[mpich-discuss] linking MPI
    Anthony Chan
    chan at mcs.anl.gov
    Mon Oct 24 11:41:04 CDT 2011
Assume mpich2 is installed in /home/carol/mocassin/mpich2install,
use /home/carol/mocassin/mpich2install/bin/mpif90 to compile/link
your f90 code.  If the error message about "missing mpif.h" remains,
send us your configure and make outputs as stated in the mpich2's
README file.
A.Chan
----- Original Message -----
> Hi,
> I'm having problems to use the command make to compile a makefile. I'm
> trying to link the makefile to the MPI library, but it isn't working.
> Several errors are appearing:
> root at carol-HP-Pavilion-dv5-Notebook-PC:/home/carol/mocassin/mocassin.2.02.69#
> make mocassin
> /opt/intel/composer_xe_2011_sp1.6.233/composer_xe_2011_sp1.6.233/bin/intel64/ifort
> -O5 -o mocassin source/infnan.f90 source/constants_mod.f90
> source/vector_mod.f90 source/common_mod.f90
> source/interpolation_mod.f90
> source/set_input_mod.f90 source/hydro_mod.f90 source/ph_mod.f90
> source/composition_mod.f90 source/continuum_mod.f90
> source/ionization_mod.f90 source/pathIntegration_mod.f90
> source/grid_mod.f90
> source/dust_mod.f90 source/emission_mod.f90 source/photon_mod.f90
> source/update_mod.f90 source/output_mod.f90 source/iteration_mod.f90
> source/mocassin.f90 -l/home/carol/mocassin/mpich2install/include
> source/common_mod.f90(240): warning #6379: The structure contains one
> or
> more misaligned fields. [GRID_TYPE]
> type grid_type ! derived grid type
> source/grid_mod.f90(491): error #5102: Cannot open include file
> 'mpif.h'
> include 'mpif.h'
> compilation aborted for source/grid_mod.f90 (code 1)
> source/dust_mod.f90(17): error #5102: Cannot open include file
> 'mpif.h'
> include 'mpif.h'
> source/dust_mod.f90(97): error #6404: This name does not have a type,
> and
> must have an explicit type. [MPI_REAL]
> & mpi_real, mpi_sum, mpi_comm_world, ierr)
> and
> must have an explicit type. [MPI_SUM]
> and
> must have an explicit type. [MPI_COMM_WORLD]
> compilation aborted for source/dust_mod.f90 (code 1)
> source/emission_mod.f90(8): error #7013: This module file was not
> generated
> by any release of this compiler. [GRID_MOD]
> use grid_mod
> source/emission_mod.f90(217): error #6404: This name does not have a
> type,
> and must have an explicit type. [GETVOLUME]
> dV = getVolume(grid,ix,iy,iz)
> source/emission_mod.f90(536): error #6404: This name does not have a
> type,
> and must have an explicit type. [HLEVXSECP]
> phXSecHI = xSecArray(i-HIPnuP+1+HlevXSecP(1)-1)
> source/emission_mod.f90(545): error #6404: This name does not have a
> type,
> and must have an explicit type. [HEISINGXSECP]
> phXSecHeI = xSecArray(i-HeIPnuP+1+HeISingXSecP(1)-1)
> source/emission_mod.f90(553): error #6404: This name does not have a
> type,
> and must have an explicit type. [HEIIXSECP]
> phXSecHeII = xSecArray(i-HeIIPnuP+1+HeIIXSecP(1)-1)
> source/emission_mod.f90(3109): remark #8291: Recommended relationship
> between field width 'W' and the number of fractional digits 'D' in
> this edit
> descriptor is 'W>=D+7'.
