[mpich-discuss] mpich compilation issue
    Gus Correa
    gus at ldeo.columbia.edu
    Tue Sep 13 12:09:49 CDT 2011
Hi Akshar
It sounds as a bug in the program,
which causes a deadlock, not a problem with MPICH2.
Your error message:
 > MPID_Send(57): DEADLOCK: attempting to send a message to the local
 > process without a prior matching receive
If you post the code, the list may help you.
Gus Correa
akshar bhosale wrote:
> sorry for not answering why not mpich2.
> We have tried to compile our code using mpich2, it compiles but while
> running the executable generated, it runs and in between it comes out
> giving some mpi send error. The code compiled with mpif90
> (mpich-1.2.7p1) using gfortran on other machine runs fine.
> Error is as follows:
>  3  aft MPI_SEND           2           7           2           0
>            3  call MPI_SEND           2           8           2           0
>            3  aft MPI_SEND           2           8           2           0
>            3  call MPI_SEND           2           9           2           0
>            3  aft MPI_SEND           2           9           2           0
>            3  call MPI_SEND           2          10           2           0
>            3  aft MPI_SEND           2          10           2           0
>            3  call MPI_SEND           3           1           3           0
> [cli_3]: aborting job:
> Fatal error in MPI_Send: Other MPI error, error stack:
> MPI_Send(175): MPI_Send(buf=0x2aaab2af2018, count=1, dtype=USER<vector>,
> dest=3, tag=30003, MPI_COMM_WORLD) failed
> -akshar
> On Tue, Sep 13, 2011 at 10:02 PM, akshar bhosale
> <akshar.bhosale at gmail.com <mailto:akshar.bhosale at gmail.com>> wrote:
>     thanks for reply.
>     Goal is to generate mpif90 using mpich-1.2.7p1 using gfortran which
>     will generate executable from our fortran code.
>     source files to be compiled are .f and .f90 files.
>     f2c flag is given because mp[if90 was not getting generated. no
>     other reason. we want mpif90.
>     Now we have tried giving only FC=gfortran and no other flag of
>     option except prefix, but still it is not generating mpif90 nor mpif77.
>     mpif90 generated  by using [export F90=fortran;F90FLAGS="-ff2c".]
>     options if tries to compile our code, it throws error
>     <path to mpif90>/mpif90 -f90=gfortran -Wl -o ../output_code.x set.o
>     inp.o otp.o bvsol.o user_kg.o mpi_util.o mpi_communication.o
>     mpi_memalloc.o driver.o rxn.o advdi_1d_finitediff_mf.o  aq_lib.o \
>             -L/ioapi/Linux2_x86_64gfort -lioapi
>     -L/np_cs/netcdf/INSTALL/lib -lnetcdf -L/usr/lib64/
>      -lgomp /np_cs/lapack/lapack-3.2.1/lapack_LINUX.a
>     /np_cs/lapack/lapack-3.2.1/blas_LINUX.a
>     /build/lib/libmpich.a(farg.o): In function `mpir_iargc__':
>     farg.f:(.text+0x6): undefined reference to `f__xargc'
>     /build/lib/libmpich.a(farg.o): In function `mpir_getarg__':
>     farg.f:(.text+0x38): undefined reference to `getarg_'
>     collect2: ld returned 1 exit status
>     make: *** [../output_code.x] Error 1
>     -akshar
>     On Tue, Sep 13, 2011 at 8:52 PM, Gus Correa <gus at ldeo.columbia.edu
>     <mailto:gus at ldeo.columbia.edu>> wrote:
>         Hi Pavan and Akshar
>         I see, it's MPICH-1.
>         May I ask why?
>         Would a workaround perhaps be to build only mpif77 (no mpif90),
>         replace 'use mpi' by '#include "mpif.h"' in the application code,
>         and recompile it with mpif77?
>         I wonder if -ff2c works at all with Fortran90.
>         (See man page detail below.)
>         Anyway, I remember that there were complaints of runtime
>         errors (P4 errors) with mpich-1,
>         reported on this and other mailing lists,
>         when running on current Linux kernels.
>         Even with simple codes like the cpi example.
