[mpich-discuss] Fwd: mpich compilation issue
    Reuti
    reuti at staff.uni-marburg.de
    Sat Sep 10 07:31:46 CDT 2011
Am 10.09.2011 um 05:45 schrieb akshar bhosale:
> but our code only works on mpich-1.2.7
> code doesn't support mpich2
why? Did you investigate the issues you face - i.e. what special feature of MPICH(1) are you using?
MPI programs should run with any MPI implementation you like to use.
-- Reuti
> can we get help?
> -akshar
> On Sat, Sep 10, 2011 at 3:13 AM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> We don't support MPICH anymore, please use MPICH2 instead.
> -Dave
> On Sep 9, 2011, at 4:38 PM CDT, akshar bhosale wrote:
> > errors we get  in make install :
> > cp: preserving permissions for `<install dir>//lib/libfmpich.a': Operation not supported
> > cp: preserving ACL for `/<install dir>/lib/libfmpich.a': Operation not supported
> > **Error copying file <path to mpich source>/mpich-1.2.7/lib/libfmpich.a to <install dir>//lib/libfmpich.a **
> > make: *** [install] Error 1
> > thank you
> > ---------- Forwarded message ----------
> > From: akshar bhosale <akshar.bhosale at gmail.com>
> > Date: Sat, Sep 10, 2011 at 2:58 AM
> > Subject: mpich compilation issue
> > To: mpich-discuss at mcs.anl.gov
> > hi,
> > we have requirement of mpich-1.2.7 with gfortran. We have fiven flags as : CC=gcc;F90=fortran;F77=gfortran; and tried to configure, it throws error as configure: error: Fortran 90 and Fortran 77 compilers are not compatible..
> > We have to do it using gfortran only. os is rhel5.1 64 bit
> > what extran flags settings we have to do?
> > -akshar
> > _______________________________________________
> > mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