> read(unit=19,fmt='(A2,I2,1x,A23,11x,A7,1x,F9.4,7x,F9.6,4x,F12.6,1x,I2,1x,I2,1x,E8.2,1x,E8.2,1x,I2)',
> this edit
> compilation aborted for source/emission_mod.f90 (code 1)
> source/photon_mod.f90(9): error #7013: This module file was not
> generated by
> use grid_mod
> compilation aborted for source/photon_mod.f90 (code 1)
> source/update_mod.f90(8): error #7013: This module file was not
> generated by
> any release of this compiler. [EMISSION_MOD]
> use emission_mod
> source/update_mod.f90(234): error #6404: This name does not have a
> type, and
> phXSec = xSecArray(j-IPnuP+1+HlevXSecP(1)-1)
> source/update_mod.f90(238): error #6404: This name does not have a
> type, and
> phXSec = xSecArray(j-IPnuP+1+HeISingXSecP(1)-1)
> source/update_mod.f90(242): error #6404: This name does not have a
> type, and
> phXSec = xSecArray(j-IPnuP+1+HeIIXSecP(1)-1)
> source/update_mod.f90(1304): error #6632: Keyword arguments are
> invalid
> without an explicit interface. [FILE_NAME]
> call equilibrium(file_name=dataFile(elem, ion), &
> source/update_mod.f90(1305): error #6632: Keyword arguments are
> invalid
> without an explicit interface. [IONDENUP]
> &ionDenUp=ionDenUsed(elementXref(elem),ion+1)/&
> source/update_mod.f90(1306): error #6632: Keyword arguments are
> invalid
> without an explicit interface. [TE]
> &ionDenUsed(elementXref(elem),ion),
> Te=TeUsed,&
> source/update_mod.f90(1307): error #6632: Keyword arguments are
> invalid
> without an explicit interface. [NE]
> &Ne=NeUsed, FlineEm=forbiddenLinesLarge(&
> invalid
> without an explicit interface. [FLINEEM]
> source/update_mod.f90(1310): error #6632: Keyword arguments are
> invalid
> source/update_mod.f90(1311): error #6632: Keyword arguments are
> invalid
> &ionDenUp=0., Te=TeUsed,&
> invalid
> source/update_mod.f90(1312): error #6632: Keyword arguments are
> invalid
> invalid
> source/update_mod.f90(2033): error #6404: This name does not have a
> type,
> and must have an explicit type. [RESLINE]
> do imul = 1, resLine(iL)%nmul
> source/update_mod.f90(2033): error #6837: The leftmost part-ref in a
> data-ref can not be a function reference. [RESLINE]
> source/update_mod.f90(2033): error #6158: The structure-name is
> invalid or
> is missing. [RESLINE]
> source/update_mod.f90(2034): error #6837: The leftmost part-ref in a
> if (resLine(iL)%elem==1) then
> source/update_mod.f90(2034): error #6158: The structure-name is
> invalid or
> source/update_mod.f90(2034): internal error: Please visit '
> http://www.intel.com/software/products/support' for assistance.
> [ Aborting due to internal error. ]
> compilation aborted for source/update_mod.f90 (code 1)
> source/output_mod.f90(6): error #7013: This module file was not
> generated by
> use emission_mod
> source/output_mod.f90(342): error #6404: This name does not have a
> type, and
> must have an explicit type. [LOG10TE]
> log10Te = log10(TeUsed)
> source/output_mod.f90(343): error #6404: This name does not have a
> type, and
> must have an explicit type. [LOG10NE]
> log10Ne = log10(NeUsed)
> source/output_mod.f90(344): error #6404: This name does not have a
> type, and
> must have an explicit type. [SQRTEUSED]
> sqrTeUsed = sqrt(TeUsed)
> source/output_mod.f90(370): error #6410: This name has not been
> declared as
> an array or a function. [HIRECLINES]
> HIRecLines(iup, ilow) = &
> source/output_mod.f90(370): internal error: Please visit '
> compilation aborted for source/output_mod.f90 (code 1)
> source/iteration_mod.f90(35): error #5102: Cannot open include file
> 'mpif.h'
> include 'mpif.h'
> source/iteration_mod.f90(7): error #7013: This module file was not
> generated
> by any release of this compiler. [EMISSION_MOD]
> use emission_mod
> source/iteration_mod.f90(103): error #6404: This name does not have a
> type,
> and must have an explicit type. [BJUMPTEMP]
> BjumpTemp = 0.