>         Using MPICH-1 may be an uphill battle.
>         I hope this helps,
>         Gus Correa
>          >From man gfortran (4.1.2):
>               -ff2c
>                   Generate code designed to be compatible with code
>         generated by g77 and f2c.
>                   The calling conventions used by g77 (originally
>         implemented in f2c) require functions that return type default
>         "REAL" to actually return the C type
>                   "double", and functions that return type "COMPLEX" to
>         return the values via an extra argument in the calling sequence
>         that points to where to store the
>                   return value.  Under the default GNU calling
>         conventions, such functions simply return their results as they
>         would in GNU C -- default "REAL" functions
>                   return the C type "float", and "COMPLEX" functions
>         return the GNU C type "complex".  Additionally, this option
>         implies the -fsecond-underscore option,
>                   unless -fno-second-underscore is explicitly requested.
>                   This does not affect the generation of code that
>         interfaces with the libgfortran library.
>                   Caution: It is not a good idea to mix Fortran code
>         compiled with "-ff2c" with code compiled with the default
>         "-fno-f2c" calling conventions as, calling
>                   "COMPLEX" or default "REAL" functions between program
>         parts which were compiled with different calling conventions
>         will break at execution time.
>                   Caution: This will break code which passes intrinsic
>         functions of type default "REAL" or "COMPLEX" as actual
>         arguments, as the library implementations
>                   use the -fno-f2c calling conventions.
>         Pavan Balaji wrote:
>             Gus: He doesn't want to use MPICH2. He's using MPICH-1.
>                    -- Pavan
>             On 09/13/2011 09:51 AM, Gus Correa wrote:
>                 Hi Akshar
>                 Maybe the F90FLAGS="-ff2c" flag is causing the problem?
>                 What if you remove it and use gfortran for F77 and FC?
>                 Also, my 'configure -help' (a bit old, MPICH2 1.3.2p1)
>                 mentions FC, not F90, as the environment variable to be set.
>                 For what it is worth, MPICH2 builds fine for us, with
>                 gcc, g++ and gfortran (for F77 and FC).
>                 My two cents,
>                 Gus Correa
>                     Hi,
>                        If i specify F77 anf F90 as gfortran, it doesn't
>                     create mpif90 and
>                     mpif77 at all.
>                     Please see attached config log
>                     If i specify F90=gfortran and F90FLAGS="-ff2c", the
>                     it creates mpif90
>                     and mpif77 but is generating below issue.
>                     Kindly help.
>                     -akshar
>                     On Tue, Sep 13, 2011 at 9:46 AM, Rajeev
>                     Thakur<thakur at mcs.anl.gov <mailto:thakur at mcs.anl.gov>
>                     <mailto:thakur at mcs.anl.gov>>>  wrote:
>                         In the configure step, if you specify both F77
>                     and F90 as gfortran,
>                         it should work.
>                         Rajeev
>                         On Sep 12, 2011, at 9:49 PM, akshar bhosale wrote:
>                          >  Hi,
>                          >  thanks.
>                          >  but, in case of mpicc, it can be ignored,
>                     but in case of mpif90,
>                         it is still an issue.
>                          >  e.g. hello_mpi.f90 program
>                          >  program main
>                          >     use mpi
>                          >  ! implicit none
>                          >    integer error
>                          >    integer id
>                          >    integer p
>                          >    real ( kind = 8 ) wtime
>                          >  !  Initialize MPI.
>                          >    call MPI_Init ( error )
>                          >  !  Get the number of processes.
>                          >    call MPI_Comm_size ( MPI_COMM_WORLD, p,
>                     error )
>                          >  !  Get the individual process ID.
>                          >    call MPI_Comm_rank ( MPI_COMM_WORLD, id,
>                     error )
>                          >  !  Print a message.
>                          >    if ( id == 0 ) then
>                          >      wtime = MPI_Wtime ( )
>                          >      write ( *, '(a)' ) ' '
>                          >      write ( *, '(a)' ) 'HELLO_MPI - Master
>                     process:'
>                          >      write ( *, '(a)' ) '  FORTRAN90/MPI version'
>                          >      write ( *, '(a)' ) '  An MPI test program.'
