[mpich-discuss] Why do predefined MPI_Ops function elementwise in MPI_Accumulate, but not in MPI-1 routines?
Rajeev Thakur thakur at mcs.anl.gov
Mon Apr 23 20:36:43 CDT 2012
MPI_Accumulate allows you to do MPI_SUM on a derived datatype. MPI_Reduce does not. It requires you to create your own reduction operation for derived datatypes. MPI_Accumulate, on the other hand, does not allow user-defined reduction operations at all.
Rajeev
On Apr 23, 2012, at 8:29 PM, Jeff Hammond wrote:
> I was under the impression that the use for MPI_Accumulate was a
> proper subset of MPIReduce, etc.  What part of the standard leads you
> to believe that restrictions pertaining to MPI_Reduce, etc. are
> stricter than for MPI_Accumulate?
> Jeff
> On Mon, Apr 23, 2012 at 7:53 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> The standard contains the following statement about MPI_Accumulate, which
>> can only use predefined operations.
>> Each datatype argument must be a predefined datatype or a derived datatype,
>> where all basic components are of the same predefined datatype. Both
>> datatype arguments must be constructed from the same predefined datatype.
>> Under this restriction, MPI_SUM can be applied to derived datatypes, but it
>> cannot be used in the same context with MPI_Allreduce and similar. This
>> causes an ugly interface in which we
>> 1. MUST create a new MPI_Op to be used when calling MPI_Allreduce with this
>> data type.
>> 2. Must NOT create a new MPI_Op when used with MPI_Accumulate.
>> This causes awkward translation if we have an API that may be implemented in
>> terms of one-sided operations or may be implemented in terms of collective
>> reductions (e.g. if we do communication graph analysis and choose an
>> implementation based on sparsity or the network).
>> Is there any way to circumvent this annoyance?
>> What was the rationale for not having MPI_SUM work with MPI_Allreduce and
>> company when the same conditions as specified for MPI_Accumulate are met?
>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Jeff Hammond
> Argonne Leadership Computing Facility
> University of Chicago Computation Institute
> jhammond at alcf.anl.gov / (630) 252-5381
> http://www.linkedin.com/in/jeffhammond
> https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond (in-progress)
> https://wiki.alcf.anl.gov/old/index.php/User:Jhammond (deprecated)
> https://wiki-old.alcf.anl.gov/index.php/User:Jhammond(deprecated)
