[mpich-discuss] How to determine if a program is not started with mpiexec
    James Dinan
    dinan at mcs.anl.gov
    Fri Oct 28 15:38:06 CDT 2011
AFAICT, this currently does not work.  It looks like there is an issue
with mpiexec when you call MPI_Comm_get_attr() after launching the
program in this way.  I passed the bug along to our mpiexec expert.
  ~Jim.
On 10/28/11 3:33 PM, Jeff Hammond wrote:
> more importantly, what is UNIVERSE_SIZE when you launch a.out without mpiexec?
> jeff
> On Fri, Oct 28, 2011 at 3:32 PM, James Dinan<dinan at mcs.anl.gov>  wrote:
>> That's interesting.  The example in 10.3.5 also suggests that UNIVERSE_SIZE
>> should be used for this purpose.  I wrote a little test that suggests the
>> value may not be helpful:
>> $ mpiexec -n 2 ./a.out
>> 0: UNIVERSE_SIZE = 1
>> 1: UNIVERSE_SIZE = 1
>> When run with the MPICH2 trunk on my 4-core laptop.
>>   ~Jim.
>> On 10/28/11 3:06 PM, Jeff Hammond wrote:
>>> Shouldn't the MPI_UNIVERSE_SIZE attribute of MPI_COMM_WORLD provide a
>>> useful way to check if MPI_COMM_SPAWN can be used to start new
>>> processes?
>>> See the very last bullet of MPI 2.2 Section 10.2.2 for the text to
>>> which I refer.
>>> Jeff
>>> On Fri, Oct 28, 2011 at 1:25 PM, Darius Buntinas<buntinas at mcs.anl.gov>
>>>   wrote:
>>>> On Oct 28, 2011, at 1:01 PM, Jonathan Bishop wrote:
>>>>> Hi,
>>>>> I would like to be able to detect when a program is not started with
>>>>> mpiexec. This is to prevent MPI_Comm_spawn from failing.
>>>> There's no portable way to determine if it's been started with mpiexec.
>>>>   You could look for environment variables set by mpiexec.  A portable way
>>>> would be to set the error handler on a communicator to MPI_ERRORS_RETURN,
>>>> then try to do a spawn and check the return value.
>>>>> Or is there a way to make MPI_Comm_spawn work in the case where a
>>>>> program is simply run by running its exec?
>>>> This depends on the MPI implementation, but currently MPICH doesn't
>>>> support this.
>>>> -d
>>>>> Jon
>>>>> _______________________________________________
>>>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>>>> To manage subscription options or unsubscribe:
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
