[mpich-discuss] linking MPI
Carolina Carneiro
carol07 at astro.ufrj.br
Tue Oct 25 10:45:24 CDT 2011
Hi Gus,
I did what you told, but it didn't work either. I don't necessarily have to
use -O5 for optimization, but the site where I did the download of the
program suggested that. I changed the makefile:
F90 = /home/carol/mocassin/mpich2-1.4.1p1/bin/mpif90
LIBS =
OPT1 = -O3
OPT2 = -O3
and now I got this errors:
carol at carol-HP-Pavilion-dv5-Notebook-PC:~/mocassin/mocassin.2.02.69$ make
mocassin
/home/carol/mocassin/mpich2-1.4.1p1/bin/mpif90 -O3 -o mocassin
source/infnan.f90 source/constants_mod.f90 source/vector_mod.f90
source/common_mod.f90 source/interpolation_mod.f90 source/set_input_mod.f90
source/hydro_mod.f90 source/ph_mod.f90 source/composition_mod.f90
source/continuum_mod.f90 source/ionization_mod.f90
source/pathIntegration_mod.f90 source/grid_mod.f90 source/dust_mod.f90
source/emission_mod.f90 source/photon_mod.f90 source/update_mod.f90
source/output_mod.f90 source/iteration_mod.f90 source/mocassin.f90
source/infnan.f90(1): error #7001: Error in creating the compiled module
file. [INF_NAN_DETECTION]
module Inf_NaN_Detection
compilation aborted for source/infnan.f90 (code 1)
source/constants_mod.f90(5): error #7001: Error in creating the compiled
module file. [CONSTANTS_MOD]
module constants_mod
compilation aborted for source/constants_mod.f90 (code 1)
source/vector_mod.f90(4): error #7001: Error in creating the compiled module
file. [VECTOR_MOD]
module vector_mod
compilation aborted for source/vector_mod.f90 (code 1)
source/common_mod.f90(240): warning #6379: The structure contains one or
more misaligned fields. [GRID_TYPE]
type grid_type ! derived grid type
source/common_mod.f90(4): error #7001: Error in creating the compiled module
file. [COMMON_MOD]
module common_mod
compilation aborted for source/common_mod.f90 (code 1)
source/interpolation_mod.f90(4): error #7001: Error in creating the compiled
module file. [INTERPOLATION_MOD]
module interpolation_mod
compilation aborted for source/interpolation_mod.f90 (code 1)
source/set_input_mod.f90(4): error #7001: Error in creating the compiled
module file. [SET_INPUT_MOD]
module set_input_mod
compilation aborted for source/set_input_mod.f90 (code 1)
source/hydro_mod.f90(4): error #7001: Error in creating the compiled module
file. [ELEMENTS_MOD]
module elements_mod
compilation aborted for source/hydro_mod.f90 (code 1)
source/ph_mod.f90(4): error #7001: Error in creating the compiled module
file. [XSEC_MOD]
module xSec_mod
compilation aborted for source/ph_mod.f90 (code 1)
source/composition_mod.f90(4): error #7001: Error in creating the compiled
module file. [COMPOSITION_MOD]
module composition_mod
compilation aborted for source/composition_mod.f90 (code 1)
source/continuum_mod.f90(4): error #7001: Error in creating the compiled
module file. [CONTINUUM_MOD]
module continuum_mod
compilation aborted for source/continuum_mod.f90 (code 1)
source/ionization_mod.f90(4): error #7001: Error in creating the compiled
module file. [IONIZATION_MOD]
module ionization_mod
compilation aborted for source/ionization_mod.f90 (code 1)
source/pathIntegration_mod.f90(4): error #7001: Error in creating the
compiled module file. [PATHINTEGRATION_MOD]
module pathIntegration_mod
compilation aborted for source/pathIntegration_mod.f90 (code 1)
source/grid_mod.f90(4): error #7001: Error in creating the compiled module
file. [GRID_MOD]
module grid_mod
compilation aborted for source/grid_mod.f90 (code 1)
source/dust_mod.f90(4): error #7001: Error in creating the compiled module
file. [DUST_MOD]
module dust_mod
compilation aborted for source/dust_mod.f90 (code 1)
source/emission_mod.f90(3109): remark #8291: Recommended relationship
between field width 'W' and the number of fractional digits 'D' in this edit
descriptor is 'W>=D+7'.
