[mpich-discuss] MPI error
Qiguo Jing
QJing at TrinityConsultants.com
Wed Apr 18 14:34:45 CDT 2012
Hi there,
Can someone help me on the following issue? The MPI program we are using
works fine with single PC of all OS (from XP to Win7, 32 and 64). However,
when we run it on a cluster, for some cases, we got the following error.
We are using MPICH2-1.2.1-win-ia32.
Thanks you.
Fatal error in MPI_Recv: Other MPI error, error stack:
MPI_Recv(187).............................: MPI_Recv(buf=0012F93C,
count=1, MPI_INTEGER, src=0, tag=4638, MPI_COMM_WORLD, status=00000001)
failed
MPIDI_CH3i_Progress_wait(215).............: an error occurred while
handling an event returned by MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(420):
MPIDU_Sock_wait(2606).....................: The specified network name is
no longer available. (errno 64)
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
failed
job aborted:
rank: node: exit code[: error message]
0: 10.0.0.52: 157: process 0 exited without calling finalize
1: 10.0.0.52: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
2: 10.0.0.52: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
3: 10.0.0.52: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
4: 10.0.0.52: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
5: 10.0.0.52: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
6: 10.0.0.52: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
7: 10.0.0.52: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
8: 10.0.0.61: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
9: 10.0.0.61: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
10: 10.0.0.61: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
11: 10.0.0.61: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
12: 10.0.0.61: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
13: 10.0.0.61: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
14: 10.0.0.61: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
15: 10.0.0.61: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
16: 10.0.0.59: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
17: 10.0.0.59: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
18: 10.0.0.59: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
19: 10.0.0.59: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
20: 10.0.0.59: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
21: 10.0.0.59: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
22: 10.0.0.59: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
23: 10.0.0.59: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
24: 10.0.0.57: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
25: 10.0.0.57: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
26: 10.0.0.57: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
27: 10.0.0.57: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
28: 10.0.0.57: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
29: 10.0.0.57: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
30: 10.0.0.57: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
31: 10.0.0.57: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
32: 10.0.0.60: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
33: 10.0.0.60: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
34: 10.0.0.60: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
35: 10.0.0.60: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
36: 10.0.0.60: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
37: 10.0.0.60: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
38: 10.0.0.60: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
39: 10.0.0.60: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
40: 10.0.0.64: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
41: 10.0.0.64: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
42: 10.0.0.64: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
43: 10.0.0.64: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
44: 10.0.0.64: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
45: 10.0.0.64: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
46: 10.0.0.64: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
47: 10.0.0.64: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
48: 10.0.0.63: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
49: 10.0.0.63: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
50: 10.0.0.63: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
51: 10.0.0.63: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
52: 10.0.0.63: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
53: 10.0.0.63: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
54: 10.0.0.63: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
55: 10.0.0.63: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
56: 10.0.0.62: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
57: 10.0.0.62: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
58: 10.0.0.62: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
failed
59: 10.0.0.62: 1: Fatal error in MPI_Recv: Other MPI error, error stack:
_________________________________________________________________________
The information transmitted is intended only for the person or entity to
which it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you
Received this in error, please contact the sender and delete the material
from any computer.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120418/a37b7c6c/attachment-0001.htm>
