[mpich-discuss] MPI I/O using large integers in file type
    Nick Stokes
    randomaccessiterator at gmail.com
    Wed Sep  7 17:38:28 CDT 2011
Dear Rajeev,
On Wed, Sep 7, 2011 at 3:27 PM, Nick Stokes
<randomaccessiterator at gmail.com>wrote:
> On Wed, Sep 7, 2011 at 3:22 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
>> MPI_Type_create_hindexed does.
Moreover, on my 32-bit system  MPI_Aint is typedef'ed to int (at least in my
installation of MPICH2 - 1.3.3 on Windows 32-bit).  So hindexed type
seems not to solve the large file problem in general.  If it were possible
to create an indexed type with MPI_Offset displacements, that would have
helped.
Maybe I am on the wrong track here. Does my question make sense?  Perhaps a
more explicit and perhaps more relate-able example would be as follows:
Imagine a simulation where there are a total of 10^9  degrees of freedom,
and double precision is used.  The computation result is to be output to a
single file, which would add up to 8 GBs.  MPI is utilized to implement
parallelization via domain partitioning, and each partition holds a certain
chunk of data.   These chunks correspond to non-overlapping regions with
gaps in the final output.   How would you do a collective READ/WRITE in such
a case without integer overflow?
thanks many
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110907/a17286c8/attachment.htm>
