[mpich-discuss] [mpich2-maint] help for running MPICH2 under	Window 7
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Sep 12 11:06:03 CDT 2011
 Please let us know the steps that you used to install MPICH2.
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Monday, September 12, 2011 9:15:32 AM
Subject: RE: [mpich2-maint] help for running MPICH2 under Window 7
HI, Jayesh,
Thanks indeed for your reply.
I did it in terms of your suggestions. But the problem is still there.
I run tests as follows:
I entered C:\Program Files\MPICH2\examples
and ran  mpiexec -n 12 cpi.exe
the error prompt is as before:
"CreateProcess failed, error 2
Unable to start the local smpd manager"
However, if I entered c:\Program Files\MPICH2\bin
and ran mpiexec -n 12 ../examples/cpi.exe
test is successful and cpi.exe works well under 12 CPUs.
This means I cannot do tests under the directory C:\Program Files\MPICH2\examples where cpi.exe is.
I look forward to your suggestions again and have a good day.
Dingjun
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Friday, September 09, 2011 2:47 PM
To: Dingjun Chen
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich2-maint] help for running MPICH2 under Window 7
 Uninstall your existing version of MPICH2 and follow the instructions in Section 9.4 (NOT 9.1) of the installer's guide (http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.4.1-installguide.pdf).
 Let us know if you still have issues.
Jayesh
To: mpich2-maint at mcs.anl.gov
Sent: Friday, September 9, 2011 3:39:27 PM
Subject: [mpich2-maint] help for running MPICH2 under Window 7
Hi, Dear Sir or Madam,
I just installed MPICH2 on my computer of Window 7 and ran the examples cpi.exe.
When I enter the following command:
mpiexec –n 4 cpi.exe
the prompt is as follow:
“CreateProcess failed, error 2
Unable to start the local smpd manager.”
Could you tell me how to solve above problem? I look forward to hearing from you.
Thank you in advance.
Dingjun Chen
R&D Technology Center
Computer Modelling Group Ltd.
3512 33 rd street NW,
Calgary, AB, Canada
mpich2-maint mailing list
mpich2-maint at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/mpich2-maint
