[mpich-discuss] Question on ch3:sock option for MPICH2 on Windows platform
Jayesh Krishna jayesh at mcs.anl.gov
Fri Oct 28 11:29:54 CDT 2011
 You could try creating a pool of threads and divide iprobes among them (You would still use the CPU resources for all the iprobe calls - however in this case it could/would be divided across cores).
 Have you considered using MPI_Waitany() ?
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>, mpich-discuss at mcs.anl.gov
Sent: Friday, October 28, 2011 11:00:39 AM
Subject: RE: [mpich-discuss] Question on ch3:sock option for MPICH2 on Windows	platform
Hi Jayesh,
The "-channel sock" option solved my problem.  Thank you very much.
I have another question now.
We are trying to follow the MPI fault tolerance design described here:
http://www.mcs.anl.gov/~lusk/papers/fault-tolerance.pdf
Let say we have approximately 500 to 1000 workers and I need to call MPI_Probe for each of those workers from the manager.
What is a good way to manage these MPI_Probe calls?  The simple solution that I can think of is to create one thread to call MPI_Probe per worker.  However, the number of threads required in this case would use up a lot of system resources and may not be ideal.
I understand that I can use MPI_Iprobe instead, but putting this into a while loop and calling it for all of the workers one by one would again tie up the CPU resources which defeat my purpose since this seems to be just polling.
Please let me know if you have any suggestion.
Eric Hui
GGY AXIS
416-2503448
Eric.Hui at ggy.com
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: October-27-11 3:09 PM
Cc: Eric Hui
Subject: Re: [mpich-discuss] Question on ch3:sock option for MPICH2 on Windows platform
 You should be able to specify the sock channel at runtime using the "-channel" option of mpiexec (mpiexec -n 2 -channel sock cpi.exe).
Jayesh
Sent: Thursday, October 27, 2011 1:06:49 PM
Subject: [mpich-discuss] Question on ch3:sock option for MPICH2 on Windows	platform
Hi Jayesh,
Pavan has previously suggested me to use the "with-device=ch3:sock" option to configure MPICH2 so that the MPI_Probe function can sleep and not tie up the CPU core by polling for message. I am on the Windows platform and tried to read through all the documentation, but can't seem to find how this configuration can be done. Can you give me some instructions on how to setup the environment to use this option?
Do I need to rebuild the entire MPI library myself or there is some setting / parameter that I can change?
What I have tried so far is to use the following:
smpd -set intermode_channel sock
However, my MPI program is still using the entire CPU core in the MPI_Probe call.
Here are the links for my original discussion with Pavan for your reference:
http://lists.mcs.anl.gov/pipermail/mpich-discuss/2011-September/010903.html
http://lists.mcs.anl.gov/pipermail/mpich-discuss/2011-September/010907.html
http://lists.mcs.anl.gov/pipermail/mpich-discuss/2011-September/010909.html
http://lists.mcs.anl.gov/pipermail/mpich-discuss/2011-September/010913.html
http://lists.mcs.anl.gov/pipermail/mpich-discuss/2011-September/010914.html
Thanks in advance for your assistance!
Eric Hui
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
