[mpich-discuss] problem wit mpd
    ajandaga at alumni.unav.es
    Mon Oct 31 06:15:00 CDT 2011
Dear Sir or Madam:
I an trying to install MPICH2 on a intel Dual-Core with Ubuntu 10.04.2
LTS and I have a problem when I check the installation. I have
followed all instructions of the install guide but when I type "which
mpd", I do not get any response. However, with "which mpicc; which
mpiexec; which mpirun", it refers to the directory "/usr/bin/". Could
you help me about it?. As additional information I attached you the
files  "c.txt", "m.txt", "mi.txt", that I have gotten during the
installation.
Thanks in advance.
Yours faithfully
Alvaro Janda
Este mensaje ha sido enviado desde https://webmail.unav.es
Configuring MPICH2 version 1.2.1p1 with  '-prefix=/home/ajandaga/mpich2-install'
Running on system: Linux ajandaga 2.6.32-28-generic #55-Ubuntu SMP Mon Jan 10 21:21:01 UTC 2011 i686 GNU/Linux
Executing mpich2prereq in /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/ch3 with
Executing mpich2prereq in /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis
sourcing /home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/mpd/mpich2prereq
sourcing /home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/hydra/mpich2prereq
sourcing /home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/gforker/mpich2prereq
sourcing /home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/mpd/setup_pm
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O2... yes
checking whether routines compiled with -O2 can be linked with ones compiled without -O2... yes
checking for type of weak symbol alias support... pragma weak
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute ((weak_import)) allowed... yes
checking for multiple weak symbol support... yes
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... ifort
checking whether we are using the GNU Fortran 77 compiler... no
checking whether ifort accepts -g... yes
checking whether Fortran 77 compiler accepts option -O2... yes
checking how to get verbose linking output from ifort... -v
checking for Fortran 77 libraries of ifort...  -L/opt/intel/composer_xe_2011_sp1.6.233/compiler/lib/ia32 -L/usr/lib/gcc/i486-linux-gnu/4.4.3/ -L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/ -L/lib/../lib/ -L/usr/lib/../lib/ -L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../ -L/lib/ -L/usr/lib/ -L/usr/lib/i486-linux-gnu -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lirc_s -ldl
checking whether ifort accepts the FLIBS found by autoconf... yes
checking whether C can link with  -L/opt/intel/composer_xe_2011_sp1.6.233/compiler/lib/ia32 -L/usr/lib/gcc/i486-linux-gnu/4.4.3/ -L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/ -L/lib/../lib/ -L/usr/lib/../lib/ -L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../ -L/lib/ -L/usr/lib/ -L/usr/lib/i486-linux-gnu -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lirc_s -ldl... yes
checking for linker for Fortran main programs... Use Fortran to link programs
checking whether Fortran 77 and C objects are compatible... yes
checking for Fortran 77 name mangling... lower underscore
checking what libraries are needed to link Fortran programs with C routines that use stdio... none
checking whether Fortran init will work with C... yes
checking that f works as the extension for Fortran 90 program... yes
checking whether we are using the GNU Fortran 90 compiler... no
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (ifort  ) works... yes
checking whether the Fortran 90 compiler (ifort  ) is a cross-compiler... no
checking whether Fortran 90 works with Fortran 77... yes
checking whether Fortran accepts ! for comments... yes
checking for include directory flag for Fortran... -I
checking for Fortran 77 flag for library directories... -L
checking for which Fortran libraries are needed to link C with Fortran... none
checking whether Fortran compiler processes .F files with C preprocessor... yes
checking whether we are using the GNU Fortran 90 compiler... (cached) no
checking whether ifort accepts -g... (cached) yes
checking for Fortran 90 module extension... mod
checking for Fortran 90 module include flag... -I
checking whether Fortran 90 accepts f90 suffix... yes
checking whether Fortran 90 compiler accepts option -O2... yes
checking whether Fortran 90 compiler processes .F90 files with C preprocessor... yes
checking what libraries are needed to link Fortran90 programs with C routines that use stdio... none
checking for f90 compiler vendor... intel
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking whether the C++ compiler c++ can build an executable... yes
checking whether C++ compiler works with string... yes
checking whether the compiler supports exceptions... yes
checking whether the compiler recognizes bool as a built-in type... yes
checking whether the compiler implements namespaces... yes
checking whether <iostream> available... yes
checking whether the compiler implements the namespace std... yes
checking whether <math> available... no
checking for GNU g++ version... 4 . 4
checking whether C++ compiler accepts option -O2... yes
checking for perl... /usr/bin/perl
checking for ar... ar
checking for ranlib... ranlib
checking for killall... killall
checking for a BSD-compatible install... /usr/bin/install -c
checking whether install works... yes
checking whether install breaks libraries... no
checking whether mkdir -p works... yes
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... no
checking for bash... /bin/bash
checking whether /bin/bash supports arrays... yes
checking for doctext... false
checking for location of doctext style files... unavailable
checking for an ANSI C-conforming const... yes
checking for working volatile... yes
checking for C/C++ restrict keyword... __restrict
checking for inline... inline
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
checking whether byte ordering is bigendian... no
checking whether C compiler allows unaligned doubles... yes
checking whether gcc supports __func__... yes
Using gcc to determine dependencies
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for max C struct integer alignment... four
checking for max C struct floating point alignment... four
checking for max C struct alignment of structs with doubles... four
checking for max C struct floating point alignment with long doubles... four
checking if alignment of structs with doubles is based on position... no
checking if alignment of structs with long long ints is based on position... no
checking if double alignment breaks rules, find actual alignment... no
checking for alignment restrictions on pointers... int or better
checking size of char... 1
checking size of unsigned char... 1
checking size of short... 2
checking size of unsigned short... 2
checking size of int... 4
checking size of unsigned int... 4
checking size of long... 4
checking size of unsigned long... 4
checking size of long long... 8
checking size of unsigned long long... 8
checking size of float... 4
checking size of double... 8
checking size of long double... 12
checking size of void *... 4
checking for ANSI C header files... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking size of wchar_t... 4
checking size of float_int... 8
checking size of double_int... 12
checking size of long_int... 8
checking size of short_int... 8
checking size of two_int... 8
checking size of long_double_int... 16
checking sys/bitypes.h usability... yes
checking sys/bitypes.h presence... yes
checking for sys/bitypes.h... yes
checking inttypes.h usability... yes
checking inttypes.h presence... yes
checking for inttypes.h... yes
checking stdint.h usability... yes
checking stdint.h presence... yes
checking for stdint.h... yes
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking size of _Bool... 1
checking size of float _Complex... 8
checking size of double _Complex... 16
checking size of long double _Complex... 24
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking for size of Fortran type integer... 4
checking for size of Fortran type real... 4
checking for size of Fortran type double precision... 8
checking whether integer*1 is supported... yes
checking whether integer*2 is supported... yes
checking whether integer*4 is supported... yes
checking whether integer*8 is supported... yes
checking whether integer*16 is supported... no
checking whether real*4 is supported... yes
checking whether real*8 is supported... yes
checking whether real*16 is supported... yes
checking for C type matching Fortran integer... int
checking for size of MPI_Status... 20
checking for values of Fortran logicals... True is -1 and False is 0
checking for Fortran 90 integer kind for 4-byte integers... 4
checking for Fortran 90 integer kind for 8-byte integers... 8
checking whether real*8 is supported in Fortran 90... yes
checking size of bool... 1
checking how to run the C++ preprocessor... c++ -E
checking complex usability... yes
checking complex presence... yes
checking for complex... yes
checking size of Complex... 8
checking size of DoubleComplex... 16
checking size of LongDoubleComplex... 24
checking if char * pointers use byte addresses... yes
checking for alignment restrictions on ... no
checking for alignment restrictions on int32_t... no
checking size of MPIR_Bsend_data_t... 56
checking for gcc __asm__ and pentium cmpxchgl instruction... yes
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... no
checking for gcc __asm__ and IA64 xchg4 instruction... no
checking for ANSI C header files... (cached) no
checking stdlib.h usability... yes
checking stdlib.h presence... yes
checking for stdlib.h... yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking sys/types.h usability... yes
checking sys/types.h presence... yes
checking for sys/types.h... yes
checking string.h usability... yes
checking string.h presence... yes
checking for string.h... yes
checking for inttypes.h... (cached) yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stddef.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking unistd.h usability... yes
checking unistd.h presence... yes
checking for unistd.h... yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/uio.h... yes
checking for size_t... yes
checking for setitimer... yes
checking for alarm... yes
checking for vsnprintf... yes
checking for vsprintf... yes
checking whether vsnprintf needs a declaration... no
checking for strerror... yes
checking for strncasecmp... yes
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for va_copy... yes
checking for variable argument list macro functionality... yes
checking valgrind.h usability... no
checking valgrind.h presence... no
checking for valgrind.h... no
checking memcheck.h usability... no
checking memcheck.h presence... no
checking for memcheck.h... no
checking valgrind/valgrind.h usability... no
checking valgrind/valgrind.h presence... no
checking for valgrind/valgrind.h... no
checking valgrind/memcheck.h usability... no
checking valgrind/memcheck.h presence... no
checking for valgrind/memcheck.h... no
checking for working alloca.h... yes
checking for alloca... yes
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for mkstemp... yes
checking whether mkstemp needs a declaration... no
checking for fdopen... yes
checking whether fdopen needs a declaration... yes
checking for putenv... yes
checking whether putenv needs a declaration... no
checking for clock_gettime... no
checking for clock_getres... no
checking for gethrtime... no
checking for gettimeofday... yes
sourcing /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/ch3/setup_device
RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
sourcing /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/setup_channel
RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
sourcing /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/common/locks/setup
RUNNING SETUP FOR THE PROCESS LOCKS MODULE
SPARC V9 inline spin locks supported...no
SPARC V8 inline spin locks supported...no
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for fgrep... /bin/fgrep
checking for pthread_key_create in -lpthread... yes
checking for pthread_yield... yes
checking for pthread_key_create... yes
checking for pthread_cleanup_push... no
checking whether pthread_cleanup_push is available (may be a macro in pthread.h)... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE... no
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK... no
checking for sched_yield... yes
checking for yield... no
checking for usleep... yes
checking for sleep... yes
checking for select... yes
checking for getpid... yes
checking for sched_setaffinity... yes
checking for sched_getaffinity... yes
checking for bindprocessor... no
checking for thread_policy_set... no
checking whether cpu_set_t available... yes
checking whether the CPU_SET and CPU_ZERO macros are defined... no
configure: configuring subsystem in src/openpa
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking whether to enable assertions... yes
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/stat.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking atomic.h usability... no
checking atomic.h presence... no
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking for stdint.h... (cached) yes
checking for pthread_create in -lpthread... yes
checking if 100 threads can be run at once... yes
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 bit primitives... yes
checking for support for gcc x86 bit primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... yes
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: src/config.h is unchanged
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
config.status: src/opa_config.h is unchanged
config.status: executing depfiles commands
configure: configuring subsystem in src/mpid/ch3
RUNNING CONFIGURE FOR CH3 DEVICE
checking whether make sets CFLAGS... yes
16
checking for string.h... (cached) yes
checking for sys/types.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking uuid/uuid.h usability... no
checking uuid/uuid.h presence... no
checking for uuid/uuid.h... no
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking for unistd.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for net/if.h... yes
checking for pid_t... yes
checking for inet_pton... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking whether CPP accepts variable length argument lists... yes
checking whether we can use struct ifconf... yes
config.status: creating util/Makefile
config.status: creating util/shm/Makefile
config.status: creating util/shmbase/Makefile
config.status: creating channels/Makefile
config.status: creating util/ftb/Makefile
config.status: creating localdefs
config.status: creating include/mpid_thread.h
config.status: creating include/mpidi_ch3_conf.h
config.status: include/mpidi_ch3_conf.h is unchanged
config.status: executing default-1 commands
copying /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/ch3/../common/thread/mpid_thread_mpe.c to src/mpid_thread.c
=== configuring in channels/nemesis (/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis)
configure: running /bin/bash /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/configure --disable-option-checking '--prefix=/home/ajandaga/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'CC=gcc' 'CFLAGS= -O2' 'LIBS= -lpthread' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' --cache-file=/dev/null --srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis
RUNNING CONFIGURE FOR THE NEMESIS CHANNEL
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking for netinet/in.h... yes
checking for rand... yes
checking for srand... yes
checking for OpenPA atomic primitive availability... yes
checking for mmap... yes
checking for munmap... yes
configure: Using a memory-mapped file for shared memory
checking whether struct hostent contains h_addr_list... yes
checking knem_io.h usability... no
checking knem_io.h presence... no
checking for knem_io.h... no
config.status: creating nemesis/Makefile
config.status: creating nemesis/src/Makefile
config.status: creating nemesis/utils/Makefile
config.status: creating nemesis/utils/replacements/Makefile
config.status: creating nemesis/utils/monitor/Makefile
config.status: creating nemesis/netmod/Makefile
config.status: creating nemesis/netmod/elan/Makefile
config.status: creating nemesis/netmod/gm/Makefile
config.status: creating nemesis/netmod/mx/Makefile
config.status: creating nemesis/netmod/tcp/Makefile
config.status: creating nemesis/netmod/ib/Makefile
config.status: creating nemesis/netmod/psm/Makefile
config.status: creating nemesis/netmod/newmad/Makefile
config.status: creating nemesis/netmod/none/Makefile
config.status: creating nemesis/include/mpid_nem_net_module_defs.h
config.status: creating nemesis/src/mpid_nem_net_array.c
config.status: creating include/mpidi_ch3i_nemesis_conf.h
config.status: include/mpidi_ch3i_nemesis_conf.h is unchanged
configure: configuring subsystem in src/mpid/common/locks
configure: WARNING: unrecognized options: --with-atomic-primitives
RUNNING CONFIGURE FOR LOCKS
checking for mutex_init... no
checking for compare_and_swap... no
checking for pthread_mutexattr_init... yes
checking for pthread_mutexattr_setpshared... yes
config.status: creating mpid_locksconf.h
config.status: mpid_locksconf.h is unchanged
configure: configuring subsystem in src/mpi/romio
Configuring with args --prefix=/home/ajandaga/mpich2-install --with-atomic-primitives=auto_allow_emulation
checking for architecture... LINUX
ROMIO home directory is /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpi/romio
checking for memalign... yes
checking Fortran external names
Fortran externals have a trailing underscore and are lowercase
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for u_char... yes
checking for u_short... yes
checking for u_int... yes
checking for u_long... yes
checking sys/attr.h usability... no
checking sys/attr.h presence... no
checking for sys/attr.h... no
checking for int large enough for pointers... yes
checking for Fortran 90 KIND parameter for 8-byte integers...            8
checking that we can use integer*8 to declare MPI_DISPLACMENT_CURRENT... yes
Overriding Array test for MPICH2
checking for weak symbol support... pragma weak
checking that weak symbols are visible to other files... yes
checking that the compiler correctly implements weak symbols... yes
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs nfs
configure: WARNING: File locks may not work with NFS.  See the Installation and
users manual for instructions on testing and if necessary fixing this
