[mpich-discuss] Why do predefined MPI_Ops function elementwise in MPI_Accumulate, but not in MPI-1 routines?
    Jim Dinan
    dinan at mcs.anl.gov
    Tue Apr 24 14:52:22 CDT 2012
Hi Jed,
Another thing to point out is that the Accumulate behavior on complex
data will do what you need for MPI_SUM, but it will give you the wrong
result for MPI_PROD (product) since complex multiplication is not just
multiplying real and imaginary parts separately.
  ~Jim.
On 4/24/12 9:37 AM, Jed Brown wrote:
> On Tue, Apr 24, 2012 at 08:30, Jim Dinan <dinan at mcs.anl.gov
> <mailto:dinan at mcs.anl.gov>> wrote:
>     I'm not sure if I'm following all the discussion, but here's my
>     understanding:
>     MPI_Reduce takes an array of elements and combines all elements from
>     every process to produce a single element of the original datatype as a
>     result.  It doesn't pick apart the datatype of each element to do a
>     reduction on the individual basic units contained inside it.  The
>     builtin operations only understand the builtin types; if you have a
>     derived datatype, you have to tell MPI how to combine elements of that
>     type and produce a new one of the same type.
>     MPI_Accumulate, on the other hand, works at the level of the basic units
>     which are described by the datatype and applies the operation at
>     that level.
>     So, the operation names are the same, but Accumulate and Reduce utilize
>     datatypes in different ways.  Reduce applies the op at the level of the
>     aggregate datatype and Accumulate applies the op at the level of the
>     basic units in the datatype.
>     It's an interesting suggestion to add the Accumulate interpretation to
>     the Reduce operations.  We can't break backward compatibility, so we
>     would probably have to define a new set of operations to do the
>     reduction at the level of the basic datatypes.
> It's not an API change to make something that was a run-time error
> become not a run-time error.
> Let's step over the implementation issues for a moment. Does anyone want
> to make the claim that there shall be no (non-deprecated) way for a user
> to create an environment where they can write the following?
> typedef std::complex<double> Complex;
> MPI_Op SUM; // MPI_SUM or a new op
> MPI_Datatype COMPLEX; // from MPI or created here
> Complex a,b;
> MPI_Allreduce(&a,&b,1,COMPLEX,SUM,MPI_COMM_WORLD);
> MPI_Accumulate(&a,1,COMPLEX,rank,0,1,COMPLEX,SUM,window);
> If the above is a reasonable thing for a user to request, then either
> (a) MPI_Accumulate must accept user-defined MPI_Ops, (b) MPI_SUM must
> operate on the base elements of a derived type for collectives (instead
> of just for MPI_Accumulate), or (c) the issue is delayed by adding a
> non-deprecated predefined std::complex<double> type.
> I think that both (a) and (b) should be done because then we could do
> __float128 or quaternions without having to change the standard. (I
> cannot currently use __float128 with one-sided, so any time I use
> one-sided because it's a better algorithmic fit, I will also have to
> implement the algorithm using MPI-1 so that __float128 works.)
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