read(unit=19,fmt='(A2,I2,1x,A23,11x,A7,1x,F9.4,7x,F9.6,4x,F12.6,1x,I2,1x,I2,1x,E8.2,1x,E8.2,1x,I2)',
source/emission_mod.f90(4): error #7001: Error in creating the compiled
module file. [EMISSION_MOD]
module emission_mod
compilation aborted for source/emission_mod.f90 (code 1)
source/photon_mod.f90(4): error #7001: Error in creating the compiled module
file. [PHOTON_MOD]
module photon_mod
compilation aborted for source/photon_mod.f90 (code 1)
source/update_mod.f90(4): error #7001: Error in creating the compiled module
file. [UPDATE_MOD]
module update_mod
compilation aborted for source/update_mod.f90 (code 1)
source/output_mod.f90(3): error #7001: Error in creating the compiled module
file. [OUTPUT_MOD]
module output_mod
compilation aborted for source/output_mod.f90 (code 1)
source/iteration_mod.f90(544): warning #8093: A do-variable within a DO body
shall not appear in a variable definition context. [GPLOC]
& gpLoc=gpLoc, cellLoc=cellLoc)
source/iteration_mod.f90(547): warning #8093: A do-variable within a DO body
source/iteration_mod.f90(4): error #7001: Error in creating the compiled
module file. [ITERATION_MOD]
module iteration_mod
compilation aborted for source/iteration_mod.f90 (code 1)
make: *** [mocassin] Error 1
Carolina.
2011/10/24 Gus Correa <gus at ldeo.columbia.edu>
> Hi Carolina
> Sorry, now I see you used the full path to mpif90.
> You don't need to point to any MPI library or include directory,
> if you're using the mpif90 compiler wrapper.
> Note that uppercase "-L" and uppercase "-I"
> are used for lib and include directories,
> whereas lowercase L "-l" is used to name a specific library.
> However, if I understood it right, you seem to be using
> lowercase L "-l" to point to a path,
> and actually giving a path to include, not to a library.
> Anyway, make it simple, just use the mpif90 wrapper,
> and leave "LIBS= " blank in your makefile,
> and see if it compiles.
> As it is now, it may be confusing the linker.
> Also, better not to compile user programs as root,
> but as a regular user, in case you're doing this,
> as your prompt suggests.
> In addition, -O5 optimization may be quite tricky.
> Any reason to go beyond -O3?
> Check 'man ifort' or 'ifort -help opt'.
> I hope it helps,
> Gus Correa
> Carolina Carneiro wrote:
>> Hi guys,
>> I think the path to install directory was wrong, what's strange since I
>> did exactly what the mpich's read me said. Now I got this error:
>> root at carol-HP-Pavilion-dv5-**Notebook-PC:/home/carol/**mocassin/mocassin.2.02.69#
>> make mocassin
>> /home/carol/mocassin/mpich2-1.**4.1p1/bin/mpif90 -O5 -o mocassin
>> -l/home/carol/mocassin/mpich2-**1.4.1p1/src/include
>> read(unit=19,fmt='(A2,I2,1x,**A23,11x,A7,1x,F9.4,7x,F9.6,4x,**
>> F12.6,1x,I2,1x,I2,1x,E8.2,1x,**E8.2,1x,I2)', &
>> body shall not appear in a variable definition context. [GPLOC]
>> ld: cannot find -lroot at carol-HP-Pavilion-dv5-**Notebook-PC:/home/carol/**mocassin/mocassin.2.02.69#
>> make mocassin
>> ld: cannot find -l/home/carol/mocassin/mpich2-**1.4.1p1/src/include
>> ld: cannot find -lmpichf90
>> the directory path /home/carol/mocassin/mpich2-1.**4.1p1/src/include is
>> right, but this file mpichf90 I can't find. When I try "locate mpichf90"
>> nothing happens.
>> Carolina.