checking for library containing aio_write... -lrt
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking if aio.h exists and can be compiled... yes
checking if sys/aio.h exists and can be compiled... no
checking whether aio routines can be used... yes
checking for obsolete two-argument aio_write... no
checking for obsolete two-argument aio_suspend... no
checking for aio_fildes member of aiocb structure... yes
checking for aio_whence member of aiocb structure... no
checking for aio_handle member of aiocb structure... no
checking for aio_reqprio member of aiocb structure... yes
checking for aio_sigevent member of aiocb structure... yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for large file defines... yes
checking whether off64_t is an scalar type... yes
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for lseek64... yes
checking whether lseek64 needs a declaration... no
setting SYSDEP_INC to
setting CC to gcc
setting F77 to ifort
setting TEST_CC to /tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc
setting TEST_F77 to /tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77
setting CFLAGS to  -O2  -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating mpi-io/Makefile
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating adio/common/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating test-internal/Makefile
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating adio/ad_nfs/Makefile
config.status: creating adio/ad_ufs/Makefile
config.status: creating adio/ad_bgl/Makefile
config.status: creating adio/ad_bglockless/Makefile
config.status: creating adio/ad_panfs/Makefile
config.status: creating adio/ad_xfs/Makefile
config.status: creating adio/ad_sfs/Makefile
config.status: creating adio/ad_pfs/Makefile
config.status: creating adio/ad_testfs/Makefile
config.status: creating adio/ad_pvfs/Makefile
config.status: creating adio/ad_pvfs2/Makefile
config.status: creating adio/ad_gridftp/Makefile
config.status: creating adio/ad_lustre/Makefile
config.status: creating adio/ad_zoidfs/Makefile
config.status: creating mpi-io/fortran/Makefile
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating mpi-io/glue/mpich2/Makefile
config.status: creating mpi-io/glue/mpich1/Makefile
config.status: creating mpi-io/glue/default/Makefile
config.status: creating common/dataloop/Makefile
config.status: creating adio/include/romioconf.h
configure: configuring subsystem in src/pmi/simple
RUNNING CONFIGURE FOR THE SIMPLE PMI
checking for stdlib.h... (cached) yes
checking for strings.h... (cached) yes
checking for sys/socket.h... (cached) yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for socket... yes
checking for setsockopt... yes
checking for gethostbyname... yes
checking whether socklen_t is defined (in sys/socket.h if present)... yes
config.status: creating pmiconf.h
config.status: pmiconf.h is unchanged
configure: configuring subsystem in src/pm/mpd
checking whether ln -s works... yes
checking whether install /usr/bin/install -c works... yes
Using INSTALL=/usr/bin/install -c
checking for totalview... no
checking for python2.6... python2.6
checking for python2.5... no
checking for python2.4... no
checking for python2.3... no
checking for python2.2... no
checking for python2... python2
checking for python... python
checking that python2.6 is a valid python version... yes
checking that the cPickle module is available for python2.6... yes
checking for sys/wait.h that is POSIX.1 compatible... yes
config.status: creating mpdconf.h
configure: configuring subsystem in src/pm/hydra
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for strip... strip
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for doxygen... no
checking for socket in -lsocket... no
checking for gethostbyname in -lnsl... yes
checking for sigaction... yes
checking for signal... yes
checking for alloca... no
checking for unsetenv... yes
checking for strsignal... yes
checking for putenv... (cached) yes
checking for environ in unistd.h... no
checking for manually declared extern environ... yes
checking boot-strap server... ssh,rsh,fork,slurm
checking communication subsystem... none
checking resource management kernel... dummy,pbs
checking process manager... pmiserv
checking user interface... mpiexec
checking debugging support... no
checking warnings... no
checking process binding library... plpa
checking if plpa works correctly... yes
checking checkpointing library... none
checking whether the compiler allows __VA_ARGS__... yes
checking for strsignal... (cached) yes
checking whether strsignal needs a declaration... no
checking for sigaction... (cached) yes
checking for signal... (cached) yes
checking for sigset... yes
checking for struct sigaction and sa_handler... yes
config.status: creating tools/bootstrap/src/bsci_init.c
config.status: creating tools/bootstrap/include/bsci.h
config.status: creating rmk/src/rmki_init.c
config.status: creating rmk/include/rmki.h
config.status: creating css/src/cssi_init.c
config.status: creating css/include/cssi.h
config.status: creating hydra-doxygen.cfg
config.status: creating include/hydra_config.h
config.status: include/hydra_config.h is unchanged
config.status: executing libtool commands
=== configuring in ../../mpl (/tmp/ajandaga/mpich2-1.2.1p1/src/pm/hydra/../../mpl)
configure: running /bin/bash /home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/hydra/../../mpl/configure --disable-option-checking '--prefix=/home/ajandaga/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' --cache-file=/dev/null --srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/hydra/../../mpl
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
config.status: creating include/config.h
config.status: include/config.h is unchanged
config.status: executing include/mplconfig.h commands
config.status: creating include/mplconfig.h - prefix MPL for include/config.h defines
config.status: include/mplconfig.h is unchanged
configure: configuring subsystem in src/pm/gforker
RUNNING CONFIGURE FOR THE GFORKER PM
checking for setsid... yes
checking for isatty... yes
checking for getsid... yes
checking for library containing socketpair... none required
checking sys/ptrace.h usability... yes
checking sys/ptrace.h presence... yes
checking for sys/ptrace.h... yes
checking for struct sigaction... yes
checking wait.h usability... yes
checking wait.h presence... yes
checking for wait.h... yes
config.status: creating forkerconf.h
config.status: forkerconf.h is unchanged
=== configuring in ../util (/tmp/ajandaga/mpich2-1.2.1p1/src/pm/gforker/../util)
configure: running /bin/bash /home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/gforker/../util/configure --disable-option-checking '--prefix=/home/ajandaga/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' --cache-file=/dev/null --srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/gforker/../util
RUNNING CONFIGURE FOR THE PM UTILITIES
checking for strtol... yes
checking whether getsid is prototyped in unistd.h... no
checking for cygwin1.dll in /bin... yes
checking for extern environ in runtime... yes
checking for ANSI C header files... (cached) yes
checking whether struct iovec is defined in sys/uio.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking whether FD_ZERO works... yes
config.status: creating pmutilconf.h
config.status: pmutilconf.h is unchanged
configure: configuring subsystem in src/mpe2
Configuring MPE Profiling System with  '--prefix=/home/ajandaga/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2'
checking gnumake... yes using --no-print-directory
checking BSD 4.4 make... no - whew
checking OSF V3 make... no
This MPE build is part of the MPICH2 build
checking for leftover Makefiles in subpackages ...  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/graphics" "src/collchk" "src/slog2sdk" cleaned
checking whether MPI_CC has been set ... /tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc
checking whether MPI_F77 has been set ... /tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77
checking for Fortran 77 libraries of ifort...  -L/opt/intel/composer_xe_2011_sp1.6.233/compiler/lib/ia32 -L/usr/lib/gcc/i486-linux-gnu/4.4.3/ -L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/ -L/lib/../lib/ -L/usr/lib/../lib/ -L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../ -L/lib/ -L/usr/lib/ -L/usr/lib/i486-linux-gnu -lpthread -lrt -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lirc_s -ldl
checking whether C can link with  -L/opt/intel/composer_xe_2011_sp1.6.233/compiler/lib/ia32 -L/usr/lib/gcc/i486-linux-gnu/4.4.3/ -L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/ -L/lib/../lib/ -L/usr/lib/../lib/ -L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../ -L/lib/ -L/usr/lib/ -L/usr/lib/i486-linux-gnu -lpthread -lrt -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lirc_s -ldl... yes
config.status: creating sbin/mpetestlink
config.status: creating sbin/mpetestexec
config.status: creating sbin/mpetestexeclog
config.status: creating sbin/mpeinstall
config.status: creating sbin/mpecheckinstall
config.status: WARNING:  '/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/sbin/mpecheckinstall.in' seems to ignore the --datarootdir setting
config.status: creating sbin/mpecheckbuild
config.status: creating etc/mpe_help.conf
config.status: creating etc/mpe_f77env.conf
config.status: creating mpe_conf.h
config.status: mpe_conf.h is unchanged
=== configuring in src/misc (/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/src/misc)
configure: running /bin/bash /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/configure --disable-option-checking '--prefix=/home/ajandaga/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' --cache-file=/dev/null --srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc
Configuring MPE Miscellaneous Library with  '--disable-option-checking' '--prefix=/home/ajandaga/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' '--cache-file=/dev/null' '--srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc'
checking whether gcc and cc understand -c and -o together... yes
checking for dbx... no
checking for gdb... /usr/bin/gdb
checking for sysinfo... yes
checking for uname... yes
checking sys/systeminfo.h usability... no
checking sys/systeminfo.h presence... no
checking for sys/systeminfo.h... no
checking for sighandler_t... no
checking for kill... yes
checking whether kill needs a declaration... no
config.status: creating src/dbxerr.c
config.status: creating mpe_misc_conf.h
=== configuring in src/callstack (/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/src/callstack)
configure: running /bin/bash /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/configure --disable-option-checking '--prefix=/home/ajandaga/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' --cache-file=/dev/null --srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack
Configuring MPE CallStack Library with  '--disable-option-checking' '--prefix=/home/ajandaga/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' '--cache-file=/dev/null' '--srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack'
checking execinfo.h usability... yes
checking execinfo.h presence... yes
checking for execinfo.h... yes
checking whether <execinfo.h> defines backtrace_symbols_fd() ... yes
checking if <execinfo.h> links with -Wl,--export-dynamic ... yes
checking whether fdopen needs a declaration... no
config.status: creating include/mpe_callstack.h
config.status: creating etc/mpe_callstack_ldflags.conf
config.status: creating mpe_callstack_conf.h
=== configuring in src/logging (/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/src/logging)
configure: running /bin/bash /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/configure --disable-option-checking '--prefix=/home/ajandaga/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' --cache-file=/dev/null --srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging
Configuring MPE Logging Library and Tools with  '--disable-option-checking' '--prefix=/home/ajandaga/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' '--cache-file=/dev/null' '--srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging'
checking for header that defines C99 integer types, intXX_t ... <stdint.h>
checking whether <inttypes.h> defines the PRIdXX macros ... yes
checking if <stdint.h> can be behind system headers ... yes
checking for address-sized integer ... CLOG_int32_t
checking for srand48... yes
checking whether srand48 needs a declaration... no
checking for lrand48... yes
checking whether lrand48 needs a declaration... no
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... 64
checking for O_LARGEFILE for open() ... needs _LARGEFILE64_SOURCE
checking for O_BINARY for open() ... no
checking for pthread_mutex_lock in -lpthread... yes
config.status: creating include/clog_inttypes.h
config.status: creating include/mpi_null.h
config.status: creating include/mpe_log_thread.h
config.status: creating etc/mpe_log.conf
config.status: creating etc/mpe_nolog.conf
config.status: creating etc/mpe_log_postlib.conf
config.status: creating mpe_logging_conf.h
=== configuring in src/wrappers (/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/src/wrappers)
configure: running /bin/bash /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/configure --disable-option-checking '--prefix=/home/ajandaga/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' --cache-file=/dev/null --srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers
Configuring MPE Wrapper Libraries For MPI with  '--disable-option-checking' '--prefix=/home/ajandaga/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' '--cache-file=/dev/null' '--srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers'
checking for stdarg is correct... yes
checking if compiler accepts prototypes ... yes
checking for safe PMPI invocations ... no
checking for the value of MPI_STATUS_SIZE ... 5
config.status: creating etc/mpe_mpilog.conf
config.status: creating etc/mpe_mpitrace.conf
config.status: creating mpe_wrappers_conf.h
=== configuring in src/graphics (/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/src/graphics)
configure: running /bin/bash /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/configure --disable-option-checking '--prefix=/home/ajandaga/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' --cache-file=/dev/null --srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics
Configuring MPE X Graphics Library with  '--disable-option-checking' '--prefix=/home/ajandaga/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' '--cache-file=/dev/null' '--srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics'
checking for X... libraries , headers
checking for long pointer... no
checking for system... yes
config.status: creating contrib/life/Makefile
config.status: creating contrib/mandel/Makefile
config.status: creating contrib/mastermind/Makefile
config.status: creating contrib/test/Makefile
config.status: creating etc/mpe_mpianim.conf
config.status: creating etc/mpe_graphics.conf
config.status: creating mpe_graphics_conf.h
=== configuring in src/collchk (/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/src/collchk)
configure: running /bin/bash /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/configure --disable-option-checking '--prefix=/home/ajandaga/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' --cache-file=/dev/null --srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk
Configuring MPE Collective and Datatype Checking Library with  '--disable-option-checking' '--prefix=/home/ajandaga/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' '--cache-file=/dev/null' '--srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk'
config.status: creating etc/mpe_mpicheck.conf
config.status: creating mpe_collchk_conf.h
=== configuring in src/slog2sdk (/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/src/slog2sdk)
configure: running /bin/bash /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/configure --disable-option-checking '--prefix=/home/ajandaga/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' --cache-file=/dev/null --srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/slog2sdk
Configuring SLOG2SDK with  '--disable-option-checking' '--prefix=/home/ajandaga/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' '--cache-file=/dev/null' '--srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/slog2sdk'
checking if CLASSPATH is set... no, good to go
checking for java in user's PATH... found /usr/bin/java
checking if /usr/bin/java runs simple java class... yes
checking if /usr/bin/java runs simple jar file... yes
checking if /usr/bin/java runs non-GUI tool... yes
checking if /usr/bin/java runs simple Swing class... yes
checking if /usr/bin/java runs simple Swing jar file... yes
checking for Java version... java full version "gcj-1.5.0", i.e. Java 2 SDK
checking for cygpath... no
creating sample logfiles from source
checking for leftover Makefiles in subpackages ... none
config.status: creating sbin/install-package
config.status: creating bin/slog2print
config.status: creating bin/slog2navigator
config.status: creating bin/slog2filter
config.status: creating bin/slog2updater
config.status: creating bin/logconvertor
config.status: creating bin/jumpshot
config.status: creating bin/clogprint
config.status: creating bin/clogTOslog2
config.status: creating bin/clog2print
config.status: creating bin/clog2TOslog2
=== configuring in trace_rlog (/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/trace_rlog)
configure: running /bin/bash /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/trace_rlog/configure --disable-option-checking '--prefix=/home/ajandaga/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' --cache-file=/dev/null --srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/trace_rlog
Configuring TRACE_RLOG implementation with  '--disable-option-checking' '--prefix=/home/ajandaga/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   ' 'CPPFLAGS= -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=ifort' 'FFLAGS= -O2' '--cache-file=/dev/null' '--srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/trace_rlog'
checking size of __int64... 0
checking for sed... sed
checking for a sed that does not truncate output... sed
checking whether to build static libraries... no
checking for malloc in -lefence... no
checking for strstr... yes
checking target system type... i686-pc-linux-gnu
checking for javah in user's PATH... not found
configure: WARNING:  Invalid JNI include dir, exit!
