[mpich-discuss] RES:  RES:  RES:  Run on Amazon AWS
    Pavan Balaji
    balaji at mcs.anl.gov
    Sat Apr  7 08:19:57 CDT 2012
Please see the FAQ on dealing with firewalls.
http://wiki.mcs.anl.gov/mpich2/index.php/Frequently_Asked_Questions
  -- Pavan
On 04/05/2012 11:09 AM, Renato Tegon Forti wrote:
> Hi Panan,
> Now the problem is firewall:
> I open (TCP) 53312, 36191, 33835, but it ask to another, and another 34314,
> see:
> server 10.248.13.102 at port 34314 (check for firewalls!)
> What range I need open? Only TCP? Any other thing?
> Any idea? Thanks a lot!
> Full log
> ubuntu at ip-10-248-13-102:~$ export HYDRA_LAUNCHER_EXTRA_ARGS="-i
> /Hades/Doksafe/System/3.0/Debug/Parallel/Processing/Resources/dok_keypair.pe
> m"
> ubuntu at ip-10-248-13-102:~$ cd
> ubuntu at ip-10-248-13-102:/Hades/Doksafe/System/3.0/Debug/Parallel/Processing$
> ./start-t.sh
> host: 10.248.13.102
> host: 10.252.20.3
> mpiexec options:
>    Base path: /usr/bin/
>    Launcher: ssh
>    Debug level: 1
>    Enable X: -1
>    Global environment:
>      HYDRA_LAUNCHER_EXTRA_ARGS=-i
> m
>      SHELL=/bin/bash
>      TERM=xterm
>      SSH_CLIENT=189.55.11.94 59240 22
> PERL5LIB=/home/ubuntu/perl5/lib/perl5/x86_64-linux-gnu-thread-multi:/home/ub
>      PERL_MB_OPT=--install_base /home/ubuntu/perl5
>      SSH_TTY=/dev/pts/1
>      USER=ubuntu
> LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;0
> 1:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37
> ;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.l
> zma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31
> :*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=
> 01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31
> :*.sar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.r
> z=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=0
> 1;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;3
> 5:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*
> .mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.m
> p4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=0
> 1;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35
> :*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm
> =01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;
> 36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:
> *.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx
> =00;36:*.xspf=00;36:
> PATH=/home/ubuntu/perl5/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bi
> n:/sbin:/bin:/usr/games
>      MAIL=/var/mail/ubuntu
>      _=/usr/bin/mpiexec
>      PWD=/Hades/Doksafe/System/3.0/Debug/Parallel/Processing
>      LANG=en_US.UTF-8
>      HOME=/home/ubuntu
>      SHLVL=2
>      PERL_LOCAL_LIB_ROOT=/home/ubuntu/perl5
>      LOGNAME=ubuntu
>      SSH_CONNECTION=189.55.11.94 59240 10.248.13.102 22
>      LESSOPEN=| /usr/bin/lesspipe %s
>      LESSCLOSE=/usr/bin/lesspipe %s %s
>      PERL_MM_OPT=INSTALL_BASE=/home/ubuntu/perl5
>    Hydra internal environment:
>      GFORTRAN_UNBUFFERED_PRECONNECTED=y
>      Proxy information:
>        [1] proxy: 10.248.13.102 (1 cores)
>        Exec list:
> /Hades/Doksafe/System/3.0/Debug/Parallel/Processing/doksafe_process_engine
> (1 processes);
> (1 processes);
> (1 processes);
>        [2] proxy: 10.252.20.3 (1 cores)
>        Exec list:
> (1 processes);
> (1 processes);
> [mpiexec at ip-10-248-13-102] Timeout set to -1 (-1 means infinite)
> [mpiexec at ip-10-248-13-102] Got a control port string of 10.248.13.102:34314
> Proxy launch args: /usr/bin/hydra_pmi_proxy --control-port
> 10.248.13.102:34314 --debug --rmk user --launcher ssh --demux poll --pgid 0
> --retries 10 --proxy-id
> [mpiexec at ip-10-248-13-102] PMI FD: (null); PMI PORT: (null); PMI ID/RANK: -1
> Arguments being passed to proxy 0:
> --version 1.4.1 --iface-ip-env-name MPICH_INTERFACE_HOSTNAME --hostname
> 10.248.13.102 --global-core-map 0,1,1 --filler-process-map 0,1,1
> --global-process-count 5 --auto-cleanup 1 --pmi-rank -1 --pmi-kvsname
> kvs_4306_0 --pmi-process-mapping (vector,(0,2,1)) --ckpoint-num -1
> --global-inherited-env 22 'HYDRA_LAUNCHER_EXTRA_ARGS=-i
> m' 'SHELL=/bin/bash' 'TERM=xterm' 'SSH_CLIENT=189.55.11.94 59240 22'
> 'PERL5LIB=/home/ubuntu/perl5/lib/perl5/x86_64-linux-gnu-thread-multi:/home/u
> buntu/perl5/lib/perl5' 'PERL_MB_OPT=--install_base /home/ubuntu/perl5'
> 'SSH_TTY=/dev/pts/1' 'USER=ubuntu'
> 'LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;
> 01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=3
> 7;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.
> lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;3
> 1:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2
> =01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;3
> 1:*.sar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.
> rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=
> 01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;
> 35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:
> *.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.
> mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=
> 01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;3
> 5:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cg
> m=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00
> ;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36
> :*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.sp
> x=00;36:*.xspf=00;36:'
> 'PATH=/home/ubuntu/perl5/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/b
> in:/sbin:/bin:/usr/games' 'MAIL=/var/mail/ubuntu' '_=/usr/bin/mpiexec'
> 'PWD=/Hades/Doksafe/System/3.0/Debug/Parallel/Processing' 'LANG=en_US.UTF-8'
> 'HOME=/home/ubuntu' 'SHLVL=2' 'PERL_LOCAL_LIB_ROOT=/home/ubuntu/perl5'
> 'LOGNAME=ubuntu' 'SSH_CONNECTION=189.55.11.94 59240 10.248.13.102 22'
> 'LESSOPEN=| /usr/bin/lesspipe %s' 'LESSCLOSE=/usr/bin/lesspipe %s %s'
> 'PERL_MM_OPT=INSTALL_BASE=/home/ubuntu/perl5' --global-user-env 0
> --global-system-env 1 'GFORTRAN_UNBUFFERED_PRECONNECTED=y'
> --proxy-core-count 1 --exec --exec-appnum 0 --exec-proc-count 1
> --exec-local-env 0 --exec-wdir
> /Hades/Doksafe/System/3.0/Debug/Parallel/Processing --exec-args 2
> --app-cnf-file=/Hades/Doksafe/System/3.0/Debug/Parallel/Processing/Resources
> /nodes.cnf --exec --exec-appnum 0 --exec-proc-count 1 --exec-local-env 0
> --exec-wdir /Hades/Doksafe/System/3.0/Debug/Parallel/Processing --exec-args
> 2 /Hades/Doksafe/System/3.0/Debug/Parallel/Processing/doksafe_process_engine
> /nodes.cnf
> Arguments being passed to proxy 1:
> 10.252.20.3 --global-core-map 1,1,0 --filler-process-map 1,1,0
> /nodes.cnf
> [mpiexec at ip-10-248-13-102] Launch arguments: /usr/bin/hydra_pmi_proxy
> --control-port 10.248.13.102:34314 --debug --rmk user --launcher ssh --demux
> poll --pgid 0 --retries 10 --proxy-id 0
> [mpiexec at ip-10-248-13-102] Launch arguments: /usr/bin/ssh -x -i
> m 10.252.20.3 "/usr/bin/hydra_pmi_proxy" --control-port 10.248.13.102:34314
> --debug --rmk user --launcher ssh --demux poll --pgid 0 --retries 10
> --proxy-id 1
> Loading app conf file:
> /Hades/Doksafe/System/3.0/Debug/Parallel/Processing/Resources/nodes.cnf
> OpenMP active threads: 4
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 6): init
> pmi_version=1 pmi_subversion=1
> [proxy:0:0 at ip-10-248-13-102] PMI response: cmd=response_to_init
> pmi_version=1 pmi_subversion=1 rc=0
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 8): init
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 0): init
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 6): get_maxes
> [proxy:0:0 at ip-10-248-13-102] PMI response: cmd=maxes kvsname_max=256
> keylen_max=64 vallen_max=1024
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 6): get_appnum
> [proxy:0:0 at ip-10-248-13-102] PMI response: cmd=appnum appnum=0
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 6): get_my_kvsname
> [proxy:0:0 at ip-10-248-13-102] PMI response: cmd=my_kvsname kvsname=kvs_4306_0
> kvsname=kvs_4306_0 key=PMI_process_mapping
> [proxy:0:0 at ip-10-248-13-102] PMI response: cmd=get_result rc=0 msg=success
> value=(vector,(0,2,1))
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 6): barrier_in
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 8): get_maxes
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 0): get_maxes
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 8): get_appnum
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 8): get_my_kvsname
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 0): get_appnum
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 0): get_my_kvsname
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 8): barrier_in
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 0): put
> kvsname=kvs_4306_0 key=sharedFilename[0] value=/dev/shm/mpich_shar_tmpca3wCR
> [proxy:0:0 at ip-10-248-13-102] we don't understand this command put;
> forwarding upstream
> [mpiexec at ip-10-248-13-102] [pgid: 0] got PMI command: cmd=put
> [mpiexec at ip-10-248-13-102] PMI response to fd 6 pid 0: cmd=put_result rc=0
> msg=success
> [proxy:0:0 at ip-10-248-13-102] we don't understand the response put_result;
> forwarding downstream
> [proxy:0:0 at ip-10-248-13-102] got pmi command (from 0): barrier_in
> [proxy:0:0 at ip-10-248-13-102] forwarding command (cmd=barrier_in) upstream
> [mpiexec at ip-10-248-13-102] [pgid: 0] got PMI command: cmd=barrier_in
> [proxy:0:1 at ip-10-252-20-3] HYDU_sock_connect (./utils/sock/sock.c:203):
> unable to connect from "ip-10-252-20-3" to "10.248.13.102" (Connection timed
> out)
> [proxy:0:1 at ip-10-252-20-3] main (./pm/pmiserv/pmip.c:209): unable to connect
> to server 10.248.13.102 at port 34314 (check for firewalls!)
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
Pavan Balaji
http://www.mcs.anl.gov/~balaji