>> 2011/10/24 Gus Correa <gus at ldeo.columbia.edu <mailto:
>> gus at ldeo.columbia.edu>**>
>> HI Carolina
>> It is easier to use the MPI compiler wrapper than the
>> bare compiler, because the wrapper knows the MPI libraries it needs,
>> the MPI include files it needs, and where to find them.
>> I.e. try to change the F90 macro in the makefile to
>> F90=/your/path/to/mpich2/bin/_**_mpif90
>> My two cents,
>> Gus Correa
>> Hi,
>> I'm having problems to use the command make to compile a
>> makefile. I'm trying to link the makefile to the MPI library,
>> but it isn't working. Several errors are appearing:
>> root at carol-HP-Pavilion-dv5-__**Notebook-PC:/home/carol/__**
>> make mocassin
>> /opt/intel/composer_xe_2011___**sp1.6.233/composer_xe_2011___**
>> sp1.6.233/bin/intel64/ifort
>> -O5 -o mocassin source/infnan.f90 source/constants_mod.f90
>> source/vector_mod.f90 source/common_mod.f90
>> source/composition_mod.f90 source/continuum_mod.f90
>> source/ionization_mod.f90 source/pathIntegration_mod.f90
>> source/grid_mod.f90 source/dust_mod.f90 source/emission_mod.f90
>> source/mocassin.f90 -l/home/carol/mocassin/__**
>> mpich2install/include
>> contains one or more misaligned fields. [GRID_TYPE]
>> source/grid_mod.f90(491): error #5102: Cannot open include file
>> 'mpif.h'
>> include 'mpif.h'
>> source/dust_mod.f90(17): error #5102: Cannot open include file
>> 'mpif.h'
>> include 'mpif.h'
>> source/dust_mod.f90(97): error #6404: This name does not have a
>> type, and must have an explicit type. [MPI_REAL]
>> & mpi_real, mpi_sum, mpi_comm_world,
>> ierr)
>> ------------------------------**__^
>> type, and must have an explicit type. [MPI_SUM]
>> ierr)
>> ------------------------------**__----------^
>> type, and must have an explicit type. [MPI_COMM_WORLD]
>> ierr)
>> ------------------------------**__-------------------^
>> source/emission_mod.f90(8): error #7013: This module file was
>> not generated by any release of this compiler. [GRID_MOD]
>> use grid_mod
>> source/emission_mod.f90(217): error #6404: This name does not
>> have a type, and must have an explicit type. [GETVOLUME]
>> dV = getVolume(grid,ix,iy,iz)
>> source/emission_mod.f90(536): error #6404: This name does not
>> have a type, and must have an explicit type. [HLEVXSECP]
>> phXSecHI = xSecArray(i-HIPnuP+1+__**HlevXSecP(1)-1)
>> ------------------------------**__---------------^
>> source/emission_mod.f90(545): error #6404: This name does not
>> have a type, and must have an explicit type. [HEISINGXSECP]
>> phXSecHeI =
>> xSecArray(i-HeIPnuP+1+__**HeISingXSecP(1)-1)
>> ------------------------------**__--------------------^
>> source/emission_mod.f90(553): error #6404: This name does not
>> have a type, and must have an explicit type. [HEIIXSECP]
>> phXSecHeII =
>> xSecArray(i-HeIIPnuP+1+__**HeIIXSecP(1)-1)
>> ------------------------------**__--------------------------^
>> relationship between field width 'W' and the number of
>> fractional digits 'D' in this edit descriptor is 'W>=D+7'.
