[mpich-discuss] problem wit mpd
    ajandaga at alumni.unav.es
    Mon Oct 31 10:06:49 CDT 2011
Thank to all for your help. Finally, I have installed it by apt-get
and it seems to work, even mpd. I wanted to install mpich2 to perform
the option of parallel computing of the program NONMEM 7.2.
Thanks again
Alvaro
Pavan Balaji <balaji at mcs.anl.gov> escribió:
> Please keep mpich-discuss cc'ed.
> You don't need to do anything special for multi-core machines.
> MPICH2 will automatically use shared memory internally.
>  -- Pavan
> On 10/31/2011 08:32 AM, ehsan saei wrote:
>> ok I forgot the libraries name .
>> What do you want to do on intel dua-core?
>> if you want to run multiprocess program on single computer I can help you.
>> On Oct 31, 2011, at 6:17 AM, Pavan Balaji wrote:
>>> Please use:
>>> % sudo apt-get install libmpich2-dev
>>> -- Pavan
>>> On 10/31/2011 07:50 AM, ehsan saei wrote:
>>>> hello
>>>> you could install MPICH2 by writing this command on terminal :
>>>> sudo apt-get install libmpi2 or other libraries that support mpi
>>>> and the operating system would done any thing automatically .
>>>> in some ubuntu versions you must install libcr library from
>>>> synpatic package manager if you can not compile your code.
>>>> On Oct 31, 2011, at 4:15 AM, ajandaga at alumni.unav.es wrote:
>>>> _______________________________________________
>>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>>> To manage subscription options or unsubscribe:
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>> Pavan Balaji
>>> http://www.mcs.anl.gov/~balaji
> Pavan Balaji
Este mensaje ha sido enviado desde https://webmail.unav.es