configure: WARNING: SLOG2SDK: No sub-package has been configured
MPE2:  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/graphics" "src/collchk" "src/slog2sdk" have been configured
checking size of OPA_ptr_t... 4
checking the sizeof MPI_Offset... 8
checking whether the Fortran Offset type works with Fortran77... yes
checking whether the Fortran Offset type works with Fortran90... yes
Running Configure for F90 Type routines
checking for cc... gcc
checking whether the C compiler sets its return status correctly... yes
checking for an ANSI C-conforming const... no
checking for Fortran 90 compiler default output file name... a.out
checking whether the Fortran 90 compiler works... yes
checking for precision and range of reals...  6 , 37
checking for precision and range of double precision...  15 , 307
checking for range of integers...  9
checking for available integer kinds and ranges...  2 , 1, 4 , 2, 9 , 4, 18 , 8,
 {  2 , 1 , 1 }, {  4 , 2 , 2 }, {  9 , 4 , 4 }, {  18 , 8 , 8 },
config.status: creating mpif90model.h
config.status: creating src/include/Makefile
config.status: creating src/include/mpich2info.h
config.status: creating mpich2-doxygen
config.status: creating src/include/mpichtimer.h
config.status: creating src/binding/Makefile
config.status: creating src/binding/cxx/Makefile
config.status: creating src/binding/cxx/mpicxx.h
config.status: creating src/binding/f77/Makefile
config.status: creating src/binding/f77/mpif.h
config.status: creating src/binding/f77/setbotf.f
config.status: creating src/binding/f90/Makefile
config.status: creating src/binding/f90/mpi_sizeofs.f90
config.status: creating src/packaging/Makefile
config.status: creating src/packaging/pkgconfig/mpich2-ch3.pc
config.status: creating src/packaging/pkgconfig/Makefile
config.status: creating src/packaging/envmods/mpich2.module
config.status: WARNING:  '/home/ajandaga/libraries/mpich2-1.2.1p1/src/packaging/envmods/mpich2.module.in' seems to ignore the --datarootdir setting
config.status: creating src/packaging/envmods/Makefile
config.status: creating src/env/mpixxx_opts.conf
config.status: creating src/env/mpicc
config.status: creating src/env/mpicc.conf
config.status: creating src/env/mpicc.bash
config.status: creating src/env/mpicxx
config.status: creating src/env/mpicxx.conf
config.status: creating src/env/mpicxx.bash
config.status: creating src/env/mpif77
config.status: creating src/env/mpif77.conf
config.status: creating src/env/mpif77.bash
config.status: creating src/env/mpif90
config.status: creating src/env/mpif90.conf
config.status: creating src/env/mpif90.bash
config.status: creating src/env/parkill
config.status: creating src/env/Makefile
config.status: creating src/util/createshlib
config.status: creating src/mpi/Makefile
config.status: creating src/mpi/attr/Makefile
config.status: creating src/mpi/coll/Makefile
config.status: creating src/mpi/comm/Makefile
config.status: creating src/mpi/datatype/Makefile
config.status: creating src/mpi/debugger/Makefile
config.status: creating src/mpi/errhan/Makefile
config.status: creating src/mpi/group/Makefile
config.status: creating src/mpi/init/Makefile
config.status: creating src/mpi/misc/Makefile
config.status: creating src/mpi/pt2pt/Makefile
config.status: creating src/mpi/rma/Makefile
config.status: creating src/mpi/spawn/Makefile
config.status: creating src/mpi/timer/Makefile
config.status: creating src/mpi/topo/Makefile
config.status: creating src/mpid/Makefile
config.status: creating src/mpid/common/Makefile
config.status: creating src/mpid/common/datatype/Makefile
config.status: creating src/mpid/common/datatype/dataloop/Makefile
config.status: creating src/pm/Makefile
config.status: creating src/pmi/Makefile
config.status: creating src/pmi/simple/Makefile
config.status: creating src/nameserv/Makefile
config.status: creating src/nameserv/file/Makefile
config.status: creating src/nameserv/mpd/Makefile
config.status: creating src/nameserv/pmi/Makefile
config.status: creating src/nameserv/test/Makefile
config.status: creating src/util/Makefile
config.status: creating src/util/info/Makefile
config.status: creating src/util/instrm/Makefile
config.status: creating src/util/thread/Makefile
config.status: creating src/util/mem/Makefile
config.status: creating src/util/msgs/Makefile
config.status: creating src/util/param/Makefile
config.status: creating src/util/dbg/Makefile
config.status: creating src/util/dbg/getfuncstack
config.status: creating src/util/osserv/Makefile
config.status: creating src/util/procmap/Makefile
config.status: creating src/util/other/Makefile
config.status: creating src/include/mpi.h
config.status: creating test/util/Makefile
config.status: creating test/basic/Makefile
config.status: creating test/commands/Makefile
config.status: creating test/commands/cmdtests
config.status: creating test/mpid/Makefile
config.status: creating test/mpid/ch3/Makefile
config.status: creating test/util/timer/Makefile
config.status: creating examples/Makefile
config.status: creating examples/f77/Makefile
config.status: creating examples/f90/Makefile
config.status: creating examples/cxx/Makefile
config.status: creating src/util/logging/Makefile
config.status: creating src/util/logging/common/Makefile
config.status: creating doc/Makefile
config.status: creating doc/mansrc/Makefile
config.status: creating doc/mansrc/createhtmlindex
config.status: creating doc/refman/Makefile
config.status: creating doc/installguide/Makefile
config.status: creating doc/userguide/Makefile
config.status: creating doc/logging/Makefile
config.status: creating doc/design/Makefile
config.status: creating doc/smpd/Makefile
config.status: creating doc/windev/Makefile
config.status: creating src/include/mpichconf.h
config.status: src/include/mpichconf.h is unchanged
config.status: executing default-2 commands
config.status: executing default-3 commands
config.status: executing default-4 commands
config.status: executing default-5 commands
config.status: executing default-6 commands
config.status: executing default-7 commands
config.status: executing default-8 commands
Updating dependency directories .deps
config.status: executing default-9 commands
config.status: executing default-10 commands
config.status: executing default-11 commands
config.status: executing default-12 commands
config.status: executing default-13 commands
=== configuring in test/mpi (/tmp/ajandaga/mpich2-1.2.1p1/test/mpi)
configure: running /bin/bash /home/ajandaga/libraries/mpich2-1.2.1p1/test/mpi/configure --disable-option-checking '--prefix=/home/ajandaga/mpich2-install'  --cache-file=/dev/null --srcdir=/home/ajandaga/libraries/mpich2-1.2.1p1/test/mpi
RUNNING CONFIGURE FOR MPI TESTS
checking for memory.h... (cached) yes
checking for pthread_create... no
checking for pthread_yield... no
checking for pthread_barrier_init... no
checking for pthread_barrier_wait... no
Configuring tests for MPICH2
checking for Fortran libraries needed for getarg... none needed
checking whether Fortran has pointer declaration... yes
checking whether Fortran 90 has Cray-style pointer declaration... yes
checking whether MPI_2DOUBLE_COMPLEX is available... yes
checking for C integer type of address size... int
config.status: creating maint/testmerge
config.status: creating runtests
config.status: creating basic/Makefile
config.status: creating attr/Makefile
config.status: creating coll/Makefile
config.status: creating comm/Makefile
config.status: creating datatype/Makefile
config.status: creating errhan/Makefile
config.status: creating group/Makefile
config.status: creating info/Makefile
config.status: creating init/Makefile
config.status: creating pt2pt/Makefile
config.status: creating rma/Makefile
config.status: creating spawn/Makefile
config.status: creating topo/Makefile
config.status: creating io/Makefile
config.status: creating f77/Makefile
config.status: creating f77/attr/Makefile
config.status: creating f77/attr/attraints.h
config.status: creating f77/pt2pt/attr1aints.h
config.status: creating f77/ext/add1size.h
config.status: creating f77/datatype/Makefile
config.status: creating f77/datatype/typeaints.h
config.status: creating f77/util/Makefile
config.status: creating f77/coll/Makefile
config.status: creating f77/comm/Makefile
config.status: creating f77/topo/Makefile
config.status: creating f77/init/Makefile
config.status: creating f77/rma/addsize.h
config.status: creating f77/pt2pt/Makefile
config.status: creating f77/info/Makefile
config.status: creating f77/spawn/Makefile
config.status: creating f77/spawn/type1aint.h
config.status: creating f77/rma/Makefile
config.status: creating f77/ext/Makefile
config.status: creating f77/ext/testlist
config.status: creating f77/io/Makefile
config.status: creating f77/io/iooffset.h
config.status: creating f77/io/iodisp.h
config.status: creating f77/io/ioaint.h
config.status: creating f90/Makefile
config.status: creating f90/attr/Makefile
config.status: creating f90/datatype/Makefile
config.status: creating f90/f90types/Makefile
config.status: creating f90/util/Makefile
config.status: creating f90/coll/Makefile
config.status: creating f90/comm/Makefile
config.status: creating f90/topo/Makefile
config.status: creating f90/init/Makefile
config.status: creating f90/pt2pt/Makefile
config.status: creating f90/rma/Makefile
config.status: creating f90/info/Makefile
config.status: creating f90/spawn/Makefile
config.status: creating f90/timer/Makefile
config.status: creating f90/ext/Makefile
config.status: creating f90/ext/testlist
config.status: creating f90/io/Makefile
config.status: creating f90/misc/Makefile
config.status: creating cxx/Makefile
config.status: creating cxx/util/Makefile
config.status: creating cxx/attr/Makefile
config.status: creating cxx/pt2pt/Makefile
config.status: creating cxx/comm/Makefile
config.status: creating cxx/coll/Makefile
config.status: creating cxx/info/Makefile
config.status: creating cxx/datatype/Makefile
config.status: creating cxx/io/Makefile
config.status: creating cxx/init/Makefile
config.status: creating cxx/rma/Makefile
config.status: creating cxx/spawn/Makefile
config.status: creating threads/Makefile
config.status: creating threads/pt2pt/Makefile
config.status: creating threads/util/Makefile
config.status: creating threads/comm/Makefile
config.status: creating threads/init/Makefile
config.status: creating threads/spawn/Makefile
config.status: creating errors/Makefile
config.status: creating errors/attr/Makefile
config.status: creating errors/basic/Makefile
config.status: creating errors/coll/Makefile
config.status: creating errors/comm/Makefile
config.status: creating errors/faults/Makefile
config.status: creating errors/group/Makefile
config.status: creating errors/pt2pt/Makefile
config.status: creating errors/rma/Makefile
config.status: creating errors/spawn/Makefile
config.status: creating errors/topo/Makefile
config.status: creating errors/io/Makefile
config.status: creating errors/cxx/Makefile
config.status: creating errors/cxx/errhan/Makefile
config.status: creating errors/cxx/io/Makefile
config.status: creating errors/f77/Makefile
config.status: creating errors/f90/Makefile
config.status: creating manual/Makefile
config.status: creating manual/manyconnect
config.status: creating perf/Makefile
config.status: creating testlist
config.status: creating cxx/testlist
config.status: creating f77/testlist
config.status: creating f90/testlist
config.status: creating threads/testlist
config.status: creating errors/testlist
config.status: creating errors/cxx/testlist
config.status: creating include/mpitestconf.h
Configuration completed.
Beginning make
Using variables CC='gcc' CFLAGS=' -O2' LDFLAGS='' AR='ar' FC='ifort' F90='ifort' FFLAGS=' -O2' F90FLAGS=' -O2' CXX='c++' CPPFLAGS=' -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src -I/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS  -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/ch3/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/common/datatype -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/common/datatype -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/common/locks -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/common/locks -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/common/locks -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpid/common/locks -I/tmp/ajandaga/mpich2-1.2.1p1/src/util/wrappers -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/util/wrappers'
make all-local
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1»
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1»
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa»
Making all in src
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src»
make  all-am
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src»
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src»
Making all in test
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/test»
make[2]: No se hace nada para «all».
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/test»
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa»
make[2]: No se hace nada para «all-am».
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa»
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa»
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src»
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/common»
make[4]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/common/locks»
make[4]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/common/locks»
make[4]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/common/datatype»
make[5]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/common/datatype/dataloop»
make[5]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/common/datatype/dataloop»
make all-local
make[5]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/common/datatype»
make[5]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/common/datatype»
make[4]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/common/datatype»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/common»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3»
make[4]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels»
make[5]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis»
make[6]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis»
make[7]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/src»
  CC              mpid_nem_net_array.c
  AR cr ../../../../../../../lib/libmpich.a mpid_nem_net_array.o
  RANLIB          libmpich.a
date > .libstamp0
make[7]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/src»
make[7]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod»
make[8]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp»
make[8]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp»
make[7]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod»
make[7]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils»
make[8]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor»
make[8]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor»
make[8]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements»
make[8]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements»
make[7]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils»
make[6]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis»
make[6]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/src»
make[6]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/src»
make[5]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis»
make[4]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/channels»
make[4]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/src»
make[4]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/src»
make[4]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/util»
make[4]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3/util»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid/ch3»
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpid»
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/attr»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/attr»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/coll»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/coll»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/comm»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/comm»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/datatype»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/datatype»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/errhan»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/errhan»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/group»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/group»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/init»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/init»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/misc»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/misc»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/pt2pt»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/pt2pt»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/rma»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/rma»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/spawn»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/spawn»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/timer»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/timer»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/topo»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/topo»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio»
make mpiolib
make[4]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio»
compiling ROMIO in directory mpi-io
make[5]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio/mpi-io»
make[5]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio/mpi-io»
compiling ROMIO in directory adio/common
make[5]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio/adio/common»
make[5]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio/adio/common»
compiling ROMIO in directory mpi-io/glue/mpich2
make[5]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio/mpi-io/glue/mpich2»
make[5]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio/mpi-io/glue/mpich2»
compiling ROMIO in directory adio/ad_testfs
make[5]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio/adio/ad_testfs»
make[5]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio/adio/ad_testfs»
compiling ROMIO in directory adio/ad_ufs
make[5]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio/adio/ad_ufs»
make[5]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio/adio/ad_ufs»
compiling ROMIO in directory adio/ad_nfs
make[5]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio/adio/ad_nfs»
make[5]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio/adio/ad_nfs»
make[4]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi/romio»
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpi»
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/mem»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/mem»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/info»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/info»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/msgs»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/msgs»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/instrm»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/instrm»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/thread»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/thread»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/dbg»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/dbg»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/param»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/param»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/osserv»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/osserv»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/procmap»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/procmap»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/other»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util/other»
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/util»
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/nameserv»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/nameserv/mpd»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/nameserv/mpd»
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/nameserv»
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/f77»
  FC              setbotf.f
  AR cr ../../../lib/libmpich.a setbotf.o
  RANLIB          libmpich.a
date > .libstamp2
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/f77»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/f90»
rm -f mpifnoext.h
sed -e 's/^C/\!/g' -e '/EXTERNAL/d' \
                -e '/REAL\*8/d' \
		-e '/DOUBLE PRECISION/d' \
		-e '/MPI_WTICK/d' ../f77/mpif.h > mpifnoext.h
ifort -O2 -I. -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/binding/f90/mpi_constants.f90
ifort -O2 -I. -c mpi_sizeofs.f90
ifort -O2 -I. -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/binding/f90/mpi_base.f90
ifort -O2 -I. -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/binding/f90/mpi.f90
  AR cr libmpichf90.a mpi.o mpi_constants.o mpi_sizeofs.o mpi_base.o
  RANLIB          libmpichf90.a
make all-postamble
make[4]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/f90»
if [ -s libmpichf90.a ] ; then \
	   cp -p libmpichf90.a ../../../lib ; fi
if [ -s libmpichf90.la ] ; then \
	   cp -p libmpichf90.la ../../../lib ; fi
make[4]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/f90»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/f90»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/cxx»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/cxx»
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding»
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/env»
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/env»
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/packaging»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/packaging/pkgconfig»
make[3]: No se hace nada para «all».
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/packaging/pkgconfig»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/packaging/envmods»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/packaging/envmods»
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/packaging»
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2»
make --no-print-directory  build_lib_bin
**** Making src/misc ....
make --no-print-directory  mpe_debug_objs
make --no-print-directory  /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_nompi.a
gcc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/../../include -O2 -DMPI_LINUX  -DMPE_NOMPI -o mpehname.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/src/mpehname.c
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_nompi.a mpehname.no
ranlib /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_nompi.a
make --no-print-directory  /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe.a
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o decomp.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/src/decomp.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o mpe_seq.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/src/mpe_seq.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o dbxerr.po -c dbxerr.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o getgrank.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/src/getgrank.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o examine.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/src/examine.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o privtags.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/src/privtags.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o mpehname.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/src/mpehname.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o mpe_io.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/src/mpe_io.c
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe.a decomp.po mpe_seq.po dbxerr.po getgrank.po examine.po privtags.po mpehname.po mpe_io.po
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o decompf.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/src/decompf.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o mpe_seqf.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/src/mpe_seqf.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/../../include -DMPI_LINUX  -o getgrankf.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/misc/src/getgrankf.c
ranlib /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe.a
**** Making src/callstack ....
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/../../include   -o iterator.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/src/iterator.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/../../include   -o fancyprint.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/src/fancyprint.c
gcc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/../../include -O2  -o iterator.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/src/iterator.c
/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/src/iterator.c: In function ?MPE_CallStack_iteratorInit?:
/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/src/iterator.c:40: warning: ignoring return value of ?pipe?, declared with attribute warn_unused_result
gcc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/../../include -O2  -o fancyprint.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/src/fancyprint.c
/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/src/fancyprint.c: In function ?MPE_CallStack_fancyprint?:
/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/src/fancyprint.c:68: warning: ignoring return value of ?write?, declared with attribute warn_unused_result
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_nompi.a iterator.no fancyprint.no
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe.a iterator.po fancyprint.po
make --no-print-directory  /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/bin/check_callstack
gcc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/../../include -O2  -o check_callstack.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/callstack/src/check_callstack.c
cp -f check_callstack.no mpe2tmp.o
gcc -Wl,--export-dynamic -O2  -o /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/bin/check_callstack mpe2tmp.o \
	                         -L/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib -lmpe_nompi
**** Making src/logging ....
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o mpi_null.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/mpi_null.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_util.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_util.c
/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_util.c: In function ?CLOG_Util_abort?:
/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_util.c:58: warning: ignoring return value of ?write?, declared with attribute warn_unused_result
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_timer.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_timer.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_uuid.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_uuid.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_commset.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_commset.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_preamble.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_preamble.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_record.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_record.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_sync.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_sync.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_block.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_block.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_buffer.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_buffer.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_merger.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_merger.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_cache.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_cache.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_joiner.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_joiner.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o mpe_log_thread.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/mpe_log_thread.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o mpe_log.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/mpe_log.c
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o mpe_log_null.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/mpe_log_null.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o mpe_log_null.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/mpe_log_null.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o clog_util.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_util.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o clog_timer.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_timer.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o clog_uuid.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_uuid.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o clog_commset.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_commset.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o clog_preamble.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_preamble.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o clog_record.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_record.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o clog_sync.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_sync.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o clog_block.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_block.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o clog_buffer.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_buffer.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o clog_merger.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_merger.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o clog_cache.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_cache.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o clog_joiner.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_joiner.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o clog.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o mpe_log_thread.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/mpe_log_thread.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o mpe_log.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/mpe_log.c
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_nompi.a mpi_null.no clog_util.no clog_timer.no clog_uuid.no clog_commset.no clog_preamble.no clog_record.no clog_sync.no clog_block.no clog_buffer.no clog_merger.no clog_cache.no clog_joiner.no clog.no mpe_log_thread.no mpe_log.no
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o mpe_logf.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/mpe_logf.c
make --no-print-directory  /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_nompi_null.a
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_nompi_null.a mpi_null.no mpe_log_null.no
make[8]: «mpe_logf.no» está actualizado.