>                          >      write ( *, '(a,i8)' ) '  The number of
>                     processes is ', p
>                          >    end if
>                          >    write ( *, '(a,i8,a)' ) '  Process ', id,
>                     ' says "Hello, world!"'
>                          >    if ( id == 0 ) then
>                     process:'
>                          >      write ( *, '(a)' ) '  Normal end of
>                     execution: "Goodbye,
>                         world!".'
>                          >      wtime = MPI_Wtime ( ) - wtime
>                          >      write ( *, '(a,g14.6,a)' ) '  Elapsed
>                     wall clock time = ',
>                         wtime, ' seconds.'
>                          >     end if
>                          >   !  Shut down MPI.
>                          >    call MPI_Finalize ( error )
>                          >    stop
>                          >    end
>                          >  $ ../../../build/bin/mpif90 hello_mpi.f90
>                      /scratch1/np_cs/trial1/build/__lib/libmpich.a(farg.o):
>                     In function
>                         `mpir_iargc__':
>                     `f__xargc'
>                     In function
>                         `mpir_getarg__':
>                     `getarg_'
>                          >  On Mon, Sep 12, 2011 at 9:42 AM, Rajeev Thakur
>                     <mailto:thakur at mcs.anl.gov><mailto:tha__kur at mcs.anl.gov
>                          >  Ignore that. Compile a real program as mpicc
>                     foo.c.
>                          >  On Sep 11, 2011, at 8:38 PM, akshar bhosale
>                     wrote:
>                          >  >  Hi,
>                          >  >  thank you for reply.
>                          >  >  I tried to install it make it using
>                     following options now and i
>                         get following error with undefined reference to
>                     main. options given
>                         while configuring the same are :
>                          >  >  but error of undefined reference to main
>                     is observed in every
>                         executable like :
>                          >  >  ./mpicc -v
>                          >  >  mpicc for 1.2.7 (release) of : 2005/06/22
>                     16:33:49
>                          >  >  Using built-in specs.
>                          >  >  Target: x86_64-redhat-linux
>                          >  >  Configured with: ../configure --prefix=/usr
>                         --mandir=/usr/share/man
>                     --infodir=/usr/share/info --enable-shared
>                         --enable-threads=posix --enable-checking=release
>                     --with-system-zlib
>                         --enable-__cxa_atexit --disable-libunwind-exceptions
>                         --enable-libgcj-multifile
>                     --enable-languages=c,c++,objc,__obj-c++,java,fortran,ada
>                         --enable-java-awt=gtk --disable-dssi
>                     --disable-plugin
>                     --with-java-home=/usr/lib/jvm/__java-1.4.2-gcj-1.4.2.0/jre
>                         --with-cpu=generic --host=x86_64-redhat-linux
>                          >  >  Thread model: posix
>                          >  >  gcc version 4.1.2 20080704 (Red Hat 4.1.2-50)
>                     /usr/libexec/gcc/x86_64-__redhat-linux/4.1.2/collect2
>                         --eh-frame-hdr -m elf_x86_64 --hash-style=gnu
>                     -dynamic-linker
>                         /lib64/ld-linux-x86-64.so.2
>                     /usr/lib/gcc/x86_64-redhat-__linux/4.1.2/../../../../lib64/__crt1.o
>                     /usr/lib/gcc/x86_64-redhat-__linux/4.1.2/../../../../lib64/__crti.o
>                         /usr/lib/gcc/x86_64-redhat-__linux/4.1.2/crtbegin.o
>                         -L/scratch1/np_cs/trial2/__build/lib
>                         -L/opt/intel/mkl/10.2.2.025/__lib/em64t
>                     <http://10.2.2.025/lib/em64t><http://10.2.2.025/__lib/em64t
>                     <http://10.2.2.025/lib/em64t>>
>                         -L/usr/lib/gcc/x86_64-redhat-__linux/4.1.2
>                     -L/usr/lib/gcc/x86_64-redhat-__linux/4.1.2/../../../../lib64
>                         -L/lib/../lib64 -L/usr/lib/../lib64 -lmpich
>                     -lpthread -lrt -lgcc
>                         --as-needed -lgcc_s --no-as-needed -lc -lgcc
>                     --as-needed -lgcc_s
>                         --no-as-needed
>                     /usr/lib/gcc/x86_64-redhat-__linux/4.1.2/crtend.o
