[mpich-discuss] Problem with LD_PRELOAD
    Gustavo Correa
    gus at ldeo.columbia.edu
    Fri Sep 30 06:59:52 CDT 2011
Maybe using the --enable-g=... [i.e. debug] option of configure would help?
You could go  to the MPICH2 top directory and do './configure --help' to check the details.
I hope this helps,
Gus Correa
On Sep 30, 2011, at 5:47 AM, Sandra Mendez wrote:
> Hi,
> I need trace  mpi-io and for this I have a library that is load with LD_PRELOAD. It traces on openmpi but does not trace on MPICH2.
> MPICH2 was installed with the next command to configure:
> ./configure --prefix=/home/smendez/mpich2-install --enable-shared --with-mpe --enable-sharedlibs=gcc F77=/usr/bin/gfortran FC=/usr/bin/gfortran --enable-dynamiclibs=ch3:sock
> But It does not trace mpi instructions.
> Somebody can help me?
> Thanks.
> Sandra.-
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