ranlib /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_nompi_null.a
make --no-print-directory  /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_null.a
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_null.a mpe_log_null.po
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include   -o mpe_logf.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/mpe_logf.c
ranlib /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_null.a
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe.a clog_util.po clog_timer.po clog_uuid.po clog_commset.po clog_preamble.po clog_record.po clog_sync.po clog_block.po clog_buffer.po clog_merger.po clog_cache.po clog_joiner.po clog.po mpe_log_thread.po mpe_log.po
make[8]: «mpe_logf.po» está actualizado.
make --no-print-directory  /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/bin/clog2_print /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/bin/clog2_join /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/bin/clog2_repair
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_print.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_print.c
cp -f clog_print.no mpe2tmp1.o
gcc  -O2  -o /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/bin/clog2_print mpe2tmp1.o \
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_join.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_join.c
cp -f clog_join.no mpe2tmp2.o
gcc  -O2  -o /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/bin/clog2_join mpe2tmp2.o \
gcc -I.. -I../../.. -I../include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/../../include -O2  -DCLOG_NOMPI -o clog_repair.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/logging/src/clog_repair.c
cp -f clog_repair.no mpe2tmp3.o
gcc  -O2  -o /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/bin/clog2_repair mpe2tmp3.o \
**** Making src/wrappers ....
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/src/log_mpi_util.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/src/log_mpi_core.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/src/trace_mpi_core.c
make --no-print-directory  /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/liblmpe.a
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/liblmpe.a log_mpi_util.o log_mpi_core.o
ranlib /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/liblmpe.a
make --no-print-directory  /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libtmpe.a
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libtmpe.a trace_mpi_core.o
ranlib /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libtmpe.a
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpif77   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/src/mpi_f2c_consts.f
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/src/mpe_proff.c
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_f2cmpi.a mpi_f2c_consts.o log_mpi_util.o mpe_proff.o
ranlib /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_f2cmpi.a
make --no-print-directory  /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/mpe_prof.o
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/wrappers/src/mpe_prof.c
make --no-print-directory  linktest_all
make --no-print-directory  linktest_C
make --no-print-directory  linktest_F77
**** Making src/graphics ....
gcc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o mpe_graphics.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/mpe_graphics.c
/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/mpe_graphics.c: In function ?MPE_Update?:
/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/mpe_graphics.c:755: warning: ignoring return value of ?system?, declared with attribute warn_unused_result
gcc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o xcolor.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xcolor.c
gcc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o xframe.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xframe.c
gcc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o xinit.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xinit.c
/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xinit.c: In function ?XBCaptureWindowToFile?:
/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xinit.c:642: warning: ignoring return value of ?system?, declared with attribute warn_unused_result
gcc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o xwmap.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xwmap.c
gcc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o xmouse.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xmouse.c
gcc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include  -O2  -DMPE_NOMPI -o xkey.no -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xkey.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include    -o mpe_graphics.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/mpe_graphics.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include    -o xcolor.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xcolor.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include    -o xframe.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xframe.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include    -o xinit.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xinit.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include    -o xwmap.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xwmap.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include    -o xmouse.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xmouse.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include    -o xkey.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xkey.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include    -o visual_mess.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/visual_mess.c
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_nompi.a mpe_graphics.no xcolor.no xframe.no xinit.no xwmap.no xmouse.no xkey.no
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe.a mpe_graphics.po xcolor.po xframe.po xinit.po xwmap.po xmouse.po xkey.po
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include    -o mpe_graphicsf.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/mpe_graphicsf.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/../../include    -o xmousef.po -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/graphics/src/xmousef.c
make --no-print-directory  /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libampe.a
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libampe.a visual_mess.po
ranlib /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libampe.a
**** Making src/collchk ....
make --no-print-directory  /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_collchk.a
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/begin.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/err_han.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/is_init.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/check_buff.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/check_dims.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/check_graph.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/check_size.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/same_amode.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/same_call.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/same_dtype.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/same_high_low.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/same_int.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/same_local_leader.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/same_op.c
/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/same_op.c: In function ?CollChk_same_op?:
/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/same_op.c:54: warning: format not a string literal and no format arguments
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/same_root.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/same_tag.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/same_datarep.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/same_whence.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/allgather.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/allgatherv.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/allreduce.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/alltoall.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/alltoallv.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/barrier.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/bcast.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/cart_create.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/cart_map.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/gather.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/gatherv.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/graph_create.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/graph_map.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/init.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/intercomm_create.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/intercomm_merge.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/reduce.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/reduce_scatter.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/scan.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/scatter.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/scatterv.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/finalize.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/exscan.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/alltoallw.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_open.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_preallocate.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_read_all_begin.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_read_all.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_read_all_end.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_read_at_all_begin.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_read_at_all.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_read_at_all_end.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_read_ordered_begin.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_read_ordered.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_read_ordered_end.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_seek_shared.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_set_atomicity.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_set_size.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_set_view.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_write_all_begin.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_write_all.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_write_all_end.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_write_at_all_begin.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_write_at_all.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_write_at_all_end.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_write_ordered_begin.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_write_ordered.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/file_write_ordered_end.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/add_fh.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/get_fh.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/win_create.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/win_fence.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/add_win.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/get_win.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/comm_accept.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/comm_connect.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/comm_create.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/comm_disconnect.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/comm_dup.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/comm_spawn.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/comm_spawn_multiple.c
/tmp/ajandaga/mpich2-1.2.1p1/bin/mpicc -I.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/include -I/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/include -I../../.. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/../../include   -c /home/ajandaga/libraries/mpich2-1.2.1p1/src/mpe2/src/collchk/src/comm_split.c
ar cr /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_collchk.a *.o
ranlib /tmp/ajandaga/mpich2-1.2.1p1/src/mpe2/lib/libmpe_collchk.a
**** Making src/slog2sdk ....
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2»
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pmi»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pmi/simple»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pmi/simple»
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pmi»
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/mpd»
gcc -I. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/mpd -O2  -c  /home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/mpd/mpdroot.c
/home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/mpd/mpdroot.c: In function ?main?:
/home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/mpd/mpdroot.c:75: warning: ignoring return value of ?write?, declared with attribute warn_unused_result
gcc -O2   -o mpdroot mpdroot.o -lpthread   -lrt
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/mpd»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/hydra»
Making all in ../../mpl
make[4]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpl»
make[4]: No se hace nada para «all».
make[4]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpl»
Making all in .
make[4]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/hydra»
  CC     rmki_init.o
  CC     rmki_query_node_list.o
  CC     rmku_query_node_list.o
  CC     rmk_dummy_init.o
  CC     rmk_pbs_init.o
  CC     rmk_pbs_query_node_list.o
  CC     cssi_init.o
  CC     cssi_finalize.o
  CC     cssi_query_string.o
  CC     cssu_tmp.o
  CC     bsci_init.o
  CC     bsci_finalize.o
  CC     bsci_launch.o
  CC     bsci_query_node_list.o
  CC     bsci_query_proxy_id.o
  CC     bsci_usize.o
  CC     bsci_wait.o
  CC     ssh_init.o
  CC     ssh_launch.o
  CC     rsh_init.o
  CC     rsh_launch.o
  CC     fork_init.o
  CC     fork_launch.o
  CC     slurm_init.o
  CC     slurm_launch.o
  CC     slurm_query_node_list.o
  CC     slurm_query_proxy_id.o
  AR     libhydra.a
  CC     pmi_handle_v1.o
  CC     pmi_handle_v2.o
  CC     pmi_serv_cb.o
  CC     pmi_serv_finalize.o
  CC     pmi_serv_launch.o
  AR     libpm.a
  CC     pmi_proxy_utils.o
  CCLD   pmi_proxy
  CC     mpiexec-mpiexec.o
  CCLD   mpiexec
make[4]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/hydra»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/hydra»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/gforker»
cd ../util && make
make[4]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/util»
make[4]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/util»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/gforker»
make all-postamble
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm»
if [ -n "mpd" -a -d "mpd" ] ; then \
	build_prefix=`cd ../.. && pwd` && cd mpd && \
	make prefix=$build_prefix exec_prefix=$build_prefix bindir=$build_prefix/bin mpich2-build-install ; \
	fi
make[4]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/mpd»
/usr/bin/install -c -m 644 /home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/mpd/mpdroot.c mpich2-mpdroot.c
gcc -I. -I/home/ajandaga/libraries/mpich2-1.2.1p1/src/pm/mpd -O2  -c mpich2-mpdroot.c
mpich2-mpdroot.c: In function ?main?:
mpich2-mpdroot.c:75: warning: ignoring return value of ?write?, declared with attribute warn_unused_result
rm -f mpich2-mpdroot.c
gcc -O2   -o mpich2-mpdroot mpich2-mpdroot.o -lpthread   -lrt
rm -f mpich2-mpdroot.o
copying python files/links into  /tmp/ajandaga/mpich2-1.2.1p1/bin
make[4]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/mpd»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm»
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm»
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src»
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/examples»
../bin/mpicc   -o cpi cpi.o  -lm
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/examples»
make all-postamble
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1»
Make completed
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1»
if [ ! -d /home/ajandaga/mpich2-install ] ; then mkdir -p /home/ajandaga/mpich2-install ; fi
if [ ! -d /home/ajandaga/mpich2-install/share ] ; then mkdir -p /home/ajandaga/mpich2-install/share ; fi
if [ ! -d /home/ajandaga/mpich2-install/share/doc/ ] ; then mkdir -p /home/ajandaga/mpich2-install/share/doc/ ; fi
if [ ! -d /home/ajandaga/mpich2-install/share/man ] ; then mkdir -p /home/ajandaga/mpich2-install/share/man ; fi
if [ ! -d /home/ajandaga/mpich2-install/include ] ; then mkdir -p /home/ajandaga/mpich2-install/include ; fi
if [ ! -d /home/ajandaga/mpich2-install/lib ] ; then mkdir -p /home/ajandaga/mpich2-install/lib ; fi
make install-local
if [ "no" = "yes" ] ; then \
	    /usr/bin/install -c -m 644 src/mpi/debugger/libtvmpich2.so \
			/home/ajandaga/mpich2-install/lib/libtvmpich2.so ; fi
if [ -n " hydra gforker" ] ; then \
	    for pm in  hydra gforker /dev/null ; do \
		if [ -d src/pm/$pm ] ; then \
		     (cd src/pm/$pm && make install-alt ) ; fi ; \
	    done ; \
	fi
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/hydra»
/usr/bin/install -c  mpiexec /home/ajandaga/mpich2-install/bin/mpiexec.hydra
/usr/bin/install -c  pmi_proxy /home/ajandaga/mpich2-install/bin/
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/hydra»
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/gforker»
cd ../util && make
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/util»
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/util»
/usr/bin/install -c  mpiexec /home/ajandaga/mpich2-install/bin/mpiexec.gforker
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/gforker»
/usr/bin/install -c -m 644 src/include/mpi.h /home/ajandaga/mpich2-install/include/mpi.h
/usr/bin/install -c -m 644 lib/libmpich.a /home/ajandaga/mpich2-install/lib/libmpich.a
/usr/bin/install -c -m 644 index.htm /home/ajandaga/mpich2-install/share/doc//index.htm
/usr/bin/install -c -m 644 index.htm /home/ajandaga/mpich2-install/share/doc//www1/index.htm
/usr/bin/install -c -m 644 mpicc.html /home/ajandaga/mpich2-install/share/doc//www1/mpicc.html
/usr/bin/install -c -m 644 mpicxx.html /home/ajandaga/mpich2-install/share/doc//www1/mpicxx.html
/usr/bin/install -c -m 644 mpiexec.html /home/ajandaga/mpich2-install/share/doc//www1/mpiexec.html
/usr/bin/install -c -m 644 mpif77.html /home/ajandaga/mpich2-install/share/doc//www1/mpif77.html
/usr/bin/install -c -m 644 mpif90.html /home/ajandaga/mpich2-install/share/doc//www1/mpif90.html
/usr/bin/install -c -m 644 MPI.html /home/ajandaga/mpich2-install/share/doc//www1/MPI.html
/usr/bin/install -c -m 644 index.htm /home/ajandaga/mpich2-install/share/doc//www3/index.htm
/usr/bin/install -c -m 644 MPI_Abort.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Abort.html
/usr/bin/install -c -m 644 MPI_Accumulate.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Accumulate.html
/usr/bin/install -c -m 644 MPI_Add_error_class.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Add_error_class.html
/usr/bin/install -c -m 644 MPI_Add_error_code.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Add_error_code.html
/usr/bin/install -c -m 644 MPI_Add_error_string.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Add_error_string.html
/usr/bin/install -c -m 644 MPI_Address.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Address.html
/usr/bin/install -c -m 644 MPI_Allgather.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Allgather.html
/usr/bin/install -c -m 644 MPI_Allgatherv.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Allgatherv.html
/usr/bin/install -c -m 644 MPI_Alloc_mem.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Alloc_mem.html
/usr/bin/install -c -m 644 MPI_Allreduce.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Allreduce.html
/usr/bin/install -c -m 644 MPI_Alltoall.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Alltoall.html
/usr/bin/install -c -m 644 MPI_Alltoallv.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Alltoallv.html
/usr/bin/install -c -m 644 MPI_Alltoallw.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Alltoallw.html
/usr/bin/install -c -m 644 MPI_Attr_delete.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Attr_delete.html
/usr/bin/install -c -m 644 MPI_Attr_get.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Attr_get.html
/usr/bin/install -c -m 644 MPI_Attr_put.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Attr_put.html
/usr/bin/install -c -m 644 MPI_Barrier.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Barrier.html
/usr/bin/install -c -m 644 MPI_Bcast.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Bcast.html
/usr/bin/install -c -m 644 MPI_Bsend.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Bsend.html
/usr/bin/install -c -m 644 MPI_Bsend_init.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Bsend_init.html
/usr/bin/install -c -m 644 MPI_Buffer_attach.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Buffer_attach.html
/usr/bin/install -c -m 644 MPI_Buffer_detach.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Buffer_detach.html
/usr/bin/install -c -m 644 MPI_Cancel.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Cancel.html
/usr/bin/install -c -m 644 MPI_Cart_coords.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Cart_coords.html
/usr/bin/install -c -m 644 MPI_Cart_create.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Cart_create.html
/usr/bin/install -c -m 644 MPI_Cartdim_get.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Cartdim_get.html
/usr/bin/install -c -m 644 MPI_Cart_get.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Cart_get.html
/usr/bin/install -c -m 644 MPI_Cart_map.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Cart_map.html
/usr/bin/install -c -m 644 MPI_Cart_rank.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Cart_rank.html
/usr/bin/install -c -m 644 MPI_Cart_shift.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Cart_shift.html
/usr/bin/install -c -m 644 MPI_Cart_sub.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Cart_sub.html
/usr/bin/install -c -m 644 MPI_Close_port.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Close_port.html
/usr/bin/install -c -m 644 MPI_Comm_accept.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_accept.html
/usr/bin/install -c -m 644 MPI_Comm_call_errhandler.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_call_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_compare.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_compare.html
/usr/bin/install -c -m 644 MPI_Comm_connect.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_connect.html
/usr/bin/install -c -m 644 MPI_Comm_create_errhandler.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_create_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_create.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_create.html
/usr/bin/install -c -m 644 MPI_Comm_create_keyval.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_create_keyval.html
/usr/bin/install -c -m 644 MPI_Comm_delete_attr.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_delete_attr.html
/usr/bin/install -c -m 644 MPI_Comm_disconnect.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_disconnect.html
/usr/bin/install -c -m 644 MPI_Comm_dup.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_dup.html
/usr/bin/install -c -m 644 MPI_Comm_free.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_free.html
