *** [dgraph_wgtf90] Error 1
Failed to build dgraph_unwgtf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi/f90/topo'
  FC              dgraph_unwgtf90.f90
/usr/local/bin/mpif90  ../util/mtestf90.o  -o dgraph_unwgtf90 dgraph_unwgtf90.o
Makefile:61: recipe for target `dgraph_unwgtf90' failed
make[2]: *** [dgraph_unwgtf90] Error 1
Processing directory errors
Looking in ./errors/testlist
Looking in ./errors/attr/testlist
Looking in ./errors/coll/testlist
Unexpected output in bcastlength: Did not detect mismatched length (long) on process 3
Unexpected output in bcastlength: Did not detect mismatched length (short) on process 3
Unexpected output in bcastlength:  Found 2 errors
Program bcastlength exited without No Errors
Looking in ./errors/comm/testlist
Unexpected output in userdup: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in userdup: MPIR_Init_thread(388).................:
Unexpected output in userdup: MPID_Init(139)........................: channel initialization failed
Unexpected output in userdup: MPIDI_CH3_Init(38)....................:
Unexpected output in userdup: MPID_nem_init(196)....................:
Unexpected output in userdup: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in userdup: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in userdup: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program userdup exited without No Errors
Processing directory group
Looking in ./errors/group/testlist
Looking in ./errors/pt2pt/testlist
Looking in ./errors/topo/testlist
Looking in ./errors/rma/testlist
Looking in ./errors/spawn/testlist
Processing directory io
Looking in ./errors/io/testlist
Processing directory f77
Looking in ./errors/f77/testlist
Looking in ./errors/cxx/testlist
Processing directory errhan
Looking in ./errors/cxx/errhan/testlist
Looking in ./errors/cxx/io/testlist
Looking in ./errors/f90/testlist
Processing directory threads
Looking in ./threads/testlist
Looking in ./threads/pt2pt/testlist
Unexpected output in multisend3: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in multisend3: MPIR_Init_thread(388).................:
Unexpected output in multisend3: MPID_Init(139)........................: channel initialization failed
Unexpected output in multisend3: MPIDI_CH3_Init(38)....................:
Unexpected output in multisend3: MPID_nem_init(196)....................:
Unexpected output in multisend3: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in multisend3: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in multisend3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in multisend3: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in multisend3: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in multisend3: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in multisend3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program multisend3 exited without No Errors
Unexpected output in multisend4: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in multisend4: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:906): assert (!closed) failed
Unexpected output in multisend4: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in multisend4: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in multisend4: [mpiexec at PC03] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting
Unexpected output in multisend4: [mpiexec at PC03] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion
Unexpected output in multisend4: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:189): launcher returned error waiting for completion
Unexpected output in multisend4: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program multisend4 exited without No Errors
Looking in ./threads/comm/testlist
Processing directory init
Looking in ./threads/init/testlist
Looking in ./threads/spawn/testlist
Unexpected output in th_taskmaster: Fatal error in MPI_Init_thread: Invalid port, error stack:
Unexpected output in th_taskmaster: MPIR_Init_thread(388)..........:
Unexpected output in th_taskmaster: MPID_Init(264).................: spawned process group was unable to connect back to the parent on port <tag#0$description#PC03$port#1363$ifname#10.67.254.216$>
Unexpected output in th_taskmaster: MPID_Comm_connect(191).........:
Unexpected output in th_taskmaster: MPIDI_Comm_connect(546)........: Named port tag#0$description#PC03$port#1363$ifname#10.67.254.216$ does not exist
Unexpected output in th_taskmaster: MPIDI_Comm_connect(401)........:
Unexpected output in th_taskmaster: MPIC_Sendrecv(192).............:
Unexpected output in th_taskmaster: MPIC_Wait(540).................:
Unexpected output in th_taskmaster: MPIDI_CH3I_Progress(402).......:
Unexpected output in th_taskmaster: MPID_nem_mpich2_test_recv(747).:
Unexpected output in th_taskmaster: MPID_nem_tcp_connpoll(1838)....:
Unexpected output in th_taskmaster: state_c_tmpvcsent_handler(1264): Failure during connection protocol
Unexpected output in th_taskmaster: recv_cmd_pkt(739)..............: read from socket failed - Connection reset by peer
Unexpected output in th_taskmaster: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in th_taskmaster: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:906): assert (!closed) failed
Unexpected output in th_taskmaster: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in th_taskmaster: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in th_taskmaster: [mpiexec at PC03] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting
Unexpected output in th_taskmaster: [mpiexec at PC03] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion
Unexpected output in th_taskmaster: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:189): launcher returned error waiting for completion
Unexpected output in th_taskmaster: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:397): process manager error waiting for completion
Program th_taskmaster exited without No Errors
205 tests failed out of 629
Details in /cygdrive/c/cygwin/mpich2-1.4/test/mpi/summary.xml
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/mpi'
(XMLFILE=../mpi/summary.xml && XMLCONTINUE=YES && \
export XMLFILE && export XMLCONTINUE && \
cd commands && make testing)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/test/commands'
make[1]: Nothing to be done for `testing'.
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/test/commands'
