[mpich-discuss] Error in MPI_COMM_WORLD in the second loop
    Anthony Chan
    chan at mcs.anl.gov
    Thu Sep 29 23:37:49 CDT 2011
This is error message from OpenMPI not mpich2.
----- Original Message -----
> Hi
> I have a problem, in the following program, at the first loop there is
> no
> error (and when I run the program with only 1 loop there is no error),
> but
> when I try to run for the second loop there is an error like this:
> [hx002:02844] *** An error occurred in MPI_Init
> [hx002:02844] *** on communicator MPI_COMM_WORLD
> [hx002:02844] *** MPI_ERR_OTHER: known error not in list
> [hx002:02844] *** MPI_ERRORS_ARE_FATAL (goodbye)
> [hx002:02846] *** An error occurred in MPI_Init
> [hx002:02846] *** on communicator MPI_COMM_WORLD
> [hx002:02846] *** MPI_ERR_OTHER: known error not in list
> [hx002:02846] *** MPI_ERRORS_ARE_FATAL (goodbye)
> [hx002:02847] *** An error occurred in MPI_Init
> [hx002:02847] *** on communicator MPI_COMM_WORLD
> [hx002:02847] *** MPI_ERR_OTHER: known error not in list
> [hx002:02847] *** MPI_ERRORS_ARE_FATAL (goodbye)
> [hx002:02851] *** An error occurred in MPI_Init
> [hx002:02851] *** on communicator MPI_COMM_WORLD
> [hx002:02851] *** MPI_ERR_OTHER: known error not in list
> [hx002:02851] *** MPI_ERRORS_ARE_FATAL (goodbye)
> [hx002:02845] *** An error occurred in MPI_Init
> [hx002:02845] *** on communicator MPI_COMM_WORLD
> [hx002:02845] *** MPI_ERR_OTHER: known error not in list
> [hx002:02845] *** MPI_ERRORS_ARE_FATAL (goodbye)
> [hx002:02848] *** An error occurred in MPI_Init
> [hx002:02848] *** on communicator MPI_COMM_WORLD
> [hx002:02848] *** MPI_ERR_OTHER: known error not in list
> [hx002:02848] *** MPI_ERRORS_ARE_FATAL (goodbye)
> [hx002:02849] *** An error occurred in MPI_Init
> [hx002:02849] *** on communicator MPI_COMM_WORLD
> [hx002:02849] *** MPI_ERR_OTHER: known error not in list
> [hx002:02849] *** MPI_ERRORS_ARE_FATAL (goodbye)
> [hx002:02850] *** An error occurred in MPI_Init
> [hx002:02850] *** on communicator MPI_COMM_WORLD
> [hx002:02850] *** MPI_ERR_OTHER: known error not in list
> [hx002:02850] *** MPI_ERRORS_ARE_FATAL (goodbye)
> The program is as follows:
> program ringtopo
> include 'mpif.h'
> integer numtasks, rank, next, prev, buf(2), tag1, tag2, ierr
> integer stats(MPI_STATUS_SIZE,2), reqs(2),reqs1(2)
> integer,parameter::buf_size=130
> real CRXi(10000),CP_sendx(buf_size)
> real CP_S6(6,buf_size),CP_R6(6,buf_size),xi(100000)
> real yi(100000),zi(100000),ui(100000),vi(100000),wi(100000)
> real CP_sendy(buf_size),CP_sendz(buf_size),CP_sendu(buf_size)
> real CP_sendv(buf_size),CP_sendw(buf_size)
> real CRYi(10000), CRZi(10000), CRUi(10000), CRVi(10000)
> real CRwi(10000)
> integer CP_send,CP_recv,ionsR,Max_p,n_p,LABEL_p,ions,loop
> tag1 = 1
> tag2 = 2
> do loop=1,2
> ions=5000
> do i=1,10000
> CRxi(i)=i*1.0
> CRyi(i)=i*2.0
> CRzi(i)=i*3.0
> CRui(i)=i*4.0
> CRvi(i)=i*5.0
> CRwi(i)=i*6.0
> end do
> call MPI_INIT(ierr)
> call MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierr)
> call MPI_COMM_SIZE(MPI_COMM_WORLD, numtasks, ierr)
> prev = rank - 1
> next = rank + 1
> if (rank .eq. 0) then
> prev = numtasks - 1
> endif
> if (rank .eq. numtasks - 1) then
> next = 0
> endif
> ionsR=1120
> C do some work
> Max_p=ionsR/buf_size+1
> LABEL_p=0
> CP_recv=20
> print*,CP_recv,Max_p,35335
> do 200 n_p=1,Max_p
> CP_send=0
> do i=1,buf_size
> n=LABEL_p+i
> C CP_S6(1,i)=CRXi(n)
> CP_sendx(i)=CRXi(n)
> CP_sendy(i)=CRyi(n)
> CP_sendz(i)=CRzi(n)
> CP_sendu(i)=CRui(n)
> CP_sendv(i)=CRvi(n)
> CP_sendw(i)=CRwi(n)
> end do
> CP_send=buf_size
> if(n.gt.ionsR)then
> CP_send=ionsR - LABEL_p
> if (CP_send.lt.0) CP_send=-CP_send
> end if
> LABEL_p=n
> do i=1,buf_size
> CP_S6(1,i)=CP_sendx(i)
> CP_S6(2,i)=CP_sendy(i)
> CP_S6(3,i)=CP_sendz(i)
> CP_S6(4,i)=CP_sendu(i)
> CP_S6(5,i)=CP_sendv(i)
> CP_S6(6,i)=CP_sendw(i)
> end do
> C print*,mreal,mint,lgrp,CP_send,reqs,1111114
> C print*,rank,MPI_INTEGER,CP_recv,CP_send,11111113
> C print*,rank,MPI_INTEGER,CP_R6(6,10),CP_s6(6,10),11111113
> print*,loop
> call MPI_IRECV(CP_recv, 1, MPI_INTEGER, prev, tag1,
> & MPI_COMM_WORLD, reqs(1), ierr)
> call MPI_ISEND(CP_send, 1, MPI_INTEGER, next, tag1,
> & MPI_COMM_WORLD, reqs(2), ierr)
> call MPI_WAITALL(2, reqs, stats, ierr);
> call MPI_IRECV(CP_R6, 6*CP_recv, MPI_REAL, prev, tag2,
> & MPI_COMM_WORLD, reqs1(1), ierr)
> call MPI_ISEND(CP_S6, 6*CP_send, MPI_REAL, next, tag2,
> & MPI_COMM_WORLD, reqs1(2), ierr)
> C call MPI_WAITALL(2, reqs1, stats, ierr);
> print*,rank,LABEL_p,CP_R6(6,10),CP_s6(6,10),11111114
> if (CP_recv.gt.0) then
> do n=1,CP_recv
> ions=ions+1
> xi(ions)=CP_R6(1,n)
> yi(ions)=CP_R6(2,n)
> zi(ions)=CP_R6(3,n)
> ui(ions)=CP_R6(4,n)
> vi(ions)=CP_R6(5,n)
> wi(ions)=CP_R6(6,n)
> end do
> else
> print*,n_p,777777771,888888881
> End if
> C110 continue
> C.......................
> 200 continue
> end do
> call MPI_FINALIZE(ierr)
> end
> Kind Regards
> Sincerely
> Amin