/usr/bin/install -c -m 644 MPI_Comm_free_keyval.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_free_keyval.html
/usr/bin/install -c -m 644 MPI_Comm_get_attr.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_get_attr.html
/usr/bin/install -c -m 644 MPI_Comm_get_errhandler.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_get_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_get_name.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_get_name.html
/usr/bin/install -c -m 644 MPI_Comm_get_parent.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_get_parent.html
/usr/bin/install -c -m 644 MPI_Comm_group.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_group.html
/usr/bin/install -c -m 644 MPI_Comm_join.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_join.html
/usr/bin/install -c -m 644 MPI_Comm_rank.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_rank.html
/usr/bin/install -c -m 644 MPI_Comm_remote_group.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_remote_group.html
/usr/bin/install -c -m 644 MPI_Comm_remote_size.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_remote_size.html
/usr/bin/install -c -m 644 MPI_Comm_set_attr.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_set_attr.html
/usr/bin/install -c -m 644 MPI_Comm_set_errhandler.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_set_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_set_name.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_set_name.html
/usr/bin/install -c -m 644 MPI_Comm_size.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_size.html
/usr/bin/install -c -m 644 MPI_Comm_spawn.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_spawn.html
/usr/bin/install -c -m 644 MPI_Comm_spawn_multiple.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_spawn_multiple.html
/usr/bin/install -c -m 644 MPI_Comm_split.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_split.html
/usr/bin/install -c -m 644 MPI_Comm_test_inter.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Comm_test_inter.html
/usr/bin/install -c -m 644 MPI_Dims_create.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Dims_create.html
/usr/bin/install -c -m 644 MPI_Dist_graph_create_adjacent.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Dist_graph_create_adjacent.html
/usr/bin/install -c -m 644 MPI_Dist_graph_create.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Dist_graph_create.html
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors_count.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Dist_graph_neighbors_count.html
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Dist_graph_neighbors.html
/usr/bin/install -c -m 644 MPI_Errhandler_create.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Errhandler_create.html
/usr/bin/install -c -m 644 MPI_Errhandler_free.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Errhandler_free.html
/usr/bin/install -c -m 644 MPI_Errhandler_get.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Errhandler_get.html
/usr/bin/install -c -m 644 MPI_Errhandler_set.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Errhandler_set.html
/usr/bin/install -c -m 644 MPI_Error_class.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Error_class.html
/usr/bin/install -c -m 644 MPI_Error_string.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Error_string.html
/usr/bin/install -c -m 644 MPI_Exscan.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Exscan.html
/usr/bin/install -c -m 644 MPI_File_c2f.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_c2f.html
/usr/bin/install -c -m 644 MPI_File_call_errhandler.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_call_errhandler.html
/usr/bin/install -c -m 644 MPI_File_close.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_close.html
/usr/bin/install -c -m 644 MPI_File_create_errhandler.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_create_errhandler.html
/usr/bin/install -c -m 644 MPI_File_delete.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_delete.html
/usr/bin/install -c -m 644 MPI_File_f2c.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_f2c.html
/usr/bin/install -c -m 644 MPI_File_get_amode.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_get_amode.html
/usr/bin/install -c -m 644 MPI_File_get_atomicity.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_get_atomicity.html
/usr/bin/install -c -m 644 MPI_File_get_byte_offset.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_get_byte_offset.html
/usr/bin/install -c -m 644 MPI_File_get_errhandler.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_get_errhandler.html
/usr/bin/install -c -m 644 MPI_File_get_group.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_get_group.html
/usr/bin/install -c -m 644 MPI_File_get_info.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_get_info.html
/usr/bin/install -c -m 644 MPI_File_get_position.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_get_position.html
/usr/bin/install -c -m 644 MPI_File_get_position_shared.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_get_position_shared.html
/usr/bin/install -c -m 644 MPI_File_get_size.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_get_size.html
/usr/bin/install -c -m 644 MPI_File_get_type_extent.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_get_type_extent.html
/usr/bin/install -c -m 644 MPI_File_get_view.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_get_view.html
/usr/bin/install -c -m 644 MPI_File_iread_at.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_iread_at.html
/usr/bin/install -c -m 644 MPI_File_iread.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_iread.html
/usr/bin/install -c -m 644 MPI_File_iread_shared.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_iread_shared.html
/usr/bin/install -c -m 644 MPI_File_iwrite_at.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_iwrite_at.html
/usr/bin/install -c -m 644 MPI_File_iwrite.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_iwrite.html
/usr/bin/install -c -m 644 MPI_File_iwrite_shared.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_iwrite_shared.html
/usr/bin/install -c -m 644 MPI_File_open.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_open.html
/usr/bin/install -c -m 644 MPI_File_preallocate.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_preallocate.html
/usr/bin/install -c -m 644 MPI_File_read_all_begin.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_read_all_begin.html
/usr/bin/install -c -m 644 MPI_File_read_all_end.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_read_all_end.html
/usr/bin/install -c -m 644 MPI_File_read_all.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_read_all.html
/usr/bin/install -c -m 644 MPI_File_read_at_all_begin.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_read_at_all_begin.html
/usr/bin/install -c -m 644 MPI_File_read_at_all_end.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_read_at_all_end.html
/usr/bin/install -c -m 644 MPI_File_read_at_all.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_read_at_all.html
/usr/bin/install -c -m 644 MPI_File_read_at.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_read_at.html
/usr/bin/install -c -m 644 MPI_File_read.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_read.html
/usr/bin/install -c -m 644 MPI_File_read_ordered_begin.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_read_ordered_begin.html
/usr/bin/install -c -m 644 MPI_File_read_ordered_end.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_read_ordered_end.html
/usr/bin/install -c -m 644 MPI_File_read_ordered.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_read_ordered.html
/usr/bin/install -c -m 644 MPI_File_read_shared.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_read_shared.html
/usr/bin/install -c -m 644 MPI_File_seek.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_seek.html
/usr/bin/install -c -m 644 MPI_File_seek_shared.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_seek_shared.html
/usr/bin/install -c -m 644 MPI_File_set_atomicity.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_set_atomicity.html
/usr/bin/install -c -m 644 MPI_File_set_errhandler.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_set_errhandler.html
/usr/bin/install -c -m 644 MPI_File_set_info.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_set_info.html
/usr/bin/install -c -m 644 MPI_File_set_size.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_set_size.html
/usr/bin/install -c -m 644 MPI_File_set_view.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_set_view.html
/usr/bin/install -c -m 644 MPI_File_sync.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_sync.html
/usr/bin/install -c -m 644 MPI_File_write_all_begin.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_write_all_begin.html
/usr/bin/install -c -m 644 MPI_File_write_all_end.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_write_all_end.html
/usr/bin/install -c -m 644 MPI_File_write_all.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_write_all.html
/usr/bin/install -c -m 644 MPI_File_write_at_all_begin.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_write_at_all_begin.html
/usr/bin/install -c -m 644 MPI_File_write_at_all_end.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_write_at_all_end.html
/usr/bin/install -c -m 644 MPI_File_write_at_all.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_write_at_all.html
/usr/bin/install -c -m 644 MPI_File_write_at.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_write_at.html
/usr/bin/install -c -m 644 MPI_File_write.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_write.html
/usr/bin/install -c -m 644 MPI_File_write_ordered_begin.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_write_ordered_begin.html
/usr/bin/install -c -m 644 MPI_File_write_ordered_end.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_write_ordered_end.html
/usr/bin/install -c -m 644 MPI_File_write_ordered.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_write_ordered.html
/usr/bin/install -c -m 644 MPI_File_write_shared.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_File_write_shared.html
/usr/bin/install -c -m 644 MPI_Finalized.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Finalized.html
/usr/bin/install -c -m 644 MPI_Finalize.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Finalize.html
/usr/bin/install -c -m 644 MPI_Free_mem.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Free_mem.html
/usr/bin/install -c -m 644 MPI_Gather.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Gather.html
/usr/bin/install -c -m 644 MPI_Gatherv.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Gatherv.html
/usr/bin/install -c -m 644 MPI_Get_address.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Get_address.html
/usr/bin/install -c -m 644 MPI_Get_count.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Get_count.html
/usr/bin/install -c -m 644 MPI_Get_elements.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Get_elements.html
/usr/bin/install -c -m 644 MPI_Get.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Get.html
/usr/bin/install -c -m 644 MPI_Get_processor_name.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Get_processor_name.html
/usr/bin/install -c -m 644 MPI_Get_version.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Get_version.html
/usr/bin/install -c -m 644 MPI_Graph_create.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Graph_create.html
/usr/bin/install -c -m 644 MPI_Graphdims_get.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Graphdims_get.html
/usr/bin/install -c -m 644 MPI_Graph_get.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Graph_get.html
/usr/bin/install -c -m 644 MPI_Graph_map.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Graph_map.html
/usr/bin/install -c -m 644 MPI_Graph_neighbors_count.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Graph_neighbors_count.html
/usr/bin/install -c -m 644 MPI_Graph_neighbors.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Graph_neighbors.html
/usr/bin/install -c -m 644 MPI_Grequest_complete.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Grequest_complete.html
/usr/bin/install -c -m 644 MPI_Grequest_start.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Grequest_start.html
/usr/bin/install -c -m 644 MPI_Group_compare.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Group_compare.html
/usr/bin/install -c -m 644 MPI_Group_difference.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Group_difference.html
/usr/bin/install -c -m 644 MPI_Group_excl.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Group_excl.html
/usr/bin/install -c -m 644 MPI_Group_free.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Group_free.html
/usr/bin/install -c -m 644 MPI_Group_incl.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Group_incl.html
/usr/bin/install -c -m 644 MPI_Group_intersection.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Group_intersection.html
/usr/bin/install -c -m 644 MPI_Group_range_excl.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Group_range_excl.html
/usr/bin/install -c -m 644 MPI_Group_range_incl.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Group_range_incl.html
/usr/bin/install -c -m 644 MPI_Group_rank.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Group_rank.html
/usr/bin/install -c -m 644 MPI_Group_size.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Group_size.html
/usr/bin/install -c -m 644 MPI_Group_translate_ranks.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Group_translate_ranks.html
/usr/bin/install -c -m 644 MPI_Group_union.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Group_union.html
/usr/bin/install -c -m 644 MPI_Ibsend.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Ibsend.html
/usr/bin/install -c -m 644 MPI_Info_create.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Info_create.html
/usr/bin/install -c -m 644 MPI_Info_delete.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Info_delete.html
/usr/bin/install -c -m 644 MPI_Info_dup.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Info_dup.html
/usr/bin/install -c -m 644 MPI_Info_free.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Info_free.html
/usr/bin/install -c -m 644 MPI_Info_get.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Info_get.html
/usr/bin/install -c -m 644 MPI_Info_get_nkeys.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Info_get_nkeys.html
/usr/bin/install -c -m 644 MPI_Info_get_nthkey.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Info_get_nthkey.html
/usr/bin/install -c -m 644 MPI_Info_get_valuelen.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Info_get_valuelen.html
/usr/bin/install -c -m 644 MPI_Info_set.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Info_set.html
/usr/bin/install -c -m 644 MPI_Init.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Init.html
/usr/bin/install -c -m 644 MPI_Initialized.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Initialized.html
/usr/bin/install -c -m 644 MPI_Init_thread.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Init_thread.html
/usr/bin/install -c -m 644 MPI_Intercomm_create.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Intercomm_create.html
/usr/bin/install -c -m 644 MPI_Intercomm_merge.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Intercomm_merge.html
/usr/bin/install -c -m 644 MPI_Iprobe.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Iprobe.html
/usr/bin/install -c -m 644 MPI_Irecv.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Irecv.html
/usr/bin/install -c -m 644 MPI_Irsend.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Irsend.html
/usr/bin/install -c -m 644 MPI_Isend.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Isend.html
/usr/bin/install -c -m 644 MPI_Issend.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Issend.html
/usr/bin/install -c -m 644 MPI_Is_thread_main.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Is_thread_main.html
/usr/bin/install -c -m 644 MPI_Keyval_create.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Keyval_create.html
/usr/bin/install -c -m 644 MPI_Keyval_free.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Keyval_free.html
/usr/bin/install -c -m 644 MPI_Lookup_name.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Lookup_name.html
/usr/bin/install -c -m 644 MPI_Op_commute.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Op_commute.html
/usr/bin/install -c -m 644 MPI_Op_create.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Op_create.html
/usr/bin/install -c -m 644 MPI_Open_port.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Open_port.html
/usr/bin/install -c -m 644 MPI_Op_free.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Op_free.html
/usr/bin/install -c -m 644 MPI_Pack_external.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Pack_external.html
/usr/bin/install -c -m 644 MPI_Pack_external_size.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Pack_external_size.html
/usr/bin/install -c -m 644 MPI_Pack.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Pack.html
/usr/bin/install -c -m 644 MPI_Pack_size.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Pack_size.html
/usr/bin/install -c -m 644 MPI_Pcontrol.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Pcontrol.html
/usr/bin/install -c -m 644 MPI_Probe.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Probe.html
/usr/bin/install -c -m 644 MPI_Publish_name.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Publish_name.html
/usr/bin/install -c -m 644 MPI_Put.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Put.html
/usr/bin/install -c -m 644 MPI_Query_thread.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Query_thread.html
/usr/bin/install -c -m 644 MPI_Recv.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Recv.html
/usr/bin/install -c -m 644 MPI_Recv_init.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Recv_init.html
/usr/bin/install -c -m 644 MPI_Reduce.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Reduce.html
/usr/bin/install -c -m 644 MPI_Reduce_local.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Reduce_local.html
/usr/bin/install -c -m 644 MPI_Reduce_scatter_block.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Reduce_scatter_block.html
/usr/bin/install -c -m 644 MPI_Reduce_scatter.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Reduce_scatter.html
/usr/bin/install -c -m 644 MPI_Register_datarep.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Register_datarep.html
/usr/bin/install -c -m 644 MPI_Request_free.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Request_free.html
/usr/bin/install -c -m 644 MPI_Request_get_status.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Request_get_status.html
/usr/bin/install -c -m 644 MPI_Rsend.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Rsend.html
/usr/bin/install -c -m 644 MPI_Rsend_init.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Rsend_init.html
/usr/bin/install -c -m 644 MPI_Scan.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Scan.html
/usr/bin/install -c -m 644 MPI_Scatter.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Scatter.html
/usr/bin/install -c -m 644 MPI_Scatterv.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Scatterv.html
/usr/bin/install -c -m 644 MPI_Send.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Send.html
/usr/bin/install -c -m 644 MPI_Send_init.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Send_init.html
/usr/bin/install -c -m 644 MPI_Sendrecv.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Sendrecv.html
/usr/bin/install -c -m 644 MPI_Sendrecv_replace.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Sendrecv_replace.html
/usr/bin/install -c -m 644 MPI_Ssend.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Ssend.html
/usr/bin/install -c -m 644 MPI_Ssend_init.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Ssend_init.html
/usr/bin/install -c -m 644 MPI_Startall.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Startall.html
/usr/bin/install -c -m 644 MPI_Start.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Start.html
/usr/bin/install -c -m 644 MPI_Status_set_cancelled.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Status_set_cancelled.html
/usr/bin/install -c -m 644 MPI_Status_set_elements.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Status_set_elements.html
/usr/bin/install -c -m 644 MPI_Testall.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Testall.html
/usr/bin/install -c -m 644 MPI_Testany.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Testany.html
/usr/bin/install -c -m 644 MPI_Test_cancelled.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Test_cancelled.html
/usr/bin/install -c -m 644 MPI_Test.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Test.html
/usr/bin/install -c -m 644 MPI_Testsome.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Testsome.html
/usr/bin/install -c -m 644 MPI_Topo_test.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Topo_test.html
/usr/bin/install -c -m 644 MPI_Type_commit.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_commit.html
/usr/bin/install -c -m 644 MPI_Type_contiguous.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_contiguous.html
/usr/bin/install -c -m 644 MPI_Type_create_darray.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_create_darray.html
/usr/bin/install -c -m 644 MPI_Type_create_hindexed.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_create_hindexed.html
/usr/bin/install -c -m 644 MPI_Type_create_hvector.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_create_hvector.html
/usr/bin/install -c -m 644 MPI_Type_create_indexed_block.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_create_indexed_block.html
/usr/bin/install -c -m 644 MPI_Type_create_keyval.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_create_keyval.html
/usr/bin/install -c -m 644 MPI_Type_create_resized.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_create_resized.html
/usr/bin/install -c -m 644 MPI_Type_create_struct.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_create_struct.html
/usr/bin/install -c -m 644 MPI_Type_create_subarray.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_create_subarray.html
/usr/bin/install -c -m 644 MPI_Type_delete_attr.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_delete_attr.html
/usr/bin/install -c -m 644 MPI_Type_dup.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_dup.html
/usr/bin/install -c -m 644 MPI_Type_extent.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_extent.html
/usr/bin/install -c -m 644 MPI_Type_free.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_free.html
/usr/bin/install -c -m 644 MPI_Type_free_keyval.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_free_keyval.html
/usr/bin/install -c -m 644 MPI_Type_get_attr.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_get_attr.html
/usr/bin/install -c -m 644 MPI_Type_get_contents.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_get_contents.html
/usr/bin/install -c -m 644 MPI_Type_get_envelope.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_get_envelope.html
/usr/bin/install -c -m 644 MPI_Type_get_extent.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_get_extent.html
/usr/bin/install -c -m 644 MPI_Type_get_name.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_get_name.html
/usr/bin/install -c -m 644 MPI_Type_get_true_extent.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_get_true_extent.html
/usr/bin/install -c -m 644 MPI_Type_hindexed.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_hindexed.html
/usr/bin/install -c -m 644 MPI_Type_hvector.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_hvector.html
