[mpich-discuss] probems with MPE
    Anthony Chan
    chan at mcs.anl.gov
    Sat Apr 14 18:10:33 CDT 2012
Did you have a valid java on your path when you configure mpich2 or mpe?
If you don't, mpe will not build jumpshot script.  If your java is not
on standard path, you could set it with --with-java=<java_home_dir>.
e.g. if your java is on /usr/openjdk/bin/java, you should set
--with-java=/usr/openjdk as part of configure argument.
A.Chan
----- Original Message -----
> I installed mpich-2 by default,but i cound not find jumpshot
> executable file in the installation directory /bin/jumpshot.So after I
> create the Unkown.clog2 file,I cound not view it.Can anybody tell me
> why?Thanks.
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
