[mpich-discuss] mpich-1.4.1p1
    Carolina Carneiro
    carol07 at astro.ufrj.br
    Tue Sep 20 21:04:36 CDT 2011
Hello,
I'm trying to install mpich2-1.4.1p1 in my computer and it's not working.
The following message appear:
"configure: error: ****  Incompatible Fortran and C Object File Types!  ****
F77 Object File Type produced by "gfortran   -O2" is : : ELF 64-bit LSB
relocatable, x86-64, version 1 (SYSV), not stripped.
 C  Object File Type produced by "gcc   " is : : ERROR: cannot open `' (No
such file or directory)."
I have gfortran and gcc installed in my computer.
I tried to use ./configure --disable-f77, because I don't require support
for Fortran 77, just for Fortran 90, but it didn't work either:
"Fortran 90 support requires compatible Fortran 77 support.
To force the use of the Fortran 90 compiler for Fortran 77,
do not use configure option --disable-f77, and set the environment
variable F77 to the name of the Fortran 90 compiler, or $FC.
If you do not want any Fortran support, use configure options
--disable-f77 and --disable-fc."
Can you help me? I don't know what to do, and I need this very quickly.
Thank you for your attencion,
Carolina Moura.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110920/ff50ba19/attachment.htm>