/usr/bin/install -c -m 644 MPI_Type_indexed.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_indexed.html
/usr/bin/install -c -m 644 MPI_Type_lb.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_lb.html
/usr/bin/install -c -m 644 MPI_Type_match_size.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_match_size.html
/usr/bin/install -c -m 644 MPI_Type_set_attr.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_set_attr.html
/usr/bin/install -c -m 644 MPI_Type_set_name.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_set_name.html
/usr/bin/install -c -m 644 MPI_Type_size.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_size.html
/usr/bin/install -c -m 644 MPI_Type_struct.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_struct.html
/usr/bin/install -c -m 644 MPI_Type_ub.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_ub.html
/usr/bin/install -c -m 644 MPI_Type_vector.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Type_vector.html
/usr/bin/install -c -m 644 MPI_Unpack_external.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Unpack_external.html
/usr/bin/install -c -m 644 MPI_Unpack.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Unpack.html
/usr/bin/install -c -m 644 MPI_Unpublish_name.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Unpublish_name.html
/usr/bin/install -c -m 644 MPI_Waitall.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Waitall.html
/usr/bin/install -c -m 644 MPI_Waitany.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Waitany.html
/usr/bin/install -c -m 644 MPI_Wait.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Wait.html
/usr/bin/install -c -m 644 MPI_Waitsome.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Waitsome.html
/usr/bin/install -c -m 644 MPI_Win_call_errhandler.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_call_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_complete.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_complete.html
/usr/bin/install -c -m 644 MPI_Win_create_errhandler.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_create_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_create.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_create.html
/usr/bin/install -c -m 644 MPI_Win_create_keyval.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_create_keyval.html
/usr/bin/install -c -m 644 MPI_Win_delete_attr.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_delete_attr.html
/usr/bin/install -c -m 644 MPI_Win_fence.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_fence.html
/usr/bin/install -c -m 644 MPI_Win_free.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_free.html
/usr/bin/install -c -m 644 MPI_Win_free_keyval.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_free_keyval.html
/usr/bin/install -c -m 644 MPI_Win_get_attr.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_get_attr.html
/usr/bin/install -c -m 644 MPI_Win_get_errhandler.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_get_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_get_group.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_get_group.html
/usr/bin/install -c -m 644 MPI_Win_get_name.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_get_name.html
/usr/bin/install -c -m 644 MPI_Win_lock.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_lock.html
/usr/bin/install -c -m 644 MPI_Win_post.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_post.html
/usr/bin/install -c -m 644 MPI_Win_set_attr.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_set_attr.html
/usr/bin/install -c -m 644 MPI_Win_set_errhandler.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_set_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_set_name.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_set_name.html
/usr/bin/install -c -m 644 MPI_Win_start.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_start.html
/usr/bin/install -c -m 644 MPI_Win_test.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_test.html
/usr/bin/install -c -m 644 MPI_Win_unlock.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_unlock.html
/usr/bin/install -c -m 644 MPI_Win_wait.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Win_wait.html
/usr/bin/install -c -m 644 MPI_Wtick.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Wtick.html
/usr/bin/install -c -m 644 MPI_Wtime.html /home/ajandaga/mpich2-install/share/doc//www3/MPI_Wtime.html
/usr/bin/install -c -m 644 mpd.1 /home/ajandaga/mpich2-install/share/man/man1/mpd.1
/usr/bin/install -c -m 644 mpdallexit.1 /home/ajandaga/mpich2-install/share/man/man1/mpdallexit.1
/usr/bin/install -c -m 644 mpdboot.1 /home/ajandaga/mpich2-install/share/man/man1/mpdboot.1
/usr/bin/install -c -m 644 mpdcheck.1 /home/ajandaga/mpich2-install/share/man/man1/mpdcheck.1
/usr/bin/install -c -m 644 mpdchkpyver.1 /home/ajandaga/mpich2-install/share/man/man1/mpdchkpyver.1
/usr/bin/install -c -m 644 mpdcleanup.1 /home/ajandaga/mpich2-install/share/man/man1/mpdcleanup.1
/usr/bin/install -c -m 644 mpdexit.1 /home/ajandaga/mpich2-install/share/man/man1/mpdexit.1
/usr/bin/install -c -m 644 mpdgdbdrv.1 /home/ajandaga/mpich2-install/share/man/man1/mpdgdbdrv.1
/usr/bin/install -c -m 644 mpdhelp.1 /home/ajandaga/mpich2-install/share/man/man1/mpdhelp.1
/usr/bin/install -c -m 644 mpdkilljob.1 /home/ajandaga/mpich2-install/share/man/man1/mpdkilljob.1
/usr/bin/install -c -m 644 mpdlib.1 /home/ajandaga/mpich2-install/share/man/man1/mpdlib.1
/usr/bin/install -c -m 644 mpdlistjobs.1 /home/ajandaga/mpich2-install/share/man/man1/mpdlistjobs.1
/usr/bin/install -c -m 644 mpdman.1 /home/ajandaga/mpich2-install/share/man/man1/mpdman.1
/usr/bin/install -c -m 644 mpdringtest.1 /home/ajandaga/mpich2-install/share/man/man1/mpdringtest.1
/usr/bin/install -c -m 644 mpdsigjob.1 /home/ajandaga/mpich2-install/share/man/man1/mpdsigjob.1
/usr/bin/install -c -m 644 mpdtrace.1 /home/ajandaga/mpich2-install/share/man/man1/mpdtrace.1
/usr/bin/install -c -m 644 MPI.1 /home/ajandaga/mpich2-install/share/man/man1/MPI.1
/usr/bin/install -c -m 644 mpicc.1 /home/ajandaga/mpich2-install/share/man/man1/mpicc.1
/usr/bin/install -c -m 644 mpicxx.1 /home/ajandaga/mpich2-install/share/man/man1/mpicxx.1
/usr/bin/install -c -m 644 mpiexec.1 /home/ajandaga/mpich2-install/share/man/man1/mpiexec.1
/usr/bin/install -c -m 644 mpif77.1 /home/ajandaga/mpich2-install/share/man/man1/mpif77.1
/usr/bin/install -c -m 644 mpif90.1 /home/ajandaga/mpich2-install/share/man/man1/mpif90.1
/usr/bin/install -c -m 644 Zeroconf.1 /home/ajandaga/mpich2-install/share/man/man1/Zeroconf.1
/usr/bin/install -c -m 644 MPI_Abort.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Abort.3
/usr/bin/install -c -m 644 MPI_Accumulate.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Accumulate.3
/usr/bin/install -c -m 644 MPI_Add_error_class.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Add_error_class.3
/usr/bin/install -c -m 644 MPI_Add_error_code.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Add_error_code.3
/usr/bin/install -c -m 644 MPI_Add_error_string.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Add_error_string.3
/usr/bin/install -c -m 644 MPI_Address.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Address.3
/usr/bin/install -c -m 644 MPI_Allgather.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Allgather.3
/usr/bin/install -c -m 644 MPI_Allgatherv.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Allgatherv.3
/usr/bin/install -c -m 644 MPI_Alloc_mem.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Alloc_mem.3
/usr/bin/install -c -m 644 MPI_Allreduce.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Allreduce.3
/usr/bin/install -c -m 644 MPI_Alltoall.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Alltoall.3
/usr/bin/install -c -m 644 MPI_Alltoallv.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Alltoallv.3
/usr/bin/install -c -m 644 MPI_Alltoallw.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Alltoallw.3
/usr/bin/install -c -m 644 MPI_Attr_delete.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Attr_delete.3
/usr/bin/install -c -m 644 MPI_Attr_get.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Attr_get.3
/usr/bin/install -c -m 644 MPI_Attr_put.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Attr_put.3
/usr/bin/install -c -m 644 MPI_Barrier.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Barrier.3
/usr/bin/install -c -m 644 MPI_Bcast.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Bcast.3
/usr/bin/install -c -m 644 MPI_Bsend.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Bsend.3
/usr/bin/install -c -m 644 MPI_Bsend_init.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Bsend_init.3
/usr/bin/install -c -m 644 MPI_Buffer_attach.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Buffer_attach.3
/usr/bin/install -c -m 644 MPI_Buffer_detach.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Buffer_detach.3
/usr/bin/install -c -m 644 MPI_Cancel.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Cancel.3
/usr/bin/install -c -m 644 MPI_Cart_coords.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Cart_coords.3
/usr/bin/install -c -m 644 MPI_Cart_create.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Cart_create.3
/usr/bin/install -c -m 644 MPI_Cartdim_get.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Cartdim_get.3
/usr/bin/install -c -m 644 MPI_Cart_get.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Cart_get.3
/usr/bin/install -c -m 644 MPI_Cart_map.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Cart_map.3
/usr/bin/install -c -m 644 MPI_Cart_rank.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Cart_rank.3
/usr/bin/install -c -m 644 MPI_Cart_shift.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Cart_shift.3
/usr/bin/install -c -m 644 MPI_Cart_sub.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Cart_sub.3
/usr/bin/install -c -m 644 MPI_Close_port.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Close_port.3
/usr/bin/install -c -m 644 MPI_Comm_accept.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_accept.3
/usr/bin/install -c -m 644 MPI_Comm_call_errhandler.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_compare.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_compare.3
/usr/bin/install -c -m 644 MPI_Comm_connect.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_connect.3
/usr/bin/install -c -m 644 MPI_Comm_create.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_create.3
/usr/bin/install -c -m 644 MPI_Comm_create_errhandler.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_create_keyval.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_create_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_delete_attr.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_delete_attr.3
/usr/bin/install -c -m 644 MPI_Comm_disconnect.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_disconnect.3
/usr/bin/install -c -m 644 MPI_Comm_dup.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_dup.3
/usr/bin/install -c -m 644 MPI_Comm_free.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_free.3
/usr/bin/install -c -m 644 MPI_Comm_free_keyval.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_free_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_get_attr.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_get_attr.3
/usr/bin/install -c -m 644 MPI_Comm_get_errhandler.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_get_name.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_get_name.3
/usr/bin/install -c -m 644 MPI_Comm_get_parent.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_get_parent.3
/usr/bin/install -c -m 644 MPI_Comm_group.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_group.3
/usr/bin/install -c -m 644 MPI_Comm_join.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_join.3
/usr/bin/install -c -m 644 MPI_Comm_rank.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_rank.3
/usr/bin/install -c -m 644 MPI_Comm_remote_group.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_remote_group.3
/usr/bin/install -c -m 644 MPI_Comm_remote_size.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_remote_size.3
/usr/bin/install -c -m 644 MPI_Comm_set_attr.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_set_attr.3
/usr/bin/install -c -m 644 MPI_Comm_set_errhandler.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_set_name.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_set_name.3
/usr/bin/install -c -m 644 MPI_Comm_size.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_size.3
/usr/bin/install -c -m 644 MPI_Comm_spawn.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_spawn.3
/usr/bin/install -c -m 644 MPI_Comm_spawn_multiple.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_spawn_multiple.3
/usr/bin/install -c -m 644 MPI_Comm_split.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_split.3
/usr/bin/install -c -m 644 MPI_Comm_test_inter.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Comm_test_inter.3
/usr/bin/install -c -m 644 MPI_Dims_create.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Dims_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Dist_graph_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create_adjacent.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Dist_graph_create_adjacent.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Dist_graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors_count.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Dist_graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Errhandler_create.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Errhandler_create.3
/usr/bin/install -c -m 644 MPI_Errhandler_free.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Errhandler_free.3
/usr/bin/install -c -m 644 MPI_Errhandler_get.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Errhandler_get.3
/usr/bin/install -c -m 644 MPI_Errhandler_set.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Errhandler_set.3
/usr/bin/install -c -m 644 MPI_Error_class.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Error_class.3
/usr/bin/install -c -m 644 MPI_Error_string.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Error_string.3
/usr/bin/install -c -m 644 MPI_Exscan.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Exscan.3
/usr/bin/install -c -m 644 MPI_File_c2f.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_c2f.3
/usr/bin/install -c -m 644 MPI_File_call_errhandler.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_call_errhandler.3
/usr/bin/install -c -m 644 MPI_File_close.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_close.3
/usr/bin/install -c -m 644 MPI_File_create_errhandler.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_create_errhandler.3
/usr/bin/install -c -m 644 MPI_File_delete.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_delete.3
/usr/bin/install -c -m 644 MPI_File_f2c.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_f2c.3
/usr/bin/install -c -m 644 MPI_File_get_amode.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_get_amode.3
/usr/bin/install -c -m 644 MPI_File_get_atomicity.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_get_atomicity.3
/usr/bin/install -c -m 644 MPI_File_get_byte_offset.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_get_byte_offset.3
/usr/bin/install -c -m 644 MPI_File_get_errhandler.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_get_errhandler.3
/usr/bin/install -c -m 644 MPI_File_get_group.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_get_group.3
/usr/bin/install -c -m 644 MPI_File_get_info.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_get_info.3
/usr/bin/install -c -m 644 MPI_File_get_position.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_get_position.3
/usr/bin/install -c -m 644 MPI_File_get_position_shared.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_get_position_shared.3
/usr/bin/install -c -m 644 MPI_File_get_size.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_get_size.3
/usr/bin/install -c -m 644 MPI_File_get_type_extent.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_get_type_extent.3
/usr/bin/install -c -m 644 MPI_File_get_view.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_get_view.3
/usr/bin/install -c -m 644 MPI_File_iread.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_iread.3
/usr/bin/install -c -m 644 MPI_File_iread_at.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_iread_at.3
/usr/bin/install -c -m 644 MPI_File_iread_shared.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_iread_shared.3
/usr/bin/install -c -m 644 MPI_File_iwrite.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_iwrite.3
/usr/bin/install -c -m 644 MPI_File_iwrite_at.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_iwrite_at.3
/usr/bin/install -c -m 644 MPI_File_iwrite_shared.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_iwrite_shared.3
/usr/bin/install -c -m 644 MPI_File_open.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_open.3
/usr/bin/install -c -m 644 MPI_File_preallocate.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_preallocate.3
/usr/bin/install -c -m 644 MPI_File_read.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_read.3
/usr/bin/install -c -m 644 MPI_File_read_all.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_read_all.3
/usr/bin/install -c -m 644 MPI_File_read_all_begin.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_read_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_all_end.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_read_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_at.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_read_at.3
/usr/bin/install -c -m 644 MPI_File_read_at_all.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_read_at_all.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_begin.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_read_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_end.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_read_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_ordered.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_read_ordered.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_begin.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_read_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_end.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_read_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_read_shared.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_read_shared.3
/usr/bin/install -c -m 644 MPI_File_seek.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_seek.3
/usr/bin/install -c -m 644 MPI_File_seek_shared.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_seek_shared.3
/usr/bin/install -c -m 644 MPI_File_set_atomicity.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_set_atomicity.3
/usr/bin/install -c -m 644 MPI_File_set_errhandler.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_set_errhandler.3
/usr/bin/install -c -m 644 MPI_File_set_info.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_set_info.3
/usr/bin/install -c -m 644 MPI_File_set_size.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_set_size.3
/usr/bin/install -c -m 644 MPI_File_set_view.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_set_view.3
/usr/bin/install -c -m 644 MPI_File_sync.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_sync.3
/usr/bin/install -c -m 644 MPI_File_write.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_write.3
/usr/bin/install -c -m 644 MPI_File_write_all.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_write_all.3
/usr/bin/install -c -m 644 MPI_File_write_all_begin.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_write_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_all_end.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_write_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_at.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_write_at.3
/usr/bin/install -c -m 644 MPI_File_write_at_all.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_write_at_all.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_begin.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_write_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_end.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_write_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_ordered.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_write_ordered.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_begin.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_write_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_end.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_write_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_write_shared.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_File_write_shared.3
/usr/bin/install -c -m 644 MPI_Finalize.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Finalize.3
/usr/bin/install -c -m 644 MPI_Finalized.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Finalized.3
/usr/bin/install -c -m 644 MPI_Free_mem.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Free_mem.3
/usr/bin/install -c -m 644 MPI_Gather.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Gather.3
/usr/bin/install -c -m 644 MPI_Gatherv.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Gatherv.3
/usr/bin/install -c -m 644 MPI_Get.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Get.3
/usr/bin/install -c -m 644 MPI_Get_address.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Get_address.3
/usr/bin/install -c -m 644 MPI_Get_count.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Get_count.3
/usr/bin/install -c -m 644 MPI_Get_elements.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Get_elements.3
/usr/bin/install -c -m 644 MPI_Get_processor_name.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Get_processor_name.3
/usr/bin/install -c -m 644 MPI_Get_version.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Get_version.3
/usr/bin/install -c -m 644 MPI_Graph_create.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Graph_create.3
/usr/bin/install -c -m 644 MPI_Graphdims_get.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Graphdims_get.3
/usr/bin/install -c -m 644 MPI_Graph_get.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Graph_get.3
/usr/bin/install -c -m 644 MPI_Graph_map.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Graph_map.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors_count.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Grequest_complete.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Grequest_complete.3
/usr/bin/install -c -m 644 MPI_Grequest_start.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Grequest_start.3
/usr/bin/install -c -m 644 MPI_Group_compare.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Group_compare.3
/usr/bin/install -c -m 644 MPI_Group_difference.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Group_difference.3
/usr/bin/install -c -m 644 MPI_Group_excl.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Group_excl.3
/usr/bin/install -c -m 644 MPI_Group_free.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Group_free.3
/usr/bin/install -c -m 644 MPI_Group_incl.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Group_incl.3
/usr/bin/install -c -m 644 MPI_Group_intersection.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Group_intersection.3
/usr/bin/install -c -m 644 MPI_Group_range_excl.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Group_range_excl.3
/usr/bin/install -c -m 644 MPI_Group_range_incl.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Group_range_incl.3
/usr/bin/install -c -m 644 MPI_Group_rank.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Group_rank.3