>                     /usr/lib/gcc/x86_64-redhat-__linux/4.1.2/../../../../lib64/__crtn.o
>                     /usr/lib/gcc/x86_64-redhat-__linux/4.1.2/../../../../lib64/__crt1.o:
>                     In
>                         function `_start':
>                          >  >  (.text+0x20): undefined reference to `main'
>                          >  >  ./mpif90 -v
>                          >  >  mpif90 for 1.2.7 (release) of :
>                     2005/06/22 16:33:49
>                          >  >  Driving: gfortran
>                     -L/scratch1/np_cs/trial2/__build/lib -v
>                         -lmpichf90 -lmpich -lpthread -lrt
>                     -lgfortranbegin -lgfortran -lm
>                         -shared-libgcc
>                     --with-system-zlib
>                     --disable-plugin
>                          >  >  Thread model: posix
>                     -dynamic-linker
>                         -L/lib/../lib64 -L/usr/lib/../lib64 -lmpichf90
>                     -lmpich -lpthread
>                         -lrt -lgfortranbegin -lgfortran -lm -lgcc_s
>                     -lgcc -lc -lgcc_s -lgcc
>                     /usr/lib/gcc/x86_64-redhat-__linux/4.1.2/libgfortranbegin.__a(fmain.o):
>                         In function `main':
>                          >  >  (.text+0xa): undefined reference to `MAIN__'
>                          >  >  Am i missing somethin?
>                          >  >  thank you
>                          >  >  -akshar
>                          >  >  On Mon, Sep 12, 2011 at 1:24 AM, William
>                     Gropp
>                         <wgropp at illinois.edu
>                     <mailto:wgropp at illinois.edu><mailto:wg__ropp at illinois.edu
>                     <mailto:wgropp at illinois.edu>>>  wrote:
>                          >  >  You can use gfortran for F77 and F90.  If
>                     your requirement is
>                         to use gfortran for F77 and a different fortran
>                     for F90, then they
>                         will need to use consistent linker names,
>                     calling conventions, data
>                         sizes, and libraries.  The config.log file will
>                     have details on why
>                         configure decided that the Fortran 77 and
>                     Fortran 90 compilers were
>                         not compatible.
>                          >  >  Bill
>                          >  >  On Sep 9, 2011, at 4:28 PM, akshar
>                     bhosale wrote:
>                          >  >  hi,
>                          >  >  we have requirement of mpich-1.2.7 with
>                     gfortran. We have fiven
>                         flags as : CC=gcc;F90=fortran;F77=__gfortran;
>                     and tried to configure,
>                         it throws error as configure: error: Fortran 90
>                     and Fortran 77
>                         compilers are not compatible..
>                          >  >  We have to do it using gfortran only. os
>                     is rhel5.1 64 bit
>                          >  >  what extran flags settings we have to do?
>                          >  >  -akshar
>                      _________________________________________________
>                          >  >  mpich-discuss mailing list
>                     mpich-discuss at mcs.anl.gov
>                     <mailto:mpich-discuss at mcs.anl.gov>
>                         <mailto:mpich-discuss at mcs.anl.__gov
>                     <mailto:mpich-discuss at mcs.anl.gov>>
>                          >  >  To manage subscription options or
>                     unsubscribe:
>                      https://lists.mcs.anl.gov/__mailman/listinfo/mpich-discuss
>                     <https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
>                          >  >  William Gropp
>                          >  >  Director, Parallel Computing Institute
>                          >  >  Deputy Director for Research
>                          >  >  Institute for Advanced Computing
>                     Applications and Technologies
>                          >  >  Paul and Cynthia Saylor Professor of
>                     Computer Science
>                          >  >  University of Illinois Urbana-Champaign
>                     unsubscribe:
>                          >  To manage subscription options or unsubscribe:
>                     ------------------------------__------------------------------__------------
>                 mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
