[mpich-discuss] Problem with LD_PRELOAD
    Darius Buntinas
    buntinas at mcs.anl.gov
    Fri Sep 30 11:32:45 CDT 2011
Try this to make sure mpiexec passes the environment variable:
  mpiexec env | grep LD_PRELOAD
-d
On Sep 30, 2011, at 11:27 AM, Sandra Mendez wrote:
> Hi,
> Yes, export LD_PRELOAD=/home/smendez/libpas2p/bin/libpas2p-pvfs2.so
> and ldd report:
> smendez at node1:~$ ldd
> /home/smendez/NPB3.3.1/NPB3.3-MPI/bin/bt.C.4.mpi_io_full	linux-vdso.so.1 =>
> (0x00007fffc7bff000)
> 	/home/smendez/libpas2p/bin/libpas2p-pvfs2.so (0x00007fd57b74f000)
> 	libmpich.so.3 => /home/smendez/mpich2-install/lib/libmpich.so.3
> (0x00007fd57b359000)
> 	libopa.so.1 => /home/smendez/mpich2-install/lib/libopa.so.1
> (0x00007fd57b157000)
> 	libmpl.so.1 => /home/smendez/mpich2-install/lib/libmpl.so.1
> (0x00007fd57af52000)
> 	librt.so.1 => /lib/librt.so.1 (0x00007fd57ad4a000)
> 	libpthread.so.0 => /lib/libpthread.so.0 (0x00007fd57ab2e000)
> 	libgfortran.so.3 => /usr/lib/libgfortran.so.3 (0x00007fd57a842000)
> 	libm.so.6 => /lib/libm.so.6 (0x00007fd57a5be000)
> 	libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007fd57a3a7000)
> 	libc.so.6 => /lib/libc.so.6 (0x00007fd57a037000)
> 	libdl.so.2 => /lib/libdl.so.2 (0x00007fd579e33000)
> 	/lib64/ld-linux-x86-64.so.2 (0x00007fd57b958000)
> When the application starts does not report nothing.
> Thanks.
> Sandra.-
> ----------------mensaje original-----------------
> De: "Simon Hammond" simon.hammond at gmail.com
> Para: mpich-discuss at mcs.anl.gov
> Fecha: Fri, 30 Sep 2011 06:46:16 -0600
>> Are you exporting the environment variable (LD_PRELOAD) correctly? Do
>> you see any output from the tracer at all (when the application starts
>> up?)
>> Si Hammond
>> On 30 September 2011 05:59, Gustavo Correa gus at ldeo.columbia.edu wrote:
>>> Maybe using the --enable-g=... [i.e. debug] option of configure would
>>> help?
>>> You could go  to the MPICH2 top directory and do './configure --help' to
> check
>>> the details.
>>> I hope this helps,
>>> Gus Correa
>>> On Sep 30, 2011, at 5:47 AM, Sandra Mendez wrote:
>>>> Hi,
>>>> I need trace  mpi-io and for this I have a library that is load with
>>>> LD_PRELOAD. It traces on openmpi but does not trace on MPICH2.
>>>> MPICH2 was installed with the next command to configure:
>>>> ./configure --prefix=/home/smendez/mpich2-install
>>>> --enable-shared --with-mpe --enable-sharedlibs=gcc
>>>> F77=/usr/bin/gfortran FC=/usr/bin/gfortran
>>>> --enable-dynamiclibs=ch3:sock
>>>> But It does not trace mpi instructions.
>>>> Somebody can help me?
>>>> Thanks.
>>>> Sandra.-
>>>> _______________________________________________
>>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>>> To manage subscription options or unsubscribe:
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