/usr/bin/install -c -m 644 MPI_Group_size.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Group_size.3
/usr/bin/install -c -m 644 MPI_Group_translate_ranks.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Group_translate_ranks.3
/usr/bin/install -c -m 644 MPI_Group_union.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Group_union.3
/usr/bin/install -c -m 644 MPI_Ibsend.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Ibsend.3
/usr/bin/install -c -m 644 MPI_Info_create.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Info_create.3
/usr/bin/install -c -m 644 MPI_Info_delete.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Info_delete.3
/usr/bin/install -c -m 644 MPI_Info_dup.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Info_dup.3
/usr/bin/install -c -m 644 MPI_Info_free.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Info_free.3
/usr/bin/install -c -m 644 MPI_Info_get.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Info_get.3
/usr/bin/install -c -m 644 MPI_Info_get_nkeys.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Info_get_nkeys.3
/usr/bin/install -c -m 644 MPI_Info_get_nthkey.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Info_get_nthkey.3
/usr/bin/install -c -m 644 MPI_Info_get_valuelen.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Info_get_valuelen.3
/usr/bin/install -c -m 644 MPI_Info_set.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Info_set.3
/usr/bin/install -c -m 644 MPI_Init.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Init.3
/usr/bin/install -c -m 644 MPI_Initialized.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Initialized.3
/usr/bin/install -c -m 644 MPI_Init_thread.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Init_thread.3
/usr/bin/install -c -m 644 MPI_Intercomm_create.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Intercomm_create.3
/usr/bin/install -c -m 644 MPI_Intercomm_merge.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Intercomm_merge.3
/usr/bin/install -c -m 644 MPI_Iprobe.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Iprobe.3
/usr/bin/install -c -m 644 MPI_Irecv.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Irecv.3
/usr/bin/install -c -m 644 MPI_Irsend.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Irsend.3
/usr/bin/install -c -m 644 MPI_Isend.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Isend.3
/usr/bin/install -c -m 644 MPI_Issend.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Issend.3
/usr/bin/install -c -m 644 MPI_Is_thread_main.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Is_thread_main.3
/usr/bin/install -c -m 644 MPI_Keyval_create.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Keyval_create.3
/usr/bin/install -c -m 644 MPI_Keyval_free.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Keyval_free.3
/usr/bin/install -c -m 644 MPI_Lookup_name.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Lookup_name.3
/usr/bin/install -c -m 644 MPI_Op_commute.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Op_commute.3
/usr/bin/install -c -m 644 MPI_Op_create.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Op_create.3
/usr/bin/install -c -m 644 MPI_Open_port.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Open_port.3
/usr/bin/install -c -m 644 MPI_Op_free.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Op_free.3
/usr/bin/install -c -m 644 MPI_Pack.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Pack.3
/usr/bin/install -c -m 644 MPI_Pack_external.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Pack_external.3
/usr/bin/install -c -m 644 MPI_Pack_external_size.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Pack_external_size.3
/usr/bin/install -c -m 644 MPI_Pack_size.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Pack_size.3
/usr/bin/install -c -m 644 MPI_Pcontrol.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Pcontrol.3
/usr/bin/install -c -m 644 MPI_Probe.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Probe.3
/usr/bin/install -c -m 644 MPI_Publish_name.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Publish_name.3
/usr/bin/install -c -m 644 MPI_Put.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Put.3
/usr/bin/install -c -m 644 MPI_Query_thread.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Query_thread.3
/usr/bin/install -c -m 644 MPI_Recv.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Recv.3
/usr/bin/install -c -m 644 MPI_Recv_init.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Recv_init.3
/usr/bin/install -c -m 644 MPI_Reduce.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Reduce.3
/usr/bin/install -c -m 644 MPI_Reduce_local.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Reduce_local.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Reduce_scatter.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter_block.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Reduce_scatter_block.3
/usr/bin/install -c -m 644 MPI_Register_datarep.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Register_datarep.3
/usr/bin/install -c -m 644 MPI_Request_free.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Request_free.3
/usr/bin/install -c -m 644 MPI_Request_get_status.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Request_get_status.3
/usr/bin/install -c -m 644 MPI_Rsend.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Rsend.3
/usr/bin/install -c -m 644 MPI_Rsend_init.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Rsend_init.3
/usr/bin/install -c -m 644 MPI_Scan.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Scan.3
/usr/bin/install -c -m 644 MPI_Scatter.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Scatter.3
/usr/bin/install -c -m 644 MPI_Scatterv.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Scatterv.3
/usr/bin/install -c -m 644 MPI_Send.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Send.3
/usr/bin/install -c -m 644 MPI_Send_init.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Send_init.3
/usr/bin/install -c -m 644 MPI_Sendrecv.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Sendrecv.3
/usr/bin/install -c -m 644 MPI_Sendrecv_replace.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Sendrecv_replace.3
/usr/bin/install -c -m 644 MPI_Ssend.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Ssend.3
/usr/bin/install -c -m 644 MPI_Ssend_init.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Ssend_init.3
/usr/bin/install -c -m 644 MPI_Start.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Start.3
/usr/bin/install -c -m 644 MPI_Startall.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Startall.3
/usr/bin/install -c -m 644 MPI_Status_set_cancelled.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Status_set_cancelled.3
/usr/bin/install -c -m 644 MPI_Status_set_elements.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Status_set_elements.3
/usr/bin/install -c -m 644 MPI_Test.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Test.3
/usr/bin/install -c -m 644 MPI_Testall.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Testall.3
/usr/bin/install -c -m 644 MPI_Testany.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Testany.3
/usr/bin/install -c -m 644 MPI_Test_cancelled.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Test_cancelled.3
/usr/bin/install -c -m 644 MPI_Testsome.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Testsome.3
/usr/bin/install -c -m 644 MPI_Topo_test.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Topo_test.3
/usr/bin/install -c -m 644 MPI_Type_commit.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_commit.3
/usr/bin/install -c -m 644 MPI_Type_contiguous.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_contiguous.3
/usr/bin/install -c -m 644 MPI_Type_create_darray.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_create_darray.3
/usr/bin/install -c -m 644 MPI_Type_create_hindexed.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_create_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_create_hvector.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_create_hvector.3
/usr/bin/install -c -m 644 MPI_Type_create_indexed_block.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_create_indexed_block.3
/usr/bin/install -c -m 644 MPI_Type_create_keyval.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_create_keyval.3
/usr/bin/install -c -m 644 MPI_Type_create_resized.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_create_resized.3
/usr/bin/install -c -m 644 MPI_Type_create_struct.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_create_struct.3
/usr/bin/install -c -m 644 MPI_Type_create_subarray.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_create_subarray.3
/usr/bin/install -c -m 644 MPI_Type_delete_attr.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_delete_attr.3
/usr/bin/install -c -m 644 MPI_Type_dup.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_dup.3
/usr/bin/install -c -m 644 MPI_Type_extent.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_extent.3
/usr/bin/install -c -m 644 MPI_Type_free.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_free.3
/usr/bin/install -c -m 644 MPI_Type_free_keyval.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_free_keyval.3
/usr/bin/install -c -m 644 MPI_Type_get_attr.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_get_attr.3
/usr/bin/install -c -m 644 MPI_Type_get_contents.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_get_contents.3
/usr/bin/install -c -m 644 MPI_Type_get_envelope.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_get_envelope.3
/usr/bin/install -c -m 644 MPI_Type_get_extent.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_get_extent.3
/usr/bin/install -c -m 644 MPI_Type_get_name.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_get_name.3
/usr/bin/install -c -m 644 MPI_Type_get_true_extent.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_get_true_extent.3
/usr/bin/install -c -m 644 MPI_Type_hindexed.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_hvector.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_hvector.3
/usr/bin/install -c -m 644 MPI_Type_indexed.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_indexed.3
/usr/bin/install -c -m 644 MPI_Type_lb.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_lb.3
/usr/bin/install -c -m 644 MPI_Type_match_size.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_match_size.3
/usr/bin/install -c -m 644 MPI_Type_set_attr.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_set_attr.3
/usr/bin/install -c -m 644 MPI_Type_set_name.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_set_name.3
/usr/bin/install -c -m 644 MPI_Type_size.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_size.3
/usr/bin/install -c -m 644 MPI_Type_struct.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_struct.3
/usr/bin/install -c -m 644 MPI_Type_ub.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_ub.3
/usr/bin/install -c -m 644 MPI_Type_vector.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Type_vector.3
/usr/bin/install -c -m 644 MPI_Unpack.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Unpack.3
/usr/bin/install -c -m 644 MPI_Unpack_external.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Unpack_external.3
/usr/bin/install -c -m 644 MPI_Unpublish_name.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Unpublish_name.3
/usr/bin/install -c -m 644 MPI_Wait.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Wait.3
/usr/bin/install -c -m 644 MPI_Waitall.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Waitall.3
/usr/bin/install -c -m 644 MPI_Waitany.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Waitany.3
/usr/bin/install -c -m 644 MPI_Waitsome.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Waitsome.3
/usr/bin/install -c -m 644 MPI_Win_call_errhandler.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_complete.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_complete.3
/usr/bin/install -c -m 644 MPI_Win_create.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_create.3
/usr/bin/install -c -m 644 MPI_Win_create_errhandler.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_create_keyval.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_create_keyval.3
/usr/bin/install -c -m 644 MPI_Win_delete_attr.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_delete_attr.3
/usr/bin/install -c -m 644 MPI_Win_fence.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_fence.3
/usr/bin/install -c -m 644 MPI_Win_free.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_free.3
/usr/bin/install -c -m 644 MPI_Win_free_keyval.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_free_keyval.3
/usr/bin/install -c -m 644 MPI_Win_get_attr.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_get_attr.3
/usr/bin/install -c -m 644 MPI_Win_get_errhandler.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_get_group.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_get_group.3
/usr/bin/install -c -m 644 MPI_Win_get_name.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_get_name.3
/usr/bin/install -c -m 644 MPI_Win_lock.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_lock.3
/usr/bin/install -c -m 644 MPI_Win_post.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_post.3
/usr/bin/install -c -m 644 MPI_Win_set_attr.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_set_attr.3
/usr/bin/install -c -m 644 MPI_Win_set_errhandler.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_set_name.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_set_name.3
/usr/bin/install -c -m 644 MPI_Win_start.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_start.3
/usr/bin/install -c -m 644 MPI_Win_test.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_test.3
/usr/bin/install -c -m 644 MPI_Win_unlock.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_unlock.3
/usr/bin/install -c -m 644 MPI_Win_wait.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Win_wait.3
/usr/bin/install -c -m 644 MPI_Wtick.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Wtick.3
/usr/bin/install -c -m 644 MPI_Wtime.3 /home/ajandaga/mpich2-install/share/man/man3/MPI_Wtime.3
if [ -s src/mpi/romio/include/mpiof.h ] ; then /usr/bin/install -c -m 644 src/mpi/romio/include/mpiof.h /home/ajandaga/mpich2-install/include/mpiof.h ; fi
if [ -s src/mpi/romio/include/mpio.h ] ; then /usr/bin/install -c -m 644 src/mpi/romio/include/mpio.h /home/ajandaga/mpich2-install/include/mpio.h ; fi
if [ -s lib/libmpich.a ] ; then /usr/bin/install -c -m 644 lib/libmpich.a /home/ajandaga/mpich2-install/lib/libmpich.a ; fi
if [ -s lib/libmpichcxx.a ] ; then /usr/bin/install -c -m 644 lib/libmpichcxx.a /home/ajandaga/mpich2-install/lib/libmpichcxx.a ; fi
if [ -s lib/libfmpich.a ] ; then /usr/bin/install -c -m 644 lib/libfmpich.a /home/ajandaga/mpich2-install/lib/libfmpich.a ; fi
if [ -s lib/libpmpich.a ] ; then /usr/bin/install -c -m 644 lib/libpmpich.a /home/ajandaga/mpich2-install/lib/libpmpich.a ; fi
if [ -s lib/libmpichf90.a ] ; then /usr/bin/install -c -m 644 lib/libmpichf90.a /home/ajandaga/mpich2-install/lib/libmpichf90.a ; fi
if [ -s lib/libmpich.so ] ; then false -version-info 1:2 --mode=install lib/libmpich.so /home/ajandaga/mpich2-install/lib/libmpich.so ; fi
if [ -s lib/libpmpich.so ] ; then false -version-info 1:2 --mode=install lib/libpmpich.so /home/ajandaga/mpich2-install/lib/libpmpich.so ; fi
if [ -s lib/libfmpich.so ] ; then false -version-info 1:2 --mode=install lib/libfmpich.so /home/ajandaga/mpich2-install/lib/libfmpich.so ; fi
if [ -s lib/libmpichf90.so ] ; then false -version-info 1:2 --mode=install lib/libmpichf90.so /home/ajandaga/mpich2-install/lib/libmpichf90.so ; fi
if [ -s lib/libmpichcxx.so ] ; then false -version-info 1:2 --mode=install lib/libmpichcxx.so /home/ajandaga/mpich2-install/lib/libmpichcxx.so ; fi
if [ -s /home/ajandaga/libraries/mpich2-1.2.1p1/doc/userguide/user.pdf ] ; then /usr/bin/install -c -m 644 /home/ajandaga/libraries/mpich2-1.2.1p1/doc/userguide/user.pdf /home/ajandaga/mpich2-install/share/doc//user.pdf ; fi
if [ -s /home/ajandaga/libraries/mpich2-1.2.1p1/doc/installguide/install.pdf ] ; then /usr/bin/install -c -m 644 /home/ajandaga/libraries/mpich2-1.2.1p1/doc/installguide/install.pdf /home/ajandaga/mpich2-install/share/doc//install.pdf ; fi
if [ -s /home/ajandaga/libraries/mpich2-1.2.1p1/doc/smpd/smpd_pmi.pdf ] ; then /usr/bin/install -c -m 644 /home/ajandaga/libraries/mpich2-1.2.1p1/doc/smpd/smpd_pmi.pdf /home/ajandaga/mpich2-install/share/doc//smpd_pmi.pdf ; fi
if [ -s /home/ajandaga/libraries/mpich2-1.2.1p1/doc/logging/logging.pdf ] ; then /usr/bin/install -c -m 644 /home/ajandaga/libraries/mpich2-1.2.1p1/doc/logging/logging.pdf /home/ajandaga/mpich2-install/share/doc//logging.pdf ; fi
(cd src/env && make INSTALL_STRIP_FLAG= install)
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/env»
if [ ! -d /home/ajandaga/mpich2-install ] ; then mkdir -p /home/ajandaga/mpich2-install ; fi
if [ ! -d /home/ajandaga/mpich2-install/bin ] ; then mkdir -p /home/ajandaga/mpich2-install/bin ; fi
/usr/bin/install -c  mpich2version /home/ajandaga/mpich2-install/bin/mpich2version
/usr/bin/install -c mpicc /home/ajandaga/mpich2-install/bin/mpicc
/usr/bin/install -c parkill /home/ajandaga/mpich2-install/bin/parkill
if [ ! -d /home/ajandaga/mpich2-install/etc ] ; then mkdir -p /home/ajandaga/mpich2-install/etc ; fi
/usr/bin/install -c -m 644 mpixxx_opts.conf /home/ajandaga/mpich2-install/etc/mpixxx_opts.conf
/usr/bin/install -c -m 644 mpicc.conf /home/ajandaga/mpich2-install/etc/mpicc.conf
if [ -s mpicxx ] ; then /usr/bin/install -c mpicxx /home/ajandaga/mpich2-install/bin/mpicxx ; fi
if [ -s mpif77 ] ; then /usr/bin/install -c mpif77 /home/ajandaga/mpich2-install/bin/mpif77 ; fi
if [ -s mpif90 ] ; then /usr/bin/install -c mpif90 /home/ajandaga/mpich2-install/bin/mpif90 ; fi
if [ -s mpicxx.conf ] ; then /usr/bin/install -c -m 644 mpicxx.conf /home/ajandaga/mpich2-install/etc/mpicxx.conf ; fi
if [ -s mpif77.conf ] ; then /usr/bin/install -c -m 644 mpif77.conf /home/ajandaga/mpich2-install/etc/mpif77.conf ; fi
if [ -s mpif90.conf ] ; then /usr/bin/install -c -m 644 mpif90.conf /home/ajandaga/mpich2-install/etc/mpif90.conf ; fi
make install-postamble
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/env»
if [ -x /home/ajandaga/mpich2-install/bin/mpicxx ] ; then \
	    cd /home/ajandaga/mpich2-install/bin && ln -sf mpicxx mpic++ ; fi
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/env»
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/env»
(cd src/packaging/pkgconfig && make INSTALL_STRIP_FLAG= install)
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/packaging/pkgconfig»
if [ ! -d /home/ajandaga/mpich2-install/lib/pkgconfig ] ; then mkdir -p /home/ajandaga/mpich2-install/lib/pkgconfig ; fi
if [ -s mpich2-ch3.pc ] ; then /usr/bin/install -c -m 644 mpich2-ch3.pc /home/ajandaga/mpich2-install/lib/pkgconfig/mpich2-ch3.pc ; fi
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/packaging/pkgconfig»
(cd src/packaging/envmods && make INSTALL_STRIP_FLAG= install)
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/packaging/envmods»
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/packaging/envmods»
for dir in  src/binding/f77 src/binding/f90 src/binding/cxx - ; do \
		if [ "$dir" = "-" ] ; then break ; fi ;\
		(cd $dir && make INSTALL_STRIP_FLAG= PACKAGE= install) ;\
	done
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/f77»
if [ ! -d /home/ajandaga/mpich2-install/include ] ; then mkdir -p /home/ajandaga/mpich2-install/include ; fi
/usr/bin/install -c -m 644 mpif.h /home/ajandaga/mpich2-install/include/mpif.h
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/f77»
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/f90»
/usr/bin/install -c -m 644 mpi.mod /home/ajandaga/mpich2-install/include/mpi.mod
/usr/bin/install -c -m 644 mpi_constants.mod /home/ajandaga/mpich2-install/include/mpi_constants.mod
/usr/bin/install -c -m 644 mpi_base.mod /home/ajandaga/mpich2-install/include/mpi_base.mod
/usr/bin/install -c -m 644 mpi_sizeofs.mod /home/ajandaga/mpich2-install/include/mpi_sizeofs.mod
if [ ! -d /home/ajandaga/mpich2-install/lib ] ; then mkdir -p /home/ajandaga/mpich2-install/lib ; fi
/usr/bin/install -c -m 644 libmpichf90.a /home/ajandaga/mpich2-install/lib/libmpichf90.a
if [ -s mpimod.pcl ] ; then /usr/bin/install -c -m 644 mpimod.pcl /home/ajandaga/mpich2-install/include/mpimod.pcl ; fi
if [ -s mpimod.pc ] ; then /usr/bin/install -c -m 644 mpimod.pc /home/ajandaga/mpich2-install/include/mpimod.pc ; fi
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/f90»
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/cxx»
/usr/bin/install -c -m 644 mpicxx.h /home/ajandaga/mpich2-install/include/mpicxx.h
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/binding/cxx»
for dir in  src/openpa src/pm/mpd src/mpe2 - ; do \
	done
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa»
Making install in src
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src»
test -z "/home/ajandaga/mpich2-install/lib" || mkdir -p "/home/ajandaga/mpich2-install/lib"
 /usr/bin/install -c -m 644  libopa.a '/home/ajandaga/mpich2-install/lib'
 ( cd '/home/ajandaga/mpich2-install/lib' && ranlib libopa.a )
test -z "/home/ajandaga/mpich2-install/include" || mkdir -p "/home/ajandaga/mpich2-install/include"
 /usr/bin/install -c -m 644 opa_config.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/opa_primitives.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/opa_queue.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/opa_util.h '/home/ajandaga/mpich2-install/include'
mkdir -p '/home/ajandaga/mpich2-install/include/primitives'
 /usr/bin/install -c -m 644  /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_by_lock.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_emulated.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_gcc_ia64.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_gcc_intel_32_64.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_gcc_intel_32_64_barrier.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_gcc_intel_32_64_ops.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_gcc_intel_32_64_p3.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_gcc_intel_32_64_p3barrier.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_gcc_intrinsics.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_gcc_ppc.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_gcc_sicortex.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_nt_intrinsics.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_sun_atomic_ops.h /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/src/primitives/opa_unsafe.h '/home/ajandaga/mpich2-install/include/primitives'
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src»
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/src»
Making install in test
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/test»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/test»
make[3]: No se hace nada para «install-exec-am».
make[3]: No se hace nada para «install-data-am».
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/test»
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa/test»
make[2]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa»
make[3]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa»
test -z "/home/ajandaga/mpich2-install/share/doc/openpa" || mkdir -p "/home/ajandaga/mpich2-install/share/doc/openpa"
 /usr/bin/install -c -m 644 /home/ajandaga/libraries/mpich2-1.2.1p1/src/openpa/README '/home/ajandaga/mpich2-install/share/doc/openpa'
test -z "/home/ajandaga/mpich2-install/lib/pkgconfig" || mkdir -p "/home/ajandaga/mpich2-install/lib/pkgconfig"
 /usr/bin/install -c -m 644 openpa.pc '/home/ajandaga/mpich2-install/lib/pkgconfig'
make[3]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa»
make[2]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa»
