[mpich-discuss] How codes are distributed?
Jierui XIE
jierui.xie at gmail.com
Mon Oct 24 22:09:05 CDT 2011
Thanks. Got it. One more question:
It seems that the instruction at
http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
is out of date. Following it, I was not able to run with Hydra
(mpich2-1.4.1, although mpd runs well ) with neither of the following
two commands.
mpiexec -f mpihosts.txt -n 2 /bin/hostname
mpiexec -machinefile mpihosts.txt -n 2 /bin/hostname
Any hins? Thanks.
On Mon, Oct 24, 2011 at 6:10 PM, Darius Buntinas <buntinas at mcs.anl.gov> wrote:
> No, the executable needs to be accessible from every node before you call mpiexec, e.g., using a shared filesystem. The process manager won't do that for you.
> -d
> On Oct 24, 2011, at 5:04 PM, Jierui XIE wrote:
>> Hello,
>> I am confused by a simple question. Hope someone can give me some hints.
>> When run mpiexec -n x program, I am assuming that the MPI will
>> distribute x processes to multiple machines.
>> Does it mean that one copy of the program would be copied to each machine??
>> Is this done by the process manager (e.g., mpd) on each machine?
>> Thanks.
>> Jerry
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
