[mpich-discuss] Using g95 to compile mpich2 problem
Jayesh Krishna
jayesh at mcs.anl.gov
Thu Aug 2 09:15:30 CDT 2012
Can you run any MPI programs (Can you run /examples/cpi.c?)?
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Thursday, August 2, 2012 7:43:27 AM
Subject: Re: Using g95 to compile mpich2 problem
Thank you,Jayesh.
Before, I had trying to use default process manager (hydra).
Using the command
User at 980622-05 /cygdrive/c/cygwin/mpich2-1.4
$./configure F77=g95 FC=g95 2>&1 | tee c.txt
$make 2>&1 | tee m.txt
$make install 2>&1 | tee mi.txt
$export MPICH2_HOME=/cygdrive/c/cygwin/mpich2-1.4
$export PATH=/cygdrive/c/cygwin/usr/local/bin:$PATH
$export LD_LIBRARY_PATH=/cygdrive/c/cygwin/usr/local/lib:$LD_LIBRARY_PATH
The MPICH2 installed to the default location /usr/local/
And I could run the mpich2-1.4/examples/cpi
But when I used command make testing in mpich2-1.4/test file, I got errors message (detail saved in testing.txt)
Looking in ./coll/testlist
Unexpected output in allred: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allred: MPIR_Init_thread(388).................:
Unexpected output in allred: MPID_Init(139)........................: channel initialization failed
Unexpected output in allred: MPIDI_CH3_Init(38)....................:
Unexpected output in allred: MPID_nem_init(196)....................:
Unexpected output in allred: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in allred: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in allred: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in allred5: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allred5: MPIR_Init_thread(388).................:
Unexpected output in allred5: MPID_Init(139)........................: channel initialization failed
Unexpected output in allred5: MPIDI_CH3_Init(38)....................:
Unexpected output in allred5: MPID_nem_init(196)....................:
Unexpected output in allred5: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allred5: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allred5: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allred5: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in allred5: [proxy:0:0 at 980622-05] HYDU_sock_read (./utils/sock/sock.c:272): read error (Software caused connection abort)
Unexpected output in allred5: [proxy:0:0 at 980622-05] pmi_cb (./pm/pmiserv/pmip_cb.c:228): unable to read PMI command
Unexpected output in allred5: [proxy:0:0 at 980622-05] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in allred5: [proxy:0:0 at 980622-05] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Can you give me some advices to solve the problem?
Thank you for your help
Best regards,
Chi-Che Hsieh
2012/8/1 Jayesh Krishna < jayesh at mcs.anl.gov >
Does the default process manager (hydra) work for you? Hydra is the recommended process manager for MPICH2 (on Unix environments).
Also see if you can compile and run <MPICH2-INSTALL-DIR>/examples/cpi.c .
(PS: SMPD is not regularly tested on Cygwin environment)
Jayesh
To: "Jayesh Krishna" < jayesh at mcs.anl.gov >, mpich-discuss at mcs.anl.gov
Cc: "謝奇哲" < 991546107 at stu.nkmu.edu.tw >
Sent: Wednesday, August 1, 2012 4:04:45 AM
Subject: Using g95 to compile mpich2 problem
I'm sorry if I'm asking too many times.
My case will need using mpi_init, so I install the MPICH2-1.4.
I'm using WindosXP, Cygwin, g95 and single-node systems.
What kind of options smpd or gforker is suitable for me?
If I suitable use smpd.
I tried using smpd before, and I could use smpd to run example cpi.
But I'm in mpich2-1.4/test file make testing, I get different problems on two computers.
