[mpich-discuss] mpich-1.4.1p1
    Carolina Carneiro
    carol07 at astro.ufrj.br
    Wed Sep 21 04:40:04 CDT 2011
Here it is.
Carolina Moura.
2011/9/21 Anthony Chan <chan at mcs.anl.gov>
> Send us the top-level config.log file which is generated automatically
> by configure.
> A.Chan
> > Hello,
> > I'm trying to install mpich2-1.4.1p1 in my computer and it's not
> > working.
> > The following message appear:
> > "configure: error: **** Incompatible Fortran and C Object File Types!
> > F77 Object File Type produced by "gfortran -O2" is : : ELF 64-bit LSB
> > relocatable, x86-64, version 1 (SYSV), not stripped.
> > C Object File Type produced by "gcc " is : : ERROR: cannot open `' (No
> > such file or directory)."
> > I have gfortran and gcc installed in my computer.
> > I tried to use ./configure --disable-f77, because I don't require
> > support
> > for Fortran 77, just for Fortran 90, but it didn't work either:
> > "Fortran 90 support requires compatible Fortran 77 support.
> > To force the use of the Fortran 90 compiler for Fortran 77,
> > do not use configure option --disable-f77, and set the environment
> > variable F77 to the name of the Fortran 90 compiler, or $FC.
> > If you do not want any Fortran support, use configure options
> > --disable-f77 and --disable-fc."
> > Can you help me? I don't know what to do, and I need this very
> > quickly.
> > Thank you for your attencion,
> > Carolina Moura.
> > _______________________________________________
> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110921/03a0d879/attachment-0001.htm>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110921/03a0d879/attachment-0001.bin>