>> read(unit=19,fmt='(A2,I2,1x,__**
>> A23,11x,A7,1x,F9.4,7x,F9.6,4x,**__F12.6,1x,I2,1x,I2,1x,E8.2,**
>> 1x,__E8.2,1x,I2)',
>> ------------------------------**__----------------------------**
>> --__--------------------------**---^
>> 1x,__E8.2,1x,I2)',
>> --__--------------------------**----__-------^
>> source/photon_mod.f90(9): error #7013: This module file was not
>> use grid_mod
>> source/update_mod.f90(8): error #7013: This module file was not
>> generated by any release of this compiler. [EMISSION_MOD]
>> use emission_mod
>> source/update_mod.f90(234): error #6404: This name does not have
>> phXSec = xSecArray(j-IPnuP+1+HlevXSecP(**
>> __1)-1)
>> ------------------------------**__---------------------^
>> source/update_mod.f90(238): error #6404: This name does not have
>> phXSec =
>> xSecArray(j-IPnuP+1+__**HeISingXSecP(1)-1)
>> source/update_mod.f90(242): error #6404: This name does not have
>> phXSec = xSecArray(j-IPnuP+1+HeIIXSecP(**
>> __1)-1)
>> source/update_mod.f90(1304): error #6632: Keyword arguments are
>> invalid without an explicit interface. [FILE_NAME]
>> call
>> equilibrium(file_name=__**dataFile(elem, ion), &
>> ------------------------------**__------------^
>> source/update_mod.f90(1305): error #6632: Keyword arguments are
>> invalid without an explicit interface. [IONDENUP]
>> &ionDenUp=ionDenUsed(__**
>> elementXref(elem),ion+1)/&
>> ------------------------------**__-^
>> source/update_mod.f90(1306): error #6632: Keyword arguments are
>> invalid without an explicit interface. [TE]
>> &ionDenUsed(elementXref(elem),
>> **__ion), Te=TeUsed,&
>> --__------^
>> source/update_mod.f90(1307): error #6632: Keyword arguments are
>> invalid without an explicit interface. [NE]
>> &Ne=NeUsed,
>> FlineEm=forbiddenLinesLarge(&
>> invalid without an explicit interface. [FLINEEM]
>> &Ne=NeUsed,
>> source/update_mod.f90(1310): error #6632: Keyword arguments are
>> call
>> source/update_mod.f90(1311): error #6632: Keyword arguments are
>> &ionDenUp=0., Te=TeUsed,&
>> ------------------------------**__--------------^
>> source/update_mod.f90(1312): error #6632: Keyword arguments are
>> &Ne=NeUsed,
>> &Ne=NeUsed,
>> source/update_mod.f90(2033): error #6404: This name does not
>> have a type, and must have an explicit type. [RESLINE]
>> do imul = 1, resLine(iL)%nmul
>> source/update_mod.f90(2033): error #6837: The leftmost part-ref
>> in a data-ref can not be a function reference. [RESLINE]
>> source/update_mod.f90(2033): error #6158: The structure-name is
>> invalid or is missing. [RESLINE]
>> source/update_mod.f90(2034): error #6837: The leftmost part-ref
>> if (resLine(iL)%elem==1) then
>> source/update_mod.f90(2034): error #6158: The structure-name is
>> source/update_mod.f90(2034): internal error: Please visit
>> 'http://www.intel.com/__**software/products/support<http://www.intel.com/__software/products/support>
>> <http://www.intel.com/**software/products/support<http://www.intel.com/software/products/support>>'
>> for assistance.
>> [ Aborting due to internal error. ]
>> source/output_mod.f90(6): error #7013: This module file was not
>> use emission_mod
>> source/output_mod.f90(342): error #6404: This name does not have
>> a type, and must have an explicit type. [LOG10TE]
>> log10Te = log10(TeUsed)
>> source/output_mod.f90(343): error #6404: This name does not have
>> a type, and must have an explicit type. [LOG10NE]
>> log10Ne = log10(NeUsed)
>> source/output_mod.f90(344): error #6404: This name does not have
>> a type, and must have an explicit type. [SQRTEUSED]
>> sqrTeUsed = sqrt(TeUsed)
>> source/output_mod.f90(370): error #6410: This name has not been
>> declared as an array or a function. [HIRECLINES]
>> HIRecLines(iup, ilow) = &
>> ------------------------------**__--^
>> source/output_mod.f90(370): internal error: Please visit
>> for assistance.
>> source/iteration_mod.f90(35): error #5102: Cannot open include
>> file 'mpif.h'
>> include 'mpif.h'
>> source/iteration_mod.f90(7): error #7013: This module file was
>> not generated by any release of this compiler. [EMISSION_MOD]
>> use emission_mod
>> source/iteration_mod.f90(103): error #6404: This name does not
>> have a type, and must have an explicit type. [BJUMPTEMP]
>> BjumpTemp = 0.