1)
Looking in ./spawn/testlist
Unexpected output in taskmaster: Fatal error in MPI_Init: Invalid port, error stack:
Unexpected output in taskmaster: MPIR_Init_thread(388).............:
Unexpected output in taskmaster: MPID_Init(264)....................: spawned process group was unable to connect back to the parent on port <tag=0 description=user001 port=2634 ifname=10.1.10.108 >
Unexpected output in taskmaster: MPID_Comm_connect(191)............:
Unexpected output in taskmaster: MPIDI_Comm_connect(546)...........: Named port tag=0 description=user001 port=2634 ifname=10.1.10.108 does not exist
Unexpected output in taskmaster: MPIDI_Comm_connect(401)...........:
Unexpected output in taskmaster: MPIC_Sendrecv(192)................:
Unexpected output in taskmaster: MPIC_Wait(540)....................:
Unexpected output in taskmaster: MPIDI_CH3I_Progress(402)..........:
Unexpected output in taskmaster: MPID_nem_mpich2_blocking_recv(905):
Unexpected output in taskmaster: MPID_nem_tcp_connpoll(1838).......:
Unexpected output in taskmaster: state_c_tmpvcsent_handler(1264)...: Failure during connection protocol
Unexpected output in taskmaster: recv_cmd_pkt(739).................: read from socket failed - Connection reset by peer
Unexpected output in taskmaster: job aborted:
Unexpected output in taskmaster: rank: node: exit code[: error message]
Unexpected output in taskmaster: 0: user001: 1: process 0 exited without calling finalize
Unexpected output in taskmaster: mpiexec terminated job due to 600 second timeout.
Program taskmaster exited without No Errors
Unexpected output in disconnect_reconnect: Fatal error in MPI_Comm_connect: Invalid port, error stack:
Unexpected output in disconnect_reconnect: MPI_Comm_connect(127)..: MPI_Comm_connect(port="", MPI_INFO_NULL, root=0, MPI_COMM_WORLD, newcomm=0x22ac48) failed
Unexpected output in disconnect_reconnect: MPID_Comm_connect(191).:
Unexpected output in disconnect_reconnect: MPIDI_Comm_connect(412): Named port does not exist
Unexpected output in disconnect_reconnect: MPI_Comm_connect(127).............: MPI_Comm_connect(port="tag=0 description=user001 port=3378 ifname=10.1.10.108 ", MPI_INFO_NULL, root=0, MPI_COMM_WORLD, newcomm=0x22ac48) failed
Unexpected output in disconnect_reconnect: MPID_Comm_connect(191)............:
Unexpected output in disconnect_reconnect: MPIDI_Comm_connect(546)...........: Named port tag=0 description=user001 port=3378 ifname=10.1.10.108 does not exist
Unexpected output in disconnect_reconnect: MPIDI_Comm_connect(401)...........:
Unexpected output in disconnect_reconnect: MPIC_Sendrecv(192)................:
Unexpected output in disconnect_reconnect: MPIC_Wait(540)....................:
Unexpected output in disconnect_reconnect: MPIDI_CH3I_Progress(402)..........:
Unexpected output in disconnect_reconnect: MPID_nem_mpich2_blocking_recv(905):
Unexpected output in disconnect_reconnect: MPID_nem_tcp_connpoll(1838).......:
Unexpected output in disconnect_reconnect: state_c_tmpvcsent_handler(1264)...: Failure during connection protocol
Unexpected output in disconnect_reconnect: recv_cmd_pkt(739).................: read from socket failed - Connection reset by peer
Unexpected output in disconnect_reconnect: job aborted:
Unexpected output in disconnect_reconnect: rank: node: exit code[: error message]
Unexpected output in disconnect_reconnect: 0: user001: 1: process 0 exited without calling finalize
Unexpected output in disconnect_reconnect: 1: user001: 1: process 1 exited without calling finalize
Unexpected output in disconnect_reconnect: 2: user001: 1: process 2 exited without calling finalize
Unexpected output in disconnect_reconnect: mpiexec terminated job due to 180 second timeout.
Program disconnect_reconnect exited without No Errors
2)
Looking in ./attr/testlist
Unexpected output in attric: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in attric: MPIR_Init_thread(388).................:
Unexpected output in attric: MPID_Init(139)........................: channel initialization failed
Unexpected output in attric: MPIDI_CH3_Init(38)....................:
Unexpected output in attric: MPID_nem_init(196)....................:
Unexpected output in attric: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in attric: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in attric: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in attric: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in attric: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in attric: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in attric: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in attric: op_read error on left context: Error = -1
Unexpected output in attric: unable to read the cmd header on the left context, Error = -1
Unexpected output in attric: .
Unexpected output in attric: mpiexec terminated job due to 180 second timeout.
Program attric exited without No Errors
The two computer are the same computer hardware. And I use the same method installing.
Best regards,
Chi-Che Hsieh