> source/iteration_mod.f90(153): error #6404: This name does not have a
> type,
> and must have an explicit type. [MPI_REAL]
> type,
> and must have an explicit type. [MPI_SUM]
> type,
> and must have an explicit type. [MPI_COMM_WORLD]
> source/iteration_mod.f90(477): error #6404: This name does not have a
> type,
> and must have an explicit type. [TOTALESCAPED]
> totalEscaped = 0.
> source/iteration_mod.f90(543): error #6632: Keyword arguments are
> invalid
> without an explicit interface. [ISTAR]
> call energyPacketDriver(iStar=0,n=load,
> grid=grid(1:nGrids), &
> invalid
> without an explicit interface. [N]
> invalid
> without an explicit interface. [GRID]
> source/iteration_mod.f90(544): error #6632: Keyword arguments are
> invalid
> without an explicit interface. [GPLOC]
> & gpLoc=gpLoc, cellLoc=cellLoc)
> invalid
> without an explicit interface. [CELLLOC]
> source/iteration_mod.f90(546): error #6632: Keyword arguments are
> invalid
> invalid
> invalid
> source/iteration_mod.f90(547): error #6632: Keyword arguments are
> invalid
> invalid
> source/iteration_mod.f90(574): error #6404: This name does not have a
> type,
> and must have an explicit type. [MPI_INTEGER]
> & mpi_integer, mpi_sum, mpi_comm_world, ierr)
> compilation aborted for source/iteration_mod.f90 (code 1)
> source/mocassin.f90(43): error #5102: Cannot open include file
> 'mpif.h'
> include 'mpif.h'
> source/mocassin.f90(34): error #7002: Error in opening the compiled
> module
> file. Check INCLUDE paths. [DUST_MOD]
> use dust_mod
> source/mocassin.f90(35): error #7013: This module file was not
> generated by
> use grid_mod
> source/mocassin.f90(55): error #6404: This name does not have a type,
> and
> call mpi_comm_rank(MPI_COMM_WORLD, taskid, ierr)
> compilation aborted for source/mocassin.f90 (code 1)
> make: *** [mocassin] Error 1
> The makefile is this:
> source1 = source/infnan.f90 source/constants_mod.f90
> source/common_mod.f90 source/interpolation_mod.f90 \
> source/composition_mod.f90 \
> source/continuum_mod.f90 source/ionization_mod.f90
> source/pathIntegration_mod.f90 \
> source/grid_mod.f90 source/dust_mod.f90 source/emission_mod.f90
> source/photon_mod.f90 \
> source/update_mod.f90 \
> source/output_mod.f90 source/iteration_mod.f90 source/mocassin.f90
> source2 = source/infnan.f90 source/constants_mod.f90
> source/output_mod.f90 source/iteration_mod.f90 source/mocassinWarm.f90
> source3 = source/infnan.f90 source/constants_mod.f90
> source/mocassinOutput.f90
> source4 = source/infnan.f90 source/constants_mod.f90
> source/output_mod.f90 source/iteration_mod.f90 source/mocassinPlot.f90
> F90 =
> LIBS = -l/home/carol/mocassin/mpich2install/include
> OPT1 = -O5
> OPT2 = -O5
> mocassin:
> $(F90) $(OPT1) -o mocassin $(source1) $(LIBS)
> mocassinWarm:
> $(F90) $(OPT1) -o mocassinWarm $(source2) $(LIBS)
> mocassinOutput:
> $(F90) $(OPT2) -o mocassinOutput $(source3) $(LIBS)
> mocassinPlot:
> $(F90) $(OPT2) -o mocassinPlot $(source4) $(LIBS)
> clean:
> /bin/rm *.o *~ *.mod mocassin mocassinWarm mocassinOutput mocassinPlot
> Does someone have a clue of what is the problem?
> Thanks,
> Carolina.
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