>> source/iteration_mod.f90(153): error #6404: This name does not
>> have a type, and must have an explicit type. [MPI_REAL]
>> & mpi_real, mpi_sum, mpi_comm_world, ierr)
>> have a type, and must have an explicit type. [MPI_SUM]
>> ------------------------------**__----^
>> have a type, and must have an explicit type. [MPI_COMM_WORLD]
>> ------------------------------**__-------------^
>> source/iteration_mod.f90(477): error #6404: This name does not
>> have a type, and must have an explicit type. [TOTALESCAPED]
>> totalEscaped = 0.
>> source/iteration_mod.f90(543): error #6632: Keyword arguments
>> are invalid without an explicit interface. [ISTAR]
>> call
>> energyPacketDriver(iStar=0,n=_**_load, grid=grid(1:nGrids), &
>> are invalid without an explicit interface. [N]
>> call
>> --__----^
>> are invalid without an explicit interface. [GRID]
>> call
>> --__------------^
>> source/iteration_mod.f90(544): error #6632: Keyword arguments
>> are invalid without an explicit interface. [GPLOC]
>> ------------------------------**__---------^
>> are invalid without an explicit interface. [CELLLOC]
>> ------------------------------**__----------------------^
>> source/iteration_mod.f90(546): error #6632: Keyword arguments
>> call
>> call
>> --__----^
>> call
>> --__------------^
>> source/iteration_mod.f90(547): error #6632: Keyword arguments
>> source/iteration_mod.f90(574): error #6404: This name does not
>> have a type, and must have an explicit type. [MPI_INTEGER]
>> & mpi_integer, mpi_sum, mpi_comm_world, ierr)
>> source/mocassin.f90(43): error #5102: Cannot open include file
>> 'mpif.h'
>> include 'mpif.h'
>> source/mocassin.f90(34): error #7002: Error in opening the
>> compiled module file. Check INCLUDE paths. [DUST_MOD]
>> use dust_mod
>> source/mocassin.f90(35): error #7013: This module file was not
>> use grid_mod
>> source/mocassin.f90(55): error #6404: This name does not have a
>> call mpi_comm_rank(MPI_COMM_WORLD, taskid, ierr)
>> compilation aborted for source/mocassin.f90 (code 1)
>> The makefile is this:
>> source1 = source/infnan.f90 source/constants_mod.f90
>> source/interpolation_mod.f90 \
>> source/set_input_mod.f90 source/hydro_mod.f90
>> source/ph_mod.f90 source/composition_mod.f90 \
>> source/pathIntegration_mod.f90 \
>> source/emission_mod.f90 source/photon_mod.f90 \
>> source/update_mod.f90 \
>> source/mocassin.f90
>> source2 = source/infnan.f90 source/constants_mod.f90
>> source/mocassinWarm.f90
>> source3 = source/infnan.f90 source/constants_mod.f90
>> source/mocassinOutput.f90
>> source4 = source/infnan.f90 source/constants_mod.f90
>> source/mocassinPlot.f90
>> F90 =
>> LIBS = -l/home/carol/mocassin/__**mpich2install/include
>> OPT1 = -O5
>> OPT2 = -O5
>> mocassin:
>> $(F90) $(OPT1) -o mocassin $(source1) $(LIBS)
>> mocassinWarm:
>> $(F90) $(OPT1) -o mocassinWarm $(source2) $(LIBS)
>> mocassinOutput:
>> $(F90) $(OPT2) -o mocassinOutput $(source3) $(LIBS)
>> mocassinPlot:
>> $(F90) $(OPT2) -o mocassinPlot $(source4) $(LIBS)
>> clean:
>> /bin/rm *.o *~ *.mod mocassin mocassinWarm mocassinOutput
>> mocassinPlot
>> Does someone have a clue of what is the problem?
>> Thanks,
>> Carolina.
>> --__------------
>> ______________________________**___________________
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> <mailto:mpich-discuss at mcs.anl.**gov <mpich-discuss at mcs.anl.gov>>
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/__**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/__mailman/listinfo/mpich-discuss>
>> <https://lists.mcs.anl.gov/**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111025/04797054/attachment-0001.htm>