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/openpa»
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/mpd»
copying python files/links into  /home/ajandaga/mpich2-install/bin
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/pm/mpd»
make[1]: se ingresa al directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2»
Installing MPE2 include files to /home/ajandaga/mpich2-install/include
Replacing existing file /home/ajandaga/mpich2-install/include/clog_commset.h...
Replacing existing file /home/ajandaga/mpich2-install/include/clog_const.h...
Replacing existing file /home/ajandaga/mpich2-install/include/clog_inttypes.h...
Replacing existing file /home/ajandaga/mpich2-install/include/clog_uuid.h...
Replacing existing file /home/ajandaga/mpich2-install/include/mpe.h...
Replacing existing file /home/ajandaga/mpich2-install/include/mpe_callstack.h...
Replacing existing file /home/ajandaga/mpich2-install/include/mpe_graphics.h...
Replacing existing file /home/ajandaga/mpich2-install/include/mpe_graphicsf.h...
Replacing existing file /home/ajandaga/mpich2-install/include/mpe_log.h...
Replacing existing file /home/ajandaga/mpich2-install/include/mpe_log_thread.h...
Replacing existing file /home/ajandaga/mpich2-install/include/mpe_logf.h...
Replacing existing file /home/ajandaga/mpich2-install/include/mpe_misc.h...
Installing MPE2 libraries to /home/ajandaga/mpich2-install/lib
Replacing existing file /home/ajandaga/mpich2-install/lib/libampe.a...
Replacing existing file /home/ajandaga/mpich2-install/lib/liblmpe.a...
Replacing existing file /home/ajandaga/mpich2-install/lib/libmpe.a...
Replacing existing file /home/ajandaga/mpich2-install/lib/libmpe_collchk.a...
Replacing existing file /home/ajandaga/mpich2-install/lib/libmpe_f2cmpi.a...
Replacing existing file /home/ajandaga/mpich2-install/lib/libmpe_nompi.a...
Replacing existing file /home/ajandaga/mpich2-install/lib/libmpe_nompi_null.a...
Replacing existing file /home/ajandaga/mpich2-install/lib/libmpe_null.a...
Replacing existing file /home/ajandaga/mpich2-install/lib/libtmpe.a...
Replacing existing file /home/ajandaga/mpich2-install/lib/mpe_prof.o...
Installing MPE2 utility programs to /home/ajandaga/mpich2-install/bin
Replacing existing file /home/ajandaga/mpich2-install/bin/check_callstack...
Replacing existing file /home/ajandaga/mpich2-install/bin/clog2_join...
Replacing existing file /home/ajandaga/mpich2-install/bin/clog2_print...
Replacing existing file /home/ajandaga/mpich2-install/bin/clog2_repair...
Installing MPE2 configuration files to /home/ajandaga/mpich2-install/etc
Installing MPE2 system utility programs to /home/ajandaga/mpich2-install/sbin
Replacing existing file /home/ajandaga/mpich2-install/sbin/mpecheckinstall...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/comm1_isr.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/comm1_isr_loop.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/comm2_connect_accept.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/comm2_spawn_child.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/comm2_spawn_parent.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/cpi.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/cpilog.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/cpilog_pack.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/fcomm1_isr.f...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/fpilog.f...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/fpilog_pack.F...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/iotest.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/log_cost.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/openmp_mpilog.F...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/openmp_sendrecv.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/pthread_allreduce.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/pthread_sendrecv.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/pthread_sendrecv_user.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_logging/srtest.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_graphics/cpi.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_graphics/cxgraphics.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_graphics/fxgraphics.f...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_collchk/composite.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_collchk/scatterv.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_collchk/time_allreduce.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_collchk/time_alltoallv.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_collchk/time_alltoallv0.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_collchk/time_bcast.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_collchk/wrong_composite.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_collchk/wrong_int_byte.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_collchk/wrong_reals.f...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_collchk/wrong_root.c...
Replacing existing file /home/ajandaga/mpich2-install/share/examples_collchk/wrong_scatterv.c...
Installing MPE2 man to /home/ajandaga/mpich2-install/share/man
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Add_RGB_color.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_CaptureFile.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Close_graphics.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Comm_global_rank.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Decomp1d.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Describe_comm_event.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Describe_comm_state.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Describe_event.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Describe_info_event.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Describe_info_state.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Describe_state.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Draw_circle.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Draw_line.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Draw_logic.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Draw_point.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Draw_points.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Draw_string.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Errors_call_debugger.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Fill_circle.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Fill_rectangle.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Finish_log.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_GetHostName.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_GetTags.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Get_mouse_press.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_IO_Stdout_to_file.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Iget_mouse_press.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Init_log.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Initialized_logging.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Line_thickness.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_bare_event.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_comm_event.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_comm_receive.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_comm_send.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_event.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_get_event_number.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_get_solo_eventID.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_get_state_eventIDs.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_info_event.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_merged_logfilename.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_pack.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_receive.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_send.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Log_sync_clocks.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Make_color_array.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Num_colors.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Open_graphics.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_ReturnTags.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Seq_begin.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Seq_end.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Signals_call_debugger.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Start_log.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Stop_log.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_TagsEnd.4...
Replacing existing file /home/ajandaga/mpich2-install/share/man/man4/MPE_Update.4...
Installing MPE2 html to /home/ajandaga/mpich2-install/share/doc/
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Add_RGB_color.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_CaptureFile.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Close_graphics.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Comm_global_rank.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Decomp1d.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Describe_comm_event.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Describe_comm_state.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Describe_event.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Describe_info_event.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Describe_info_state.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Describe_state.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Draw_circle.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Draw_line.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Draw_logic.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Draw_point.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Draw_points.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Draw_string.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Errors_call_debugger.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Fill_circle.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Fill_rectangle.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Finish_log.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_GetHostName.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_GetTags.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Get_mouse_press.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_IO_Stdout_to_file.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Iget_mouse_press.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Init_log.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Initialized_logging.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Line_thickness.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_bare_event.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_comm_event.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_comm_receive.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_comm_send.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_event.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_get_event_number.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_get_solo_eventID.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_get_state_eventIDs.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_info_event.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_merged_logfilename.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_pack.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_receive.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_send.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Log_sync_clocks.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Make_color_array.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Num_colors.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Open_graphics.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_ReturnTags.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Seq_begin.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Seq_end.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Signals_call_debugger.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Start_log.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Stop_log.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_TagsEnd.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/MPE_Update.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//www4/libmpe.cit...
Installing SLOG2SDK's lib
Replacing existing file /home/ajandaga/mpich2-install/lib/clog2TOdrawable.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/clog2TOslog2.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/clog2print.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/clogTOdrawable.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/clogTOslog2.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/clogprint.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/jumpshot.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/jumpshot_launcher.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/logconvertor.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/slog2filter.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/slog2navigator.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/slog2printrecur.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/slog2printserial.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/slog2update205to206.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/traceTOslog2.jar...
Replacing existing file /home/ajandaga/mpich2-install/lib/traceprint.jar...
Installing SLOG2SDK's doc
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/usersguide.pdf...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/About24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Backward24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Convert24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/ConvertCancel24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/ConvertOk24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Delete24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Down24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Edit24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Find24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/FindBack24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/FindFore24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Forward24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/HandCloseUpLeft25.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/HandOpenUpLeft25.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Help24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Home24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Information24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/New24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Open24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Paste24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Preferences24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Print24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Properties24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Refresh24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Stop24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/TreeCollapse24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/TreeExpand24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/Up24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/WARNINGS...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/WinRedo.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/WinUndo.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/ZoomIn24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/ZoomMinusUpLeft25.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/ZoomOut24.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/ZoomPlusUpLeft25.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/adj_row_count.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/adj_row_height.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/contents.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/convertor_done.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/convertor_init.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/convertor_parameters.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/convertor_progress.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/histogram_arrow.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/histogram_arrow_infobox.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/histogram_mpi_overhead.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/histogram_state_all_cumu_excl.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/histogram_state_infobox.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/histogram_state_over_incl.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/index.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/internals.pl...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/labels.pl...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/legend_checkbox_menu.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/legend_color_chooser.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/legend_count.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/legend_excl.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/legend_incl.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/legend_name.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/legend_popup.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/legend_popup_full.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/legend_s.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/legend_sort_number_menu.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/legend_sort_string_menu.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/legend_topo.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/legend_v.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/main.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/mouse_hand_mode.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/mouse_zoom_mode.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/next.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/next_g.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node1.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node10.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node11.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node12.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node13.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node14.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node15.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node16.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node17.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node18.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node19.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node2.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node20.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node21.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node22.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node23.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node24.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node25.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node26.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node27.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node28.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node29.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node3.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node30.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node31.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node32.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node33.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node34.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node35.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node36.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node4.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node5.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node6.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node7.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node8.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/node9.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/openmpi_4_2_commthd.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/openmpi_4_2_procthd.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/openmpi_4_3_commthd.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/openmpi_4_3_procthd.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/openmpi_4_4_commthd.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/openmpi_4_4_procthd.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/openmpi_4_5_commthd.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/openmpi_4_5_procthd.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/openmpi_4_6_commthd.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/openmpi_4_6_procthd.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/preference_pview_state.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/prev.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/prev_g.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/pthread_sendrecv_legend.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_infobox_duration.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_infobox_preview_state.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_infobox_real_primitive.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_infobox_time.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_mpi_overhead.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_nesting_detail.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_nesting_legend_innermost.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_nesting_legend_middle.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_nesting_legend_outermost.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_nesting_preview_all.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_popup.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_popup_finer.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_preview_detail_0.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_preview_detail_0_excl.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_preview_detail_1.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_preview_detail_1_excl.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_preview_detail_2.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_preview_detail_3.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_preview_detail_4.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_search_preview.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/timeline_search_preview_zoomed.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/up.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/up_g.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/usersguide.css...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/usersguide.html...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/yaxis_label_panel_expanded.png...
Replacing existing file /home/ajandaga/mpich2-install/share/doc//jumpshot-4/html/yaxis_label_panel_simple.png...
Installing SLOG2SDK's share
Replacing existing file /home/ajandaga/mpich2-install/share/logfiles/fpilog.clog...
Replacing existing file /home/ajandaga/mpich2-install/share/logfiles/fpilog.slog2...
Creating SLOG2SDK's bin
Installed SLOG2SDK in /home/ajandaga/mpich2-install
/home/ajandaga/mpich2-install/sbin/mpeuninstall may be used to remove the installation
Installed MPE2 in /home/ajandaga/mpich2-install
make[1]: se sale del directorio «/tmp/ajandaga/mpich2-1.2.1p1/src/mpe2»
