[mpich-discuss] Errors: In direct memory block for handle type REQUEST, 2 handles are still allocated
Dave Goodell
goodell at mcs.anl.gov
Wed Oct 26 16:21:19 CDT 2011
On Oct 26, 2011, at 4:12 PM CDT, Borrelli, Steven wrote:
> I'm seeing the following issues when I attempt to run a program that used to run on 1.2.1p1/mpd. What should be my next step in debugging this issue?
> Results for launching mpiexec with -n
> N=1, run completes without any issues
> N=2,3, run completes, but has the "In direct memory block for handle type REQUEST, 2 handles are still allocated" warning
This message indicates that you are leaking requests somehow. Perhaps you aren't invoking MPI_Wait (or equivalent) on every request in your program?
> N=4+, run fails with a signal 11.
Hard to say from the included info exactly what's causing the segfault. I'd try running your application under valgrind. Something like:
mpiexec -n $NUM_PROCS valgrind -q ./myapp
I'd start with NUM_PROCS=1 and work up from there after fixing any errors encountered at each level.
-Dave
