[mpich-discuss] MPID_nem_tcp_connpoll(1826): Communication error with rank 0: Connection refused
Pavan Balaji
balaji at mcs.anl.gov
Sat Oct 22 16:20:43 CDT 2011
It picks whichever port it can find. It's not fixed.
This does look like a firewall problem. Most firewalls, keep the ssh
port (22) open, so being able to do an ssh doesn't mean there's no firewall.
On 10/22/2011 03:46 PM, Miguel Angel Fernández wrote:
> Hi Rajeev
> Thanks for your response but there is no any firewall among them.
> mpi0 is Ubuntu
> mpi1 to mpi4 are Debian (minimun distribution without GUI)
> I am doing the conection among them with ssh and it is well configured
> and properly working, I tested it.
> I am thinking,...are you using a socket conettion to comunicate the
> diferent processes? This could be the problem in the Ubuntu one (mpi0).
> If this is the case, can you tell me the exactly socket you are using?
> Thanks
> Miguel Angel
> > From: thakur at mcs.anl.gov
> > Date: Sat, 22 Oct 2011 15:30:26 -0500
> > To: mpich-discuss at mcs.anl.gov
> > Subject: Re: [mpich-discuss] MPID_nem_tcp_connpoll(1826):
> > Make sure the 5 machines can communicate with each other, i.e., there
> is no firewall preventing connections.
> > Rajeev
> > On Oct 22, 2011, at 12:36 PM, Miguel Angel Fernández wrote:
> > > Hello everybody
> > > I'm trying to fix a problem that appear when I execute one of the
> mpich2 program examples.
> > > As you can see, if I execute a normal command there are no
> problems. The cluster work properly.
> > > mpi at mpi0:~$ mpiexec -f ./mpich2-install/machinefile -n 5 hostname
> > > mpi0
> > > mpi2
> > > mpi3
> > > mpi1
> > > mpi4
> > > mpi at mpi0:~$
> > > but when I try to execute the program, the results are something
> like this
> /home/mpi/mpich2-install/workspace/Prueba/Debug/Prueba
> > > Hello MPI World the original.
> > > From process 0: Num processes: 5
> > > Fatal error in MPI_Send: Other MPI error, error stack:
> > > MPI_Send(173)..............: MPI_Send(buf=0xbfcbe268, count=26,
> MPI_CHAR, dest=0, tag=0, MPI_COMM_WORLD) failed
> Connection refused
> > > MPI_Send(173)..............: MPI_Send(buf=0xbfb32ca8, count=26,
> Connection refused
> > > MPI_Send(173)..............: MPI_Send(buf=0xbfa49e98, count=26,
> Connection refused
> > > MPI_Send(173)..............: MPI_Send(buf=0xbfa57538, count=26,
> Connection refused
> > > Do you have any idea what can be the problem?
> > > Thank you in advance
> > > Miguel Angel
> > > _______________________________________________
> > > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> > > To manage subscription options or unsubscribe:
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
http://www.mcs.anl.gov/~balaji
