[mpich-discuss] Trouble with checkpoint
    Fernando Luz
    fernando_luz at tpn.usp.br
    Fri Oct 28 14:54:19 CDT 2011
Hi Darius,
I applied the patch following your instructions and don't work.
I received this message (I ran salloc with verbose option)
[fernando_luz at masternode1 modelos_teste_mpi]$ salloc --verbose -n 26
--exclusive mpiexec -ckpointlib blcr -ckpoint-prefix teste.ckpoint/
-ckpoint-interval 20 -ckpoint-num 0
salloc: auth plugin for Munge (http://home.gna.org/munge/) loaded
salloc: Consumable Resources (CR) Node Selection plugin loaded with
argument 4
salloc: Granted job allocation 12941
salloc: Relinquishing job allocation 12941
salloc: Job allocation 12941 has been revoked.
salloc: Command "mpiexec" was terminated by signal 11
Thanks for help,
Regards
Fernando Luz
On Sex, 2011-10-28 at 11:13 -0500, Darius Buntinas wrote:
> Hi Fernando,
> Can you apply this patch and try it again?  Don't forget to do a make clean;make;make install again.
> Please let us know if this fixes the problem.
> Thanks,
> -d
> On Oct 26, 2011, at 10:10 AM, Fernando Luz wrote:
> > Darius,
> > Thanks for the help. It's works. I forgot to recompile my application.
> > But I have another question. It's possible use the checkpoint-restart feature in mpich2 using slurm pm?
> > I tried execute
> > salloc -n 26 mpiexec -ckpointlib blcr -ckpoint-prefix ./teste.ckpoint -ckpoint-interval 30 Dyna Prea_teste001.p3d 2
> > And to restart I use
> > salloc -n 26 mpiexec -ckpointlib blcr -ckpoint-prefix ./teste.ckpoint -ckpoint-interval 30 -ckpoint-num 2
> > I received the follow message
> > salloc: Granted job allocation 12613
> > [mpiexec at masternode1] HYD_pmcd_pmi_alloc_pg_scratch (./pm/pmiserv/pmiserv_utils.c:594): assert (pg->pg_process_count * sizeof(struct HYD_pmcd_pmi_ecount)) failed
> > [mpiexec at masternode1] HYD_pmci_launch_procs (./pm/pmiserv/pmiserv_pmci.c:103): error allocating pg scratch space
> > [mpiexec at masternode1] main (./ui/mpich/mpiexec.c:401): process manager returned error launching processes
> > salloc: Relinquishing job allocation 12613
> > The entire cluster are run under NFS.
> > But if I use salloc to select the nodes and I use the -f hosts (with the nodes allocated by salloc) works perfectly.
> > Regards
> > Fernando Luz
> > On Seg, 2011-10-24 at 16:41 -0500, Darius Buntinas wrote:
> >> Hmm strange.  Did you do a make clean first?  I.e.:
> >>   make clean
> >>   make
> >>   make install
> >> Also make sure you recompile your app (maybe even do a make clean for the app too).
> >> -d
> >> On Oct 22, 2011, at 3:28 PM, Fernando Luz wrote:
> >> > Hi Darius,
> >> > I applied the patch, but I have the same errors.
> >> > Do you need some file or info about my system?
> >> > Regards
> >> > Fernando Luz
> >> > ----- Mensagem original -----
> >> > De: "Darius Buntinas" <
> >> buntinas at mcs.anl.gov
> >> > Para:
> >> mpich-discuss at mcs.anl.gov
> >> > Enviadas: Sexta-feira, 21 de Outubro de 2011 16:20:49
> >> > Assunto: Re: [mpich-discuss] Trouble with checkpoint
> >> > Hi Fernando,
> >> > Can you apply this patch and see if it fixes your problem?
> >> > Let us know how it goes.
> >> > -d
> >> > On Oct 19, 2011, at 2:13 PM, Fernando Luz wrote:
> >> >> Hi,
> >> >> I tried use the checkpoint-restart with this execution.
