[mpich-discuss] undefined reference to `__muldc3'
Rayson Ho raysonlogin at gmail.com
Wed Aug 1 16:55:46 CDT 2012
Ted,
__muldc3 (and friends) is an internal function defined by the compiler runtime.
It is called from opprod.c because in that file MPIR_PROD() computes
complex datatypes... I think there is a library missing from the
mpif90 link command. C does not have native complex data type support,
but fortran does, so if you compile C code that computes compldex
numbers but link with a fortran compiler, then you can encounter
problems like this!
The easiest way to check is to compile this code and look at the linker map:
main()
 double a, b, c, d;
 return __muldc3(a, b, c, d);
% cc a.c -Wl,--print-map >&map
>From the map, I found that it is defined in:
 .text          0x00000000004004c0      0x3b2
/usr/lib/gcc/x86_64-redhat-linux/4.4.6/libgcc.a(_muldc3.o)
                0x00000000004004c0                __muldc3
If you are on Solaris then you will need to find the name of the
option in the ld man page.
Rayson
Open Grid Scheduler - The Official Open Source Grid Engine
http://gridscheduler.sourceforge.net/
On Wed, Aug 1, 2012 at 5:24 PM, Ted Sariyski <tsariysk at craft-tech.com> wrote:
> The same error without -j
> --Ted
> On 08/01/2012 05:22 PM, Anthony Chan wrote:
>> mpich2-1.4.1p1 does not support parallel make which is
>> available in 1.5 and later releases, so try to build mpich2
>> with just "make" without -j.
>> ----- Original Message -----
>>> Hi,
>>> I compiled mpich2-1.4.1p1 with the following script:
>>> export FC=sunf90
>>> export F77=sun77
>>> export CC=suncc
>>> export CXX=sunCC
>>> make distclean
>>> ./configure --prefix=/opt/mpich2-1.4.1p1_sun
>>> make -j 6
>>> Compilation and installation went clean, but when compile the example
>>> under examples/f90 i get:
>>> make
>>> ../../bin/mpif90 -o pi3f90 pi3f90.o -lrt -lpthread
>>> /home/tsariysk/mpich2-1.4.1p1/lib/libmpich.a(opprod.o): In function
>>> `MPIR_PROD':
>>> opprod.c:(.text+0x858): undefined reference to `__muldc3'
>>> opprod.c:(.text+0xa28): undefined reference to `__mulsc3'
>>> opprod.c:(.text+0x1083): undefined reference to `__mulxc3'
>>> make: *** [pi3f90] Error 2
>>> I also tried to use the system c and c++ compilers, but the error
>>> persists. What do I miss here?
>>> I'll highly appreciate any help.
>>> Thanks,
>>> --Ted
>>> _______________________________________________
>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
