[mpich-discuss] how to use ifhn in machinefile in mpich2-1.3.2?
    Limin Gu
    lgu at penguincomputing.com
    Mon Sep 26 15:43:23 CDT 2011
Hi All,
mpich2-1.3.2 is configured and built with default options.
I have a machine file like this:
n0 ifhn=172.20.20.100
n1 ifhn=172.20.20.101
but mpiexec would not take ifhn as a valid token. What did I do wrong? Do I
need to turn on some specific configure option and rebuild?
Thank you for your help!
Limin
[root at flatline examples]# mpiexec -f machinefile -n 2 ./cpi
[mpiexec at flatline] HYDU_process_mfile_token (./utils/args/args.c:292): token
ifhn not supported at this time
[mpiexec at flatline] HYDU_parse_hostfile (./utils/args/args.c:340): unable to
process token
[mpiexec at flatline] mfile_fn (./ui/mpich/utils.c:181): error parsing hostfile
[mpiexec at flatline] match_arg (./utils/args/args.c:115): match handler
returned error
[mpiexec at flatline] HYDU_parse_array (./utils/args/args.c:140): argument
matching returned error
[mpiexec at flatline] HYD_uii_mpx_get_parameters (./ui/mpich/utils.c:1113):
error parsing input array
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110926/8376b98c/attachment.htm>