> >> >> mpiexec -ckpointlib blcr -ckpoint-prefix ./teste.ckpoint -ckpoint-interval 30 -f hosts -n 26 Dyna Prea_teste001.p3d 2
> >> >> with mpich2 and I received the follows errors.
> >> >>  0% [=                                                 ] 00:00:28 / 00:56:27
> >> >> [proxy:0:
> >> 0 at s23n20.gradebr.tpn
> >> ] requesting checkpoint
> >> >> [proxy:0:
> >> 1 at s23n21.gradebr.tpn
> >> >> [proxy:0:
> >> 2 at s23n22.gradebr.tpn
> >> >> [proxy:0:
> >> 3 at s23n23.gradebr.tpn
> >> >> [proxy:0:
> >> ] checkpoint completed
> >> >> [proxy:0:
> >> >> [proxy:0:
> >> >> [proxy:0:
> >> >>  0% [=                                                 ] 00:00:29 / 00:56:28Fatal error in MPI_Recv: Other MPI error, error stack:
> >> >> MPI_Recv(186).............: MPI_Recv(buf=0x1ebebfc0, count=7, MPI_DOUBLE, src=0, tag=2, MPI_COMM_WORLD, status=0x7fff7ba7b620) failed
> >> >> MPIDI_CH3I_Progress(321)..:
> >> >> MPIDI_nem_ckpt_finish(469): sem_wait() failed Interrupted system call
> >> >> MPI_Recv(186).............: MPI_Recv(buf=0x1f84f600, count=7, MPI_DOUBLE, src=0, tag=2, MPI_COMM_WORLD, status=0x7fff957566a0) failed
> >> >> MPI_Recv(186).............: MPI_Recv(buf=0x1fc58d50, count=7, MPI_DOUBLE, src=0, tag=2, MPI_COMM_WORLD, status=0x7ffff54102a0) failed
> >> >> MPI_Recv(186).............: MPI_Recv(buf=0x7752ca0, count=7, MPI_DOUBLE, src=0, tag=2, MPI_COMM_WORLD, status=0x7fffeab72ca0) failed
> >> >> MPI_Recv(186).............: MPI_Recv(buf=0x12274ca0, count=7, MPI_DOUBLE, src=0, tag=2, MPI_COMM_WORLD, status=0x7fffb55e4ea0) failed
> >> >> MPI_Recv(186).............: MPI_Recv(buf=0x1b6c4600, count=7, MPI_DOUBLE, src=0, tag=2, MPI_COMM_WORLD, status=0x7fff74e63520) failed
> >> >> MPI_Recv(186).............: MPI_Recv(buf=0x15511ca0, count=7, MPI_DOUBLE, src=0, tag=2, MPI_COMM_WORLD, status=0x7fff9fb57ca0) failed
> >> >> MPI_Recv(186).............: MPI_Recv(buf=0x815afc0, count=7, MPI_DOUBLE, src=0, tag=2, MPI_COMM_WORLD, status=0x7fff87e31fa0) failed
> >> >> MPI_Recv(186).............: MPI_Recv(buf=0xf1e7d80, count=7, MPI_DOUBLE, src=0, tag=2, MPI_COMM_WORLD, status=0x7fff19d30120) failed
> >> >> MPI_Recv(186).............: MPI_Recv(buf=0x1758f9a0, count=7, MPI_DOUBLE, src=0, tag=2, MPI_COMM_WORLD, status=0x7fff06ac13a0) failed
> >> >> MPI_Recv(186).............: MPI_Recv(buf=0xaaf8ce0, count=7, MPI_DOUBLE, src=0, tag=2, MPI_COMM_WORLD, status=0x7fff7e488920) failed
> >> >> MPI_Recv(186).............: MPI_Recv(buf=0x1cc47990, count=7, MPI_DOUBLE, src=0, tag=2, MPI_COMM_WORLD, status=0x7fff00638520) failed
> >> >> without checkpoint, the execution is accomplish. How I need to proceed to solve this error?
> >> >> Regards
> >> >> Fernando Luz
> >> >> _______________________________________________
> >> >> mpich-discuss mailing list
> >> >> To manage subscription options or unsubscribe:
> >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> > mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111028/363b787f/attachment.htm>
