[mpich-discuss] [mvapich-discuss] Announcing the Release of MVAPICH2 1.8 and OSU Micro-Benchmarks (OMB) 3.6
Dhabaleswar Panda
panda at cse.ohio-state.edu
Mon Apr 30 22:44:03 CDT 2012
These releases might be of interest to some of the MPICH users. Thus, I am
posting it here.
DK
---------- Forwarded message ----------
Date: Mon, 30 Apr 2012 21:44:37 -0400 (EDT)
From: Dhabaleswar Panda <panda at cse.ohio-state.edu>
To: mvapich-discuss at cse.ohio-state.edu
Cc: Dhabaleswar Panda <panda at cse.ohio-state.edu>
Subject: [mvapich-discuss] Announcing the Release of MVAPICH2 1.8 and OSU
The MVAPICH team is pleased to announce the release of MVAPICH2 1.8 and
OSU Micro-Benchmarks (OMB) 3.6.
Features, Enhancements, and Bug Fixes for MVAPICH2 1.8 are listed here.
* New Features and Enhancements (since 1.8RC1):
- Introduced a unified run time parameter MV2_USE_ONLY_UD to
enable UD only mode
- Enhanced designs for Alltoall and Allgather collective communication
from GPU device buffers
- Tuned collective communication from GPU device buffers
- Tuned Gather collective
- Introduced a run time parameter MV2_SHOW_CPU_BINDING to show current
CPU bindings
- Updated to hwloc v1.4.1
- Remove dependency on LEX and YACC
* Bug Fixes (since 1.8RC1):
- Fix hang with multiple GPU configuration
- Thanks to Jens Glaser from University of Minnesota
for the report
- Fix buffer alignment issues to improve intra-node performance
- Fix a DPM multispawn behavior
- Enhanced error reporting in DPM functionality
- Quote environment variables in job startup to protect from shell
- Fix hang when LIMIC is enabled
- Fix hang in environments with heterogeneous HCAs
- Fix issue when using multiple HCA ports in RDMA_CM mode
- Thanks to Steve Wise from Open Grid Computing for the report
- Fix hang during MPI_Finalize in Nemesis IB netmod
- Fix for a start-up issue in Nemesis with heterogeneous architectures
- Fix few memory leaks and warnings
Features, Enhancements, and Bug Fixes for OSU Micro-Benchmarks (OMB) 3.6
are listed here.
* New Features & Enhancements (since OMB 3.5.1)
- New collective benchmarks
* osu_allgather
* osu_allgatherv
* osu_allreduce
* osu_alltoall
* osu_alltoallv
* osu_barrier
* osu_bcast
* osu_gather
* osu_gatherv
* osu_reduce
* osu_reduce_scatter
* osu_scatter
* osu_scatterv
* Bug Fixes (since OMB 3.5.1)
- Fix GPU binding issue when running with HH mode
The complete set of features and enhancements for MVAPICH2 1.8 compared
to MVAPICH2 1.7 are as follows:
* Features & Enhancements:
- Support for MPI communication from NVIDIA GPU device memory
- High performance RDMA-based inter-node point-to-point
communication (GPU-GPU, GPU-Host and Host-GPU)
- High performance intra-node point-to-point communication for
multi-GPU adapters/node (GPU-GPU, GPU-Host and Host-GPU)
- Taking advantage of CUDA IPC (available in CUDA 4.1) in
intra-node communication
for multiple GPU adapters/node
- Optimized and tuned collectives for GPU device buffers
- MPI datatype support for point-to-point and collective
- Support for running UD only mode
- Support suspend/resume functionality with mpirun_rsh
- Enhanced support for CPU binding with socket and numanode level
granularity
- Support for showing current CPU bindings
- Exporting local rank, local size, global rank and global
size through environment variables (both mpirun_rsh and hydra)
- Update to hwloc v1.4.1
- Checkpoint-Restart support in OFA-IB-Nemesis interface
- Enabling run-through stabilization support to handle
process failures in OFA-IB-Nemesis interface
- Enhancing OFA-IB-Nemesis interface to handle IB errors gracefully
- Performance tuning on various architecture clusters
- Support for Mellanox IB FDR adapter
- Adjust shared-memory communication block size at runtime
- Enable XRC by default at configure time
- New shared memory design for enhanced intra-node small message
performance
- Tuned inter-node and intra-node performance on different cluster
architectures
- Support for fallback to R3 rendezvous protocol if RGET fails
- SLURM integration with mpiexec.mpirun_rsh to use SLURM
allocated hosts without specifying a hostfile
- Support added to automatically use PBS_NODEFILE in Torque and PBS
environments
- Enable signal-triggered (SIGUSR2) migration
- Reduced memory footprint of the library
- Enhanced one-sided communication design with reduced
memory requirement
- Enhancements and tuned collectives (Bcast and Alltoallv)
- Flexible HCA selection with Nemesis interface
- Thanks to Grigori Inozemtsev, Queens University
- Support iWARP interoperability between Intel NE020 and
Chelsio T4 Adapters
- RoCE enable environment variable name is changed from
MV2_USE_RDMAOE to MV2_USE_RoCE
MVAPICH2 1.8 continues to deliver excellent performance. Sample
performance numbers include:
OpenFabrics/Gen2 on Sandy Bridge 8-core (2.6 GHz) with PCIe-Gen3
and ConnectX-3 FDR (Two-sided Operations):
- 1.05 microsec one-way latency (4 bytes)
- 6344 MB/sec unidirectional bandwidth
- 11994 MB/sec bidirectional bandwidth
OpenFabrics/Gen2-RoCE (RDMA over Converged Ethernet) Support on
Sandy Bridge 8-core (2.6 GHz) with ConnectX-3 EN (40GigE)
(Two-sided operations):
- 1.2 microsec one-way latency (4 bytes)
- 4565 MB/sec unidirectional bandwidth
- 9117 MB/sec bidirectional bandwidth
Intra-node performance on Sandy Bridge 8-core (2.6 GHz)
(Two-sided operations, intra-socket)
- 0.19 microsec one-way latency (4 bytes)
- 9643 MB/sec unidirectional bandwidth
- 16941 MB/sec bidirectional bandwidth
Sample performance numbers for MPI communication from NVIDIA GPU memory
using MVAPICH2 1.8 and OMB 3.6 can be obtained from the following URL:
http://mvapich.cse.ohio-state.edu/performance/gpu.shtml
Performance numbers for several other platforms and system configurations
can be viewed by visiting `Performance' section of the project's web page.
For downloading MVAPICH2 1.8, OMB 3.6, associated user guide, quick start
guide, and accessing the SVN, please visit the following URL:
All questions, feedbacks, bug reports, hints for performance tuning,
patches and enhancements are welcome. Please post it to the
mvapich-discuss mailing list (mvapich-discuss at cse.ohio-state.edu).
We are also happy to inform that the number of organizations using
MVAPICH/MVAPICH2 (and registered at the MVAPICH site) has crossed 1,900
world-wide (in 67 countries). The MVAPICH team extends thanks to all these
organizations.
The MVAPICH Team
