[mpich-discuss] Questions about "Configure"
kaz_wada_JCOM kaz_wada at jcom.home.ne.jp
Sat Sep 10 19:54:21 CDT 2011
Hi, A Chan,
Thank you very much for your comments.
Following your suggestions and using MPICH2-1.4.1p1, I used the follwoing
shell:
  cd /tmp/wadakazusige/mpich2-1.4.1p1
 /home/wadakazusige/libraries/mpich2-1.4.1p1/configure
CC=gcc --disable-f77 --disable-fc --build=i686-pc-cygwin --prefix=/home/wadakazusige/mpich2-install
2>&1 | tee c.txt
and the configuration was completed.
Then, I built MPICH2 and install commands.  And after putting PATH, I
checked
 which mpicc
 which mpiexec
They showed the appropriate location of the two codes, and I believe they
were completed.
In the next step, for testing the setup, I entered
 mpiexec -f machinefile -n 3 hostname
The response was as follows:
[mpiexec at Inspiron510m] HYDU_parse_hostfile
(/home/wadakazusige/libraries/mpich2-1.4.1p1/src/pm/hydra/utils/args/args.c:303):
unable to open host file: machinefile
[mpiexec at Inspiron510m] mfile_fn
(/home/wadakazusige/libraries/mpich2-1.4.1p1/src/pm/hydra/ui/mpich/utils.c:223):
error parsing hostfile
[mpiexec at Inspiron510m] match_arg
(/home/wadakazusige/libraries/mpich2-1.4.1p1/src/pm/hydra/utils/args/args.c:115):
match handler returned error
[mpiexec at Inspiron510m] HYDU_parse_array
(/home/wadakazusige/libraries/mpich2-1.4.1p1/src/pm/hydra/utils/args/args.c:140):
argument matching returned error
[mpiexec at Inspiron510m] parse_args
(/home/wadakazusige/libraries/mpich2-1.4.1p1/src/pm/hydra/ui/mpich/utils.c:1387):
error parsing input array
[mpiexec at Inspiron510m] HYD_uii_mpx_get_parameters
(/home/wadakazusige/libraries/mpich2-1.4.1p1/src/pm/hydra/ui/mpich/utils.c:1438):
unable to parse user arguments
Usage: ./mpiexec [global opts] [exec1 local opts] : [exec2 local opts] : ...
Global options (passed to all executables):
  Global environment options:
    -genv {name} {value}             environment variable name and value
    -genvlist {env1,env2,...}        environment variable list to pass
    -genvnone                        do not pass any environment variables
    -genvall                         pass all environment variables not
managed
                                          by the launcher (default)
  Other global options:
    -f {name}                        file containing the host names
    -hosts {host list}               comma separated host list
    -wdir {dirname}                  working directory to use
    -configfile {name}               config file containing MPMD launch
options
Local options (passed to individual executables):
  Local environment options:
    -env {name} {value}              environment variable name and value
    -envlist {env1,env2,...}         environment variable list to pass
    -envnone                         do not pass any environment variables
    -envall                          pass all environment variables
(default)
  Other local options:
    -n/-np {value}                   number of processes
    {exec_name} {args}               executable name and arguments
Hydra specific options (treated as global):
  Launch options:
    -launcher                        launcher to use ( ssh rsh fork slurm ll
lsf sge manual persist)
    -launcher-exec                   executable to use to launch processes
    -enable-x/-disable-x             enable or disable X forwarding
  Resource management kernel options:
    -rmk                             resource management kernel to use (
user slurm ll lsf sge pbs)
  Hybrid programming options:
    -ranks-per-proc                  assign so many ranks to each process
  Processor topology options:
    -binding                         process-to-core binding mode
    -topolib                         processor topology library ()
  Checkpoint/Restart options:
    -ckpoint-interval                checkpoint interval
    -ckpoint-prefix                  checkpoint file prefix
    -ckpoint-num                     checkpoint number to restart
    -ckpointlib                      checkpointing library (none)
  Demux engine options:
    -demux                           demux engine ( poll select)
  Other Hydra options:
    -verbose                         verbose mode
    -info                            build information
    -print-all-exitcodes             print exit codes of all processes
    -iface                           network interface to use
    -ppn                             processes per node
    -profile                         turn on internal profiling
    -prepend-rank                    prepend rank to output
    -prepend-pattern                 prepend pattern to output
    -outfile-pattern                 direct stdout to file
    -errfile-pattern                 direct stderr to file
    -nameserver                      name server information (host:port
format)
    -disable-auto-cleanup            don't cleanup processes on error
    -disable-hostname-propagation    let MPICH2 auto-detect the hostname
    -order-nodes                     order nodes as ascending/descending
cores
Please see the intructions provided at
http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
for further details
Could you let me know the reason?
Wada
>I copied and pasted your commmand without looking carefully, you should
>be using 1.4.1p1 instead of 1.4.1.
>A.Chan
----- Original Message -----
> That is odd! The same test in top-level mpich2 worked but the one
> in src/openpa failed! Both config.guess in src/openpa and top-level
> contain entry to cygwin (openpa's config.guess is newer). Can you redo
> configure as follows:
> > /home/wadakazusige/libraries/mpich2-1.4.1/configure CC=gcc
> > --prefix=/home/wadakazusige/mpich2-install 2>&1 | tee c.txt
> See if it works. If it fails similarly, add "--build=i686-pc-cygwin"
> and see if
> things work.
> A.Chan
> > Dear Sirs and Madams:
> > I am tring to install MPICH2-1.4.1p1 to my stand-alone PC based on
> > Windows
> > XP.
> > While configuring MPICH2, following your "MPICH2 Installer's Guide",
> > I got error message: "OpenPA configure failed", as you can see
> > attached
> > c.txt.
> > I would like to use MPICH2 under Cygwin I already installed.
> > Used commands to configure MPICH2 are as follows:
> > env CC="gcc"
> > 2>&1 | tee c.txt
> > Could you please teach me how to fix this problem.
> > Thank you very much for your support in advance.
> > Best regards,
> > Kazushige Wada
> > _______________________________________________
> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110911/c99715ed/attachment.htm>
