[mpich-discuss] [mpich2-maint] help for running MPICH2 under	Window 7
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Sep 12 16:03:07 CDT 2011
 Good to know MPICH2 is working for you now. Let us know if you need any help.
(PS: Looks like you have Intel and Microsoft MPI suites installed in your system.)
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Monday, September 12, 2011 3:14:22 PM
Subject: RE: [mpich2-maint] help for running MPICH2 under Window 7
Hi, Jayesh,
You are right. Under Window 7, I searched ‘mpiexec.exe’ and found several ‘mpiexec.exe’ on my computer. so I put ‘C:\Program Files\MPICH2\bin’ into the head of the PATH environmental variable. Please see the ‘PATH’ variable for details. Then I did tests again and the problem did not occur.
I did compiled cxxpi.exe cpi.exe fpi.exe under MS Studio 2008 and the latest MPICH2 lib was used, I guess. Please see the following snapshots.
Thanks indeed for your assistances.
Dingjun
Ls
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Monday, September 12, 2011 1:38 PM
To: Dingjun Chen
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich2-maint] help for running MPICH2 under Window 7
Try the following commands and let us know the output of each command
# Run "which mpiexec" (To make sure that you are using the right mpiexec)
# Run "mpiexec -n 2 c:\Progra~1\MPICH2\examples\cpi.exe"
Have you compiled "exe\cpi.exe" and "exe\cxxpi.exe" with the latest MPICH2 libraries ?
Jayesh
Sent: Monday, September 12, 2011 11:46:37 AM
This means the ‘mpiexec.exe’ must be with ‘cpi.exe, cpxx.exe, and fpi.exe’ under the same directory. Otherwise the problem is occurred.
If I copy ‘mpiexec.exe’ into the directory where cpi.exe is and run mpiexec –n 12 cpi.exe. then the test is successful.
Dingjun
Sent: Monday, September 12, 2011 10:06 AM
To: Dingjun Chen
Please let us know the steps that you used to install MPICH2.
Jayesh
Sent: Monday, September 12, 2011 9:15:32 AM
HI, Jayesh,
Thanks indeed for your reply.
I did it in terms of your suggestions. But the problem is still there.
I run tests as follows:
I entered C:\Program Files\MPICH2\examples
and ran mpiexec -n 12 cpi.exe
the error prompt is as before:
"CreateProcess failed, error 2
Unable to start the local smpd manager"
However, if I entered c:\Program Files\MPICH2\bin
and ran mpiexec -n 12 ../examples/cpi.exe
test is successful and cpi.exe works well under 12 CPUs.
This means I cannot do tests under the directory C:\Program Files\MPICH2\examples where cpi.exe is.
I look forward to your suggestions again and have a good day.
Dingjun
Sent: Friday, September 09, 2011 2:47 PM
To: Dingjun Chen
Uninstall your existing version of MPICH2 and follow the instructions in Section 9.4 (NOT 9.1) of the installer's guide (http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.4.1-installguide.pdf).
Let us know if you still have issues.
Jayesh
To: mpich2-maint at mcs.anl.gov
Sent: Friday, September 9, 2011 3:39:27 PM
Subject: [mpich2-maint] help for running MPICH2 under Window 7
Hi, Dear Sir or Madam,
I just installed MPICH2 on my computer of Window 7 and ran the examples cpi.exe.
When I enter the following command:
mpiexec –n 4 cpi.exe
the prompt is as follow:
“CreateProcess failed, error 2
Unable to start the local smpd manager.”
Could you tell me how to solve above problem? I look forward to hearing from you.
Thank you in advance.
Dingjun Chen
R&D Technology Center
Computer Modelling Group Ltd.
3512 33 rd street NW,
Calgary, AB, Canada
mpich2-maint mailing list
mpich2-maint at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/mpich2-maint
